diskutil list
sudo systemsetup -liststartupdisks
faxus ha scritto:Per controllare la situazione, puoi postare la risposta a questi comandi di Terminale?Codice: Seleziona tutto
diskutil list
Per favore la risposta come testo, tra i tag Code (codice)Codice: Seleziona tutto
E quello che vedi in Preferenze di Sistema, Disco d'avvio, è una annotazione distinta e chiara, così:
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme *500.3 GB disk0
1: EFI EFI 209.7 MB disk0s1
2: Apple_HFS Sistema 499.4 GB disk0s2
3: Apple_Boot Recovery HD 650.0 MB disk0s3
/dev/disk1 (internal, physical):
0: FDisk_partition_scheme *127.9 GB disk1
1: Windows_NTFS Senza titol 127.8 GB disk1s1
/System/Library/CoreServices
Hardware Information: ⓘ
MacBook Pro (Retina, 15-inch, Late 2013)
MacBook Pro - model: MacBookPro11,3
1 2,3 GHz Intel Core i7 (i7-4850HQ) CPU: 4-core
16 GB RAM Not upgradeable
BANK 0/DIMM0
8 GB DDR3 1600 MHz ok
BANK 1/DIMM0
Wireless: en0: 802.11 a/b/g/n/ac
Battery: Health = Normal - Cycle count = 825
Video Information: ⓘ
Intel Iris Pro
Color LCD 2880 x 1800
NVIDIA GeForce GT 750M - VRAM: 2048 MB
System Software: ⓘ
OS X El Capitan 10.11.6 (15G1212) - Time since boot: less than an hour
Disk Information: ⓘ
APPLE SSD SM0512F disk0 : (500,28 GB) (Solid State - TRIM: Yes)
[Show SMART report]
Sistema (disk0s2) / [Startup]: 499.42 GB (215.53 GB free)
USB Information: ⓘ
Apple Card Reader 127,86 GB
ExT (disk1s1) /Volumes/ExT : 127.85 GB (41.48 GB free)
Apple Inc. BRCM20702 Hub
Thunderbolt Information: ⓘ
Apple Inc. thunderbolt_bus
Configuration files: ⓘ
System Integrity Protection status: disabled
Gatekeeper: ⓘ
Kernel Extensions: ⓘ
/Library/Application Support/Roxio
[not loaded] com.roxio.TDIXController (2.0 - 2016-03-28) [Support]
/Library/Extensions
[loaded] at.obdev.nke.LittleSnitch (3.6 - SDK 10.8 - 2016-12-14) [Support]
System Launch Agents: ⓘ
[not loaded] 6 Apple tasks
[loaded] 164 Apple tasks
[running] 68 Apple tasks
System Launch Daemons: ⓘ
[not loaded] 48 Apple tasks
[loaded] 165 Apple tasks
[running] 76 Apple tasks
Launch Agents: ⓘ
[running] at.obdev.LittleSnitchUIAgent.plist (2016-06-13) [Support]
[running] com.bjango.istatmenusagent.plist (2016-01-13) [Support]
[running] com.bjango.istatmenusstatus.plist (2016-01-13) [Support]
Launch Daemons: ⓘ
[running] at.obdev.littlesnitchd.plist (2016-06-13) [Support]
[running] com.bjango.istatmenusdaemon.plist (2016-01-13) [Support]
User Launch Agents: ⓘ
[running] com.vladalexa.MagicPrefs.plist (2016-12-15) [Support]
User Login Items: ⓘ
Translate Tab Applicazione
(/Applications/Translate Tab.app)
Internet Plug-ins: ⓘ
Silverlight: 5.1.50428.0 - SDK 10.6 (2016-07-11) [Support]
FlashPlayer-10.6: 24.0.0.186 - SDK 10.9 (2016-12-15) [Support]
QuickTime Plugin: 7.7.3 (2016-12-14)
Flash Player: 24.0.0.186 - SDK 10.9 (2016-12-15) [Support]
PepperFlashPlayer: 24.0.0.186 - SDK 10.9 (2016-12-15) [Support]
Default Browser: 601 - SDK 10.11 (2016-09-23)
User internet Plug-ins: ⓘ
Google Earth Web Plug-in: 7.0 (2013-02-27) [Support]
Safari Extensions: ⓘ
1Password - AgileBits - https://agilebits.com/onepassword (2016-11-21)
Adblock Plus - Eyeo GmbH - https://adblockplus.org/ (2016-11-16)
Open in Internet Explorer - Parallels - http://www.parallels.com (2016-01-14)
3rd Party Preference Panes: ⓘ
Flash Player (2016-12-11) [Support]
MagicPrefs (2016-11-12) [Support]
Tuxera NTFS (2016-03-17) [Support]
Time Machine: ⓘ
Skip System Files: NO
Mobile backups: OFF
Volumes being backed up:
Sistema: Disk size: 499.42 GB Disk used: 283.89 GB
Destinations:
Senza titolo [Local]
Total size: 2.00 TB
Total number of backups: 20
Oldest backup: 14/01/16, 13:47
Last backup: 18/11/16, 13:30
Size of backup disk: Excellent
Backup size 2.00 TB > (Disk size 499.42 GB X 3)
Top Processes by CPU: ⓘ
4% kernel_task
3% WindowServer
3% MagicPrefs
2% fontd
1% hidd
Top Processes by Memory: ⓘ
942 MB kernel_task
770 MB com.apple.WebKit.WebContent(4)
393 MB Safari
197 MB Dock
131 MB WindowServer
Virtual Memory Information: ⓘ
12.13 GB Available RAM
9.30 GB Free RAM
3.87 GB Used RAM
2.84 GB Cached files
0 B Swap Used
Diagnostics Information: ⓘ
Dec 15, 2016, 08:44:35 PM Self test - passed
Dec 15, 2016, 04:07:21 PM /Library/Logs/DiagnosticReports/Safari_2016-12-15-160721_[redacted].crash
com.apple.Safari - /Applications/Safari.app/Contents/MacOS/Safari
Dec 15, 2016, 01:15:27 PM ~/Library/Logs/DiagnosticReports/Finder_2016-12-15-131527_[redacted].crash
com.apple.finder - /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
Il sip l'avevo disabilitato temporaneamente per cambiare delle icone, mi ero scordato di riattivarlo, grazie di avermelo fatto notare.faxus ha scritto:Bah... Apparentemente non c'è nulla che indichi qualcosa di significativo.
C'è qualche motivo per cui disabiliti il SIP?
Non ne vedo la necessità, da quel che vedo.
(Non che ci sia qualcosa di male, io neanche lo abilito, ma ho dei giustificati e vari motivi)
Le applicazioni vanno aggiornate, non importa altro, ma vanno aggiornate.
Aggiorna Tuxera e IstatMenus, almeno (anche Silverlight).
Volevo evitare, ma pare indispensabile...
Posta un syslog di un avvio.
Apri Console, sulla barra laterale scegli System.log.
Appuntati con precisione l'ora.
Poi riavvia subito, riapri Console, copia e incolla il log dall'ora appuntata fino a quando hai spento o trovi SHUTDOWN.
Da lì copia solo 100 righe, gentilmente non postare centinaia e centinaia di righe inopportunamente
Posta come testo tra i tag Code, per favore.
Disabilita le faccine e controlla che non appaiano i tuoi dati personali
Dec 15 21:43:12 MacBook-Pro Notes[452]: Failed to connect (iconWidthConstraint) outlet from (ICMNoteEditorDateView) to (NSLayoutConstraint): missing setter or instance variable
Dec 15 21:43:12 MacBook-Pro nehelper[174]: Metadata.framework [Error]: couldn't get the client port
Dec 15 21:43:12 MacBook-Pro nehelper[174]: Failed to start a query for com.apple.Notes
Dec 15 21:43:13 MacBook-Pro AppleSpell[454]: Lexicon creation failed: Lexicon resources not found
Dec 15 21:43:13 MacBook-Pro com.apple.InputMethodKit.TextReplacementService[456]: -[PFUbiquitySwitchboardEntryMetadata setUseLocalStorage:](898): CoreData: Ubiquity: amaidek~B5258EBD-F372-5E09-B166-72572455D369:UserDictionary
Using local storage: 1 for new NSFileManager current token <53af4e11 6f70cef1 b8aff95d 6234fbed 38be4f1f>
Dec 15 21:43:13 MacBook-Pro nehelper[174]: Metadata.framework [Error]: couldn't get the client port
Dec 15 21:43:13 MacBook-Pro nehelper[174]: Failed to start a query for com.apple.clouddocs.com.apple.CloudDocs.container-metadata
Dec 15 21:43:13 MacBook-Pro Notes[452]: Metadata.framework [Error]: couldn't get the client port
Dec 15 21:43:13 MacBook-Pro Notes[452]: Could not launch query, mds might have an issue
Dec 15 21:43:14 MacBook-Pro nehelper[174]: Metadata.framework [Error]: couldn't get the client port
Dec 15 21:43:14 MacBook-Pro nehelper[174]: Failed to start a query for com.apple.clouddocs.com.apple.SharedDocs
Dec 15 21:43:14 MacBook-Pro secd[302]: securityd_xpc_dictionary_handler cloudd[374] copy_matching Error Domain=NSOSStatusErrorDomain Code=-50 "query missing class name" (paramErr: error in user parameter list) UserInfo={NSDescription=query missing class name}
Dec 15 21:43:14 MacBook-Pro cloudd[374]: SecOSStatusWith error:[-50] Error Domain=NSOSStatusErrorDomain Code=-50 "query missing class name" (paramErr: error in user parameter list) UserInfo={NSDescription=query missing class name}
Dec 15 21:43:14 MacBook-Pro com.apple.InputMethodKit.TextReplacementService[456]: -[PFUbiquitySwitchboardEntryMetadata setUseLocalStorage:](898): CoreData: Ubiquity: amaidek~B5258EBD-F372-5E09-B166-72572455D369:UserDictionary
Using local storage: 0 for new NSFileManager current token <53af4e11 6f70cef1 b8aff95d 6234fbed 38be4f1f>
Dec 15 21:43:14 MacBook-Pro nehelper[174]: Failed to start a query for com.apple.Notes
Dec 15 21:43:15 MacBook-Pro nehelper[174]: Metadata.framework [Error]: couldn't get the client port
Dec 15 21:43:15 MacBook-Pro nehelper[174]: Failed to start a query for com.apple.Notes
Dec 15 21:43:15 MacBook-Pro Notes[452]: Continuing migration if necessary
Dec 15 21:43:15 MacBook-Pro Notes[452]: Already finished with migration
Dec 15 21:43:24 MacBook-Pro com.apple.AddressBook.ContactsAccountsService[311]: [Accounts] Current connection, <NSXPCConnection: 0x7fd7a2513b90> connection from pid 457, doesn't have account access.
Dec 15 21:43:24 MacBook-Pro DataDetectorsDynamicData[457]: [Accounts] Failed to update account with identifier 37D882B0-17C6-416D-9FAB-B4F09A1EC53C, error: Error Domain=ABAddressBookErrorDomain Code=1002 "(null)"
Dec 15 21:43:24 MacBook-Pro sharingd[316]: 21:43:24.157 : SDConnectionManager:: XPC connection invalidated
Dec 15 21:43:32 MacBook-Pro Safari[421]: KeychainGetICDPStatus: keychain: -25300
Dec 15 21:43:32 MacBook-Pro Safari[421]: KeychainGetICDPStatus: status: off
Dec 15 21:43:32 MacBook-Pro com.apple.xpc.launchd[1] (com.apple.WebKit.Networking.D0099059-8ED9-4CD0-97B9-340C8C5ADF13[425]): Service exited with abnormal code: 1
Dec 15 21:43:32 MacBook-Pro com.apple.xpc.launchd[1] (com.apple.WebKit.Databases.1AF2E8FE-5540-4288-B12C-3FEF705BB194[448]): Service exited with abnormal code: 1
Dec 15 21:43:32 MacBook-Pro NewFileHereMenu[372]: host connection <NSXPCConnection: 0x7f98e261ecb0> connection from pid 290 invalidated
Dec 15 21:43:32 MacBook-Pro WindowServer[155]: CGXGetConnectionProperty: Invalid connection 56591
Dec 15 21:43:32 --- last message repeated 4 times ---
Dec 15 21:43:32 MacBook-Pro loginwindow[88]: Login Window point of no return
Dec 15 21:43:32 MacBook-Pro com.apple.xpc.launchd[1] (com.apple.AirPlayUIAgent[347]): Service exited due to signal: Killed: 9
Dec 15 21:43:32 MacBook-Pro com.apple.xpc.launchd[1] (com.apple.coreservices.uiagent[402]): Service exited due to signal: Killed: 9
Dec 15 21:43:32 MacBook-Pro com.apple.xpc.launchd[1] (com.apple.powerchime[345]): Service exited due to signal: Killed: 9
Dec 15 21:43:32 MacBook-Pro MagicPrefs[343]: Restored mouse tracking speed to 3.000000
Dec 15 21:43:32 MacBook-Pro MagicPrefs[343]: Restored trackpad tracking speed to 0.687500
Dec 15 21:43:32 MacBook-Pro com.apple.xpc.launchd[1] (2BUA8C4S2C.com.agilebits.onepassword4-helper[337]): Service exited due to signal: Killed: 9
Dec 15 21:43:32 MacBook-Pro com.apple.xpc.launchd[1] (com.apple.cloudphotosd[378]): Service exited due to signal: Killed: 9
Dec 15 21:43:32 MacBook-Pro com.apple.xpc.launchd[1] (com.apple.wifi.WiFiAgent[353]): Service exited due to signal: Killed: 9
Dec 15 21:43:32 MacBook-Pro appleeventsd[45]: SecTaskLoadEntitlements failed error=3
Dec 15 21:43:32 --- last message repeated 1 time ---
Dec 15 21:43:32 MacBook-Pro loginwindow[88]: ERROR | -[SessionLogoutManager allPrivateProcesses] | No LS dictionary found for LSASN: LSASN:{hi=0x0;lo=0x15015}
Dec 15 21:43:32 MacBook-Pro loginwindow[88]: ERROR | -[SessionLogoutManager allPrivateProcesses] | No LS dictionary found for LSASN: LSASN:{hi=0x0;lo=0x1e01e}
Dec 15 21:43:32 MacBook-Pro loginwindow[88]: ERROR | -[SessionLogoutManager allPrivateProcesses] | No LS dictionary found for LSASN: LSASN:{hi=0x0;lo=0x1f01f}
Dec 15 21:43:32 MacBook-Pro loginwindow[88]: ERROR | -[SessionLogoutManager allPrivateProcesses] | No LS dictionary found for LSASN: LSASN:{hi=0x0;lo=0x22022}
Dec 15 21:43:32 MacBook-Pro loginwindow[88]: ERROR | -[SessionLogoutManager allPrivateProcesses] | No LS dictionary found for LSASN: LSASN:{hi=0x0;lo=0x25025}
Dec 15 21:43:32 MacBook-Pro com.apple.xpc.launchd[1] (com.apple.universalaccessd[281]): Service exited due to signal: Killed: 9
Dec 15 21:43:32 MacBook-Pro com.apple.xpc.launchd[1] (com.apple.FolderActionsDispatcher[328]): Service exited due to signal: Killed: 9
Dec 15 21:43:32 MacBook-Pro sessionlogoutd[463]: sessionlogoutd Launched
Dec 15 21:43:32 MacBook-Pro sessionlogoutd[463]: DEAD_PROCESS: 88 console
Dec 15 21:43:32 MacBook-Pro sharingd[316]: 21:43:32.386 : SCDynamicStoreCopyConsoleUser returned NULL
Dec 15 21:43:32 MacBook-Pro sharingd[316]: 21:43:32.386 : SDActivityAdvertiser::consoleUserChanged: Stopping for user 501 on logout
Dec 15 21:43:32 MacBook-Pro sharingd[316]: 21:43:32.387 : SCDynamicStoreCopyConsoleUser returned NULL
Dec 15 21:43:32 --- last message repeated 2 times ---
Dec 15 21:43:32 MacBook-Pro shutdown[464]: reboot by AAA:
Dec 15 21:43:32 MacBook-Pro kernel[0]: Kext loading now disabled.
Dec 15 21:43:32 MacBook-Pro kernel[0]: Kext unloading now disabled.
Dec 15 21:43:32 MacBook-Pro kernel[0]: Kext autounloading now disabled.
Dec 15 21:43:32 MacBook-Pro kernel[0]: Kernel requests now disabled.
Dec 15 21:43:32 MacBook-Pro shutdown[464]: SHUTDOWN_TIME: 1481834612 425962
Dec 15 21:43:32 MacBook-Pro com.apple.xpc.launchd[1] (com.apple.xpc.launchd.domain.system): System shutdown initiated by: shutdown.464<-sessionlogoutd.463<-launchd.1
Dec 15 21:43:32 MacBook-Pro kernel[0]: Process launchd [1] disabling system-wide I/O Throttling
Dec 15 21:43:32 MacBook-Pro kernel[0]: Process launchd [1] disabling system-wide CPU Throttling
Dec 15 21:43:58 localhost bootlog[0]: BOOT_TIME 1481834638 0
Dec 15 21:43:59 localhost syslogd[38]: Configuration Notice:
ASL Module "com.apple.AccountPolicyHelper" claims selected messages.
Those messages may not appear in standard system log files or in the ASL database.
ASL Module "com.apple.Accounts" claims selected messages.
Dec 15 21:43:59 --- last message repeated 1 time ---
ASL Module "com.apple.authd" sharing output destination "/var/log/asl" with ASL Module "com.apple.asl".
Output parameters from ASL Module "com.apple.asl" override any specified in ASL Module "com.apple.authd".
ASL Module "com.apple.authd" sharing output destination "/var/log/system.log" with ASL Module "com.apple.asl".
ASL Module "com.apple.authd" claims selected messages.
ASL Module "com.apple.authkit.osx.asl" sharing output destination "/var/log/Accounts" with ASL Module "com.apple.Accounts".
Output parameters from ASL Module "com.apple.Accounts" override any specified in ASL Module "com.apple.authkit.osx.asl".
ASL Module "com.apple.authkit.osx.asl" claims selected messages.
ASL Module "com.apple.awdd" claims selected messages.
ASL Module "com.apple.callhistory.asl.conf" claims selected messages.
ASL Module "com.apple.cdscheduler" claims selected messages.
ASL Module "com.apple.cloudd" claims selected messages.
ASL Module "com.apple.clouddocs" claims selected messages.
ASL Module "com.apple.commerce.asl" claims selected messages.
ASL Module "com.apple.contacts.ContactsAutocomplete" claims selected messages.
ASL Module "com.apple.corecdp.osx.asl" sharing output destination "/var/log/Accounts" with ASL Module "com.apple.Accounts".
Output parameters from ASL Module "com.apple.Accounts" override any specified in ASL Module "com.apple.corecdp.osx.asl".
ASL Module "com.apple.corecdp.osx.asl" claims selected messages.
ASL Module "com.apple.CoreDuetAdmissionControl" claims selected messages.
ASL Module "com.apple.corespotlight" claims selected messages.
ASL Module "com.apple.eventmonitor" claims selected messages.
ASL Module "com.apple.family.asl" claims selected messages.
ASL Module "com.apple.ical" claims selected messages.
ASL Module "com.apple.icloud.FindMyDevice" claims selected messages.
ASL Module "com.apple.icloud.fmfd" claims selected messages.
Dec 15 21:43:59 --- last message repeated 2 times ---
ASL Module "com.apple.install" claims selected messages.
ASL Module "com.apple.iokit.power" claims selected messages.
ASL Module "com.apple.mail" claims selected messages.
ASL Module "com.apple.MessageTracer" claims selected messages.
ASL Module "com.apple.mobileme.fmf1" claims selected messages.
ASL Module "com.apple.mobileme.fmf1.internal" sharing output destination "/var/log/FindMyFriendsApp/FindMyFriendsApp.asl" with ASL Module "com.apple.mobileme.fmf1".
Output parameters from ASL Module "com.apple.mobileme.fmf1" override any specified in ASL Module "com.apple.mobileme.fmf1.internal".
ASL Module "com.apple.mobileme.fmf1.internal" sharing output destination "/var/log/FindMyFriendsApp" with ASL Module "com.apple.mobileme.fmf1".
ASL Module "com.apple.mobileme.fmf1.internal" claims selected messages.
ASL Module "com.apple.networking.symptoms" claims selected messages.
ASL Module "com.apple.performance" claims selected messages.
ASL Module "com.apple.secinitd" claims selected messages.
ASL Module "com.apple.securityd" claims selected messages.
Dec 15 21:43:59 --- last message repeated 7 times ---
ASL Module "com.apple.xpc.activity" claims selected messages.
Dec 15 21:43:59 localhost kernel[0]: Longterm timer threshold: 1000 ms
Dec 15 21:43:59 localhost kernel[0]: PMAP: PCID enabled
Dec 15 21:43:59 localhost kernel[0]: PMAP: Supervisor Mode Execute Protection enabled
Dec 15 21:43:59 localhost kernel[0]: Darwin Kernel Version 15.6.0: Wed Nov 2 20:30:56 PDT 2016; root:xnu-3248.60.11.1.2~2/RELEASE_X86_64
Dec 15 21:43:59 localhost kernel[0]: vm_page_bootstrap: 3956566 free pages and 204970 wired pages
Dec 15 21:43:59 localhost kernel[0]: kext submap [0x<ptr> - 0x<ptr>], kernel text [0x<ptr> - 0x<ptr>]
Dec 15 21:43:59 localhost kernel[0]: zone leak detection enabled
Dec 15 21:43:59 localhost kernel[0]: "vm_compressor_mode" is 4
Dec 15 21:43:59 localhost kernel[0]: multiq scheduler config: deep-drain 0, ceiling 47, depth limit 4, band limit 127, sanity check 0
Dec 15 21:43:58 localhost com.apple.xpc.launchd[1] (com.apple.alf): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Dec 15 21:43:59 localhost kernel[0]: standard timeslicing quantum is 10000 us
Dec 15 21:43:59 localhost kernel[0]: standard background quantum is 2500 us
Dec 15 21:43:59 localhost kernel[0]: WQ[lt_init]: init linktable with max:262144 elements (8388608 bytes)
Dec 15 21:43:59 localhost kernel[0]: WQ[wqp_init]: init prepost table with max:262144 elements (8388608 bytes)
Dec 15 21:43:59 localhost kernel[0]: mig_table_max_displ = 16
Dec 15 21:43:59 localhost kernel[0]: TSC Deadline Timer supported and enabled
Dec 15 21:43:59 localhost kernel[0]: kdp_core zlib memory 0x7000
Dec 15 21:43:59 localhost kernel[0]: AppleACPICPU: ProcessorId=1 LocalApicId=0 Enabled
Dec 15 21:43:59 localhost kernel[0]: AppleACPICPU: ProcessorId=2 LocalApicId=2 Enabled
Dec 15 21:43:59 localhost kernel[0]: AppleACPICPU: ProcessorId=3 LocalApicId=4 Enabled
Dec 15 21:43:59 localhost kernel[0]: AppleACPICPU: ProcessorId=4 LocalApicId=6 Enabled
Dec 15 21:43:59 localhost kernel[0]: AppleACPICPU: ProcessorId=5 LocalApicId=1 Enabled
Dec 15 21:43:59 localhost kernel[0]: AppleACPICPU: ProcessorId=6 LocalApicId=3 Enabled
Dec 15 21:43:59 localhost kernel[0]: AppleACPICPU: ProcessorId=7 LocalApicId=5 Enabled
Dec 15 21:43:59 localhost kernel[0]: AppleACPICPU: ProcessorId=8 LocalApicId=7 Enabled
Dec 15 21:43:59 localhost kernel[0]: calling mpo_policy_init for TMSafetyNet
Dec 15 21:43:59 localhost kernel[0]: Security policy loaded: Safety net for Time Machine (TMSafetyNet)
Dec 15 21:43:59 localhost kernel[0]: calling mpo_policy_init for AMFI
Dec 15 21:43:59 localhost kernel[0]: Security policy loaded: Apple Mobile File Integrity (AMFI)
Dec 15 21:43:59 localhost kernel[0]: calling mpo_policy_init for Sandbox
Dec 15 21:43:59 localhost kernel[0]: Security policy loaded: Seatbelt sandbox policy (Sandbox)
Dec 15 21:43:59 localhost kernel[0]: calling mpo_policy_init for Quarantine
Dec 15 21:43:59 localhost kernel[0]: Security policy loaded: Quarantine policy (Quarantine)
Dec 15 21:43:59 localhost kernel[0]: Copyright (c) 1982, 1986, 1989, 1991, 1993
Dec 15 21:43:59 localhost kernel[0]: The Regents of the University of California. All rights reserved.
Dec 15 21:43:59 localhost kernel[0]: MAC Framework successfully initialized
Dec 15 21:43:59 localhost kernel[0]: using 16384 buffer headers and 10240 cluster IO buffer headers
Dec 15 21:43:59 localhost kernel[0]: AppleCredentialManager::start called
Dec 15 21:43:59 localhost kernel[0]: AssertMacros: tmpData (value: 0x0), file: /BuildRoot/Library/Caches/com.apple.xbs/Sources/AppleCredentialManager/AppleCredentialManager-83.40.3/AppleCredentialManager/AppleCredentialManager.cpp, line: 785
Dec 15 21:43:59 localhost kernel[0]: AppleKeyStore starting (BUILT: Nov 2 2016 21:28:45)
Dec 15 21:43:59 localhost kernel[0]: IOAPIC: Version 0x20 Vectors 64:87
Dec 15 21:43:59 localhost kernel[0]: ACPI: sleep states S3 S4 S5
Dec 15 21:43:59 localhost kernel[0]: pci (build 20:49:00 Nov 2 2016), flags 0xe3000, pfm64 (39 cpu) 0x7f80000000, 0x80000000
Dec 15 21:43:59 localhost kernel[0]: [ PCI configuration begin ]
Dec 15 21:43:59 localhost kernel[0]: 000000.891687 AppleUSBLegacyRoot@: AppleUSBLegacyRoot::init: enabling legacy matching
Dec 15 21:43:59 localhost kernel[0]: console relocated to 0x7f80020000
Dec 15 21:43:59 localhost kernel[0]: [ PCI configuration end, bridges 13, devices 14 ]
Dec 15 21:43:59 localhost kernel[0]: AirPort_Brcm4360::init AirPortFamily_kexts-1110.28 "AirPortFamily_kexts-1110.28" Nov 2 2016 21:18:58
Dec 15 21:43:59 localhost kernel[0]: AppleThunderboltNHIType2::setupPowerSavings - GPE based runtime power management
Dec 15 21:43:59 localhost kernel[0]: SATA WARNING: IDENTIFY DEVICE checksum not implemented
Dec 15 21:43:59 localhost kernel[0]: mcache: 8 CPU(s), 64 bytes CPU cache line size
Dec 15 21:43:59 localhost kernel[0]: mbinit: done [128 MB total pool size, (85/42) split]
Dec 15 21:43:59 localhost kernel[0]: rooting via boot-uuid from /chosen: B022F814-FC54-3460-8730-C277ECDD3748
Dec 15 21:43:59 localhost kernel[0]: Waiting on <dict ID="0"><key>IOProviderClass</key><string ID="1">IOResources</string><key>IOResourceMatch</key><string ID="2">boot-uuid-media</string></dict>
Scusa, ma se usi la SD solo nel Mac perché non la formatti HFS+ e vedi se risolvi.butterfly ha scritto:Ciao a tutti, ho un macbook retina ed uso una scheda sd come spazio di backup per qualche documento. La tengo perennemente inserita nel mac tramite questo...
Grazie per la dritta. ci provo subitoJethro ha scritto:Scusa, ma usi la SD solo nel Mac perché non la formatti HFS+ e vedi se risolvi.butterfly ha scritto:Ciao a tutti, ho un macbook retina ed uso una scheda sd come spazio di backup per qualche documento. La tengo perennemente inserita nel mac tramite questo...
Grazie per le risposte. Ho fatto come mi avete suggerito, ho inizializzato la scheda in "OSX esteso (distingue tra maiuscole....)"Jethro ha scritto: Scusa, ma se usi la SD solo nel Mac perché non la formatti HFS+ e vedi se risolvi.
faxus ha scritto: Credo che il modo di ovviare sia smontare le estensioni delle schede in avvio.
Altrimenti si dovranno smontare fisicamente le schede.
Poi inserirle dopo l'avvio.
Non avresti dovuto scegliere il "case sensitive", è fonte di problemi.butterfly ha scritto:... ho inizializzato la scheda in "OSX esteso (distingue tra maiuscole....)"
e come schema ho messo "mappa partizione Apple"...
