Allora... : ieri ho ripristinato il risparmio energetico.
Tutto bene fino alle sera dove un attimo prima di chiudere final pro x e spegnere il computer si e' riverificato il problema,spegnendosi completamente la macchina.
Questo e' quello che e' successo qualche secondo prima:
09/10/14 19:02:56,229 Final Cut Pro[319]: An instance 0x7fe04bc1af60 of class FFAnchoredCollection was deallocated while key value observers were still registered with it. Observation info was leaked, and may even become mistakenly attached to some other object. Set a breakpoint on NSKVODeallocateBreak to stop here in the debugger. Here's the current observation info:
<NSKeyValueObservationInfo 0x60001f44d1d0> (
<NSKeyValueObservance 0x6180030dae80: Observer: 0x60800014dec0, Key path: activeVariant, Options: <New: NO, Old: NO, Prior: NO> Context: 0x608000641260, Property: 0x6180004438d0>
09/10/14 19:02:59,248 Final Cut Pro[319]: An instance 0x7fe035b3ee50 of class FFAnchoredCollection was deallocated while key value observers were still registered with it. Observation info was leaked, and may even become mistakenly attached to some other object. Set a breakpoint on NSKVODeallocateBreak to stop here in the debugger. Here's the current observation info:
09/10/14 19:03:52,683 Final Cut Pro[319]: An instance 0x7fe021718f10 of class FFAnchoredCollection was deallocated while key value observers were still registered with it. Observation info was leaked, and may even become mistakenly attached to some other object. Set a breakpoint on NSKVODeallocateBreak to stop here in the debugger. Here's the current observation info:
<NSKeyValueObservationInfo 0x60001fc52ed0> (
09/10/14 19:04:03,312 Final Cut Pro[319]: CoreAnimation: warning, deleted thread with uncommitted CATransaction; set CA_DEBUG_TRANSACTIONS=1 in environment to log backtraces.
09/10/14 19:04:03,710 Final Cut Pro[319]: CoreAnimation: warning, deleted thread with uncommitted CATransaction; set CA_DEBUG_TRANSACTIONS=1 in environment to log backtraces.
09/10/14 19:04:05,673 Final Cut Pro[319]: An instance 0x7fe027b29dc0 of class FFAnchoredCollection was deallocated while key value observers were still registered with it. Observation info was leaked, and may even become mistakenly attached to some other object. Set a breakpoint on NSKVODeallocateBreak to stop here in the debugger. Here's the current observation info:
09/10/14 19:04:06,260 Final Cut Pro[319]: CoreAnimation: warning, deleted thread with uncommitted CATransaction; set CA_DEBUG_TRANSACTIONS=1 in environment to log backtraces.
09/10/14 19:04:19,484 Final Cut Pro[319]: *** OpenGL error 0x0506 (invalid framebuffer operation) in function "GL_CHECK_CURRENT_ERROR"
09/10/14 19:04:27,882 Final Cut Pro[319]: An instance 0x7fe027c0ab60 of class FFAnchoredCollection was deallocated while key value observers were still registered with it. Observation info was leaked, and may even become mistakenly attached to some other object. Set a breakpoint on NSKVODeallocateBreak to stop here in the debugger. Here's the current observation info:
09/10/14 19:04:29,780 Final Cut Pro[319]: CoreAnimation: warning, deleted thread with uncommitted CATransaction; set CA_DEBUG_TRANSACTIONS=1 in environment to log backtraces.
09/10/14 19:04:29,781 Final Cut Pro[319]: CoreAnimation: warning, deleted thread with uncommitted CATransaction; set CA_DEBUG_TRANSACTIONS=1 in environment to log backtraces.
09/10/14 19:04:29,783 Final Cut Pro[319]: CoreAnimation: warning, deleted thread with uncommitted CATransaction; set CA_DEBUG_TRANSACTIONS=1 in environment to log backtraces.
09/10/14 19:04:34,566 Final Cut Pro[319]: CoreAnimation: warning, deleted thread with uncommitted CATransaction; set CA_DEBUG_TRANSACTIONS=1 in environment to log backtraces.
09/10/14 19:04:47,249 Final Cut Pro[319]: An instance 0x7fe02b2f69c0 of class FFAnchoredCollection was deallocated while key value observers were still registered with it. Observation info was leaked, and may even become mistakenly attached to some other object. Set a breakpoint on NSKVODeallocateBreak to stop here in the debugger. Here's the current observation info:
09/10/14 19:05:00,207 Final Cut Pro[319]: An instance 0x7fe02b2ea7e0 of class FFAnchoredCollection was deallocated while key value observers were still registered with it. Observation info was leaked, and may even become mistakenly attached to some other object. Set a breakpoint on NSKVODeallocateBreak to stop here in the debugger. Here's the current observation info:
09/10/14 19:05:01,638 Final Cut Pro[319]: An instance 0x7fe027c4f180 of class FFAnchoredCollection was deallocated while key value observers were still registered with it. Observation info was leaked, and may even become mistakenly attached to some other object. Set a breakpoint on NSKVODeallocateBreak to stop here in the debugger. Here's the current observation info:
09/10/14 19:05:04,302 Final Cut Pro[319]: *** OpenGL error 0x0506 (invalid framebuffer operation) in function "GL_CHECK_CURRENT_ERROR"
Questi problemi mi succedono solo e sopratutto durante il rendering di Final cut pro x.
Io sono andato bene finche' ho aggiunto un paio di giorni fa gli ultimi effetti di FxFactory . Non so' se e' una coincidenza o meno.
