Simone.m ha scritto:Puoi postare un log del sistema al momento del tentato spegnimento?
La versione de OS è la 10.9.2
Questo è quello che da il log da quando spengo fino a quando mi riloggo:
Apr 29 15:39:28 MacBook-de-Luca com.apple.launchd.peruser.501[151] (com.apple.PackageKit.InstallStatus): Throttling respawn: Will start in 8 seconds
Apr 29 15:39:29 MacBook-de-Luca com.apple.launchd.peruser.501[151] ([0x0-0x48048].com.apple.Console[600]): Exited: Killed: 9
Apr 29 15:39:29 MacBook-de-Luca.local WindowServer[555]: CGXGetConnectionProperty: Invalid connection 52739
Apr 29 15:39:29 --- last message repeated 4 times ---
Apr 29 15:39:29 MacBook-de-Luca com.apple.launchd[1] (com.apple.internetaccounts[629]): Exited: Killed: 9
Apr 29 15:39:29 MacBook-de-Luca com.apple.launchd[1] (com.apple.ShareKitHelper[624]): Exited: Killed: 9
Apr 29 15:39:29 MacBook-de-Luca com.apple.launchd.peruser.501[151] (com.apple.systemevents.27312[663]): Exited: Killed: 9
Apr 29 15:39:29 MacBook-de-Luca com.apple.launchd[1] (com.apple.ShareKitHelper[592]): Exited: Killed: 9
Apr 29 15:39:29 MacBook-de-Luca com.apple.launchd.peruser.501[151] (com.apple.gamed[660]): Exited: Killed: 9
Apr 29 15:39:29 MacBook-de-Luca com.apple.launchd.peruser.501[151] (com.Logitech.Control Center.Daemon[651]): Job appears to have crashed: Segmentation fault: 11
Apr 29 15:39:29 MacBook-de-Luca.local ReportCrash[679]: Saved crash report for LCCDaemon[651] version 3.9.0 (3.9.0) to /Users/Luca/Library/Logs/DiagnosticReports/LCCDaemon_2014-04-29-153929_MacBook-de-Luca.crash
Apr 29 15:39:39 MacBook-de-Luca.local loginwindow[554]: ERROR | -[ApplicationManager quitPrivateProcesses] | Private process did not quit
Apr 29 15:39:39 MacBook-de-Luca.local sessionlogoutd[681]: sessionlogoutd Launched
Apr 29 15:39:39 MacBook-de-Luca.local sessionlogoutd[681]: DEAD_PROCESS: 554 console
Apr 29 15:39:39 MacBook-de-Luca.local sessionlogoutd[681]: WriteDictionaryToFileURL:90: ERROR: CFURLWriteDataAndPropertiesToResource failed with errorCode: -10
Apr 29 15:39:39 --- last message repeated 1 time ---
Apr 29 15:39:39 MacBook-de-Luca.local loginwindow[554]: ERROR | SLODErrorHandler | Connection to sessionlogoutd lost, exiting loginwindow
Apr 29 15:39:39 MacBook-de-Luca.local WindowServer[555]: CGXRestartSessionWorkspace: session workspace exited for session 256 (on console)
Apr 29 15:39:39 MacBook-de-Luca.local WindowServer[555]: Session 256 released (1 references)
Apr 29 15:39:39 MacBook-de-Luca.local WindowServer[555]: Session 256 released (0 references)
Apr 29 15:39:39 MacBook-de-Luca.local WindowServer[555]: loginwindow connection closed; closing server.
Apr 29 15:39:39 MacBook-de-Luca.local UserEventAgent[11]: Captive: [UserAgentDied:142] User Agent @port=81419 Died
Apr 29 15:39:39 MacBook-de-Luca.local identityservicesd[628]: Quit - notifying about shutdown
Apr 29 15:39:39 MacBook-de-Luca.local identityservicesd[628]: Quit - shutting down daemon
Apr 29 15:39:39 MacBook-de-Luca com.apple.launchd[1] (com.apple.loginwindow[554]): Exited with code: 3
Apr 29 15:39:39 MacBook-de-Luca.local imagent[627]: Quit - notifying about shutdown
Apr 29 15:39:39 MacBook-de-Luca.local imagent[627]: Quit - shutting down daemon
Apr 29 15:39:39 MacBook-de-Luca.local airportd[61]: _doAutoJoin: Already associated to “NETGEAR37”. Bailing on auto-join.
Apr 29 15:39:39 MacBook-de-Luca.local loginwindow[683]: Login Window Application Started
Apr 29 15:39:39 MacBook-de-Luca.local WindowServer[684]: Server is starting up
Apr 29 15:39:39 MacBook-de-Luca.local WindowServer[684]: Session 256 retained (2 references)
Apr 29 15:39:39 MacBook-de-Luca.local WindowServer[684]: Session 256 released (1 references)
Apr 29 15:39:39 MacBook-de-Luca.local WindowServer[684]: init_page_flip: page flip mode is on
Apr 29 15:39:39 MacBook-de-Luca.local WindowServer[684]: Found 27 modes for display 0x00000000 [24, 3]
Apr 29 15:39:39 MacBook-de-Luca.local WindowServer[684]: Found 1 modes for display 0x00000000 [1, 0]
Apr 29 15:39:39 MacBook-de-Luca.local WindowServer[684]: mux_initialize: Couldn't find any matches
Apr 29 15:39:39 MacBook-de-Luca.local WindowServer[684]: WSMachineUsesNewStyleMirroring: false
Apr 29 15:39:39 MacBook-de-Luca.local WindowServer[684]: Display 0x04273000: GL mask 0x1; bounds (0, 0)[1280 x 800], 27 modes available
Main, Active, on-line, enabled, built-in, boot, Vendor 610, Model 9cc0, S/N 0, Unit 0, Rotation 0
UUID 0xdb334f0d223658039c0666a1dc1411d5
Apr 29 15:39:39 MacBook-de-Luca.local WindowServer[684]: Display 0x003f003d: GL mask 0x2; bounds (0, 0)[0 x 0], 1 modes available
off-line, enabled, Vendor ffffffff, Model ffffffff, S/N ffffffff, Unit 1, Rotation 0
UUID 0xffffffffffffffffffffffffffffffff
Apr 29 15:39:39 MacBook-de-Luca.local WindowServer[684]: WSSetWindowTransform: Singular matrix
Apr 29 15:39:39 MacBook-de-Luca.local WindowServer[684]: Display 0x003f003d: GL mask 0x2; bounds (2304, 0)[1 x 1], 1 modes available
Apr 29 15:39:39 MacBook-de-Luca.local WindowServer[684]: CGXPerformInitialDisplayConfiguration
Apr 29 15:39:39 MacBook-de-Luca.local WindowServer[684]: Display 0x04273000: Unit 0; Vendor 0x610 Model 0x9cc0 S/N 0 Dimensions 10.28 x 6.42; online enabled built-in, Bounds (0,0)[1280 x 800], Rotation 0, Resolution 1
Apr 29 15:39:39 MacBook-de-Luca.local WindowServer[684]: Display 0x003f003d: Unit 1; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (2304,0)[1 x 1], Rotation 0, Resolution 1
Apr 29 15:39:39 MacBook-de-Luca.local WindowServer[684]: GLCompositor: GL renderer id 0x0102260e, GL mask 0x00000003, accelerator 0x00003f8b, unit 0, caps QEX|MIPMAP, vram 256 MB
Apr 29 15:39:39 MacBook-de-Luca.local WindowServer[684]: GLCompositor: GL renderer id 0x0102260e, GL mask 0x00000003, texture max 8192, viewport max {8192, 8192}, extensions FPRG|NPOT|GLSL|FLOAT
Apr 29 15:39:39 MacBook-de-Luca.local WindowServer[684]: GLCompositor enabled for tile size [256 x 256]
Apr 29 15:39:39 MacBook-de-Luca.local WindowServer[684]: CGXGLInitMipMap: mip map mode is on
Apr 29 15:39:39 MacBook-de-Luca.local loginwindow[683]: **DMPROXY** Found `/System/Library/CoreServices/DMProxy'.
Apr 29 15:39:39 MacBook-de-Luca.local WindowServer[684]: Display 0x04273000: Unit 0; ColorProfile { 2, "Color LCD"}; TransferTable (256, 12)
Apr 29 15:39:40 MacBook-de-Luca.local loginwindow[683]: USER_PROCESS: 683 console
Apr 29 15:39:40 MacBook-de-Luca.local launchctl[686]: com.apple.findmymacmessenger: Already loaded
Apr 29 15:39:40 MacBook-de-Luca.local airportd[61]: _doAutoJoin: Already associated to “NETGEAR37”. Bailing on auto-join.
Apr 29 15:39:40 MacBook-de-Luca com.apple.launchd[1]: System: Could not find requested session: Aqua
Apr 29 15:39:40 MacBook-de-Luca.local Software Update.app (0)[697]: com.apple.appstore.23616: Invalid argument
Apr 29 15:39:40 MacBook-de-Luca.local WindowServer[684]: CGXGetConnectionProperty: Invalid connection 31235
Apr 29 15:39:40 --- last message repeated 4 times ---
Apr 29 15:39:40 MacBook-de-Luca.local loginwindow[683]: DEAD_PROCESS: 683 console
Apr 29 15:39:40 MacBook-de-Luca.local com.apple.SecurityServer[25]: Session 100027 created
Apr 29 15:39:40 MacBook-de-Luca.local loginwindow[683]: Login Window Started Security Agent
Apr 29 15:39:41 MacBook-de-Luca.local SecurityAgent[700]: MacBuddy was run = 1
Apr 29 15:39:41 MacBook-de-Luca.local WindowServer[684]: _CGXGLDisplayContextForDisplayDevice: acquired display context (0x7f9cbbc33080) - enabling OpenGL
Apr 29 15:39:41 MacBook-de-Luca.local WindowServer[684]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'.
Apr 29 15:39:41 MacBook-de-Luca.local WindowServer[684]: 3891612: App App Store cannot order in untagged windows before login.
Apr 29 15:39:41 MacBook-de-Luca.local WindowServer[684]: WSOrderWinsAndPanels: error ordering window
Apr 29 15:39:42 MacBook-de-Luca.local WindowServer[684]: 3891612: App App Store cannot order in untagged windows before login.
Apr 29 15:39:42 MacBook-de-Luca.local WindowServer[684]: WSOrderWinsAndPanels: error ordering window
Apr 29 15:39:42 MacBook-de-Luca.local com.apple.SecurityServer[25]: Killing auth hosts
Apr 29 15:39:42 MacBook-de-Luca.local com.apple.SecurityServer[25]: Session 100026 destroyed
Apr 29 15:39:42 MacBook-de-Luca.local com.apple.SecurityServer[25]: Session 100028 created
Apr 29 15:39:42 MacBook-de-Luca kernel[0]: Sandbox: App Store(698) deny file-write-data /private/var/db/mds/system/mds.lock
Apr 29 15:39:42 --- last message repeated 39 times ---
Apr 29 15:39:42 MacBook-de-Luca.local UserEventAgent[690]: Failed to copy info dictionary for bundle /System/Library/UserEventPlugins/alfUIplugin.plugin
Apr 29 15:39:42 MacBook-de-Luca.local WindowServer[684]: Display 0x04273000: Unit 0; ColorProfile { 2, "Color LCD"}; TransferTable (256, 12)
Apr 29 15:39:42 --- last message repeated 59 times ---
Apr 29 15:39:42 MacBook-de-Luca.local sandboxd[483] ([698]): App Store(698) deny file-write-data /private/var/db/mds/system/mds.lock
Apr 29 15:39:42 --- last message repeated 43 times ---
Apr 29 15:39:42 --- last message repeated 7 times ---
Apr 29 15:39:42 MacBook-de-Luca.local cfprefsd[70]: CFPreferences: error renaming file /private/var/root/Library/Preferences/com.apple.storeagent.plist.LWOKILC to /private/var/root/Library/Preferences/com.apple.storeagent.plist.
Apr 29 15:39:43 MacBook-de-Luca.local sandboxd[483] ([698]): App Store(698) deny file-write-data /private/var/db/mds/system/mds.lock
Apr 29 15:39:43 --- last message repeated 2 times ---
Apr 29 15:39:43 MacBook-de-Luca kernel[0]: Sandbox: com.apple.WebKit(708) deny file-read-data /Library/Preferences/com.apple.HIToolbox.plist
Apr 29 15:39:43 MacBook-de-Luca kernel[0]: Sandbox: com.apple.WebKit(708) deny mach-lookup com.apple.tsm.uiserver
Apr 29 15:39:43 MacBook-de-Luca.local com.apple.WebKit.WebContent[711]: CKSoftwareMap: Registering with Daemon
Apr 29 15:39:43 MacBook-de-Luca kernel[0]: Sandbox: com.apple.WebKit(711) deny file-read-data /Library/Preferences/com.apple.HIToolbox.plist
Apr 29 15:39:43 MacBook-de-Luca kernel[0]: Sandbox: com.apple.WebKit(711) deny mach-lookup com.apple.tsm.uiserver
Apr 29 15:39:43 MacBook-de-Luca.local com.apple.ShareKitHelper[713]: Untrusted apps are not allowed to connect to Window Server before login.
Apr 29 15:39:43 MacBook-de-Luca.local com.apple.ShareKitHelper[713]: This user is not allowed access to the window system right now.
Apr 29 15:39:43 MacBook-de-Luca.local com.apple.ShareKitHelper[713]: _RegisterApplication(), FAILED TO establish the default connection to the WindowServer, _CGSDefaultConnection() is NULL.
Apr 29 15:39:43 MacBook-de-Luca.local com.apple.ShareKitHelper[713]: CGSConnectionByID: 0 is not a valid connection ID.
Apr 29 15:39:43 --- last message repeated 8 times ---
Apr 29 15:39:43 MacBook-de-Luca.local com.apple.ShareKitHelper[713]: Error enabling suspendResume handling
Apr 29 15:39:43 MacBook-de-Luca kernel[0]: Sandbox: com.apple.ShareK(713) deny file-write-data /private/var/db/mds/system/mds.lock
Apr 29 15:39:43 --- last message repeated 11 times ---
Apr 29 15:39:43 MacBook-de-Luca.local com.apple.ShareKitHelper[713]: --error: [ShareKit-Plugin] ShareKit plugin is not signed by Apple: AirDrop.sharingservice/ -- file:///System/Library/PrivateFrameworks/ShareKit.framework/PlugIns/
Apr 29 15:39:43 MacBook-de-Luca.local com.apple.ShareKitHelper[713]: ShareKit plugin is not signed by Apple: AirDrop.sharingservice/ -- file:///System/Library/PrivateFrameworks/ShareKit.framework/PlugIns/
Apr 29 15:39:43 MacBook-de-Luca.local com.apple.ShareKitHelper[713]: --error: [ShareKit-Plugin] ShareKit plugin is not signed by Apple: Facebook.sharingservice/ -- file:///System/Library/PrivateFrameworks/ShareKit.framework/PlugIns/
Apr 29 15:39:43 MacBook-de-Luca.local com.apple.ShareKitHelper[713]: ShareKit plugin is not signed by Apple: Facebook.sharingservice/ -- file:///System/Library/PrivateFrameworks/ShareKit.framework/PlugIns/
Apr 29 15:39:43 MacBook-de-Luca.local com.apple.ShareKitHelper[713]: --error: [ShareKit-Plugin] ShareKit plugin is not signed by Apple: LinkedIn.sharingservice/ -- file:///System/Library/PrivateFrameworks/ShareKit.framework/PlugIns/
Apr 29 15:39:43 MacBook-de-Luca.local com.apple.ShareKitHelper[713]: ShareKit plugin is not signed by Apple: LinkedIn.sharingservice/ -- file:///System/Library/PrivateFrameworks/ShareKit.framework/PlugIns/
Apr 29 15:39:43 MacBook-de-Luca.local com.apple.ShareKitHelper[713]: --error: [ShareKit-Plugin] ShareKit plugin is not signed by Apple: Mail.sharingservice/ -- file:///System/Library/PrivateFrameworks/ShareKit.framework/PlugIns/
Apr 29 15:39:43 MacBook-de-Luca.local com.apple.ShareKitHelper[713]: ShareKit plugin is not signed by Apple: Mail.sharingservice/ -- file:///System/Library/PrivateFrameworks/ShareKit.framework/PlugIns/
Apr 29 15:39:43 MacBook-de-Luca.local com.apple.ShareKitHelper[713]: --error: [ShareKit-Plugin] ShareKit plugin is not signed by Apple: Messages.sharingservice/ -- file:///System/Library/PrivateFrameworks/ShareKit.framework/PlugIns/
Apr 29 15:39:43 MacBook-de-Luca.local com.apple.ShareKitHelper[713]: ShareKit plugin is not signed by Apple: Messages.sharingservice/ -- file:///System/Library/PrivateFrameworks/ShareKit.framework/PlugIns/
Apr 29 15:39:43 --- last message repeated 7 times ---
Apr 29 15:39:43 MacBook-de-Luca.local com.apple.ShareKitHelper[713]: --error: [ShareKit-Plugin] ShareKit plugin is not signed by Apple: SinaWeibo.sharingservice/ -- file:///System/Library/PrivateFrameworks/ShareKit.framework/PlugIns/
Apr 29 15:39:43 MacBook-de-Luca.local com.apple.ShareKitHelper[713]: ShareKit plugin is not signed by Apple: SinaWeibo.sharingservice/ -- file:///System/Library/PrivateFrameworks/ShareKit.framework/PlugIns/
Apr 29 15:39:43 MacBook-de-Luca.local com.apple.ShareKitHelper[713]: --error: [ShareKit-Plugin] ShareKit plugin is not signed by Apple: System.sharingservice/ -- file:///System/Library/PrivateFrameworks/ShareKit.framework/PlugIns/
Apr 29 15:39:43 MacBook-de-Luca.local com.apple.ShareKitHelper[713]: ShareKit plugin is not signed by Apple: System.sharingservice/ -- file:///System/Library/PrivateFrameworks/ShareKit.framework/PlugIns/
Apr 29 15:39:43 MacBook-de-Luca.local com.apple.ShareKitHelper[713]: --error: [ShareKit-Plugin] ShareKit plugin is not signed by Apple: TencentWeibo.sharingservice/ -- file:///System/Library/PrivateFrameworks/ShareKit.framework/PlugIns/
Apr 29 15:39:43 MacBook-de-Luca.local com.apple.ShareKitHelper[713]: ShareKit plugin is not signed by Apple: TencentWeibo.sharingservice/ -- file:///System/Library/PrivateFrameworks/ShareKit.framework/PlugIns/
Apr 29 15:39:43 MacBook-de-Luca.local com.apple.ShareKitHelper[713]: --error: [ShareKit-Plugin] ShareKit plugin is not signed by Apple: Twitter.sharingservice/ -- file:///System/Library/PrivateFrameworks/ShareKit.framework/PlugIns/
Apr 29 15:39:43 MacBook-de-Luca.local com.apple.ShareKitHelper[713]: ShareKit plugin is not signed by Apple: Twitter.sharingservice/ -- file:///System/Library/PrivateFrameworks/ShareKit.framework/PlugIns/
Apr 29 15:39:43 MacBook-de-Luca.local com.apple.ShareKitHelper[713]: --error: [ShareKit-Plugin] ShareKit plugin is not signed by Apple: Video.sharingservice/ -- file:///System/Library/PrivateFrameworks/ShareKit.framework/PlugIns/
Apr 29 15:39:43 MacBook-de-Luca.local com.apple.ShareKitHelper[713]: ShareKit plugin is not signed by Apple: Video.sharingservice/ -- file:///System/Library/PrivateFrameworks/ShareKit.framework/PlugIns/
Apr 29 15:39:44 MacBook-de-Luca kernel[0]: **** [IOBluetoothHostControllerUSBTransport][SuspendDevice] -- Resume -- suspendDeviceCallResult = 0x0000 (kIOReturnSuccess) -- 0xac00 ****
Apr 29 15:39:44 MacBook-de-Luca kernel[0]: Sandbox: storeagent(701) deny file-write-create /private/var/root/Library/Application Support
Apr 29 15:39:44 --- last message repeated 1 time ---
Apr 29 15:39:44 MacBook-de-Luca.local softwareupdated[135]: CGError CGSGetDisplaySystemState(uint64_t, CGSDisplaySystemState **): MIG error 0x10000003: (ipc/send) invalid destination port
Apr 29 15:39:45 --- last message repeated 5 times ---
Apr 29 15:39:45 MacBook-de-Luca.local com.apple.WebKit.WebContent[710]: CKSoftwareMap: Registering with Daemon
Apr 29 15:39:45 MacBook-de-Luca.local locationd[40]: Location icon should now be in state 'Active'
Apr 29 15:39:45 MacBook-de-Luca.local com.apple.WebKit.WebContent[702]: CKSoftwareMap: Registering with Daemon
Apr 29 15:39:46 MacBook-de-Luca.local SecurityAgent[700]: User info context values set for Luca
Apr 29 15:39:46 MacBook-de-Luca.local SecurityAgent[700]: Login Window login proceeding
Apr 29 15:39:47 MacBook-de-Luca.local loginwindow[683]: Login Window - Returned from Security Agent
Apr 29 15:39:47 MacBook-de-Luca.local loginwindow[683]: USER_PROCESS: 683 console
Apr 29 15:39:47 MacBook-de-Luca.local WindowServer[684]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'.
Apr 29 15:39:47 MacBook-de-Luca.local WindowServer[684]: CGXGetConnectionProperty: Invalid connection 31003
Apr 29 15:39:47 --- last message repeated 4 times ---
Apr 29 15:39:47 MacBook-de-Luca com.apple.launchd[1] (com.apple.WebKit.WebContent.A42B583F-7436-4AC6-A28B-83165D694589[711]): Could not terminate job: 3: No such process
Apr 29 15:39:47 MacBook-de-Luca com.apple.launchd[1] (com.apple.WebKit.WebContent.A42B583F-7436-4AC6-A28B-83165D694589[711]): Using fallback option to terminate job...
Apr 29 15:39:47 MacBook-de-Luca com.apple.launchd[1] (com.apple.WebKit.WebContent.E8F02BA5-3B78-4404-ABA5-6C71F029CCD8[710]): Could not terminate job: 3: No such process
Apr 29 15:39:47 MacBook-de-Luca com.apple.launchd[1] (com.apple.WebKit.WebContent.E8F02BA5-3B78-4404-ABA5-6C71F029CCD8[710]): Using fallback option to terminate job...
Apr 29 15:39:47 MacBook-de-Luca com.apple.launchd[1] (com.apple.WebKit.WebContent.B6584A04-C1D1-4167-B881-3E367CCC0001[708]): Could not terminate job: 3: No such process
Apr 29 15:39:47 MacBook-de-Luca com.apple.launchd[1] (com.apple.WebKit.WebContent.B6584A04-C1D1-4167-B881-3E367CCC0001[708]): Using fallback option to terminate job...
Apr 29 15:39:47 MacBook-de-Luca com.apple.launchd[1] (com.apple.WebKit.WebContent.E86C18B5-AAB1-4404-9DB9-AD321607286A[707]): Could not terminate job: 3: No such process
Apr 29 15:39:47 MacBook-de-Luca com.apple.launchd[1] (com.apple.WebKit.WebContent.E86C18B5-AAB1-4404-9DB9-AD321607286A[707]): Using fallback option to terminate job...
Apr 29 15:39:47 MacBook-de-Luca com.apple.launchd[1] (com.apple.WebKit.WebContent.03D9E1CA-F572-456B-B45D-B0C403DC5E1C[702]): Could not terminate job: 3: No such process
Apr 29 15:39:47 MacBook-de-Luca com.apple.launchd[1] (com.apple.WebKit.WebContent.03D9E1CA-F572-456B-B45D-B0C403DC5E1C[702]): Using fallback option to terminate job...
Apr 29 15:39:47 MacBook-de-Luca com.apple.launchd.peruser.501[151]: Background: Aqua: Registering new GUI session.
Apr 29 15:39:47 MacBook-de-Luca com.apple.launchd.peruser.501[151] (0x7f8bb0421ca0.anonymous.com.apple.WebKi[710]): Failed to add kevent for PID 710. Will unload at MIG return
Apr 29 15:39:47 MacBook-de-Luca com.apple.launchd.peruser.501[151] (0x7f8bb0422030.anonymous.com.apple.WebKi[707]): Failed to add kevent for PID 707. Will unload at MIG return
Apr 29 15:39:47 MacBook-de-Luca com.apple.launchd.peruser.501[151] (0x7f8bb040c270.anonymous.com.apple.WebKi[711]): Failed to add kevent for PID 711. Will unload at MIG return
Apr 29 15:39:47 MacBook-de-Luca com.apple.launchd.peruser.501[151] (0x7f8bb040c600.anonymous.com.apple.WebKi[708]): Failed to add kevent for PID 708. Will unload at MIG return
Apr 29 15:39:47 MacBook-de-Luca com.apple.launchd.peruser.501[151] (0x7f8bb040c990.anonymous.com.apple.WebKi[702]): Failed to add kevent for PID 702. Will unload at MIG return
Apr 29 15:39:47 MacBook-de-Luca com.apple.launchd[1] (com.apple.WebKit.WebContent.A42B583F-7436-4AC6-A28B-83165D694589[711]): XPC Service could not exec(3). Resetting port.
Apr 29 15:39:47 MacBook-de-Luca.local airportd[61]: _doAutoJoin: Already associated to “NETGEAR37”. Bailing on auto-join.
Apr 29 15:39:47 MacBook-de-Luca com.apple.launchd.peruser.501[151] (com.apple.EscrowSecurityAlert): Unknown key: seatbelt-profiles
Apr 29 15:39:47 MacBook-de-Luca com.apple.launchd.peruser.501[151] (com.apple.ReportCrash): Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
Apr 29 15:39:47 MacBook-de-Luca.local launchctl[719]: com.apple.pluginkit.pkd: Already loaded
Apr 29 15:39:47 MacBook-de-Luca.local launchctl[719]: com.apple.sbd: Already loaded
Apr 29 15:39:47 MacBook-de-Luca.local loginwindow[683]: ERROR | processNotificationManagerLSNotificationCallBack | LWCASProcessNotificationManager UNEXPECTED NOTIFICATION of type: kLSNotifyBecameFrontmost
Apr 29 15:39:48 --- last message repeated 1 time ---
Apr 29 15:39:48 MacBook-de-Luca.local WindowServer[684]: Display 0x04273000: Unit 0; ColorProfile { 2, "Color LCD"}; TransferTable (256, 12)
Apr 29 15:39:48 MacBook-de-Luca com.apple.launchd[1] (com.apple.storeagent[701]): Exit timeout elapsed (1 seconds). Killing
Apr 29 15:39:49 MacBook-de-Luca.local SystemUIServer[727]: Could not load menu extra NSBundle </System/Library/CoreServices/Menu Extras/User.menu> (loaded) for Class AppleUser
Apr 29 15:39:49 MacBook-de-Luca.local SystemUIServer[727]: Cannot find executable for CFBundle 0x7fc0e35d50c0 </System/Library/CoreServices/Menu Extras/Clock.menu> (not loaded)
Apr 29 15:39:49 MacBook-de-Luca.local SystemUIServer[727]: Cannot find executable for CFBundle 0x7fc0e35d5990 </System/Library/CoreServices/Menu Extras/Battery.menu> (not loaded)
Apr 29 15:39:49 MacBook-de-Luca.local SystemUIServer[727]: Cannot find executable for CFBundle 0x7fc0e349be60 </System/Library/CoreServices/Menu Extras/Volume.menu> (not loaded)
Apr 29 15:39:50 MacBook-de-Luca.local backupd[634]: Property list invalid for format: 200 (property lists cannot contain NULL)
Apr 29 15:39:50 MacBook-de-Luca.local SystemUIServer[727]: *** WARNING: -[NSImage compositeToPoint:operation:fraction:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
Apr 29 15:39:50 MacBook-de-Luca.local SystemUIServer[727]: *** WARNING: -[NSImage compositeToPoint:fromRect:operation:fraction:] is deprecated in MacOSX 10.8 and later. Please use -[NSImage drawAtPoint:fromRect:operation:fraction:] instead.
Apr 29 15:39:50 MacBook-de-Luca.local sharingd[740]: Starting Up...
Apr 29 15:39:51 MacBook-de-Luca.local locationd[40]: Location icon should now be in state 'Inactive'
Apr 29 15:39:51 MacBook-de-Luca.local soagent[742]: Restoring DB from MetaData
Apr 29 15:39:51 MacBook-de-Luca.local soagent[742]: Restoration from MetaData complete (0.000s)
Apr 29 15:39:52 MacBook-de-Luca xpcproxy[753]: assertion failed: 13C64: xpcproxy + 3438 [D559FC96-E6B1-363A-B850-C7AC9734F210]: 0x2
Apr 29 15:39:52 MacBook-de-Luca.local UserEventAgent[720]: Failed to copy info dictionary for bundle /System/Library/UserEventPlugins/alfUIplugin.plugin
Apr 29 15:39:52 MacBook-de-Luca.local Console[722]: setPresentationOptions called with NSApplicationPresentationFullScreen when there is no visible fullscreen window; this call will be ignored.
Apr 29 15:39:52 MacBook-de-Luca accountsd[754]: assertion failed: 13C64: liblaunch.dylib + 25164 [38D1AB2C-A476-385F-8EA8-7AB604CA1F89]: 0x25
Apr 29 15:39:53 MacBook-de-Luca.local backupd[634]: Property list invalid for format: 200 (property lists cannot contain NULL)
Apr 29 15:39:54 MacBook-de-Luca.local com.apple.SecurityServer[25]: Session 100029 created
Apr 29 15:39:54 MacBook-de-Luca.local com.apple.NotesMigratorService[219]: Joined Aqua audit session
Apr 29 15:39:54 MacBook-de-Luca.local com.apple.time[720]: Interval maximum value is 946100000 seconds (specified value: 9223372036854775807).
Apr 29 15:39:54 --- last message repeated 1 time ---
Apr 29 15:39:54 MacBook-de-Luca.local com.apple.dock.extra[738]: <NSXPCConnection: 0x7f9cc059f930>: received an undecodable message (no exported object to receive message). Dropping message.
Apr 29 15:39:54 MacBook-de-Luca.local com.apple.internetaccounts[753]: *** -[IADomainCache init]: IA domains cache couldn't be read.
Apr 29 15:39:54 MacBook-de-Luca.local com.apple.internetaccounts[753]: -[IAPluginManager allAListPlugins] [546] -- *** warning: we're on the slow path.
Apr 29 15:39:54 MacBook-de-Luca.local syncdefaultsd[748]: *** -[IADomainCache init]: IA domains cache couldn't be read.
Apr 29 15:39:54 MacBook-de-Luca.local syncdefaultsd[748]: -[IAPluginManager allAListPlugins] [546] -- *** warning: we're on the slow path.
Apr 29 15:39:55 MacBook-de-Luca.local CalendarAgent[746]: *** -[IADomainCache init]: IA domains cache couldn't be read.
Apr 29 15:39:55 MacBook-de-Luca.local CalendarAgent[746]: -[IAPluginManager allAListPlugins] [546] -- *** warning: we're on the slow path.
Apr 29 15:39:55 MacBook-de-Luca com.apple.launchd[1] (com.apple.preferences.timezone.auto): Throttling respawn: Will start in 1 seconds
Apr 29 15:39:55 MacBook-de-Luca.local talagent[726]: CGSBindSurface: Invalid window 0x1c
Apr 29 15:39:55 MacBook-de-Luca.local WindowServer[684]: _CGXWindowRightsRelinquish: Invalid window 0x1c
Apr 29 15:39:55 MacBook-de-Luca.local talagent[726]: CGSConnectionRelinquishWindowRights(cid, result, reservedRights): CGError 1001 on line 875
Apr 29 15:39:55 MacBook-de-Luca.local WindowServer[684]: _CGXTerminateWindowList: Invalid window 28
Apr 29 15:39:55 MacBook-de-Luca kernel[0]: CODE SIGNING: cs_invalid_page(0x1000): p=771[GoogleSoftwareUp] final status 0x0, allowing (remove VALID) page
Apr 29 15:39:55 MacBook-de-Luca com.apple.launchd.peruser.501[151] (com.hegenberg.BetterTouchTool.33120[773]): Spawned and waiting for the debugger to attach before continuing...
Apr 29 15:39:56 MacBook-de-Luca.local locationd[40]: Location icon should now be in state 'Active'
Apr 29 15:39:57 MacBook-de-Luca com.apple.launchd.peruser.501[151] (com.apple.mrt.uiagent[763]): Exited with code: 255
Apr 29 15:39:57 MacBook-de-Luca.local accountsd[754]: /SourceCache/Accounts/Accounts-336.9/ACDAuthenticationPluginManager.m - -[ACDAuthenticationPluginManager credentialForAccount:client:handler:] - 230 - The authentication plugin for account "
luca.tass@gmail.com" (41AA6536-C176-4D0C-9DAE-F2E234E02E42) could not be found!
Apr 29 15:39:57 MacBook-de-Luca.local accountsd[754]: /SourceCache/Accounts/Accounts-336.9/ACDAccountStore.m - __62-[ACDAccountStore credentialForAccountWithIdentifier:handler:]_block_invoke389 - 857 - No plugin provides credentials for account
luca.tass@gmail.com. Falling back to legacy behavior.
Apr 29 15:39:57 MacBook-de-Luca.local WiFiKeychainProxy[759]: [NO client logger] <Nov 10 2013 18:30:13> WIFICLOUDSYNC WiFiCloudSyncEngineCreate: created...
Apr 29 15:39:57 MacBook-de-Luca.local WiFiKeychainProxy[759]: [NO client logger] <Nov 10 2013 18:30:13> WIFICLOUDSYNC WiFiCloudSyncEngineRegisterCallbacks: WiFiCloudSyncEngineCallbacks version - 0, bundle id - com.apple.wifi.WiFiKeychainProxy
Apr 29 15:39:57 MacBook-de-Luca.local AddressBookSourceSync[774]: Restoring DB from MetaData
Apr 29 15:39:57 MacBook-de-Luca.local AddressBookSourceSync[774]: Restoration from MetaData complete (0.000s)
Apr 29 15:39:57 MacBook-de-Luca.local soagent[742]: <ABAddressBook: 0x7f921a447530>: Resetting database due to: __CFNotification 0x7f921a5927f0 {name = ABDistributedDatabaseChangedNotification; object = /Users/Luca/Library/Application Support/AddressBook-0x7fd99ac232c0; userInfo = {
ABRestoreFromMetadata = 1;
ABSenderProcessID = 774;
ABSenderProcessName = AddressBookSourceSync;
kABUserUID = 501;
Apr 29 15:39:57 MacBook-de-Luca.local System Events[781]: .sdef warning for part of complex type 'any | number | boolean | date | list | record | text | data' used in suite 'Property List Suite': 'data' is not a valid type name.
Apr 29 15:39:57 MacBook-de-Luca.local System Events[781]: .sdef warning for type 'text | missing value | any' attribute 'uniqueID' of class 'XML element' in suite 'XML Suite': AppleScript ID references may not work for this property because its type is not NSNumber- or NSString-derived.
Apr 29 15:39:57 MacBook-de-Luca.local BetterTouchTool[773]: Attempt to add read-only file at path file:///Users/Luca/Library/Application%20Support/BetterTouchTool/bttdata2 read/write. Adding it read-only instead. This will be a hard error in the future; you must specify the NSReadOnlyPersistentStoreOption.
Apr 29 15:39:57 MacBook-de-Luca.local BetterTouchTool[773]: init
Apr 29 15:39:57 MacBook-de-Luca.local CalendarAgent[746]: Restoring DB from MetaData
Apr 29 15:39:57 MacBook-de-Luca.local CalendarAgent[746]: Restoration from MetaData complete (0.001s)
Apr 29 15:39:57 MacBook-de-Luca.local soagent[742]: <ABAddressBook: 0x7f921a447530>: Resetting database due to: __CFNotification 0x7f921a610e90 {name = ABDistributedDatabaseChangedNotification; object = /Users/Luca/Library/Application Support/AddressBook-0x7fbfe071c750; userInfo = {
ABSenderProcessID = 746;
ABSenderProcessName = CalendarAgent;
kABUserUID = 501;
Apr 29 15:39:58 MacBook-de-Luca.local AddressBookSourceSync[774]: <ABAddressBook: 0x7fd99ac232c0>: Resetting database due to: __CFNotification 0x7fd99ac65940 {name = ABDistributedDatabaseChangedNotification; object = /Users/Luca/Library/Application Support/AddressBook-0x7fbfe071c750; userInfo = {
kABUserUID = 501;
Apr 29 15:39:58 MacBook-de-Luca.local AddressBookSourceSync[774]: <ABAddressBook: 0x7fd99adc3bc0>: Resetting database due to: __CFNotification 0x7fd99ac65940 {name = ABDistributedDatabaseChangedNotification; object = /Users/Luca/Library/Application Support/AddressBook-0x7fbfe071c750; userInfo = {
kABUserUID = 501;
Apr 29 15:39:58 MacBook-de-Luca.local CalendarAgent[746]: <ABAddressBook: 0x7fbfe071c750>: Resetting database due to: __CFNotification 0x7fbfe06540e0 {name = ABDistributedDatabaseChangedNotification; object = /Users/Luca/Library/Application Support/AddressBook-0x7fd99ac232c0; userInfo = {
kABUserUID = 501;
Apr 29 15:39:58 MacBook-de-Luca.local CalendarAgent[746]: -[ABPersistentStoreBuilder removePersistentStoreAtPath:]: storeUrl is nil
Apr 29 15:39:58 MacBook-de-Luca.local gamed[776]: CKSoftwareMap: Registering with Daemon
Apr 29 15:39:58 MacBook-de-Luca.local mDNSResponder[35]: mDNS_Register_internal: ERROR!! Tried to register AuthRecord 00007FBB1B016560 MacBook-de-Luca.local. (AAAA) that's already in the list
Apr 29 15:39:58 MacBook-de-Luca.local mDNSResponder[35]: mDNS_Register_internal: ERROR!! Tried to register AuthRecord 00007FBB1B0169F0 A.8.E.E.A.8.E.F.F.F.E.9.5.1.6.3.0.0.0.0.0.0.0.0.0.0.0.0.0.8.E.F.ip6.arpa. (PTR) that's already in the list
Apr 29 15:39:58 MacBook-de-Luca.local mDNSResponder[35]: mDNS_Register_internal: ERROR!! Tried to register AuthRecord 00007FBB1B018160 MacBook-de-Luca.local. (Addr) that's already in the list
Apr 29 15:39:58 MacBook-de-Luca.local mDNSResponder[35]: mDNS_Register_internal: ERROR!! Tried to register AuthRecord 00007FBB1B0185F0 2.1.168.192.in-addr.arpa. (PTR) that's already in the list
Apr 29 15:39:58 MacBook-de-Luca.local locationd[40]: Location icon should now be in state 'Inactive'
Apr 29 15:40:05 MacBook-de-Luca.local talagent[726]: CGSBindSurface: Invalid window 0x21
Apr 29 15:40:05 MacBook-de-Luca.local WindowServer[684]: _CGXWindowRightsRelinquish: Invalid window 0x21
Apr 29 15:40:05 MacBook-de-Luca.local talagent[726]: CGSConnectionRelinquishWindowRights(cid, result, reservedRights): CGError 1001 on line 875
Apr 29 15:40:05 MacBook-de-Luca.local WindowServer[684]: _CGXTerminateWindowList: Invalid window 33
Apr 29 15:40:06 MacBook-de-Luca.local parentalcontrolsd[788]: StartObservingFSEvents [849:] -- *** StartObservingFSEvents started event stream
Apr 29 15:40:12 MacBook-de-Luca.local com.apple.SecurityServer[25]: Killing auth hosts
Apr 29 15:40:12 MacBook-de-Luca.local com.apple.SecurityServer[25]: Session 100028 destroyed
Apr 29 15:40:29 MacBook-de-Luca kernel[0]: **** [IOBluetoothHostControllerUSBTransport][SuspendDevice] -- Suspend -- suspendDeviceCallResult = 0x0000 (kIOReturnSuccess) -- 0xac00 ****
