smartctl 6.5 2016-05-07 r4318 [Darwin 14.5.0 x86_64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Hitachi Travelstar 5K500.B
Device Model: Hitachi HTS545032B9A300
Serial Number: 100113PBPC00QDF8N57L
LU WWN Device Id: 5 000cca 5a0ee3531
Firmware Version: PB3OC60N
User Capacity: 320,072,933,376 bytes [320 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 5400 rpm
Form Factor: 2.5 inches
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS T13/1699-D revision 6
SATA Version is: SATA 2.6, 3.0 Gb/s
Local Time is: Tue Nov 1 22:16:08 2016 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 645) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 106) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000b 100 100 062 Pre-fail Always - 0
2 Throughput_Performance 0x0005 100 100 040 Pre-fail Offline - 0
3 Spin_Up_Time 0x0007 136 136 033 Pre-fail Always - 1
4 Start_Stop_Count 0x0012 097 097 000 Old_age Always - 5056
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 100 100 040 Pre-fail Offline - 0
9 Power_On_Hours 0x0012 085 085 000 Old_age Always - 6892
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 097 097 000 Old_age Always - 4850
191 G-Sense_Error_Rate 0x000a 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 099 099 000 Old_age Always - 65800
193 Load_Cycle_Count 0x0012 080 080 000 Old_age Always - 207831
194 Temperature_Celsius 0x0002 183 183 000 Old_age Always - 30 (Min/Max 5/57)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
223 Load_Retry_Count 0x000a 100 100 000 Old_age Always - 0
SMART Error Log Version: 1
ATA Error Count: 3
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 3 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
10 51 01 81 15 43 e0 Error: IDNF 1 sectors at LBA = 0x00431581 = 4396417
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
25 db 01 81 15 43 e0 00 00:01:13.100 READ DMA EXT
25 db 01 81 15 43 e0 00 00:01:13.000 READ DMA EXT
35 db 01 00 00 00 e0 00 00:01:13.000 WRITE DMA EXT
25 db 01 00 00 00 e0 00 00:01:12.900 READ DMA EXT
25 db 01 81 15 43 e0 00 00:01:12.600 READ DMA EXT
Error 2 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
25 00 01 00 00 00 e0 00 00:00:35.200 READ DMA EXT
Error 1 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Extended offline Completed without error 00% 6407 -
# 2 Short offline Completed without error 00% 6404 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Strano. A me dice che Smart support è disabilitato, quando sia Utility Disco che Onyx invece mi danno stato Smart OK.kext ha scritto:Incuriosito, l'ho riscaricato per il report SMART.. Finalmente!
... EtreCheck, per me, sostituisce di gran lunga SMART Utility (almeno per le condizioni di salute e i vari errori catalogati in precedenza)..
smartctl 6.5 2016-05-07 r4318 [Darwin 13.4.0 x86_64] (local build)
Model Family: Apple SD/SM/TS...E/F SSDs
Device Model: APPLE SSD SD0256F
Serial Number: 1350A1402226
LU WWN Device Id: 5 001b44 a846ce5f2
Firmware Version: A223321
User Capacity: 251,000,193,024 bytes [251 GB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: Solid State Device
Form Factor: Unknown (0x0012)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Tue Nov 1 22:41:53 2016 CET
SMART support is: Disabled
SMART Disabled. Use option -s with argument 'on' to enable it.
(override with '-T permissive' option)
E che cavolo, non ci si può distrarre un attimo (ero al cinema).faxus ha scritto: KP sta invecchiando, latita e ci tocca fare gli straordinari......
Propendo di più nel pensare che la funzione SMART di EtreCheck, fra l'altro appena introdotta nel programma e quindi non testata a sufficienza, possa dare qualche risultato sballato.faxus ha scritto:Probabilmente lo avete disabilitato, chissà come e perché.
Impossibile.Jethro ha scritto:... Propendo di più nel pensare che la funzione SMART di EtreCheck, fra l'altro appena introdotta nel programma e quindi non testata a sufficienza, possa dare qualche risultato sballato....
Sono nomi...Jethro ha scritto:... OsX (il mio si chiama ancora così :wink: ) anche in Informazioni di Sistema/Resoconto, così come in Utility Disco, mi da "Stato S.M.A.R.T.: Verificato".
Model Family: SiliconMotion based SSDs
Device Model: CT240BX200SSD1
Serial Number: 1614F019C75B
LU WWN Device Id: 5 00a075 1f019c75b
Firmware Version: MU02.6
User Capacity: 240,057,409,536 bytes [240 GB]
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Wed Nov 2 17:43:33 2016 CET
was never started.
been run.
data collection: ( 0) seconds.
capabilities: (0x71) SMART execute Offline immediate.
No Auto Offline data collection support.
command.
No Offline surface scan supported.
SMART capabilities: (0x0002) Does not save SMART data before
entering power-saving mode.
recommended polling time: ( 1) minutes.
Conveyance self-test routine
SCT capabilities: (0x0035) SCT Status supported.
1 Raw_Read_Error_Rate 0x0000 100 100 000 Old_age Offline - 0
5 Reallocated_Sector_Ct 0x0000 100 100 000 Old_age Offline - 0
9 Power_On_Hours 0x0000 100 100 000 Old_age Offline - 8
12 Power_Cycle_Count 0x0000 100 100 000 Old_age Offline - 191
160 Uncorrectable_Error_Cnt 0x0000 100 100 000 Old_age Offline - 0
161 Valid_Spare_Block_Cnt 0x0000 100 100 000 Old_age Offline - 19
163 Initial_Bad_Block_Count 0x0000 100 100 000 Old_age Offline - 359
148 Total_SLC_Erase_Ct 0x0000 100 100 000 Old_age Offline - 5633
149 Max_SLC_Erase_Ct 0x0000 100 100 000 Old_age Offline - 160
150 Min_SLC_Erase_Ct 0x0000 100 100 000 Old_age Offline - 16
151 Average_SLC_Erase_Ct 0x0000 100 100 000 Old_age Offline - 77
164 Total_Erase_Count 0x0000 100 100 000 Old_age Offline - 664
165 Max_Erase_Count 0x0000 100 100 000 Old_age Offline - 28
166 Min_Erase_Count 0x0000 100 100 000 Old_age Offline - 0
167 Average_Erase_Count 0x0000 100 100 000 Old_age Offline - 0
169 Remaining_Lifetime_Perc 0x0000 100 100 001 Old_age Offline - 100
181 Program_Fail_Cnt_Total 0x0000 100 100 000 Old_age Offline - 0
182 Erase_Fail_Count_Total 0x0000 100 100 000 Old_age Offline - 0
192 Power-Off_Retract_Count 0x0000 100 100 000 Old_age Offline - 1
194 Temperature_Celsius 0x0000 100 100 070 Old_age Offline - 20 (30 27 28 28 0)
199 UDMA_CRC_Error_Count 0x0000 100 100 000 Old_age Offline - 0
232 Available_Reservd_Space 0x0000 100 100 000 Old_age Offline - 100
241 Host_Writes_32MiB 0x0000 100 100 000 Old_age Offline - 2332
242 Host_Reads_32MiB 0x0000 100 100 000 Old_age Offline - 7143
245 TLC_Writes_32MiB 0x0000 100 100 000 Old_age Offline - 3921
246 SLC_Writes_32MiB 0x0000 100 100 000 Old_age Offline - 11266
247 Raid_Recoverty_Ct 0x0000 100 100 000 Old_age Offline - 0
No Errors Logged
Warning! SMART Self-Test Log Structure error: invalid SMART checksum.
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
6 0 65535 Read_scanning was never started
