si intendevo link simbolici io ho usato questo programma SymbolicLinker. Quindi a sto punto, i link simbolici non possono essere, l'sed neanche, a questo punto non riesco proprio a capire quale potrebbe essere il problema.
@faxus il risultato di etrecheck
EtreCheck version: 3.4.6 (460)
Report generated 2017-10-10 22:07:51
Download EtreCheck from
https://etrecheck.com" onclick="window.open(this.href);return false;
Runtime: 4:23
Performance: Good
Problem: Other problem
Hardware Information: ⓘ
iMac Intel Core i5, Intel Core i7 (widescreen, Late 2009)
iMac - model: iMac11,1
1 2,66 GHz Intel Core i5 (i5) CPU: 4-core
12 GB RAM Upgradeable - [Instructions]
BANK 0/DIMM0
2 GB DDR3 1067 MHz ok
BANK 1/DIMM0
BANK 0/DIMM1
4 GB DDR3 1067 MHz ok
BANK 1/DIMM1
Wireless: en1: 802.11 a/b/g/n
Video Information: ⓘ
ATI Radeon HD 4850 - VRAM: 512 MB
iMac 2560 x 1440
Disk Information: ⓘ
ST31000528ASQ disk1: (1 TB) (Rotational)
[Show SMART report]
EFI (disk1s1 - MS-DOS FAT32) <not mounted> [EFI]: 210 MB
Macintosh HD (disk1s2 - Journaled HFS+) /Volumes/Macintosh HD : 850.30 GB (653.19 GB free)
Recovery HD (disk1s3 - Journaled HFS+) <not mounted> [Recovery]: 650 MB
BOOTCAMP (disk1s4 - Tuxera NTFS) /Volumes/BOOTCAMP : 148.91 GB (99.04 GB free)
Samsung SSD 850 EVO 500GB disk0: (500,11 GB) (Solid State - TRIM: Yes)
[Show SMART report]
Macintosh SSD (disk0s2 - Journaled HFS+) / [Startup]: 499.11 GB (383.13 GB free)
Recovery HD (disk0s3 - Journaled HFS+) <not mounted> [Recovery]: 650 MB
USB Information: ⓘ
USB20Bus
hub_device
USB OPTICAL MOUSE
Hauppauge Nova-T Stick
Apple Card Reader
Apple Inc. BRCM2046 Hub
USB20Bus
hub_device
USB2.0 Hub
USB2.0 Hub
Apple Inc. Built-in iSight
System Software: ⓘ
macOS Sierra 10.12.6 (16G29) - Time since boot: less than an hour
Configuration files: ⓘ
/etc/hosts - Count: 34
Gatekeeper: ⓘ
Anywhere [Fix Gatekeeper security]
Kernel Extensions: ⓘ
/Applications/Parallels Desktop.app
[not loaded] com.parallels.kext.hypervisor (13.1.0 43108 - SDK 10.9) [Lookup]
[not loaded] com.parallels.kext.netbridge (13.1.0 43108 - SDK 10.9) [Lookup]
[not loaded] com.parallels.kext.usbconnect (13.1.0 43108 - SDK 10.9) [Lookup]
[not loaded] com.parallels.kext.vnic (13.1.0 43108 - SDK 10.9) [Lookup]
/Applications/Toast 11 Titanium/Spin Doctor.app
[not loaded] com.hzsystems.terminus.driver (4) [Lookup]
/Applications/Trim Enabler.app
[not loaded] org.cindori.TrimEnabler (1.0 - SDK 10.10) [Lookup]
/Applications/VMware Fusion.app
[not loaded] com.vmware.kext.vmci (8.5.3) [Lookup]
[not loaded] com.vmware.kext.vmioplug.15.2.0 (8.5.3) [Lookup]
[not loaded] com.vmware.kext.vmnet (8.5.3) [Lookup]
[not loaded] com.vmware.kext.vmx86 (8.5.3) [Lookup]
/Applications/iSkysoft iTube Studio.app
[not loaded] com.Perfect.Driver.SystemAudioRecorder (1.1.0 - SDK 10.6) [Lookup]
/Library/Application Support/Fortinet/FortiClient/nke
[not loaded] com.fortinet.fct.kext.avkern2 (1.0 - SDK 10.12) [Lookup]
[not loaded] com.fortinet.fct.kext.fctapnke (1.0 - SDK 10.12) [Lookup]
[not loaded] com.fortinet.kext.fctrouternke (1.0 - SDK 10.12) [Lookup]
/Library/Extensions
[loaded] at.obdev.nke.LittleSnitch (4.0.3 - SDK 10.11) [Lookup]
[loaded] com.globaldelight.driver.Boom2Device (1.2 - SDK 10.10) [Lookup]
[loaded] com.paragon-software.filesystems.ntfs (15.0.293 - SDK 10.10) [Lookup]
/System/Library/Extensions
[loaded] com.Cycling74.driver.Soundflower (1.6.7 - SDK 10.7) [Lookup]
[not loaded] com.elgato.driver.DontMatchAfaTech (1.1) [Lookup]
[not loaded] com.elgato.driver.DontMatchCinergy450 (1.1) [Lookup]
[not loaded] com.elgato.driver.DontMatchCinergyXS (1.1) [Lookup]
[not loaded] com.elgato.driver.DontMatchEmpia (1.1) [Lookup]
[not loaded] com.elgato.driver.DontMatchVoyager (1.1) [Lookup]
~/Library/Services/ToastIt.service/Contents/MacOS
[not loaded] com.roxio.TDIXController (2.0) [Lookup]
Startup Items: ⓘ
TuxeraNTFSUnmountHelper: Path: /Library/StartupItems/TuxeraNTFSUnmountHelper
Startup items no longer function in OS X Yosemite or later
System Launch Agents: ⓘ
[not loaded] 7 Apple tasks
[loaded] 175 Apple tasks
[running] 103 Apple tasks
System Launch Daemons: ⓘ
[failed] com.apple.spindump.plist (Apple, Inc. - installed 2017-07-15)
[not loaded] 39 Apple tasks
Launch Agents: ⓘ
[running] at.obdev.LittleSnitchHelper.plist (Objective Development Software GmbH - installed 2017-10-03) [Lookup]
[running] at.obdev.LittleSnitchUIAgent.plist (Objective Development Software GmbH - installed 2017-10-03) [Lookup]
[not loaded] com.adobe.AAM.Updater-1.0.plist (Adobe Systems, Inc. - installed 2016-12-03) [Lookup]
[loaded] com.adobe.AdobeCreativeCloud.plist (Adobe Systems, Inc. - installed 2017-03-31) [Lookup]
[running] com.bjango.istatmenusagent.plist (Bjango Pty Ltd - installed 2017-06-18) [Lookup]
[running] com.bjango.istatmenusnotifications.plist (Bjango Pty Ltd - installed 2017-06-18) [Lookup]
[running] com.bjango.istatmenusstatus.plist (Bjango Pty Ltd - installed 2017-06-18) [Lookup]
[running] com.brother.LOGINserver.plist (? a1772de2 41ad4933 - installed 2016-11-20) [Lookup]
[loaded] com.oracle.java.Java-Updater.plist (? a1374a56 7c97ba23 - installed 2017-09-23) [Lookup]
[loaded] com.paragon-software.facebook.agent.plist (? 95fb0bd4 e9648c48 - installed 2016-12-01) [Lookup]
[running] com.paragon-software.ntfs.notification-agent.plist (Paragon Software GmbH - installed 2017-03-12) [Lookup]
[loaded] com.paragon.updater.plist (Paragon Software GmbH - installed 2017-02-18) [Lookup]
[not loaded] com.teamviewer.teamviewer.plist (TeamViewer GmbH - installed 2017-02-18) [Lookup]
[not loaded] com.teamviewer.teamviewer_desktop.plist (TeamViewer GmbH - installed 2016-11-21) [Lookup]
[not loaded] uk.co.dssw.pmnotify.login.plist (? 1fb0f5be 8fbc7524 - installed 2017-04-13) [Lookup]
[running] uk.co.dssw.pmnotify.plist (? 2bab823 8fbc7524 - installed 2017-04-13) [Lookup]
[running] uk.co.dssw.pmuser.plist (Dragon Systems Software Limited - installed 2017-04-07) [Lookup]
Launch Daemons: ⓘ
[running] at.obdev.littlesnitchd.plist (? d0208090 361b2067 - installed 2017-10-03) [Lookup]
[running] com.adobe.adobeupdatedaemon.plist (Adobe Systems, Inc. - installed 2017-03-31) [Lookup]
[running] com.adobe.agsservice.plist (Adobe Systems, Inc. - installed 2017-10-01) [Lookup]
[loaded] com.adobe.fpsaud.plist (? 2afb3af7 4898e928 - installed 2017-08-29) [Lookup]
[not loaded] com.apple.installer.cleanupinstaller.plist (? ? ? - installed 2017-10-01)
[loaded] com.apple.installer.osmessagetracing.plist (Apple, Inc. - installed 2017-09-21)
[loaded] com.barebones.authd.plist (Bare Bones Software, Inc. - installed 2017-02-18) [Lookup]
[running] com.bjango.istatmenusdaemon.plist (Bjango Pty Ltd - installed 2017-06-18) [Lookup]
[loaded] com.bombich.ccchelper.plist (? bc948f55 d1c46930 - installed 2017-03-13) [Lookup]
[loaded] com.daisydiskapp.DaisyDiskAdminHelper.plist (Software Ambience Corp. - installed 2017-04-03) [Lookup]
[loaded] com.fortinet.forticlient.appfw.plist (Fortinet, Inc - installed 2017-06-15) [Lookup]
[running] com.fortinet.forticlient.epctrl.plist (Fortinet, Inc - installed 2017-06-15) [Lookup]
[running] com.fortinet.forticlient.servctl.plist (Fortinet, Inc - installed 2017-06-15) [Lookup]
[loaded] com.fortinet.forticlient.vpn.plist (Fortinet, Inc - installed 2017-06-15) [Lookup]
[loaded] com.macpaw.CleanMyMac3.Agent.plist (MacPaw Inc. - installed 2017-10-07) [Lookup]
[loaded] com.microsoft.autoupdate.helper.plist (Microsoft Corporation - installed 2017-09-17) [Lookup]
[loaded] com.microsoft.office.licensingV2.helper.plist (Microsoft Corporation - installed 2017-01-07) [Lookup]
[loaded] com.oracle.java.Helper-Tool.plist (Shell Script fa56dec8 - installed 2017-09-23) [Lookup]
[loaded] com.paragon-software.installer.plist (Paragon Software GmbH - installed 2017-06-18) [Lookup]
[loaded] com.paragon-software.ntfs.loader.plist (Apple, Inc. - installed 2017-07-15)
[running] com.paragon-software.ntfsd.plist (Paragon Software GmbH - installed 2017-02-16) [Lookup]
[loaded] com.paragon.ntfs14.refresh.plist (Shell Script 5941d160 - installed 2016-12-01) [Lookup]
[loaded] com.surteesstudios.Bartender.BartenderInstallHelper.plist (Surtees Studios Limited - installed 2017-06-18) [Lookup]
[loaded] com.teamviewer.Helper.plist (TeamViewer GmbH - installed 2016-09-19) [Lookup]
[not loaded] com.teamviewer.teamviewer_service.plist (TeamViewer GmbH - installed 2017-02-18) [Lookup]
[loaded] org.cindori.TEAuth.plist (Oskar Groth - installed 2017-04-13) [Lookup]
[running] uk.co.dssw.pmd.plist (? decffe96 23485618 - installed 2017-04-12) [Lookup]
User Launch Agents: ⓘ
[loaded] com.adobe.AAM.Updater-1.0.plist (Adobe Systems, Inc. - installed 2016-12-03) [Lookup]
[loaded] com.dropbox.DropboxMacUpdate.agent.plist (Dropbox, Inc. - installed 2017-08-18) [Lookup]
[loaded] com.macpaw.CleanMyMac3.Scheduler.plist (MacPaw Inc. - installed 2017-09-23) [Lookup]
[running] com.spotify.webhelper.plist (Spotify - installed 2017-09-29) [Lookup]
[failed] com.wondershare.NewTunesGoHelper.plist (Wondershare Software Co., Ltd - installed 2017-10-09) [Lookup]
[failed] com.wondershare.mobilegodaemon.plist (Wondershare Software Co., Ltd - installed 2017-10-03) [Lookup]
User Login Items: ⓘ
Magnet Applicazione
(/Applications/Magnet.app)
HyperDock Helper Applicazione (? 0 - installed 2017-03-22)
(/Applications/HyperDock.app/Contents/Library/LoginItems/HyperDock Helper.app)
EyeTV Helper Applicazione
(/Library/Application Support/EyeTV/EyeTV Helper.app)
Dropbox Applicazione
(/Applications/Dropbox.app)
CleanMyMac 3 Menu Applicazione (? 0 - installed 2017-09-25)
(/Applications/CleanMyMac 3.app/Contents/MacOS/CleanMyMac 3 Menu.app)
iSkysoft Helper Compact Applicazione
(~/Library/Application Support/Helper/iSkysoft Helper Compact.app)
Wondershare TunesGo Helper Applicazione
(~/Library/Application Support/Wondershare TunesGo/Wondershare TunesGo Helper.app)
TotalFinder Applicazione
(/Applications/TotalFinder.app)
Wondershare Helper Compact Applicazione
(~/Library/Application Support/Helper/Wondershare Helper Compact.app)
Zoom It Applicazione
(/Applications/Zoom It.app)
iMazing Mini Applicazione (? 0 - installed 2017-09-20)
(/Applications/iMazing.app/Contents/MacOS/iMazing Mini.app)
FortiClientAgent Applicazione
(/Applications/FortiClient.app/Contents/Resources/runtime.helper/FortiClientAgent.app)
InstTranslateHelper SMLoginItem - Hidden (Apple, Inc. - installed 2017-08-16)
(/Applications/Instant Translate.app/Contents/Library/LoginItems/InstTranslateHelper.app)
CloudKitJS Callback URL SMLoginItem - Hidden (? 0 - installed 2017-10-03)
(/Applications/1Password 6.app/Contents/Library/LoginItems/2BUA8C4S2C.com.agilebits.onepassword4-helper.app)
Ember Library Mediator SMLoginItem - Hidden (Apple, Inc. - installed 2017-02-18)
(/Volumes/Macintosh SSD/Applications/Ember.app/Contents/Library/LoginItems/Ember Library Mediator.app)
Ember Status Item SMLoginItem - Hidden (Apple, Inc. - installed 2017-02-18)
(/Volumes/Macintosh SSD/Applications/Ember.app/Contents/Library/LoginItems/Ember Status Item.app)
(/Applications/Ember.app/Contents/Library/LoginItems/Ember Library Mediator.app)
SSDReporterLaunchHelper SMLoginItem - Hidden (Apple, Inc. - installed 2017-02-20)
(/Applications/SSDReporter.app/Contents/Library/LoginItems/SSDReporterLaunchHelper.app)
(/Applications/Ember.app/Contents/Library/LoginItems/Ember Status Item.app)
Internet Plug-ins: ⓘ
AdobeAAMDetect: 3.0.0.0 (installed 2017-03-31) [Lookup]
FlashPlayer-10.6: 27.0.0.130 (installed 2017-09-17) [Lookup]
QuickTime Plugin: 7.7.3 (installed 2017-07-20)
Flash Player: 27.0.0.130 (installed 2017-09-17) Outdated! Update
jdk: Unknown (installed 2017-09-23)
JavaPlugin2_NPAPI: Unknown
MeetingJoinPlugin: 1.0 (installed 2016-11-20) [Lookup]
JavaAppletPlugin: Java 9 build 181 (installed 2017-09-23) Check version
User internet Plug-ins: ⓘ
tblive-4-VIP: 4.17.0.0 (installed 2017-07-22) [Lookup]
tblive-4: Unknown (installed 2016-11-21)
Safari Extensions: ⓘ
[enabled] Translate - SideTree.com - Apps for Mac -
http://SideTree.com/extensions.html#Translate" onclick="window.open(this.href);return false; (installed 2017-09-17)
[enabled] 1Password - AgileBits -
https://agilebits.com/onepassword" onclick="window.open(this.href);return false; (installed 2017-09-17)
[not loaded] Open in Internet Explorer - Parallels -
http://www.parallels.com" onclick="window.open(this.href);return false; (installed 2017-10-09)
Audio Plug-ins: ⓘ
BartenderAudioPlugIn: 1.0.0 (installed 2016-09-14) [Lookup]
3rd Party Preference Panes: ⓘ
Flash Player (installed 2017-08-29) [Lookup]
Java (installed 2017-08-03) [Lookup]
Tuxera NTFS (installed 2017-03-22) [Lookup]
Time Machine: ⓘ
Time Machine not configured!
Top Processes by CPU: ⓘ
5% WindowServer
2% mdworker
2% mds
2% mdworker
1% kernel_task
Top Processes by Memory: ⓘ
782 MB kernel_task
319 MB Safari
219 MB com.apple.WebKit.WebContent
154 MB mds_stores
145 MB Dropbox
Input Output Process name
75 KB 118 KB Dropbox
33 KB 39 KB mDNSResponder
30 KB 31 KB apsd
13 KB 8 KB assistantd
7 KB 13 KB usbmuxd
17.66 iStat Menus Status
7.04 WindowServer
1.34 com.apple.WebKit.WebContent
0.84 Finder
Virtual Memory Information: ⓘ
7.69 GB Available RAM
4.96 GB Free RAM
4.31 GB Used RAM
2.72 GB Cached files
0 B Swap Used
Microsoft AutoUpdate: (installed 2017-09-17)
Microsoft Outlook for Mac: (installed 2017-09-17)
Microsoft PowerPoint for Mac: (installed 2017-09-17)
Microsoft Excel for Mac: (installed 2017-09-17)
Microsoft OneNote for Mac: (installed 2017-09-17)
Microsoft Word for Mac: (installed 2017-09-17)
Adobe Flash Player: (installed 2017-09-17)
Badia Images to PDF: 1.1.0 (installed 2017-09-17)
TotalFinder 1.10.2: (installed 2017-09-17)
FortiClient: 5.6.0.703 (installed 2017-09-23)
Microsoft Remote Desktop: 8.0.27319 (installed 2017-09-23)
JDK 9: (installed 2017-09-23)
Microsoft Remote Desktop: 8.0.27325 (installed 2017-09-29)
1Password: (installed 2017-10-03)
Skype for Business: (installed 2017-10-06)
2017-10-10 22:03:30 spindump Crash [Open]
2017-10-10 21:59:12 cleanup_installer Crash [Open]
