No, già controllato.faxus ha scritto:Chissà se a Jethro e Scialla adesso funziona il check su SMART...
smartctl 5.43 (build date Apr 27 2012) [x86_64-apple-darwin11.3.0] (local build)
Copyright (C) 2002-12 by Bruce Allen, http://smartmontools.sourceforge.net" onclick="window.open(this.href);return false;
=== START OF INFORMATION SECTION ===
Model Family: Samsung based SSDs
Device Model: SAMSUNG SSD 830 Series
Serial Number: S0WKNEAC300729
LU WWN Device Id: 5 002538 043584d30
Firmware Version: CXM03B1Q
User Capacity: 256,060,514,304 bytes [256 GB]
Sector Size: 512 bytes logical/physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: 8
ATA Standard is: ACS-2 revision 2
Local Time is: Mon Nov 7 22:24:23 2016 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF ENABLE/DISABLE COMMANDS SECTION ===
SMART Enabled.
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x02) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 25) The self-test routine was aborted by
the host.
Total time to complete Offline
data collection: ( 1020) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 17) minutes.
SMART Attributes Data Structure revision number: 1
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
9 Power_On_Hours 0x0032 098 098 000 Old_age Always - 9401
12 Power_Cycle_Count 0x0032 098 098 000 Old_age Always - 1581
177 Wear_Leveling_Count 0x0013 095 095 000 Pre-fail Always - 155
179 Used_Rsvd_Blk_Cnt_Tot 0x0013 100 100 010 Pre-fail Always - 0
181 Program_Fail_Cnt_Total 0x0032 100 100 010 Old_age Always - 0
182 Erase_Fail_Count_Total 0x0032 100 100 010 Old_age Always - 0
183 Runtime_Bad_Block 0x0013 100 100 010 Pre-fail Always - 0
187 Uncorrectable_Error_Cnt 0x0032 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0032 057 045 000 Old_age Always - 43
195 ECC_Rate 0x001a 200 200 000 Old_age Always - 0
199 CRC_Error_Count 0x003e 253 253 000 Old_age Always - 0
235 Unknown_Attribute 0x0012 099 099 000 Old_age Always - 177
241 Total_LBAs_Written 0x0032 099 099 000 Old_age Always - 20973438932
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Aborted by host 90% 9378 -
# 2 Short offline Aborted by host 90% 5202 -
# 3 Short offline Aborted by host 90% 4911 -
# 4 Short offline Aborted by host 90% 4810 -
# 5 Short offline Aborted by host 90% 4809 -
# 6 Short offline Aborted by host 90% 4657 -
# 7 Short offline Aborted by host 90% 4657 -
# 8 Short offline Aborted by host 90% 4656 -
# 9 Short offline Aborted by host 90% 4656 -
#10 Short offline Aborted by host 90% 4655 -
#11 Short offline Aborted by host 90% 4655 -
#12 Short offline Aborted by host 90% 4655 -
#13 Short offline Aborted by host 90% 4654 -
#14 Short offline Aborted by host 90% 4654 -
#15 Short offline Aborted by host 90% 4653 -
#16 Short offline Aborted by host 90% 4653 -
#17 Short offline Aborted by host 90% 4653 -
#18 Short offline Aborted by host 90% 4652 -
#19 Short offline Aborted by host 90% 4652 -
#20 Short offline Aborted by host 90% 4651 -
#21 Short offline Aborted by host 90% 4651 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
