L'attenzione maggiore, giustificata anche dalla natura dell'elemento e da riferimenti, è su FitBit.Aller76 ha scritto:... Avevo pensato a quello perchè vedevo FitBit ricorrente: Vedo però anche "iCloudHelper"...
Process: akd [392]
Path: /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd
Identifier: akd
Version: 1.0 (1.0)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: akd [392]
User ID: 501
PlugIn Path: /System/Library/PrivateFrameworks/CoreADI.framework/Versions/A/CoreADI
PlugIn Identifier: com.apple.CoreADI
PlugIn Version: 3.37.0 (3.37.0)
Date/Time: 2016-12-08 06:03:57.071 +0100
OS Version: Mac OS X 10.12.1 (16B2555)
Report Version: 12
Anonymous UUID: B4153480-C789-03D5-26F7-B70523D2CD9B
Time Awake Since Boot: 87 seconds
System Integrity Protection: enabled
Crashed Thread: 2 Dispatch queue: com.apple.akd.anisette
Exception Type: EXC_BAD_ACCESS (Code Signature Invalid)
Exception Codes: 0x0000000000000032, 0x00000001102bbcfa
Exception Note: EXC_CORPSE_NOTIFY
Termination Reason: Namespace CODESIGNING, Code 0x2
Thread 2 Crashed:: Dispatch queue: com.apple.akd.anisette
0 com.apple.CoreADI 0x00000001102bbcfa vdfut768ig + 19802
1 akd 0x000000010e3e0642 0x10e37e000 + 403010
2 akd 0x000000010e3e3dda 0x10e37e000 + 417242
3 akd 0x000000010e3874cf 0x10e37e000 + 38095
4 akd 0x000000010e386b51 0x10e37e000 + 35665
5 libdispatch.dylib 0x00007fffb8fe3f5f _dispatch_call_block_and_release + 12
6 libdispatch.dylib 0x00007fffb8fdb128 _dispatch_client_callout + 8
7 libdispatch.dylib 0x00007fffb8ff1b97 _dispatch_queue_serial_drain + 896
8 libdispatch.dylib 0x00007fffb8fe3d41 _dispatch_queue_invoke + 1046
9 libdispatch.dylib 0x00007fffb8fea158 _dispatch_queue_override_invoke + 369
10 libdispatch.dylib 0x00007fffb8fdcee0 _dispatch_root_queue_drain + 476
11 libdispatch.dylib 0x00007fffb8fdccb7 _dispatch_worker_thread3 + 99
12 libsystem_pthread.dylib 0x00007fffb9228736 _pthread_wqthread + 1299
13 libsystem_pthread.dylib 0x00007fffb9228211 start_wqthread + 13
/code]
Process: com.apple.iCloudHelper [374]
Path: /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/XPCServices/com.apple.iCloudHelper.xpc/Contents/MacOS/com.apple.iCloudHelper
Identifier: com.apple.iCloudHelper
Version: 1.07 (241)
Responsible: com.apple.iCloudHelper [374]
User ID: 501
PlugIn Path: /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/AOSKit
PlugIn Identifier: com.apple.AOSKit
PlugIn Version: 1.07 (241)
Date/Time: 2016-12-08 06:03:41.843 +0100
Report Version: 12
Time Awake Since Boot: 71 seconds
Crashed Thread: 1 Dispatch queue: NSOperationQueue 0x7f9e8dc00280 :: NSOperation 0x7f9e8dd07160 (QOS: DEFAULT)
Exception Codes: 0x0000000000000032, 0x00007fffac3fc000
Thread 1 Crashed:: Dispatch queue: NSOperationQueue 0x7f9e8dc00280 :: NSOperation 0x7f9e8dd07160 (QOS: DEFAULT)
0 com.apple.AOSKit 0x00007fffac3fbfff +[KeychainAccountStorage storedInfoForAccount:] + 259
1 com.apple.AOSKit 0x00007fffac3fbc2b AOSCopyStoredAccountInfo + 70
2 com.apple.AOSKit 0x00007fffac3e493a AOSAccountCopyInfo + 84
3 com.apple.iCloudHelper 0x000000010e6ef763 0x10e6e9000 + 26467
4 com.apple.iCloudHelper 0x000000010e6ee021 0x10e6e9000 + 20513
5 com.apple.Foundation 0x00007fffa58e2979 __NSBLOCKOPERATION_IS_CALLING_OUT_TO_A_BLOCK__ + 7
6 com.apple.Foundation 0x00007fffa58e265c -[NSBlockOperation main] + 101
7 com.apple.Foundation 0x00007fffa58e0d84 -[__NSOperationInternal _start:] + 672
8 com.apple.Foundation 0x00007fffa58dcc3b __NSOQSchedule_f + 201
9 libdispatch.dylib 0x00007fffb8fdb128 _dispatch_client_callout + 8
10 libdispatch.dylib 0x00007fffb8ff1b97 _dispatch_queue_serial_drain + 896
11 libdispatch.dylib 0x00007fffb8fe3d41 _dispatch_queue_invoke + 1046
12 libdispatch.dylib 0x00007fffb8fdcee0 _dispatch_root_queue_drain + 476
13 libdispatch.dylib 0x00007fffb8fdccb7 _dispatch_worker_thread3 + 99
14 libsystem_pthread.dylib 0x00007fffb9228736 _pthread_wqthread + 1299
15 libsystem_pthread.dylib 0x00007fffb9228211 start_wqthread + 13
code]
Process: com.apple.iCloudHelper [391]
Version: 1.07 (241)
Responsible: com.apple.iCloudHelper [391]
User ID: 501
Date/Time: 2016-12-08 06:03:52.380 +0100
Report Version: 12
Time Awake Since Boot: 82 seconds
Crashed Thread: 5 Dispatch queue: NSOperationQueue 0x7fa672500260 :: NSOperation 0x7fa6725146c0 (QOS: DEFAULT)
Thread 5 Crashed:: Dispatch queue: NSOperationQueue 0x7fa672500260 :: NSOperation 0x7fa6725146c0 (QOS: DEFAULT)
3 com.apple.iCloudHelper 0x000000010c746763 0x10c740000 + 26467
4 com.apple.iCloudHelper 0x000000010c745021 0x10c740000 + 20513
15 libsystem_pthread.dylib 0x00007fffb9228211 start_wqthread + 13 code]
Process: storeaccountd [349]
Path: /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeaccountd
Identifier: storeaccountd
Version: 580.11
Responsible: storeaccountd [349]
User ID: 501
Date/Time: 2016-12-08 06:03:42.748 +0100
Report Version: 12
Time Awake Since Boot: 72 seconds
Crashed Thread: 1 Dispatch queue: ADI Serial Processing Queue
Exception Codes: 0x0000000000000032, 0x000000010b2fbcfa
Thread 1 Crashed:: Dispatch queue: ADI Serial Processing Queue
0 com.apple.CoreADI 0x000000010b2fbcfa vdfut768ig + 19802
1 storeaccountd 0x00000001093e30c2 0x109366000 + 512194
2 storeaccountd 0x00000001093e42e7 0x109366000 + 516839
3 storeaccountd 0x0000000109367cf6 0x109366000 + 7414
4 storeaccountd 0x0000000109368c04 0x109366000 + 11268
5 storeaccountd 0x0000000109369170 0x109366000 + 12656
7 libdispatch.dylib 0x00007fffb8fdbd62 _dispatch_barrier_sync_f_invoke + 83
8 storeaccountd 0x0000000109369103 0x109366000 + 12547
9 storeaccountd 0x0000000109369245 0x109366000 + 12869
10 storeaccountd 0x0000000109371b9d 0x109366000 + 48029
11 libdispatch.dylib 0x00007fffb8fe3f5f _dispatch_call_block_and_release + 12
12 libdispatch.dylib 0x00007fffb8fdb128 _dispatch_client_callout + 8
13 libdispatch.dylib 0x00007fffb8ff0c10 _dispatch_continuation_pop + 533
14 libdispatch.dylib 0x00007fffb8fe7ea3 _dispatch_async_redirect_invoke + 734
15 libdispatch.dylib 0x00007fffb8fdcee0 _dispatch_root_queue_drain + 476
16 libdispatch.dylib 0x00007fffb8fdccb7 _dispatch_worker_thread3 + 99
17 libsystem_pthread.dylib 0x00007fffb9228736 _pthread_wqthread + 1299
18 libsystem_pthread.dylib 0x00007fffb9228211 start_wqthread + 13
