Feb 6 01:43:00 localhost kernel[0]: Previous shutdown cause: 5
Feb 6 01:43:00 localhost kernel[0]: DSMOS has arrived
Feb 6 01:43:00 localhost distnoted[72]: # distnote server daemon absolute time: 28.355959060 civil time: Fri Feb 6 01:43:00 2015 pid: 72 uid: 241 root: yes
Feb 6 01:43:00 localhost hidd[68]: ____IOHIDSessionScheduleAsync_block_invoke: thread_id=0x10a60a000
Feb 6 01:43:00 localhost hidd[68]: HID Session async scheduling initiated.
Feb 6 01:43:00 localhost hidd[68]: HID Session async root queue running at priority 63 and schedule 2.
Feb 6 01:43:00 localhost com.apple.usbmuxd[51]: usbmuxd-344.5 on Dec 5 2014 at 17:02:22, running 64 bit
Feb 6 01:43:00 localhost opendirectoryd[45]: BUG in libdispatch: 14C109 - 2004 - 0x5
Feb 6 01:43:00 localhost iconservicesd[36]: iconservicesd launched.
Feb 6 01:43:00 localhost iconservicesd[36]: Cache path: /Library/Caches/com.apple.iconservices.store
Feb 6 01:43:00 localhost hidd[68]: HID Session async scheduling complete.
Feb 6 01:43:00 localhost hidd[68]: Successfully opened the IOHIDSession
Feb 6 01:43:00 localhost configd[25]: preference: no sharing preferences
Feb 6 01:43:02 localhost configd[25]: [bootp_transmit.c:213] bootp_transmit(): bpf_write(en0) failed: Network is down (50)
Feb 6 01:43:02 localhost configd[25]: DHCP en0: INIT transmit failed
Feb 6 01:43:02 localhost com.apple.SecurityServer[52]: Entering service
Feb 6 01:43:02 localhost thermald[22]: Waiting for OSTT support notification
Feb 6 01:43:02 localhost com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.system): Service "com.apple.ManagedClient.startup" tried to hijack endpoint "com.apple.ManagedClient.agent" from owner: com.apple.ManagedClient
Feb 6 01:43:02 localhost loginwindow[64]: Login Window Application Started
Feb 6 01:43:02 localhost digest-service[99]: label: default
Feb 6 01:43:02 localhost digest-service[99]: dbname: od:/Local/Default
Feb 6 01:43:02 localhost digest-service[99]: mkey_file: /var/db/krb5kdc/m-key
Feb 6 01:43:02 localhost digest-service[99]: acl_file: /var/db/krb5kdc/kadmind.acl
Feb 6 01:43:02 localhost WindowServer[114]: Server is starting up
Feb 6 01:43:03 localhost blued[57]: Release the WiFi lock
Feb 6 01:43:03 localhost blued[57]: HID Page timeout 2710
Feb 6 01:43:03 localhost locationd[54]: Logging binary sensor data to /var/folders/zz/zyxvpxvq6csfxvn_n00000sm00006d/C/locationdSensors.bin
Feb 6 01:43:03 localhost locationd[54]: Incorrect NSStringEncoding value 0x8000100 detected. Assuming NSASCIIStringEncoding. Will stop this compatiblity mapping behavior in the near future.
Feb 6 01:43:03 localhost locationd[54]: NBB-Could not get UDID for stable refill timing, falling back on random
Feb 6 01:43:03 localhost locationd[54]: Location icon should now be in state 'Inactive'
Feb 6 01:43:03 localhost secinitd[116]: UID[0]: cache loaded: /System/Library/Caches/com.apple.app-sandbox-cache.plist
Feb 6 01:43:03 localhost secinitd[116]: ctkd[115]: unable to get root path for bundle of main executable: /System/Library/Frameworks/CryptoTokenKit.framework/ctkd
Feb 6 01:43:03 localhost digest-service[99]: digest-request: uid=0
Feb 6 01:43:03 localhost digest-service[99]: digest-request: netr probe 0
Feb 6 01:43:03 localhost digest-service[99]: digest-request: init request
Feb 6 01:43:03 localhost digest-service[99]: digest-request: init return domain: BUILTIN server: LOCALHOST indomain was: <NULL>
Feb 6 01:43:03 localhost com.apple.xpc.launchd[1] (com.apple.appkit.xpc.sandboxedServiceRunner): The JoinExistingSession key is only available to Application services.
Feb 6 01:43:04 localhost mdmclient[40]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Feb 6 01:43:04 localhost kernel[0]: AirPort: Link Down on en1. Reason 8 (Disassociated because station leaving).
Feb 6 01:43:04 localhost kernel[0]: en1: channel changed to 1
Feb 6 01:43:04 localhost kernel[0]: en1::IO80211Interface::postMessage bssid changed
Feb 6 01:43:04 localhost kernel[0]: bpfAttach len 94 dlt 163
Feb 6 01:43:04 localhost kernel[0]: bpfAttach len 30 dlt 105
Feb 6 01:43:04 localhost kernel[0]: bpfAttach len 52 dlt 127
Feb 6 01:43:04 localhost kernel[0]: bpfAttach len 38 dlt 192
Feb 6 01:43:04 localhost discoveryd[48]: Basic Sockets GetProcessNameFromSocket() failed errno[57] err[-1]
Feb 6 01:43:04 localhost discoveryd[48]: Basic Sockets Unknown(-1), errno 0 UDS FD=3
Feb 6 01:43:04 localhost discoveryd[48]: Basic Sockets UDS FD=3 ERROR: failed to get effective user ID, errno 0
Feb 6 01:43:04 localhost discoveryd[48]: Basic SleepProxy BSP Server Disabled. Metric = 3373
Feb 6 01:43:04 localhost discoveryd[48]: AwdlD2d AwdlD2dInitialize: Initialized
Feb 6 01:43:04 localhost discoveryd[48]: D2D_IPC: Loaded
Feb 6 01:43:04 localhost discoveryd[48]: Basic WABServer NetResolverEvent no resolvers, resetting domains
Feb 6 01:43:04 localhost discoveryd[48]: Basic DNSResolver etc/hosts file changed: Event 0x7fa67ad1cd20 Flushed /etc/hosts cache
Feb 6 01:43:04 localhost discoveryd[48]: Basic RemoteControl com.apple.discoveryd Starting XPC Server
Feb 6 01:43:04 localhost discoveryd[48]: Basic SleepProxy Could not get the primary interface
Feb 6 01:43:04 localhost discoveryd[48]: Basic RemoteControl com.apple.discoveryd.dnsproxy Starting XPC Server
Feb 6 01:43:04 localhost discoveryd[48]: Basic SleepProxy Sleep Proxy Server is not enabled
Feb 6 01:43:04 localhost discoveryd_helper[123]: Basic RemoteControl com.apple.discoveryd_helper Starting XPC Server
Feb 6 01:43:04 localhost discoveryd_helper[123]: Detailed RemoteControl com.apple.discoveryd_helper XPC connection 0x7fa9e95031e0: start (pid=48, <unknown> not root)
Feb 6 01:43:04 localhost networkd[124]: networkd-411.1 pid 124
Feb 6 01:43:05 localhost mdmclient[40]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Feb 6 01:43:05 localhost mds[32]: (FMW.Normal:1402) FMW 0 0
Feb 6 01:43:06 localhost configd[25]: dhcp_arp_router: en1 SSID unavailable
Feb 6 01:43:06 localhost configd[25]: network changed.
Feb 6 01:43:06 MacBook-Pro-di-Jacopo-Tabani.local configd[25]: setting hostname to "MacBook-Pro-di-Jacopo-Tabani.local"
Feb 6 01:43:06 MacBook-Pro-di-Jacopo-Tabani.local mdmclient[40]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Feb 6 01:43:06 MacBook-Pro-di-Jacopo-Tabani kernel[0]: in func createVirtualInterface ifRole = 1
Feb 6 01:43:06 MacBook-Pro-di-Jacopo-Tabani kernel[0]: AirPort_Brcm4331_P2PInterface::init name <p2p0> role 1
Feb 6 01:43:06 MacBook-Pro-di-Jacopo-Tabani kernel[0]: AirPort_Brcm4331_P2PInterface::init <p2p> role 1
Feb 6 01:43:06 MacBook-Pro-di-Jacopo-Tabani kernel[0]: Created virtif 0xffffff8011171c00 p2p0
Feb 6 01:43:06 MacBook-Pro-di-Jacopo-Tabani.local airportd[29]: airportdProcessDLILEvent: en1 attached (up)
Feb 6 01:43:07 MacBook-Pro-di-Jacopo-Tabani.local mdmclient[40]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Feb 6 01:43:08 MacBook-Pro-di-Jacopo-Tabani kernel[0]: en1: channel changed to 1
Feb 6 01:43:08 MacBook-Pro-di-Jacopo-Tabani.local systemkeychain[127]: done file: /var/run/systemkeychaincheck.done
Feb 6 01:43:08 MacBook-Pro-di-Jacopo-Tabani kernel[0]: MacAuthEvent en1 Auth result for: e8
27:8c:1a:ec MAC AUTH succeeded
Feb 6 01:43:08 MacBook-Pro-di-Jacopo-Tabani kernel[0]: wlEvent: en1 en1 Link UP virtIf = 0
Feb 6 01:43:08 MacBook-Pro-di-Jacopo-Tabani kernel[0]: AirPort: Link Up on en1
Feb 6 01:43:08 MacBook-Pro-di-Jacopo-Tabani kernel[0]: en1: BSSID changed to e8
27:8c:1a:ec
Feb 6 01:43:08 MacBook-Pro-di-Jacopo-Tabani kernel[0]: en1: channel changed to 5
Feb 6 01:43:08 MacBook-Pro-di-Jacopo-Tabani kernel[0]: en1::IO80211Interface::postMessage bssid changed
Feb 6 01:43:08 MacBook-Pro-di-Jacopo-Tabani.local mdmclient[40]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Feb 6 01:43:08 MacBook-Pro-di-Jacopo-Tabani kernel[0]: AirPort: RSN handshake complete on en1
Feb 6 01:43:09 MacBook-Pro-di-Jacopo-Tabani.local stackshot[62]: Timed out waiting for IOKit to finish matching.
Feb 6 01:43:09 MacBook-Pro-di-Jacopo-Tabani.local mdmclient[40]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Feb 6 01:43:10 MacBook-Pro-di-Jacopo-Tabani.local UserEventAgent[16]: Failed to copy info dictionary for bundle /System/Library/UserEventPlugins/alfUIplugin.plugin
Feb 6 01:43:10 MacBook-Pro-di-Jacopo-Tabani com.apple.xpc.launchd[1] (com.apple.lakitu): The JoinExistingSession key is only available to Application services.
Feb 6 01:43:10 MacBook-Pro-di-Jacopo-Tabani com.apple.xpc.launchd[1] (com.apple.accounts.dom): The _DirtyJetsamMemoryLimit key is not available on this platform.
Feb 6 01:43:10 MacBook-Pro-di-Jacopo-Tabani com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Feb 6 01:43:10 MacBook-Pro-di-Jacopo-Tabani.local UserEventAgent[16]: nsurlsessiond_events plugin: adding token 1 for client softwareupdate_download_service
Feb 6 01:43:10 MacBook-Pro-di-Jacopo-Tabani UserEventAgent[16]: assertion failed: 14C109: com.apple.telemetry + 24526 [B033615E-AC6E-3C72-A493-A728F602B10C]: 0xffffffffe0000001
Feb 6 01:43:11 MacBook-Pro-di-Jacopo-Tabani.local apsd[49]: CGSLookupServerRootPort: Failed to look up the port for "com.apple.windowserver.active" (1102)
Feb 6 01:43:11 MacBook-Pro-di-Jacopo-Tabani.local apsd[49]: Unable to bootstrap_look_up connection port 'com.apple.askpermission.aps' for user 0: Unknown service name
Feb 6 01:43:11 MacBook-Pro-di-Jacopo-Tabani.local apsd[49]: Attempt to set push wake topics without dark wake enabled: ()
Feb 6 01:43:11 MacBook-Pro-di-Jacopo-Tabani.local apsd[49]: <APSConnectionServer: 0x7fd7a0e04920> Invalid mach port - Cleaning up this named port's topics. com.apple.askpermission.aps
Feb 6 01:43:11 MacBook-Pro-di-Jacopo-Tabani.local findmydeviced[150]: findmydeviced has been launched
Feb 6 01:43:11 MacBook-Pro-di-Jacopo-Tabani.local locationd[151]: Logging binary sensor data to /var/folders/zz/zyxvpxvq6csfxvn_n00000sm00006d/C/locationdSensors.bin
Feb 6 01:43:11 MacBook-Pro-di-Jacopo-Tabani.local locationd[151]: Incorrect NSStringEncoding value 0x8000100 detected. Assuming NSASCIIStringEncoding. Will stop this compatiblity mapping behavior in the near future.
Feb 6 01:43:11 MacBook-Pro-di-Jacopo-Tabani.local locationd[151]: NBB-Could not get UDID for stable refill timing, falling back on random
Feb 6 01:43:11 MacBook-Pro-di-Jacopo-Tabani.local locationd[151]: Location icon should now be in state 'Inactive'
Feb 6 01:43:11 MacBook-Pro-di-Jacopo-Tabani.local discoveryd[48]: Basic SleepProxy Could not get the primary interface
Feb 6 01:43:14 MacBook-Pro-di-Jacopo-Tabani.local discoveryd[48]: Basic Sockets,Warn UDS FD=34 ERROR: Send failed errno=32
Feb 6 01:43:14 MacBook-Pro-di-Jacopo-Tabani.local configd[25]: network changed: v4(en1+:192.168.1.103) DNS+ Proxy+ SMB
Feb 6 01:43:15 MBPdiJapoTabani configd[25]: setting hostname to "MBPdiJapoTabani"
Feb 6 01:43:16 MBPdiJapoTabani sntp[158]: time set +0.349979 s
Feb 6 01:43:16 MBPdiJapoTabani ntpd[143]: peer time.euro.apple.com @ 17.72.148.53
Feb 6 01:43:16 MBPdiJapoTabani ntpd[143]: drift PPM:0.000 -> -18.268
Feb 6 01:43:16 MBPdiJapoTabani nsurlstoraged[161]: realpath() returned NULL for /var/root/Library/Caches/ocspd
Feb 6 01:43:16 MBPdiJapoTabani nsurlstoraged[161]: The read-connection to the DB=/var/root/Library/Caches/ocspd/Cache.db is NOT valid. Unable to determine schema version.
Feb 6 01:43:21 --- last message repeated 1 time ---
Feb 6 01:43:16 MBPdiJapoTabani nsurlstoraged[161]: ERROR: unable to determine file-system usage for FS-backed cache at /var/root/Library/Caches/ocspd/fsCachedData. Errno=13
Feb 6 01:43:16 MBPdiJapoTabani UserEventAgent[16]: Captive: [CNInfoNetworkActive:1709] en1: SSID 'TP-LINK_NUOVO' making interface primary (protected network)
Feb 6 01:43:16 MBPdiJapoTabani configd[25]: network changed: DNS- Proxy-
Feb 6 01:43:16 MBPdiJapoTabani UserEventAgent[16]: Captive: CNPluginHandler en1: Evaluating
Feb 6 01:43:16 MBPdiJapoTabani configd[25]: network changed: v4(en1!:192.168.1.103) DNS+ Proxy+ SMB
Feb 6 01:43:16 MBPdiJapoTabani UserEventAgent[16]: Captive: en1: Probing 'TP-LINK_NUOVO'
Feb 6 01:43:16 MBPdiJapoTabani networkd[124]: +[NETLedBelly stopFastFail] Clearing ledbelly failure cache
Feb 6 01:43:16 MBPdiJapoTabani UserEventAgent[16]: Captive: CNPluginHandler en1: Authenticated
Feb 6 01:43:16 MBPdiJapoTabani kernel[0]: fGPUIdleIntervalMS = 0
Feb 6 01:43:16 MBPdiJapoTabani kernel[0]: en2: promiscuous mode enable succeeded
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: Session 257 retained (2 references)
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: Session 257 released (1 references)
Feb 6 01:43:16 MBPdiJapoTabani kernel[0]: en1: BSSID changed to e8
27:8c:1a:ec
Feb 6 01:43:16 MBPdiJapoTabani kernel[0]: en1: channel changed to 5
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: init_page_flip: page flip mode is on
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: Found 13 modes for display 0x00000000 [13, 0]
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: Found 1 modes for display 0x00000000 [1, 0]
Feb 6 01:43:21 --- last message repeated 2 times ---
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: mux_initialize: kAGCGetMuxState (kMuxControl, kMuxControl_switchingMode) failed (0xe0000001)
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: mux_initialize: Mode is safe
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: WSMachineUsesNewStyleMirroring: false
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: Display 0x042731c0: GL mask 0x1; bounds (0, 0)[1280 x 800], 13 modes available
Main, Active, on-line, enabled, built-in, boot, Vendor 610, Model 9cc7, S/N 0, Unit 0, Rotation 0
UUID 0xcb5a19e16c20c98ebb2d70fc3bb550b4
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: Display 0x003f0040: GL mask 0x10; bounds (0, 0)[4096 x 2160], 2 modes available
off-line, enabled, Vendor ffffffff, Model ffffffff, S/N ffffffff, Unit 4, Rotation 0
UUID 0xffffffffffffffffffffffffffffffff
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: Display 0x003f003f: GL mask 0x8; bounds (0, 0)[0 x 0], 1 modes available
off-line, enabled, Vendor ffffffff, Model ffffffff, S/N ffffffff, Unit 3, Rotation 0
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: Display 0x003f003e: GL mask 0x4; bounds (0, 0)[0 x 0], 1 modes available
off-line, enabled, Vendor ffffffff, Model ffffffff, S/N ffffffff, Unit 2, Rotation 0
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: Display 0x003f003d: GL mask 0x2; bounds (0, 0)[0 x 0], 1 modes available
off-line, enabled, Vendor ffffffff, Model ffffffff, S/N ffffffff, Unit 1, Rotation 0
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: Set a breakpoint at CGSLogError to catch errors as they are logged.
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: WSSetWindowTransform: Singular matrix
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: Display 0x003f0040: GL mask 0x10; bounds (2304, 0)[1 x 1], 2 modes available
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: Display 0x003f003f: GL mask 0x8; bounds (2305, 0)[1 x 1], 1 modes available
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: Display 0x003f003e: GL mask 0x4; bounds (2306, 0)[1 x 1], 1 modes available
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: Display 0x003f003d: GL mask 0x2; bounds (2307, 0)[1 x 1], 1 modes available
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: CGXPerformInitialDisplayConfiguration
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: Display 0x042731c0: Unit 0; Vendor 0x610 Model 0x9cc7 S/N 0 Dimensions 11.26 x 7.05; online enabled built-in, Bounds (0,0)[1280 x 800], Rotation 0, Resolution 1
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: Display 0x003f0040: Unit 4; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (2304,0)[1 x 1], Rotation 0, Resolution 1
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: Display 0x003f003f: Unit 3; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (2305,0)[1 x 1], Rotation 0, Resolution 1
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: Display 0x003f003e: Unit 2; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (2306,0)[1 x 1], Rotation 0, Resolution 1
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: Display 0x003f003d: Unit 1; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (2307,0)[1 x 1], Rotation 0, Resolution 1
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: CGXMuxBoot: Unexpected boot switch return value (0xe00002c7)
Feb 6 01:43:16 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.FileSyncAgent.PHD.isRunning): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:16 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.mbloginhelper.user): This key does not do anything: OnDemand
Feb 6 01:43:16 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.mbpluginhost.user): This key does not do anything: OnDemand
Feb 6 01:43:16 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.secd): This key does not do anything: OnDemand
Feb 6 01:43:16 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.secd): The ServiceIPC key is no longer respected. Please remove it.
Feb 6 01:43:16 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): This key does not do anything: OnDemand
Feb 6 01:43:16 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.TrustEvaluationAgent): This key does not do anything: OnDemand
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: GLCompositor: GL renderer id 0x01024301, GL mask 0x0000001f, accelerator 0x000043db, unit 0, caps QEX|MIPMAP, vram 451 MB
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: GLCompositor: GL renderer id 0x01024301, GL mask 0x0000001f, texture max 8192, viewport max {8192, 8192}, extensions NPOT|GLSL|FLOAT
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: GLCompositor enabled for tile size [256 x 256]
Feb 6 01:43:16 MBPdiJapoTabani WindowServer[114]: CGXGLInitMipMap: mip map mode is on
Feb 6 01:43:16 MBPdiJapoTabani kernel[0]: hfs: mounted Recovery HD on device disk0s3
Feb 6 01:43:16 MBPdiJapoTabani fseventsd[20]: Logging disabled completely for device:1: /Volumes/Recovery HD
Feb 6 01:43:17 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.FileSyncAgent.PHD.isRunning): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:17 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.mbloginhelper.user): This key does not do anything: OnDemand
Feb 6 01:43:17 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.mbpluginhost.user): This key does not do anything: OnDemand
Feb 6 01:43:17 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.secd): This key does not do anything: OnDemand
Feb 6 01:43:17 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.secd): The ServiceIPC key is no longer respected. Please remove it.
Feb 6 01:43:17 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): This key does not do anything: OnDemand
Feb 6 01:43:17 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.TrustEvaluationAgent): This key does not do anything: OnDemand
Feb 6 01:43:17 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.appkit.xpc.sandboxedServiceRunner): The JoinExistingSession key is only available to Application services.
Feb 6 01:43:17 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.DataDetectorsDynamicData): The JoinExistingSession key is only available to Application services.
Feb 6 01:43:17 MBPdiJapoTabani kernel[0]: BUG in process suhelperd[166]: over-released legacy external boost assertions (1 total, 1 external, 0 legacy-external)
Feb 6 01:43:18 MBPdiJapoTabani WindowServer[114]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'. Run with arg = -discovery
Feb 6 01:43:19 MBPdiJapoTabani WindowServer[114]: _CGXGLDisplayContextForDisplayDevice: acquired display context (0x7f947251b9f0) - enabling OpenGL
Feb 6 01:43:21 MBPdiJapoTabani mds[32]: (Volume.Normal:2464) volume:0x7fb15a043600 ********** Bootstrapped Creating a default store:0 SpotLoc:(null) SpotVerLoc:(null) occlude:0 /Volumes/Recovery HD
Feb 6 01:43:21 MBPdiJapoTabani lsregister[126]: LaunchServices: Begin database seeding
Feb 6 01:43:21 MBPdiJapoTabani lsregister[126]: LaunchServices: Completed database seeding
Feb 6 01:43:21 MBPdiJapoTabani kernel[0]: hfs: unmount initiated on Recovery HD on device disk0s3
Feb 6 01:43:21 MBPdiJapoTabani WindowServer[114]: CGXSetDisplayColorProfileAndTransfer: Display 0x042731c0: Unit 0; ColorProfile { -1239862747 }; TransferTable (256, 12)
Feb 6 01:43:21 MBPdiJapoTabani com.apple.AmbientDisplayAgent[171]: AmbientDisplayAgent started
Feb 6 01:43:21 MBPdiJapoTabani com.apple.AmbientDisplayAgent[171]: AMBD initializing devices
Feb 6 01:43:21 MBPdiJapoTabani com.apple.AmbientDisplayAgent[171]: AMBD Agent: xpc connection became invalid during event handler
Feb 6 01:43:21 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.AssistiveControl.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:21 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.btsa): This key does not do anything: OnDemand
Feb 6 01:43:21 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.coreservices.lsactivity): Unknown key for Boolean: DrainMessagesAfterFailedInit
Feb 6 01:43:21 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.helpd): This key does not do anything: OnDemand
Feb 6 01:43:21 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.noticeboard.agent): This key does not do anything: OnDemand
Feb 6 01:43:21 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): This key does not do anything: OnDemand
Feb 6 01:43:21 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.inputswitcher.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:21 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.universalaccesscontrol.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:21 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.universalaccessd.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:21 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.UserEventAgent-LoginWindow): This service is defined to be constantly running and is inherently inefficient.
Feb 6 01:43:21 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.VoiceOver.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:21 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.ZoomWindow.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:21 MBPdiJapoTabani DMProxy[167]: AMBD Services: connection interrupted: com.apple.AmbientDisplayAgent (Connection interrupted)
Feb 6 01:43:21 MBPdiJapoTabani loginwindow[64]: Setting the initial value of the magsave brightness level 2
Feb 6 01:43:21 MBPdiJapoTabani askpermissiond[172]: objc[172]: Class FALogging is implemented in both /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/FamilyCircle and /System/Library/PrivateFrameworks/FamilyNotification.framework/Versions/A/FamilyNotification. One of the two will be used. Which one is undefined.
Feb 6 01:43:21 MBPdiJapoTabani com.apple.SecurityServer[52]: Session 100005 created
Feb 6 01:43:21 MBPdiJapoTabani loginwindow[64]: The current system was not found in the list of machines requiring a switch to a black background
Feb 6 01:43:21 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.DataDetectorsDynamicData): The JoinExistingSession key is only available to Application services.
Feb 6 01:43:21 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.appkit.xpc.sandboxedServiceRunner): The JoinExistingSession key is only available to Application services.
Feb 6 01:43:21 MBPdiJapoTabani loginwindow[64]: Login Window Started Security Agent
Feb 6 01:43:22 MBPdiJapoTabani askpermissiond[172]: StoreTransport: Resetting APS Connection using environment name production
Feb 6 01:43:22 MBPdiJapoTabani WiFiAgent[179]: [NO client logger] <Sep 9 2014 16:12:26> WIFICLOUDSYNC WiFiCloudSyncEngineCreate: created...
Feb 6 01:43:22 MBPdiJapoTabani WiFiAgent[179]: [NO client logger] <Sep 9 2014 16:12:26> WIFICLOUDSYNC WiFiCloudSyncEngineRegisterCallbacks: WiFiCloudSyncEngineCallbacks version - 0, bundle id - com.apple.wifi.WiFiAgent
Feb 6 01:43:22 MBPdiJapoTabani WiFiAgent[179]: securityd_message_with_reply_sync Failed to talk to secd after 4 attempts.
Feb 6 01:43:22 MBPdiJapoTabani UserEventAgent[178]: Failed to copy info dictionary for bundle /System/Library/UserEventPlugins/alfUIplugin.plugin
Feb 6 01:43:22 MBPdiJapoTabani SecurityAgent[184]: This is the first run
Feb 6 01:43:22 MBPdiJapoTabani SecurityAgent[184]: MacBuddy was run = 0
Feb 6 01:43:22 MBPdiJapoTabani SecurityAgent[184]: User info context values set for jacopotabanii
Feb 6 01:43:22 MBPdiJapoTabani UserEventAgent[178]: user agent networkd: built Nov 19 2014 21:39:47
Feb 6 01:43:22 MBPdiJapoTabani apsd[49]: Unable to bootstrap_look_up connection port 'com.apple.askpermission.aps' for user 0: Unknown service name
Feb 6 01:43:22 MBPdiJapoTabani SecurityAgent[184]: Login Window login proceeding
Feb 6 01:43:22 MBPdiJapoTabani loginwindow[64]: Login Window - Returned from Security Agent
Feb 6 01:43:22 MBPdiJapoTabani loginwindow[64]: USER_PROCESS: 64 console
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.FileSyncAgent.PHD.isRunning): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.mbloginhelper.user): This key does not do anything: OnDemand
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.mbpluginhost.user): This key does not do anything: OnDemand
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.secd): This key does not do anything: OnDemand
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.secd): The ServiceIPC key is no longer respected. Please remove it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): This key does not do anything: OnDemand
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.TrustEvaluationAgent): This key does not do anything: OnDemand
Feb 6 01:43:22 MBPdiJapoTabani kernel[0]: AppleKeyStore:Sending lock change 0 for handle -502
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.AssistiveControl.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.btsa): This key does not do anything: OnDemand
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.coreservices.lsactivity): Unknown key for Boolean: DrainMessagesAfterFailedInit
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.coreservices.uiagent): This key does not do anything: OnDemand
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.diagnostics_agent): This service is defined to be constantly running and is inherently inefficient.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.dock.fullscreen): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.dock.server): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.dock.notificationcenter): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.dock.appstore): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.dock.remotedesktoppicture): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.dock.launchpad): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.dock.downloads): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.EscrowSecurityAlert): Unknown key for string: seatbelt-profiles
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.Finder): ThrottleInterval set to zero. You're not that important. Ignoring.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.FontRegistryUIAgent): This key does not do anything: OnDemand
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.ATS.FontValidator): This key does not do anything: OnDemand
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.ATS.FontValidatorConduit): This key does not do anything: OnDemand
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.gamed): The JetsamProperties key is not available on this platform.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.gamed): This key does not do anything: OnDemand
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.gamed): The ServiceIPC key is no longer respected. Please remove it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.helpd): This key does not do anything: OnDemand
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.installd.user): This key does not do anything: OnDemand
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.Maps.mapspushd): Unknown key for double: StartInterval
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.502.100005.Aqua): Caller tried to hijack service: path = /System/Library/LaunchAgents/com.apple.mbpluginhost.user.plist, caller = loginwindow.64
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.midiserver.io): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.noticeboard.agent): This key does not do anything: OnDemand
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.notificationcenterui.alerts): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.notificationcenterui.tcc): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.notificationcenterui.agent): This service is defined to be constantly running and is inherently inefficient.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.502.100005.Aqua): Caller tried to hijack service: path = /System/Library/LaunchAgents/com.apple.pluginkit.pkd.plist, caller = loginwindow.64
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.PubSub.Agent): The ServiceIPC key is no longer respected. Please remove it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.quicklook.ui.helper.active): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.ReportCrash): The DrainMessagesOnCrash key is not yet implemented. If you rely on this key, please file a bug.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.ReportCrash.Self): The DrainMessagesOnCrash key is not yet implemented. If you rely on this key, please file a bug.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.rtcreportingd): The UserName key is not supported for non-System services.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.sharingd): This service is defined to be constantly running and is inherently inefficient.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.soagent): Invalid type for event (event/type): events/array
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.soagent): Invalid type for event (event/type): bundleid/string
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.speech.speechdatainstallerd): This key does not do anything: OnDemand
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.ssinvitationagent): This key does not do anything: OnDemand
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.systemuiserver.ServiceProvider): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.dockextra.server): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.SUISMessaging): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.ipodserver): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.systemuiserver.screencapture): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.tsm.uiserver): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.dockling.server): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.window_proxies.startup): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.window_proxies): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.inputswitcher.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.universalaccesscontrol.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.universalaccessd.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.UserEventAgent-Aqua): This service is defined to be constantly running and is inherently inefficient.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.usernoted): This service is defined to be constantly running and is inherently inefficient.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.VoiceOver.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.ZoomWindow.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (org.openbsd.ssh-agent): The ServiceIPC key is no longer respected. Please remove it.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.502.100005.Aqua): Failed to bootstrap path: path = /System/Library/LaunchAgents/com.apple.pluginkit.pkd.plist, error = 17: File exists
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.502.100005.Aqua): Failed to bootstrap path: path = /System/Library/LaunchAgents/com.apple.mbpluginhost.user.plist, error = 17: File exists
Feb 6 01:43:22 MBPdiJapoTabani distnoted[191]: # distnote server agent absolute time: 50.571402179 civil time: Fri Feb 6 01:43:22 2015 pid: 191 uid: 502 root: no
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.valvesoftware.steamclean): Unknown key for array: SteamContentPaths
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.DataDetectorsDynamicData): The JoinExistingSession key is only available to Application services.
Feb 6 01:43:22 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.appkit.xpc.sandboxedServiceRunner): The JoinExistingSession key is only available to Application services.
Feb 6 01:43:23 MBPdiJapoTabani UserEventAgent[189]: Failed to copy info dictionary for bundle /System/Library/UserEventPlugins/alfUIplugin.plugin
Feb 6 01:43:23 MBPdiJapoTabani UserEventAgent[189]: com.apple.TMHelperAgent.SetupOffer enabled
Feb 6 01:43:23 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.FileSyncAgent.PHD.isRunning): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 6 01:43:23 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.mbloginhelper.user): This key does not do anything: OnDemand
Feb 6 01:43:23 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.mbpluginhost.user): This key does not do anything: OnDemand
Feb 6 01:43:23 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.secd): This key does not do anything: OnDemand
Feb 6 01:43:23 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.secd): The ServiceIPC key is no longer respected. Please remove it.
Feb 6 01:43:23 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): This key does not do anything: OnDemand
Feb 6 01:43:23 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.TrustEvaluationAgent): This key does not do anything: OnDemand
Feb 6 01:43:23 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.DataDetectorsDynamicData): The JoinExistingSession key is only available to Application services.
Feb 6 01:43:23 MBPdiJapoTabani UserEventAgent[189]: user agent networkd: built Nov 19 2014 21:39:47
Feb 6 01:43:23 MBPdiJapoTabani com.apple.audio.DriverHelper[200]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class AMDRadeonX4000_AMDAccelDevice.
Feb 6 01:43:23 MBPdiJapoTabani com.apple.audio.DriverHelper[200]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class AMDRadeonX4000_AMDAccelSharedUserClient.
Feb 6 01:43:23 MBPdiJapoTabani com.apple.audio.DriverHelper[200]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class AMDSIVideoContext.
Feb 6 01:43:23 MBPdiJapoTabani com.apple.audio.DriverHelper[200]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class Gen6DVDContext.
Feb 6 01:43:23 MBPdiJapoTabani com.apple.audio.DriverHelper[200]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IGAccelDevice.
Feb 6 01:43:23 MBPdiJapoTabani com.apple.audio.DriverHelper[200]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IGAccelSharedUserClient.
Feb 6 01:43:23 MBPdiJapoTabani com.apple.audio.DriverHelper[200]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IGAccelVideoContextMain.
Feb 6 01:43:23 MBPdiJapoTabani com.apple.audio.DriverHelper[200]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IGAccelVideoContextMedia.
Feb 6 01:43:23 MBPdiJapoTabani com.apple.audio.DriverHelper[200]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IGAccelVideoContextVEBox.
Feb 6 01:43:23 MBPdiJapoTabani com.apple.audio.DriverHelper[200]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IOBluetoothDeviceUserClient.
Feb 6 01:43:23 MBPdiJapoTabani com.apple.audio.DriverHelper[200]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IOHIDParamUserClient.
Feb 6 01:43:23 MBPdiJapoTabani com.apple.audio.DriverHelper[200]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IOSurfaceRootUserClient.
Feb 6 01:43:23 MBPdiJapoTabani com.apple.audio.DriverHelper[200]: The plug-in named AirPlay.driver requires extending the sandbox for the mach service named com.apple.AirPlayXPCHelper.
Feb 6 01:43:23 MBPdiJapoTabani com.apple.audio.DriverHelper[200]: The plug-in named AirPlay.driver requires extending the sandbox for the mach service named com.apple.wirelessproxd.
Feb 6 01:43:23 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.appkit.xpc.sandboxedServiceRunner): The JoinExistingSession key is only available to Application services.
Feb 6 01:43:23 MBPdiJapoTabani UserEventAgent[189]: received an unknown event from daemon
Feb 6 01:43:23 MBPdiJapoTabani coreaudiod[199]: 2015-02-06 01:43:23.183874 AM [AirPlay] BTLE discovery removing all devices
Feb 6 01:43:23 MBPdiJapoTabani coreaudiod[199]: 2015-02-06 01:43:23.186397 AM [AirPlay] Resetting AWDL traffic registration.
Feb 6 01:43:23 MBPdiJapoTabani coreaudiod[199]: 2015-02-06 01:43:23.186881 AM [AirPlay] Deregister AirPlay traffic for AWDL at MAC 00:00:00:00:00:00 with target infra non critical PeerIndication=0 err=-3900
Feb 6 01:43:23 MBPdiJapoTabani com.apple.audio.DriverHelper[200]: The plug-in named BluetoothAudioPlugIn.driver requires extending the sandbox for the IOKit user-client class IOBluetoothDeviceUserClient.
Feb 6 01:43:23 MBPdiJapoTabani com.apple.audio.DriverHelper[200]: The plug-in named BluetoothAudioPlugIn.driver requires extending the sandbox for the mach service named com.apple.blued.
Feb 6 01:43:23 MBPdiJapoTabani com.apple.audio.DriverHelper[200]: The plug-in named BluetoothAudioPlugIn.driver requires extending the sandbox for the mach service named com.apple.bluetoothaudiod.
Feb 6 01:43:23 MBPdiJapoTabani coreaudiod[199]: Logging disabled
Feb 6 01:43:23 MBPdiJapoTabani coreaudiod[199]: 2015-02-06 01:43:23.215539 AM [AirPlay] AirPlay: Performing audio format change for 4 (AP Out) to PCM/44100/16/2 for output and for input
Feb 6 01:43:23 MBPdiJapoTabani coreaudiod[199]: 2015-02-06 01:43:23.215767 AM [AirPlay] AirPlay: Performing audio format change for 4 (AP Out) to PCM/44100/16/2 for output and for input
Feb 6 01:43:23 MBPdiJapoTabani bluetoothaudiod[204]: Logging disabled
Feb 6 01:43:23 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Feb 6 01:43:23 MBPdiJapoTabani secinitd[206]: UID[502]: cache loaded: /System/Library/Caches/com.apple.app-sandbox-cache.plist
Feb 6 01:43:23 MBPdiJapoTabani com.apple.SecurityServer[52]: Session 100008 created
Feb 6 01:43:23 MBPdiJapoTabani lsregister[194]: LaunchServices: Begin database seeding
Feb 6 01:43:23 MBPdiJapoTabani lsregister[194]: LaunchServices: Completed database seeding
Feb 6 01:43:23 MBPdiJapoTabani tccd[209]: Communications error: <OS_xpc_error: <error: 0x7fff7ed02c60> { count = 1, contents =
"XPCErrorDescription" => <string: 0x7fff7ed02f70> { length = 18, contents = "Connection invalid" }
Feb 6 01:43:23 MBPdiJapoTabani WindowServer[114]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'. Run with arg = -login
Feb 6 01:43:23 MBPdiJapoTabani pboard[214]: Attempt to unlink previous shared memory during startup returned an error. Continuing...
Feb 6 01:43:23 MBPdiJapoTabani sharingd[215]: 01:43:23.899 : Starting Up...
Feb 6 01:43:23 MBPdiJapoTabani sharingd[215]: 01:43:23.907 : Device Capabilities (Handoff:NO, Instant Hotspot:NO, AirDrop:NO, Legacy AirDrop:YES, Remote Disc:NO)
Feb 6 01:43:23 MBPdiJapoTabani mds[32]: (Server.Warning:445) No stores registered for metascope "kMDQueryScopeComputer"
Feb 6 01:43:23 MBPdiJapoTabani WindowServer[114]: CGXSetDisplayColorProfileAndTransfer: Display 0x042731c0: Unit 0; ColorProfile { -1239862747 }; TransferTable (256, 12)
Feb 6 01:43:23 MBPdiJapoTabani DMProxy[213]: AMBD Services: connection interrupted: com.apple.AmbientDisplayAgent (Connection interrupted)
Feb 6 01:43:24 MBPdiJapoTabani com.apple.AmbientDisplayAgent[171]: AmbientDisplayAgent started
Feb 6 01:43:24 MBPdiJapoTabani com.apple.AmbientDisplayAgent[171]: AMBD initializing devices
Feb 6 01:43:24 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Feb 6 01:43:24 MBPdiJapoTabani iconservicesagent[224]: iconservicesagent launched.
Feb 6 01:43:24 MBPdiJapoTabani iconservicesagent[224]: Starting service with cache path: /var/folders/24/65jvxkjn3fd7yp0407nls11h0000gp/C/com.apple.iconservices
Feb 6 01:43:24 MBPdiJapoTabani com.apple.AmbientDisplayAgent[171]: AMBD Agent: xpc connection became invalid during event handler
Feb 6 01:43:24 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.502.100005.Aqua): Could not import service from caller: caller = otherbsd.190, service = com.shazam.mac.ShazamHelper, error = 119: Service is disabled
Feb 6 01:43:24 MBPdiJapoTabani otherbsd[190]: Could not submit LoginItem job com.shazam.mac.ShazamHelper: 119: Service is disabled
Feb 6 01:43:24 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.502.100005.Aqua): Could not import service from caller: caller = otherbsd.190, service = com.stahltechnologies.App-for-Instagram-Helper, error = 119: Service is disabled
Feb 6 01:43:24 MBPdiJapoTabani otherbsd[190]: Could not submit LoginItem job com.stahltechnologies.App-for-Instagram-Helper: 119: Service is disabled
Feb 6 01:43:24 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.502.100005.Aqua): Could not import service from caller: caller = otherbsd.190, service = co.appforfacebook.LoginHelper, error = 119: Service is disabled
Feb 6 01:43:24 MBPdiJapoTabani otherbsd[190]: Could not submit LoginItem job co.appforfacebook.LoginHelper: 119: Service is disabled
Feb 6 01:43:25 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.quicklook[227]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.quicklook
Feb 6 01:43:25 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.accounts.dom): The _DirtyJetsamMemoryLimit key is not available on this platform.
Feb 6 01:43:25 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Feb 6 01:43:25 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.lakitu): The JoinExistingSession key is only available to Application services.
Feb 6 01:43:25 --- last message repeated 1 time ---
Feb 6 01:43:25 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.imdmessageservices.IMDMessageServicesAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Feb 6 01:43:25 MBPdiJapoTabani bird[218]: Assertion failed: ![_xpcClients containsObject:client]
Feb 6 01:43:25 MBPdiJapoTabani logind[65]: -[SessionManager getClient:withRole:inAuditSession:]:241: ERROR: No session dictionary for audit session 100008
Feb 6 01:43:25 MBPdiJapoTabani logind[65]: _SMGetSessionAgent:73: ERROR: __SMGetClientForAuditSessionAgent failed 2
Feb 6 01:43:25 MBPdiJapoTabani IMDPersistenceAgent[236]: SACShieldWindowShowing:925: ERROR: NULL response
Feb 6 01:43:26 MBPdiJapoTabani BezelServices 250.13[64]: ASSERTION FAILED: dvcAddrRef != ((void *)0) -[DriverServices getDeviceAddress:] line: 2727
Feb 6 01:43:26 --- last message repeated 1 time ---
Feb 6 01:43:26 MBPdiJapoTabani Finder[198]: assertion failed: 14C109: libxpc.dylib + 97940 [876216DC-D5D3-381E-8AF9-49AE464E5107]: 0x89
Feb 6 01:43:26 MBPdiJapoTabani xpcproxy[251]: CFPreferences could not connect to its daemon.
Preferences using the connection 0x0 will be volatile and will not be persisted to disk.
Feb 6 01:43:27 MBPdiJapoTabani askpermissiond[250]: objc[250]: Class FALogging is implemented in both /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/FamilyCircle and /System/Library/PrivateFrameworks/FamilyNotification.framework/Versions/A/FamilyNotification. One of the two will be used. Which one is undefined.
Feb 6 01:43:27 MBPdiJapoTabani bird[218]: Assertion failed: ![_xpcClients containsObject:client]
Feb 6 01:43:27 --- last message repeated 2 times ---
Feb 6 01:43:27 MBPdiJapoTabani CallHistorySyncHelper[239]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Feb 6 01:43:27 MBPdiJapoTabani WindowServer[114]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'. Run with arg = -login
Feb 6 01:43:27 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.SocialPushAgent.242): Failed to bootstrap path: path = /System/Library/PrivateFrameworks/AccountsDaemon.framework/XPCServices/DataclassOwnersManager copy.xpc, error = 128: The specified path is not a bundle
Feb 6 01:43:27 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Feb 6 01:43:27 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.syncdefaultsd.259): Failed to bootstrap path: path = /System/Library/PrivateFrameworks/AccountsDaemon.framework/XPCServices/DataclassOwnersManager copy.xpc, error = 128: The specified path is not a bundle
Feb 6 01:43:28 MBPdiJapoTabani syncdefaultsd[259]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
Feb 6 01:43:28 MBPdiJapoTabani Keychain Circle Notification[244]: Posted at launch: (
Feb 6 01:43:28 MBPdiJapoTabani com.apple.iCloudHelper[265]: objc[265]: Class FALogging is implemented in both /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/FamilyCircle and /System/Library/PrivateFrameworks/FamilyNotification.framework/Versions/A/FamilyNotification. One of the two will be used. Which one is undefined.
Feb 6 01:43:28 MBPdiJapoTabani backupd[122]: Property list invalid for format: 200 (property lists cannot contain NULL)
Feb 6 01:43:28 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Feb 6 01:43:28 MBPdiJapoTabani com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.om.apple.photostream-agent.251): Failed to bootstrap path: path = /System/Library/PrivateFrameworks/AccountsDaemon.framework/XPCServices/DataclassOwnersManager copy.xpc, error = 128: The specified path is not a bundle
Feb 6 01:43:28 MBPdiJapoTabani Keychain Circle Notification[244]: REMINDER TIME: 2015-02-06 00:43:28 +0000 >>> 2015-01-24 16:54:37 +0000
