Daniel X
- Maccanico attivo
Buonasera, da pochi giorni ho notato un leggero rumore appoggiando il dito sulla parte destra in basso del mio trackpad. Ho un MacBook Pro retina 15". Il rumore è esattamente come nel video che segue, ma solo nella parte destra e molto più leggero, si sente solo quando c'è silenzio. Spero non sia da assistenza... e sinceramente non capisco il motivo. Il Mac ha pochi mesi e l'ho sempre trattato benissimo.
https://www.youtube.com/watch?v=tY-qFgy1LTA
"It's not my fault, i'm better than you."
"Is better to be hated for what you are than to be loved for what you are not."
"...Puri di sangue e di astuzia provetti."
MacBook Pro Retina 15"
iPad mini 2
iPhone 6s Silver 64 GB
Apple Watch Sport 42mm oro
Peppiniello
La risposta l'hai segnalata tu, linkando il video e te la dà nei commenti Ivan Camara:
Ivan Camara ha scritto:DEFINITIVE SOLUTION!!:
Had the same problem on mine. The "paper trick" worked, but the same problem appeared again after a few months. Just found a definitive (and relatively safe) solution. It feels like I have a brand new trackpad again!
You'll need:
1 - Phillips #00 screwdriver
2 - Phillips #000 screwdriver
3 - Y0 screwdriver
4 - T6 screwdriver (all included in ifixit set)
5 - Isopropyl Alcohol (DO NOT USE RUBBING ALCOHOL!!!)
6 - A soft brush
What you're going to do:
1 - Remove bottom, by taking out the 10 screws
2 - Disconnect the battery and remove it, by taking out the three Y screws
3 - Remove the 4 silver phillips (do not remove the black ones) and the large torx screw (that is actually a kind of a disk) from the back of your trackpad, then carefully remove the black connector
4 - Open the lid carefully and push the trackpad slightly to the top, the trackpad will fall down on your hand
5 - Thoroughly clean all the edges from the trackpad and the laptop (they will probably be very dirty) with the soft brush and some isopropyl alcohol
6 - Put the trackpad back on place (it's a little tricky to hook it), fasten the silver phillips screws and carefully attach the black connector again
7 - Fasten the large torx screw/disk back on place. At this point, you can adjust how "deep" your trackpad will go when pressed.
8 - Put the battery back on place with the Y screws, and connect it again to the motherboard.
9 - Close the bottom, connect the power ant boot your mac
10 - Enjoy your "brand new" trackpad
In sintesi, basta registrare la vite che regola il gioco.
Bonnie3
- Expert Latitante
Si come dice Peppiniello il problema è l'allentamento della vite del trackpad, un questo modo dovresti risolvere
- MacBook Pro 15" (Mid 2009) 2,53 GHz Intel Core2Duo•4GB RAM•NVIDIA GeForce 9400M•Mavericks• -
- iPhone 7 Plus • 32gb • Rose gold
Daniel X
- Maccanico attivo
Vi ringrazio ragazzi
Fatemi capire, dovrei smontare il Mac? Non è che sia molto sicuro, ho paura di far danni. Se lo portassi ad un'assistenza Apple autorizzata?
In ogni caso sembra che il mio Mac mi prenda in giro, adesso il rumore non c'è più...
iPad mini 2
Peppiniello
Daniel X ha scritto:Vi ringrazio ragazzi
Hai detto che il Mac ha pochi mesi quindi gode ancora di garanzia piena: se non te la senti di aprirlo tu, portalo ad un centro Apple autorizzato; chiamali prima per concordare un appuntamento per far sì che te lo facciano subito (è un intervento che, fatto da mano esperta che vuole andare calma per prudenza, richiede una ventina di minuti massimo). Quando glielo consegni, chiedigli per favore che ti ci diano una soffiata per togliere quel po' di polvere che nel frattempo si sarà già accumulata.
Bonnie3
- Expert Latitante
Quoto in pieno Peppiniello
lillosos
- Maccanico Pro
se in garanzia vai diretto all'apple store. Ci sarà tempo per aprirlo.
"Ut tensio, sic vis" R.H.
Daniel X
- Maccanico attivo
Vi ringrazio tutti
Ho notato che quel rumore è presente solamente quando metto inizialmente il Mac sul supporto per tenere lo schermo all'altezza degli occhi, esattamente questo:
http://ecx.images-amazon.com/images/I/6 ... L1500_.jpg . Successivamente non si sente più, e usandolo senza supporto non c'è proprio.
iPad mini 2
tighine
- Expert Latitante
Non é che son scarichette elettrostatiche? Il supporto per "innalzarlo a livello occhi" é innanzitutto una base di ventilazione aggiuntiva.
Daniel X
- Maccanico attivo
tighine ha scritto:Non é che son scarichette elettrostatiche? Il supporto per "innalzarlo a livello occhi" é innanzitutto una base di ventilazione aggiuntiva.
Però io non uso le ventole del supporto
In ogni caso se si verifica, è solo quando lo metto li, per i primi minuti.
iPad mini 2
Visitano il forum: Nessuno e 29 ospiti
