sudo opensnoop -n mdworker
sudo fs_usage -w -f filesys mdworker | egrep "open"
fatti entrambi uno per volta per due minuti ciascuno e non è venuto fuori nulla.faxus ha scritto:PoiCodice: Seleziona tutto
Top Processes by CPU: ⓘ
91% mdworker(2)
3% WindowServer
2% kernel_task
1% fontd
0% aosnotifyd
Virtual Memory Information: ⓘ
112 MB Free RAM
3.89 GB Used RAM (1.00 GB Cached)
0 B Swap Used
Diagnostics Information: ⓘ
Sep 24, 2016, 02:19:17 PM Self test - passed
Sep 23, 2016, 03:39:34 PM /Library/Logs/DiagnosticReports/mdworker32_2016-09-23-153934_[redacted].crash
/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker32
Sep 23, 2016, 03:39:32 PM /Library/Logs/DiagnosticReports/mdworker32_2016-09-23-153932_[redacted].crash
Sep 23, 2016, 03:39:30 PM /Library/Logs/DiagnosticReports/mdworker32_2016-09-23-153930_[redacted].crash
Sep 23, 2016, 03:39:27 PM /Library/Logs/DiagnosticReports/mdworker32_2016-09-23-153927_[redacted].crash
Sep 23, 2016, 03:39:22 PM /Library/Logs/DiagnosticReports/mdworker32_2016-09-23-153922_[redacted].crash
Sep 23, 2016, 03:39:20 PM /Library/Logs/DiagnosticReports/mdworker32_2016-09-23-153920_[redacted].crash
Sep 23, 2016, 03:39:18 PM /Library/Logs/DiagnosticReports/mdworker32_2016-09-23-153918_[redacted].crash
Sep 23, 2016, 03:39:16 PM /Library/Logs/DiagnosticReports/mdworker32_2016-09-23-153916_[redacted].crash
Sep 23, 2016, 03:39:14 PM /Library/Logs/DiagnosticReports/mdworker32_2016-09-23-153914_[redacted].crash
Sep 23, 2016, 03:39:12 PM /Library/Logs/DiagnosticReports/mdworker32_2016-09-23-153912_[redacted].crash
Sep 23, 2016, 03:39:10 PM /Library/Logs/DiagnosticReports/mdworker32_2016-09-23-153910_[redacted].crash
Sep 23, 2016, 03:39:08 PM /Library/Logs/DiagnosticReports/mdworker32_2016-09-23-153908_[redacted].crash
Sep 23, 2016, 03:39:06 PM /Library/Logs/DiagnosticReports/mdworker32_2016-09-23-153906_[redacted].crash
Sep 23, 2016, 03:39:04 PM /Library/Logs/DiagnosticReports/mdworker32_2016-09-23-153904_[redacted].crash
Sep 23, 2016, 03:39:02 PM /Library/Logs/DiagnosticReports/mdworker32_2016-09-23-153902_[redacted].crash
Sep 23, 2016, 03:39:00 PM /Library/Logs/DiagnosticReports/mdworker32_2016-09-23-153900_[redacted].crash
Sep 23, 2016, 03:38:58 PM /Library/Logs/DiagnosticReports/mdworker32_2016-09-23-153858_[redacted].crash
Sep 23, 2016, 03:38:57 PM /Library/Logs/DiagnosticReports/mdworker32_2016-09-23-153857_[redacted].crash
Sep 23, 2016, 03:38:55 PM /Library/Logs/DiagnosticReports/mdworker32_2016-09-23-153855_[redacted].crash
Sep 23, 2016, 03:38:53 PM /Library/Logs/DiagnosticReports/mdworker32_2016-09-23-153853_[redacted].crash
ma il gioco non sta dando problemi e non mi sembra collegato, il problema si è verificato quando il gioco non era in esecuzione...tighine ha scritto:Levare il giochino?
in effetti...Simone.m ha scritto:Prova a fare anche un reset PRAM e SMC che male non fa
Process: mdworker32 [449]
Path: /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Support/mdworker32
Identifier: mdworker32
Version: 800.30
Code Type: X86 (Native)
Parent Process: launchd [231]
Responsible: mdworker32 [449]
User ID: 89
PlugIn Path: /Library/Spotlight/Finale.mdimporter/Contents/MacOS/Finale
PlugIn Identifier: com.makemusic.MDImporter.Finale
PlugIn Version: 2.0 (1.1)
Date/Time: 2016-09-23 15:38:52.529 +0200
OS Version: Mac OS X 10.9.5 (13F1808)
Report Version: 11
Anonymous UUID: A644DD1B-3D4D-D953-565A-FBB988FC64A6
Crashed Thread: 5
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x00000000b0198fcc
VM Regions Near 0xb0198fcc:
Stack 00000000b0117000-00000000b0198000 [ 516K] rw-/rwx SM=COW
--> Stack 00000000b0198000-00000000b0199000 [ 4K] ---/rwx SM=NUL
Stack 00000000b0199000-00000000b021a000 [ 516K] rw-/rwx SM=COW
Application Specific Information:
import fstype:hfs fsflag:480D000 flags:40000005E diag:0 isXCode:0 uti:com.makemusic.mus plugin:/Library/Spotlight/Finale.mdimporter - find suspect file using: sudo mdutil -t 800965
Application Specific Signatures:
import uti:com.makemusic.mus plugin:/Library/Spotlight/Finale.mdimporter uuid:8F7AD1E0-0DB3-11D9-95E0-000A95BA3EA2 1.1
Thread 5 Crashed:
0 libsystem_c.dylib 0x901f7866 __vfprintf + 12
1 libsystem_c.dylib 0x9021e11e __v2printf + 442
2 libsystem_c.dylib 0x90204c4c _vsnprintf + 891
3 libsystem_c.dylib 0x90204cad vsnprintf_l + 61
4 libsystem_c.dylib 0x901f62a4 snprintf + 80
5 com.makemusic.MDImporter.Finale 0x01fceb27 SqliteStatement::GetBindIndex(char const*) + 189
6 com.makemusic.MDImporter.Finale 0x01fced4d SqliteStatement::BindNameToString(char const*, FinStringUTF8 const&) + 25
7 com.makemusic.MDImporter.Finale 0x01fbed33 FCInstrumentManager::GetInstrumentByUUID(FinStringUTF8 const&) + 81
8 com.makemusic.MDImporter.Finale 0x01fbee28 FCInstrumentManager::GetInstrumentByUUID(boost::uuids::uuid const&) + 72
9 com.makemusic.MDImporter.Finale 0x01fbedc1 FCInstrumentManager::GetInstrumentByUUID(FinStringUTF8 const&) + 223
10 com.makemusic.MDImporter.Finale 0x01fbee28 FCInstrumentManager::GetInstrumentByUUID(boost::uuids::uuid const&) + 72
11 com.makemusic.MDImporter.Finale 0x01fbedc1 FCInstrumentManager::GetInstrumentByUUID(FinStringUTF8 const&) + 223
12 com.makemusic.MDImporter.Finale 0x01fbee28 FCInstrumentManager::GetInstrumentByUUID(boost::uuids::uuid const&) + 72
13 com.makemusic.MDImporter.Finale 0x01fbedc1 FCInstrumentManager::GetInstrumentByUUID(FinStringUTF8 const&) + 223
14 com.makemusic.MDImporter.Finale 0x01fbee28 FCInstrumentManager::GetInstrumentByUUID(boost::uuids::uuid const&) + 72
15 com.makemusic.MDImporter.Finale 0x01fbedc1 FCInstrumentManager::GetInstrumentByUUID(FinStringUTF8 const&) + 223
16 com.makemusic.MDImporter.Finale 0x01fbee28 FCInstrumentManager::GetInstrumentByUUID(boost::uuids::uuid const&) + 72
17 com.makemusic.MDImporter.Finale 0x01fbedc1 FCInstrumentManager::GetInstrumentByUUID(FinStringUTF8 const&) + 223
18 com.makemusic.MDImporter.Finale 0x01fbee28 FCInstrumentManager::GetInstrumentByUUID(boost::uuids::uuid const&) + 72
19 com.makemusic.MDImporter.Finale 0x01fbedc1 FCInstrumentManager::GetInstrumentByUUID(FinStringUTF8 const&) + 223
20 com.makemusic.MDImporter.Finale 0x01fbee28 FCInstrumentManager::GetInstrumentByUUID(boost::uuids::uuid const&) + 72
21 com.makemusic.MDImporter.Finale 0x01fbedc1 FCInstrumentManager::GetInstrumentByUUID(FinStringUTF8 const&) + 223
22 com.makemusic.MDImporter.Finale 0x01fbee28 FCInstrumentManager::GetInstrumentByUUID(boost::uuids::uuid const&) + 72
23 com.makemusic.MDImporter.Finale 0x01fbedc1 FCInstrumentManager::GetInstrumentByUUID(FinStringUTF8 const&) + 223
24 com.makemusic.MDImporter.Finale 0x01fbee28 FCInstrumentManager::GetInstrumentByUUID(boost::uuids::uuid const&) + 72
25 com.makemusic.MDImporter.Finale 0x01fbedc1 FCInstrumentManager::GetInstrumentByUUID(FinStringUTF8 const&) + 223
26 com.makemusic.MDImporter.Finale 0x01fbee28 FCInstrumentManager::GetInstrumentByUUID(boost::uuids::uuid const&) + 72
27 com.makemusic.MDImporter.Finale 0x01fbedc1 FCInstrumentManager::GetInstrumentByUUID(FinStringUTF8 const&) + 223
28 com.makemusic.MDImporter.Finale 0x01fbee28 FCInstrumentManager::GetInstrumentByUUID(boost::uuids::uuid const&) + 72
29 com.makemusic.MDImporter.Finale 0x01fbedc1 FCInstrumentManager::GetInstrumentByUUID(FinStringUTF8 const&) + 223
30 com.makemusic.MDImporter.Finale 0x01fbee28 FCInstrumentManager::GetInstrumentByUUID(boost::uuids::uuid const&) + 72
31 com.makemusic.MDImporter.Finale 0x01fbedc1 FCInstrumentManager::GetInstrumentByUUID(FinStringUTF8 const&) + 223
...arriva fino a 511 e non me lo fa postare!
sudo mdutil -i off /
sudo rm -rf /.Spotlight*
sudo mdutil -i on /
Visitano il forum: Ahrefs [Bot], Brandwatch [Crawler] e 34 ospiti
