AEServer
/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/Support/AEServer
what is that?
Ohibò!Kundalini ha scritto: ↑mar, 22 feb 2022 18:48https://discussions.apple.com/thread/250774112
SPEGNILO SUBITO!
AppleEvents
New Features
To enhance security, AppleEvents and AppleScripts that target an app on a remote system must authenticate as the same user on the remote system. An AppleEvent that targets an app running as a different user receives a procNotFound error.To allow remote AppleEvents to target apps in any user session, run the following command in Terminal on the server:
defaults write /Library/Preferences/com.apple.AEServer RestrictAccessToUserSession -bool false
Then disable and reenable Remote Apple Events in System Preferences > Sharing. (5353592)
AppleEvents
Nuove caratteristiche
Per migliorare la sicurezza, AppleEvents e AppleScripts destinati a un'app su un sistema remoto devono autenticarsi come lo stesso utente sul sistema remoto. Un AppleEvent destinato a un'app in esecuzione come utente diverso riceve un errore procNotFound. Per consentire agli AppleEvent remoti di indirizzare le app in qualsiasi sessione utente,
eseguire il comando seguente in Terminale sul server:
valori predefiniti scrivi /Library/Preferences/com.apple.AEServer RestrictAccessToUserSession -bool false
Quindi disabilita e riattiva gli eventi Apple remoti in Preferenze di Sistema> Condivisione. (5353592)
