Aggiornamento Pacifist
Charles Srstka aggiorna Pacifist alla versione 2.6.
Pacifist è uno storico shareware scritto in Cocoa e prodotto da CharlesSoft, che consente di estrarre dai "package" di Mac OS X (.pkg, .dmg, .zip, .tar, .tar.gz, .tar.bz2 e .xar) tutto quello che ci serve con estrema semplicità.
L'applicazione è utile per estrarre e reinstallare le applicazioni presenti nei dischi di Sistema senza bisogno di reinstallare tutto daccapo, e permette di verificare le installazioni e le kernel extension presenti nel Sistema.
È possibile usarlo gratuitamente, con il fastidio del ritardo iniziale di un messaggio che invita a registrarlo per 20 dollari, e si scarica qui.
http://www.charlessoft.com/" onclick="window.open(this.href);return false;
Release note:
• Compatibility with Mac OS X 10.6 “Snow Leopard”
• Added a QuickLook plug-in
• Added Simplified Chinese localization by Yunxuan He
• Added support for PKZIP, WinZip, and Info-Zip self-extracting .zip archives
• Added support for Zip64 archives
• Added support for bzip2-compressed .zip archives
• While extracting, the Verification phase is much faster
• The Verification phase is now optional and can be disabled in the preferences
• Fixed a bug that caused .xar, .pkg, and .zip files on some HTTP servers not to load properly
• Fixed a crashing bug that could occur while viewing packages with no resources
• Fixed a bug that caused some Leopard flat packages not to be read properly
• Fixed a bug that could cause the Logic Studio 9 discs to fail to load
• Fixed a few bugs that could cause spurious errors when extracting files from pre-Leopard packages
• Fixed a bug that could cause the resource forks not to be written properly for some files in pre-Leopard packages
• Fixed a bug that could cause symlinks to be extracted with an incorrect path content or omitted entirely
• Fixed a crashing bug that could occur while opening .zip files
• Fixed a bug that could cause the window for the image view to appear at an incorrect size
• Made some corrections to the localizations
• Miscellaneous bug fixes
yellons
è meglio di unrarx?
È… diverso.
Pacifist aggiornato alla versione 2.6.3 che risolve un bug relativo al trascinamento degli elementi nel Finder di Snow Leopard.
Mac
Oggetto del messaggio:
Messaggio da Mac »
yellons ha scritto:è meglio di unrarx?
unrarx serve per decomprmere i file rar, pacifist per aprire i package di installazione
Rilasciato il nuovo Pacifist 2.6.4 che non risolve ma scavalca un bug relativo al controllo di alcuni pacchetti in Snow Leopard, che risultavano erroneamente corrotti.
Per ora (nella versione 2.6.4) questo controllo verrà ignorato in quanto gli sviluppatori non sono ancora in grado di offrire una soluzione definitiva.
Curzio
Rilasciata la versione 3.0 dell'utilissimo Pacifist (MacOS X 10.4.11 e successivi):
http://www.macupdate.com/app/mac/6812/pacifist" onclick="window.open(this.href);return false;
(per caso, ci stava già qualche altro thread al riguardo?)
Curzio ha scritto:Rilasciata la versione 3.0 dell'utilissimo Pacifist (MacOS X 10.4.11 e successivi):
Grazie per la segnalazione!
Ricordo che è possibile usarlo gratuitamente, con il fastidio del ritardo iniziale di un messaggio che invita a registrarlo per 20 dollari, e si scarica qui.
(argomento unito con il thread esistente) ;)
Pacifist - 3.0.1
What's new:
Suppressed a number of “Duplicate XML Element” errors when loading some packages
Fixed a few crashing bugs
Fixed a bug that could cause the QuickLook plugin not to work on some systems
Using the “View” function on text files should now cause them to open in a standard text view like in 2.6.x instead of in the QuickLook viewer as in 3.0, allowing them to be selectable and searchable
Fixed a bug that could cause dates not to appear correctly in the verification reports
Fixed a bug that could cause resources not to load properly for packages inside disk images.
Requirements:
PPC / Intel, Mac OS X 10.4.11 or later.
pierecall
Scusate ragazzi io tempo fa sempre consultando il forum scaricai la versione 2.6.4 ( non ricordo se perchè era totalmente free o per quale altro motivo) Volevo domandare se,non utilizzandolo spesso come programma, va bene ancora mantenere la versione che vi ho citato oppure prelevo questa ultima versione,seppur con il piccolo fastidio che avete accennato della finestra che si apre all'inizio e che invita all'acquisto del programma ? ciao
gennaro
pierecall
Kernel Panic ha scritto:In generale è sempre meglio tenere la versione più aggiornata.
Allora procedo con il download della nuova versione :wink:
Pacifist - 3.0.3
Now uses code-signing information to prune extraneous files out of applications extracted using the “Search Receipts” feature
General improvements and bug fixes to the “Search Receipts” feature
Several Mountain Lion-related fixes
Fixed a bug that affected loading some Apple install discs such as Final Cut Studio and Logic Pro
All files in the .zip distribution of Pacifist are now free of resource forks and extended attributes, to keep third-party .zip unarchivers from failing to unarchive the extended attributes properly and invalidating Pacifist’s code signing
Text is now selectable in HTML files in the viewer
Miscellaneous bug fixes.
Pacifist - 3.0.4
Fixed a bug that could cause packages from versions of OS X older than 10.2 not to load
Fixed a bug that could cause spurious error messages on extracting the entirety of a mpkg
Fixed another Mountain Lion-specific bug
Got rid of some deprecated API usage.
Rilasciato Pacifist 3.0.6 che corregge solo un bug.
Fixed a bug that could cause loading distribution packages from non-file URLs not to work
Visitano il forum: Nessuno e 15 ospiti
