Diamo un'occhiata?Aller76 ha scritto:... Cosa devo fare?...
May 4 18:31:02 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.quicklook[899]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.quicklook
May 4 18:32:12 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.quicklook[937]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.quicklook
May 4 18:32:25 MacBook-di-Luca diagnosticd[941]: System mode client started - Console (938) - mode: 0x8
May 4 18:33:00 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
May 4 18:33:03 MacBook-di-Luca Console[938]: BUG in libdispatch client: kevent[EVFILT_VNODE] monitored resource vanished before the source cancel handler was invoked
May 4 18:33:06 MacBook-di-Luca diagnosticd[941]: System mode client stopped - Console (938) - clearing mode: 0x8, still active: 0x0
May 4 18:33:22 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.quicklook[1050]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.quicklook
May 4 18:33:36 MacBook-di-Luca com.apple.usbmuxd[84]: notice Idle, stopping.
May 4 18:33:36 MacBook-di-Luca xpcproxy[1210]: libcoreservices: _dirhelper_userdir: 523: bootstrap_look_up returned 268435459
May 4 18:33:36 MacBook-di-Luca com.apple.usbmuxd[1210]: notice usbmuxd-374.913 on Mar 17 2017 at 17:43:50, running 64 bit
May 4 18:34:33 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.quicklook[1603]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.quicklook
May 4 18:34:59 MacBook-di-Luca diagnosticd[941]: System mode client started - Console (1604) - mode: 0x8
May 4 18:38:26 MacBook-di-Luca syslogd[38]: ASL Sender Statistics
May 4 18:38:43 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.quicklook[1622]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.quicklook
May 4 18:41:20 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.WebKit.Networking.3D388007-89A5-41CE-AE2F-747DA5318F25[1634]): Service exited with abnormal code: 1
May 4 18:42:54 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.quicklook[1645]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.quicklook
May 4 18:44:56 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd[1654]): Service exited due to signal: Segmentation fault: 11 sent by exc handler[0]
May 4 18:44:56 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
May 4 18:44:56 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.ReportCrash[1655]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.ReportCrash
May 4 18:45:07 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd[1656]): Service exited due to signal: Segmentation fault: 11 sent by exc handler[0]
May 4 18:45:07 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
May 4 18:45:17 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd[1658]): Service exited due to signal: Segmentation fault: 11 sent by exc handler[0]
May 4 18:45:17 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
May 4 18:45:28 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd[1659]): Service exited due to signal: Segmentation fault: 11 sent by exc handler[0]
May 4 18:45:28 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
May 4 18:45:38 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd[1660]): Service exited due to signal: Segmentation fault: 11 sent by exc handler[0]
May 4 18:45:38 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
May 4 18:45:48 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd[1661]): Service exited due to signal: Segmentation fault: 11 sent by exc handler[0]
May 4 18:45:48 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
May 4 18:45:58 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd[1662]): Service exited due to signal: Segmentation fault: 11 sent by exc handler[0]
May 4 18:45:58 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.ReportCrash[1663]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.ReportCrash
May 4 18:45:58 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
May 4 18:46:08 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd[1664]): Service exited due to signal: Segmentation fault: 11 sent by exc handler[0]
May 4 18:46:08 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
May 4 18:46:18 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd[1665]): Service exited due to signal: Segmentation fault: 11 sent by exc handler[0]
May 4 18:46:18 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
May 4 18:46:28 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd[1666]): Service exited due to signal: Segmentation fault: 11 sent by exc handler[0]
May 4 18:46:28 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
May 4 18:46:38 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd[1667]): Service exited due to signal: Segmentation fault: 11 sent by exc handler[0]
May 4 18:46:39 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
May 4 18:46:49 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd[1668]): Service exited due to signal: Segmentation fault: 11 sent by exc handler[0]
May 4 18:46:49 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
May 4 18:46:59 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd[1669]): Service exited due to signal: Segmentation fault: 11 sent by exc handler[0]
May 4 18:46:59 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.ReportCrash[1670]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.ReportCrash
May 4 18:46:59 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
May 4 18:47:05 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.quicklook[1671]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.quicklook
May 4 18:47:09 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd[1672]): Service exited due to signal: Segmentation fault: 11 sent by exc handler[0]
May 4 18:47:09 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
May 4 18:47:19 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd[1673]): Service exited due to signal: Segmentation fault: 11 sent by exc handler[0]
May 4 18:47:40 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd[1674]): Service exited due to signal: Segmentation fault: 11 sent by exc handler[0]
May 4 18:47:42 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): Service only ran for 2 seconds. Pushing respawn out by 8 seconds.
May 4 18:47:50 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd[1675]): Service exited due to signal: Segmentation fault: 11 sent by exc handler[0]
May 4 18:47:51 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
May 4 18:48:01 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd[1676]): Service exited due to signal: Segmentation fault: 11 sent by exc handler[0]
May 4 18:48:01 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.ReportCrash[1677]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.ReportCrash
May 4 18:48:03 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): Service only ran for 2 seconds. Pushing respawn out by 8 seconds.
May 4 18:48:11 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd[1678]): Service exited due to signal: Segmentation fault: 11 sent by exc handler[0]
May 4 18:48:12 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
May 4 18:48:22 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd[1679]): Service exited due to signal: Segmentation fault: 11 sent by exc handler[0]
May 4 18:48:22 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
May 4 18:48:32 MacBook-di-Luca syslogd[38]: ASL Sender Statistics
May 4 18:48:32 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd[1680]): Service exited due to signal: Segmentation fault: 11 sent by exc handler[0]
May 4 18:49:07 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd[1681]): Service exited due to signal: Segmentation fault: 11 sent by exc handler[0]
May 4 18:49:07 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.ReportCrash[1682]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.ReportCrash
May 4 18:49:08 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): Service only ran for 1 seconds. Pushing respawn out by 9 seconds.
May 4 18:49:17 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd[1683]): Service exited due to signal: Segmentation fault: 11 sent by exc handler[0]
May 4 18:49:17 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
May 4 18:49:27 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd[1684]): Service exited due to signal: Segmentation fault: 11 sent by exc handler[0]
May 4 18:49:27 MacBook-di-Luca com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
Process: com.apple.speech.speechsynthesisd [1698]
Path: /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/Resources/com.apple.speech.speechsynthesisd
Identifier: com.apple.speech.speechsynthesisd
Version: 6.3.3
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: com.apple.speech.speechsynthesisd [1698]
User ID: 501
Date/Time: 2017-05-04 18:51:40.884 +0200
OS Version: Mac OS X 10.12.4 (16E195)
Report Version: 12
Anonymous UUID: 622A4B9A-5F35-5D00-B25D-071DA71E8EA9
Time Awake Since Boot: 12000 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Signal: Segmentation fault: 11
Termination Reason: Namespace SIGNAL, Code 0xb
Terminating Process: exc handler [0]
VM Regions Near 0:
__TEXT 000000010cc81000-000000010cc93000 [ 72K] r-x/rwx SM=COW /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/Resources/com.apple.speech.speechsynthesisd
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.apple.CoreFoundation 0x00007fff7d117766 CFStringHasSuffix + 22
1 com.apple.speech.speechsynthesisd 0x000000010cc8e3b3 0x10cc81000 + 54195
2 com.apple.speech.speechsynthesisd 0x000000010cc8397f 0x10cc81000 + 10623
3 libdispatch.dylib 0x00007fff928ad8fc _dispatch_client_callout + 8
4 libdispatch.dylib 0x00007fff928b9ffb _dispatch_barrier_sync_f_slow_invoke + 295
5 libdispatch.dylib 0x00007fff928ad8fc _dispatch_client_callout + 8
6 libdispatch.dylib 0x00007fff928baaac _dispatch_main_queue_callback_4CF + 925
7 com.apple.CoreFoundation 0x00007fff7d1bfc69 __CFRUNLOOP_IS_SERVICING_THE_MAIN_DISPATCH_QUEUE__ + 9
8 com.apple.CoreFoundation 0x00007fff7d180cbd __CFRunLoopRun + 2205
9 com.apple.CoreFoundation 0x00007fff7d1801c4 CFRunLoopRunSpecific + 420
10 com.apple.speech.speechsynthesisd 0x000000010cc820dd 0x10cc81000 + 4317
11 libdyld.dylib 0x00007fff928e3235 start + 1/code]
Visitano il forum: Nessuno e 18 ospiti
