Credevo, speravo di aver risolto i problemi... ma oggi (un paio di giorni dopo le operazioni, di cui nel post precedente),
riavvio e mi ritrovo le icone dei files (su Scrivania e nelle Cartelle varie) di nuovo scombinate, cioè - come talvolta capitava - persa la disposizione che avevo impostato!
Allora, ti ricopio il log da Console (da pochi istanti PRIMA del reboot sino a pochi istanti DOPO il reboot):
Apr 22 01:12:48 iMac-di-***************[0x0-0xcd0cd].com.google.Chrome[3620]: [3644:263:0422/011248:ERROR:gles2_cmd_decoder.cc(11344)] [GroupMarkerNotSet(crbug.com/242999)!:D072060101000000]GL ERROR :GL_INVALID_OPERATION : glConsumeTextureCHROMIUM: invalid mailbox name
Apr 22 01:12:48 iMac-di-***************[0x0-0xcd0cd].com.google.Chrome[3620]: [3644:263:0422/011248:ERROR:gles2_cmd_decoder.cc(6433)] [GroupMarkerNotSet(crbug.com/242999)!:D072060101000000]RENDER WARNING: texture bound to texture unit 0 is not renderable. It maybe non-power-of-2 and have incompatible texture filtering.
Apr 22 01:13:04 iMac-di-***************[0x0-0xcd0cd].com.google.Chrome[3620]: [3620:29699:0422/011304:ERROR:connection_factory_impl.cc(366)] Failed to connect to MCS endpoint with error -106
Apr 22 01:13:36 iMac-di-***************login[3660]: USER_PROCESS: 3660 ttys000
Apr 22 01:13:44 iMac-di-***************login[3660]: DEAD_PROCESS: 3660 ttys000
Apr 22 01:13:44 iMac-di-***************auditd[3667]: Auditing enabled
Apr 22 01:13:44 iMac-di-***************auditd[3667]: Got low space trigger
Apr 22 01:13:44 iMac-di-***************auditd[3667]: auditd_read_dirs(): all audit log directories over soft limit
Apr 22 01:13:44 iMac-di-***************auditd[3667]: renamed /var/audit/20150420202109.not_terminated to /var/audit/20150420202109.20150421231344
Apr 22 01:13:44 iMac-di-***************auditd[3667]: New audit file is /var/audit/20150421231344.not_terminated
Apr 22 01:13:44 iMac-di-***************_atsserver[3672]: audit warning: soft /var/audit
Apr 22 01:13:44 iMac-di-***************_atsserver[3673]: audit warning: allsoft
Apr 22 01:13:44 iMac-di-***************_atsserver[3671]: audit warning: closefile /var/audit/20150420202109.20150421231344
Apr 22 01:13:50 iMac-di-***************[0x0-0xd10d1].com.google.Chrome[3675]: objc[3675]: Class GTMLogMaximumLevelFilter is implemented in both /Applications/Google Chrome.app/Contents/MacOS/../Versions/42.0.2311.90/Google Chrome Framework.framework/Google Chrome Framework and /Applications/Google Chrome.app/Contents/Versions/42.0.2311.90/Google Chrome Framework.framework/Frameworks/KeystoneRegistration.framework/KeystoneRegistration. One of the two will be used. Which one is undefined.
Apr 22 01:13:50 iMac-di-***************[0x0-0xd10d1].com.google.Chrome[3675]: objc[3675]: Class GTMLogMininumLevelFilter is implemented in both /Applications/Google Chrome.app/Contents/MacOS/../Versions/42.0.2311.90/Google Chrome Framework.framework/Google Chrome Framework and /Applications/Google Chrome.app/Contents/Versions/42.0.2311.90/Google Chrome Framework.framework/Frameworks/KeystoneRegistration.framework/KeystoneRegistration. One of the two will be used. Which one is undefined.
Apr 22 01:13:50 iMac-di-***************[0x0-0xd10d1].com.google.Chrome[3675]: objc[3675]: Class GTMLogAllowedLevelFilter is implemented in both /Applications/Google Chrome.app/Contents/MacOS/../Versions/42.0.2311.90/Google Chrome Framework.framework/Google Chrome Framework and /Applications/Google Chrome.app/Contents/Versions/42.0.2311.90/Google Chrome Framework.framework/Frameworks/KeystoneRegistration.framework/KeystoneRegistration. One of the two will be used. Which one is undefined.
Apr 22 01:13:50 iMac-di-***************[0x0-0xd10d1].com.google.Chrome[3675]: objc[3675]: Class GTMLogNoFilter is implemented in both /Applications/Google Chrome.app/Contents/MacOS/../Versions/42.0.2311.90/Google Chrome Framework.framework/Google Chrome Framework and /Applications/Google Chrome.app/Contents/Versions/42.0.2311.90/Google Chrome Framework.framework/Frameworks/KeystoneRegistration.framework/KeystoneRegistration. One of the two will be used. Which one is undefined.
Apr 22 01:13:50 iMac-di-***************[0x0-0xd10d1].com.google.Chrome[3675]: objc[3675]: Class GTMLogLevelFilter is implemented in both /Applications/Google Chrome.app/Contents/MacOS/../Versions/42.0.2311.90/Google Chrome Framework.framework/Google Chrome Framework and /Applications/Google Chrome.app/Contents/Versions/42.0.2311.90/Google Chrome Framework.framework/Frameworks/KeystoneRegistration.framework/KeystoneRegistration. One of the two will be used. Which one is undefined.
Apr 22 01:13:50 iMac-di-***************[0x0-0xd10d1].com.google.Chrome[3675]: objc[3675]: Class GTMLogStandardFormatter is implemented in both /Applications/Google Chrome.app/Contents/MacOS/../Versions/42.0.2311.90/Google Chrome Framework.framework/Google Chrome Framework and /Applications/Google Chrome.app/Contents/Versions/42.0.2311.90/Google Chrome Framework.framework/Frameworks/KeystoneRegistration.framework/KeystoneRegistration. One of the two will be used. Which one is undefined.
Apr 22 01:13:50 iMac-di-***************[0x0-0xd10d1].com.google.Chrome[3675]: objc[3675]: Class GTMLogBasicFormatter is implemented in both /Applications/Google Chrome.app/Contents/MacOS/../Versions/42.0.2311.90/Google Chrome Framework.framework/Google Chrome Framework and /Applications/Google Chrome.app/Contents/Versions/42.0.2311.90/Google Chrome Framework.framework/Frameworks/KeystoneRegistration.framework/KeystoneRegistration. One of the two will be used. Which one is undefined.
Apr 22 01:13:50 iMac-di-***************[0x0-0xd10d1].com.google.Chrome[3675]: objc[3675]: Class GTMLogger is implemented in both /Applications/Google Chrome.app/Contents/MacOS/../Versions/42.0.2311.90/Google Chrome Framework.framework/Google Chrome Framework and /Applications/Google Chrome.app/Contents/Versions/42.0.2311.90/Google Chrome Framework.framework/Frameworks/KeystoneRegistration.framework/KeystoneRegistration. One of the two will be used. Which one is undefined.
Apr 22 01:13:50 iMac-di-***************[0x0-0xd10d1].com.google.Chrome[3675]: [3675:519:0422/011350:ERROR:url_pattern_set.cc(240)] Invalid url pattern: chrome://print/*
Apr 22 01:13:51 iMac-di-***************/Applications/Google Chrome.app/Contents/MacOS/Google Chrome[3675]: MDS Error: unable to create user DBs in /var/folders/38/38ZZl+avE3C-GBGVvewY9k+++TI/-Caches-//mds
Apr 22 01:13:51: --- last message repeated 5 times ---
Apr 22 01:13:51 iMac-di-***************[0x0-0xd10d1].com.google.Chrome[3675]: [3675:29699:0422/011351:ERROR:connection_factory_impl.cc(366)] Failed to connect to MCS endpoint with error -106
Apr 22 01:13:51 iMac-di-***************[0x0-0xd10d1].com.google.Chrome[3675]: [3675:29699:0422/011351:ERROR:checkin_request.cc(185)] Failed to get checkin response. Fetcher failed. Retrying.
Apr 22 01:13:52 iMac-di-***************[0x0-0xd10d1].com.google.Chrome[3675]: [3681:263:0422/011352:ERROR:vt_video_decode_accelerator.cc(211)] Failed to initialize VideoToobox framework. Hardware accelerated video decoding will be disabled.
Apr 22 01:14:10 iMac-di-***************[0x0-0xd10d1].com.google.Chrome[3675]: [3675:24323:0422/011410:ERROR:rlz.cc(45)] Not implemented reached in bool GoogleUpdateSettings::GetLanguage(base::string16 *)
Apr 22 01:14:12 iMac-di-***************[0x0-0xd10d1].com.google.Chrome[3675]: [3675:29699:0422/011412:ERROR:checkin_request.cc(185)] Failed to get checkin response. Fetcher failed. Retrying.
Apr 22 01:14:15 iMac-di-***************[0x0-0xd10d1].com.google.Chrome[3675]: [3675:29699:0422/011415:ERROR:connection_factory_impl.cc(366)] Failed to connect to MCS endpoint with error -106
Apr 22 01:14:55 iMac-di-***************[0x0-0xd10d1].com.google.Chrome[3675]: [3700:263:0422/011455:ERROR:vt_video_decode_accelerator.cc(211)] Failed to initialize VideoToobox framework. Hardware accelerated video decoding will be disabled.
Apr 22 01:15:03 iMac-di-***************[0x0-0xd10d1].com.google.Chrome[3675]: [3675:29699:0422/011503:ERROR:checkin_request.cc(185)] Failed to get checkin response. Fetcher failed. Retrying.
Apr 22 01:15:12 iMac-di-***************[0x0-0xd10d1].com.google.Chrome[3675]: [3675:29699:0422/011512:ERROR:connection_factory_impl.cc(366)] Failed to connect to MCS endpoint with error -106
Apr 22 01:15:35 iMac-di-***************[0x0-0xd10d1].com.google.Chrome[3675]: [3705:263:0422/011535:ERROR:vt_video_decode_accelerator.cc(211)] Failed to initialize VideoToobox framework. Hardware accelerated video decoding will be disabled.
Apr 22 01:16:53 iMac-di-***************[0x0-0xd10d1].com.google.Chrome[3675]: [3675:29699:0422/011653:ERROR:checkin_request.cc(185)] Failed to get checkin response. Fetcher failed. Retrying.
Apr 22 01:17:04 iMac-di-***************[0x0-0xd10d1].com.google.Chrome[3675]: [3675:29699:0422/011704:ERROR:connection_factory_impl.cc(366)] Failed to connect to MCS endpoint with error -106
Apr 22 01:20:44 iMac-di-***************[0x0-0xd10d1].com.google.Chrome[3675]: [3675:29699:0422/012044:ERROR:checkin_request.cc(185)] Failed to get checkin response. Fetcher failed. Retrying.
Apr 22 01:20:54 iMac-di-***************[0x0-0xd10d1].com.google.Chrome[3675]: [3675:29699:0422/012054:ERROR:connection_factory_impl.cc(366)] Failed to connect to MCS endpoint with error -106
Apr 22 01:25:14 iMac-di-***************com.apple.launchd.peruser.501[98] ([0x0-0xd10d1].com.google.Chrome[3675]): Exited: Killed
Apr 22 01:25:57 iMac-di-***************com.apple.launchd.peruser.501[98] ([0x0-0x1e01e].com.apple.Stickies[230]): Exited: Killed
Apr 22 01:25:57 iMac-di-***************com.apple.launchd.peruser.501[98] (com.apple.AirPortBaseStationAgent[125]): Exited: Killed
Apr 22 01:25:57 iMac-di-***************[0x0-0x9009].com.stuffit.MagicMenu[129]: 2015-04-22 01:25:57.664 MagicMenuHotKeyDaemon[138:903] Quit
Apr 22 01:25:57 iMac-di-***************MagicMenuHotKeyDaemon[138]: Quit
Apr 22 01:25:58 iMac-di-***************loginwindow[41]: DEAD_PROCESS: 41 console
Apr 22 01:25:58 iMac-di-***************auditd[3717]: Auditing enabled
Apr 22 01:25:58 iMac-di-***************auditd[3717]: Got low space trigger
Apr 22 01:25:58 iMac-di-***************auditd[3717]: auditd_read_dirs(): all audit log directories over soft limit
Apr 22 01:25:58 iMac-di-***************auditd[3717]: renamed /var/audit/20150421231344.not_terminated to /var/audit/20150421231344.20150421232558
Apr 22 01:25:58 iMac-di-***************auditd[3717]: New audit file is /var/audit/20150421232558.not_terminated
Apr 22 01:25:58 iMac-di-*****************************[3721]: audit warning: soft /var/audit
Apr 22 01:25:58 iMac-di-*****************************[3722]: audit warning: allsoft
Apr 22 01:25:58 iMac-di-*****************************[3723]: audit warning: closefile /var/audit/20150421231344.20150421232558
Apr 22 01:25:58 iMac-di-***************shutdown[3725]: reboot by **************:
Apr 22 01:25:58 iMac-di-***************shutdown[3725]: SHUTDOWN_TIME: 1429658758 412165
Apr 22 01:25:58 iMac-di-***************DirectoryService[11]: BUG in libdispatch: 10K549 - 1960 - 0x10004004
Apr 22 01:25:58 iMac-di-***************WindowServer[78]: hidd died. Reestablishing connection.
Apr 22 01:25:58 iMac-di-***************WindowServer[78]: Unable to create event queue via hidd: (0x10000003)
Apr 22 01:25:58 iMac-di-***************mDNSResponder[18]: mDNSResponder mDNSResponder-258.21 (May 26 2011 14:40:13) stopping
Apr 22 01:26:40 localhost com.apple.launchd[1]: *** launchd[1] has started up. ***
Apr 22 01:26:44 localhost com.apple.launchd[1] (com.apple.usbmuxd): Unknown key: POSIXSpawnType
Apr 22 01:26:46 localhost blued[17]: Apple Bluetooth daemon started
Apr 22 01:26:46 localhost mDNSResponder[19]: mDNSResponder mDNSResponder-258.21 (May 26 2011 14:40:13) starting
Apr 22 01:26:52 localhost configd[14]: network configuration changed.
Apr 22 01:26:52 iMac-di-***************configd[14]: setting hostname to "iMac-di-**************.local"
Apr 22 01:26:56 iMac-di-***************auditd[61]: Auditing enabled
Apr 22 01:26:56 iMac-di-***************auditd[61]: Got low space trigger
Apr 22 01:26:56 iMac-di-***************auditd[61]: auditd_read_dirs(): all audit log directories over soft limit
Apr 22 01:26:57 iMac-di-***************_usbmuxd[65]: audit warning: soft /var/audit
Apr 22 01:26:57 iMac-di-***************_usbmuxd[64]: audit warning: allsoft
Apr 22 01:26:57 iMac-di-***************auditd[61]: renamed /var/audit/20150421232642.not_terminated to /var/audit/20150421232642.20150421232656
Apr 22 01:26:57 iMac-di-***************auditd[61]: New audit file is /var/audit/20150421232656.not_terminated
Apr 22 01:26:57 iMac-di-***************_usbmuxd[67]: audit warning: closefile /var/audit/20150421232642.20150421232656
Apr 22 01:27:00 iMac-di-***************/System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow[38]: Login Window Application Started
Apr 22 01:27:01 iMac-di-***************com.apple.usbmuxd[32]: usbmuxd-327.4 on Feb 12 2014 at 14:54:33, running 64 bit
Apr 22 01:27:01 iMac-di-***************bootlog[50]: BOOT_TIME: 1429658800 0
Apr 22 01:27:02 iMac-di-***************configd[14]: bootp_session_transmit: bpf_write(en2) failed: Operation not permitted (1)
Apr 22 01:27:02 iMac-di-***************configd[14]: DHCP en2: INIT transmit failed
Apr 22 01:27:05 iMac-di-***************loginwindow[38]: Login Window Started Security Agent
Apr 22 01:27:05 iMac-di-***************loginwindow[38]: Login Window - Returned from Security Agent
Apr 22 01:27:05 iMac-di-***************loginwindow[38]: USER_PROCESS: 38 console
Apr 22 01:27:05 iMac-di-***************loginwindow[38]: MDS Error: unable to create user DBs in /var/folders/38/38ZZl+avE3C-GBGVvewY9k+++TI/-Caches-//mds
Apr 22 01:27:05: --- last message repeated 2 times ---
Apr 22 01:27:05 iMac-di-***************com.apple.launchd.peruser.501[98] (com.apple.ReportCrash): Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
Apr 22 01:27:11 iMac-di-***************com.apple.launchd.peruser.501[98] (com.apple.Kerberos.renew.plist[123]): Exited with exit code: 1
Apr 22 01:27:11 iMac-di-***************com.apple.launchd.peruser.501[98] (com.apple.mrt.uiagent[122]): Exited with exit code: 255
Apr 22 01:27:12 iMac-di-***************MagicMenuHotKeyDaemon[136]: Started
Apr 22 01:27:12 iMac-di-***************[0x0-0xa00a].com.stuffit.MagicMenu[130]: 2015-04-22 01:27:12.786 MagicMenuHotKeyDaemon[136:903] Started
Apr 22 01:27:13 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x1ecfd0 of class OC_PythonString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x3c4f250 of class OC_PythonString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x4b9eb0 of class OC_PythonString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x4db3e0 of class NSCFString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x4f6240 of class NSPathStore2 autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x4f5860 of class NSBundle autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x4f0e90 of class NSCFArray autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x4df230 of class NSPathStore2 autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x4f6950 of class NSCFString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x4f69f0 of class NSURL autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x4f6860 of class OC_PythonString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x4f6b00 of class NSCFString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x4f6ba0 of class NSURL autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x4f6b50 of class OC_PythonString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x4f6c50 of class NSCFString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x4f6d00 of class NSURL autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x4f6cd0 of class OC_PythonString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x4f7030 of class NSCFString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x4f6ea0 of class NSURL autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x4f6bf0 of class OC_PythonString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x4f7080 of class NSCFString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x4f6fb0 of class NSURL autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x4f70d0 of class OC_PythonString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x4f73b0 of class NSCFString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x4f7220 of class NSURL autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x4f7020 of class OC_PythonString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x3c624c0 of class NSCFString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x3c57d70 of class NSURL autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x3c675a0 of class OC_PythonString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x3c6aff0 of class NSCFString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x3c299c0 of class NSURL autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x3c6b040 of class OC_PythonString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x141102e0 of class NSCFString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x14110040 of class NSURL autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x141101f0 of class OC_PythonString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x141104b0 of class NSCFString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x14110370 of class NSURL autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x141102d0 of class OC_PythonString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x141104a0 of class OC_PythonString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x141111c0 of class NSCFString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x14111230 of class NSPathStore2 autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x14110820 of class NSBundle autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x141110b0 of class NSCFArray autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x14111310 of class NSPathStore2 autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x141114f0 of class NSCFString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x14111140 of class NSURL autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x141111a0 of class OC_PythonString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x3c2bbf0 of class NSCFString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x3c66d90 of class NSURL autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x3c3e050 of class OC_PythonString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x3c6ad40 of class NSCFString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x3c68600 of class NSURL autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x1f8b90 of class OC_PythonString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x3c6b2e0 of class NSCFString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x3c6b120 of class NSURL autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x3c6a760 of class OC_PythonString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x3c6b350 of class NSCFString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x3c6b250 of class NSURL autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x3c6b3d0 of class OC_PythonString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x3c6b6f0 of class NSCFString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x3c6b530 of class NSURL autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x3c6b2c0 of class OC_PythonString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x3c6bce0 of class NSCFString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x3c6bba0 of class NSURL autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x3c6b4c0 of class OC_PythonString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x3c6bd20 of class NSCFString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x3c6be40 of class NSURL autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x3c6be20 of class OC_PythonString autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x4cfc60 of class __NSArray0 autoreleased with no pool in place - just leaking
Apr 22 01:27:14 iMac-di-***************Dropbox[135]: *** __NSAutoreleaseNoPool(): Object 0x3c6bf90 of class __NSFastEnumerationEnumerator autoreleased with no pool in place - just leaking
Apr 22 01:27:15 iMac-di-***************Dropbox[135]: PyObjCPointer created: at 0x1450bd24 of type ^{OpaqueJSContext=}
Apr 22 01:27:33 iMac-di-***************_mdnsresponder[147]: /usr/libexec/ntpd-wrapper: scutil key State:/Network/Global/DNS not present after 30 seconds
Apr 22 01:27:33 iMac-di-***************_mdnsresponder[150]: sntp options: a=2 v=1 e=0.100 E=5.000 P=2147483647.000
Apr 22 01:27:33 iMac-di-***************_mdnsresponder[150]: d=15 c=5 x=0 op=1 l=/var/run/sntp.pid f= time.euro.apple.com
Apr 22 01:27:33 iMac-di-***************_mdnsresponder[150]: sntp: getaddrinfo(hostname, ntp) failed with nodename nor servname provided, or not known
Apr 22 01:28:58 iMac-di-***************XProtectUpdater[30]: NSURLConnection error: Error Domain=NSURLErrorDomain Code=-1009 UserInfo=0x100176da0 "This computer’s Internet connection appears to be offline." Underlying Error=(Error Domain=kCFErrorDomainCFNetwork Code=-1009 UserInfo=0x10011b010 "This computer’s Internet connection appears to be offline.")
Apr 22 01:28:58 iMac-di-***************com.apple.launchd[1] (com.apple.xprotectupdater[30]): Exited with exit code: 255
Apr 22 01:31:13 iMac-di-***************login[172]: USER_PROCESS: 172 ttys000
Apr 22 01:31:21 iMac-di-***************login[172]: DEAD_PROCESS: 172 ttys000
Apr 22 01:31:22 iMac-di-***************auditd[179]: Auditing enabled
Apr 22 01:31:22 iMac-di-***************auditd[179]: Got low space trigger
Apr 22 01:31:22 iMac-di-***************auditd[179]: auditd_read_dirs(): all audit log directories over soft limit
Apr 22 01:31:22 iMac-di-***************auditd[179]: renamed /var/audit/20150421232656.not_terminated to /var/audit/20150421232656.20150421233122
Apr 22 01:31:22 iMac-di-***************auditd[179]: New audit file is /var/audit/20150421233122.not_terminated
Apr 22 01:31:22 iMac-di-***************_atsserver[183]: audit warning: allsoft
Apr 22 01:31:22 iMac-di-***************_atsserver[184]: audit warning: soft /var/audit
Apr 22 01:31:22 iMac-di-***************_atsserver[185]: audit warning: closefile /var/audit/20150421232656.20150421233122
Apr 22 01:37:11 iMac-di-***************/System/Library/CoreServices/CCacheServer.app/Contents/MacOS/CCacheServer[129]: No valid tickets, timing out
Poi, in concomitanza con a rottura di palle di cui sopra, c'è Chrome che rompe le palle a sua volta, cioè mi dà in "Monitoraggio attività"- anche se killo le (poche) finestre attive - mi dà sempre un processo che si riattiva di continuo, mi pare facia riferimento a un task del Kernel (guardando la gerarchia Processi)...
Da Console mi pare sia uno di questi
22/04/15 01.50.28 kernel Google Chrome He (map: 0x8e68c2c) triggered DYLD shared region unnest for map: 0x8e68c2c, region 0x7fff89000000->0x7fff89200000. While not abnormal for debuggers, this increases system memory footprint until the target exits.
22/04/15 02.19.19 [0x0-0x25025].com.google.Chrome[233] objc[233]: Class GTMLogBasicFormatter is implemented in both /Applications/Google Chrome.app/Contents/MacOS/../Versions/42.0.2311.90/Google Chrome Framework.framework/Google Chrome Framework and /Applications/Google Chrome.app/Contents/Versions/42.0.2311.90/Google Chrome Framework.framework/Frameworks/KeystoneRegistration.framework/KeystoneRegistration. One of the two will be used. Which one is undefined.
22/04/15 02.19.19 [0x0-0x25025].com.google.Chrome[233] objc[233]: Class GTMLogger is implemented in both /Applications/Google Chrome.app/Contents/MacOS/../Versions/42.0.2311.90/Google Chrome Framework.framework/Google Chrome Framework and /Applications/Google Chrome.app/Contents/Versions/42.0.2311.90/Google Chrome Framework.framework/Frameworks/KeystoneRegistration.framework/KeystoneRegistration. One of the two will be used. Which one is undefined.
22/04/15 02.19.21 [0x0-0x25025].com.google.Chrome[233] [239:263:0422/021921:ERROR:vt_video_decode_accelerator.cc(211)] Failed to initialize VideoToobox framework. Hardware accelerated video decoding will be disabled.
22/04/15 02.19.23 [0x0-0x25025].com.google.Chrome[233] [233:519:0422/021923:ERROR:url_pattern_set.cc(240)] Invalid url pattern: chrome://print/*
22/04/15 02.19.44 [0x0-0x25025].com.google.Chrome[233] [233:29699:0422/021944:ERROR:connection_factory_impl.cc(366)] Failed to connect to MCS endpoint with error -106
22/04/15 02.19.45 [0x0-0x25025].com.google.Chrome[233] [233:52739:0422/021945:ERROR:rlz.cc(45)] Not implemented reached in bool GoogleUpdateSettings::GetLanguage(base::string16 *)
22/04/15 02.20.10 [0x0-0x25025].com.google.Chrome[233] [233:29699:0422/022010:ERROR:connection_factory_impl.cc(366)] Failed to connect to MCS endpoint with error -106
22/04/15 02.21.06 [0x0-0x25025].com.google.Chrome[233] [233:29699:0422/022106:ERROR:connection_factory_impl.cc(366)] Failed to connect to MCS endpoint with error -106
22/04/15 02.22.30 [0x0-0x25025].com.google.Chrome[233] [265:263:0422/022230:ERROR:vt_video_decode_accelerator.cc(211)] Failed to initialize VideoToobox framework. Hardware accelerated video decoding will be disabled.
22/04/15 02.22.54 [0x0-0x25025].com.google.Chrome[233] [233:29699:0422/022254:ERROR:connection_factory_impl.cc(366)] Failed to connect to MCS endpoint with error -106
22/04/15 02.22.59 [0x0-0x25025].com.google.Chrome[233] [267:263:0422/022259:ERROR:vt_video_decode_accelerator.cc(211)] Failed to initialize VideoToobox framework. Hardware accelerated video decoding will be disabled.
Grazie.
