cancellare file con etrecheck
oceanoprofondo7
Oggetto del messaggio: cancellare file con etrecheck
Messaggio da oceanoprofondo7 »
ho fatto una ripassata con etrecheck perche ultimamente si blocca spesso il mio mac, forse conviene una ripulita totale? non capisco che errori mi da.
grazie
EtreCheck version: 3.4.6 (460)
Report generated 2018-02-06 22:14:51
Runtime: 1:57
Performance: Excellent
Click the [Clean up] link to delete unused files.
Problem: Beachballing
Hardware Information: ⓘ
MacBook Pro (Retina, 15-inch, Mid 2015)
MacBook Pro - model: MacBookPro11,5
1 2,5 GHz Intel Core i7 (i7-4870HQ) CPU: 4-core
16 GB RAM Not upgradeable
BANK 0/DIMM0
8 GB DDR3 1600 MHz ok
BANK 1/DIMM0
Handoff/Airdrop2: supported
Wireless: en0: 802.11 a/b/g/n/ac
Battery: Health = Normal - Cycle count = 405
iCloud Quota: 128.96 GB available
Video Information: ⓘ
AMD Radeon R9 M370X - VRAM: 2048 MB
Intel Iris Pro - VRAM: 1536 MB
Color LCD
Disk Information: ⓘ
APPLE SSD SM0512G disk0: (500,28 GB) (Solid State - TRIM: Yes)
[Show SMART report]
(disk0s2) <not mounted> [APFS Container]: 499.41 GB
(disk0s3) <not mounted> [KernelCoreDump]: 655 MB
USB Information: ⓘ
USB30Bus
Broadcom Corp. Bluetooth USB Host Controller
Thunderbolt Information: ⓘ
Apple Inc. thunderbolt_bus
Virtual disks: ⓘ
(disk1s1 - APFS) / [Startup]: 499.41 GB (91.61 GB free)
Physical disk: disk0s2 499.41 GB (91.61 GB free)
(disk1s2) <not mounted> [Preboot]: 499.41 GB
(disk1s3) <not mounted> [Recovery]: 499.41 GB
(disk1s4) /private/var/vm [VM]: 499.41 GB
System Software: ⓘ
macOS High Sierra 10.13.4 (17E139j) - Time since boot: about one day
Gatekeeper: ⓘ
Clean up: ⓘ
/System/Library/LaunchAgents/com.apple.corespeechd.plist
/System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd
Executable not found!
One orphan file found. [Clean up]
Kernel Extensions: ⓘ
/Applications/MacX Video Converter Pro.app
[not loaded] com.macxdvd.driver.goodSysAudioCapture (1.0 - SDK 10.10) [Lookup]
/Applications/iTube Studio.app
[not loaded] com.Perfect.Driver.SystemAudioRecorder (1.1.0 - SDK 10.6) [Lookup]
/Library/Application Support/com.adguard.Adguard/kext
[not loaded] com.adguard.nfext (1.0.4 - SDK 10.11) [Lookup]
System Launch Agents: ⓘ
[failed] com.apple.corespeechd.plist (? ? ? - installed 2017-11-01) - /System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd: Executable not found!
[not loaded] 8 Apple tasks
[loaded] 161 Apple tasks
[running] 124 Apple tasks
System Launch Daemons: ⓘ
[not loaded] 37 Apple tasks
[loaded] 172 Apple tasks
[running] 125 Apple tasks
Launch Agents: ⓘ
[running] com.epson.scannermonitor.plist (Seiko Epson Corporation - installed 2016-09-25) [Lookup]
[failed] com.google.keystone.agent.plist (Google, Inc. - installed 2017-09-28) [Lookup]
Launch Daemons: ⓘ
[loaded] com.adobe.fpsaud.plist (Adobe Systems, Inc. - installed 2017-12-15) [Lookup]
[loaded] com.google.keystone.daemon.plist (Google, Inc. - installed 2017-10-13) [Lookup]
[loaded] com.malwarebytes.HelperTool.plist (Malwarebytes Corporation - installed 2017-02-07) [Lookup]
User Launch Agents: ⓘ
[loaded] com.valvesoftware.steamclean.plist (? c25d3a02 6db598b5 - installed 2017-12-09) [Lookup]
User Login Items: ⓘ
iTunesHelper Applicazione (Apple, Inc. - installed 2018-01-24)
(/Applications/iTunes.app/Contents/MacOS/iTunesHelper.app)
MailButler Applicazione
(/Applications/MailButler.app)
iTranslateHelper SMLoginItem - Hidden (Apple, Inc. - installed 2017-11-23)
(/Applications/iTranslate.app/Contents/Library/LoginItems/iTranslateHelper.app)
goproapp.devicedetection SMLoginItem - Hidden (Woodman Labs, Inc. - installed 2017-10-14)
(/Applications/GoPro Quik.app/Contents/Library/LoginItems/goproapp.devicedetection.app)
Internet Plug-ins: ⓘ
Silverlight: 5.1.50901.0 (installed 2017-05-04) [Lookup]
FlashPlayer-10.6: 28.0.0.137 (installed 2018-01-09) [Lookup]
Flash Player: 28.0.0.137 (installed 2018-01-09) Outdated! Update
QuickTime Plugin: 7.7.3 (installed 2018-01-27)
PepperFlashPlayer: 28.0.0.137 (installed 2018-01-10) [Lookup]
Safari Extensions: ⓘ
[not loaded] Open in Internet Explorer - Parallels - http://www.parallels.com" onclick="window.open(this.href);return false; (installed 2017-08-02)
[disabled] Ka-Block! - David Graham & Josh Peek - http://kablock.com" onclick="window.open(this.href);return false; (installed 2018-02-06)
[enabled] Amazon Assistant for Safari - Amazon - https://www.amazon.com/gp/BIT/AmazonAssistant/TOU" onclick="window.open(this.href);return false; (installed 2018-01-15)
[disabled] Adamant - Cocoa App - http://cocoaapp.com/adamant" onclick="window.open(this.href);return false; (installed 2016-12-14)
[disabled] Adblock Plus - Eyeo GmbH - https://adblockplus.org/" onclick="window.open(this.href);return false; (installed 2017-02-13)
[disabled] Ghostery - GHOSTERY, Inc. - https://www.ghostery.com/" onclick="window.open(this.href);return false; (installed 2018-02-06)
[enabled] Wipr - Giorgio Calderolla - http://giorgiocalderolla.com/" onclick="window.open(this.href);return false; (installed 2018-02-04)
[disabled] AdBlock - BetaFish, Inc. - https://getadblock.com" onclick="window.open(this.href);return false; (installed 2017-11-17)
[disabled] AdGuard AdBlocker - adguard - http://adguard.com" onclick="window.open(this.href);return false; (installed 2018-02-06)
[enabled] Translate - SideTree.com - Apps for Mac - http://SideTree.com/extensions.html#Translate" onclick="window.open(this.href);return false; (installed 2017-08-29)
3rd Party Preference Panes: ⓘ
Flash Player (installed 2017-12-15) [Lookup]
Time Machine: ⓘ
Mobile backups: OFF
Volumes being backed up:
: Disk size: 499.41 GB Disk used: 407.80 GB
Destinations:
LaCie [Local]
Total size: 0 B
Total number of backups: 0
Oldest backup: -
Last backup: -
Backup size 0 B < (Disk used 407.80 GB X 3)
Top Processes by CPU: ⓘ
15% mdworker
15% mdworker
10% mds
7% WindowServer
6% coreaudiod
Top Processes by Memory: ⓘ
1.36 GB kernel_task
179 MB com.apple.SpeechRecognitionCore.speechrecognitiond
114 MB spindump
76 MB installd
73 MB WindowServer
Input Output Process name
10 MB 10 MB mDNSResponder
123 KB 50 KB netbiosd
17 KB 10 KB apsd
7 KB 2 KB cloudd
6 KB 1 KB iTranslate
11.90 coreaudiod
8.86 WindowServer
6.94 com.apple.SpeechRecognitionCore.speechrecognitiond
3.12 DictationIM
Virtual Memory Information: ⓘ
11.25 GB Available RAM
8.98 GB Free RAM
4.75 GB Used RAM
2.27 GB Cached files
512 MB Swap Used
Spark: 1.5.6 (installed 2018-01-09)
Adobe Flash Player: (installed 2018-01-09)
Adobe Pepper Flash Player: (installed 2018-01-10)
WhatsApp: 0.2.8000 (installed 2018-01-18)
ShutterCount: 3.3 (installed 2018-01-19)
Mactracker: 7.7.1 (installed 2018-01-23)
WhatsApp: 0.2.8082 (installed 2018-02-01)
Mactracker: 7.7.2 (installed 2018-02-06)
2018-02-06 09:35:57 fud Crash [Open]
Cause: objc_msgSend() selector name: respondsToSelector:
2018-02-05 23:29:07 com.apple.WebKit.WebContent High CPU use [Open] [Details]
2018-02-05 14:03:04 Last shutdown cause: -60 - Corrupt filesystem
 - MacBook Pro 15" (2008)
 - iPhone 4s • 32gb • Nero
 - Ipad 1 • 16gb • Wifi •
Uno_qualunque
Oggetto del messaggio: Re: cancellare file con etrecheck
Messaggio da Uno_qualunque »
oceanoprofondo7 ha scritto: 2018-02-05 14:03:04 Last shutdown cause: -60 - Corrupt filesystem
Brutto brutto.
Direi che c'e' da fare qualche controllo approfondito sul disco.
oceanoprofondo7
presti il mac a qualcuno e poi ritorna con problemi... addirittura il disco... che bella settimana con tutte notizie positive vedo ;(
Messaggio da Jethro »
Ma magari basta fare una riparazione del disco con Utility Disco...
Non ne sono certo, ma visto che provare non costa nulla farei un tentativo.
(Credo meglio se riavviando da una altro disco o dalla partizione di recupero)
oceanoprofondo7
per quello chiedo sempre a voi le procedure corrette. anche perche a maggio mi scadono i 2 anni di garanzia
