Icristian
- Maccanico assiduo
ragazzi mi è riaapparso il problema del trakpad che perde funzioni....
anche il log
-60005 creating authorization
Jan 6 11:10:37 MacBook-Pro-di-Cristian.local storeaccountd[271]: AccountServiceDelegate: Accepting new connection <NSXPCConnection: 0x7fc9e2f13080> connection from pid 576 with interface <AccountServiceInterface: 0x7fc9e2e30dc0> (PID 576)
Jan 6 11:10:37 MacBook-Pro-di-Cristian com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Jan 6 11:10:37 --- last message repeated 1 time ---
Jan 6 11:10:37 MacBook-Pro-di-Cristian com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.syncdefaultsd.580): Failed to bootstrap path: path = /System/Library/PrivateFrameworks/AccountsDaemon.framework/XPCServices/DataclassOwnersManager copy.xpc, error = 128: The specified path is not a bundle
Jan 6 11:10:37 MacBook-Pro-di-Cristian com.apple.iCloudHelper[581]: objc[581]: Class FALogging is implemented in both /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/FamilyCircle and /System/Library/PrivateFrameworks/FamilyNotification.framework/Versions/A/FamilyNotification. One of the two will be used. Which one is undefined.
Jan 6 11:10:37 MacBook-Pro-di-Cristian.local locationd[54]: Couldn't find a requirement string for masquerading client /System/Library/PrivateFrameworks/Parsec.framework
Jan 6 11:10:37 MacBook-Pro-di-Cristian.local locationd[54]: could not get apple languages array, assuming english
Jan 6 11:10:45 --- last message repeated 1 time ---
Jan 6 11:10:45 MacBook-Pro-di-Cristian.local com.apple.WebKit.Plugin.64[585]: Failed to connect (colorGridView) outlet from (NSApplication) to (NSColorPickerGridView): missing setter or instance variable
Jan 6 11:10:45 MacBook-Pro-di-Cristian.local com.apple.WebKit.Plugin.64[585]: Failed to connect (view) outlet from (NSApplication) to (NSColorPickerGridView): missing setter or instance variable
Jan 6 11:11:13 MacBook-Pro-di-Cristian.local sandboxd[292] ([280]): com.apple.metada(280) deny mach-lookup com.apple.cfnetwork.cfnetworkagent
Jan 6 11:11:13 MacBook-Pro-di-Cristian com.apple.xpc.launchd[1] (com.apple.quicklook[587]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.quicklook
Jan 6 11:11:14 MacBook-Pro-di-Cristian.local Console[592]: Failed to connect (_consoleX) outlet from (NSApplication) to (ConsoleX): missing setter or instance variable
per farlo riandare ho dovuto spegnere il monitor e riaccenderlo ctrl + shift + tasto accensione.
Non so piu cosa fare che cos'è secondo voi ?
- Pro-Expert
Ti è riapparso il problema?
Quando ti era apparso e come hai risolto?
Ne avevi parlato già e in che thread?
Che MacBook hai?
Che sistema e versione usi?
Quante volte lo fa?
In quali occasioni lo fa?
Il log a quale momento si riferisce, esattamente, alla disfunzione quando appare, al blocco o altro?
Hai introdotto modifiche, con SIMBL, Trim, MagicPrefs Trackpad, disabilitato il kext-signing o altro?
Hai abilitato kext (estensioni del kernel o drive) di terze parti?
Hai provato ad avviarlo in modalità sicura?
Ha lo stesso problema?
Hai provato a cercare un chrash.log relativo in Console?
Se non sai tu che ce l'hai davanti a te, il Mac, e sai tutte le cose chieste sopra, come potremmo averne una vaga idea noi?
Icristian
- Maccanico assiduo
macbook pro retina 13 pollici 8gb ram 256 gb sdd i5
Yosemite 10.10 (ultima versione)
Il log risale al momento in cui il trakpad ha smesso di fare andare alcune funzioni, in particolare il pinch to zoom...
Ne avevo gia parlato nel forum e mi avevano fatto fare le pulizie delle varie caches con onyx.
Non ho modificato niente, magicprefs non lo uso.
In precedenza ( 4 settimane fa) mi avevano sostituito la scheda logica perchè ogni tanto faceva dei rumori forti, ma il problema si presentava anche la.
Il problema si presenta quando vuole lui, come si puo presentare tra 3 4 settimane come si può presentare tra tre giorni.
Il problema si risolvere , quando si presenta, o mettendo il mac in stop, o spegnendo il monitor ( ctrl shift power) o riavviando o spegnendo il macbook)... onestamente non so cosa fare...
- Pro-Expert
Mah, ero piuttosto nel dubbioso.
Questi messaggi si ritrovano di frequente in concomitanza di problemi, anche rilevanti.
Una incongruenza che provoca blocchi e crash di qualche funzione.
Ma non sono collegabili direttamente al trackpad, a mio parere.
Si riferiscono genericamente ad errori ed impostazioni errate dell'utente.
O a fenomeni analoghi creati volontariamente dall'utente.
Un po' difficile dare una spiegazione senza che la maggior parte dell'intuizione o esposizione dell'evento venga da te.
Il tutto sembrerebbe legato ad un picco di richiesta eccessiva di impegno della cpu o della ram.
Che il sistema non ce la fa a gestire o a scaricare sulla memoria virtuale.
Ora che sia determinato dal trackpad mi sembra strano.
Più facile che il trackpad ne soffra in maniera evidente.
Io direi, se non hai trovato un lag.log in Console che significhi qualcosa, di aspettare il prossimo evento e dai un'occhiata al processo che ha un picco molto alto
Icristian
- Maccanico assiduo
ciao faxus, grazie per la risposta.
che cos'è il lag.log e dove lo vedo ?
il processo che utilizza piu cpu in monitoraggio attività?
una cosa che però posso dire è che i fenomeni si sonoverificati quando avevo un app a tutto schermo non so se possa servire....
Icristian
- Maccanico assiduo
Una cosa non mi è chiara quando intendi, "non ce la fa, e magari il trakpad ne soffre particolarmente", intenderesti dire che il pc ha qualcosa che non va (presumibilmente) a livello hardware ?
- Pro-Expert
Un lag è un blocco senza crash, si blocca perché viene inviato un segnale di interruzione ma non crascia nulla.
È senza nome perché non so quale sia.
No, non sembra a livello hardware
Icristian
- Maccanico assiduo
ecco è riaccaduto cosa faccio ???? i processi ch eoccupano di piu sono quelli di vmware fusion.... che faccio?
Icristian
- Maccanico assiduo
Jan 7 13:48:43 MacBook-Pro-di-Cristian com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Jan 7 13:48:43 --- last message repeated 1 time ---
Jan 7 13:48:43 MacBook-Pro-di-Cristian com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.pid.syncdefaultsd.1456): Failed to bootstrap path: path = /System/Library/PrivateFrameworks/AccountsDaemon.framework/XPCServices/DataclassOwnersManager copy.xpc, error = 128: The specified path is not a bundle
Jan 7 13:48:43 MacBook-Pro-di-Cristian com.apple.iCloudHelper[1457]: objc[1457]: Class FALogging is implemented in both /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/FamilyCircle and /System/Library/PrivateFrameworks/FamilyNotification.framework/Versions/A/FamilyNotification. One of the two will be used. Which one is undefined.
Jan 7 13:48:44 MacBook-Pro-di-Cristian.local locationd[54]: Couldn't find a requirement string for masquerading client /System/Library/PrivateFrameworks/Parsec.framework
Jan 7 13:48:44 MacBook-Pro-di-Cristian.local locationd[54]: could not get apple languages array, assuming english
Jan 7 13:48:44 MacBook-Pro-di-Cristian com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Jan 7 13:48:45 MacBook-Pro-di-Cristian.local com.apple.SecurityServer[52]: Session 100026 created
Jan 7 13:48:46 MacBook-Pro-di-Cristian com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Jan 7 13:49:23 --- last message repeated 2 times ---
Jan 7 13:49:23 MacBook-Pro-di-Cristian com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Jan 7 13:49:24 MacBook-Pro-di-Cristian.local lsuseractivityd[253]: -[LSUserActivityClientProcess doUpdateUserActivityInfo:makeCurrent:completionHandler:], refusing to register user activity from client, and returning error Error Domain=LSContinuityErrorDomain Code=-108 "The operation couldnât be completed. (LSContinuityErrorDomain error -108.)" for item <__NSConcreteUUID 0x7fc8d1e15d10> 5838F449-2D64-4A85-895A-11864B9CFE1E NSUserActivityTypeBrowsingWeb (LSUserActivityClientProcess.m #1148)
Jan 7 13:49:50 MacBook-Pro-di-Cristian.local CoreServicesUIAgent[274]: unexpected message <OS_xpc_error: <error: 0x7fff7b0aec60> { count = 1, contents =
"XPCErrorDescription" => <string: 0x7fff7b0aef70> { length = 18, contents = "Connection invalid" }
Jan 7 13:49:50 MacBook-Pro-di-Cristian com.apple.xpc.launchd[1] (com.apple.WebKit.Networking.A619EB56-4218-443B-8EA9-00DDCAA2BF00[1453]): Service exited with abnormal code: 1
Jan 7 13:49:54 MacBook-Pro-di-Cristian.local storeaccountd[272]: AccountServiceDelegate: Accepting new connection <NSXPCConnection: 0x7fd710f225a0> connection from pid 1473 with interface <AccountServiceInterface: 0x7fd710f0c480> (PID 1473)
Jan 7 13:49:54 MacBook-Pro-di-Cristian com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Jan 7 13:49:55 --- last message repeated 1 time ---
Jan 7 13:49:55 MacBook-Pro-di-Cristian.local locationd[54]: Couldn't find a requirement string for masquerading client /System/Library/PrivateFrameworks/Parsec.framework
Jan 7 13:49:55 MacBook-Pro-di-Cristian.local locationd[54]: could not get apple languages array, assuming english
Jan 7 13:49:56 MacBook-Pro-di-Cristian.local com.apple.SecurityServer[52]: Session 100027 created
Jan 7 13:49:56 MacBook-Pro-di-Cristian com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Jan 7 13:50:01 MacBook-Pro-di-Cristian kernel[0]: Sandbox: com.apple.metada(279) deny mach-lookup com.apple.cfnetwork.cfnetworkagent
Jan 7 13:50:07 --- last message repeated 4 times ---
Jan 7 13:50:07 MacBook-Pro-di-Cristian com.apple.xpc.launchd[1] (com.apple.quicklook[1485]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.quicklook
Jan 7 13:50:23 MacBook-Pro-di-Cristian.local com.apple.sbd[314]: SOSCCThisDeviceIsInCircle SOSCCThisDeviceIsInCircle!! 13
Jan 7 13:50:23 MacBook-Pro-di-Cristian.local com.apple.sbd[314]: SOSCCThisDeviceIsInCircle SOSCCThisDeviceIsInCircle!! 14
Jan 7 13:50:28 MacBook-Pro-di-Cristian kernel[0]: Sandbox: com.apple.metada(279) deny mach-lookup com.apple.cfnetwork.cfnetworkagent
Jan 7 13:50:28 MacBook-Pro-di-Cristian.local Console[1489]: Failed to connect (_consoleX) outlet from (NSApplication) to (ConsoleX): missing setter or instance variable
Jan 7 13:50:29 MacBook-Pro-di-Cristian.local com.apple.WebKit.Plugin.64[1490]: Failed to connect (colorGridView) outlet from (NSApplication) to (NSColorPickerGridView): missing setter or instance variable
Jan 7 13:50:29 MacBook-Pro-di-Cristian.local com.apple.WebKit.Plugin.64[1490]: Failed to connect (view) outlet from (NSApplication) to (NSColorPickerGridView): missing setter or instance variable
Jan 7 13:50:38 MacBook-Pro-di-Cristian.local Spotlight[250]: CoreAnimation: warning, deleted thread with uncommitted CATransaction; set CA_DEBUG_TRANSACTIONS=1 in environment to log backtraces.
Jan 7 13:51:44 MacBook-Pro-di-Cristian kernel[0]: vmnet: VMNetDisconnect called for port 0xffffff802d5fce00
Jan 7 13:51:44 MacBook-Pro-di-Cristian kernel[0]: vmnet: VMNetDisconnect called for port 0xffffff802d22da00
Jan 7 13:51:44 MacBook-Pro-di-Cristian kernel[0]: vmnet: VNetUserIfFree: freeing userIf at 0xffffff802d22da00.
Jan 7 13:51:44 MacBook-Pro-di-Cristian kernel[0]: vmmon: Cleaned up 519736 virtual main memory pages from VM 0xffffff8023052008.
Jan 7 13:51:44 MacBook-Pro-di-Cristian kernel[0]: vmmon: Cleaned up 2756 monitor anonymous pages from VM 0xffffff8023052008.
Jan 7 13:51:44 MacBook-Pro-di-Cristian kernel[0]: vmmon: Cleaned up 2280 user anonymous pages from VM 0xffffff8023052008.
Jan 7 13:51:55 MacBook-Pro-di-Cristian kernel[0]: Sandbox: com.apple.metada(279) deny mach-lookup com.apple.cfnetwork.cfnetworkagent
ecco il sistem log
Icristian
- Maccanico assiduo
edit: il trakpad oltre aver perso la funzioen di zoom anche quello di scorrere nelle app a tutto schermo
- Pro-Expert
Forse, prova a vedere se Fusion è aggiornato o disinstallarlo poi rimontarlo.
Anche se vedo riferimenti ai core in relazione a iCloud, Messaggi e Face Time
Ultima modifica di
faxus il mer, 07 gen 2015 14:03, modificato 1 volta in totale.
Icristian
- Maccanico assiduo
Cosa disinstallo e reinstallo ?
Potresti dirmi cosa faresti tu ?
- Pro-Expert
Icristian
- Maccanico assiduo
Ok il problema omunque si presentava anche prima....
- Pro-Expert
Hai cercato tra i log qualcosa relativo?
Ai lag e al trackpad
Visitano il forum: Nessuno e 29 ospiti
