Blackmagic Disk Speed Test
charlie
Open Office Expert
Open Office Expert
Oggetto del messaggio: Blackmagic Disk Speed Test
Messaggio da charlie »
Buona giornata a tutti.
Nel ricercare possibili motivi di rallentamenti occasionale del mio iMac (27" metà 2011 con 10.7.5 Lion), ho provato ad installare Blackmagic Disk Speed Test, ma mi si chiude "inaspettatamente" appena aperto.
Rimosso e re-installato più volte con lo stesso esito.
Questo è il resoconto, qualcuno mi aiuta? Grazie.
Process:         launchd [498]
Path:            /Applications/Blackmagic Disk Speed Test.app/Contents/MacOS/DiskSpeedTest
Identifier:      com.blackmagic-design.DiskSpeedTest
Version:         ??? (???)
Code Type:       X86-64 (Native)
Parent Process:  launchd [242]
Date/Time:       2017-02-10 09:17:11.935 +0100
OS Version:      Mac OS X 10.7.5 (11G63)
Report Version:  9
Interval Since Last Report:          300213 sec
Crashes Since Last Report:           17
Per-App Crashes Since Last Report:   12
Anonymous UUID:                      78CE9FD4-58BC-4A27-8191-0643DC6F7A83
Crashed Thread:  Unknown
Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x00007fff5fc01028
Backtrace not available
Unknown thread crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000055  rbx: 0x0000000000000000  rcx: 0x0000000000000000  rdx: 0x0000000000000000
  rdi: 0x0000000000000000  rsi: 0x0000000000000000  rbp: 0x0000000000000000  rsp: 0x0000000000000000
   r8: 0x0000000000000000   r9: 0x0000000000000000  r10: 0x0000000000000000  r11: 0x0000000000000000
  r12: 0x0000000000000000  r13: 0x0000000000000000  r14: 0x0000000000000000  r15: 0x0000000000000000
  rip: 0x00007fff5fc01028  rfl: 0x0000000000010203  cr2: 0x00007fff5fc01028
Logical CPU: 1
Binary images description not available
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 1
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 453
    thread_create: 0
    thread_set_state: 0
Model: iMac12,2, BootROM IM121.0047.B25, 4 processors, Intel Core i5, 2.7 GHz, 4 GB, SMC 1.72f2
Graphics: AMD Radeon HD 6770M, AMD Radeon HD 6770M, PCIe, 512 MB
Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1333 MHz, 0x02FE, 0x45424A3230554638424353302D444A2D4620
Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1333 MHz, 0x02FE, 0x45424A3230554638424353302D444A2D4620
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x9A), Atheros 9380: 4.0.67.5-P2P
Bluetooth: Version 4.0.8f17, 2 service, 18 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Serial ATA Device: ST31000528AS, 1 TB
Serial ATA Device: HL-DT-STDVDRW  GA32N
USB Device: hub_device, 0x0424  (SMSC), 0x2514, 0xfa100000 / 3
USB Device: M3, 0x0bc2  (Seagate LLC), 0x61b6, 0xfa130000 / 5
USB Device: BRCM2046 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000 / 4
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8215, 0xfa111000 / 6
USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x850b, 0xfa200000 / 2
USB Device: hub_device, 0x0424  (SMSC), 0x2514, 0xfd100000 / 2
USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd120000 / 4
USB Device: Internal Memory Card Reader, apple_vendor_id, 0x8403, 0xfd110000 / 3
Charlie
Mac 24 M1 - 1 TB - 16 GB ram - macOS 15.5 Sequoia
ex iMac 27" metà 2011- SSD 525 GB - 12 GB RAM - macOS 10.13.6 High Sierra
non funziona più.
http://www.charlieopenoffice.altervista.org"
kext
Oggetto del messaggio: Re: Blackmagic Disk Speed Test
Messaggio da kext »
Scarica una versione più "antica"..
Hammarby
Messaggio da Hammarby »
kext ha scritto:Scarica una versione più "antica"..
Oppure ascoltati l'unica vera Black Magic
...e spesso peggio.
Cervantes
Messaggio da faxus »
Ci sono versioni precedenti, ma irraggiungibili perché distribuito solo tramite AppStore.
Ma non ci sono versioni per sistemi precedenti.
È sempre la stessa applicazione, solo migliorata.
L'unica discriminante sono i processori a 32 bit non supportati.
Il resoconto è assolutamente inservibile, non c'è nulla di significativo.
L'ipotesi più probabile è che sia l'applicazione corrotta.
Anche se dirlo è comunque senza fondamento.
Qualche indicazione potrebbe venire dal log di sistema, forse
charlie
Open Office Expert
Open Office Expert
Hammarby ha scritto:Oppure ascoltati l'unica vera Black Magic
Un bel ricordo di qualche annetto fa ...
Charlie
non funziona più.
Peppiniello
Messaggio da Peppiniello »
charlie, scaricati questa versione di Blackmagic Disk Speed Test, è la 2.2.2 che funziona bene su Snow Leopard, Lion e Mountain Lion:
https://www.sendspace.com/file/r8fw42" onclick="window.open(this.href);return false;
Decomprimila, metti l'applicazione nella cartella Applicazioni e lanciala: vedrai che funziona! :)
Facci sapere!
Se qualche amministratore de iMaccanici la scarica e la mette da parte e a disposizione a futura richiesta, sarebbe cosa buona e giusta! :wink:
charlie
Open Office Expert
Open Office Expert
Grazie Peppiniello, funziona :thumbright: Non c'è nemmeno bisogno di decomprimerla.
Charlie
non funziona più.
Peppiniello
charlie ha scritto:Grazie Peppiniello, funziona :thumbright: Non c'è nemmeno bisogno di decomprimerla.
Prega! :D
... Come non c'è bisogno di decomprimerla? Ho caricato l'applicazione compressa, infatti avrai scaricato un file .app.zip: c'avrai fatto su un doppio click oppure avrai qualche funzione che ti apre i file e/o te li decomprime automaticamente al termine del download; fosse così, come temo, ti consiglio di deselezionare tale funzione perché non si mai cosa si va scaricare e per una serie di altri motivi che non sto ad elencarti, è sempre opportuno che le cose scaricate te le apri da te e dove e quando vuoi!
In Safari, per esempio, devi andare sul primo pannello delle sue preferenze, quello generali e deselezionare -apri file "sicuri" dopo il download-. ... La Apple seguita a tenere questa impostazione selezionata di base ed il paradosso è che lei stessa metta fra le virgolette la qualifica di "sicuri"! :D :D :D
charlie
Open Office Expert
Open Office Expert
Infatti, questi sono i 2 download, prima e dopo aver seguito il tuo consiglio.
Devo pregare ancora? :P
P.S. in altre occasioni mi ero chiesto come mai trovavo scompattati file che non dovevano esserlo.
Il ciclo delle cose installate/opzionate a mia insaputa continua, proprio come nel mondo della politica !
Charlie
non funziona più.
Peppiniello
charlie ha scritto:Infatti, questi sono i 2 download, prima e dopo aver seguito il tuo consiglio.
Prega! Prega! ... Può sempre servire, chissà?!! :D
charlie ha scritto:P.S. in altre occasioni mi ero chiesto come mai trovavo scompattati file che non dovevano esserlo.
:lol: :lol: :lol:
Messaggio da iStefano »
L'ho scaricata, ma ...
E' stato rivelato l'aggiornamento da AppStore:
:shock: :shock: :shock:
Nun so Peppe ... :roll: :roll: :D :D :D
iStefano ha scritto:... E' stato rivelato l'aggiornamento da AppStore...
Cazpita!
Dal 9 settembre, solo adesso?
viewtopic.php?f=5&t=32846&start=45#p417980" onclick="window.open(this.href);return false;
faxus ha scritto: Cazpita!
Meglio tardi che mai...
In verità l'ho scaricato solo ora seguendo il link di peppiniello!!!
Eh... Non volevo dirlo.
Ma come successo di recente per FileSpy, vedi da questo post alla decina di successivi
viewtopic.php?f=2&t=36725&start=525#p435126" onclick="window.open(this.href);return false;
Intervengono alcuni problemi di vario tipo.
Succede altro, oltre all'avviso di un aggiornamento disponibile?
Peppiniello
Infatti l'avevo scaricata dal Mac App Store ai tempi dell'ultimo Snow Leopard... E recuperata da un clone backup dopo che feci il successivo aggiornamento che non si apriva più e che intanto m'aveva cancellato questa versione buona, la 2.2.2... :D
Per evitare di essere importunato ossessivamente da quelle notifiche dell'App Store, ho dovuto comprimere l'applicazione e toglierla da tutti gli HD, sia dalla cartella Applicazioni sul Macintosh HD che da quelli esterni di backup. :twisted:
