Slowblues ha scritto:... non so come fare i tag code tra cui racchiudere il testo.....
Questo testo è racchiuso tra i tag Code
Hai veramente una marea di roba, evidentemente la usi... non ci vedo ciofeche. A parte AVAST: Io lo rimuoverei senz'altro, è spesso causa di rallentamenti e problematiche di vario genere, a fronte di vantaggi nemmeno misurabili.Slowblues ha scritto:Questo è il report etrecheck
/Feb 21 15:17:56 imacdignnielkan syncdefaultsd[2347]: SecTaskLoadEntitlements failed error=3
Feb 21 15:17:56 imacdignnielkan syncdefaultsd[2347]: com.apple.Safari has been removed from syncing apps.
Feb 21 15:17:56 imacdignnielkan com.apple.xpc.launchd[1] (com.apple.WebKit.Networking.F8BFEF55-1DAD-4900-8DFC-8ACD62429D42[303]): Service exited with abnormal code: 1
Feb 21 15:17:56 imacdignnielkan com.apple.WebKit.WebContent[816]: [15:17:56.721] <<<< Boss >>>> figPlaybackBossPrerollCompleted: unexpected preroll-complete notification
Feb 21 15:17:56 imacdignnielkan com.apple.WebKit.WebContent[816]: [15:17:56.788] FigAgglomeratorSetObjectForKey signalled err=-16020 (kFigStringConformerError_ParamErr) (NULL key) at /Library/Caches/com.apple.xbs/Sources/CoreMedia/CoreMedia-1731.15.33/Prototypes/LegibleOutput/FigAgglomerator.c line 92
Feb 21 15:17:56 imacdignnielkan com.apple.WebKit.WebContent[816]: [15:17:56.828] <<<< Boss >>>> figPlaybackBossPrerollCompleted: unexpected preroll-complete notification
Feb 21 15:17:57 imacdignnielkan com.apple.xpc.launchd[1] (com.apple.Console.68832[2346]): Service exited due to signal: Killed: 9
Feb 21 15:17:57 imacdignnielkan WindowServer[163]: CGXGetConnectionProperty: Invalid connection 36475
Feb 21 15:17:57 --- last message repeated 4 times ---
Feb 21 15:17:57 imacdignnielkan loginwindow[95]: Login Window point of no return
Feb 21 15:17:57 imacdignnielkan com.apple.xpc.launchd[1] (com.apple.WebKit.WebContent.C5BA118D-FE08-4470-B421-7D51DA17C902[1008]): Service exited with abnormal code: 1
Feb 21 15:17:57 imacdignnielkan com.apple.xpc.launchd[1] (com.apple.WebKit.WebContent.95B5EF09-138B-4335-8012-8F2679BC28FB[1408]): Service exited with abnormal code: 1
Feb 21 15:17:57 imacdignnielkan com.apple.xpc.launchd[1] (com.apple.AirPlayUIAgent[361]): Service exited due to signal: Killed: 9
Feb 21 15:17:57 imacdignnielkan SystemUIServer[278]: Spotlight: Service connection interrupted!
Feb 21 15:17:57 imacdignnielkan AirPlayXPCHelper[100]: 2016-02-21 03:17:57.616981 PM [APBrowser] IPv4 listener stopped.
Feb 21 15:17:57 imacdignnielkan com.apple.xpc.launchd[1] (com.apple.lateragent[392]): Service exited due to signal: Killed: 9
Feb 21 15:17:57 imacdignnielkan com.apple.xpc.launchd[1] (com.apple.universalaccessAuthWarn[597]): Service exited due to signal: Killed: 9
Feb 21 15:17:57 imacdignnielkan appleeventsd[54]: SecTaskLoadEntitlements failed error=3
Feb 21 15:17:57 --- last message repeated 3 times ---
Feb 21 15:17:57 imacdignnielkan loginwindow[95]: ERROR | -[SessionLogoutManager allPrivateProcesses] | No LS dictionary found for LSASN: LSASN:{hi=0x0;lo=0x14014}
Feb 21 15:17:57 imacdignnielkan com.apple.xpc.launchd[1] (com.apple.EscrowSecurityAlert[1886]): Service exited due to signal: Killed: 9
Feb 21 15:17:57 imacdignnielkan loginwindow[95]: ERROR | -[SessionLogoutManager allPrivateProcesses] | No LS dictionary found for LSASN: LSASN:{hi=0x0;lo=0x71071}
Feb 21 15:17:57 imacdignnielkan com.apple.xpc.launchd[1] (com.apple.cloudphotosd[285]): Service exited due to signal: Killed: 9
Feb 21 15:17:57 imacdignnielkan com.apple.xpc.launchd[1] (com.apple.wifi.WiFiAgent[365]): Service exited due to signal: Killed: 9
Feb 21 15:17:57 imacdignnielkan com.apple.xpc.launchd[1] (com.apple.storeuid[2124]): Service exited due to signal: Killed: 9
Feb 21 15:17:57 imacdignnielkan loginwindow[95]: ERROR | -[SessionLogoutManager allPrivateProcesses] | No LS dictionary found for LSASN: LSASN:{hi=0x0;lo=0x7e07e}
Feb 21 15:17:57 imacdignnielkan com.apple.xpc.launchd[1] (com.apple.universalaccessd[258]): Service exited due to signal: Killed: 9
Feb 21 15:17:57 imacdignnielkan identityservicesd[265]: Quit - notifying about shutdown
Feb 21 15:17:57 imacdignnielkan identityservicesd[265]: Quit - shutting down daemon
Feb 21 15:17:57 imacdignnielkan loginwindow[95]: BUG in libdispatch client: kevent[EVFILT_PROC] enable: "No such file or directory" - 0x2
Feb 21 15:17:57 imacdignnielkan com.apple.xpc.launchd[1] (com.apple.coreservices.uiagent[296]): Service exited due to signal: Killed: 9
Feb 21 15:17:57 imacdignnielkan com.apple.xpc.launchd[1] (com.apple.ImageCaptureExtension2.85792[1589]): Service exited due to signal: Terminated: 15
Feb 21 15:17:57 imacdignnielkan com.apple.xpc.launchd[1] (com.apple.FolderActionsDispatcher[345]): Service exited due to signal: Killed: 9
Feb 21 15:17:57 imacdignnielkan wirelessproxd[76]: identityservicesd's WPDContinuity connection died
Feb 21 15:17:57 imacdignnielkan com.apple.xpc.launchd[1] (com.apple.ViewBridgeAuxiliary[397]): Service exited due to signal: Killed: 9
Feb 21 15:17:57 imacdignnielkan com.apple.xpc.launchd[1] (com.apple.noticeboard.agent[1324]): Service exited due to signal: Killed: 9
Feb 21 15:17:57 imacdignnielkan loginwindow[95]: ERROR | -[SessionLogoutManager quitAllPrivateProcesses] | Private Process failed to quit: identityservicesd
Feb 21 15:17:58 imacdignnielkan sessionlogoutd[2360]: sessionlogoutd Launched
Feb 21 15:17:58 imacdignnielkan sessionlogoutd[2360]: DEAD_PROCESS: 95 console
Feb 21 15:17:58 imacdignnielkan sharingd[292]: 15:17:58.704 : SCDynamicStoreCopyConsoleUser returned NULL
Feb 21 15:17:58 imacdignnielkan sharingd[292]: 15:17:58.705 : SDActivityAdvertiser::consoleUserChanged: Stopping for user 501 on logout
Feb 21 15:17:58 imacdignnielkan sharingd[292]: 15:17:58.705 : SCDynamicStoreCopyConsoleUser returned NULL
Feb 21 15:17:58 --- last message repeated 2 times ---
Feb 21 15:17:58 imacdignnielkan kernel[0]: IO80211AWDLPeerManager::setAwdlOperatingMode Setting the AWDL operation mode from AUTO to SUSPENDED
Feb 21 15:17:58 imacdignnielkan kernel[0]: IO80211AWDLPeerManager::setAwdlSuspendedMode() Suspending AWDL, enterQuietMode(true)
Feb 21 15:17:58 imacdignnielkan mdworker[2308]: (ImportBailout.Error:1325) Asked to exit for Diskarb
Feb 21 15:17:58 imacdignnielkan mdworker[2344]: (ImportBailout.Error:1325) Asked to exit for Diskarb
Feb 21 15:17:59 imacdignnielkan sharingd[292]: [Warning] Failed IDSDaemonRequestConnection, no reply
Feb 21 15:17:59 imacdignnielkan shutdown[2363]: halt by giovannielkan:
Feb 21 15:17:59 imacdignnielkan kernel[0]: Kext loading now disabled.
Feb 21 15:17:59 imacdignnielkan kernel[0]: Kext unloading now disabled.
Feb 21 15:17:59 imacdignnielkan kernel[0]: Kext autounloading now disabled.
Feb 21 15:17:59 imacdignnielkan kernel[0]: Kernel requests now disabled.
Feb 21 15:17:59 imacdignnielkan kernel[0]: Process launchd [1] disabling system-wide I/O Throttling
Feb 21 15:17:59 imacdignnielkan kernel[0]: Process launchd [1] disabling system-wide CPU Throttling
Feb 21 15:17:59 imacdignnielkan shutdown[2363]: SHUTDOWN_TIME: 1456064279 881230
Feb 21 15:18:36 localhost bootlog[0]: BOOT_TIME 1456064316 0
Feb 21 15:19:07 localhost syslogd[46]: Configuration Notice:
ASL Module "com.apple.AccountPolicyHelper" claims selected messages.
Those messages may not appear in standard system log files or in the ASL database.
/code]
Visitano il forum: Nessuno e 28 ospiti
