Ciao a tutti,
da ieri mi sono accorta che in Console, non appena mi attacco a internet con la chiavetta (Huawei E 122 supportata da TRE), mi compaiono messaggi di questo tipo:
21/02/11 09.53.21 [0x0-0x26026].com.huawei.MobilePartner[204] [JavaAppLauncher] Requested [1.5*], launching in [1.6] instead.
21/02/11 09.53.24 [0x0-0x26026].com.huawei.MobilePartner[204] aaaaaaaaa=dd/MM/yyyy
21/02/11 09.53.24 [0x0-0x26026].com.huawei.MobilePartner[204] bbbbbbb=HH:mm:ss
21/02/11 09.53.24 [0x0-0x26026].com.huawei.MobilePartner[204] Stable Library
21/02/11 09.53.24 [0x0-0x26026].com.huawei.MobilePartner[204] =========================================
21/02/11 09.53.24 [0x0-0x26026].com.huawei.MobilePartner[204] Native lib Version = RXTX-2.1-7
21/02/11 09.53.24 [0x0-0x26026].com.huawei.MobilePartner[204] Java lib Version = RXTX-2.1-7
21/02/11 09.53.24 [0x0-0x26026].com.huawei.MobilePartner[204] RXTX Warning: Removing stale lock file. /var/lock/LK.007.011.006
21/02/11 09.53.25 [0x0-0x26026].com.huawei.MobilePartner[204] <CFBasicHash 0x519550 [0xa
21/02/11 09.53.25 [0x0-0x26026].com.huawei.MobilePartner[204] 0a1eec0]>{type = mutable dict, count = 1,
21/02/11 09.53.25 [0x0-0x26026].com.huawei.MobilePartner[204] entries =>
21/02/11 09.53.25 [0x0-0x26026].com.huawei.MobilePartner[204] 2 : <CFSt
21/02/11 09.53.25 [0x0-0x26026].com.huawei.MobilePartner[204] ring 0xa0a2fbe8 [0xa0a1eec0]>{contents = "IOProvid
21/02/11 09.53.25 [0x0-0x26026].com.huawei.MobilePartner[204] erClass"} = <CFString 0x50624
21/02/11 09.53.25 [0x0-0x26026].com.huawei.MobilePartner[204] 0 [0xa0a1eec0]>{contents = "HuaweiDataC
21/02/11 09.53.25 [0x0-0x26026].com.huawei.MobilePartner[204] ardECMData"}
21/02/11 09.53.25 [0x0-0x26026].com.huawei.MobilePartner[204] }
21/02/11 09.53.25 [0x0-0x26026].com.huawei.MobilePartner[204] Couldn't find any matching drivers.
21/02/11 09.53.26 [0x0-0x26026].com.huawei.MobilePartner[204] [Time:2011-02-21 09:53:26,114] message: ------AT^SN-------ERROR or COMMAND NOT SUPPORT---
21/02/11 09.53.26 [0x0-0x26026].com.huawei.MobilePartner[204] [Time:2011-02-21 09:53:26,267] message: ------AT+CGSN-------ERROR or COMMAND NOT SUPPORT---
21/02/11 09.53.26 [0x0-0x26026].com.huawei.MobilePartner[204] [Time:2011-02-21 09:53:26,716] message: ------AT+CIMI-------ERROR or COMMAND NOT SUPPORT---
21/02/11 09.53.26 [0x0-0x26026].com.huawei.MobilePartner[204] [Time:2011-02-21 09:53:26,869] message: ------AT+CNUM-------ERROR or COMMAND NOT SUPPORT---
21/02/11 09.53.26 [0x0-0x26026].com.huawei.MobilePartner[204] [Time:2011-02-21 09:53:26,869] message: ------AT+CNUM----- return ------sconosciuto
21/02/11 09.53.27 [0x0-0x26026].com.huawei.MobilePartner[204] [Time:2011-02-21 09:53:27,021] message: ------AT+CPMS="SM"-------ERROR or COMMAND NOT SUPPORT---
21/02/11 09.53.27 [0x0-0x26026].com.huawei.MobilePartner[204] [Time:2011-02-21 09:53:27,022] message: ------AT+CPMS="SM"----- return ------sconosciuto
21/02/11 09.53.27 [0x0-0x26026].com.huawei.MobilePartner[204] [Time:2011-02-21 09:53:27,326] message: ------AT+CSCA?-------ERROR or COMMAND NOT SUPPORT---
ed in particolare questo susseguirsi di :
21/02/11 09.54.06 [0x0-0x26026].com.huawei.MobilePartner[204] [class com.huawei.mobilePartner.business.apn.SetDefaultAPN] message: CSNR algorithm is running
21/02/11 09.54.07 [0x0-0x26026].com.huawei.MobilePartner[204] [Time:2011-02-21 09:54:07,126] message: java.lang.StringIndexOutOfBoundsException: String index out of range: -1
21/02/11 09.54.07 [0x0-0x26026].com.huawei.MobilePartner[204] [class com.huawei.mobilePartner.business.apn.InitAPNManagement] message: search OPLlist error
21/02/11 09.54.07 [0x0-0x26026].com.huawei.MobilePartner[204] [class com.huawei.mobilePartner.business.apn.InitAPNManagement] message: ==PublicConfig.PinStatus=4
21/02/11 09.54.08 [0x0-0x26026].com.huawei.MobilePartner[204] [Time:2011-02-21 09:54:08,174] message: function[checkRefreshAccessMaxSize] failure: AT ERROR AT+CPBS="SM"
21/02/11 09.54.08 [0x0-0x26026].com.huawei.MobilePartner[204] [Time:2011-02-21 09:54:08,478] message: function[checkRefreshAccessMaxSize] failure: AT ERROR AT+CPBS="SM"
21/02/11 09.54.12 [0x0-0x26026].com.huawei.MobilePartner[204] <CFBasicHash 0x177ef0 [0xa0a1eec0]>{type = mutable dict,
21/02/11 09.54.12 [0x0-0x26026].com.huawei.MobilePartner[204] count = 1,
21/02/11 09.54.12 [0x0-0x26026].com.huawei.MobilePartner[204] entries =>
21/02/11 09.54.12 [0x0-0x26026].com.huawei.MobilePartner[204] 2 : <CFString 0xa0a2fbe8 [0xa0a1eec0]
21/02/11 09.54.12 [0x0-0x26026].com.huawei.MobilePartner[204] >{contents = "IOProviderClass"} = <CFStr
21/02/11 09.54.12 [0x0-0x26026].com.huawei.MobilePartner[204] ing 0x173ee0 [0xa0a1eec0]>{c
21/02/11 09.54.12 [0x0-0x26026].com.huawei.MobilePartner[204] ontents = "HuaweiDataCardECMDa
21/02/11 09.54.12 [0x0-0x26026].com.huawei.MobilePartner[204] ta"}
21/02/11 09.54.12 [0x0-0x26026].com.huawei.MobilePartner[204] }
21/02/11 09.54.12 [0x0-0x26026].com.huawei.MobilePartner[204] Couldn't find any matching drivers.
Ho un IMac 21,5', processore 3,2 GHz, Intel core i3
Memoria 4 GB 1333 Mhz DDR3
con OSX versione 10.6.6
Non ho notato rallentamenti di connessione; non mi sembra di aver fatto niente di particolare, ho solo verificato i DNS con Name Bench (che fra l'altro ha evidenziato che il server in uso era quello + veloce fra quelli disponibili).
Perchè questa serie di messaggi? Idee? Devo fare qualcosa?
Grazie e Buona settimana a tutti!
Sus
PS: ho trovato in rete questo:
http://www.italiamac.it/forum/showthread.php?t=388485
ma la mia connessione funziona ed il SO non è 10.6.3.
Ho provato a installare i driver aggiornati dellaTRE dal sito UK, ma mi sono incasinata con le impostazioni ed ho rimosso tutto; soprattutto non mi torna il fatto che la mia connessione è comunque ben funzionante..
