Ci dovrebbe essere la scelta per fare egualmente una scansione rapida.Bonnie3 ha scritto:... Adesso ho fatto il comando con sudo pdisk /dev/rdisk1 ma dice "pdisk: Can't open file '/dev/rdisk1' for writing (resource busy). Devo procedere ugualmente con "c"?
TestDisk 7.0-WIP, Data Recovery Utility, December 2014
Christophe GRENIER <grenier@cgsecurity.org>
http://www.cgsecurity.org
Disk /dev/disk2 - 500 GB / 465 GiB - 976707584 sectors (RO)
Current partition structure:
Partition Start End Size in sectors
check_FAT: Unusual media descriptor (0xf0!=0xf8)
Warning: number of heads/cylinder mismatches 255 (FAT) != 1 (HD)
Warning: number of sectors per track mismatches 32 (FAT) != 1 (HD)
1 P FAT32 63 976707521 976707459 [******]
Warning: Bad ending sector (CHS and LBA don't match)
No partition is bootable
*=Primary bootable P=Primary L=Logical E=Extended D=Deleted
>[Quick Search] [ Backup ]
Try to locate partition
>* FAT32 LBA 63 976707521 976707459 [*****]
Structure: Ok. Use Up/Down Arrow keys to select partition.
Use Left/Right Arrow keys to CHANGE partition characteristics:
Keys A: add partition, L: load backup, T: change type, P: list files,
Enter: to continue
FAT32, blocksize=32768, 500 GB / 465 GiB
1 P FAT32 63 976707521 976707459 [*****]
Enter: to continue
MacBook-Pro-di-*****:testdisk-7.0-WIP *****$ sudo pdisk /dev/rdisk2
pdisk: No valid block 1 on '/dev/rdisk2'
Edit /dev/rdisk2 -
Command (? for help): i
pdisk: can't open file '/dev/rdisk2' for writing (Resource busy)
Command (? for help): c
No partition map exists
Visitano il forum: Nessuno e 23 ospiti
