Il mac non rispondeva ai comandi di riavvio,logout e spegnimento,poi ho riavviato il finder e tutto e' tornato nella norma!!!mentre succedeva questo,tutti gli altri comandi funzionavano!!!Ci capite qualcosa?!
02/07/10 15.30.28 Mail[3335] *** Assertion failure in -[ComposeBackEnd setAccount:], /SourceCache/Mail/Mail-1081/Compose.subproj/ComposeBackEnd.m:1522
ComposeBackEnd does not support explicitly setting an account
0 Message 0x00007fff879d0488 -[MFAssertionHandler _handleFailureWithPreamble:description:arguments:] + 137
1 Message 0x00007fff879d03ed -[MFAssertionHandler handleFailureInMethod:object:file:lineNumber:description:] + 220
2 Mail 0x0000000100144da8 0x0 + 4296297896
3 Foundation 0x00007fff8099064a _NSSetObjectValueAndNotify + 258
4 Mail 0x0000000100143396 0x0 + 4296291222
5 CoreFoundation 0x00007fff8768ad2c __invoking___ + 140
6 CoreFoundation 0x00007fff8768abfd -[NSInvocation invoke] + 141
7 Message 0x00007fff87811eb3 -[ThrowingInvocationOperation main] + 31
8 Message 0x00007fff878117f3 -[_MFInvocationOperation main] + 275
9 Foundation 0x00007fff8099d061 -[__NSOperationInternal start] + 681
10 Foundation 0x00007fff8099cd17 ____startOperations_block_invoke_2 + 99
11 libSystem.B.dylib 0x00007fff864281b0 _dispatch_call_block_and_release + 15
12 libSystem.B.dylib 0x00007fff86406751 _dispatch_worker_thread2 + 239
13 libSystem.B.dylib 0x00007fff86406088 _pthread_wqthread + 353
14 libSystem.B.dylib 0x00007fff86405f25 start_wqthread + 13
02/07/10 15.31.19 loginwindow[38] ERROR | -[ApplicationManager _instantOffTryQuitAllForRequstor:replyEvent:] | _instantOffTryQuitAllForRequstor - _vproc_set_global_on_demand returned error -2042127274
02/07/10 15.31.35 loginwindow[38] ERROR | -[ApplicationManager _instantOffTryQuitAllForRequstor:replyEvent:] | _instantOffTryQuitAllForRequstor - _vproc_set_global_on_demand returned error -2042127274
02/07/10 15.31.54 kernel hibernate image path: /var/vm/sleepimage
02/07/10 15.31.54 kernel sizeof(IOHibernateImageHeader) == 512
02/07/10 15.31.54 kernel Opened file /var/vm/sleepimage, size 4294967296, partition base 0xc805000, maxio 400000
02/07/10 15.31.54 kernel hibernate image major 14, minor 2, blocksize 512, pollers 5
02/07/10 15.31.54 kernel hibernate_alloc_pages flags 00000000, gobbling 0 pages
02/07/10 15.31.55 kernel /drv/ MacModule.cpp:261 powerStateWillChangeTo: flags=4 stateNumber=2
02/07/10 15.31.55 kernel /drv/ MacModule.cpp:266 powerStateWillChangeTo: found flag=kIOPMSleepCapability (4)
02/07/10 15.31.55 kernel NVEthernet::setLinkStatus - Valid but not Active
02/07/10 15.31.55 kernel AirPort: Link Down on en1. Reason 8 (Disassociated because station leaving).
02/07/10 15.31.56 kernel /drv/ MacModule.cpp:261 powerStateDidChangeTo: flags=4 stateNumber=2
02/07/10 15.31.56 kernel /drv/ MacModule.cpp:266 powerStateDidChangeTo: found flag=kIOPMSleepCapability (4)
02/07/10 15.31.56 kernel System SafeSleep
02/07/10 15.32.08 kernel hibernate_page_list_setall start
02/07/10 15.32.08 kernel hibernate_page_list_setall time: 244 ms
02/07/10 15.32.08 kernel pages 562573, wire 133320, act 171979, inact 267, spec 27, zf 859, throt 0, could discard act 36161 inact 157602 purgeable 5546 spec 56812
02/07/10 15.32.08 kernel hibernate_page_list_setall found pageCount 306452
02/07/10 15.32.08 kernel IOHibernatePollerOpen, ml_get_interrupts_enabled 0
02/07/10 15.32.08 kernel IOHibernatePollerOpen(0)
02/07/10 15.32.08 kernel writing 304027 pages
02/07/10 15.32.08 kernel image1Size 337446400
02/07/10 15.32.08 kernel PMStats: Hibernate write took 10787 ms
02/07/10 15.32.08 kernel all time: 10787 ms, comp time: 1787 ms, deco time: 0 ms,
02/07/10 15.32.08 kernel image 708914176, uncompressed 1245593600 (304100), compressed 700956832 (56%), sum1 74a2371e, sum2 c432161b
02/07/10 15.32.08 kernel hibernate_write_image done(0)
02/07/10 15.32.08 kernel sleep
02/07/10 15.32.08 kernel Wake reason = OHC2
02/07/10 15.32.08 kernel System Wake
02/07/10 15.32.08 kernel /drv/ MacModule.cpp:261 powerStateWillChangeTo: flags=82 stateNumber=4
02/07/10 15.32.08 kernel /drv/ MacModule.cpp:262 powerStateWillChangeTo: found flag=kIOPMPowerOn (2)
02/07/10 15.32.08 kernel /drv/ MacModule.cpp:267 powerStateWillChangeTo: found flag=kIOPMRestartCapability (80)
02/07/10 15.32.08 kernel /drv/ MacModule.cpp:261 powerStateDidChangeTo: flags=82 stateNumber=4
02/07/10 15.32.08 kernel /drv/ MacModule.cpp:262 powerStateDidChangeTo: found flag=kIOPMPowerOn (2)
02/07/10 15.32.08 kernel /drv/ MacModule.cpp:267 powerStateDidChangeTo: found flag=kIOPMRestartCapability (80)
02/07/10 15.32.08 kernel Previous Sleep Cause: 5
02/07/10 15.32.08 kernel The USB device BRCM2046 Hub (Port 1 of Hub at 0x6000000) may have caused a wake by issuing a remote wakeup
02/07/10 15.32.08 kernel en1: 802.11d country code set to 'X3'.
02/07/10 15.32.08 kernel en1: Supported channels 1 2 3 4 5 6 7 8 9 10 11 12 13 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140
02/07/10 15.32.08 kernel The USB device Bluetooth USB Host Controller (Port 1 of Hub at 0x6100000) may have caused a wake by issuing a remote wakeup
02/07/10 15.32.08 kernel EIR is supported.
02/07/10 15.32.08 kernel SSP is supported.
02/07/10 15.32.09 kernel NVEthernet::setLinkStatus - Valid but not Active
02/07/10 15.32.09 kernel en1: 802.11d country code set to 'IT'.
02/07/10 15.32.09 kernel en1: Supported channels 1 2 3 4 5 6 7 8 9 10 11 12 13 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140
02/07/10 15.32.09 kernel Auth result for: 90:84:0d:d7:b9:77 MAC AUTH succeeded
02/07/10 15.32.09 kernel AirPort: Link Up on en1
02/07/10 15.32.09 kernel AirPort: RSN handshake complete on en1
02/07/10 15.32.13 loginwindow[38] ERROR | -[ApplicationManager _instantOffTryQuitAllForRequstor:replyEvent:] | _instantOffTryQuitAllForRequstor - _vproc_set_global_on_demand returned error -2042127274
02/07/10 15.33.27 loginwindow[38] ERROR | -[ApplicationManager _instantOffTryQuitAllForRequstor:replyEvent:] | _instantOffTryQuitAllForRequstor - _vproc_set_global_on_demand returned error -2042127274
02/07/10 15.34.10 com.apple.launchd.peruser.501[113] (com.apple.AirPortBaseStationAgent[138]) Exited: Killed
02/07/10 15.34.10 com.apple.launchd.peruser.501[113] (com.apple.Finder[119]) Exited: Terminated
02/07/10 15.34.10 kernel systemShutdown true
02/07/10 15.34.11 loginwindow[38] DEAD_PROCESS: 38 console
02/07/10 15.34.11 loginwindow[38] kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
02/07/10 15.34.11 com.apple.loginwindow[38] Fri Jul 2 15:34:11 TEGO.local loginwindow[38] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
02/07/10 15.34.11 loginwindow[38] PScurrentwindowbounds: CGSGetWindowBounds returned error (1002)
02/07/10 15.34.11 com.apple.loginwindow[38] 2010-07-02 15:34:11.347 loginwindow[38:107] PScurrentwindowbounds: CGSGetWindowBounds returned error (1002)
02/07/10 15.34.11 com.apple.loginwindow[38] Fri Jul 2 15:34:11 TEGO.local loginwindow[38] <Warning>: CGSShutdownServerConnections: Detaching application from window server
02/07/10 15.34.11 loginwindow[38] CGSShutdownServerConnections: Detaching application from window server
02/07/10 15.34.11 AppleVNCServer[133] CGSShutdownServerConnections: Detaching application from window server
02/07/10 15.34.11 AppleVNCServer[133] CGSDisplayServerShutdown: Detaching display subsystem from window server
02/07/10 15.34.11 AppleVNCServer[133] CGSGetNextEventRecord err 1002
02/07/10 15.34.11 com.apple.ScreenSharing.server[133] Fri Jul 2 15:34:11 TEGO.local AppleVNCServer[133] <Warning>: CGSShutdownServerConnections: Detaching application from window server
02/07/10 15.34.11 com.apple.ScreenSharing.server[133] Fri Jul 2 15:34:11 TEGO.local AppleVNCServer[133] <Warning>: CGSDisplayServerShutdown: Detaching display subsystem from window server
02/07/10 15.34.11 loginwindow[38] CGSDisplayServerShutdown: Detaching display subsystem from window server
02/07/10 15.34.11 com.apple.loginwindow[38] Fri Jul 2 15:34:11 TEGO.local loginwindow[38] <Warning>: CGSDisplayServerShutdown: Detaching display subsystem from window server
02/07/10 15.34.11 /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow[3372] Login Window Application Started
02/07/10 15.34.11 com.apple.SecurityServer[21] Session 0x305698 dead
02/07/10 15.34.11 com.apple.SecurityServer[21] Killing auth hosts
02/07/10 15.34.11 com.apple.SecurityServer[21] Session 0x305698 destroyed
02/07/10 15.34.12 com.apple.SecurityServer[21] Session 0x34dfd7 created
02/07/10 15.34.12 com.apple.SecurityServer[21] Session 0x34dfd7 attributes 0x30
02/07/10 15.34.13 loginwindow[3372] Login Window Started Security Agent
02/07/10 15.34.13 WindowServer[3373] kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
02/07/10 15.34.13 com.apple.WindowServer[3373] Fri Jul 2 15:34:13 TEGO.local WindowServer[3373] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
02/07/10 15.34.13 SecurityAgent[3383] Showing Login Window
02/07/10 15.34.21 SecurityAgent[3383] User info context values set for macbookpro485
02/07/10 15.34.21 SecurityAgent[3383] Login Window Showing Progress
02/07/10 15.34.21 SecurityAgent[3383] Login Window done
02/07/10 15.34.21 loginwindow[3372] Login Window - Returned from Security Agent
02/07/10 15.34.21 loginwindow[3372] USER_PROCESS: 3372 console
02/07/10 15.34.22 com.apple.launchd.peruser.501[113] (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
02/07/10 15.34.27 SystemUIServer[3391] MenuCracker 2.0 (/Users/macbookpro485/Library/PreferencePanes/MenuMeters.prefPane/Contents/Resources/MenuCracker.menu)
MenuCracker is now loaded. Ready to accept new menu extras. Ignore the failure message that follows.
02/07/10 15.34.27 SystemUIServer[3391] failed to instantiate and get the principal class of bundle: NSBundle </Users/macbookpro485/Library/PreferencePanes/MenuMeters.prefPane/Contents/Resources/MenuCracker.menu> (loaded)
02/07/10 15.34.28 com.apple.launchd.peruser.501[113] (com.apple.Kerberos.renew.plist[3409]) Exited with exit code: 1
02/07/10 15.34.30 SystemUIServer[3391] MenuCracker: Allowing "MenuMeterNetExtra".
02/07/10 15.34.31 SystemUIServer[3391] MenuMeterNet loaded.
02/07/10 15.34.31 SystemUIServer[3391] MenuCracker: Allowing "MenuMeterMemExtra".
02/07/10 15.34.31 SystemUIServer[3391] MenuMeterMem loaded.
02/07/10 15.34.31 SystemUIServer[3391] MenuCracker: Allowing "MenuMeterCPUExtra".
02/07/10 15.34.31 SystemUIServer[3391] MenuMeterCPU loaded.
02/07/10 15.34.40 com.apple.launchd.peruser.501[113] (com.apple.AirPortBaseStationAgent[3411]) Exited: Killed
02/07/10 15.34.40 loginwindow[3372] DEAD_PROCESS: 3372 console
02/07/10 15.34.40 kernel systemShutdown true
02/07/10 15.34.40 shutdown[3420] halt by macbookpro485:
02/07/10 15.34.40 shutdown[3420] SHUTDOWN_TIME: 1278077680 766881
02/07/10 15.34.40 mDNSResponder[17] getHelperPort: cannot contact helper
02/07/10 15.34.40 WindowServer[3373] hidd died. Reestablishing connection.
02/07/10 15.34.40 DirectoryService[11] BUG in libdispatch: 10F569 - 1960 - 0x10004004
02/07/10 15.34.40 com.apple.SecurityServer[21] Session 0x34dfd7 dead
02/07/10 15.34.40 com.apple.SecurityServer[21] Killing auth hosts
02/07/10 15.34.40 com.apple.SecurityServer[21] Session 0x34dfd7 destroyed
02/07/10 15.34.40 WindowServer[3373] Unable to create event queue via hidd: (0x10000003)
02/07/10 15.34.41 mDNSResponder[17] mDNSDynamicStoreSetConfig: Mach communication failed: (ipc/send) invalid destination port
02/07/10 15.34.41 mDNSResponder[17] mDNSResponder mDNSResponder-214.3.2 (May 14 2010 15:29:49) stopping
02/07/10 15.34.41 kernel Kext loading now disabled.
02/07/10 15.34.41 kernel Kext unloading now disabled.
02/07/10 15.34.41 kernel Kext autounloading now disabled.
02/07/10 15.34.41 kernel Kernel requests now disabled.
