Turiddo1
- Maccanico attivo
Salve ho questo problema ho istallato pro X con tutte le librerie completo però
ho molti programmi esterni che si interfacciano poi con Logix. Sapete come si fà
ad aggiungere instruments a Logic? Io adesso questa cosa la faccio in Garageband
creo nuovi instruments che poi me li ritrovo in Logic, in pratica io volevo saltare questo
passaggio.
karmakode
- Maccanico assiduo
Se sono AU Components,te li deve vedere da se,non c'è da reinstallare nulla,ricorda che Logic Pro X è "solo" a 64 bit,quindi tutti i vecchi AU a 32 Bit non li caga nemmeno di striscio,per quanto riguarda strumenti tipo Kontakt,è la stessa cosa,ti serve l'ultima release del porgramma, e vedrai che caricherà da se tutte le relative librerie.
mauripucci
Ammesso e concesso che funzioni...
32 Lives
32 Lives is a 32-bit to 64-bit Audio-Units plug-ins adapter compatible with virtually all 64-bit Audio-Units hosts and 32-bit Audio-Units plug-ins.
Requires OS X 10.7.5 or above.
32 Lives is a 32-bit to 64-bit Audio-Units plug-ins adapter, and is compatible with virtually all 64-bit Audio-Units host applications.
In July 2013, Apple introduced Logic Pro X, the next-generation version of its professional audio software, bringing many new features and improvements and an updated user interface. Moving forward with new technologies, the new Logic Pro X is a modern, 64-bit only application, which means that older 32-bit plug-ins will no longer work in Logic Pro X. Previous projects that were created in Logic 9 or earlier that include 32-bit only plug-ins will not fully open in Logic Pro X.
Enter 32 Lives.
32 Lives is a new application, capable of generating 64-bit Audio Units versions of your loved and hard-earned 32-bit legacy plug-ins, helping you to cross over to the new Logic Pro X smoothly and transparently. Older Logic 9 sessions will completely load into Logic Pro X, including all presets, parameters and automation. No special re-wiring or routing is required. All your 32-bit only plug-ins will again re-appear in the plug-ins menu as they always did.
Features
Creates 64-bit adapter plug-ins for your 32-bit only Audio Units plug-ins
Transparently loads your legacy TC PowerCore, Abbey Road, URS and other plug-ins into Logic Pro X and other 64-bit Audio Units compatible DAW’s.
Fully compatible with older sessions, loads all presets, parameters and automation
Ultra-low latency and high CPU efficiency
GUI workflow is transparent and doesn't require additional clicks and windows
Compatible with Logic Pro X, Mainstage 3, Final Cut Pro X, Garageband X, Live 9, Digital Performer 8, Studio One 2, Audition CC, Tracktion 4, Triumph, QLab and others.
Compatible with OS X Snow Leopard, Lion, Mountain Lion and Mavericks
certo il costo: $99... non invita a provare
esiste comunque "
Try It"
http://www.soundradix.com/products/32-lives" onclick="window.open(this.href);return false;
Turiddo1
- Maccanico attivo
Si ti ringrazio sapevo perfettamente del fatto dei 32 e 64bit ho anche quel 32 live ma c'è anche
gratis AU Lab e Soundflower e scavalchi questo problema. Si sono AU (component) ma negli au
non me li vede però avevo risolto creando lo strumento da Garageband..
Turiddo1
- Maccanico attivo
Volevo segnalare che alla fine ho capito come si fà io cliccavo sul cmd sbagliato ecco perchè vedevo solo AU Apple
ho cliccato sull'instruments caricato (pulsante blu) e li ho trovato tutti i plugin esterni a Apple...
Visitano il forum: Google [Bot] e 49 ospiti
