macariog
- Apprendista Maccanico
salve a tutti...ho un imac con processore 2,66Ghz intel core Duo con sistema operativo Mac Os x 10.6.8
a me sembra negli ultimi giorni abbastanza lento...se apro più pagine, se gioco su quei giochini di facebook e quanto altro.....leggendo sulla rete dove si leggono tante cose, non sono comunque riuscito a capire cosa possa essere.....intanto sono andato su console e mi sono uscite tante righe...provo a postarle qui dove magari qualcuno riesce a darmi un'idea di dove possa intervenire
26/01/12 09.50.23 com.apple.launchd[1] *** launchd[1] has started up. ***
26/01/12 09.50.32 com.apple.launchd[1] (com.apple.SystemStarter) Failed to count the number of files in "/System/Library/StartupItems": No such file or directory
26/01/12 09.50.36 com.apple.launchd[1] (com.apple.SystemStarter) Failed to count the number of files in "/System/Library/StartupItems": No such file or directory
26/01/12 09.50.41 com.apple.launchd.peruser.501[88] (com.apple.ReportCrash) Falling back to default Mach exception handler. Could not find: com.apple.ReportCrash.Self
26/01/12 09.50.44 com.apple.launchd.peruser.501[88] (com.apple.Kerberos.renew.plist[114]) Exited with exit code: 1
26/01/12 10.48.59 com.apple.WindowServer[57] Thu Jan 26 10:48:59 imac(il mio)-1622.local WindowServer[57] <Error>: kCGErrorFailure: Set a breakpoint @ CGErrorBreakpoint() to catch errors as they are logged.
26/01/12 10.50.58 com.apple.backupd-auto[170] Not starting scheduled Time Machine backup - time machine destination not resolvable.
26/01/12 11.05.33 [0x0-0x10010].org.mozilla.firefox[134] NOTE: child process received `Goodbye', closing down
26/01/12 11.05.33 ARM[125] Adobe Reader Updater encountered errorCode 1651
26/01/12 11.05.33 com.apple.launchd.peruser.501[88] (com.apple.AirPortBaseStationAgent[116]) Exited: Killed
26/01/12 11.05.34 com.apple.launchd[1] (com.apple.SystemStarter) Failed to count the number of files in "/System/Library/StartupItems": No such file or directory
credo ci sia qualcosa che non va...aspetto i vostri pareri ...e comincio a ringraziarvi..
Avvia dal DVD di Snow Leopard, scegli l'italiano e lancia Utility Disco.
Ripara il disco (non i permessi) del tuo Macintosh HD esci dai programma (mela Q) e riavvia.
Poi, se ancora lo trovi lento, prova a scaricare e installare l'ultima combo per Snow Leopard:
http://support.apple.com/kb/dl1399" onclick="window.open(this.href);return false;
macariog
ho provato ad installare la combo update....ma i risultati non cambiano....appena apro più pagine...il pc si impalla...e si rallenta....pensate che di solito ho una finestra di youtube sempre aperta insieme ad altre...e quando le chiudo la musica dei video resta per qualche secondo ancora in essere nonostante la finestra sia chiusa...
cosa posso provare ? c'è sicuramente qualche errore
kato
Mickie
- Expert Latitante
macariog ha scritto:ho provato ad installare la combo update....
Ma hai fatto anche la riparazione del disco come spiegato da Franz?
Era tutto ok?
macariog
Mickie ha scritto:macariog ha scritto:ho provato ad installare la combo update....
Era tutto ok?
spazio su disco tanto...
fatto verifica disco e ripara permessi....lui li ripara...ma niente....si impalla sempre
Visitano il forum: Bing [Bot] e 34 ospiti
