Incollalo su una pagina di TextEdit, poi la metti su DropBox e posti il link.resonate ha scritto:Non riesco a copiare il syslog mi dice che sono troppi caratteri, qualche consiglio sul come potertelo inviare diversamente?
Nov 18 13:22:12 Macintosh.local Locum[342]: Connection with distnoted server was invalidated
Nov 18 13:22:12 Macintosh.local coreaudiod[171]: Disabled automatic stack shots because audio IO is active
Nov 18 13:22:13 Macintosh.local coreaudiod[171]: Enabled automatic stack shots because audio IO is inactive
Nov 18 13:22:25 Macintosh.local WindowServer[96]: CGXSetWindowBackgroundBlurRadius: Invalid window 0xffffffff
Nov 18 13:22:55 --- last message repeated 1 time ---
Nov 18 13:24:59 Macintosh.local librariand[349]: MMe quota status changed: under quota
Nov 18 13:24:59 Macintosh.local com.apple.security.pboxd[351]: Bug: 12F45: liblaunch.dylib + 23849 [2F71CAF8-6524-329E-AC56-C506658B4C0C]: 0x25
Nov 18 13:25:03 Macintosh.local TextEdit[347]: SCNetworkReachability server not available
Nov 18 13:25:03 --- last message repeated 1 time ---
Nov 18 13:25:03 Macintosh.local TextEdit[347]: socket(PF_ROUTE) failed: Operation not permitted
Nov 18 13:25:03 Macintosh kernel[0]: Sandbox: sandboxd(352) deny mach-lookup com.apple.coresymbolicationd
Nov 18 13:25:06 Macintosh.local sandboxd[352] ([347]): TextEdit(347) deny mach-lookup com.apple.SystemConfiguration.SCNetworkReachability
Nov 18 13:25:06 Macintosh.local sandboxd[352] ([347]): TextEdit(347) deny system-socket
Nov 18 13:25:08 Macintosh.local com.apple.security.pboxd[351]: CGSGetWindowTags: Invalid window 0x5c
Nov 18 13:25:08 Macintosh.local com.apple.security.pboxd[351]: kCGErrorFailure: CGSSetHideOnDeact: error getting window tags
Nov 18 13:25:08 Macintosh.local com.apple.security.pboxd[351]: CGSCopyWindowColorSpace: Invalid window 0x5c
Nov 18 13:25:21 Macintosh.local com.apple.security.pboxd[351]: CGSReleaseWindow: Invalid window 92
Nov 18 13:25:21 Macintosh.local com.apple.security.pboxd[351]: _NXTermWindow: error releasing window (1000)
Nov 18 13:25:33 Macintosh.local coreaudiod[171]: Disabled automatic stack shots because audio IO is active
Nov 18 13:25:34 Macintosh.local coreaudiod[171]: Enabled automatic stack shots because audio IO is inactive
Nov 18 13:25:43 Macintosh.local coreaudiod[171]: Disabled automatic stack shots because audio IO is active
Nov 18 13:25:43 Macintosh.local coreaudiod[171]: Enabled automatic stack shots because audio IO is inactive
Nov 18 13:26:22 Macintosh com.apple.launchd.peruser.502[151] (com.apple.PackageKit.InstallStatus): Throttling respawn: Will start in 9 seconds
Nov 18 13:26:22 Macintosh.local WindowServer[96]: dict count after removing entry for window 0x30 is 0
Nov 18 13:26:22 Macintosh.local WindowServer[96]: CGXGetConnectionProperty: Invalid connection 49155
Nov 18 13:26:22 --- last message repeated 4 times ---
Nov 18 13:26:22 Macintosh com.apple.launchd.peruser.502[151] (com.apple.talagent[168]): Exited: Killed: 9
Nov 18 13:26:22 Macintosh com.apple.launchd[1] (com.apple.quicklook.satellite.5E468918-8247-45F3-BE32-366997FDFFF0[344]): Could not terminate job: 3: No such process
Nov 18 13:26:22 Macintosh com.apple.launchd[1] (com.apple.quicklook.satellite.5E468918-8247-45F3-BE32-366997FDFFF0[344]): Using fallback option to terminate job...
Nov 18 13:26:22 Macintosh.local UserEventAgent[11]: Captive: [UserAgentDied:139] User Agent @port=43527 Died
Nov 18 13:26:22 Macintosh com.apple.launchd.peruser.502[151] ([0x0-0x1a01a].com.apple.ImageCaptureExtension2[244]): Exited: Killed: 9
Nov 18 13:26:22 Macintosh com.apple.launchd.peruser.502[151] ([0x0-0x21021].com.apple.AppleSpell[335]): Exited: Terminated: 15
Nov 18 13:26:22 Macintosh com.apple.launchd.peruser.502[151] (com.apple.quicklook[343]): Exited: Killed: 9
Nov 18 13:26:22 Macintosh com.apple.launchd.peruser.502[151] (com.apple.UserEventAgent-Aqua[154]): Exited: Killed: 9
Nov 18 13:26:38 localhost bootlog[0]: BOOT_TIME 1416313598 0
Nov 18 13:26:54 localhost kernel[0]: PMAP: PCID enabled
Nov 18 13:26:54 localhost kernel[0]: Darwin Kernel Version 12.5.0: Sun Sep 29 13:33:47 PDT 2013; root:xnu-2050.48.12~1/RELEASE_X86_64
Nov 18 13:26:54 localhost kernel[0]: vm_page_bootstrap: 890400 free pages and 117216 wired pages
Nov 18 13:26:54 localhost kernel[0]: kext submap [0xffffff7f80742000 - 0xffffff8000000000], kernel text [0xffffff8000200000 - 0xffffff8000742000]
Nov 18 13:26:54 localhost kernel[0]: zone leak detection enabled
Nov 18 13:26:54 localhost kernel[0]: standard timeslicing quantum is 10000 us
Nov 18 13:26:54 localhost kernel[0]: standard background quantum is 2500 us
Nov 18 13:26:54 localhost kernel[0]: mig_table_max_displ = 74
Nov 18 13:26:54 localhost kernel[0]: corecrypto kext started!
Nov 18 13:26:54 localhost kernel[0]: Running kernel space in FIPS MODE
Nov 18 13:26:54 localhost kernel[0]: Plist hmac value is 735d392b68241ef173d81097b1c8ce9ba283521626d1c973ac376838c466757d
Nov 18 13:26:54 localhost kernel[0]: Computed hmac value is 735d392b68241ef173d81097b1c8ce9ba283521626d1c973ac376838c466757d
Nov 18 13:26:54 localhost kernel[0]: corecrypto.kext FIPS integrity POST test passed!
Nov 18 13:26:54 localhost kernel[0]: corecrypto.kext FIPS AES CBC POST test passed!
Nov 18 13:26:54 localhost kernel[0]: corecrypto.kext FIPS TDES CBC POST test passed!
Nov 18 13:26:54 localhost kernel[0]: corecrypto.kext FIPS AES ECB AESNI POST test passed!
Nov 18 13:26:54 localhost kernel[0]: corecrypto.kext FIPS AES XTS AESNI POST test passed!
Nov 18 13:26:54 localhost kernel[0]: corecrypto.kext FIPS SHA POST test passed!
Nov 18 13:26:54 localhost kernel[0]: corecrypto.kext FIPS HMAC POST test passed!
Nov 18 13:26:54 localhost kernel[0]: corecrypto.kext FIPS ECDSA POST test passed!
Nov 18 13:26:54 localhost kernel[0]: corecrypto.kext FIPS DRBG POST test passed!
Nov 18 13:26:54 localhost kernel[0]: corecrypto.kext FIPS POST passed!
Nov 18 13:26:54 localhost kernel[0]: AppleACPICPU: ProcessorId=1 LocalApicId=0 Enabled
Nov 18 13:26:54 localhost kernel[0]: AppleACPICPU: ProcessorId=2 LocalApicId=1 Enabled
Nov 18 13:26:54 localhost kernel[0]: AppleACPICPU: ProcessorId=3 LocalApicId=4 Enabled
Nov 18 13:26:54 localhost kernel[0]: AppleACPICPU: ProcessorId=4 LocalApicId=5 Enabled
Nov 18 13:26:54 localhost kernel[0]: AppleACPICPU: ProcessorId=5 LocalApicId=0 Disabled
Nov 18 13:26:54 localhost kernel[0]: AppleACPICPU: ProcessorId=6 LocalApicId=0 Disabled
Nov 18 13:26:54 localhost kernel[0]: AppleACPICPU: ProcessorId=7 LocalApicId=0 Disabled
Nov 18 13:26:54 localhost kernel[0]: AppleACPICPU: ProcessorId=8 LocalApicId=0 Disabled
Nov 18 13:26:54 localhost kernel[0]: calling mpo_policy_init for TMSafetyNet
Nov 18 13:26:54 localhost kernel[0]: Security policy loaded: Safety net for Time Machine (TMSafetyNet)
Nov 18 13:26:54 localhost kernel[0]: calling mpo_policy_init for Sandbox
Nov 18 13:26:54 localhost kernel[0]: Security policy loaded: Seatbelt sandbox policy (Sandbox)
Nov 18 13:26:54 localhost kernel[0]: calling mpo_policy_init for Quarantine
Nov 18 13:26:54 localhost kernel[0]: Security policy loaded: Quarantine policy (Quarantine)
Nov 18 13:26:54 localhost kernel[0]: Copyright (c) 1982, 1986, 1989, 1991, 1993
Nov 18 13:26:54 localhost kernel[0]: The Regents of the University of California. All rights reserved.
Nov 18 13:26:54 localhost kernel[0]: MAC Framework successfully initialized
Nov 18 13:26:54 localhost kernel[0]: using 16384 buffer headers and 10240 cluster IO buffer headers
Nov 18 13:26:54 localhost kernel[0]: IOAPIC: Version 0x20 Vectors 64:87
Nov 18 13:26:54 localhost kernel[0]: ACPI: sleep states S3 S4 S5
Nov 18 13:26:54 localhost kernel[0]: pci build Sep 29 2013 13:35:16, flags 0x23008, pfm64 (36 cpu) 0xf80000000, 0x80000000
Nov 18 13:26:54 localhost kernel[0]: [ PCI configuration begin ]
Nov 18 13:26:54 localhost kernel[0]: AppleIntelCPUPowerManagement: Turbo Ratios 0024
Nov 18 13:26:54 localhost kernel[0]: AppleIntelCPUPowerManagement: (built 13:50:43 Sep 29 2013) initialization complete
Nov 18 13:26:54 localhost kernel[0]: console relocated to 0xf80030000
Nov 18 13:26:54 localhost kernel[0]: [ PCI configuration end, bridges 7, devices 16 ]
Nov 18 13:26:54 localhost kernel[0]: [ PCI configuration end, bridges 8, devices 22 ]
Nov 18 13:26:54 localhost kernel[0]: FireWire (OHCI) Lucent ID 5901 built-in now active, GUID 78ca39fffe1e3266; max speed s800.
Nov 18 13:26:54 localhost kernel[0]: mbinit: done [64 MB total pool size, (42/21) split]
Nov 18 13:26:54 localhost kernel[0]: Pthread support ABORTS when sync kernel primitives misused
Nov 18 13:26:54 localhost kernel[0]: rooting via boot-uuid from /chosen: 2AD9527E-03C4-3C15-9CB0-9B546FACCE85
Nov 18 13:26:54 localhost kernel[0]: Waiting on <dict ID="0"><key>IOProviderClass</key><string ID="1">IOResources</string><key>IOResourceMatch</key><string ID="2">boot-uuid-media</string></dict>
Nov 18 13:26:54 localhost kernel[0]: com.apple.AppleFSCompressionTypeZlib kmod start
Nov 18 13:26:54 localhost kernel[0]: com.apple.AppleFSCompressionTypeDataless kmod start
Nov 18 13:26:54 localhost kernel[0]: com.apple.AppleFSCompressionTypeZlib load succeeded
Nov 18 13:26:54 localhost kernel[0]: com.apple.AppleFSCompressionTypeDataless load succeeded
Nov 18 13:26:54 localhost kernel[0]: AppleIntelCPUPowerManagementClient: ready
Nov 18 13:26:54 localhost kernel[0]: Got boot device = IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@1F,2/AppleIntelPchSeriesAHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice/IOBlockStorageDriver/Hitachi HTS545032B9SA02 Media/IOGUIDPartitionScheme/Mac HD 15.12.13@2
Nov 18 13:26:54 localhost kernel[0]: BSD root: disk0s2, major 1, minor 2
Nov 18 13:26:54 localhost kernel[0]: BTCOEXIST off
Nov 18 13:26:54 localhost kernel[0]: BRCM tunables:
Nov 18 13:26:54 localhost kernel[0]: pullmode[1] txringsize[ 256] txsendqsize[1024] reapmin[ 32] reapcount[ 128]
Nov 18 13:26:54 localhost kernel[0]: Kernel is LP64
Nov 18 13:26:54 localhost kernel[0]: USBMSC Identifier (non-unique): 000000009833 0x5ac 0x8403 0x9833, 2
Nov 18 13:26:40 localhost com.apple.launchd[1]: *** launchd[1] has started up. ***
Nov 18 13:26:40 localhost com.apple.launchd[1]: *** Shutdown logging is enabled. ***
Nov 18 13:26:54 localhost com.apple.launchd[1] (com.apple.automountd): Unknown key for boolean: NSSupportsSuddenTermination
Nov 18 13:26:54 localhost distnoted[19]: # distnote server daemon absolute time: 17.528172248 civil time: Tue Nov 18 13:26:54 2014 pid: 19 uid: 0 root: yes
Nov 18 13:27:06 localhost kernel[0]: BCM5701Enet: Ethernet address c8:bc:c8:8d:76:56
Nov 18 13:27:06 localhost kernel[0]: AirPort_Brcm4331: Ethernet address c8:bc:c8:cf:cf:30
Nov 18 13:27:06 localhost kernel[0]: IO80211Controller::dataLinkLayerAttachComplete(): adding AppleEFINVRAM notification
Nov 18 13:27:06 localhost kernel[0]: IO80211Interface::efiNVRAMPublished():
Nov 18 13:27:06 localhost kernel[0]: macx_swapon SUCCESS
Nov 18 13:27:07 localhost kernel[0]: Waiting for DSMOS...
Nov 18 13:27:07 localhost hidd[48]: Posting 'com.apple.iokit.hid.displayStatus' notifyState=1
Nov 18 13:27:08 localhost appleeventsd[54]: main: Starting up
Nov 18 13:27:08 localhost com.apple.usbmuxd[29]: usbmuxd-344.3 on Oct 13 2014 at 21:10:09, running 64 bit
Nov 18 13:27:08 localhost mDNSResponder[41]: mDNSResponder mDNSResponder-379.38.1 (Apr 25 2013 19:19:56) starting OSXVers 12
Nov 18 13:27:08 localhost coreservicesd[66]: FindBestLSSession(), no match for inSessionID 0xfffffffffffffffc auditTokenInfo( uid=0 euid=0 auSessionID=100000 create=false
Nov 18 13:27:08 localhost hidd[48]: void __IOHIDLoadBundles(): Loaded 0 HID plugins
Nov 18 13:27:09 localhost kernel[0]: AGC: 3.4.5, HW version=1.9.21, flags:0, features:20600
Nov 18 13:27:09 localhost kernel[0]: Previous Shutdown Cause: 5
Nov 18 13:27:09 localhost kernel[0]: SMC::smcInitHelper ERROR: MMIO regMap == NULL - fall back to old SMC mode
Nov 18 13:27:09 localhost kernel[0]: IOBluetoothUSBDFU::probe
Nov 18 13:27:09 localhost kernel[0]: IOBluetoothUSBDFU::probe ProductID - 0x8218 FirmwareVersion - 0x0042
Nov 18 13:27:09 localhost kernel[0]: **** [BroadcomBluetoothHostControllerUSBTransport][start] -- Completed -- this = 0xffffff8021133c00 ****
Nov 18 13:27:09 localhost kernel[0]: fNumVRAMBlocks is 4
Nov 18 13:27:09 localhost kernel[0]: NVDAStartup: Official
Nov 18 13:27:09 localhost kernel[0]: NVDANV50HAL loaded and registered
Nov 18 13:27:09 localhost com.apple.kextd[12]: Can't load /System/Library/Extensions/DigiDal.kext - no code for running kernel's architecture.
Nov 18 13:27:09 localhost com.apple.kextd[12]: Load com.digidesign.iokit.DigiDal failed; removing personalities from kernel.
Nov 18 13:27:09 localhost com.apple.kextd[12]: Can't load /System/Library/Extensions/DigiIO.kext - no code for running kernel's architecture.
Nov 18 13:27:09 localhost com.apple.kextd[12]: Load com.digidesign.iokit.DigiIO failed; removing personalities from kernel.
Nov 18 13:27:10 localhost kernel[0]: DSMOS has arrived
Nov 18 13:27:10 localhost kernel[0]: [IOBluetoothHCIController][staticBluetoothHCIControllerTransportShowsUp] -- Received Bluetooth Controller register service notification -- controller = 0xffffff8021133c00
Nov 18 13:27:10 localhost kernel[0]: [IOBluetoothHCIController][start] -- completed
Nov 18 13:27:10 localhost kernel[0]: Waves SoundGrid Version: 2.0.0.14, Non-Interleaved Playback
Nov 18 13:27:10 localhost kernel[0]: [IOBluetoothHCIController::setConfigState] calling registerService
Nov 18 13:27:10 localhost com.apple.kextd[12]: Can't load /System/Library/Extensions/DigiIO.kext - no code for running kernel's architecture.
Nov 18 13:27:10 localhost com.apple.kextd[12]: Load com.digidesign.iokit.DigiIO failed; removing personalities from kernel.
Nov 18 13:27:10 localhost com.apple.SecurityServer[15]: Session 100000 created
Nov 18 13:27:11 localhost kernel[0]: [AGPM Controller] build GPUDict by Vendor8086Device0046
Nov 18 13:27:11 localhost kernel[0]: [AGPM Controller] build GPUDict by Vendor10deDevice0a29
Nov 18 13:27:11 localhost kernel[0]: SMC::smcReadKeyAction ERROR: smcReadData8 failed for key MOTP (kSMCKeyNotFound)
Nov 18 13:27:11 localhost mds[40]: (Normal) FMW: FMW 0 0
Nov 18 13:27:11 localhost revisiond[35]: Had metainfo
Nov 18 13:27:11 localhost revisiond[35]: UUIDs match!
Nov 18 13:27:11 localhost airportd[82]: _processDLILEvent: en1 attached (down)
Nov 18 13:27:11 localhost kernel[0]: createVirtIf(): ifRole = 1
Nov 18 13:27:11 localhost kernel[0]: in func createVirtualInterface ifRole = 1
Nov 18 13:27:11 localhost kernel[0]: AirPort_Brcm4331_P2PInterface::init name <p2p0> role 1 this 0xffffff8021010000
Nov 18 13:27:11 localhost kernel[0]: AirPort_Brcm4331_P2PInterface::init() <p2p> role 1
Nov 18 13:27:11 localhost kernel[0]: Created virtif 0xffffff8021010000 p2p0
Nov 18 13:27:12 localhost WindowServer[83]: Server is starting up
Nov 18 13:27:12 localhost WindowServer[83]: Session 256 retained (2 references)
Nov 18 13:27:12 localhost WindowServer[83]: Session 256 released (1 references)
Nov 18 13:27:12 localhost WindowServer[83]: init_page_flip: page flip mode is on
Nov 18 13:27:13 Macintosh.local configd[18]: setting hostname to "Macintosh.local"
Nov 18 13:27:13 Macintosh kernel[0]: AirPort: Link Down on en1. Reason 1 (Unspecified).
Nov 18 13:27:13 Macintosh kernel[0]: en1::IO80211Interface::postMessage bssid changed
Nov 18 13:27:13 Macintosh.local configd[18]: network changed.
Nov 18 13:27:13 Macintosh.local blued[57]: hostControllerOnline - Number of Paired devices = 1, List of Paired devices = (
"68-96-7b-a9-df-09"
Nov 18 13:27:14 Macintosh.local WindowServer[83]: mux_initialize: Mode is dynamic
Nov 18 13:27:14 Macintosh.local WindowServer[83]: GLCompositor enabled for tile size [256 x 256]
Nov 18 13:27:14 Macintosh.local WindowServer[83]: CGXGLInitMipMap: mip map mode is on
Nov 18 13:27:14 Macintosh.local WindowServer[83]: WSMachineUsesNewStyleMirroring: false
Nov 18 13:27:14 Macintosh.local WindowServer[83]: Display 0x042728c0: GL mask 0x5; bounds (0, 0)[1440 x 900], 36 modes available
Main, Active, on-line, enabled, built-in, boot, Vendor 610, Model 9ca3, S/N 0, Unit 0, Rotation 0
UUID 0x0000061000009ca300000000042728c0
Nov 18 13:27:14 Macintosh.local WindowServer[83]: Display 0x003f003d: GL mask 0x2; bounds (0, 0)[0 x 0], 1 modes available
off-line, enabled, Vendor ffffffff, Model ffffffff, S/N ffffffff, Unit 1, Rotation 0
UUID 0xffffffffffffffffffffffff003f003d
Nov 18 13:27:14 Macintosh.local WindowServer[83]: Created shield window 0x5 for display 0x042728c0
Nov 18 13:27:14 Macintosh.local WindowServer[83]: Created shield window 0x6 for display 0x003f003d
Nov 18 13:27:14 Macintosh.local WindowServer[83]: Display 0x003f003d: GL mask 0x2; bounds (2464, 0)[1 x 1], 1 modes available
Nov 18 13:27:14 Macintosh.local WindowServer[83]: CGXPerformInitialDisplayConfiguration
Nov 18 13:27:14 Macintosh.local WindowServer[83]: Display 0x042728c0: MappedDisplay Unit 0; Alias(0, 0x5); Vendor 0x610 Model 0x9ca3 S/N 0 Dimensions 13.03 x 8.15; online enabled built-in, Bounds (0,0)[1440 x 900], Rotation 0, Resolution 1
Nov 18 13:27:14 Macintosh.local WindowServer[83]: Display 0x003f003d: MappedDisplay Unit 1; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (2464,0)[1 x 1], Rotation 0, Resolution 1
Nov 18 13:27:14 Macintosh.local WindowServer[83]: CGXMuxBoot: Boot normal
Nov 18 13:27:14 Macintosh.local launchctl[88]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
Nov 18 13:27:14 Macintosh.local launchctl[89]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
Nov 18 13:27:14 Macintosh.local WindowServer[83]: GLCompositor: GL renderer id 0x01022612, GL mask 0x00000003, accelerator 0x000043a3, unit 0, caps QEX|QGL|MIPMAP, vram 256 MB
Nov 18 13:27:14 Macintosh.local WindowServer[83]: GLCompositor: GL renderer id 0x01022612, GL mask 0x00000003, texture units 8, texture max 8192, viewport max {8192, 8192}, extensions FPRG|NPOT|GLSL|FLOAT
Nov 18 13:27:14 Macintosh.local WindowServer[83]: GLCompositor: GL renderer id 0x01024300, GL mask 0x00000004, accelerator 0x0000331f, unit 2, caps QEX|QGL|MIPMAP, vram 288 MB
Nov 18 13:27:14 Macintosh.local WindowServer[83]: GLCompositor: GL renderer id 0x01024300, GL mask 0x00000004, texture units 8, texture max 8192, viewport max {8192, 8192}, extensions FPRG|NPOT|GLSL|FLOAT
Nov 18 13:27:14 Macintosh.local WindowServer[83]: Unable to open IOHIDSystem (e00002bd)
Nov 18 13:27:15 Macintosh kernel[0]: virtual bool IOHIDEventSystemUserClient::initWithTask(task_t, void *, UInt32): Client task not privileged to open IOHIDSystem for mapping memory (e00002c1)
Nov 18 13:27:16 Macintosh.local WindowServer[83]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'.
Nov 18 13:27:16 Macintosh.local WindowServer[83]: Received display connect changed for display 0x42728c0
Nov 18 13:27:16 Macintosh.local WindowServer[83]: CGXMuxAcknowledge: Posting glitchless acknowledge
Nov 18 13:27:16 Macintosh.local WindowServer[83]: Received display connect changed for display 0x3f003d
Nov 18 13:27:19 Macintosh.local com.apple.SecurityServer[15]: Entering service
Nov 18 13:27:19 Macintosh.local systemkeychain[75]: done file: /var/run/systemkeychaincheck.done
Nov 18 13:27:19 Macintosh.local mDNSResponder[41]: D2D_IPC: Loaded
Nov 18 13:27:19 Macintosh.local mDNSResponder[41]: D2DInitialize succeeded
Nov 18 13:27:19 Macintosh.local configd[18]: network changed: DNS*
Nov 18 13:27:20 Macintosh.local UserEventAgent[11]: Captive: [HandleNetworkInformationChanged:2435] nwi_state_copy returned NULL
Nov 18 13:27:20 Macintosh.local loginwindow[44]: Login Window Application Started
Nov 18 13:27:20 Macintosh.local awacsd[58]: Starting awacsd connectivity-78.3 (Apr 25 2013 19:22:44)
Nov 18 13:27:20 Macintosh.local awacsd[58]: InnerStore CopyAllZones: no info in Dynamic Store
Nov 18 13:27:20 Macintosh.local loginwindow[44]: **DMPROXY** Found `/System/Library/CoreServices/DMProxy'.
Nov 18 13:27:20 Macintosh.local com.apple.SecurityServer[15]: Succeeded authorizing right 'com.apple.ServiceManagement.daemons.modify' by client '/usr/libexec/UserEventAgent' [11] for authorization created by '/usr/libexec/UserEventAgent' [11] (100012,0)
Nov 18 13:27:20 Macintosh.local netbiosd[84]: Unable to start NetBIOS name service:
Nov 18 13:27:20 Macintosh.local digest-service[114]: label: default
Nov 18 13:27:20 Macintosh.local digest-service[114]: dbname: od:/Local/Default
Nov 18 13:27:20 Macintosh.local digest-service[114]: mkey_file: /var/db/krb5kdc/m-key
Nov 18 13:27:20 Macintosh.local digest-service[114]: acl_file: /var/db/krb5kdc/kadmind.acl
Nov 18 13:27:20 Macintosh.local digest-service[114]: digest-request: uid=0
Nov 18 13:27:20 Macintosh.local rpcsvchost[122]: sandbox_init: com.apple.msrpc.netlogon.sb succeeded
Nov 18 13:27:20 Macintosh.local sudo[120]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/kextload /System/Library/Extensions/speedit.kext
Nov 18 13:27:20 Macintosh.local digest-service[114]: digest-request: init request
Nov 18 13:27:20 Macintosh.local digest-service[114]: digest-request: init return domain: BUILTIN server: MACINTOSH
Nov 18 13:27:20 Macintosh.local com.apple.kextd[12]: Can't load /System/Library/Extensions/speedit.kext - no code for running kernel's architecture.
Nov 18 13:27:20 Macintosh.local SystemStarter[111]: SpeedIt kernel extension auto-load create for CoreDuoTemp (117) did not complete successfully
Nov 18 13:27:20 Macintosh.local SystemStarter[111]: The following StartupItems failed to start properly:
Nov 18 13:27:20 Macintosh.local SystemStarter[111]: /Library/StartupItems/CoreDuoTemp
Nov 18 13:27:20 Macintosh.local SystemStarter[111]: - execution of Startup script failed
Nov 18 13:27:21 Macintosh kernel[0]: en1: 802.11d country code set to 'IT'.
Nov 18 13:27:21 Macintosh kernel[0]: en1: Supported channels 1 2 3 4 5 6 7 8 9 10 11 12 13 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140
Nov 18 13:27:21 Macintosh kernel[0]: MacAuthEvent en1 Auth result for: 38:22:9d:35:91:68 MAC AUTH succeeded
Nov 18 13:27:21 Macintosh kernel[0]: wlEvent: en1 en1 Link UP virtIf = 0
Nov 18 13:27:21 Macintosh kernel[0]: AirPort: Link Up on en1
Nov 18 13:27:21 Macintosh kernel[0]: en1: BSSID changed to 38:22:9d:35:91:68
Nov 18 13:27:21 Macintosh kernel[0]: en1::IO80211Interface::postMessage bssid changed
Nov 18 13:27:21 Macintosh kernel[0]: AirPort: RSN handshake complete on en1
Nov 18 13:27:22 Macintosh.local locationd[45]: Incorrect NSStringEncoding value 0x8000100 detected. Assuming NSASCIIStringEncoding. Will stop this compatiblity mapping behavior in the near future.
Nov 18 13:27:26 Macintosh.local locationd[45]: NOTICE,Location icon should now be in state 0
Nov 18 13:27:29 Macintosh.local configd[18]: network changed: v4(en1+:192.168.1.142) DNS+ Proxy+ SMB
Nov 18 13:27:29 Macintosh.local UserEventAgent[11]: Captive: en1: Not probing 'Alice-65172985' (protected network)
Nov 18 13:27:29 Macintosh.local configd[18]: network changed: v4(en1!:192.168.1.142) DNS Proxy SMB
Nov 18 13:27:30 Macintosh.local ntpd[110]: proto: precision = 1.000 usec
Nov 18 13:27:31 Macintosh.local WindowServer[83]: Created shield window 0x7 for display 0x042728c0
Nov 18 13:27:31 Macintosh.local WindowServer[83]: Display 0x042728c0: MappedDisplay Unit 0; ColorProfile { 2, "Color LCD"}; TransferTable (256, 3)
Nov 18 13:27:31 Macintosh.local launchctl[129]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
Nov 18 13:27:31 Macintosh.local launchctl[129]: com.apple.findmymacmessenger: Already loaded
Nov 18 13:27:31 Macintosh.local launchctl[129]: com.apple.store_helper: Already loaded
Nov 18 13:27:31 Macintosh.local launchctl[129]: com.apple.storeagent: Already loaded
Nov 18 13:27:31 Macintosh.local com.apple.SecurityServer[15]: Session 100004 created
Nov 18 13:27:32 Macintosh.local hidd[48]: CGSShutdownServerConnections: Detaching application from window server
Nov 18 13:27:32 Macintosh.local hidd[48]: CGSDisplayServerShutdown: Detaching display subsystem from window server
Nov 18 13:27:32 Macintosh.local loginwindow[44]: Login Window Started Security Agent
Nov 18 13:27:32 Macintosh.local airportd[82]: _doAutoJoin: Already associated to “Alice-65172985”. Bailing on auto-join.
Nov 18 13:28:06 --- last message repeated 3 times ---
Nov 18 13:27:32 Macintosh.local UserEventAgent[130]: cannot find useragent 1102
Nov 18 13:27:32 Macintosh.local SecurityAgent[137]: This is the first run
Nov 18 13:27:32 Macintosh.local SecurityAgent[137]: MacBuddy was run = 0
Nov 18 13:27:32 Macintosh.local launchctl[141]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
Nov 18 13:27:33 Macintosh.local WindowServer[83]: Received display connect changed for display 0x42728c0
Nov 18 13:27:33 Macintosh.local WindowServer[83]: Received display connect changed for display 0x3f003d
Nov 18 13:27:33 Macintosh.local WindowServer[83]: CGXMuxAcknowledge: Posting glitchless acknowledge
Nov 18 13:27:33 Macintosh.local SecurityAgent[137]: *** WARNING: -[NSImage compositeToPoint:operation:fraction:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
Nov 18 13:27:33 Macintosh.local SecurityAgent[137]: *** WARNING: -[NSImage compositeToPoint:fromRect:operation:fraction:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
Nov 18 13:27:33 Macintosh.local SecurityAgent[137]: *** WARNING: -[NSImage compositeToPoint:operation:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
Nov 18 13:27:33 Macintosh.local SecurityAgent[137]: *** WARNING: -[NSImage compositeToPoint:fromRect:operation:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
Nov 18 13:27:33 Macintosh.local WindowServer[83]: Display 0x042728c0: MappedDisplay Unit 0; ColorProfile { 2, "Color LCD"}; TransferTable (256, 3)
Nov 18 13:28:08 --- last message repeated 1 time ---
Nov 18 13:27:33 Macintosh.local XProtectUpdater[26]: Ignoring new signature plist: Not an increase in version
Nov 18 13:27:33 Macintosh com.apple.launchd[1] (com.apple.xprotectupdater[26]): Exited with code: 252
Nov 18 13:27:35 Macintosh.local awacsd[58]: Exiting
Nov 18 13:27:36 Macintosh.local timezoned[146]: bootstrap_look_up failed (44e)
Nov 18 13:27:36 Macintosh.local locationd[147]: Incorrect NSStringEncoding value 0x8000100 detected. Assuming NSASCIIStringEncoding. Will stop this compatiblity mapping behavior in the near future.
Nov 18 13:27:36 Macintosh.local locationd[147]: NOTICE,Location icon should now be in state 0
Nov 18 13:27:38 Macintosh.local timezoned[146]: bootstrap_look_up failed (44e)
Nov 18 13:27:39 Macintosh.local SecurityAgent[137]: User info context values set for refraction - backup 15.12.13
Nov 18 13:27:39 Macintosh.local authorizationhost[148]: in pam_sm_authenticate(): Got user: refraction - backup 15.12.13
Nov 18 13:27:39 Macintosh.local authorizationhost[148]: in pam_sm_authenticate(): Got ruser: (null)
Nov 18 13:27:39 Macintosh.local authorizationhost[148]: in pam_sm_authenticate(): Got service: authorization
Nov 18 13:27:39 Macintosh.local authorizationhost[148]: in od_principal_for_user(): No authentication authority returned
Nov 18 13:27:39 Macintosh.local authorizationhost[148]: in od_principal_for_user(): failed: 7
Nov 18 13:27:39 Macintosh.local authorizationhost[148]: in pam_sm_authenticate(): Failed to determine Kerberos principal name.
Nov 18 13:27:39 Macintosh.local authorizationhost[148]: in pam_sm_authenticate(): Done cleanup3
Nov 18 13:27:39 Macintosh.local authorizationhost[148]: in pam_sm_authenticate(): Kerberos 5 refuses you
Nov 18 13:27:39 Macintosh.local authorizationhost[148]: in pam_sm_authenticate(): pam_sm_authenticate: ntlm
Nov 18 13:27:39 Macintosh.local authorizationhost[148]: in pam_sm_acct_mgmt(): OpenDirectory - Membership cache TTL set to 1800.
Nov 18 13:27:39 Macintosh.local authorizationhost[148]: in od_record_check_pwpolicy(): retval: 0
Nov 18 13:27:39 Macintosh.local authorizationhost[148]: in od_record_attribute_create_cfstring(): returned 2 attributes for dsAttrTypeStandard:AuthenticationAuthority
Nov 18 13:27:39 Macintosh.local authorizationhost[148]: in pam_sm_setcred(): Establishing credentials
Nov 18 13:27:39 Macintosh.local authorizationhost[148]: in pam_sm_setcred(): Got user: refraction - backup 15.12.13
Nov 18 13:27:39 Macintosh.local authorizationhost[148]: in pam_sm_setcred(): Context initialised
Nov 18 13:27:39 Macintosh.local authorizationhost[148]: in pam_sm_setcred(): Got euid, egid: 0 0
Nov 18 13:27:39 Macintosh.local authorizationhost[148]: in pam_sm_setcred(): Done getpwnam()
Nov 18 13:27:39 Macintosh.local authorizationhost[148]: in pam_sm_setcred(): Done setegid() & seteuid()
Nov 18 13:27:39 Macintosh.local authorizationhost[148]: in pam_sm_setcred(): pam_sm_setcred: krb5 user refraction - backup 15.12.13 doesn't have a principal
Nov 18 13:27:39 Macintosh.local authorizationhost[148]: in pam_sm_setcred(): Done cleanup3
Nov 18 13:27:39 Macintosh.local authorizationhost[148]: in pam_sm_setcred(): Done seteuid() & setegid()
Nov 18 13:27:39 Macintosh.local authorizationhost[148]: in pam_sm_setcred(): Done cleanup4
Nov 18 13:27:39 Macintosh.local authorizationhost[148]: in pam_sm_setcred(): pam_sm_setcred: ntlm
Nov 18 13:27:39 Macintosh.local authorizationhost[148]: in pam_sm_setcred(): pam_sm_setcred: no domain found skipping
Nov 18 13:27:39 Macintosh.local SecurityAgent[137]: Login Window login proceeding
Nov 18 13:27:40 Macintosh.local com.apple.SecurityServer[15]: Succeeded authorizing right 'system.login.console' by client '/System/Library/CoreServices/loginwindow.app' [44] for authorization created by '/System/Library/CoreServices/loginwindow.app' [44] (100003,0)
Nov 18 13:27:40 Macintosh.local loginwindow[44]: Login Window - Returned from Security Agent
Nov 18 13:27:40 Macintosh.local loginwindow[44]: ERROR | ScreensharingLoginNotification | Failed sending message to screen sharing GetScreensharingPort, err: 1102
Nov 18 13:27:40 Macintosh.local loginwindow[44]: USER_PROCESS: 44 console
Nov 18 13:27:40 Macintosh.local airportd[82]: _doAutoJoin: Already associated to “Alice-65172985”. Bailing on auto-join.
Nov 18 13:27:40 Macintosh.local launchctl[150]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
Nov 18 13:27:40 Macintosh.local launchctl[151]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
Nov 18 13:27:40 Macintosh com.apple.launchd.peruser.502[149] (com.spotify.webhelper): Unknown key: SpotifyPath
Nov 18 13:27:40 Macintosh com.apple.launchd.peruser.502[149] (com.apple.gamed): Ignored this key: UserName
Nov 18 13:27:40 Macintosh com.apple.launchd.peruser.502[149] (com.apple.gamed): Ignored this key: GroupName
Nov 18 13:27:40 Macintosh com.apple.launchd.peruser.502[149] (com.apple.ReportCrash): Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
Nov 18 13:27:40 Macintosh.local loginwindow[44]: Connection with distnoted server was invalidated
Nov 18 13:27:40 Macintosh.local distnoted[153]: # distnote server agent absolute time: 62.065607433 civil time: Tue Nov 18 13:27:40 2014 pid: 153 uid: 502 root: no
Nov 18 13:27:40 Macintosh.local WindowServer[83]: Received display connect changed for display 0x42728c0
Nov 18 13:27:40 Macintosh.local WindowServer[83]: CGXMuxAcknowledge: Posting glitchless acknowledge
Nov 18 13:27:40 Macintosh.local com.apple.SecurityServer[15]: Succeeded authorizing right 'system.login.done' by client '/System/Library/CoreServices/loginwindow.app' [44] for authorization created by '/System/Library/CoreServices/loginwindow.app' [44] (100002,0)
Nov 18 13:27:40 Macintosh.local WindowServer[83]: Received display connect changed for display 0x3f003d
Nov 18 13:27:40 Macintosh.local WindowServer[83]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'.
Nov 18 13:27:40 Macintosh.local coreaudiod[169]: Enabled automatic stack shots because audio IO is inactive
Nov 18 13:27:41 Macintosh.local coreaudiod[169]: Error loading /Library/Audio/Plug-Ins/HAL/Digidesign CoreAudio.plugin/Contents/MacOS/Digidesign CoreAudio: dlopen(/Library/Audio/Plug-Ins/HAL/Digidesign CoreAudio.plugin/Contents/MacOS/Digidesign CoreAudio, 262): no suitable image found. Did find:
/Library/Audio/Plug-Ins/HAL/Digidesign CoreAudio.plugin/Contents/MacOS/Digidesign CoreAudio: no matching architecture in universal wrapper
Nov 18 13:27:41 Macintosh.local coreaudiod[169]: Cannot find function pointer NewDigiCoreAudioPlugIn for factory B8A063B5-2F3D-444A-88CB-D0B8F1B22042 in CFBundle/CFPlugIn 0x7f86c3031c50 </Library/Audio/Plug-Ins/HAL/Digidesign CoreAudio.plugin> (bundle, not loaded)
Nov 18 13:27:41 Macintosh.local com.apple.SecurityServer[15]: Succeeded authorizing right 'system.services.systemconfiguration.network' by client '/usr/libexec/UserEventAgent' [152] for authorization created by '/usr/libexec/UserEventAgent' [152] (100000,0)
Nov 18 13:28:16 --- last message repeated 1 time ---
Nov 18 13:27:41 Macintosh.local UserEventAgent[152]: cannot find fw daemon port 1102
Nov 18 13:27:42 Macintosh.local loginwindow[44]: Error loading /Library/Audio/Plug-Ins/HAL/Digidesign CoreAudio.plugin/Contents/MacOS/Digidesign CoreAudio: dlopen(/Library/Audio/Plug-Ins/HAL/Digidesign CoreAudio.plugin/Contents/MacOS/Digidesign CoreAudio, 262): no suitable image found. Did find:
Nov 18 13:27:42 Macintosh.local loginwindow[44]: Cannot find function pointer NewDigiCoreAudioPlugIn for factory B8A063B5-2F3D-444A-88CB-D0B8F1B22042 in CFBundle/CFPlugIn 0x7ff620c97220 </Library/Audio/Plug-Ins/HAL/Digidesign CoreAudio.plugin> (bundle, not loaded)
Nov 18 13:27:42 Macintosh.local com.apple.SecurityServer[15]: Session 100007 created
Nov 18 13:27:43 Macintosh.local Little Snitch Agent[162]: Little Snitch Agent version 3894 started.
Nov 18 13:27:43 Macintosh com.apple.launchd.peruser.502[149] (com.apple.afpstat-qfa[193]): Job failed to exec(3). Setting up event to tell us when to try again: 2: No such file or directory
Nov 18 13:27:43 Macintosh com.apple.launchd.peruser.502[149] (com.apple.afpstat-qfa[193]): Job failed to exec(3) for weird reason: 2
Nov 18 13:27:43 Macintosh.local NetworkBrowserAgent[201]: Starting NetworkBrowserAgent
Nov 18 13:27:44 Macintosh com.apple.launchd.peruser.502[149] (com.apple.mrt.uiagent[183]): Exited with code: 255
Nov 18 13:27:44 Macintosh.local WindowServer[83]: Display 0x042728c0: MappedDisplay Unit 0; ColorProfile { 2, "Color LCD"}; TransferTable (256, 3)
Nov 18 13:27:45 Macintosh.local MIDIServer[208]: MIDIServer [208] starting; arch=x86_64
Nov 18 13:27:47 Macintosh.local MIDIServer[208]: PlugIn NIUSBMaschineControllerMIDIDriver.plugin -- file://localhost/Library/Audio/MIDI%20Drivers/ does not contain a supported architecture.
Nov 18 13:27:47 Macintosh.local MIDIServer[208]: MIDIServer relaunching because a 32-bit driver was found
Nov 18 13:27:47 Macintosh.local MIDIServer[208]: MIDIServer [208] starting; arch=i386
Nov 18 13:27:48 Macintosh.local com.apple.time[152]: Interval maximum value is 946100000 seconds (specified value: 9223372036854775807).
Nov 18 13:27:48 Macintosh.local WindowServer[83]: CGXDisableUpdate: UI updates were forcibly disabled by application "SystemUIServer" for over 1.00 seconds. Server has re-enabled them.
Nov 18 13:27:49 Macintosh.local WindowServer[83]: reenable_update_for_connection: UI updates were finally reenabled by application "SystemUIServer" after 2.09 seconds (server forcibly re-enabled them after 1.00 seconds)
Nov 18 13:27:50 Macintosh.local ReceiptInstaller[213]: Connection with distnoted server was invalidated
Nov 18 13:27:50 Macintosh.local SystemUIServer[167]: *** WARNING: -[NSImage compositeToPoint:operation:fraction:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
Nov 18 13:27:50 Macintosh.local SystemUIServer[167]: *** WARNING: -[NSImage compositeToPoint:fromRect:operation:fraction:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
Nov 18 13:27:50 Macintosh.local AGProtocolService[62]: Waves SG Protocol Service: Could not Start Kernel Driver Streaming!
Nov 18 13:27:50 Macintosh.local SystemUIServer[167]: Error loading /Library/Audio/Plug-Ins/HAL/Digidesign CoreAudio.plugin/Contents/MacOS/Digidesign CoreAudio: dlopen(/Library/Audio/Plug-Ins/HAL/Digidesign CoreAudio.plugin/Contents/MacOS/Digidesign CoreAudio, 262): no suitable image found. Did find:
Nov 18 13:27:50 Macintosh.local SystemUIServer[167]: Cannot find function pointer NewDigiCoreAudioPlugIn for factory B8A063B5-2F3D-444A-88CB-D0B8F1B22042 in CFBundle/CFPlugIn 0x7ffd918351f0 </Library/Audio/Plug-Ins/HAL/Digidesign CoreAudio.plugin> (bundle, not loaded)
Nov 18 13:27:53 Macintosh.local Dropbox[209]: objc[209]: Object 0x5a3100 of class OC_PythonString autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
Nov 18 13:27:53 Macintosh.local Dropbox[209]: objc[209]: Object 0x193ab0 of class __NSCFData autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
Nov 18 13:27:56 Macintosh.local com.apple.time[152]: Interval maximum value is 946100000 seconds (specified value: 9223372036854775807).
Nov 18 13:28:00 Macintosh com.apple.launchd[1] (com.apple.coreservices.appleid.authentication[134]): Exit timeout elapsed (20 seconds). Killing
Nov 18 13:28:02 Macintosh.local Dropbox[209]: objc[209]: Object 0x5a3b6b0 of class OC_PythonString autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
Nov 18 13:28:13 Macintosh.local Dropbox[209]: objc[209]: Object 0x5c9a460 of class __NSCFData autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
Nov 18 13:28:14 Macintosh.local WindowServer[83]: CGXDisableUpdate: UI updates were forcibly disabled by application "Dropbox" for over 1.00 seconds. Server has re-enabled them.
Nov 18 13:28:16 Macintosh.local WindowServer[83]: reenable_update_for_connection: UI updates were finally reenabled by application "Dropbox" after 2.91 seconds (server forcibly re-enabled them after 1.00 seconds)
Nov 18 13:28:17 Macintosh.local Dropbox[209]: objc[209]: Object 0x5ca6f80 of class OC_PythonString autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
Nov 18 13:28:17 Macintosh.local Dropbox[209]: objc[209]: Object 0x5c9a4f0 of class __NSCFData autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
Nov 18 13:28:18 Macintosh.local Dropbox[209]: PyObjCPointer created: at 0x889fca0 of type {OpaqueJSContext=}
Nov 18 13:28:18 Macintosh kernel[0]: fsevents: watcher dbfseventsd (pid: 227) - Using /dev/fsevents directly is unsupported. Migrate to FSEventsFramework
Nov 18 13:28:18 Macintosh.local Dropbox[209]: objc[209]: Object 0x5ab6290 of class OC_PythonString autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
Nov 18 13:28:18 Macintosh.local Dropbox[209]: objc[209]: Object 0x5cd4430 of class __NSCFData autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
Nov 18 13:28:24 Macintosh.local Dropbox[209]: objc[209]: Object 0x30ee10 of class OC_PythonString autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
Nov 18 13:28:24 Macintosh.local Dropbox[209]: objc[209]: Object 0x5c55d30 of class __NSCFData autoreleased with no pool in place - just leaking - break on objc_autoreleaseNoPool() to debug
Nov 18 13:29:24 Macintosh.local launchctl[238]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
Nov 18 13:29:24 Macintosh.local distnoted[240]: # distnote server agent absolute time: 166.168598778 civil time: Tue Nov 18 13:29:24 2014 pid: 240 uid: 89 root: no
Nov 18 13:30:14 Macintosh.local com.apple.SecurityServer[15]: Session 100006 created
Nov 18 13:31:13 Macintosh com.apple.launchd.peruser.502[149] (com.macpaw.CleanMyMac.volumeWatcher[253]): Job failed to exec(3). Setting up event to tell us when to try again: 2: No such file or directory
Nov 18 13:31:13 Macintosh com.apple.launchd.peruser.502[149] (com.macpaw.CleanMyMac.volumeWatcher[253]): Job failed to exec(3) for weird reason: 2
Nov 18 13:47:55 Macintosh kernel[0]: MacAuthEvent en1 Auth result for: 38:22:9d:35:91:68 MAC AUTH succeeded
Nov 18 13:47:55 Macintosh kernel[0]: wlEvent: en1 en1 Link UP virtIf = 0
Nov 18 13:47:55 Macintosh kernel[0]: AirPort: RSN handshake complete on en1
Nov 18 13:47:55 Macintosh kernel[0]: wl0: Roamed or switched channel, reason #8, bssid 38:22:9d:35:91:68
Nov 18 13:47:55 Macintosh kernel[0]: en1: BSSID changed to 38:22:9d:35:91:68
Nov 18 13:47:55 Macintosh kernel[0]: en1::IO80211Interface::postMessage bssid changed
Nov 18 13:49:40 Macintosh kernel[0]: MacAuthEvent en1 Auth result for: 38:22:9d:35:91:68 MAC AUTH succeeded
Nov 18 13:49:40 Macintosh kernel[0]: wlEvent: en1 en1 Link UP virtIf = 0
Nov 18 13:49:40 Macintosh kernel[0]: AirPort: RSN handshake complete on en1
Nov 18 13:49:40 Macintosh kernel[0]: wl0: Roamed or switched channel, reason #8, bssid 38:22:9d:35:91:68
Nov 18 13:49:40 Macintosh kernel[0]: en1: BSSID changed to 38:22:9d:35:91:68
Nov 18 13:49:40 Macintosh kernel[0]: en1::IO80211Interface::postMessage bssid changed
Nov 18 13:50:00 Macintosh kernel[0]: MacAuthEvent en1 Auth result for: 38:22:9d:35:91:68 MAC AUTH succeeded
Nov 18 13:50:00 Macintosh kernel[0]: wlEvent: en1 en1 Link UP virtIf = 0
Nov 18 13:50:00 Macintosh kernel[0]: AirPort: RSN handshake complete on en1
Nov 18 13:50:00 Macintosh kernel[0]: wl0: Roamed or switched channel, reason #8, bssid 38:22:9d:35:91:68
Nov 18 13:50:00 Macintosh kernel[0]: en1: BSSID changed to 38:22:9d:35:91:68
Nov 18 13:50:00 Macintosh kernel[0]: en1::IO80211Interface::postMessage bssid changed
Nov 18 13:52:42 Macintosh kernel[0]: firefox (map: 0xffffff80201f5de8) triggered DYLD shared region unnest for map: 0xffffff80201f5de8, region 0x7fff95400000->0x7fff95600000. While not abnormal for debuggers, this increases system memory footprint until the target exits.
Nov 18 13:52:51 Macintosh.local librariand[272]: MMe quota status changed: under quota
Nov 18 13:52:54 Macintosh kernel[0]: Sandbox: sandboxd(278) deny mach-lookup com.apple.coresymbolicationd
Nov 18 13:52:54 Macintosh.local sandboxd[278] ([264]): mdworker(264) deny file-read-xattr /Users/refraction - backup 15.12.13/Library/Application Support/Firefox/Profiles/2vw412zr.default/prefs.js (pre-plugin fstype:hfs fsflag:480D000 flags:240000005E diag:0 uti:com.netscape.javascript-source plugin:/Library/Spotlight/RichText.mdimporter - find suspect file using: sudo mdutil -t 6428691)
Nov 18 13:53:06 Macintosh.local mdwrite[283]: [ERROR] [0.000s] com.apple. UBItemStatusNotification.c:805 _do_UBItemStatusNotificationRegisterURLs() can't find realpath for "/Users/refraction - backup 15.12.13/Library/Mobile Documents/com~apple~system~spotlight/mdlabels", was blocked at "/Users/refraction - backup 15.12.13/Library/Mobile Documents": 2 (No such file or directory)
Nov 18 13:53:06 Macintosh.local mdwrite[283]: [ERROR] [0.001s] com.apple. UBItemStatusNotification.c:805 _do_UBItemStatusNotificationRegisterURLs() can't find realpath for "/Users/refraction - backup 15.12.13/Library/Mobile Documents/com~apple~system~spotlight/mdlabels", was blocked at "/Users/refraction - backup 15.12.13/Library/Mobile Documents": 2 (No such file or directory)
Nov 18 13:53:28 Macintosh.local SIMBL Agent[194]: warning: failed to get scripting definition from /Applications/Utilities/Console.app; it may not be scriptable.
Visitano il forum: Apple [Bot] e 48 ospiti
