Problemi CPU e IMAC bloccato - UserEventAgent? Help
Clallo
Buonasera a tutti,
ho un problema e il mio IMAC da alcuni giorni non funziona più. Le ho provate tutte ma la CPU ci impalla e il processo UserEventAgent arriva a occupare circa il 99% della CPU
Posto di seguito l'analisi fatta con EtreCheck (ci ha messo quasi due ore!) sperando che qualche angelo del forum possa aiutarmi.
Graazie!
EtreCheck version: 3.4.6 (460)
Report generated 2017-12-18 20:17:44
Runtime: 32:46
Performance: Poor
Click the [Clean up] link to delete unused files.
Problem: Computer is too slow
Description:
too too too slow
Hardware Information: ⓘ
iMac (27-inch, Late 2012)
iMac - model: iMac13,2
1 2,9 GHz Intel Core i5 (i5-3470S) CPU: 4-core
BANK 0/DIMM0
4 GB DDR3 1600 MHz ok
BANK 1/DIMM0
BANK 0/DIMM1
Empty
BANK 1/DIMM1
Empty
Handoff/Airdrop2: supported
Wireless: en1: 802.11 a/b/g/n
Video Information: ⓘ
NVIDIA GeForce GTX 660M - VRAM: 512 MB
iMac 2560 x 1440
SAMSUNG 2560 x 1440 @ 60 Hz
Disk Information: ⓘ
APPLE HDD ST1000DM003 disk0: (1 TB) (Rotational)
[Show SMART report]
Macintosh HD (disk0s2 - Journaled HFS+) / [Startup]: 999.35 GB (110.78 GB free)
(disk0s3) <not mounted> [Recovery]: 650 MB
USB Information: ⓘ
USB20Bus
hub_device
USB20Bus
hub_device
hub_device
Apple Inc. BRCM20702 Hub
USB30Bus
Thunderbolt Information: ⓘ
Apple Inc. thunderbolt_bus
System Software: ⓘ
macOS High Sierra 10.13.1 (17B1003) - Time since boot: less than an hour
Configuration files: ⓘ
/etc/hosts - Count: 30
Gatekeeper: ⓘ
Clean up: ⓘ
/Library/LaunchAgents/com.divx.update.agent.plist
/Library/Application Support/DivX/DivXUpdate.app/Contents/MacOS/DivXUpdate
Executable not found!
/Library/LaunchAgents/com.kaspersky.kav.gui.plist
open -a Kaspersky Anti-Virus.app
2 orphan files found. [Clean up]
Kernel Extensions: ⓘ
/Library/Application Support/Roxio
[not loaded] com.roxio.TDIXController (1.7) [Lookup]
/Library/Application Support/WDSmartWare
[not loaded] com.wdc.driver.1394HP (1.0.9) [Lookup]
[not loaded] com.wdc.driver.USBHP (1.0.11) [Lookup]
/Library/Extensions
[not loaded] com.FTDI.driver.D2XXHelper (1.0 - SDK 10.11) [Lookup]
[not loaded] com.sophos.kext.sav (9.4.50 - SDK 10.9) [Lookup]
[not loaded] com.sophos.nke.swi (9.4.50 - SDK 10.9) [Lookup]
/System/Library/Extensions
[not loaded] com.Cycling74.driver.Soundflower (1.4.3) [Lookup]
[not loaded] com.avira.kext.FileAccessControl (1.0.0d1 - SDK 10.9) [Lookup]
[loaded] com.corel.painter.PainterAudioDriver (1.0 - SDK 10.9) [Lookup]
[not loaded] com.pctools.iantivirus.kfs (1.0.1) [Lookup]
[not loaded] com.roxio.BluRaySupport (1.1.3) [Lookup]
[not loaded] com.wacom.kext.wacomtablet (Wacom Tablet 6.3.6-4 - SDK 10.8) [Lookup]
Startup Items: ⓘ
ChmodBPF: Path: /Library/StartupItems/ChmodBPF
EyeConnect: Path: /Library/StartupItems/EyeConnect
ProTec6b: Path: /Library/StartupItems/ProTec6b
Startup items no longer function in OS X Yosemite or later
System Launch Agents: ⓘ
[not loaded] 8 Apple tasks
[loaded] 175 Apple tasks
[running] 73 Apple tasks
[killed] 32 Apple tasks
32 processes killed due to insufficient RAM
System Launch Daemons: ⓘ
[not loaded] 35 Apple tasks
[loaded] 190 Apple tasks
[running] 78 Apple tasks
[killed] 28 Apple tasks
28 processes killed due to insufficient RAM
Launch Agents: ⓘ
[not loaded] com.adobe.AAM.Updater-1.0.plist (Adobe Systems, Inc. - installed 2017-05-27) [Lookup]
[loaded] com.divx.uninstall.converter.plist (Shell Script 9e90dee7 - installed 2017-10-25)
[loaded] com.divx.uninstall.player.plist (Shell Script 664f994d - installed 2017-10-25)
[loaded] com.divx.uninstall.preferences.plist (Shell Script 1cd1d81c - installed 2017-10-25)
[loaded] com.divx.update.agent.plist (? a041d049 0 - installed 2016-09-22) [Lookup] - /Library/Application Support/DivX/DivXUpdate.app/Contents/MacOS/DivXUpdate: Executable not found!
[loaded] com.kaspersky.kav.gui.plist (? 72469ece 0 - installed 2014-10-21) [Lookup] - Kaspersky Anti-Virus.app: Executable not found!
[not loaded] com.maintain.LogOut.plist (Shell Script 52c16c4b - installed 2017-10-25)
[not loaded] com.maintain.PurgeInactiveMemory.plist (Apple, Inc. - installed 2017-10-25)
[not loaded] com.maintain.Restart.plist (Shell Script b392741a - installed 2017-10-25)
[not loaded] com.maintain.ShutDown.plist (Shell Script 83dbe49b - installed 2017-10-25)
[not loaded] com.maintain.Sleep.plist (Shell Script 269361ac - installed 2017-10-25)
[running] jp.co.canon.SELPHYCP.BG.plist (? 6c0813be a7990858 - installed 2014-06-22) [Lookup]
[not loaded] net.culater.SIMBL.Agent.plist (? 850e6250 aeee4209 - installed 2010-02-23) [Lookup]
[loaded] org.macosforge.xquartz.startx.plist (Apple Inc. - XQuartz - installed 2012-09-28) [Lookup]
Launch Daemons: ⓘ
[loaded] com.adobe.SwitchBoard.plist (? 856489a3 0 - installed 2014-11-14) [Lookup]
[running] com.adobe.adobeupdatedaemon.plist (Adobe Systems, Inc. - installed 2017-05-21) [Lookup]
[running] com.adobe.agsservice.plist (Adobe Systems, Inc. - installed 2017-09-28) [Lookup]
[loaded] com.adobe.fpsaud.plist (? 2afb3af7 6cf41d3c - installed 2016-04-16) [Lookup]
[loaded] com.avast.osx.secureline.init.plist (Shell Script 1bda83b1 - installed 2017-10-24) [Lookup]
[loaded] com.avast.osx.secureline.uninstall.plist (Shell Script ba7a0061 - installed 2017-10-24) [Lookup]
[loaded] com.avast.osx.secureline.update.plist (Shell Script f50a649c - installed 2017-10-24) [Lookup]
[running] com.daz3d.content_management_service.plist (? 4223a539 afc8b660 - installed 2014-03-17) [Lookup]
[running] com.easeus.dataprotectbackup.plist (? ? ? - installed 2017-12-10) [Lookup]
[loaded] com.google.keystone.daemon.plist (Google, Inc. - installed 2017-10-13) [Lookup]
[failed] com.kaspersky.klif_loader.plist (Apple, Inc. - installed 2017-10-25)
[loaded] com.macpaw.CleanMyMac2.Agent.plist (? 753d8be6 e456392f - installed 2017-12-10) [Lookup]
[not loaded] com.maintain.AutoLoginUserScreenLocked.plist (Apple, Inc. - installed 2017-10-25)
[not loaded] com.maintain.CocktailScheduler.plist (Shell Script da64ddf8 - installed 2017-10-25)
[not loaded] com.maintain.HideSpotlightMenuBarIcon.plist (Apple, Inc. - installed 2017-10-25)
[loaded] com.malwarebytes.HelperTool.plist (Malwarebytes Corporation - installed 2017-04-24) [Lookup]
[loaded] com.microsoft.office.licensing.helper.plist (? 6d8cb30e afb3bef0 - installed 2010-09-23) [Lookup]
[loaded] com.prosofteng.PRInstaller.plist (PROSOFT Engineering, Inc. - installed 2017-10-05) [Lookup]
[loaded] com.wacom.displayhelper.plist (Apple, Inc. - installed 2017-10-25)
[loaded] org.macosforge.xquartz.privileged_startx.plist (Apple Inc. - XQuartz - installed 2012-09-28) [Lookup]
User Launch Agents: ⓘ
[loaded] com.adobe.AAM.Updater-1.0.plist (Adobe Systems, Inc. - installed 2017-05-27) [Lookup]
[loaded] com.dropbox.DropboxMacUpdate.agent.plist (Dropbox, Inc. - installed 2017-08-12) [Lookup]
[loaded] com.google.keystone.agent.plist (Google, Inc. - installed 2017-12-10) [Lookup]
[loaded] com.macpaw.CleanMyMac2Helper.scheduledScan.plist (MacPaw Inc. - installed 2017-12-17) [Lookup]
[loaded] com.macpaw.CleanMyMac2Helper.trashWatcher.plist (MacPaw Inc. - installed 2017-12-17) [Lookup]
[loaded] com.redgiantsoftware.updater.plist (? 63cc02c7 0 - installed 2017-10-10) [Lookup]
User Login Items: ⓘ
6H4HRTU5E3.com.avast.osx.secureline.avastsecurelinehelper SMLoginItem - Hidden (AVAST Software a.s. - installed 2017-11-25)
(/Applications/AvastSecureLine.app/Contents/Library/LoginItems/6H4HRTU5E3.com.avast.osx.secureline.avastsecurelinehelper.app)
ATLoginItemHelper SMLoginItem - Hidden (Apple, Inc. - installed 2017-12-10)
(/Applications/DrCleaner.app/Contents/Library/LoginItems/ATLoginItemHelper.app)
TuneUpHelper SMLoginItem - Hidden (GMGP LLC - installed 2017-01-30)
(/Applications/TuneUp.app/Contents/Library/LoginItems/TuneUpHelper.app)
com.adobe.SwitchBoard.monitor.plist MachInit - Hidden
(/etc/mach_init_per_user.d/com.adobe.SwitchBoard.monitor.plist)
Mach Init items are deprecated
Internet Plug-ins: ⓘ
JavaAppletPlugin: 15.0.1 (installed 2013-10-27) Check version
3rd Party Preference Panes: ⓘ
None
Time Machine: ⓘ
Time Machine not configured!
Top Processes by CPU: ⓘ
27% UserEventAgent
10% kernel_task
3% WindowServer
3% lsd
0% ps
Top Processes by Memory: ⓘ
4.73 GB kernel_task
865 MB UserEventAgent
20 MB mds_stores
16 MB WindowServer
15 MB routined
Input Output Process name
159 KB 46 KB mDNSResponder
35 KB 6 KB netbiosd
11 KB 21 KB apsd
0 B 64 B SystemUIServer
46.88 UserEventAgent
5.80 lsd
5.18 WindowServer
1.54 trustd
Virtual Memory Information: ⓘ
277 MB Available RAM
3 MB Free RAM
7.73 GB Used RAM
274 MB Cached files
10.44 GB Swap Used
2017-12-18 18:58:37 SIMBL Agent.app Crash [Open]
Cause: dyld: launch, running initializers
/usr/lib/libSystem.B.dylib
2017-12-18 00:53:32 Avast.app Crash [Open]
Cause: dyld: launch, loading dependent libraries
2017-12-18 00:34:27 ~/Library/Logs/DiagnosticReports/cloudd_2017-12-18-003427_[redacted].crash Crash [Open]
Kundalini
Ciao, sto uscendo ed ho buttato un occhio velocemente.
Avast, Kaspersky, CleanmyMac, sophos ed un mucchio di altra porcheria.
È un mezzo miracolo che quel Mac si accenda ancora. Ti verranno dati dei consigli, magari più tardi se faccio in tempo lo farò anche io.
Certo che siamo quasi al limite dell' "Inizializza e reinstalla".
Il link sopra è per presentarti, hai diritto ad un nuovo topic tutto tuo :) .
Se funziona, non aggiustarlo.
Clallo
Grazie provo a fare un po' di pulizia anche se con il MAC così ridotto ci metterò una vita.. :cry:
Kundalini ha scritto:... Avast, Kaspersky, CleanmyMac, sophos ...
C'è anche Avira e iAntivirus...
Intanto benvenuto Clallo!
E tracce di vaiolo .....
Qualcuno prenda il primo messaggio dell'utente e crei un nuovo topic in una sezione di aiuto tecnico, altrimenti l'infezione si propagherà a tutto il forum .....
Clallo
Fatto! Mi sono trasferito sul tipico giusto....
Clallo ha scritto:Fatto! Mi sono trasferito sul tipico giusto....
E cioè?
Scasi_1980
Buongiorno a tutti\e,
non capisco come mai la mia risposta che ho dato all’utente Clallo, sia stata cancellata da qualche moderatore. Vi chiedo pertanto spiegazioni in merito.
Capisco che la mia risposta non era ben articolata, però almeno informarmi e darmi motivazioni del perché sia stata tolta penso sia lecito.
Buon proseguimento di giornata a tutti\e.
Saluti.
Scasi_1980.
Albert Einstein
Probabilmente hai postato la tua risposta nello stesso istante in cui è avvenuto il trasferimento del topic.
Buon tutto.
Scasi_1980 ha scritto:Buongiorno a tutti\e,
Saluti.
Scasi_1980.
Controlla, manca effettivamente o è rimasta impigliata altrove?
search.php?author_id=8889&sr=posts" onclick="window.open(this.href);return false;
Clallo
Ecco il nuovo topic in Software:"IMAC bloccato - UserEventAgent impegna la CPU al 99%"
C
Scasi_1980
Saluti.
Scasi_1980.
Buonasera franz,
nel link che mi hai dato non la vedo, ma comunque io scritto la mia risposta citando il suo argomento. Comunque grazie ancora e Buon Natale Franz.
Albert Einstein
Scasi_1980 ha scritto:... la mia risposta che ho dato all’utente Clallo...
Sta qui.
viewtopic.php?f=9&t=42411&p=463294#p463195" onclick="window.open(this.href);return false;
Il Forum nasconde, ma non ruba...
Visitano il forum: Google [Bot] e 48 ospiti
