Non uso Stuffit. Questo è ciò che ho trovato dalla console:
Apr 17 09:08:37 localhost bootlog[0]: BOOT_TIME 1397718517 0
Apr 17 09:08:39 localhost com.apple.launchd[1]: *** launchd[1] has started up. ***
Apr 17 09:08:44 localhost com.apple.launchd[1] (com.apple.powerd): Unknown value for key POSIXSpawnType: Interactive
Apr 17 09:08:44 localhost com.apple.launchd[1] (com.apple.sandboxd): Unknown value for key POSIXSpawnType: Interactive
Apr 17 09:08:44 localhost com.apple.launchd[1] (com.apple.usbmuxd): Unknown value for key POSIXSpawnType: Interactive
Apr 17 09:08:49 localhost com.apple.ucupdate.plist[20]: ucupdate: Checked 1 update, no match found.
Apr 17 09:08:49 localhost com.apple.pfctl[30]: No ALTQ support in kernel
Apr 17 09:08:49 localhost com.apple.pfctl[30]: ALTQ related functions disabled
Apr 17 09:08:59 localhost UserEventAgent[11]: starting CaptiveNetworkSupport as SystemEventAgent built May 25 2011 12:27:35
Apr 17 09:08:59 localhost UserEventAgent[11]: CaptiveNetworkSupport:CreateInterfaceWatchList:2788 WiFi Devices Found.
Apr 17 09:08:59 localhost UserEventAgent[11]: CaptiveNetworkSupport:CaptivePublishState:1211 en1 - PreProbe
Apr 17 09:08:59 localhost UserEventAgent[11]: CaptiveNetworkSupport:CaptiveSCRebuildCache:81 Failed to get service order
Apr 17 09:09:05: --- last message repeated 1 time ---
Apr 17 09:08:59 localhost UserEventAgent[11]: CertsKeychainMonitor: configuring
Apr 17 09:09:06 localhost com.apple.usbmuxd[19]: usbmuxd-327.4 on Feb 12 2014 at 14:54:33, running 64 bit
Apr 17 09:09:06 localhost mDNSResponder[34]: mDNSResponder mDNSResponder-320.16 (Jul 19 2012 21:07:07) starting OSXVers 11
Apr 17 09:09:07 localhost UserEventAgent[11]: ServermgrdRegistration cannot load config data
Apr 17 09:09:07 localhost UserEventAgent[11]: get_backup_share_points no AFP
Apr 17 09:09:07 localhost launchdadd[66]: FAILURE: Could not send MIG reply: 0x10000003
Apr 17 09:09:08 localhost airportd[70]: _processDLILEvent: en1 attached (down)
Apr 17 09:09:09 localhost UserEventAgent[11]: CaptiveNetworkSupport:CaptiveSCRebuildCache:81 Failed to get service order
Apr 17 09:09:09: --- last message repeated 1 time ---
Apr 17 09:09:09 localhost UserEventAgent[11]: CaptiveNetworkSupport:CaptivePublishState:1211 en1 - PreProbe
Apr 17 09:09:09 localhost mds[33]: (Normal) FMW: FMW 0 0
Apr 17 09:09:09 localhost systemkeychain[79]: done file: /var/run/systemkeychaincheck.done
Apr 17 09:09:09 localhost mDNSResponder[34]: D2D_IPC: Loaded
Apr 17 09:09:09 localhost mDNSResponder[34]: D2DInitialize succeeded
Apr 17 09:09:09 localhost rpcsvchost[94]: sandbox_init: com.apple.msrpc.netlogon.sb succeeded
Apr 17 09:09:10 localhost com.apple.launchctl.Background[98]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
Apr 17 09:09:11 localhost SophosAutoUpdate[58]: AlreadyRegistered
Apr 17 09:09:11 localhost SophosAntiVirus[56]: reloading scheduled scans...
Apr 17 09:09:11 localhost configd[48]: bootp_session_transmit: bpf_write(en1) failed: Network is down (50)
Apr 17 09:09:11 localhost configd[48]: DHCP en1: INIT-REBOOT transmit failed
Apr 17 09:09:11 localhost foundry[99]: This process is attempting to exclude an item from Time Machine by path without administrator privileges. This is not supported.
Apr 17 09:09:11: --- last message repeated 6 times ---
Apr 17 09:09:11 MacBook-Pro-di-Fabio configd[48]: setting hostname to "MacBook-Pro-di-Fabio.local"
Apr 17 09:09:11 MacBook-Pro-di-Fabio foundry[99]: This process is attempting to exclude an item from Time Machine by path without administrator privileges. This is not supported.
Apr 17 09:09:11: --- last message repeated 4 times ---
Apr 17 09:09:11 MacBook-Pro-di-Fabio configd[48]: network configuration changed.
Apr 17 09:09:14: --- last message repeated 2 times ---
Apr 17 09:09:14 MacBook-Pro-di-Fabio xpchelper[104]: for uid: 222 -- timeout while waiting on FSEvents flush; clearing cache.
Apr 17 09:09:14 MacBook-Pro-di-Fabio configd[48]: network configuration changed.
Apr 17 09:09:14 MacBook-Pro-di-Fabio UserEventAgent[11]: CaptiveNetworkSupport:CaptivePublishState:1211 en1 - Probe
Apr 17 09:09:14 MacBook-Pro-di-Fabio UserEventAgent[11]: CaptiveNetworkSupport:CNSPreferencesBuildSSIDLookup:278 ssidLookup:
Apr 17 09:09:14 MacBook-Pro-di-Fabio UserEventAgent[11]: <empty>
Apr 17 09:09:14 MacBook-Pro-di-Fabio UserEventAgent[11]: CaptiveNetworkSupport:CaptiveStartDetect:2343 Bypassing probe on USR5462 because it is protected and not on the exception list
Apr 17 09:09:14 MacBook-Pro-di-Fabio UserEventAgent[11]: CaptiveNetworkSupport:CaptivePublishState:1211 en1 - Unknown
Apr 17 09:09:15 MacBook-Pro-di-Fabio mds[33]: (/.Spotlight-V100/Store-V2/58BAE464-1388-4E38-926C-306E7DE38E4D)(Normal) IndexGeneral in openReverseStore:Shadowing reverse store on open
Apr 17 09:09:15 MacBook-Pro-di-Fabio loginwindow[36]: Login Window Application Started
Apr 17 09:09:18 MacBook-Pro-di-Fabio SophosAntiVirus[56]: reloading scheduled scans...
Apr 17 09:09:18 MacBook-Pro-di-Fabio ntpd[15]: proto: precision = 1.000 usec
Apr 17 09:09:20 MacBook-Pro-di-Fabio XProtectUpdater[17]: Ignoring new signature plist: Not an increase in version
Apr 17 09:09:20 MacBook-Pro-di-Fabio com.apple.launchd[1] (com.apple.xprotectupdater[17]): Exited with code: 252
Apr 17 09:09:20 MacBook-Pro-di-Fabio loginwindow[36]: **DMPROXY** Found `/System/Library/CoreServices/DMProxy'.
Apr 17 09:09:21 MacBook-Pro-di-Fabio com.apple.launchctl.LoginWindow[118]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
Apr 17 09:09:21 MacBook-Pro-di-Fabio com.apple.launchctl.LoginWindow[118]: com.apple.findmymacmessenger: Already loaded
Apr 17 09:09:21 MacBook-Pro-di-Fabio com.apple.launchctl.LoginWindow[118]: com.apple.store_helper: Already loaded
Apr 17 09:09:21 MacBook-Pro-di-Fabio com.apple.launchctl.LoginWindow[118]: com.apple.storeagent: Already loaded
Apr 17 09:09:21 MacBook-Pro-di-Fabio airportd[70]: _doAutoJoin: Already associated to “USR5462”. Bailing on auto-join.
Apr 17 09:09:21 MacBook-Pro-di-Fabio loginwindow[36]: Login Window Started Security Agent
Apr 17 09:09:21 MacBook-Pro-di-Fabio SecurityAgent[125]: Echo enabled
Apr 17 09:09:21 MacBook-Pro-di-Fabio com.apple.launchctl.Background[127]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
Apr 17 09:09:21 MacBook-Pro-di-Fabio com.apple.launchctl.Background[133]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
Apr 17 09:09:21 MacBook-Pro-di-Fabio WindowServer[110]: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
Apr 17 09:09:23 MacBook-Pro-di-Fabio warmd[18]: [___bootcachectl_filter_out_sharedio_from_history_block_invoke_0:1683] Unable to open i386 shared cache: 2 No such file or directory
Apr 17 09:09:28 MacBook-Pro-di-Fabio SecurityAgent[125]: User info context values set for fabiobullegas
Apr 17 09:09:30 MacBook-Pro-di-Fabio UserEventAgent[11]: [11] error in getAndLockContext: open returned -1 (errno=2) file was /private/var/servermgrd//servermgr_certs.lock
Apr 17 09:09:30: --- last message repeated 1 time ---
Apr 17 09:09:30 MacBook-Pro-di-Fabio UserEventAgent[11]: CertsKeychainMonitor: ready to process keychain & timer events
Apr 17 09:09:33 MacBook-Pro-di-Fabio SecurityAgent[125]: User info context values set for fabiobullegas
Apr 17 09:09:34 MacBook-Pro-di-Fabio SecurityAgent[125]: Login Window login proceeding
Apr 17 09:09:34 MacBook-Pro-di-Fabio loginwindow[36]: Login Window - Returned from Security Agent
Apr 17 09:09:34 MacBook-Pro-di-Fabio loginwindow[36]: USER_PROCESS: 36 console
Apr 17 09:09:34 MacBook-Pro-di-Fabio airportd[70]: _doAutoJoin: Already associated to “USR5462”. Bailing on auto-join.
Apr 17 09:09:34 MacBook-Pro-di-Fabio com.apple.launchctl.Background[139]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
Apr 17 09:09:34 MacBook-Pro-di-Fabio applepushserviced[52]: Unable to bootstrap_lookup connection port for 'com.apple.iCalPush': unknown error code
Apr 17 09:09:34 MacBook-Pro-di-Fabio applepushserviced[52]: Unable to bootstrap_lookup connection port for 'com.apple.AddressBook.PushNotification': unknown error code
Apr 17 09:09:34 MacBook-Pro-di-Fabio applepushserviced[52]: Unable to bootstrap_lookup connection port for 'com.apple.syncdefaultsd.push': unknown error code
Apr 17 09:09:34 MacBook-Pro-di-Fabio applepushserviced[52]: Unable to bootstrap_lookup connection port for 'com.apple.safaridavclient.push': unknown error code
Apr 17 09:09:34 MacBook-Pro-di-Fabio com.apple.launchctl.Aqua[140]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
Apr 17 09:09:34 MacBook-Pro-di-Fabio com.apple.launchd.peruser.501[138] (com.spotify.webhelper): Unknown key: SpotifyPath
Apr 17 09:09:34 MacBook-Pro-di-Fabio com.apple.launchd.peruser.501[138] (com.apple.AirPortBaseStationAgent): Unknown value for key POSIXSpawnType: Background
Apr 17 09:09:34 MacBook-Pro-di-Fabio com.apple.launchd.peruser.501[138] (com.apple.ReportCrash): Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
Apr 17 09:09:34 MacBook-Pro-di-Fabio com.apple.launchctl.Aqua[140]: load: option requires an argument -- D
Apr 17 09:09:34 MacBook-Pro-di-Fabio com.apple.launchctl.Aqua[140]: usage: launchctl load [-wF] [-D <user|local|network|system|all>] paths...
Apr 17 09:09:35 MacBook-Pro-di-Fabio UserEventAgent[11]: CaptiveNetworkSupport:CNSServerRegisterUserAgent:187 new user agent port: 42503
Apr 17 09:09:35 MacBook-Pro-di-Fabio com.apple.launchd.peruser.501[138] (com.apple.launchctl.Aqua[140]): Exited with code: 1
Apr 17 09:09:35 MacBook-Pro-di-Fabio loginwindow[36]: ISGetIconFamilyFromStorage: seed mismatch for 231b0001, actual seed is 3352255a
Apr 17 09:09:37: --- last message repeated 2 times ---
Apr 17 09:09:37 MacBook-Pro-di-Fabio com.apple.launchctl.Background[165]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
Apr 17 09:09:37 MacBook-Pro-di-Fabio com.apple.dock.extra[162]: Could not connect the action buttonPressed: to target of class NSApplication
Apr 17 09:09:37 MacBook-Pro-di-Fabio com.apple.dock.extra[162]: 2014-04-17 09:09:37.543 com.apple.dock.extra[162:1a07] Could not connect the action buttonPressed: to target of class NSApplication
Apr 17 09:09:37 MacBook-Pro-di-Fabio com.apple.dock.extra[162]: 2014-04-17 09:09:37.544 com.apple.dock.extra[162:1a07] Could not connect the action buttonPressed: to target of class NSApplication
Apr 17 09:09:37 MacBook-Pro-di-Fabio com.apple.dock.extra[162]: 2014-04-17 09:09:37.545 com.apple.dock.extra[162:1a07] Could not connect the action buttonPressed: to target of class NSApplication
Apr 17 09:09:37 MacBook-Pro-di-Fabio com.apple.launchd.peruser.501[138] (com.plexapp.helper[187]): posix_spawn("/Applications/Plex.app/Contents/Resources/Plex/tools/osx/PlexHelper", ...): No such file or directory
Apr 17 09:09:37 MacBook-Pro-di-Fabio com.apple.launchd.peruser.501[138] (com.plexapp.helper[187]): Exited with code: 1
Apr 17 09:09:38 MacBook-Pro-di-Fabio Paragon Updater[182]: opening log at /Users/fabiobullegas/Library/Logs/paragon.Paragon-Updater.log ...
Apr 17 09:09:38 MacBook-Pro-di-Fabio Paragon Updater[182]: done
Apr 17 09:09:38 MacBook-Pro-di-Fabio Paragon Updater[182]: Updater started. Updater version: 1.100
Apr 17 09:09:38 MacBook-Pro-di-Fabio Paragon Updater[182]: Arguments: --check, --delay=30
Apr 17 09:09:38 MacBook-Pro-di-Fabio com.apple.launchd.peruser.501[138] (com.apple.mrt.uiagent[174]): Exited with code: 255
Apr 17 09:09:38 MacBook-Pro-di-Fabio appleprofilepolicyd[198]: appleprofilepolicyd: profiling drivers not loaded, loading
Apr 17 09:09:39 MacBook-Pro-di-Fabio Vox Helper[196]: Non of media apps is launched
Apr 17 09:09:39 MacBook-Pro-di-Fabio Vox Helper[196]: Not intersepting
Apr 17 09:09:39 MacBook-Pro-di-Fabio Vox Helper[196]: Prefs with headphones: 1,mediakeys: 1 , remote: 1, start on play: 1
Apr 17 09:09:39 MacBook-Pro-di-Fabio Vox Helper[196]: Intersepting
Apr 17 09:09:40 MacBook-Pro-di-Fabio com.apple.launchd.peruser.501[138] (
com.apple.CSConfigDotMacCert-fabio.bullegas@me.com-SharedServices[189]): Exited with code: 1
Apr 17 09:09:41 MacBook-Pro-di-Fabio fseventsd[41]: event logs in /Volumes/BULLEGAS 32/.fseventsd out of sync with volume. destroying old logs. (59682 1 126290)
Apr 17 09:09:41 MacBook-Pro-di-Fabio fseventsd[41]: log dir: /Volumes/BULLEGAS 32/.fseventsd getting new uuid: BE7C89B5-A7CD-4620-AEEF-8B2A84D69554
Apr 17 09:09:41 MacBook-Pro-di-Fabio GoogleSoftwareUpdateDaemon[216]: -[KeystoneDaemon logServiceState] GoogleSoftwareUpdate daemon (1.1.0.3659) vending:
com.google.Keystone.Daemon.UpdateEngine: 2 connection(s)
com.google.Keystone.Daemon.Administration: 0 connection(s)
Apr 17 09:09:41 MacBook-Pro-di-Fabio Vox Helper[196]: Non of media apps is launched
Apr 17 09:09:41 MacBook-Pro-di-Fabio Vox Helper[196]: Intersepting
Apr 17 09:09:41 MacBook-Pro-di-Fabio GoogleSoftwareUpdateDaemon[216]: -[KSUpdateEngine updateProductID:] KSUpdateEngine updating product ID: "com.google.Keystone"
Apr 17 09:09:41 MacBook-Pro-di-Fabio GoogleSoftwareUpdateDaemon[216]: -[KSCheckAction performAction] KSCheckAction checking 1 ticket(s).
Apr 17 09:09:42 MacBook-Pro-di-Fabio GoogleSoftwareUpdateDaemon[216]: -[KSUpdateCheckAction performAction] KSUpdateCheckAction starting update check for ticket(s): {(
<KSTicket:0x6521d00
productID=com.google.Keystone
version=1.1.0.3659
xc=<KSPathExistenceChecker:0x6521f50 path=/Library/Google/GoogleSoftwareUpdate/GoogleSoftwareUpdate.bundle/>
serverType=Omaha
url=
https://tools.google.com/service/update2
creationDate=2012-11-27 01:58:30
Using server: <KSOmahaServer:0x8e24310
engine=<KSDaemonUpdateEngine:0x8d22df0>
params={
EngineVersion = "1.1.0.3659";
ActivesInfo = {
"com.google.android.mtpviewer" = {
LastActivePingDate = 2014-04-15 07:00:00 +0000;
LastActiveDate = 2014-04-14 17:09:37 +0000;
LastRollCallPingDate = 2014-04-16 07:00:10 +0000;
"com.google.Keystone" = {
LastActivePingDate = 2014-04-16 07:00:10 +0000;
LastActiveDate = 2014-04-17 07:09:39 +0000;
"com.google.Chrome" = {
LastActiveDate = 2014-04-16 21:29:13 +0000;
UserInitiated = 0;
IsSystem = 1;
OmahaOSVersion = "10.7.5_i486";
Identity = KeystoneDaemon;
AllowedSubdomains = (
".omaha.sandbox.google.com",
".tools.google.com",
www.google.com",
".corp.google.com"
Apr 17 09:09:42 MacBook-Pro-di-Fabio Vox Helper[196]: Non of media apps is launched
Apr 17 09:09:42 MacBook-Pro-di-Fabio Vox Helper[196]: Intersepting
Apr 17 09:09:43 MacBook-Pro-di-Fabio GoogleSoftwareUpdateDaemon[216]: -[KSUpdateCheckAction performAction] KSUpdateCheckAction running KSServerUpdateRequest: <KSOmahaServerUpdateRequest:0x8e29a40
server=<KSOmahaServer:0x8e24310>
url="
https://tools.google.com/service/update2"
runningFetchers=0
tickets=1
activeTickets=1
rollCallTickets=1
body=
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<o:gupdate xmlns:o="
http://www.google.com/update2/request" protocol="2.0" version="KeystoneDaemon-1.1.0.3659" ismachine="1">
<o:os platform="mac" version="MacOSX" sp="10.7.5_i486"></o:os>
<o:app appid="com.google.Keystone" version="1.1.0.3659" lang="en-us" installage="506" brand="GGLG">
<o:ping r="1" a="1"></o:ping>
<o:updatecheck></o:updatecheck>
</o:app>
</o:gupdate>
Apr 17 09:09:43 MacBook-Pro-di-Fabio com.apple.launchctl.Background[234]: launchctl: Dubious permissions on file (skipping): /Library/LaunchAgents/com.adobe.AAM.Updater-1.0.plist
Apr 17 09:09:44 MacBook-Pro-di-Fabio Vox Helper[196]: Non of media apps is launched
Apr 17 09:09:44 MacBook-Pro-di-Fabio Vox Helper[196]: Intersepting
Apr 17 09:09:44 MacBook-Pro-di-Fabio Dropbox[206]: PyObjCPointer created: at 0x165ffd24 of type {OpaqueJSContext=}
Apr 17 09:09:45 MacBook-Pro-di-Fabio GoogleSoftwareUpdateDaemon[216]: -[KSUpdateCheckAction(KSServerUpdateRequestDelegate) serverRequest:fetchedWithResponse:] KSUpdateCheckAction received KSServerUpdateResponse: <KSOmahaServerUpdateResponse:0x6522540
url="
status=200
tickets=1
activeTickets=1
rollCallTickets=1
data=
<gupdate xmlns="
http://www.google.com/update2/response" protocol="2.0" server="prod">
<daystart elapsed_days="2663" elapsed_seconds="584"></daystart>
<app appid="com.google.Keystone" status="ok">
<ping status="ok"></ping>
<updatecheck status="noupdate"></updatecheck>
</app>
</gupdate>
Apr 17 09:09:45 MacBook-Pro-di-Fabio WDDriveUtilityHelper[239]: Running WDDriveUtilityHelper v1.0.0.12
Apr 17 09:09:46 MacBook-Pro-di-Fabio GoogleSoftwareUpdateDaemon[216]: -[KSUpdateCheckAction(PrivateMethods) finishAction] KSUpdateCheckAction found updates: {( )}
Apr 17 09:09:46 MacBook-Pro-di-Fabio mds[33]: (/)(Warning) IndexQuery in bool preIterate_FSI(SISearchCtx_FSI*):Throttling inefficient file system query
Apr 17 09:09:47 MacBook-Pro-di-Fabio GoogleSoftwareUpdateDaemon[216]: -[KSPrefetchAction performAction] KSPrefetchAction no updates to prefetch.
Apr 17 09:09:47 MacBook-Pro-di-Fabio GoogleSoftwareUpdateDaemon[216]: -[KSMultiUpdateAction performAction] KSSilentUpdateAction had no updates to apply.
Apr 17 09:09:47 MacBook-Pro-di-Fabio GoogleSoftwareUpdateDaemon[216]: -[KSMultiUpdateAction performAction] KSPromptAction had no updates to apply.
Apr 17 09:09:47 MacBook-Pro-di-Fabio GoogleSoftwareUpdateDaemon[216]: -[KSUpdateEngine(PrivateMethods) updateFinish] KSUpdateEngine update processing complete.
Apr 17 09:09:48 MacBook-Pro-di-Fabio GoogleSoftwareUpdateDaemon[216]: -[KSUpdateEngine updateAllProducts] KSUpdateEngine updating all installed products.
Apr 17 09:09:48 MacBook-Pro-di-Fabio GoogleSoftwareUpdateDaemon[216]: -[KSCheckAction performAction] KSCheckAction checking 2 ticket(s).
Apr 17 09:09:48 MacBook-Pro-di-Fabio GoogleSoftwareUpdateDaemon[216]: -[KSUpdateCheckAction performAction] KSUpdateCheckAction starting update check for ticket(s): {(
<KSTicket:0x6136e60
version=1.1.0.3659
xc=<KSPathExistenceChecker:0x6139a90 path=/Library/Google/GoogleSoftwareUpdate/GoogleSoftwareUpdate.bundle/>
serverType=Omaha
url=
<KSTicket:0x61385b0
productID=com.google.Chrome
version=34.0.1847.116
xc=<KSPathExistenceChecker:0x6137400 path=/Applications/Google Chrome.app>
serverType=Omaha
url=
creationDate=2012-11-27 01:58:31
tagPath=/Applications/Google Chrome.app/Contents/Info.plist
tagKey=KSChannelID
brandPath=/Library/Google/Google Chrome Brand.plist
brandKey=KSBrandID
versionPath=/Applications/Google Chrome.app/Contents/Info.plist
versionKey=KSVersion
Using server: <KSOmahaServer:0x6621fb0
params={
ActivesInfo = {
LastActivePingDate = 2014-04-17 07:00:02 +0000;
LastRollCallPingDate = 2014-04-17 07:00:02 +0000;
UserInitiated = 0;
IsSystem = 1;
www.google.com",
".corp.google.com"
Apr 17 09:09:48 MacBook-Pro-di-Fabio GoogleSoftwareUpdateDaemon[216]: -[KSUpdateCheckAction performAction] KSUpdateCheckAction running KSServerUpdateRequest: <KSOmahaServerUpdateRequest:0x89264a0
server=<KSOmahaServer:0x6621fb0>
url="
runningFetchers=0
tickets=2
activeTickets=1
rollCallTickets=1
body=
</o:app>
<o:app appid="com.google.Chrome" version="34.0.1847.116" lang="en-us" installage="506" brand="GGRO">
</o:app>
</o:gupdate>
Apr 17 09:09:48 MacBook-Pro-di-Fabio Mail[200]: Using V2 Layout
Apr 17 09:09:49 MacBook-Pro-di-Fabio GoogleSoftwareUpdateDaemon[216]: -[KSUpdateCheckAction(KSServerUpdateRequestDelegate) serverRequest:fetchedWithResponse:] KSUpdateCheckAction received KSServerUpdateResponse: <KSOmahaServerUpdateResponse:0x8e27080
url="
status=200
tickets=2
activeTickets=1
rollCallTickets=1
data=
<gupdate xmlns="
<daystart elapsed_days="2663" elapsed_seconds="589"></daystart>
</app>
<app appid="com.google.Chrome" status="ok">
</app>
</gupdate>
Apr 17 09:09:49 MacBook-Pro-di-Fabio GoogleSoftwareUpdateDaemon[216]: -[KSUpdateCheckAction(PrivateMethods) finishAction] KSUpdateCheckAction found updates: {( )}
Apr 17 09:09:49 MacBook-Pro-di-Fabio GoogleSoftwareUpdateDaemon[216]: -[KSPrefetchAction performAction] KSPrefetchAction no updates to prefetch.
Apr 17 09:09:49 MacBook-Pro-di-Fabio GoogleSoftwareUpdateDaemon[216]: -[KSMultiUpdateAction performAction] KSSilentUpdateAction had no updates to apply.
Apr 17 09:09:49 MacBook-Pro-di-Fabio GoogleSoftwareUpdateDaemon[216]: -[KSMultiUpdateAction performAction] KSPromptAction had no updates to apply.
Apr 17 09:09:49 MacBook-Pro-di-Fabio GoogleSoftwareUpdateDaemon[216]: -[KSUpdateEngine(PrivateMethods) updateFinish] KSUpdateEngine update processing complete.
Apr 17 09:09:53 MacBook-Pro-di-Fabio GoogleSoftwareUpdateDaemon[216]: -[KeystoneDaemon logServiceState] GoogleSoftwareUpdate daemon (1.1.0.3659) vending:
com.google.Keystone.Daemon.UpdateEngine: 1 connection(s)
Apr 17 09:09:53 MacBook-Pro-di-Fabio Vox Helper[196]: Non of media apps is launched
Apr 17 09:09:53 MacBook-Pro-di-Fabio Vox Helper[196]: Intersepting
Apr 17 09:09:54 MacBook-Pro-di-Fabio com.apple.launchd[1] (com.apple.coreservices.appleid.authentication[122]): Exit timeout elapsed (20 seconds). Killing
Apr 17 09:09:57 MacBook-Pro-di-Fabio com.apple.Finder[151]: Dropbox: Entered INJECT_pthread_entry
Apr 17 09:09:57 MacBook-Pro-di-Fabio com.apple.Finder[151]: Dropbox: Installing event loop timer
Apr 17 09:09:57 MacBook-Pro-di-Fabio com.apple.Finder[151]: Dropbox: proc: 0x1058a1e62
Apr 17 09:09:57 MacBook-Pro-di-Fabio com.apple.Finder[151]: Dropbox: upp: 0x1058a1e62
Apr 17 09:09:57 MacBook-Pro-di-Fabio com.apple.Finder[151]: Dropbox: InstallEventLoopTimer: 0x10546f04e
Apr 17 09:09:57 MacBook-Pro-di-Fabio com.apple.Finder[151]: Dropbox: GetMainEventLoop: 0x105430749
Apr 17 09:09:57 MacBook-Pro-di-Fabio com.apple.Finder[151]: Dropbox: timer installed!
Apr 17 09:09:57 MacBook-Pro-di-Fabio com.apple.Finder[151]: Dropbox: Loading /Library/DropboxHelperTools/Dropbox_u501/DropboxBundle.bundle/Contents/MacOS/DropboxBundle
Apr 17 09:09:57 MacBook-Pro-di-Fabio com.apple.Finder[151]: Dropbox: dlopen returned: 0x7fd1fab2ada0
Apr 17 09:09:57 MacBook-Pro-di-Fabio com.apple.Finder[151]: module initializer in main thread?: 1
Apr 17 09:10:08 MacBook-Pro-di-Fabio Paragon Updater[182]: [Paragon NTFS for Mac] found installed version: 11.2.443
Apr 17 09:10:08 MacBook-Pro-di-Fabio Paragon Updater[182]: [Paragon ExtFS for Mac] no installed version found
Apr 17 09:10:09 MacBook-Pro-di-Fabio Paragon Updater[182]: checking for updates (1)
Apr 17 09:10:09 MacBook-Pro-di-Fabio Paragon Updater[182]: checking for Paragon NTFS for Mac update...
Apr 17 09:10:09 MacBook-Pro-di-Fabio Paragon Updater[182]: [Paragon NTFS for Mac] check for update... (at
http://www.paragon-software.com/feed/ntfs.xml" onclick="window.open(this.href);return false;)
Apr 17 09:10:09 MacBook-Pro-di-Fabio Paragon Updater[182]: [Paragon NTFS for Mac] Update item not contains valid update. Reason: update item is not newer
Apr 17 09:10:09 MacBook-Pro-di-Fabio Paragon Updater[182]: [Paragon NTFS for Mac] didn't find update
Apr 17 09:10:09 MacBook-Pro-di-Fabio Paragon Updater[182]: update not found
Apr 17 09:10:09 MacBook-Pro-di-Fabio Paragon Updater[182]: Update is not available
Apr 17 09:10:09 MacBook-Pro-di-Fabio Paragon Updater[182]: update available? NO
Apr 17 09:10:11 MacBook-Pro-di-Fabio GoogleSoftwareUpdateDaemon[216]: -[KeystoneDaemon main] GoogleSoftwareUpdateDaemon inactive, shutdown.
Apr 17 09:10:14 MacBook-Pro-di-Fabio [0x0-0x15015].com.apple.mail[200]: com.apple.Dataclass.DeviceLocator
Apr 17 09:10:14 MacBook-Pro-di-Fabio [0x0-0x15015].com.apple.mail[200]: aclass.Mail
Apr 17 09:10:14 MacBook-Pro-di-Fabio [0x0-0x15015].com.apple.mail[200]: com.apple.Dataclass.Ubiquity
Apr 17 09:10:14 MacBook-Pro-di-Fabio [0x0-0x15015].com.apple.mail[200]: com.apple.Dataclass.MediaStream
Apr 17 09:10:14 MacBook-Pro-di-Fabio [0x0-0x15015].com.apple.mail[200]: com.apple.Dataclass.BackToMyMac
Apr 17 09:10:14 MacBook-Pro-di-Fabio [0x0-0x15015].com.apple.mail[200]: com.apple.Dataclass.Contacts
Apr 17 09:10:14 MacBook-Pro-di-Fabio [0x0-0x15015].com.apple.mail[200]: com.apple.Dataclass.Bookmarks
Apr 17 09:10:14 MacBook-Pro-di-Fabio [0x0-0x15015].com.apple.mail[200]: com.apple.Dataclass.Calendars
Apr 17 09:10:16 MacBook-Pro-di-Fabio OverlayHelper[271]: --- Log opened Thu Apr 17 09:10:16 2014 ---
Apr 17 09:10:16 MacBook-Pro-di-Fabio OverlayHelper[271]: --- OverlayHelper ---
Apr 17 09:10:17 MacBook-Pro-di-Fabio OverlayLoader[271]: --- Log opened Thu Apr 17 09:10:17 2014 ---
Apr 17 09:10:17 MacBook-Pro-di-Fabio OverlayLoader[271]: --- OverlayLoader ---
Apr 17 09:10:20 MacBook-Pro-di-Fabio Vox Helper[196]: Non of media apps is launched
Apr 17 09:10:20 MacBook-Pro-di-Fabio Vox Helper[196]: Intersepting
Apr 17 09:10:29 MacBook-Pro-di-Fabio Vox Helper[196]: Non of media apps is launched
Apr 17 09:10:29 MacBook-Pro-di-Fabio Vox Helper[196]: Intersepting
Apr 17 09:10:29 MacBook-Pro-di-Fabio com.apple.launchd.peruser.501[138] (com.apple.Finder[151]): Job appears to have crashed: Illegal instruction: 4
Apr 17 09:10:30 MacBook-Pro-di-Fabio ReportCrash[273]: Saved crash report for Finder[151] version 10.7.5 (10.7.5) to /Users/fabiobullegas/Library/Logs/DiagnosticReports/Finder_2014-04-17-091030_MacBook-Pro-di-Fabio.crash
Apr 17 09:10:30 MacBook-Pro-di-Fabio ReportCrash[273]: Removing excessive log: file://localhost/Users/fabiobullegas/Library/Logs/DiagnosticReports/Finder_2014-04-14-101810_MacBook-Pro-di-Fabio.crash" onclick="window.open(this.href);return false;
Apr 17 09:10:34 MacBook-Pro-di-Fabio OverlayHelper[279]: --- Log opened Thu Apr 17 09:10:34 2014 ---
Apr 17 09:10:34 MacBook-Pro-di-Fabio OverlayHelper[279]: --- OverlayHelper ---
Apr 17 09:10:35 MacBook-Pro-di-Fabio InterCheck[57]: SXLC: Setting [key:SXLDNSIP1] [value:8.8.8.8]
Apr 17 09:10:35 MacBook-Pro-di-Fabio InterCheck[57]: SXLC: Setting [key:SXLDNSIP2] [value:8.8.4.4]
Apr 17 09:10:35 MacBook-Pro-di-Fabio InterCheck[57]: Live protection is Enabled
Apr 17 09:10:35 MacBook-Pro-di-Fabio OverlayLoader[279]: --- Log opened Thu Apr 17 09:10:35 2014 ---
Apr 17 09:10:35 MacBook-Pro-di-Fabio OverlayLoader[279]: --- OverlayLoader ---
Apr 17 09:10:38 MacBook-Pro-di-Fabio Vox Helper[196]: Non of media apps is launched
Apr 17 09:10:38 MacBook-Pro-di-Fabio Vox Helper[196]: Intersepting
Apr 17 09:10:43 MacBook-Pro-di-Fabio Vox Helper[196]: Non of media apps is launched
Apr 17 09:10:43 MacBook-Pro-di-Fabio Vox Helper[196]: Intersepting
Apr 17 09:10:49 MacBook-Pro-di-Fabio Vox Helper[196]: Non of media apps is launched
Apr 17 09:10:49 MacBook-Pro-di-Fabio Vox Helper[196]: Intersepting
Apr 17 09:10:56 MacBook-Pro-di-Fabio Vox Helper[196]: Non of media apps is launched
Apr 17 09:10:56 MacBook-Pro-di-Fabio Vox Helper[196]: Intersepting
Apr 17 09:10:56 MacBook-Pro-di-Fabio com.apple.launchd.peruser.501[138] (com.apple.Finder[274]): Job appears to have crashed: Segmentation fault: 11
Apr 17 09:10:56 MacBook-Pro-di-Fabio ReportCrash[273]: Saved crash report for Finder[274] version 10.7.5 (10.7.5) to /Users/fabiobullegas/Library/Logs/DiagnosticReports/Finder_2014-04-17-091056_MacBook-Pro-di-Fabio.crash
Apr 17 09:10:56 MacBook-Pro-di-Fabio ReportCrash[273]: Removing excessive log: file://localhost/Users/fabiobullegas/Library/Logs/DiagnosticReports/Finder_2014-04-14-101816_MacBook-Pro-di-Fabio.crash" onclick="window.open(this.href);return false;
Apr 17 09:11:03 MacBook-Pro-di-Fabio OverlayHelper[287]: --- Log opened Thu Apr 17 09:11:03 2014 ---
Apr 17 09:11:03 MacBook-Pro-di-Fabio OverlayHelper[287]: --- OverlayHelper ---
Apr 17 09:11:03 MacBook-Pro-di-Fabio OverlayLoader[287]: --- Log opened Thu Apr 17 09:11:03 2014 ---
Apr 17 09:11:03 MacBook-Pro-di-Fabio OverlayLoader[287]: --- OverlayLoader ---
Apr 17 09:11:04 MacBook-Pro-di-Fabio Vox Helper[196]: Non of media apps is launched
Apr 17 09:11:04 MacBook-Pro-di-Fabio Vox Helper[196]: Intersepting
Apr 17 09:11:04 MacBook-Pro-di-Fabio com.apple.launchd.peruser.501[138] (com.apple.Finder[283]): Job appears to have crashed: Bus error: 10
Apr 17 09:11:04 MacBook-Pro-di-Fabio ReportCrash[273]: Saved crash report for Finder[283] version 10.7.5 (10.7.5) to /Users/fabiobullegas/Library/Logs/DiagnosticReports/Finder_2014-04-17-091104_MacBook-Pro-di-Fabio.crash
Apr 17 09:11:04 MacBook-Pro-di-Fabio ReportCrash[273]: Removing excessive log: file://localhost/Users/fabiobullegas/Library/Logs/DiagnosticReports/Finder_2014-04-14-101822_MacBook-Pro-di-Fabio.crash" onclick="window.open(this.href);return false;
Apr 17 09:11:04 MacBook-Pro-di-Fabio Finder[288]: ISGetIconFamilyFromStorage: seed mismatch for 279f001a, actual seed is 257130a3
Apr 17 09:11:04 MacBook-Pro-di-Fabio Finder[288]: _GetISImageRefFromIconRefInternal: could not retain image ref 0x279f001a (err=-2580)
Apr 17 09:11:04 MacBook-Pro-di-Fabio Finder[288]: ISGetIconFamilyFromStorage: seed mismatch for 24c9001b, actual seed is 62bbd95a
Apr 17 09:11:04 MacBook-Pro-di-Fabio Finder[288]: _GetISImageRefFromIconRefInternal: could not retain image ref 0x24c9001b (err=-2580)
Apr 17 09:11:06 MacBook-Pro-di-Fabio Vox Helper[196]: Non of media apps is launched
Apr 17 09:11:06 MacBook-Pro-di-Fabio Vox Helper[196]: Intersepting
Apr 17 09:11:09 MacBook-Pro-di-Fabio OverlayHelper[292]: --- Log opened Thu Apr 17 09:11:09 2014 ---
Apr 17 09:11:09 MacBook-Pro-di-Fabio OverlayHelper[292]: --- OverlayHelper ---
Apr 17 09:11:09 MacBook-Pro-di-Fabio OverlayLoader[292]: --- Log opened Thu Apr 17 09:11:09 2014 ---
Apr 17 09:11:09 MacBook-Pro-di-Fabio OverlayLoader[292]: --- OverlayLoader ---
Apr 17 09:11:10 MacBook-Pro-di-Fabio Vox Helper[196]: Non of media apps is launched
Apr 17 09:11:10 MacBook-Pro-di-Fabio Vox Helper[196]: Intersepting
Apr 17 09:11:10 MacBook-Pro-di-Fabio com.apple.launchd.peruser.501[138] (com.apple.Finder[288]): Job appears to have crashed: Bus error: 10
Apr 17 09:11:10 MacBook-Pro-di-Fabio ReportCrash[273]: Saved crash report for Finder[288] version 10.7.5 (10.7.5) to /Users/fabiobullegas/Library/Logs/DiagnosticReports/Finder_2014-04-17-091110_MacBook-Pro-di-Fabio.crash
Apr 17 09:11:10 MacBook-Pro-di-Fabio ReportCrash[273]: Removing excessive log: file://localhost/Users/fabiobullegas/Library/Logs/DiagnosticReports/Finder_2014-04-14-101828_MacBook-Pro-di-Fabio.crash" onclick="window.open(this.href);return false;
Apr 17 09:11:13 MacBook-Pro-di-Fabio Vox Helper[196]: Non of media apps is launched
Apr 17 09:11:13 MacBook-Pro-di-Fabio Vox Helper[196]: Intersepting
Apr 17 09:11:15 MacBook-Pro-di-Fabio OverlayHelper[298]: --- Log opened Thu Apr 17 09:11:15 2014 ---
Apr 17 09:11:15 MacBook-Pro-di-Fabio OverlayHelper[298]: --- OverlayHelper ---
Apr 17 09:11:16 MacBook-Pro-di-Fabio OverlayLoader[298]: --- Log opened Thu Apr 17 09:11:16 2014 ---
Apr 17 09:11:16 MacBook-Pro-di-Fabio OverlayLoader[298]: --- OverlayLoader ---
Apr 17 09:11:16 MacBook-Pro-di-Fabio Vox Helper[196]: Non of media apps is launched
Apr 17 09:11:16 MacBook-Pro-di-Fabio Vox Helper[196]: Intersepting
Apr 17 09:11:16 MacBook-Pro-di-Fabio com.apple.launchd.peruser.501[138] (com.apple.Finder[293]): Job appears to have crashed: Segmentation fault: 11
Apr 17 09:11:16 MacBook-Pro-di-Fabio ReportCrash[273]: Saved crash report for Finder[293] version 10.7.5 (10.7.5) to /Users/fabiobullegas/Library/Logs/DiagnosticReports/Finder_2014-04-17-091116_MacBook-Pro-di-Fabio.crash
Apr 17 09:11:16 MacBook-Pro-di-Fabio ReportCrash[273]: Removing excessive log: file://localhost/Users/fabiobullegas/Library/Logs/DiagnosticReports/Finder_2014-04-14-101834_MacBook-Pro-di-Fabio.crash" onclick="window.open(this.href);return false;
Apr 17 09:11:19 MacBook-Pro-di-Fabio Vox Helper[196]: Non of media apps is launched
Apr 17 09:11:19 MacBook-Pro-di-Fabio Vox Helper[196]: Intersepting
Apr 17 09:11:21 MacBook-Pro-di-Fabio OverlayHelper[303]: --- Log opened Thu Apr 17 09:11:21 2014 ---
Apr 17 09:11:21 MacBook-Pro-di-Fabio OverlayHelper[303]: --- OverlayHelper ---
Apr 17 09:11:22 MacBook-Pro-di-Fabio OverlayLoader[303]: --- Log opened Thu Apr 17 09:11:22 2014 ---
Apr 17 09:11:22 MacBook-Pro-di-Fabio OverlayLoader[303]: --- OverlayLoader ---
Apr 17 09:11:23 MacBook-Pro-di-Fabio Vox Helper[196]: Non of media apps is launched
Apr 17 09:11:23 MacBook-Pro-di-Fabio Vox Helper[196]: Intersepting
Apr 17 09:11:23 MacBook-Pro-di-Fabio com.apple.launchd.peruser.501[138] (com.apple.Finder[299]): Job appears to have crashed: Bus error: 10
Apr 17 09:11:23 MacBook-Pro-di-Fabio ReportCrash[304]: Saved crash report for Finder[299] version 10.7.5 (10.7.5) to /Users/fabiobullegas/Library/Logs/DiagnosticReports/Finder_2014-04-17-091123_MacBook-Pro-di-Fabio.crash
Apr 17 09:11:23 MacBook-Pro-di-Fabio ReportCrash[304]: Removing excessive log: file://localhost/Users/fabiobullegas/Library/Logs/DiagnosticReports/Finder_2014-04-14-101841_MacBook-Pro-di-Fabio.crash" onclick="window.open(this.href);return false;
Apr 17 09:11:25 MacBook-Pro-di-Fabio Vox Helper[196]: Non of media apps is launched
Apr 17 09:11:25 MacBook-Pro-di-Fabio Vox Helper[196]: Intersepting
Apr 17 09:11:28 MacBook-Pro-di-Fabio OverlayHelper[311]: --- Log opened Thu Apr 17 09:11:28 2014 ---
Apr 17 09:11:28 MacBook-Pro-di-Fabio OverlayHelper[311]: --- OverlayHelper ---
Apr 17 09:11:28 MacBook-Pro-di-Fabio OverlayLoader[311]: --- Log opened Thu Apr 17 09:11:28 2014 ---
Apr 17 09:11:28 MacBook-Pro-di-Fabio OverlayLoader[311]: --- OverlayLoader ---
Apr 17 09:11:29 MacBook-Pro-di-Fabio Vox Helper[196]: Non of media apps is launched
Apr 17 09:11:29 MacBook-Pro-di-Fabio Vox Helper[196]: Intersepting
Apr 17 09:11:29 MacBook-Pro-di-Fabio com.apple.launchd.peruser.501[138] (com.apple.Finder[305]): Job appears to have crashed: Bus error: 10
Apr 17 09:11:29 MacBook-Pro-di-Fabio ReportCrash[304]: Saved crash report for Finder[305] version 10.7.5 (10.7.5) to /Users/fabiobullegas/Library/Logs/DiagnosticReports/Finder_2014-04-17-091129_MacBook-Pro-di-Fabio.crash
Apr 17 09:11:29 MacBook-Pro-di-Fabio ReportCrash[304]: Removing excessive log: file://localhost/Users/fabiobullegas/Library/Logs/DiagnosticReports/Finder_2014-04-14-101847_MacBook-Pro-di-Fabio.crash" onclick="window.open(this.href);return false;
Apr 17 09:11:31 MacBook-Pro-di-Fabio Vox Helper[196]: Non of media apps is launched
Apr 17 09:11:31 MacBook-Pro-di-Fabio Vox Helper[196]: Intersepting
Apr 17 09:11:34 MacBook-Pro-di-Fabio OverlayHelper[316]: --- Log opened Thu Apr 17 09:11:34 2014 ---
Apr 17 09:11:34 MacBook-Pro-di-Fabio OverlayHelper[316]: --- OverlayHelper ---
Apr 17 09:11:34 MacBook-Pro-di-Fabio OverlayLoader[316]: --- Log opened Thu Apr 17 09:11:34 2014 ---
Apr 17 09:11:34 MacBook-Pro-di-Fabio OverlayLoader[316]: --- OverlayLoader ---
Apr 17 09:11:35 MacBook-Pro-di-Fabio Vox Helper[196]: Non of media apps is launched
Apr 17 09:11:35 MacBook-Pro-di-Fabio Vox Helper[196]: Intersepting
Apr 17 09:11:35 MacBook-Pro-di-Fabio com.apple.launchd.peruser.501[138] (com.apple.Finder[312]): Job appears to have crashed: Bus error: 10
Apr 17 09:11:35 MacBook-Pro-di-Fabio ReportCrash[304]: Saved crash report for Finder[312] version 10.7.5 (10.7.5) to /Users/fabiobullegas/Library/Logs/DiagnosticReports/Finder_2014-04-17-091135_MacBook-Pro-di-Fabio.crash
Apr 17 09:11:35 MacBook-Pro-di-Fabio ReportCrash[304]: Removing excessive log: file://localhost/Users/fabiobullegas/Library/Logs/DiagnosticReports/Finder_2014-04-14-101853_MacBook-Pro-di-Fabio.crash" onclick="window.open(this.href);return false;
Apr 17 09:11:37 MacBook-Pro-di-Fabio Vox Helper[196]: Non of media apps is launched
Apr 17 09:11:37 MacBook-Pro-di-Fabio Vox Helper[196]: Intersepting
Apr 17 09:11:40 MacBook-Pro-di-Fabio OverlayHelper[321]: --- Log opened Thu Apr 17 09:11:40 2014 ---
Apr 17 09:11:40 MacBook-Pro-di-Fabio OverlayHelper[321]: --- OverlayHelper ---
Apr 17 09:11:40 MacBook-Pro-di-Fabio OverlayLoader[321]: --- Log opened Thu Apr 17 09:11:40 2014 ---
Apr 17 09:11:40 MacBook-Pro-di-Fabio OverlayLoader[321]: --- OverlayLoader ---
Apr 17 09:11:41 MacBook-Pro-di-Fabio Vox Helper[196]: Non of media apps is launched
Apr 17 09:11:41 MacBook-Pro-di-Fabio Vox Helper[196]: Intersepting
Apr 17 09:11:41 MacBook-Pro-di-Fabio com.apple.launchd.peruser.501[138] (com.apple.Finder[317]): Job appears to have crashed: Segmentation fault: 11
Apr 17 09:11:41 MacBook-Pro-di-Fabio ReportCrash[304]: Saved crash report for Finder[317] version 10.7.5 (10.7.5) to /Users/fabiobullegas/Library/Logs/DiagnosticReports/Finder_2014-04-17-091141_MacBook-Pro-di-Fabio.crash
Apr 17 09:11:41 MacBook-Pro-di-Fabio ReportCrash[304]: Removing excessive log: file://localhost/Users/fabiobullegas/Library/Logs/DiagnosticReports/Finder_2014-04-14-101859_MacBook-Pro-di-Fabio.crash" onclick="window.open(this.href);return false;
Apr 17 09:11:43 MacBook-Pro-di-Fabio Vox Helper[196]: Non of media apps is launched
Apr 17 09:11:43 MacBook-Pro-di-Fabio Vox Helper[196]: Intersepting
Apr 17 09:11:45 MacBook-Pro-di-Fabio Vox Helper[196]: Non of media apps is launched
Apr 17 09:11:45 MacBook-Pro-di-Fabio Vox Helper[196]: Intersepting
Apr 17 09:11:46 MacBook-Pro-di-Fabio OverlayHelper[327]: --- Log opened Thu Apr 17 09:11:46 2014 ---
Apr 17 09:11:46 MacBook-Pro-di-Fabio OverlayHelper[327]: --- OverlayHelper ---
Apr 17 09:11:46 MacBook-Pro-di-Fabio OverlayLoader[327]: --- Log opened Thu Apr 17 09:11:46 2014 ---
Apr 17 09:11:46 MacBook-Pro-di-Fabio OverlayLoader[327]: --- OverlayLoader ---
Apr 17 09:11:47 MacBook-Pro-di-Fabio Vox Helper[196]: Non of media apps is launched
Apr 17 09:11:47 MacBook-Pro-di-Fabio Vox Helper[196]: Intersepting
Apr 17 09:11:47 MacBook-Pro-di-Fabio com.apple.launchd.peruser.501[138] (com.apple.Finder[322]): Job appears to have crashed: Segmentation fault: 11
Apr 17 09:11:47 MacBook-Pro-di-Fabio ReportCrash[304]: Saved crash report for Finder[322] version 10.7.5 (10.7.5) to /Users/fabiobullegas/Library/Logs/DiagnosticReports/Finder_2014-04-17-091147_MacBook-Pro-di-Fabio.crash
Apr 17 09:11:47 MacBook-Pro-di-Fabio ReportCrash[304]: Removing excessive log: file://localhost/Users/fabiobullegas/Library/Logs/DiagnosticReports/Finder_2014-04-14-101905_MacBook-Pro-di-Fabio.crash" onclick="window.open(this.href);return false;
Apr 17 09:11:49 MacBook-Pro-di-Fabio Vox Helper[196]: Non of media apps is launched
Apr 17 09:11:49 MacBook-Pro-di-Fabio Vox Helper[196]: Intersepting
Apr 17 09:11:51 MacBook-Pro-di-Fabio com.apple.Finder[328]: Dropbox: Entered INJECT_pthread_entry
Apr 17 09:11:51 MacBook-Pro-di-Fabio com.apple.Finder[328]: Dropbox: Installing event loop timer
Apr 17 09:11:51 MacBook-Pro-di-Fabio com.apple.Finder[328]: Dropbox: proc: 0x1040a6e62
Apr 17 09:11:51 MacBook-Pro-di-Fabio com.apple.Finder[328]: Dropbox: upp: 0x1040a6e62
Apr 17 09:11:51 MacBook-Pro-di-Fabio com.apple.Finder[328]: Dropbox: InstallEventLoopTimer: 0x10362904e
Apr 17 09:11:51 MacBook-Pro-di-Fabio com.apple.Finder[328]: Dropbox: GetMainEventLoop: 0x1035ea749
Apr 17 09:11:51 MacBook-Pro-di-Fabio com.apple.Finder[328]: Dropbox: Loading /Library/DropboxHelperTools/Dropbox_u501/DropboxBundle.bundle/Contents/MacOS/DropboxBundle
Apr 17 09:11:51 MacBook-Pro-di-Fabio com.apple.Finder[328]: Dropbox: timer installed!
Apr 17 09:11:51 MacBook-Pro-di-Fabio com.apple.Finder[328]: Dropbox: dlopen returned: 0x7fde1a47bf10
