Kernel Panic ha scritto:Anche tu scarica Etrecheck, fai il test e posta qui il relativo log.
http://etrecheck.com" onclick="window.open(this.href);return false;
Forse è il caso di unire i due topic >>
viewtopic.php?f=9&t=40957" onclick="window.open(this.href);return false;
EtreCheck version: 3.3 (383)
Report generated 2017-05-17 14:43:49
Download EtreCheck from
https://etrecheck.com" onclick="window.open(this.href);return false;
Runtime: 1:39
Performance: Excellent
Click the [Clean up] link to delete unused files.
Problem: Other problem
Hardware Information: ⓘ
MacBook Pro (Retina, 15-inch, Mid 2014)
MacBook Pro - model: MacBookPro11,2
1 2,2 GHz Intel Core i7 (i7-4770HQ) CPU: 4-core
16 GB RAM Not upgradeable
BANK 0/DIMM0
8 GB DDR3 1600 MHz ok
BANK 1/DIMM0
Wireless: en0: 802.11 a/b/g/n/ac
Battery: Health = Normal - Cycle count = 455
Video Information: ⓘ
Intel Iris Pro - VRAM: 1536 MB
Color LCD 2880 x 1800
SAMSUNG 1920 x 1080 @ 60 Hz
System Software: ⓘ
macOS Sierra 10.12.5 (16F73) - Time since boot: about one hour
Disk Information: ⓘ
APPLE SSD SM0256F disk0 : (251 GB) (Solid State - TRIM: Yes)
[Show SMART report]
EFI (disk0s1 - MS-DOS FAT32) <not mounted> : 210 MB
Recovery HD (disk0s3 - Journaled HFS+) <not mounted> [Recovery]: 650 MB
Macintosh HD (disk1 - Journaled HFS+) / [Startup]: 249.78 GB (27.52 GB free)
Encrypted AES-XTS Unlocked
Core Storage: disk0s2 250.14 GB Online
USB Information: ⓘ
Apple Inc. BRCM20702 Hub
FiiO DigiHug USB Audio
Thunderbolt Information: ⓘ
Apple Inc. thunderbolt_bus
Gatekeeper: ⓘ
Clean up: ⓘ
~/Library/LaunchAgents/com.BlueStacks.AppPlayer.Service.plist
/Applications/BlueStacks.app/Contents/MacOS/bstservice Android
Executable not found!
~/Library/LaunchAgents/com.BlueStacks.AppPlayer.Updater.plist
/Applications/BlueStacks.app/Contents/MacOS/bstupdater pull
com.adobe.ARM.[...].plist
/Applications/Adobe Reader.app/Contents/MacOS/Updater/Adobe Reader Updater Helper.app/Contents/MacOS/Adobe Reader Updater Helper
~/Library/LaunchAgents/com.spotify.webhelper.plist
~/Library/Application Support/Spotify/SpotifyWebHelper
~/Library/LaunchAgents/com.wondershare.TunesGoHelper.plist
~/Library/Application Support/Wondershare TunesGo/Wondershare TunesGo Helper.app
~/Library/LaunchAgents/org.virtualbox.vboxwebsrv.plist
/Applications/VirtualBox.app/Contents/MacOS/vboxwebsrv
6 orphan files found. [Clean up]
Kernel Extensions: ⓘ
/Applications/Kies.app
[not loaded] com.devguru.driver.SamsungACMControl (1.4.32 - SDK 10.6) [Lookup]
[not loaded] com.devguru.driver.SamsungACMData (1.4.32 - SDK 10.6) [Lookup]
[not loaded] com.devguru.driver.SamsungComposite (1.4.32 - SDK 10.6) [Lookup]
[not loaded] com.devguru.driver.SamsungMTP (1.4.32 - SDK 10.5) [Lookup]
[not loaded] com.devguru.driver.SamsungSerial (1.4.32 - SDK 10.6) [Lookup]
/Library/Extensions
[not loaded] com.BlackBerry.driver.USBCDCNCM (1.0.10 - SDK 10.7) [Lookup]
[loaded] com.rim.driver.BlackBerryVirtualPrivateNetwork (1.0.18 - SDK 10.
[Lookup]
/System/Library/Extensions
[not loaded] com.rim.driver.BlackBerryUSBDriverInt (0.0.97) [Lookup]
[not loaded] com.rim.driver.BlackBerryUSBDriverVSP (0.0.97) [Lookup]
[not loaded] com.tomtom.driver.UsbEthernetGadget (1.0.0d1) [Lookup]
System Launch Agents: ⓘ
[failed] com.apple.helpd.plist (Apple - installed 2017-04-29)
[not loaded] 6 Apple tasks
[loaded] 177 Apple tasks
[running] 98 Apple tasks
System Launch Daemons: ⓘ
[not loaded] 42 Apple tasks
[loaded] 175 Apple tasks
[running] 100 Apple tasks
Launch Agents: ⓘ
[loaded] com.google.keystone.agent.plist (Google, Inc. - installed 2017-03-29) [Lookup]
[loaded] com.oracle.java.Java-Updater.plist (Unknown - installed 2015-10-05) [Lookup]
[running] com.rim.BBAlbumArtCacher.plist (Research in Motion Limited - installed 2013-06-25) [Lookup]
[running] com.rim.BBLaunchAgent.plist (Unknown - installed 2014-08-30) [Lookup]
[running] com.rim.PeerManager.plist (Research in Motion Limited - installed 2014-06-24) [Lookup]
[running] com.rim.blackberrylink.BlackBerry-Link-Helper-Agent.plist (Unknown - installed 2014-08-30) [Lookup]
[loaded] org.macosforge.xquartz.startx.plist (Apple Inc. - XQuartz - installed 2016-05-05) [Lookup]
Launch Daemons: ⓘ
[loaded] com.adobe.fpsaud.plist (Unknown - installed 2017-04-27) [Lookup]
[loaded] com.disc-soft.DAEMONTools.PrivilegedHelper.plist (Unknown - installed 2013-08-31) [Lookup]
[loaded] com.google.keystone.daemon.plist (Google, Inc. - installed 2017-04-26) [Lookup]
[running] com.malwarebytes.HelperTool.plist (Malwarebytes Corporation - installed 2017-02-02) [Lookup]
[loaded] com.oracle.java.Helper-Tool.plist (Shell script - installed 2015-08-04) [Lookup]
[running] com.rim.BBDaemon.plist (Unknown - installed 2014-06-24) [Lookup]
[not loaded] com.rim.nkehelper.plist ((null) - installed 2017-04-29)
[running] com.rim.tunmgr.plist (Research in Motion Limited - installed 2014-06-24) [Lookup]
[loaded] org.macosforge.xquartz.privileged_startx.plist (Apple Inc. - XQuartz - installed 2016-05-05) [Lookup]
[not loaded] org.virtualbox.startup.plist (Unknown - installed (null)) [Lookup]
User Launch Agents: ⓘ
[loaded] com.BlueStacks.AppPlayer.Service.plist (Unknown - installed 2015-08-10) [Lookup] - /Applications/BlueStacks.app/Contents/MacOS/bstservice: Executable not found!
[loaded] com.BlueStacks.AppPlayer.UninstallWatcher.plist (Shell script - installed 2017-04-29)
[failed] com.BlueStacks.AppPlayer.Updater.plist (Unknown - installed 2015-08-10) [Lookup] - /Applications/BlueStacks.app/Contents/MacOS/bstupdater: Executable not found!
[failed] com.adobe.ARM.[...].plist (Unknown - installed 2012-09-25) [Lookup] - /Applications/Adobe Reader.app/Contents/MacOS/Updater/Adobe Reader Updater Helper.app/Contents/MacOS/Adobe Reader Updater Helper: Executable not found!
[loaded] com.apple.AddressBook.ScheduledSync.PHXCardDAVSource.D60A6C04-8473-4771-85E5-2518A4BD91FD.plist (Apple - installed 2017-05-17)
[running] com.coppertino.VoxHelper.plist (Coppertino Inc. - installed 2015-02-11) [Lookup]
[loaded] com.facebook.videochat.[redacted].plist ((null) - installed 2016-09-25)
[failed] com.spotify.webhelper.plist (Unknown - installed 2014-11-30) [Lookup] - ~/Library/Application Support/Spotify/SpotifyWebHelper: Executable not found!
[failed] com.wondershare.TunesGoHelper.plist (Unknown - installed 2017-02-16) [Lookup] - ~/Library/Application Support/Wondershare TunesGo/Wondershare TunesGo Helper.app: Executable not found!
[not loaded] org.virtualbox.vboxwebsrv.plist (Unknown - installed 2016-09-04) [Lookup] - /Applications/VirtualBox.app/Contents/MacOS/vboxwebsrv: Executable not found!
User Login Items: ⓘ
iTunesHelper Applicazione - Hidden (installed 2017-05-16)
(/Applications/iTunes.app/Contents/MacOS/iTunesHelper.app)
KiesAgent Applicazione - Hidden (installed 2015-08-29)
(/Applications/Kies.app/Contents/MacOS/KiesAgent.app)
fuspredownloader Applicazione - Hidden
(~/Library/Application Support/.FUS/fuspredownloader.app)
Internet Plug-ins: ⓘ
JavaAppletPlugin: Java 8 Update 60 build 27 (installed 2015-10-05) Check version
FlashPlayer-10.6: 25.0.0.171 (installed 2017-05-09) [Lookup]
QuickTime Plugin: 7.7.3 (installed 2017-05-17)
AdobePDFViewerNPAPI: 11.0.0 (installed 2014-06-09) [Lookup]
AdobePDFViewer: 11.0.0 (installed 2014-06-09) [Lookup]
Flash Player: 25.0.0.171 (installed 2017-05-09) [Lookup]
o1dbrowserplugin: 5.41.3.0 (installed 2015-12-15) [Lookup]
googletalkbrowserplugin: 5.41.3.0 (installed 2015-12-11) [Lookup]
Silverlight: 5.1.50901.0 (installed 2017-05-15) [Lookup]
iPhotoPhotocast: 7.0 (installed 2013-04-23)
Safari Extensions: ⓘ
[disabled] AdBlock - Michael Gundlach -
http://safariadblock.com" onclick="window.open(this.href);return false; (installed 2015-04-10)
[not loaded] Open in Internet Explorer - Parallels -
http://www.parallels.com" onclick="window.open(this.href);return false; (installed 2016-09-04)
3rd Party Preference Panes: ⓘ
Flash Player (installed 2017-04-27) [Lookup]
Java (installed 2015-10-05) [Lookup]
VOX Preferences (installed 2015-01-30) [Lookup]
Time Machine: ⓘ
Mobile backups: OFF
Volumes being backed up:
Macintosh HD: Disk size: 249.78 GB Disk used: 222.26 GB
Destinations:
TIME MACHINE [Local]
Total size: 999.83 GB
Total number of backups: 1
Oldest backup: 04/10/15, 14:57
Last backup: 04/10/15, 14:57
Size of backup disk: Excellent
Backup size 999.83 GB > (Disk size 249.78 GB X 3)
Top Processes by CPU: ⓘ
5% WindowServer
2% plugin-container
2% kernel_task
1% fontd
1% sysmond
Top Processes by Memory: ⓘ
1.34 GB firefox
1.14 GB kernel_task
295 MB com.malwarebytes.HelperTool
229 MB WindowServer
197 MB mdworker(8)
Input Output Process name
3 MB 361 KB firefox
93 KB 81 KB mDNSResponder
9 KB 12 KB apsd
15 KB 4 KB netbiosd
3 KB 3 KB ntpd
7.40 WindowServer
4.38 plugin-container
1.18 PeerManager
0.92 BBLaunchAgent.ap
0.52 sysmond
Virtual Memory Information: ⓘ
9.99 GB Available RAM
5.52 GB Free RAM
6.01 GB Used RAM
4.47 GB Cached files
0 B Swap Used
Diagnostics Information: ⓘ
2017-05-17 13:23:35 Self test - passed
Mi è uscito questo. Ho selezionato la voce "other problem" per la verifica.
Devo cliccare su "Clean up" per pulire il tutto?
