Buondì a tutti, ho cercato di mettere in atto i consigli ultimi fornitimi super gentilmente da Bonnie e Kundalini, ho riavviato il computer e poi ho cliccato etrecheck per un nuovo report ed ecco cosa è venuto fuori:
EtreCheck version: 3.4.7 (461)
Report generated 2018-04-18 14:24:30
Download EtreCheck from
https://etrecheck.com" onclick="window.open(this.href);return false;
Runtime: 2:43
Performance: Excellent
Problem: Computer is too slow
Hardware Information: ⓘ
MacBook Air (13-inch, Mid 2011)
MacBook Air - model: MacBookAir4,2
1 1,7 GHz Intel Core i5 (i5-2557M) CPU: 2-core
4 GB RAM Not upgradeable
BANK 0/DIMM0
2 GB DDR3 1333 MHz ok
BANK 1/DIMM0
Handoff/Airdrop2: not supported
Wireless: en0: 802.11 a/b/g/n
Battery: Health = Check Battery - Cycle count = 651
Video Information: ⓘ
Intel HD Graphics 3000 - VRAM: 384 MB
Color LCD 1440 x 900
Disk Information: ⓘ
APPLE SSD SM256C disk0: (251 GB) (Solid State - TRIM: Yes)
[Show SMART report]
(disk0s2) <not mounted> [APFS Container]: 250.79 GB
USB Information: ⓘ
USB20Bus
hub_device
USB20Bus
Apple Inc. FaceTime Camera (Built-in)
hub_device
USB Optical Mouse
Apple Inc. BRCM20702 Hub
Thunderbolt Information: ⓘ
Apple Inc. thunderbolt_bus
Virtual disks: ⓘ
Macintosh HD (disk1s1 - APFS) / [Startup]: 250.79 GB (41.95 GB free)
Encrypted: Yes (Unlocked)
Physical disk: disk0s2 250.79 GB (41.95 GB free)
(disk1s2) <not mounted> [Preboot]: 250.79 GB
(disk1s3) <not mounted> [Recovery]: 250.79 GB
(disk1s4) /private/var/vm [VM]: 250.79 GB
System Software: ⓘ
macOS High Sierra 10.13.4 (17E199) - Time since boot: less than an hour
Configuration files: ⓘ
/etc/hosts - Count: 1
Gatekeeper: ⓘ
Clean up: ⓘ
/System/Library/LaunchAgents/com.apple.corespeechd.plist
/System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd
Executable not found!
One orphan file found. [Clean up]
System Launch Agents: ⓘ
[failed] com.apple.corespeechd.plist (? ? ? - installed 2018-02-27) - /System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd: Executable not found!
[not loaded] 10 Apple tasks
[loaded] 188 Apple tasks
[running] 94 Apple tasks
System Launch Daemons: ⓘ
[not loaded] 33 Apple tasks
[loaded] 192 Apple tasks
[running] 110 Apple tasks
User Login Items: ⓘ
GoPro Importer SMLoginItem - Hidden (? 0 - installed 2016-01-02)
(/Applications/GoPro Studio.app/Contents/Library/LoginItems/GoPro Importer.app)
Internet Plug-ins: ⓘ
Flip4Mac WMV Plugin: 2.4.4.2 (installed 2012-10-26) [Lookup]
FlashPlayer-10.6: 29.0.0.140 (installed 2018-04-10) [Lookup]
QuickTime Plugin: 7.7.3 (installed 2018-04-12)
AdobePDFViewerNPAPI: 17.012.20098 (installed 2018-02-20) [Lookup]
AdobePDFViewer: 18.011.20036 (installed 2018-02-20) [Lookup]
Flash Player: 29.0.0.140 (installed 2018-04-10) [Lookup]
SharePointBrowserPlugin: 14.4.2 (installed 2014-06-22) [Lookup]
Google Earth Web Plug-in: 7.1 (installed 2018-02-13) [Lookup]
Silverlight: 5.1.50901.0 (installed 2018-04-18) [Lookup]
DirectorShockwave: 11.6.8r638 (installed 2012-10-04) [Lookup]
JavaAppletPlugin: Java 8 Update 121 build 13 (installed 2017-03-16) Check version
User internet Plug-ins: ⓘ
ConduitNPAPIPlugin: 1.0 (installed 2017-06-26) [Lookup]
RealPlayer Plugin: Unknown
Safari Extensions: ⓘ
None
3rd Party Preference Panes: ⓘ
Flash Player (installed 2018-03-27) [Lookup]
FUSE (installed 2017-09-21) [Lookup]
Java (installed 2017-03-16) [Lookup]
Tuxera NTFS (installed 2011-06-20) [Lookup]
Time Machine: ⓘ
Time Machine not configured!
Top Processes by CPU: ⓘ
10% WindowServer
3% RdrCEF
2% mdworker
2% mdworker
1% kernel_task
Top Processes by Memory: ⓘ
496 MB kernel_task
90 MB RdrCEF Helper
89 MB icdd
88 MB mds_stores
88 MB soagent
Input Output Process name
32 KB 29 KB mDNSResponder
13 KB 7 KB cloudd
4 KB 3 KB apsd
5 KB 3 KB netbiosd
4 KB 1 KB com.apple.WebKit.Networking
11.66 WindowServer
4.52 RdrCEF
0.30 hidd
0.30 com.apple.AmbientDisplayAgent
Virtual Memory Information: ⓘ
1.04 GB Available RAM
97 MB Free RAM
2.96 GB Used RAM
969 MB Cached files
7 MB Swap Used
Memory Clean: 6.4 (installed 2018-03-31)
Adobe Flash Player: (installed 2018-04-10)
Microsoft Silverlight Internet Browser Plugin: 5.1.50901.0 (installed 2018-04-18)
FUSE for macOS: (installed 2018-04-18)
2018-04-18 14:19:49 Last shutdown cause: -60 - Corrupt filesystem
2018-04-18 13:03:25 coreservicesd High CPU use [Open] [Details]
Ora evidenzio cio che mi sembra ancora da risolvere, che poi sono gli elementi con scritte in rosso, e chiedo lumi:
devo eliminare quanto segue?
Click the [
Con questi che faccio?
Elimino tutto?
Clean up: ⓘ
Pare che un recente arresto errato abbia causato il danneggiamento di non so quale file di sistema, come posso rimediare?
Inoltre:
ho provato a configurare Time Machine ma non ci son riuscito.
Devo dire che non lo ho mai usato e sicuramente ignoro anche solo come abilitarlo.
Vorrei anche un consiglio su quali Plug-ins vanno eliminati per alleggerire l'avvio di Safari e quali passi fare per eliminarli o spostarli?
Non so se mi sia sfuggito qualcosa?
Ancora un immenso grazie per l'aiuto a tutti ![Very Happy :D](./images/smilies/icon_biggrin.gif)
