Sep 7 17:54:09 MBPdiOMISSIS com.apple.xpc.launchd[1] (com.apple.quicklook[487]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.quicklook
Sep 7 17:54:38 MBPdiOMISSIS com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.domain.501.100005.Aqua): Caller not allowed to perform action: plugin-containe.488, action = pid-local registration, code = 1: Operation not permitted, uid = 501, euid = 501, gid = 20, egid = 20, asid = 100005
Sep 7 17:54:43 --- last message repeated 2 times ---
Sep 7 17:54:43 MBPdiOMISSIS Dock[246]: BUG in libdispatch client: kevent[EVFILT_MACHPORT] monitored resource vanished before the source cancel handler was invoked
Sep 7 17:55:09 MBPdiOMISSIS garcon[446]: Garcon destroyed (0 alive).
Sep 7 17:55:09 MBPdiOMISSIS com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.domain.501.100005.Aqua): Caller not allowed to perform action: loginwindow.95, action = service removal, code = 150: Operation not permitted while System Integrity Protection is engaged, uid = 0, euid = 501, gid = 20, egid = 20, asid = 100005
Sep 7 17:55:09 MBPdiOMISSIS com.apple.xpc.launchd[1] (com.apple.universalaccessAuthWarn[433]): Service exited due to signal: Killed: 9 sent by loginwindow[95]
Sep 7 17:55:09 MBPdiOMISSIS com.apple.xpc.launchd[1] (com.apple.SystemUIServer.agent[248]): Service exited due to signal: Killed: 9 sent by loginwindow[95]
Sep 7 17:55:09 MBPdiOMISSIS com.apple.xpc.launchd[1] (com.apple.noticeboard.agent[355]): Service exited due to signal: Killed: 9 sent by loginwindow[95]
Sep 7 17:55:09 MBPdiOMISSIS com.apple.xpc.launchd[1] (com.apple.cloudphotosd[277]): Service exited due to signal: Killed: 9 sent by loginwindow[95]
Sep 7 17:55:09 MBPdiOMISSIS com.apple.xpc.launchd[1] (com.apple.wifi.WiFiAgent[357]): Service exited due to signal: Killed: 9 sent by loginwindow[95]
Sep 7 17:55:09 MBPdiOMISSIS com.apple.xpc.launchd[1] (com.apple.AirPlayUIAgent[353]): Service exited due to signal: Killed: 9 sent by loginwindow[95]
Sep 7 17:55:09 MBPdiOMISSIS com.apple.xpc.launchd[1] (com.apple.imklaunchagent[346]): Service exited due to signal: Killed: 9 sent by loginwindow[95]
Sep 7 17:55:09 MBPdiOMISSIS com.apple.xpc.launchd[1] (com.apple.coreservices.uiagent[453]): Service exited due to signal: Killed: 9 sent by loginwindow[95]
Sep 7 17:55:09 MBPdiOMISSIS com.apple.xpc.launchd[1] (com.apple.ViewBridgeAuxiliary[387]): Service exited due to signal: Killed: 9 sent by loginwindow[95]
Sep 7 17:55:09 MBPdiOMISSIS com.apple.xpc.launchd[1] (com.apple.Siri.agent[347]): Service exited with abnormal code: 1
Sep 7 17:55:09 MBPdiOMISSIS com.apple.xpc.launchd[1] (com.apple.FolderActionsDispatcher[338]): Service exited due to signal: Killed: 9 sent by loginwindow[95]
Sep 7 17:55:09 MBPdiOMISSIS com.apple.xpc.launchd[1] (com.apple.lateragent[444]): Service exited due to signal: Killed: 9 sent by loginwindow[95]
Sep 7 17:55:09 MBPdiOMISSIS loginwindow[95]: BUG in libdispatch client: kevent[EVFILT_MACHPORT] monitored resource vanished before the source cancel handler was invoked
Sep 7 17:55:09 MBPdiOMISSIS sessionlogoutd[499]: DEAD_PROCESS: 95 console
Sep 7 17:55:09 MBPdiOMISSIS shutdown[500]: SHUTDOWN_TIME: 1504799709 883320
Sep 8 12:27:20 MacBook-Pro-di-OMISSIS com.apple.xpc.launchd[1] (com.apple.DwellControl.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Sep 8 12:27:20 MacBook-Pro-di-OMISSIS com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.domain.501.100005.Aqua): Service sets EnableTransactions=false and EnablePressuredExit=true, which makes no sense. Enabling Transactions.
Sep 8 12:27:20 --- last message repeated 4 times ---
Sep 8 12:27:20 MacBook-Pro-di-OMISSIS com.apple.xpc.launchd[1] (com.apple.gamed): The ServiceIPC key is no longer respected. Please remove it.
Sep 8 12:27:20 --- last message repeated 1 time ---
Sep 8 12:27:20 MacBook-Pro-di-OMISSIS com.apple.xpc.launchd[1] (com.apple.icdd): This service is defined to be constantly running and is inherently inefficient.
Hai qualche problema?Demart81 ha scritto:... ho aperto Console (dopo uno spegnimento buono) e nel log di avvio compaiono messaggi del genere...
... Non so, occorre qualche altro intervento prima (o dopo) il ripristino?
E allora va bene cosìDemart81 ha scritto:No, tutto regolare...
Questa è una cosa che riguarda l'efficienza hardwareDemart81 ha scritto:... a copiare cose da/a HD esterno o pendrive a volte esce la rotella colorata e non mi pare molto veloce...
Non ci posso fare nulla.Demart81 ha scritto:... i problemi li ho a volte con il caricamento pagine Firefox...
Dei supporti esterni o del computer?faxus ha scritto:Questa è una cosa che riguarda l'efficienza hardwareDemart81 ha scritto:... a copiare cose da/a HD esterno o pendrive a volte esce la rotella colorata e non mi pare molto veloce...
Su un Mac di due anni?Demart81 ha scritto:Pensi possa essere tipo obsolescenza programmata?
Non so cosa sono i supporti esterni...Demart81 ha scritto:... Dei supporti esterni o del computer?
Mannò, chiavette e HD esterno dicofaxus ha scritto:Su un Mac di due anni?Demart81 ha scritto:Pensi possa essere tipo obsolescenza programmata?
Ed entro il periodo di Apple Care.
Ma via...
]Non so cosa sono i supporti esterni...Demart81 ha scritto:... Dei supporti esterni o del computer?
Comunque, se l'avessi saputo, eventualmente ti saresti risparmiato il viaggio all'assistenza
Non si copiano MAI le applicazioni dal backup, nelle installazioni pulite!Demart81 ha scritto:... ricopiando delle app dal backup...
Visitano il forum: Nessuno e 37 ospiti
