Feb 9 10:20:29 Mac-mini-di-Lorenzo.local configd[25]: network changed: v4(en0+:192.168.1.71) DNS+ Proxy+ SMB
Feb 9 10:20:29 Mini-di-Lorenzo.lan configd[25]: setting hostname to "Mini-di-Lorenzo.lan"
Feb 9 10:20:29 Mini-di-Lorenzo.lan blued[58]: link key found for device: e4-8b-7f-1c-18-d4
Feb 9 10:20:29 Mini-di-Lorenzo.lan blued[58]: Save link key for device: e4-8b-7f-1c-18-d4
Feb 9 10:20:29 Mini-di-Lorenzo.lan blued[58]: link key found for device: 60-c5-47-80-f7-19
Feb 9 10:20:29 Mini-di-Lorenzo.lan blued[58]: Save link key for device: 60-c5-47-80-f7-19
Feb 9 10:20:30 Mini-di-Lorenzo.lan sntp[164]: time set +0.917594 s
Feb 9 10:20:31 Mini-di-Lorenzo.lan ntpd[141]: peer time.euro.apple.com @ 17.72.148.52
Feb 9 10:20:31 Mini-di-Lorenzo.lan ntpd[141]: drift PPM:0.000 -> -17.669
Feb 9 10:20:31 Mini-di-Lorenzo kernel[0]: hfs: mounted Recovery HD on device disk0s3
Feb 9 10:20:31 Mini-di-Lorenzo.lan mds[32]: (Volume.Normal:2464) volume:0x7fa19500cc00 ********** Bootstrapped Creating a default store:0 SpotLoc:(null) SpotVerLoc:(null) occlude:0 /Volumes/Recovery HD
Feb 9 10:20:31 Mini-di-Lorenzo.lan fseventsd[20]: Logging disabled completely for device:1: /Volumes/Recovery HD
Feb 9 10:20:31 Mini-di-Lorenzo.lan stackshot[64]: Timed out waiting for IOKit to finish matching.
Feb 9 10:20:33 Mini-di-Lorenzo.lan nsurlstoraged[171]: realpath() returned NULL for /var/root/Library/Caches/ocspd
Feb 9 10:20:33 Mini-di-Lorenzo.lan nsurlstoraged[171]: The read-connection to the DB=/var/root/Library/Caches/ocspd/Cache.db is NOT valid. Unable to determine schema version.
Feb 9 10:20:33 --- last message repeated 1 time ---
Feb 9 10:20:33 Mini-di-Lorenzo.lan nsurlstoraged[171]: ERROR: unable to determine file-system usage for FS-backed cache at /var/root/Library/Caches/ocspd/fsCachedData. Errno=13
Feb 9 10:20:33 Mini-di-Lorenzo.lan lsregister[156]: LaunchServices: Begin database seeding
Feb 9 10:20:33 Mini-di-Lorenzo.lan lsregister[156]: LaunchServices: Completed database seeding
Feb 9 10:20:33 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.appkit.xpc.sandboxedServiceRunner): The JoinExistingSession key is only available to Application services.
Feb 9 10:20:33 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.DataDetectorsDynamicData): The JoinExistingSession key is only available to Application services.
Feb 9 10:20:33 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.FileSyncAgent.PHD.isRunning): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:33 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.mbloginhelper.user): This key does not do anything: OnDemand
Feb 9 10:20:33 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.mbpluginhost.user): This key does not do anything: OnDemand
Feb 9 10:20:33 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.secd): This key does not do anything: OnDemand
Feb 9 10:20:33 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.secd): The ServiceIPC key is no longer respected. Please remove it.
Feb 9 10:20:33 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): This key does not do anything: OnDemand
Feb 9 10:20:33 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.TrustEvaluationAgent): This key does not do anything: OnDemand
Feb 9 10:20:34 Mini-di-Lorenzo kernel[0]: BUG in process suhelperd[173]: over-released legacy external boost assertions (1 total, 1 external, 0 legacy-external)
Feb 9 10:20:34 Mini-di-Lorenzo kernel[0]: IOBluetoothDevice::setProperties() -- calling hciController->CallCreateDeviceReporter() -- this = 0xe800
Feb 9 10:20:34 Mini-di-Lorenzo kernel[0]: IOBluetoothHCIController::CallCreateDeviceReporter -- calling enqueueAction() -- device = 0xe800
Feb 9 10:20:34 Mini-di-Lorenzo kernel[0]: IOBluetoothHCIController::CreateDeviceReporterAction -- device = = 0xe800
Feb 9 10:20:34 Mini-di-Lorenzo kernel[0]: IOBluetoothHCIController::CreateDeviceReporterAction -- calling CreateDeviceReporter() device = = 0xe800
Feb 9 10:20:34 Mini-di-Lorenzo kernel[0]: IOBluetoothHCIController::CreateDeviceReporter -- device = = 0xe800
Feb 9 10:20:34 Mini-di-Lorenzo.lan blued[58]: Release the WiFi lock
Feb 9 10:20:34 Mini-di-Lorenzo.lan blued[58]: Acquiring the wifi lock
Feb 9 10:20:34 Mini-di-Lorenzo.lan blued[58]: Acquired the wifi lock
Feb 9 10:20:34 --- last message repeated 119 times ---
Feb 9 10:20:34 Mini-di-Lorenzo kernel[0]: en2: promiscuous mode enable succeeded
Feb 9 10:20:34 Mini-di-Lorenzo.lan WindowServer[134]: Session 257 retained (2 references)
Feb 9 10:20:34 Mini-di-Lorenzo.lan WindowServer[134]: Session 257 released (1 references)
Feb 9 10:20:34 Mini-di-Lorenzo.lan WindowServer[134]: init_page_flip: page flip mode is on
Feb 9 10:20:34 Mini-di-Lorenzo kernel[0]: [BNBTrackpadDevice::init][85.3] init is complete
Feb 9 10:20:35 Mini-di-Lorenzo kernel[0]: [BNBTrackpadDevice::handleStart][85.3] returning 1
Feb 9 10:20:35 Mini-di-Lorenzo kernel[0]: [AppleMultitouchHIDEventDriver::start] entered
Feb 9 10:20:35 Mini-di-Lorenzo kernel[0]: hfs: unmount initiated on Recovery HD on device disk0s3
Feb 9 10:20:35 Mini-di-Lorenzo kernel[0]: [AppleMultitouchDevice::start] entered
Feb 9 10:20:35 Mini-di-Lorenzo.lan WindowServer[134]: Found 1 modes for display 0x00000000 [1, 0]
Feb 9 10:20:35 --- last message repeated 2 times ---
Feb 9 10:20:35 Mini-di-Lorenzo.lan WindowServer[134]: Found 40 modes for display 0x00000000 [40, 0]
Feb 9 10:20:35 Mini-di-Lorenzo.lan WindowServer[134]: mux_initialize: Couldn't find any matches
Feb 9 10:20:35 Mini-di-Lorenzo kernel[0]: IOHIDSystem: Seize of IOHIDPointing failed.
Feb 9 10:20:35 Mini-di-Lorenzo kernel[0]: IOHIDSystem: Seize of AppleMultitouchHIDEventDriver failed.
Feb 9 10:20:35 Mini-di-Lorenzo.lan WindowServer[134]: WSMachineUsesNewStyleMirroring: false
Feb 9 10:20:35 Mini-di-Lorenzo.lan WindowServer[134]: Display 0x003f0040: GL mask 0x10; bounds (0, 0)[4096 x 2160], 2 modes available
off-line, enabled, Vendor ffffffff, Model ffffffff, S/N ffffffff, Unit 4, Rotation 0
UUID 0xffffffffffffffffffffffffffffffff
Feb 9 10:20:35 Mini-di-Lorenzo.lan WindowServer[134]: Display 0x1a493c83: GL mask 0x8; bounds (0, 0)[1920 x 1080], 40 modes available
Main, Active, on-line, enabled, Vendor 469, Model 24f2, S/N 0, Unit 3, Rotation 0
UUID 0x73591bd62fa4ba65ac08a9c337e515be
Feb 9 10:20:35 Mini-di-Lorenzo.lan WindowServer[134]: Display 0x003f003e: GL mask 0x4; bounds (0, 0)[0 x 0], 1 modes available
off-line, enabled, Vendor ffffffff, Model ffffffff, S/N ffffffff, Unit 2, Rotation 0
Feb 9 10:20:35 Mini-di-Lorenzo.lan WindowServer[134]: Display 0x003f003d: GL mask 0x2; bounds (0, 0)[0 x 0], 1 modes available
off-line, enabled, Vendor ffffffff, Model ffffffff, S/N ffffffff, Unit 1, Rotation 0
Feb 9 10:20:35 Mini-di-Lorenzo.lan WindowServer[134]: Display 0x003f003c: GL mask 0x1; bounds (0, 0)[0 x 0], 1 modes available
off-line, enabled, boot, Vendor ffffffff, Model ffffffff, S/N ffffffff, Unit 0, Rotation 0
Feb 9 10:20:35 Mini-di-Lorenzo.lan WindowServer[134]: Set a breakpoint at CGSLogError to catch errors as they are logged.
Feb 9 10:20:35 Mini-di-Lorenzo.lan WindowServer[134]: WSSetWindowTransform: Singular matrix
Feb 9 10:20:35 Mini-di-Lorenzo.lan WindowServer[134]: Display 0x003f0040: GL mask 0x10; bounds (2944, 0)[1 x 1], 2 modes available
Feb 9 10:20:35 Mini-di-Lorenzo.lan WindowServer[134]: Display 0x003f003e: GL mask 0x4; bounds (2945, 0)[1 x 1], 1 modes available
Feb 9 10:20:35 Mini-di-Lorenzo.lan WindowServer[134]: Display 0x003f003d: GL mask 0x2; bounds (2946, 0)[1 x 1], 1 modes available
Feb 9 10:20:35 Mini-di-Lorenzo.lan WindowServer[134]: Display 0x003f003c: GL mask 0x1; bounds (2947, 0)[1 x 1], 1 modes available
Feb 9 10:20:35 Mini-di-Lorenzo.lan WindowServer[134]: CGXPerformInitialDisplayConfiguration
Feb 9 10:20:35 Mini-di-Lorenzo.lan WindowServer[134]: Display 0x1a493c83: Unit 3; Vendor 0x469 Model 0x24f2 S/N 0 Dimensions 20.91 x 11.77; online enabled, Bounds (0,0)[1920 x 1080], Rotation 0, Resolution 1
Feb 9 10:20:35 Mini-di-Lorenzo.lan WindowServer[134]: Display 0x003f0040: Unit 4; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (2944,0)[1 x 1], Rotation 0, Resolution 1
Feb 9 10:20:35 Mini-di-Lorenzo.lan WindowServer[134]: Display 0x003f003e: Unit 2; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (2945,0)[1 x 1], Rotation 0, Resolution 1
Feb 9 10:20:35 Mini-di-Lorenzo.lan WindowServer[134]: Display 0x003f003d: Unit 1; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (2946,0)[1 x 1], Rotation 0, Resolution 1
Feb 9 10:20:35 Mini-di-Lorenzo.lan WindowServer[134]: Display 0x003f003c: Unit 0; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (2947,0)[1 x 1], Rotation 0, Resolution 1
Feb 9 10:20:35 Mini-di-Lorenzo.lan hidd[70]: IOHIDService compatibility thread running at priority 63 and schedule 2.
Feb 9 10:20:35 Mini-di-Lorenzo.lan WindowServer[134]: GLCompositor: GL renderer id 0x01021b06, GL mask 0x0000001f, accelerator 0x00003153, unit 0, caps QEX|MIPMAP, vram 256 MB
Feb 9 10:20:35 Mini-di-Lorenzo.lan WindowServer[134]: GLCompositor: GL renderer id 0x01021b06, GL mask 0x0000001f, texture max 16384, viewport max {16384, 16384}, extensions NPOT|GLSL|FLOAT
Feb 9 10:20:35 Mini-di-Lorenzo.lan WindowServer[134]: GLCompositor enabled for tile size [256 x 256]
Feb 9 10:20:35 Mini-di-Lorenzo.lan WindowServer[134]: CGXGLInitMipMap: mip map mode is on
Feb 9 10:20:35 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.FileSyncAgent.PHD.isRunning): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:35 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.mbloginhelper.user): This key does not do anything: OnDemand
Feb 9 10:20:35 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.mbpluginhost.user): This key does not do anything: OnDemand
Feb 9 10:20:35 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.secd): This key does not do anything: OnDemand
Feb 9 10:20:35 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.secd): The ServiceIPC key is no longer respected. Please remove it.
Feb 9 10:20:35 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): This key does not do anything: OnDemand
Feb 9 10:20:35 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.TrustEvaluationAgent): This key does not do anything: OnDemand
Feb 9 10:20:35 Mini-di-Lorenzo.lan WindowServer[134]: CGXSetDisplayColorProfileAndTransfer: Display 0x1a493c83: Unit 3; ColorProfile { -964737535 }; TransferFormula (1.000000, 1.000000, 1.000000)
Feb 9 10:20:36 Mini-di-Lorenzo.lan com.apple.AmbientDisplayAgent[180]: AmbientDisplayAgent started
Feb 9 10:20:36 Mini-di-Lorenzo.lan com.apple.AmbientDisplayAgent[180]: AMBD initializing devices
Feb 9 10:20:36 Mini-di-Lorenzo.lan com.apple.AmbientDisplayAgent[180]: AMBD Agent: xpc connection became invalid during event handler
Feb 9 10:20:36 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.AssistiveControl.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:36 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.btsa): This key does not do anything: OnDemand
Feb 9 10:20:36 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.coreservices.lsactivity): Unknown key for Boolean: DrainMessagesAfterFailedInit
Feb 9 10:20:36 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.helpd): This key does not do anything: OnDemand
Feb 9 10:20:36 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.noticeboard.agent): This key does not do anything: OnDemand
Feb 9 10:20:36 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): This key does not do anything: OnDemand
Feb 9 10:20:36 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.inputswitcher.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:36 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.universalaccesscontrol.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:36 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.universalaccessd.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:36 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.UserEventAgent-LoginWindow): This service is defined to be constantly running and is inherently inefficient.
Feb 9 10:20:36 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.VoiceOver.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:36 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.ZoomWindow.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:36 Mini-di-Lorenzo askpermissiond[181]: objc[181]: Class FALogging is implemented in both /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/FamilyCircle and /System/Library/PrivateFrameworks/FamilyNotification.framework/Versions/A/FamilyNotification. One of the two will be used. Which one is undefined.
Feb 9 10:20:36 Mini-di-Lorenzo.lan com.apple.SecurityServer[53]: Session 100006 created
Feb 9 10:20:36 Mini-di-Lorenzo.lan askpermissiond[181]: StoreTransport: Resetting APS Connection using environment name production
Feb 9 10:20:36 Mini-di-Lorenzo.lan apsd[50]: Unable to bootstrap_look_up connection port 'com.apple.askpermission.aps' for user 0: Unknown service name
Feb 9 10:20:36 Mini-di-Lorenzo.lan UserEventAgent[186]: Failed to copy info dictionary for bundle /System/Library/UserEventPlugins/alfUIplugin.plugin
Feb 9 10:20:36 Mini-di-Lorenzo.lan UserEventAgent[186]: user agent networkd: built Nov 19 2014 21:39:47
Feb 9 10:20:36 Mini-di-Lorenzo.lan WiFiAgent[187]: [NO client logger] <Sep 9 2014 16:12:26> WIFICLOUDSYNC WiFiCloudSyncEngineCreate: created...
Feb 9 10:20:36 Mini-di-Lorenzo.lan WiFiAgent[187]: [NO client logger] <Sep 9 2014 16:12:26> WIFICLOUDSYNC WiFiCloudSyncEngineRegisterCallbacks: WiFiCloudSyncEngineCallbacks version - 0, bundle id - com.apple.wifi.WiFiAgent
Feb 9 10:20:36 Mini-di-Lorenzo.lan WiFiAgent[187]: securityd_message_with_reply_sync Failed to talk to secd after 4 attempts.
Feb 9 10:20:36 Mini-di-Lorenzo.lan loginwindow[66]: ERROR | -[LoginProgress startingProgressRectForMainScreen] | Could not locate the boot display
Feb 9 10:20:36 Mini-di-Lorenzo.lan WindowServer[134]: MPAccessSurfaceForDisplayDevice: Set up page flip mode on display 0x1a493c83 device: 0x7f9dc8c28ac0 isBackBuffered: 1 numComp: 3 numDisp: 3
Feb 9 10:20:36 Mini-di-Lorenzo.lan WindowServer[134]: _CGXGLDisplayContextForDisplayDevice: acquired display context (0x7f9dc8c28ac0) - enabling OpenGL
Feb 9 10:20:36 Mini-di-Lorenzo.lan loginwindow[66]: The current system was not found in the list of machines requiring a switch to a black background
Feb 9 10:20:36 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.DataDetectorsDynamicData): The JoinExistingSession key is only available to Application services.
Feb 9 10:20:36 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.appkit.xpc.sandboxedServiceRunner): The JoinExistingSession key is only available to Application services.
Feb 9 10:20:36 Mini-di-Lorenzo.lan loginwindow[66]: Login Window Started Security Agent
Feb 9 10:20:36 Mini-di-Lorenzo.lan SecurityAgent[191]: This is the first run
Feb 9 10:20:36 Mini-di-Lorenzo.lan SecurityAgent[191]: MacBuddy was run = 0
Feb 9 10:20:36 Mini-di-Lorenzo kernel[0]: hfs: mounted Lacie Esterno on device disk1s2
Feb 9 10:20:36 Mini-di-Lorenzo kernel[0]: hfs: unmount initiated on Lacie Esterno on device disk1s2
Feb 9 10:20:37 Mini-di-Lorenzo.lan WindowServer[134]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'. Run with arg = -discovery
Feb 9 10:20:37 Mini-di-Lorenzo.lan WindowServer[134]: CGXSetDisplayColorProfileAndTransfer: Display 0x1a493c83: Unit 3; ColorProfile { -964737535 }; TransferFormula (1.000000, 1.000000, 1.000000)
Feb 9 10:20:37 Mini-di-Lorenzo.lan com.apple.AmbientDisplayAgent[180]: AMBD Agent: xpc connection became invalid during event handler
Feb 9 10:20:37 Mini-di-Lorenzo.lan DMProxy[204]: AMBD Services: connection interrupted: com.apple.AmbientDisplayAgent (Connection interrupted)
Feb 9 10:20:37 Mini-di-Lorenzo.lan com.apple.AmbientDisplayAgent[180]: AmbientDisplayAgent started
Feb 9 10:20:38 Mini-di-Lorenzo.lan com.apple.AmbientDisplayAgent[180]: AMBD initializing devices
Feb 9 10:20:38 Mini-di-Lorenzo.lan com.apple.AmbientDisplayAgent[180]: AMBD Agent: xpc connection became invalid during event handler
Feb 9 10:20:38 Mini-di-Lorenzo kernel[0]: IOBluetoothDevice::setProperties() -- calling hciController->CallCreateDeviceReporter() -- this = 0xa400
Feb 9 10:20:38 Mini-di-Lorenzo kernel[0]: IOBluetoothHCIController::CallCreateDeviceReporter -- calling enqueueAction() -- device = 0xa400
Feb 9 10:20:38 Mini-di-Lorenzo kernel[0]: IOBluetoothHCIController::CreateDeviceReporterAction -- device = = 0xa400
Feb 9 10:20:38 Mini-di-Lorenzo kernel[0]: IOBluetoothHCIController::CreateDeviceReporterAction -- calling CreateDeviceReporter() device = = 0xa400
Feb 9 10:20:38 Mini-di-Lorenzo kernel[0]: IOBluetoothHCIController::CreateDeviceReporter -- device = = 0xa400
Feb 9 10:20:38 Mini-di-Lorenzo.lan blued[58]: Release the WiFi lock
Feb 9 10:20:38 Mini-di-Lorenzo.lan blued[58]: Acquiring the wifi lock
Feb 9 10:20:38 Mini-di-Lorenzo.lan blued[58]: Acquired the wifi lock
Feb 9 10:20:38 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.FileSyncAgent.PHD.isRunning): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:38 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.mbloginhelper.user): This key does not do anything: OnDemand
Feb 9 10:20:38 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.mbpluginhost.user): This key does not do anything: OnDemand
Feb 9 10:20:38 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.secd): This key does not do anything: OnDemand
Feb 9 10:20:38 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.secd): The ServiceIPC key is no longer respected. Please remove it.
Feb 9 10:20:38 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): This key does not do anything: OnDemand
Feb 9 10:20:38 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.TrustEvaluationAgent): This key does not do anything: OnDemand
Feb 9 10:20:38 Mini-di-Lorenzo.lan mds_stores[172]: (Permissions.Error:1719) Failed stat on perm journal with error 9
Feb 9 10:20:41 Mini-di-Lorenzo.lan BezelServices 250.13[66]: ASSERTION FAILED: dvcAddrRef != ((void *)0) -[DriverServices getDeviceAddress:] line: 2727
Feb 9 10:20:44 --- last message repeated 1 time ---
Feb 9 10:20:44 Mini-di-Lorenzo.lan blued[58]: Logging disabled
Feb 9 10:20:46 Mini-di-Lorenzo.lan nsurlstoraged[171]: realpath() returned NULL for /var/root/Library/Caches/$(CFBundleIdentifier)
Feb 9 10:20:46 Mini-di-Lorenzo.lan nsurlstoraged[171]: The read-connection to the DB=/var/root/Library/Caches/$(CFBundleIdentifier)/Cache.db is NOT valid. Unable to determine schema version.
Feb 9 10:20:46 --- last message repeated 1 time ---
Feb 9 10:20:46 Mini-di-Lorenzo.lan nsurlstoraged[171]: ERROR: unable to determine file-system usage for FS-backed cache at /var/root/Library/Caches/$(CFBundleIdentifier)/fsCachedData. Errno=13
Feb 9 10:20:47 Mini-di-Lorenzo.lan AppleIDAuthAgent[182]: AppleIdAuth URL:
https://identity.apple.com/dsservices/dsxmlrpc" onclick="window.open(this.href);return false;
Feb 9 10:20:51 Mini-di-Lorenzo.lan SecurityAgent[191]: User info context values set for Fobiax
Feb 9 10:20:51 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.FileSyncAgent.PHD.isRunning): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:51 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.mbloginhelper.user): This key does not do anything: OnDemand
Feb 9 10:20:51 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.mbpluginhost.user): This key does not do anything: OnDemand
Feb 9 10:20:51 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.secd): This key does not do anything: OnDemand
Feb 9 10:20:51 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.secd): The ServiceIPC key is no longer respected. Please remove it.
Feb 9 10:20:51 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): This key does not do anything: OnDemand
Feb 9 10:20:51 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.TrustEvaluationAgent): This key does not do anything: OnDemand
Feb 9 10:20:52 Mini-di-Lorenzo.lan SecurityAgent[191]: Login Window login proceeding
Feb 9 10:20:52 Mini-di-Lorenzo.lan loginwindow[66]: Login Window - Returned from Security Agent
Feb 9 10:20:52 Mini-di-Lorenzo.lan loginwindow[66]: USER_PROCESS: 66 console
Feb 9 10:20:52 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.FileSyncAgent.PHD.isRunning): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:52 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.mbloginhelper.user): This key does not do anything: OnDemand
Feb 9 10:20:52 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.mbpluginhost.user): This key does not do anything: OnDemand
Feb 9 10:20:52 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.secd): This key does not do anything: OnDemand
Feb 9 10:20:52 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.secd): The ServiceIPC key is no longer respected. Please remove it.
Feb 9 10:20:52 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): This key does not do anything: OnDemand
Feb 9 10:20:52 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.TrustEvaluationAgent): This key does not do anything: OnDemand
Feb 9 10:20:53 Mini-di-Lorenzo kernel[0]: AppleKeyStore:Sending lock change 0 for handle -501
Feb 9 10:20:53 Mini-di-Lorenzo.lan distnoted[212]: # distnote server agent absolute time: 65.319206741 civil time: Mon Feb 9 10:20:53 2015 pid: 212 uid: 501 root: no
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.AssistiveControl.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.btsa): This key does not do anything: OnDemand
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.coreservices.lsactivity): Unknown key for Boolean: DrainMessagesAfterFailedInit
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.coreservices.uiagent): This key does not do anything: OnDemand
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.diagnostics_agent): This service is defined to be constantly running and is inherently inefficient.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.dock.fullscreen): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.dock.server): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.dock.notificationcenter): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.dock.appstore): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.dock.remotedesktoppicture): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.dock.launchpad): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.dock.downloads): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.EscrowSecurityAlert): Unknown key for string: seatbelt-profiles
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.Finder): ThrottleInterval set to zero. You're not that important. Ignoring.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.FontRegistryUIAgent): This key does not do anything: OnDemand
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.ATS.FontValidator): This key does not do anything: OnDemand
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.ATS.FontValidatorConduit): This key does not do anything: OnDemand
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.gamed): The JetsamProperties key is not available on this platform.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.gamed): This key does not do anything: OnDemand
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.gamed): The ServiceIPC key is no longer respected. Please remove it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.helpd): This key does not do anything: OnDemand
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.installd.user): This key does not do anything: OnDemand
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.Maps.mapspushd): Unknown key for double: StartInterval
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.501.100006.Aqua): Caller tried to hijack service: path = /System/Library/LaunchAgents/com.apple.mbpluginhost.user.plist, caller = loginwindow.66
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.midiserver.io): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.noticeboard.agent): This key does not do anything: OnDemand
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.notificationcenterui.alerts): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.notificationcenterui.tcc): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.notificationcenterui.agent): This service is defined to be constantly running and is inherently inefficient.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.501.100006.Aqua): Caller tried to hijack service: path = /System/Library/LaunchAgents/com.apple.pluginkit.pkd.plist, caller = loginwindow.66
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.PubSub.Agent): The ServiceIPC key is no longer respected. Please remove it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.quicklook.ui.helper.active): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.ReportCrash): The DrainMessagesOnCrash key is not yet implemented. If you rely on this key, please file a bug.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.ReportCrash.Self): The DrainMessagesOnCrash key is not yet implemented. If you rely on this key, please file a bug.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.rtcreportingd): The UserName key is not supported for non-System services.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.sharingd): This service is defined to be constantly running and is inherently inefficient.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.soagent): Invalid type for event (event/type): events/array
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.soagent): Invalid type for event (event/type): bundleid/string
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.speech.speechdatainstallerd): This key does not do anything: OnDemand
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.ssinvitationagent): This key does not do anything: OnDemand
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.systemuiserver.ServiceProvider): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.dockextra.server): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.SUISMessaging): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.ipodserver): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.systemuiserver.screencapture): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.tsm.uiserver): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.dockling.server): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.window_proxies.startup): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.window_proxies): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.inputswitcher.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.universalaccesscontrol.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.universalaccessd.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.UserEventAgent-Aqua): This service is defined to be constantly running and is inherently inefficient.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.usernoted): This service is defined to be constantly running and is inherently inefficient.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.VoiceOver.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.ZoomWindow.running): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (org.openbsd.ssh-agent): The ServiceIPC key is no longer respected. Please remove it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.hp.devicemonitor): This service is defined to be constantly running and is inherently inefficient.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.501.100006.Aqua): Failed to bootstrap path: path = /System/Library/LaunchAgents/com.apple.pluginkit.pkd.plist, error = 17: File exists
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.501.100006.Aqua): Failed to bootstrap path: path = /System/Library/LaunchAgents/com.apple.mbpluginhost.user.plist, error = 17: File exists
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.nds.pcshow): Please switch away from OnDemand to KeepAlive.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.DataDetectorsDynamicData): The JoinExistingSession key is only available to Application services.
Feb 9 10:20:53 --- last message repeated 1 time ---
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.appkit.xpc.sandboxedServiceRunner): The JoinExistingSession key is only available to Application services.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.FileSyncAgent.PHD.isRunning): The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.mbloginhelper.user): This key does not do anything: OnDemand
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.mbpluginhost.user): This key does not do anything: OnDemand
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.secd): This key does not do anything: OnDemand
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.secd): The ServiceIPC key is no longer respected. Please remove it.
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.speech.speechsynthesisd): This key does not do anything: OnDemand
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.TrustEvaluationAgent): This key does not do anything: OnDemand
Feb 9 10:20:53 Mini-di-Lorenzo.lan UserEventAgent[210]: Failed to copy info dictionary for bundle /System/Library/UserEventPlugins/alfUIplugin.plugin
Feb 9 10:20:53 Mini-di-Lorenzo.lan UserEventAgent[210]: user agent networkd: built Nov 19 2014 21:39:47
Feb 9 10:20:53 Mini-di-Lorenzo.lan UserEventAgent[210]: received an unknown event from daemon
Feb 9 10:20:53 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Feb 9 10:20:53 Mini-di-Lorenzo.lan secinitd[225]: UID[501]: cache loaded: /System/Library/Caches/com.apple.app-sandbox-cache.plist
Feb 9 10:20:53 Mini-di-Lorenzo.lan com.apple.SecurityServer[53]: Session 100010 created
Feb 9 10:20:54 Mini-di-Lorenzo.lan com.apple.audio.DriverHelper[221]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class AMDRadeonX4000_AMDAccelDevice.
Feb 9 10:20:54 Mini-di-Lorenzo.lan com.apple.audio.DriverHelper[221]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class AMDRadeonX4000_AMDAccelSharedUserClient.
Feb 9 10:20:54 Mini-di-Lorenzo.lan com.apple.audio.DriverHelper[221]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class AMDSIVideoContext.
Feb 9 10:20:54 Mini-di-Lorenzo.lan com.apple.audio.DriverHelper[221]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class Gen6DVDContext.
Feb 9 10:20:54 Mini-di-Lorenzo.lan com.apple.audio.DriverHelper[221]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IGAccelDevice.
Feb 9 10:20:54 Mini-di-Lorenzo.lan com.apple.audio.DriverHelper[221]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IGAccelSharedUserClient.
Feb 9 10:20:54 Mini-di-Lorenzo.lan com.apple.audio.DriverHelper[221]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IGAccelVideoContextMain.
Feb 9 10:20:54 Mini-di-Lorenzo.lan com.apple.audio.DriverHelper[221]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IGAccelVideoContextMedia.
Feb 9 10:20:54 Mini-di-Lorenzo.lan com.apple.audio.DriverHelper[221]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IGAccelVideoContextVEBox.
Feb 9 10:20:54 Mini-di-Lorenzo.lan com.apple.audio.DriverHelper[221]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IOBluetoothDeviceUserClient.
Feb 9 10:20:54 Mini-di-Lorenzo.lan com.apple.audio.DriverHelper[221]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IOHIDParamUserClient.
Feb 9 10:20:54 Mini-di-Lorenzo.lan com.apple.audio.DriverHelper[221]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IOSurfaceRootUserClient.
Feb 9 10:20:54 Mini-di-Lorenzo.lan com.apple.audio.DriverHelper[221]: The plug-in named AirPlay.driver requires extending the sandbox for the mach service named com.apple.AirPlayXPCHelper.
Feb 9 10:20:54 Mini-di-Lorenzo.lan com.apple.audio.DriverHelper[221]: The plug-in named AirPlay.driver requires extending the sandbox for the mach service named com.apple.wirelessproxd.
Feb 9 10:20:54 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.appkit.xpc.sandboxedServiceRunner): The JoinExistingSession key is only available to Application services.
Feb 9 10:20:54 Mini-di-Lorenzo.lan coreaudiod[220]: 2015-02-09 10:20:54.200116 AM [AirPlay] BTLE discovery removing all devices
Feb 9 10:20:54 Mini-di-Lorenzo.lan coreaudiod[220]: 2015-02-09 10:20:54.201316 AM [AirPlay] Resetting AWDL traffic registration.
Feb 9 10:20:54 Mini-di-Lorenzo.lan coreaudiod[220]: 2015-02-09 10:20:54.201688 AM [AirPlay] Deregister AirPlay traffic for AWDL at MAC 00:00:00:00:00:00 with target infra non critical PeerIndication=0 err=-3900
Feb 9 10:20:54 Mini-di-Lorenzo.lan com.apple.audio.DriverHelper[221]: The plug-in named BluetoothAudioPlugIn.driver requires extending the sandbox for the IOKit user-client class IOBluetoothDeviceUserClient.
Feb 9 10:20:54 Mini-di-Lorenzo.lan com.apple.audio.DriverHelper[221]: The plug-in named BluetoothAudioPlugIn.driver requires extending the sandbox for the mach service named com.apple.blued.
Feb 9 10:20:54 Mini-di-Lorenzo.lan com.apple.audio.DriverHelper[221]: The plug-in named BluetoothAudioPlugIn.driver requires extending the sandbox for the mach service named com.apple.bluetoothaudiod.
Feb 9 10:20:54 Mini-di-Lorenzo.lan coreaudiod[220]: 2015-02-09 10:20:54.206373 AM [AirPlay] BTLE client stopping to browse for AirPlay Solo Target Presence.
Feb 9 10:20:54 Mini-di-Lorenzo.lan coreaudiod[220]: 2015-02-09 10:20:54.206647 AM [AirPlay] BTLE client starting to browse for AirPlay Solo Target Presence.
Feb 9 10:20:54 Mini-di-Lorenzo.lan coreaudiod[220]: 2015-02-09 10:20:54.208073 AM [AirPlay] BTLE client stopped to browse for AirPlay Solo Target Presence.
Feb 9 10:20:54 Mini-di-Lorenzo.lan coreaudiod[220]: 2015-02-09 10:20:54.208588 AM [AirPlay] BTLE client started to browse for AirPlay Solo Target Presence.
Feb 9 10:20:54 Mini-di-Lorenzo.lan coreaudiod[220]: Logging disabled
Feb 9 10:20:54 Mini-di-Lorenzo.lan coreaudiod[220]: 2015-02-09 10:20:54.231054 AM [AirPlay] AirPlay: Performing audio format change for 4 (AP Out) to PCM/44100/16/2 for output and for input
Feb 9 10:20:54 Mini-di-Lorenzo.lan coreaudiod[220]: 2015-02-09 10:20:54.231264 AM [AirPlay] AirPlay: Performing audio format change for 4 (AP Out) to PCM/44100/16/2 for output and for input
Feb 9 10:20:54 Mini-di-Lorenzo.lan bluetoothaudiod[227]: Logging disabled
Feb 9 10:20:55 Mini-di-Lorenzo.lan coreaudiod[220]: 2015-02-09 10:20:55.533840 AM [AirPlay] AirPlay: Performing audio format change for 4 (AP Out) to PCM/44100/16/2 for output and PCM/44100/16/2 for input
Feb 9 10:20:55 Mini-di-Lorenzo.lan coreaudiod[220]: 2015-02-09 10:20:55.555336 AM [AirPlay] AirPlay: Performing audio format change for 4 (AP Out) to PCM/44100/16/2 for output and for input
Feb 9 10:20:55 Mini-di-Lorenzo.lan coreaudiod[220]: 2015-02-09 10:20:55.555541 AM [AirPlay] AirPlay: Performing audio format change for 4 (AP Out) to PCM/44100/16/2 for output and for input
Feb 9 10:20:55 Mini-di-Lorenzo.lan lsregister[215]: LaunchServices: Begin database seeding
Feb 9 10:20:55 Mini-di-Lorenzo.lan lsregister[215]: LaunchServices: Completed database seeding
Feb 9 10:20:55 Mini-di-Lorenzo.lan pboard[233]: Attempt to unlink previous shared memory during startup returned an error. Continuing...
Feb 9 10:20:55 Mini-di-Lorenzo.lan tccd[203]: Communications error: <OS_xpc_error: <error: 0x7fff79be4c60> { count = 1, contents =
"XPCErrorDescription" => <string: 0x7fff79be4f70> { length = 18, contents = "Connection invalid" }
Feb 9 10:20:55 Mini-di-Lorenzo.lan WindowServer[134]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'. Run with arg = -login
Feb 9 10:20:55 Mini-di-Lorenzo.lan DMProxy[236]: AMBD Services: connection interrupted: com.apple.AmbientDisplayAgent (Connection interrupted)
Feb 9 10:20:55 Mini-di-Lorenzo.lan com.apple.AmbientDisplayAgent[180]: AmbientDisplayAgent started
Feb 9 10:20:55 Mini-di-Lorenzo.lan sharingd[243]: 10:20:55.899 : Starting Up...
Feb 9 10:20:55 Mini-di-Lorenzo.lan sharingd[243]: 10:20:55.914 : Device Capabilities (Handoff:NO, Instant Hotspot:NO, AirDrop:NO, Legacy AirDrop:YES, Remote Disc:YES)
Feb 9 10:20:56 Mini-di-Lorenzo kernel[0]: hfs: mounted Lacie Esterno on device disk1s2
Feb 9 10:20:56 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.501.100006.Aqua): Could not import service from caller: caller = otherbsd.211, service = com.freemacsoft.AppCleaner-Helper, error = 119: Service is disabled
Feb 9 10:20:56 Mini-di-Lorenzo.lan otherbsd[211]: Could not submit LoginItem job com.freemacsoft.AppCleaner-Helper: 119: Service is disabled
Feb 9 10:20:56 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.501.100006.Aqua): Could not import service from caller: caller = otherbsd.211, service = com.apple.photostream-agent, error = 119: Service is disabled
Feb 9 10:20:56 Mini-di-Lorenzo.lan otherbsd[211]: Could not submit LoginItem job com.apple.photostream-agent: 119: Service is disabled
Feb 9 10:20:56 Mini-di-Lorenzo.lan Spotlight[248]: spot: agent checkin
Feb 9 10:20:56 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Feb 9 10:20:56 Mini-di-Lorenzo.lan iconservicesagent[256]: iconservicesagent launched.
Feb 9 10:20:56 Mini-di-Lorenzo.lan iconservicesagent[256]: Starting service with cache path: /var/folders/rb/xgqqxsls6k5gbyknfs7c7pqm0000gn/C/com.apple.iconservices
Feb 9 10:20:56 Mini-di-Lorenzo.lan SystemUIServer[218]: Cannot find executable for CFBundle 0x7f84f9c0b130 </System/Library/CoreServices/Menu Extras/Clock.menu> (not loaded)
Feb 9 10:20:57 Mini-di-Lorenzo Finder[219]: assertion failed: 14C109: libxpc.dylib + 97940 [876216DC-D5D3-381E-8AF9-49AE464E5107]: 0x89
Feb 9 10:20:57 Mini-di-Lorenzo.lan SystemUIServer[218]: Cannot find executable for CFBundle 0x7f84f9d1f680 </System/Library/CoreServices/Menu Extras/Volume.menu> (not loaded)
Feb 9 10:20:57 Mini-di-Lorenzo com.apple.xpc.launchd[1] (
com.apple.CSConfigDotMacCert-fobiax@me.com-SharedServices[260]): Could not find and/or execute program specified by service: 2: No such file or directory: /System/Library/Frameworks/CoreServices.framework/Frameworks/OSServices.framework/Versions/A/Support/CSConfigDotMacCert
com.apple.CSConfigDotMacCert-fobiax@me.com-SharedServices[260]): Service setup event to handle failure and will not launch until it fires.
Feb 9 10:20:57 Mini-di-Lorenzo.lan backupd[150]: Property list invalid for format: 200 (property lists cannot contain NULL)
Feb 9 10:20:57 Mini-di-Lorenzo askpermissiond[275]: objc[275]: Class FALogging is implemented in both /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/FamilyCircle and /System/Library/PrivateFrameworks/FamilyNotification.framework/Versions/A/FamilyNotification. One of the two will be used. Which one is undefined.
Feb 9 10:20:57 Mini-di-Lorenzo.lan HP Device Monitor[272]: WARNING: The Gestalt selector gestaltSystemVersion is returning 10.9.2 instead of 10.10.2. Use NSProcessInfo's operatingSystemVersion property to get correct system version number.
Call location:
Feb 9 10:20:57 Mini-di-Lorenzo.lan HP Device Monitor[272]: 0 CarbonCore 0x00007fff91b3cd9b ___Gestalt_SystemVersion_block_invoke + 113
Feb 9 10:20:57 Mini-di-Lorenzo.lan HP Device Monitor[272]: 1 libdispatch.dylib 0x00007fff9526fc13 _dispatch_client_callout + 8
Feb 9 10:20:57 Mini-di-Lorenzo.lan HP Device Monitor[272]: 2 libdispatch.dylib 0x00007fff9526fb26 dispatch_once_f + 117
Feb 9 10:20:57 Mini-di-Lorenzo.lan HP Device Monitor[272]: 3 CarbonCore 0x00007fff91ae53ca _Gestalt_SystemVersion + 987
Feb 9 10:20:57 Mini-di-Lorenzo.lan HP Device Monitor[272]: 4 CarbonCore 0x00007fff91ae4fb7 Gestalt + 144
Feb 9 10:20:57 Mini-di-Lorenzo.lan HP Device Monitor[272]: 5 Core 0x00000001001175c7 DMGetLocalSysVersion + 29
Feb 9 10:20:57 Mini-di-Lorenzo.lan HP Device Monitor[272]: 6 Core 0x0000000100117470 DMGetObjCProtocolName + 17
Feb 9 10:20:57 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.imdmessageservices.IMDMessageServicesAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Feb 9 10:20:57 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): The _DirtyJetsamMemoryLimit key is not available on this platform.
Feb 9 10:20:58 Mini-di-Lorenzo.lan SystemUIServer[218]: Could not find image named 'greenmarker'.
Feb 9 10:20:58 Mini-di-Lorenzo.lan logind[67]: -[SessionManager getClient:withRole:inAuditSession:]:241: ERROR: No session dictionary for audit session 100010
Feb 9 10:20:58 Mini-di-Lorenzo.lan logind[67]: _SMGetSessionAgent:73: ERROR: __SMGetClientForAuditSessionAgent failed 2
Feb 9 10:20:58 Mini-di-Lorenzo.lan IMDPersistenceAgent[296]: SACShieldWindowShowing:925: ERROR: NULL response
Feb 9 10:20:58 Mini-di-Lorenzo.lan backupd[150]: Property list invalid for format: 200 (property lists cannot contain NULL)
Feb 9 10:20:58 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.lakitu): The JoinExistingSession key is only available to Application services.
Feb 9 10:20:58 Mini-di-Lorenzo com.apple.xpc.launchd[1] (com.apple.accounts.dom): The _DirtyJetsamMemoryLimit key is not available on this platform.
