Buongiorno,
Possiedo un Macbook Pro 15'' del 2015 e ultimamente molto spesso mi si verifica problemi come riportato qui sotto con codici diversi ma tt inerenti allo stesso framework.
Cosa potrebbe essere perche è molto fastidioso??
Come è possibile risolverlo??
P.S. Oltre agli errori che appaiono il computer funziona perfettamente.
Errore:
Process: cloudd [405]
Path: /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Support/cloudd
Identifier: cloudd
Version: 643.5 (643.5)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: cloudd [405]
User ID: 501
Date/Time: 2017-01-18 14:04:37.069 +0100
OS Version: Mac OS X 10.12.2 (16C67)
Report Version: 12
Anonymous UUID: EB9F8A8C-DFD0-B854-AC82-1C05C55617A6
Time Awake Since Boot: 210 seconds
System Integrity Protection: enabled
Crashed Thread: 5 Dispatch queue: com.apple.cloudkit.metadatacache
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
*** Terminating app due to uncaught exception 'NSGenericException', reason: 'Failed to step (6922): "select tokenRegistered, usesAPSPublicToken, darkWakeEnabled from AppContainerIntersection where appBundleIdentifier = ? AND sourceAppBundleIdentifier = ? AND containerIdentifier = ? AND containerEnvironment = ?" - errcode:1b0a, msg:"disk I/O error", size: (null), path:/Users/USER/Library/Caches/*/CloudKitMetadata, fs:(null)/(null)'
abort() called
terminating with uncaught exception of type NSException
<rdar://problem/28724618> Process unable to create connection because the sandbox denied the right to lookup com.apple.coreservices.launchservicesd and so this process cannot talk to launchservicesd.
XPC_ERROR_CONNECTION_INVALID from launchservices
Application Specific Backtrace 1:
0 CoreFoundation 0x00007fff99bffe7b __exceptionPreprocess + 171
1 libobjc.A.dylib 0x00007fffae7eacad objc_exception_throw + 48
2 CoreFoundation 0x00007fff99c7e99d +[NSException raise:format:] + 205
3 CloudKit 0x00007fff994ce7e3 +[CKSQLiteError raise:code:extended:] + 1553
4 CloudKit 0x00007fff994c9a64 -[CKSQLite raise:] + 1199
5 CloudKit 0x00007fff995223cf -[CKSQLiteStatement step] + 152
6 CloudKit 0x00007fff994caa7e -[CKSQLite select:from:where:bindings:] + 348
7 CloudKitDaemon 0x00007fffa47b233a __73-[CKDMetadataCache appContainerIntersectionMetadataForAppContainerTuple:]_block_invoke + 497
8 libdispatch.dylib 0x00007fffaf0980b8 _dispatch_client_callout + 8
9 libdispatch.dylib 0x00007fffaf098cf2 _dispatch_barrier_sync_f_invoke + 83
10 CloudKitDaemon 0x00007fffa47b20d7 -[CKDMetadataCache appContainerIntersectionMetadataForAppContainerTuple:] + 235
11 CloudKitDaemon 0x00007fffa4577853 -[CKDClientContext appContainerIntersectionMetadata] + 143
12 CloudKitDaemon 0x00007fffa4576de0 __65-[CKDClientContext finishSetupWithClientProxy:completionHandler:]_block_invoke + 824
13 libdispatch.dylib 0x00007fffaf0a0ef7 _dispatch_call_block_and_release + 12
14 libdispatch.dylib 0x00007fffaf0980b8 _dispatch_client_callout + 8
15 libdispatch.dylib 0x00007fffaf0aeae5 _dispatch_queue_serial_drain + 896
16 libdispatch.dylib 0x00007fffaf0a0cd9 _dispatch_queue_invoke + 1046
17 libdispatch.dylib 0x00007fffaf0a70f0 _dispatch_queue_override_invoke + 369
18 libdispatch.dylib 0x00007fffaf099e70 _dispatch_root_queue_drain + 476
19 libdispatch.dylib 0x00007fffaf099c47 _dispatch_worker_thread3 + 99
20 libsystem_pthread.dylib 0x00007fffaf2e5712 _pthread_wqthread + 1299
21 libsystem_pthread.dylib 0x00007fffaf2e51ed start_wqthread + 13
Thread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fffaf1f538a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fffaf1f47d7 mach_msg + 55
2 com.apple.CoreFoundation 0x00007fff99b76c94 __CFRunLoopServiceMachPort + 212
3 com.apple.CoreFoundation 0x00007fff99b76121 __CFRunLoopRun + 1361
4 com.apple.CoreFoundation 0x00007fff99b75974 CFRunLoopRunSpecific + 420
5 com.apple.Foundation 0x00007fff9b58a612 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277
6 com.apple.Foundation 0x00007fff9b58a4ea -[NSRunLoop(NSRunLoop) run] + 76
7 cloudd 0x00000001058669ea 0x105865000 + 6634
8 libdyld.dylib 0x00007fffaf0ce255 start + 1
Thread 1:: com.apple.NSURLConnectionLoader
5 com.apple.CFNetwork 0x00007fff98ce5680 +[NSURLConnection(Loader) _resourceLoadLoop:] + 313
6 com.apple.Foundation 0x00007fff9b59ac6d __NSThread__start__ + 1243
7 libsystem_pthread.dylib 0x00007fffaf2e5aab _pthread_body + 180
8 libsystem_pthread.dylib 0x00007fffaf2e59f7 _pthread_start + 286
9 libsystem_pthread.dylib 0x00007fffaf2e51fd thread_start + 13
Thread 2:: com.apple.CFStream.LegacyThread
5 com.apple.CoreFoundation 0x00007fff99c4d345 _legacyStreamRunLoop_workThread + 261
6 libsystem_pthread.dylib 0x00007fffaf2e5aab _pthread_body + 180
7 libsystem_pthread.dylib 0x00007fffaf2e59f7 _pthread_start + 286
8 libsystem_pthread.dylib 0x00007fffaf2e51fd thread_start + 13
Thread 3:: Dispatch queue: NSOperationQueue 0x7fc4c243c270 :: NSOperation 0x7fc4c2732cf0 (QOS: USER_INITIATED)
0 libsystem_kernel.dylib 0x00007fffaf1f53c6 semaphore_wait_trap + 10
1 libdispatch.dylib 0x00007fffaf09dfe8 _dispatch_group_wait_slow + 249
2 com.apple.cloudkit.CloudKitDaemon 0x00007fffa456a8b4 -[CKDClientProxy forceFinishClientSetupWithClientContext:] + 201
3 com.apple.cloudkit.CloudKitDaemon 0x00007fffa4569263 __67-[CKDClientProxy _startClientSetupWithSetupInfo:completionHandler:]_block_invoke_2 + 42
4 com.apple.Foundation 0x00007fff9b5ac2d9 __NSBLOCKOPERATION_IS_CALLING_OUT_TO_A_BLOCK__ + 7
5 com.apple.Foundation 0x00007fff9b5abfbc -[NSBlockOperation main] + 101
6 com.apple.Foundation 0x00007fff9b5aa6e4 -[__NSOperationInternal _start:] + 672
7 com.apple.Foundation 0x00007fff9b5a659b __NSOQSchedule_f + 201
9 libdispatch.dylib 0x00007fffaf0aeae5 _dispatch_queue_serial_drain + 896
10 libdispatch.dylib 0x00007fffaf0a0cd9 _dispatch_queue_invoke + 1046
11 libdispatch.dylib 0x00007fffaf099e70 _dispatch_root_queue_drain + 476
12 libdispatch.dylib 0x00007fffaf099c47 _dispatch_worker_thread3 + 99
13 libsystem_pthread.dylib 0x00007fffaf2e5712 _pthread_wqthread + 1299
14 libsystem_pthread.dylib 0x00007fffaf2e51ed start_wqthread + 13
Thread 4:
0 libsystem_kernel.dylib 0x00007fffaf1fd4e2 __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fffaf2e5791 _pthread_wqthread + 1426
2 libsystem_pthread.dylib 0x00007fffaf2e51ed start_wqthread + 13
Thread 5 Crashed:: Dispatch queue: com.apple.cloudkit.metadatacache
0 libsystem_kernel.dylib 0x00007fffaf1fcdd6 __pthread_kill + 10
1 libsystem_pthread.dylib 0x00007fffaf2e8787 pthread_kill + 90
2 libsystem_c.dylib 0x00007fffaf162420 abort + 129
3 libc++abi.dylib 0x00007fffadcbd85a abort_message + 266
4 libc++abi.dylib 0x00007fffadce2c4f default_terminate_handler() + 267
5 libobjc.A.dylib 0x00007fffae7ecf1e _objc_terminate() + 103
6 libc++abi.dylib 0x00007fffadcdfd69 std::__terminate(void (*)()) + 8
7 libc++abi.dylib 0x00007fffadcdfde3 std::terminate() + 51
8 libdispatch.dylib 0x00007fffaf0980cc _dispatch_client_callout + 28
10 com.apple.cloudkit.CloudKitDaemon 0x00007fffa47b20d7 -[CKDMetadataCache appContainerIntersectionMetadataForAppContainerTuple:] + 235
11 com.apple.cloudkit.CloudKitDaemon 0x00007fffa4577853 -[CKDClientContext appContainerIntersectionMetadata] + 143
12 com.apple.cloudkit.CloudKitDaemon 0x00007fffa4576de0 __65-[CKDClientContext finishSetupWithClientProxy:completionHandler:]_block_invoke + 824
Thread 6:: Dispatch queue: NSOperationQueue 0x7fc4c2668d40 :: NSOperation 0x7fc4c2734de0 (QOS: USER_INITIATED)
0 libsystem_kernel.dylib 0x00007fffaf1fccb6 __psynch_mutexwait + 10
1 libsystem_pthread.dylib 0x00007fffaf2e5f6a _pthread_mutex_lock_wait + 100
2 libsystem_pthread.dylib 0x00007fffaf2e3689 _pthread_mutex_lock_slow + 285
3 libobjc.A.dylib 0x00007fffae7df469 recursive_mutex_tt<false>::lock() + 9
4 libobjc.A.dylib 0x00007fffae7e1d2a objc_sync_enter + 25
5 com.apple.cloudkit.CloudKitDaemon 0x00007fffa45756c5 -[CKDClientContext flowControlManager] + 34
6 com.apple.cloudkit.CloudKitDaemon 0x00007fffa4585b94 -[CKDOperation start] + 1564
Thread 5 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000000000006 rcx: 0x0000700009d81508 rdx: 0x0000000000000000
rdi: 0x000000000000711f rsi: 0x0000000000000006 rbp: 0x0000700009d81530 rsp: 0x0000700009d81508
r8: 0x00007fffaf18b650 r9: 0x00007fffaf14da50 r10: 0x000000000c000000 r11: 0x0000000000000206
r12: 0x0000700009d81690 r13: 0x0000000000000030 r14: 0x0000700009d82000 r15: 0x0000000000000008
rip: 0x00007fffaf1fcdd6 rfl: 0x0000000000000206 cr2: 0x00007fffb7efd128
Logical CPU: 0
Error Code: 0x02000148
Trap Number: 133
Binary Images:
0x105865000 - 0x105869ffb cloudd (643.5 - 643.5) <90689D13-419C-36D0-8CBE-706C7B3824EE> /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Support/cloudd
0x10c9a3000 - 0x10c9e0267 dyld (421.2) <947FC440-80F9-32F7-A773-6FC418FE1AB7> /usr/lib/dyld
0x7fff96683000 - 0x7fff96683fff com.apple.Accelerate (1.11 - Accelerate 1.11) <D700DBDF-69AE-37A2-B9C7-0961CF0B6841> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff9669c000 - 0x7fff96bb5feb com.apple.vImage (8.1 - ???) <6408805B-67E9-3874-8D32-0BB814CE5CDA> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff96bb6000 - 0x7fff96d26ff3 libBLAS.dylib (1185) <C7E42BBE-2337-3AEF-9C45-A2F2CB1A5B3E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff96d27000 - 0x7fff96d3bffb libBNNS.dylib (14) <CFDEE88D-E002-347C-BC68-83099651585B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fff96d3c000 - 0x7fff97132fef libLAPACK.dylib (1185) <2E8201CB-9A41-3D65-853E-841917FCE77B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff97133000 - 0x7fff97149fff libLinearAlgebra.dylib (1185) <8CC29DE1-A231-3D5E-B5F1-DCC309036FE0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff9714a000 - 0x7fff97150fff libQuadrature.dylib (3) <120F6228-A3D4-3184-89D7-785ADC2AC715> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fff97151000 - 0x7fff97165ff7 libSparseBLAS.dylib (1185) <C35235B7-CFA6-39A7-BD6E-79F4D9CAFD36> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fff97166000 - 0x7fff972edfe7 libvDSP.dylib (600) <F59348AA-E1D3-3A27-8AB5-F546D38BFB76> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff972ee000 - 0x7fff973a0ffb libvMisc.dylib (600) <70D4B548-47EE-3C6B-A93B-3EA6B60701E0> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff973a1000 - 0x7fff973a1fff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <A395B521-8E54-30F2-B4FE-355D68900DAF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff973a2000 - 0x7fff973e0ff3 com.apple.Accounts (113 - 113) <E9D296BC-6DAC-3AB2-81A0-8DD6D1F8673B> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x7fff97661000 - 0x7fff98432ff7 com.apple.AppKit (6.9 - 1504.76) <AF99A491-3175-362D-B313-074A3F87E49A> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff98444000 - 0x7fff98444fff com.apple.ApplicationServices (48 - 48) <A29F0B74-33C1-3062-B68D-12BC3881C399> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff98445000 - 0x7fff984b3ff7 com.apple.ApplicationServices.ATS (377 - 422.2) <3680281F-DB99-3CA2-9C76-CABFC8DBC980> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff9854d000 - 0x7fff9867cfff libFontParser.dylib (194.6) <F3DF2CF7-B25D-30BB-9EE6-1EA9F3B8A066> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff9867d000 - 0x7fff986c7fff libFontRegistry.dylib (196.3) <855AF921-EAE0-3D07-B161-5EF09806B643> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff987c3000 - 0x7fff9886dff7 com.apple.ColorSync (4.12.0 - 502.1) <5F244DE3-A6E8-335F-AE3B-25F0E407DD62> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff9886e000 - 0x7fff988beff7 com.apple.HIServices (1.22 - 591) <34C950CC-1084-354A-BCE6-9396EDB29DF8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff988bf000 - 0x7fff988ceff3 com.apple.LangAnalysis (1.7.0 - 1.7.0) <47D1A017-91A4-37F3-93E0-3923CD6ED2DE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff988cf000 - 0x7fff9891cfff com.apple.print.framework.PrintCore (12 - 491) <B7CC15C1-AF50-37F3-8AF6-65F8CDC323F0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff9891d000 - 0x7fff98958fff com.apple.QD (3.12 - 310) <8F718290-DD82-36CE-9AF0-EFB6D31A49F4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff98959000 - 0x7fff98964ff7 com.apple.speech.synthesis.framework (6.3.3 - 6.3.3) <629831B1-B13C-30F5-AE16-6BB9037E3753> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff98965000 - 0x7fff98b75fff com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <A1B98513-C19E-376F-8DAF-71BB2F263C5F> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff98b76000 - 0x7fff98b76fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <55C6A958-D52B-3D81-B230-EB949212B5D9> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff98cdf000 - 0x7fff990b2ff7 com.apple.CFNetwork (807.2.14 - 807.2.14) <9702C8B9-2984-3DD9-9C59-A83499C2DBC4> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff990d1000 - 0x7fff993d9ff7 com.apple.HIToolbox (2.1.1 - 856.11) <11F1BAA6-547C-37CB-88DE-6C4B698AFF37> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff993e4000 - 0x7fff9947bff3 com.apple.ink.framework (10.9 - 219) <B44BA36D-7549-3EB2-8CF6-E171885194FB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff9949c000 - 0x7fff994a2ff7 com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <A20B0F7B-C32A-3FF1-BB75-BAC0EE4EF889> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff994a3000 - 0x7fff99580ff7 com.apple.cloudkit.CloudKit (643.5 - 643.5) <2AB1D950-7EA5-359C-B17C-42AEFE99D360> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fff99581000 - 0x7fff99581fff com.apple.Cocoa (6.11 - 22) <6A3C97E3-3905-3767-978F-C2E4C3899CD2> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff996c1000 - 0x7fff99751ff7 com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <A38A11A5-130B-39CE-BEBA-F5427F6801DC> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff99752000 - 0x7fff99765fff com.apple.CoreBluetooth (1.0 - 1) <76AFC4B4-A9FD-3434-B168-90087E71F5C4> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff99766000 - 0x7fff99a60feb com.apple.CoreData (120 - 752.
<FE3F152B-4C35-3A58-A0CB-D04EE5908818> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff99a61000 - 0x7fff99aedfff com.apple.CoreDisplay (1.0 - 1) <48B568C0-1E12-34F4-943D-EAB447FBA1BE> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fff99aee000 - 0x7fff99f88fff com.apple.CoreFoundation (6.9 - 1348.28) <A40AA224-7A50-3989-95D0-5A228A0E2FAF> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff99f89000 - 0x7fff9a60bfff com.apple.CoreGraphics (2.0 - 1070.13) <C6E5A0EC-CEEE-3834-B37C-E5CF9EECDD52> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff9a60c000 - 0x7fff9a84efff com.apple.CoreImage (12.2.0 - 451.2.6) <FA735717-BE82-397E-B0DC-71D83682D2F7> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff9a84f000 - 0x7fff9a8b5ff7 com.apple.corelocation (2100.0.34) <C953574D-5945-34C2-A122-9435E0D5D84C> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
0x7fff9a9b3000 - 0x7fff9a9b3fff com.apple.CoreServices (775.9.7 - 775.9.7) <A5C444F3-408B-3062-AF4B-BF8CD919F221> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff9a9b4000 - 0x7fff9aa05fff com.apple.AE (712.2 - 712.2) <342A13C0-4A6A-3947-B66B-0F624A4A7B52> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff9aa06000 - 0x7fff9ace1ff7 com.apple.CoreServices.CarbonCore (1159.5 - 1159.5) <11CC2194-0C9C-397A-B7F9-CDAB9B68D87D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff9ace2000 - 0x7fff9ad15fff com.apple.DictionaryServices (1.2 - 274) <864F3808-FFDD-3C4B-A5B7-F1A6C4668A86> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff9ad16000 - 0x7fff9ad1effb com.apple.CoreServices.FSEvents (1230 - 1230) <13A2FC17-8F8C-35BF-9584-59FDFB738E2B> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff9ad1f000 - 0x7fff9ae8bff7 com.apple.LaunchServices (775.9.7 - 775.9.7) <E350E4F6-822A-3F04-B59B-468A39AF5C64> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff9ae8c000 - 0x7fff9af3cfff com.apple.Metadata (10.7.0 - 1075.28) <DBB524CD-6938-3623-99C2-4B1EC1E1BE58> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff9af3d000 - 0x7fff9af9cfff com.apple.CoreServices.OSServices (775.9.7 - 775.9.7) <E9625B0B-9AE7-3024-9FEF-FEE0A1876D9D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff9af9d000 - 0x7fff9b00dfff com.apple.SearchKit (1.4.0 - 1.4.0) <F1B3EF8D-E820-317C-AC7F-8F056C246874> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff9b00e000 - 0x7fff9b054ff7 com.apple.coreservices.SharedFileList (38 - 38) <E1400999-1F08-35A1-9D07-27D80A2AF89A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fff9b0e1000 - 0x7fff9b22dff7 com.apple.CoreText (352.0 - 544.5) <E90EA1D8-3491-3014-9043-9928C4E4349C> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff9b22e000 - 0x7fff9b263fff com.apple.CoreVideo (1.8 - 234.0) <48C31E93-87C2-31F4-97E7-9E54C1EA8E7D> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff9b264000 - 0x7fff9b2d5ffb com.apple.framework.CoreWLAN (11.0 - 1200.25.1) <BEBE9C03-3B9A-3948-99E3-CC8148FA2AB5> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff9b309000 - 0x7fff9b314ff3 com.apple.DirectoryService.Framework (10.12 - 194) <0D68A91D-F811-3563-9449-47425CD40895> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff9b315000 - 0x7fff9b3d3ff7 com.apple.DiscRecording (9.0.3 - 9030.4.5) <1A3FBBCF-E81D-3395-B96D-6D9FA8D2EDF0> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff9b3d4000 - 0x7fff9b3d9fff com.apple.DiskArbitration (2.7 - 2.7) <16EA6D93-A2EC-31DB-BF52-C4764E7B1630> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff9b568000 - 0x7fff9b90fff3 com.apple.Foundation (6.9 - 1349.25) <D820A498-2E62-367D-BC72-5845B14C06E3> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff9b93b000 - 0x7fff9b96cfff com.apple.GSS (4.0 - 2.0) <95FAD1F9-1610-3428-B9B4-D32F67C26574> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff9ba2c000 - 0x7fff9bacfffb com.apple.Bluetooth (5.0.2 - 5.0.2f4) <D4B76B20-7777-39C9-8365-FC0C0DE17AB0> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff9bad0000 - 0x7fff9bb65ff7 com.apple.framework.IOKit (2.0.2 - 1324.30.13) <163BE7FA-B29A-348F-8B5F-E301F2E8C964> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff9bb66000 - 0x7fff9bb6cffb com.apple.IOSurface (153.3 - 153.3) <3DD3BF22-0800-31F2-B179-87F87D6F0548> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff9bbbe000 - 0x7fff9bd17fef com.apple.ImageIO.framework (3.3.0 - 1582) <564168E7-BEC0-35E3-9BF0-59B65C17225E> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff9bd18000 - 0x7fff9bd1cfff libGIF.dylib (1582) <040243CD-3A68-3ADC-805C-FE1D17C80028> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff9bd1d000 - 0x7fff9be0dff7 libJP2.dylib (1582) <A55870F9-F27F-3BD0-BE89-981BFF63D485> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff9be0e000 - 0x7fff9be31ffb libJPEG.dylib (1582) <58C01E72-10A0-313F-8139-ED6E9D087ABB> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff9be32000 - 0x7fff9be59ff7 libPng.dylib (1582) <F2CC3750-3520-311B-9C66-9D86036375B7> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff9be5a000 - 0x7fff9be5cff3 libRadiance.dylib (1582) <C3E9CE5C-1A25-391B-9ACB-556AA065B985> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff9be5d000 - 0x7fff9beb6ff3 libTIFF.dylib (1582) <71ADCD24-67C9-31B5-8E48-A4B89AFBB19F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff9bebb000 - 0x7fff9bfe1ff7 com.apple.Intents (1.0 - 1) <2B7F52EB-527A-3139-A7B9-8EB8282742B8> /System/Library/Frameworks/Intents.framework/Versions/A/Intents
0x7fff9ca86000 - 0x7fff9ca9fff7 com.apple.Kerberos (3.0 - 1) <49DCBE1A-130C-3FBF-AAEA-AF9A518913AC> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff9caa0000 - 0x7fff9cad6fff com.apple.LDAPFramework (2.4.28 - 194.5) <0F18D033-BBD8-3D88-A17C-EC7E796CA88F> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff9d29d000 - 0x7fff9d2f5fff com.apple.Metal (86.18 - 86.18) <7DFE0437-25A8-3E87-8318-91573C895742> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fff9dbc9000 - 0x7fff9dbd1fff com.apple.NetFS (6.0 - 4.0) <6614F9B8-0861-338B-8FF0-8E402F96141C> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff9df77000 - 0x7fff9dfc5ff3 com.apple.opencl (2.8.6 - 2.8.6) <85574B12-CEED-373A-808E-B4BC7907AC7A> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff9dfc6000 - 0x7fff9dfdfffb com.apple.CFOpenDirectory (10.12 - 194) <292FCA26-B2E4-37F8-BC8C-8369ACD3345A> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff9dfe0000 - 0x7fff9dfebff7 com.apple.OpenDirectory (10.12 - 194) <399F4633-97CE-3560-BB3C-1E30E9604878> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff9dfec000 - 0x7fff9dfeefff libCVMSPluginSupport.dylib (13.0.10) <06D7F8EC-1D2B-38C2-B3FE-7D39185370BE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff9dfef000 - 0x7fff9dff2ff7 libCoreFSCache.dylib (151.1) <1910EF80-DE30-3817-8FDF-63F3C8B4BA37> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fff9dff3000 - 0x7fff9dff6fff libCoreVMClient.dylib (151.1) <8C8E9295-1918-3763-A0B7-6397EB181EF4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff9dff7000 - 0x7fff9dfffffb libGFXShared.dylib (13.0.10) <0257924D-0226-306C-817B-6B624AD8C80F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff9e000000 - 0x7fff9e00bfff libGL.dylib (13.0.10) <9BDE83C8-D820-34AB-ADBB-89394EE706FB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff9e00c000 - 0x7fff9e048fe7 libGLImage.dylib (13.0.10) <38CB2689-C869-31A4-BECB-2E4F91F1FD1C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff9e1c0000 - 0x7fff9e200ff3 libGLU.dylib (13.0.10) <0303130B-3A1D-37C3-BEA5-0A2154C842D3> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff9eb68000 - 0x7fff9eb76fff com.apple.opengl (13.0.10 - 13.0.10) <7F1E35F8-F0D1-389B-B8CC-E06E02714005> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff9f893000 - 0x7fff9fa8eff7 com.apple.QuartzCore (1.11 - 449.41.15) <32D80183-DCE4-34A7-AA46-DD1DE0DAA859> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff9fae5000 - 0x7fff9faf8ff7 com.apple.SafariServices.framework (12602 - 12602.3.12.0.1) <B6EEDF8F-56BF-3E9D-A615-175E03E6A547> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
0x7fff9fff4000 - 0x7fffa0313fff com.apple.security (7.0 - 57740.31.2) <A47D7BAE-0591-3184-8E44-FB2EB08A19C2> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fffa0314000 - 0x7fffa038aff7 com.apple.securityfoundation (6.0 - 55132.20.1) <9407620B-B230-3320-B0B7-5AE59F1D135C> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fffa03b4000 - 0x7fffa03b7ff3 com.apple.xpc.ServiceManagement (1.0 - 1) <4E24C12E-6164-3A7A-8EB8-C2523492BAE8> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fffa073e000 - 0x7fffa07afff7 com.apple.SystemConfiguration (1.14 - 1.14) <D9A57D90-E54F-3E1A-AA2F-F5A694BCE4BB> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fffa2275000 - 0x7fffa22c0ff7 com.apple.AOSAccounts (1.3.1 - 62.6) <0BAA7CE9-F498-39F2-A4B5-2B4CBD90ACD7> /System/Library/PrivateFrameworks/AOSAccounts.framework/Versions/A/AOSAccounts
0x7fffa22c1000 - 0x7fffa255dffb com.apple.AOSKit (1.07 - 241) <65BECFB4-57A5-341C-BD5E-750D0A74AF52> /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/AOSKit
0x7fffa255e000 - 0x7fffa255effb com.apple.AOSMigrate (1.0 - 1) <17287A8D-1469-3DAD-898D-BEA0339745AB> /System/Library/PrivateFrameworks/AOSMigrate.framework/Versions/A/AOSMigrate
0x7fffa2678000 - 0x7fffa267eff7 com.apple.APFS (1.0 - 1) <7846BAA7-F9FD-3110-8DCB-C6DFAA86F7B0> /System/Library/PrivateFrameworks/APFS.framework/Versions/A/APFS
0x7fffa2ac1000 - 0x7fffa2b66ffb com.apple.accounts.AccountsDaemon (113 - 113) <8D7BC2C8-5645-3B24-ACD4-88887CACBB30> /System/Library/PrivateFrameworks/AccountsDaemon.framework/Versions/A/AccountsDaemon
0x7fffa2de8000 - 0x7fffa2e03ff3 com.apple.AppContainer (4.0 - 307.30.3) <EF4C3C83-6F51-38F7-A3D2-2D46EE4560EB> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
0x7fffa2e04000 - 0x7fffa2e11ff3 com.apple.AppSandbox (4.0 - 307.30.3) <D2C978EB-F4F1-3E79-9DB1-BEE2A92590CE> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
0x7fffa2e12000 - 0x7fffa2e34ffb com.apple.framework.Apple80211 (12.0 - 1200.41) <360012DB-DAE7-3EEF-85F0-E5BE1DE3425D> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fffa2e35000 - 0x7fffa2e44fdb com.apple.AppleFSCompression (88 - 1.0) <B6E2148F-BFBF-3F1B-A7DF-0F39190B4C20> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fffa2f0d000 - 0x7fffa2f18ff7 com.apple.AppleIDAuthSupport (1.0 - 1) <62FE63B8-8893-31D6-ADAD-1EFBC800F9B7> /System/Library/PrivateFrameworks/AppleIDAuthSupport.framework/Versions/A/AppleIDAuthSupport
0x7fffa2f35000 - 0x7fffa2fc097f com.apple.AppleJPEG (1.0 - 1) <B4C3209B-58A5-359F-A898-F61B6C40E5E9> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fffa2fd4000 - 0x7fffa2feffff com.apple.aps.framework (4.0 - 4.0) <05212284-4905-3EF2-B284-DC1794769C13> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fffa2ff0000 - 0x7fffa2ff8ffb com.apple.AppleSRP (5.0 - 1) <F105D2D2-8A12-3361-9C9D-E405668CAF75> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fffa3058000 - 0x7fffa305fffb com.apple.AssetCacheServices (31.2 - 31.2) <5E08DBDE-1DF0-37AC-9ED0-035A2ED67573> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServices
0x7fffa30f6000 - 0x7fffa3380ff7 com.apple.AuthKit (1.0 - 1) <D9C8B950-8545-369A-BA18-D0DACBE117D9> /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/AuthKit
0x7fffa33e5000 - 0x7fffa3463fff com.apple.backup.framework (1.8.3 - 1.8.3) <B2E28A7A-1727-3052-AA73-CBC108286C07> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fffa348c000 - 0x7fffa34c9ff7 com.apple.bom (14.0 - 193.
<FAA5CE82-0A87-34C5-A606-81A179009930> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fffa34d3000 - 0x7fffa34d3fff com.apple.SafariDAVNotifier (1.1.1 - 1) <A1ACBB4B-FAA8-3380-A30C-C403913FE4FC> /System/Library/PrivateFrameworks/BookmarkDAV.framework/Versions/A/Frameworks/SafariDAVNotifier.framework/Versions/A/SafariDAVNotifier
0x7fffa3707000 - 0x7fffa3733fff com.apple.CacheDelete (1.0 - 1) <74C78009-7CC8-366B-8673-3D698AC1C307> /System/Library/PrivateFrameworks/CacheDelete.framework/Versions/A/CacheDelete
0x7fffa40e9000 - 0x7fffa4110ffb com.apple.ChunkingLibrary (172 - 172) <83E91936-305D-32A4-A256-5582B96B1852> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fffa4111000 - 0x7fffa41a3ff7 com.apple.CloudDocs (1.0 - 485.12) <42A562A2-284D-3252-9341-855E52E45A02> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fffa4530000 - 0x7fffa498aff7 com.apple.cloudkit.CloudKitDaemon (643.5 - 643.5) <3C343914-F969-342D-B554-DCC1FBDAC433> /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Versions/A/CloudKitDaemon
0x7fffa49d6000 - 0x7fffa49e9ff7 com.apple.CloudPhotoServicesConfiguration (2.0 - 3130.0.240) <5421C35E-BF96-3D3F-B185-3EE046F9C38F> /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/Frameworks/CloudPhotoServicesConfiguration.framework/Versions/A/CloudPhotoServicesConfiguration
0x7fffa49ea000 - 0x7fffa49eaff7 com.apple.CloudPhotosConfigurationXPC (2.0 - 3130.0.240) <D6127039-B733-39D4-B2B9-B53514EDBFDB> /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/Frameworks/CloudPhotosConfigurationXPC.framework/Versions/A/CloudPhotosConfigurationXPC
0x7fffa49eb000 - 0x7fffa49f7fff com.apple.CloudServices (1.0 - 222.30.3) <4D5CE15B-66D6-3E8F-A390-75B175F3D505> /System/Library/PrivateFrameworks/CloudServices.framework/Versions/A/CloudServices
0x7fffa4a39000 - 0x7fffa4a42ffb com.apple.CommonAuth (4.0 - 2.0) <830B940B-3523-38DE-996D-695739616D10> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fffa4a43000 - 0x7fffa4a4ffff com.apple.commonutilities (8.0 - 900) <9BBB5C4D-7D27-385E-B1B7-38AA77E2F1B3> /System/Library/PrivateFrameworks/CommonUtilities.framework/Versions/A/CommonUtilities
0x7fffa504a000 - 0x7fffa5052ffb com.apple.frameworks.CoreDaemon (1.3 - 1.3) <212D3DB2-DC44-329F-B810-238DF156D1EE> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
0x7fffa5053000 - 0x7fffa512bff3 com.apple.CoreDuet (1.0 - 1) <FD8B1E05-B93E-3EBE-9C0B-39AF155C81C1> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
0x7fffa5148000 - 0x7fffa515afff com.apple.CoreDuetDaemonProtocol (1.0 - 1) <F5D0C478-2F7F-3BA6-9EA5-D4728A58A828> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
0x7fffa515d000 - 0x7fffa515ffff com.apple.CoreDuetDebugLogging (1.0 - 1) <9A0AD6D9-1C6F-38FC-A02E-911BD67C11DA> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
0x7fffa5162000 - 0x7fffa5172fff com.apple.CoreEmoji (1.0 - 39.1) <0A46D6BF-22F3-39AD-B3DC-DE1EE5C442CC> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fffa5455000 - 0x7fffa5485ff3 com.apple.CoreServicesInternal (276.2 - 276.2) <7D8DEF04-72F1-39F4-BBFB-09E65D7B8C10> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fffa5715000 - 0x7fffa579ffff com.apple.CoreSymbolication (61050) <F4B7C798-F7B7-3977-AA08-59A03F00308E> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fffa57a0000 - 0x7fffa58defd7 com.apple.coreui (2.1 - 430.6) <99D08D71-3E9D-300C-9EB2-A73F1B5E228C> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fffa58df000 - 0x7fffa598fff3 com.apple.CoreUtils (5.0 - 500.9) <5567181B-721C-339E-A3DC-579E36D92341> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fffa59df000 - 0x7fffa5a44ff3 com.apple.framework.CoreWiFi (12.0 - 1200.25.1) <BEFA276C-D284-3160-8641-7DD47E38C9D7> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fffa5a45000 - 0x7fffa5a52ff7 com.apple.CrashReporterSupport (10.12 - 817) <CB5251B1-5BE5-308B-B30B-0050065E04CC> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fffa5ac4000 - 0x7fffa5aceff7 com.apple.framework.DFRFoundation (1.0 - 104.14) <258B6CFE-FD64-31C5-9973-2FD80597ECDA> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fffa5b04000 - 0x7fffa5b7bff7 com.apple.datadetectorscore (7.0 - 539.1) <E9892E38-3D5F-36CF-BDC5-E4E3C5516B55> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fffa5bb8000 - 0x7fffa5bf7fff com.apple.DebugSymbols (137 - 137) <B229F3F7-250B-3151-8048-CEA7BF80FA52> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fffa5bf8000 - 0x7fffa5d09fff com.apple.desktopservices (1.11.3 - 1.11.3) <CCE689AA-85F3-3587-AE12-1231E8ED127E> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fffa5d0c000 - 0x7fffa5d0dff3 com.apple.diagnosticlogcollection (10.0 - 1000) <969A55D2-366E-3615-81D3-DEBD091471C8> /System/Library/PrivateFrameworks/DiagnosticLogCollection.framework/Versions/A/DiagnosticLogCollection
0x7fffa5d0e000 - 0x7fffa5de4ff7 com.apple.DiskImagesFramework (444.30.5 - 444.30.5) <E119DFDF-592B-35DF-8D44-73293AF31595> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fffa5e54000 - 0x7fffa5e61ffb com.apple.DuetActivityScheduler (1.0 - 1) <1D683D6E-889A-33EB-B689-582F9C5D94E4> /System/Library/PrivateFrameworks/DuetActivityScheduler.framework/Versions/A/DuetActivityScheduler
0x7fffa5e98000 - 0x7fffa5e9affb com.apple.EFILogin (2.0 - 2) <E03C6225-7650-3498-906B-C248A93F55B5> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fffa5f35000 - 0x7fffa5f4bfff com.apple.icloud.FMCoreLite (1.0 - 1) <50E158B2-E673-334C-BE62-00ADAC6ECAD8> /System/Library/PrivateFrameworks/FMCoreLite.framework/Versions/A/FMCoreLite
0x7fffa5fed000 - 0x7fffa641eff7 com.apple.vision.FaceCore (3.3.2 - 3.3.2) <DEB42099-6927-332C-8D3E-D45096318D25> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fffa644a000 - 0x7fffa6456ff7 com.apple.icloud.FindMyDevice (1.0 - 1) <BF63AB60-BD91-3EAA-AE3D-270ACF863E58> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
0x7fffa7773000 - 0x7fffa7773fff libmetal_timestamp.dylib (600.0.48.32) <31DF1B9E-0BBF-308B-B78D-11CCE72DAA68> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
0x7fffa7a3f000 - 0x7fffa7a5bff3 com.apple.GenerationalStorage (2.0 - 259.2) <00BF8427-967F-3693-A86F-DA0F29B49BF3> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fffa7a74000 - 0x7fffa8113fff com.apple.GeoServices (1.0 - 1228.22.8.29.13) <280AEA5E-2EF5-3A88-B1DE-D0811045F9CC> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fffa8159000 - 0x7fffa81cffff com.apple.Heimdal (4.0 - 2.0) <00F00E7E-7EF4-3254-86D3-ADA4F67938CF> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fffa8207000 - 0x7fffa82c8ff7 com.apple.ids (10.0 - 1000) <ACB515FC-B92F-3D08-AC42-444784B8E6DE> /System/Library/PrivateFrameworks/IDS.framework/Versions/A/IDS
0x7fffa82c9000 - 0x7fffa830cff7 com.apple.idsfoundation (10.0 - 1000) <48F51212-3252-32A2-A349-7CDA971511B7> /System/Library/PrivateFrameworks/IDSFoundation.framework/Versions/A/IDSFoundation
0x7fffa873e000 - 0x7fffa87a2ffb com.apple.imfoundation (10.0 - 1000) <57FF9654-3548-34FD-9306-1A34CE118D9F> /System/Library/PrivateFrameworks/IMFoundation.framework/Versions/A/IMFoundation
0x7fffa87f2000 - 0x7fffa87f9ffb com.apple.IOAccelerator (289.27 - 289.27) <61C7765B-EE2E-36E1-B51C-FFA13A657711> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fffa87fb000 - 0x7fffa880fff3 com.apple.IOPresentment (1.0 - 25) <40934217-996A-3DDB-A8C4-484CA0F0222B> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fffa8810000 - 0x7fffa8832fff com.apple.IconServices (74.3 - 74.3) <3F0BD358-D019-3083-82F2-69CCAD5E5D66> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fffa885f000 - 0x7fffa885ffff com.apple.IntentsFoundation (1.0 - 1) <3CA42171-42EF-3E7B-BF76-2F03B1459BED> /System/Library/PrivateFrameworks/IntentsFoundation.framework/Versions/A/IntentsFoundation
0x7fffa890b000 - 0x7fffa8914ffb com.apple.security.KeychainCircle.KeychainCircle (1.0 - 1) <A6880BA5-3203-3B70-8E3F-94188E31C2B1> /System/Library/PrivateFrameworks/KeychainCircle.framework/Versions/A/KeychainCircle
0x7fffa8915000 - 0x7fffa8acbfff com.apple.LanguageModeling (1.0 - 123.2.4) <FEB98F96-A9BB-3E6C-85B4-B466825B8C92> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fffa8afb000 - 0x7fffa8affff7 com.apple.LoginUICore (4.0 - 4.0) <7B8321EA-6F89-37C0-A128-398436BE6342> /System/Library/PrivateFrameworks/LoginUIKit.framework/Versions/A/Frameworks/LoginUICore.framework/Versions/A/LoginUICore
0x7fffa8bab000 - 0x7fffa8c7cffb com.apple.MMCS (1.3 - 381.1) <5582D879-5F26-3552-8E88-58703456EB7A> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
0x7fffa9166000 - 0x7fffa9168ffb com.apple.marco (10.0 - 1000) <C761F1E8-BDAC-34F8-BEBF-9B812ED294F8> /System/Library/PrivateFrameworks/Marco.framework/Versions/A/Marco
0x7fffa9200000 - 0x7fffa9234ff3 com.apple.MediaKit (16 - 840) <2035FF47-C7E6-3F73-A335-AC0BFBB1DB36> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fffa938f000 - 0x7fffa9408ff7 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <6A759DBA-B7DF-363B-9827-AB1D1129BB34> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fffa956e000 - 0x7fffa9579ff3 com.apple.MobileKeyBag (2.0 - 1.0) <8A7EEA75-8334-3FB5-A83B-F0ECB87952B2> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
0x7fffa958a000 - 0x7fffa95b2fff com.apple.MultitouchSupport.framework (368.7 - 368.7) <BA3D9226-2672-3039-A105-C2639A7E22F2> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fffa9661000 - 0x7fffa966bfff com.apple.NetAuth (6.0 - 6.0) <1E7765FC-4580-3CE4-A0F1-CAA22006AE43> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fffa9678000 - 0x7fffa96f3ff3 com.apple.Network (1.0 - 1) <4CE42C2C-C34E-3760-A02E-1752E14796CC> /System/Library/PrivateFrameworks/Network.framework/Versions/A/Network
0x7fffa9a63000 - 0x7fffa9a65fff com.apple.OAuth (25 - 25) <1A29AF10-4AFE-32A2-9CA9-A98BACA2CE8D> /System/Library/PrivateFrameworks/OAuth.framework/Versions/A/OAuth
0x7fffa9ee7000 - 0x7fffa9f28ff7 com.apple.PerformanceAnalysis (1.145 - 145) <2D5D4A56-5F67-3BBB-9AAC-95FAC199877C> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fffaa536000 - 0x7fffaa558ff7 com.apple.pluginkit.framework (1.0 - 1) <E41C33BD-8C3F-32B2-A485-A2BFEE148E04> /System/Library/PrivateFrameworks/PlugInKit.framework/Versions/A/PlugInKit
0x7fffaa59f000 - 0x7fffaa5caffb com.apple.ProtectedCloudStorage (1.0 - 1) <4B38E6F6-AD64-3345-B51D-38E9DD518666> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fffaa5cb000 - 0x7fffaa5e5fff com.apple.ProtocolBuffer (1 - 249) <D8B7694B-B598-3728-8583-9C4CC0F05B64> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fffaa5ff000 - 0x7fffaa622ff3 com.apple.RemoteViewServices (2.0 - 124) <4765DC2E-CF05-38CF-9564-1FBACB7E167C> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fffab28e000 - 0x7fffab291fff com.apple.SecCodeWrapper (4.0 - 307.30.3) <1B0B2122-C230-3E3F-8A81-EBD58818586B> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
0x7fffab298000 - 0x7fffab29ffff com.apple.SetupAssistantFramework (1.0 - 1) <16464194-2E75-334A-B1DE-01D372892D38> /System/Library/PrivateFrameworks/SetupAssistantFramework.framework/Versions/A/SetupAssistantFramework
0x7fffab320000 - 0x7fffab39dff7 com.apple.Sharing (696.1.22 - 696.1.22) <D0A5C682-8996-3851-B332-AD05301E6FA3> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fffab3be000 - 0x7fffab61dfe7 com.apple.SkyLight (1.600.0 - 122.
<2B8B6734-2B70-3BD8-BB8E-3338FB2708EE> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fffab7fe000 - 0x7fffab80aff7 com.apple.SpeechRecognitionCore (3.3.2 - 3.3.2) <F9F0FCED-3A72-3639-91F2-B7EF248ED1B9> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fffabef3000 - 0x7fffabf5fff3 com.apple.Symbolication (61080.2) <27A57DC2-FEB7-3D23-AEB5-E3E76C5AAE79> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fffac149000 - 0x7fffac175ffb com.apple.framework.SystemAdministration (1.0 - 1.0) <81B27779-ABCD-35DE-931E-E8BCE07ACFB4> /System/Library/PrivateFrameworks/SystemAdministration.framework/Versions/A/SystemAdministration
0x7fffac359000 - 0x7fffac35fff7 com.apple.TCC (1.0 - 1) <956F7C1A-D457-3FE0-9CFE-3F1719F0865C> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fffac3ee000 - 0x7fffac5b6ff7 com.apple.TextureIO (1.41 - 1.41) <3A9D9FD9-8997-3BD1-8046-76D0BF709806> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fffac62c000 - 0x7fffac7bcff3 com.apple.UIFoundation (1.0 - 490.7) <047781ED-9E79-361F-8E04-71FF90C650F3> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fffad218000 - 0x7fffad2dbff7 com.apple.ViewBridge (280 - 280) <6D4F6019-5ECC-377B-AF7D-9796E96841CB> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x7fffad452000 - 0x7fffad5c8fff libAWDSupportFramework.dylib (561.2) <3DC1B774-B84A-330A-93E5-1C6E91C969E2> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libAWDSupportFramework.dylib
0x7fffad5c9000 - 0x7fffad638fff libprotobuf.dylib (561.2) <82A41F4C-B228-35AE-88FA-59813ABE3DD9> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/Libraries/libprotobuf.dylib
0x7fffad639000 - 0x7fffad676fff com.apple.awd (1.0 - 849) <4989C08A-A998-367B-A64E-48153D224274> /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Versions/A/WirelessDiagnostics
0x7fffad705000 - 0x7fffad70bfff com.apple.XPCService (2.0 - 1) <BC3FCE26-6219-3316-949F-37F7005C9A0F> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
0x7fffad7dc000 - 0x7fffad7deffb com.apple.loginsupport (1.0 - 1) <4449ACBA-27A8-3311-BD92-CB7E63583FC6> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fffad7df000 - 0x7fffad7f7ffb com.apple.login (3.0 - 3.0) <F322D80F-F291-3824-BB32-54E8F8B5509D> /System/Library/PrivateFrameworks/login.framework/Versions/A/login
0x7fffad833000 - 0x7fffad84eff7 libCRFSuite.dylib (34) <BACC371B-6153-36B5-BC54-3BCF26FBB221> /usr/lib/libCRFSuite.dylib
0x7fffad84f000 - 0x7fffad85afff libChineseTokenizer.dylib (21) <09E74E18-ADB2-30D2-A858-13691CB1186C> /usr/lib/libChineseTokenizer.dylib
0x7fffad85b000 - 0x7fffad8ebff7 libCoreStorage.dylib (540.30.1) <127A0A91-4E62-39A7-B18F-A3E166304505> /usr/lib/libCoreStorage.dylib
0x7fffad8ec000 - 0x7fffad8edff3 libDiagnosticMessagesClient.dylib (102) <422911A4-E273-3E88-BFC4-DF6470E48242> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fffad8ee000 - 0x7fffadb01fff libFosl_dynamic.dylib (16.38) <8232FA8A-F16A-3DC0-AE68-B61EFCD5F4A4> /usr/lib/libFosl_dynamic.dylib
0x7fffadb1d000 - 0x7fffadb24fff libMatch.1.dylib (27) <5D52A207-E2AF-3E05-8C51-91C1D82FCEE8> /usr/lib/libMatch.1.dylib
0x7fffadb25000 - 0x7fffadb25fff libOpenScriptingUtil.dylib (172) <D025E180-BB3B-3FFA-98FC-B6835354D723> /usr/lib/libOpenScriptingUtil.dylib
0x7fffadb26000 - 0x7fffadb2aff3 libScreenReader.dylib (477.20.6) <8158E263-B7DF-3B0C-BABE-4FE94A53DFE5> /usr/lib/libScreenReader.dylib
0x7fffadb2b000 - 0x7fffadb2cff3 libSystem.B.dylib (1238) <FF55E335-37C3-3567-9415-A3A1473775F5> /usr/lib/libSystem.B.dylib
0x7fffadb2d000 - 0x7fffadb94ff7 libTelephonyUtilDynamic.dylib (1413) <91A5B47A-167B-3A3C-8E59-F5B8F5A50D35> /usr/lib/libTelephonyUtilDynamic.dylib
0x7fffadb98000 - 0x7fffadbc3ffb libarchive.2.dylib (41.30.3) <19B93FE5-4386-38C8-963F-7DBDAB96FEBA> /usr/lib/libarchive.2.dylib
0x7fffadbc4000 - 0x7fffadc40fc7 libate.dylib (1.12.13) <8A963F37-CB4F-37FB-BFA5-273917C42437> /usr/lib/libate.dylib
0x7fffadc44000 - 0x7fffadc44ff3 libauto.dylib (187) <5BBF6A00-CC76-389D-84E7-CA88EDADE683> /usr/lib/libauto.dylib
0x7fffadc45000 - 0x7fffadc55ff3 libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
0x7fffadc56000 - 0x7fffadc64ff7 libbz2.1.0.dylib (38) <6FD3B63F-0F86-3A25-BD5B-E243F58792C9> /usr/lib/libbz2.1.0.dylib
0x7fffadc65000 - 0x7fffadcbbff7 libc++.1.dylib (307.4) <BEE86868-F831-384C-919E-2B286ACFE87C> /usr/lib/libc++.1.dylib
0x7fffadcbc000 - 0x7fffadce6fff libc++abi.dylib (307.2) <1CEF8ABB-7E6D-3C2F-8E0A-E7884478DD23> /usr/lib/libc++abi.dylib
0x7fffadce7000 - 0x7fffadcf7ffb libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
0x7fffadcf8000 - 0x7fffadd0dfc3 libcompression.dylib (34) <1691D6F2-46CD-3DA6-B44F-24CDD9BD0E4E> /usr/lib/libcompression.dylib
0x7fffadd0e000 - 0x7fffadd0eff7 libcoretls.dylib (121.31.1) <BCC32537-4831-3E9F-876E-8C9F4CF52FD3> /usr/lib/libcoretls.dylib
0x7fffadd0f000 - 0x7fffadd10ff3 libcoretls_cfhelpers.dylib (121.31.1) <6F37C5AD-7999-3D31-A52F-7AEED935F32D> /usr/lib/libcoretls_cfhelpers.dylib
0x7fffae041000 - 0x7fffae04cfff libcsfde.dylib (540.30.1) <8E7FAE94-37E0-3181-B2C4-9878FFF63851> /usr/lib/libcsfde.dylib
0x7fffae04d000 - 0x7fffae0a0ff7 libcups.2.dylib (450) <78243BA4-43AB-3364-8111-8D54D3382621> /usr/lib/libcups.2.dylib
0x7fffaf195000 - 0x7fffaf198fff libsystem_coreservices.dylib (41.4) <1A572B9E-0C47-320F-8C64-7990D0A5FB5A> /usr/lib/system/libsystem_coreservices.dylib
0x7fffaf199000 - 0x7fffaf1b1ff3 libsystem_coretls.dylib (121.31.1) <4676F06D-274D-31BE-B61C-4D7A4AEF4858> /usr/lib/system/libsystem_coretls.dylib
0x7fffaf1b2000 - 0x7fffaf1b8fff libsystem_dnssd.dylib (765.30.11) <DC708D84-ED7D-3936-B996-A67C66B8DDAA> /usr/lib/system/libsystem_dnssd.dylib
0x7fffaf1b9000 - 0x7fffaf1e2ff7 libsystem_info.dylib (503.30.1) <9ED9121C-F111-3FAD-BC2F-C95DEE1C9362> /usr/lib/system/libsystem_info.dylib
0x7fffaf1e3000 - 0x7fffaf205ff7 libsystem_kernel.dylib (3789.31.2) <FCEEBBD4-DF66-34D8-A32F-4F8C8E814E40> /usr/lib/system/libsystem_kernel.dylib
0x7fffaf206000 - 0x7fffaf24dfe7 libsystem_m.dylib (3121.4) <266DB92B-A86F-3691-80FB-1B26AD73CFF3> /usr/lib/system/libsystem_m.dylib
0x7fffaf24e000 - 0x7fffaf26cff7 libsystem_malloc.dylib (116.30.3) <F40DEE3B-386A-3529-A3F7-98117ED55BF4> /usr/lib/system/libsystem_malloc.dylib
0x7fffaf26d000 - 0x7fffaf2c4ffb libsystem_network.dylib (856.30.16) <4AE368E9-605D-379D-B04C-2AC7455B8250> /usr/lib/system/libsystem_network.dylib
0x7fffaf2c5000 - 0x7fffaf2ceff3 libsystem_networkextension.dylib (563.30.15) <EB020B0C-7DF0-3EEF-8E3C-15DA3C01D687> /usr/lib/system/libsystem_networkextension.dylib
0x7fffaf2cf000 - 0x7fffaf2d8ff3 libsystem_notify.dylib (165.20.1) <E7FD3A7C-DD07-36E2-9FA4-7561F9F114DA> /usr/lib/system/libsystem_notify.dylib
0x7fffaf2d9000 - 0x7fffaf2e1fe7 libsystem_platform.dylib (126.1.2) <3CA06D4E-C00A-36DE-AA65-3A390097D1F6> /usr/lib/system/libsystem_platform.dylib
0x7fffaf2e2000 - 0x7fffaf2ecff7 libsystem_pthread.dylib (218.30.1) <C869ED7C-BE29-3532-8E69-3A8DA1447EDC> /usr/lib/system/libsystem_pthread.dylib
0x7fffaf2ed000 - 0x7fffaf2f0ff7 libsystem_sandbox.dylib (592.31.1) <7BBFDF96-293F-3DD9-B3A4-7C168280B441> /usr/lib/system/libsystem_sandbox.dylib
0x7fffaf2f1000 - 0x7fffaf2f2fff libsystem_secinit.dylib (24) <5C1F1E47-0F7D-3E25-8DEB-D9DB1F902281> /usr/lib/system/libsystem_secinit.dylib
0x7fffaf2f3000 - 0x7fffaf2fafff libsystem_symptoms.dylib (532.30.6) <5D990CF5-B58F-39F7-B375-99B4EC62CFBD> /usr/lib/system/libsystem_symptoms.dylib
0x7fffaf2fb000 - 0x7fffaf31bff7 libsystem_trace.dylib (518.30.7) <5BD4ECD4-75CA-38EA-AF5C-B481C15955F8> /usr/lib/system/libsystem_trace.dylib
0x7fffaf31c000 - 0x7fffaf321ffb libunwind.dylib (35.3) <9F7C2AD8-A9A7-3DE4-828D-B0F0F166AAA0> /usr/lib/system/libunwind.dylib
0x7fffaf322000 - 0x7fffaf34bff7 libxpc.dylib (972.30.7) <65E41BB6-EBD5-3D93-B0BE-B190CEE4DD93> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 93
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=268.3M resident=0K(0%) swapped_out_or_unallocated=268.3M(100%)
Writable regions: Total=101.6M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=101.6M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Activity Tracing 256K 2
Dispatch continuations 16.0M 2
Kernel Alloc Once 8K 2
MALLOC 73.9M 23
MALLOC guard page 32K 7
Memory Tag 251 16K 2
SQLite page cache 192K 4
STACK GUARD 56.0M 8
Stack 11.0M 8
VM_ALLOCATE 12K 4
__DATA 25.5M 264
__IMAGE 528K 2
__LINKEDIT 111.5M 4
__TEXT 156.8M 269
__UNICODE 556K 2
mapped file 29.1M 7
shared memory 340K 8
TOTAL 481.7M 601
Grazie a tt in anticipo.
