/Library/Managed Preferences:
it.murus.pf.helper
com.charlessoft.pacifist.helper
com.apple.serverd
com.paragon-software.installer
com.microsoft.autoupdate.helper
com.microsoft.office.licensingV2.helper
/Library/ScriptingAdditions:
Adobe Unit Types.osax
/Library/StartupItems:
/Library/Updates:
ProductMetadata.plist
PPDVersions.plist
index.plist
Top Processes:
%CPU PID COMMAND
29.3 1023 deleted
21.4 1004 Console
18.4 1019 diagnosticd
17.0 309 WindowServer
11.4 183 syspolicyd
6.9 249 trustd
5.3 0 kernel_task
5.3 1964 DetectX Swift
5.0 867 routined
3.6 148 opendirectoryd
Running Processes:
PPID PID %CPU USER COMMAND
0 1 0.0 root /sbin/launchd
1 112 0.0 root /usr/sbin/syslogd
1 113 0.0 root /usr/libexec/UserEventAgent (System)
1 116 0.0 root /System/Library/PrivateFrameworks/Uninstall.framework/Resources/uninstalld
1 117 0.0 root /usr/libexec/kextd
1 118 0.0 root /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/Support/fseventsd
1 119 0.0 root /System/Library/PrivateFrameworks/MediaRemote.framework/Support/mediaremoted
1 122 0.0 root /usr/sbin/systemstats --daemon
1 123 0.0 root /usr/libexec/configd
1 124 0.0 root endpointsecurityd
1 125 0.1 root /System/Library/CoreServices/powerd.bundle/powerd
1 126 0.0 root /Library/PrivilegedHelperTools/com.apple.serverd
1 130 0.2 root /usr/libexec/logd
1 131 0.0 root /usr/libexec/keybagd -t 15
1 133 0.0 root /usr/local/bin/pfloggerd
1 135 0.0 root /usr/libexec/watchdogd
1 139 1.8 root /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Support/mds
1 140 0.0 _iconservices /System/Library/CoreServices/iconservicesd
1 141 0.9 root /usr/libexec/diskarbitrationd
1 144 0.0 root /usr/libexec/coreduetd
1 145 3.0 root /Library/Objective-See/BlockBlock/BlockBlock.app/Contents/MacOS/BlockBlock daemon
1 148 9.1 root /usr/libexec/opendirectoryd
1 149 0.0 root /Library/PreferencePanes/TechTool Protection.prefPane/Contents/PlugIns/TechToolProDaemon.app/Contents/MacOS/TechToolProDaemon
1 150 0.0 root /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
1 151 0.0 root /System/Library/CoreServices/launchservicesd
1 152 0.0 _timed /usr/libexec/timed
1 153 0.0 root /Applications/OneDrive.app/Contents/StandaloneUpdaterDaemon.xpc/Contents/MacOS/StandaloneUpdaterDaemon
1 154 0.0 _usbmuxd /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/Resources/usbmuxd -launchd
1 155 0.0 root /usr/sbin/securityd -i
1 156 0.0 root auditd -l
1 158 0.0 _locationd /usr/libexec/locationd
1 161 0.0 root autofsd
1 162 0.0 _displaypolicyd /usr/libexec/displaypolicyd -k 1
1 163 0.0 root /usr/libexec/dasd
1 164 0.0 root /System/Library/PrivateFrameworks/Heimdal.framework/Helpers/kdc
1 168 0.0 root /System/Library/CoreServices/logind
1 169 0.0 root /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/Support/revisiond
1 170 0.0 root /usr/sbin/KernelEventAgent
1 173 0.0 root /usr/sbin/bluetoothd
1 175 1.7 _hidd /usr/libexec/hidd
1 176 0.0 root /usr/libexec/sandboxd
1 177 0.0 root /usr/libexec/corebrightnessd --launchd
1 178 0.0 root /usr/libexec/AirPlayXPCHelper
1 179 0.0 root /usr/sbin/notifyd
1 181 0.0 _distnote /usr/sbin/distnoted daemon
1 182 0.0 root /usr/sbin/cfprefsd daemon
1 183 11.9 root /usr/libexec/syspolicyd
1 184 0.0 root /usr/libexec/amfid
1 185 0.0 root /System/Library/CoreServices/coreservicesd
1 187 0.0 root /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/authd.xpc/Contents/MacOS/authd
1 188 0.0 root aslmanager
1 190 0.0 root /System/Library/PrivateFrameworks/TCC.framework/Resources/tccd system
1 191 0.0 matteobonelli /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow console
1 198 0.0 _analyticsd /System/Library/PrivateFrameworks/CoreAnalytics.framework/Support/analyticsd
1 228 0.0 root /System/Library/Frameworks/SystemExtensions.framework/Versions/A/Helpers/sysextd
1 230 0.0 root /System/Library/PrivateFrameworks/CoreDuetContext.framework/Resources/contextstored
1 246 0.0 root /usr/libexec/nehelper
1 249 3.6 root /usr/libexec/trustd
1 253 0.0 _coreaudiod /usr/sbin/coreaudiod
1 274 0.0 root /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd-helper -launchd
1 277 0.0 _coreaudiod /System/Library/Frameworks/CoreAudio.framework/Versions/A/XPCServices/com.apple.audio.DriverHelper.xpc/Contents/MacOS/com.apple.audio.DriverHelper
1 299 0.0 _networkd /usr/libexec/symptomsd
1 301 0.0 root /usr/libexec/mobileassetd
1 302 0.0 root /usr/sbin/ocspd
1 308 0.1 _mdnsresponder /usr/sbin/mDNSResponder
1 309 15.5 _windowserver /System/Library/PrivateFrameworks/SkyLight.framework/Resources/WindowServer -daemon
1 315 0.0 root /usr/sbin/mDNSResponderHelper
1 320 0.0 root /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Support/awdd
1 331 0.0 root /usr/libexec/lsd runAsRoot
1 337 0.0 _locationd /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod
1 338 0.0 _locationd /usr/libexec/secinitd
1 340 0.0 _nsurlsessiond /usr/libexec/nsurlsessiond --privileged
1 341 0.0 root /usr/libexec/multiversed
1 342 0.0 root /System/Library/CryptoTokenKit/com.apple.ifdreader.slotd/Contents/MacOS/com.apple.ifdreader
1 345 0.0 root /usr/libexec/apfsd
1 349 0.0 root /usr/libexec/usbd
1 351 0.0 _cmiodalassistants /System/Library/Frameworks/CoreMediaIO.framework/Resources/VDC.plugin/Contents/Resources/VDCAssistant
1 359 0.0 _assetcache /usr/libexec/AssetCache/AssetCache
1 360 0.0 root /System/Library/PrivateFrameworks/Heimdal.framework/Helpers/kadmind
1 362 0.0 _softwareupdate /System/Library/PrivateFrameworks/BridgeOSSoftwareUpdate.framework/Support/bosUpdateProxy
1 365 0.0 root /System/Library/CoreServices/SubmitDiagInfo server-init
1 368 0.0 root /System/Library/PrivateFrameworks/XprotectFramework.framework/Versions/A/XPCServices/XprotectService.xpc/Contents/MacOS/XprotectService
1 369 0.0 root /usr/sbin/cupsd -l
1 370 0.0 _locationd /usr/sbin/cfprefsd agent
1 374 0.0 root /usr/libexec/slapd -d 0 -h ldap:/// ldapi://%2Fvar%2Frun%2Fldapi
1 375 0.0 root /usr/libexec/ApplicationFirewall/socketfilterfw
1 379 0.0 root /System/Library/PrivateFrameworks/Heimdal.framework/Helpers/kpasswdd
1 380 0.0 _locationd /usr/libexec/trustd --agent
1 383 0.0 root /sbin/emond
1 387 0.0 root /usr/libexec/smd
1 392 0.0 root /Applications/Server.app/Contents/ServerRoot/usr/libexec/ServerEventAgent
1 393 0.0 _devicemgr /Applications/Server.app/Contents/ServerRoot/usr/bin/postgres -D /Library/Server/ProfileManager/Config/ServiceData/Data/PostgreSQL -c unix_socket_directories=/Library/Server/ProfileManager/Config/var/PostgreSQL -c archive_mode=on -c archive_command=/Applications/Server.app/Contents/ServerRoot/usr/share/devicemgr/config/postgres/wal_archive_tool.sh %p %f -c max_wal_senders=2 -c wal_level=hot_standby
1 395 0.0 root /Applications/Server.app/Contents/ServerRoot/System/Library/PrivateFrameworks/ServerEventsDaemon.framework/eventsd
1 396 0.0 _devicemgr /Applications/Server.app/Contents/ServerRoot/usr/share/devicemgr/dmhttpd
1 398 0.0 root /Applications/Server.app/Contents/ServerRoot/usr/libexec/servermetricsd -daemonize YES
1 399 0.0 root /Applications/Server.app/Contents/ServerRoot/System/Library/PrivateFrameworks/ApplePushServiceProvider.framework/apspd
1 400 0.0 root /usr/sbin/httpd -D FOREGROUND -f /Library/Server/Web/Config/Proxy/apache_serviceproxy.conf -E /private/var/log/apache2/service_proxy_error.log
1 401 0.0 _devicemgr /Applications/Server.app/Contents/ServerRoot/usr/share/devicemgr/dmrunnerd
1 402 0.0 root /usr/sbin/filecoordinationd
1 407 0.0 root /usr/libexec/airportd
1 409 0.0 _devicemgr /Applications/Server.app/Contents/ServerRoot/usr/share/devicemgr/devicemgrd
393 410 0.0 _devicemgr postgres: logger process
393 412 0.0 _devicemgr postgres: checkpointer process
393 413 0.0 _devicemgr postgres: writer process
393 414 0.0 _devicemgr postgres: wal writer process
393 415 0.0 _devicemgr postgres: autovacuum launcher process
393 416 0.0 _devicemgr postgres: archiver process
393 417 0.0 _devicemgr postgres: stats collector process
1 430 0.0 root /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/com.apple.CodeSigningHelper.xpc/Contents/MacOS/com.apple.CodeSigningHelper
1 433 0.0 root /System/Library/PrivateFrameworks/CoreSymbolication.framework/coresymbolicationd
1 436 0.0 root /System/Library/PrivateFrameworks/AssetCacheServicesExtensions.framework/XPCServices/AssetCacheManagerService.xpc/Contents/MacOS/AssetCacheManagerService
1 439 0.0 root /usr/libexec/runningboardd
393 442 0.0 _devicemgr postgres: devicemgrd devicemgr_v2m0 [local] idle
393 443 0.0 _devicemgr postgres: devicemgrd devicemgr_v2m0 [local] idle
393 444 0.0 _devicemgr postgres: devicemgrd devicemgr_v2m0 [local] idle
1 445 0.0 _devicemgr /Applications/Server.app/Contents/ServerRoot/System/Library/PrivateFrameworks/DeviceManagerModels.framework/Versions/Current/XPCServices/dmpgHelper.xpc/Contents/MacOS/dmpgHelper
1 446 0.0 _devicemgr /Applications/Server.app/Contents/ServerRoot/System/Library/PrivateFrameworks/DeviceManagerModels.framework/Versions/Current/XPCServices/dmAuthService.xpc/Contents/MacOS/dmAuthService
1 449 0.0 root /usr/libexec/diskmanagementd
1 450 0.0 _devicemgr /Applications/Server.app/Contents/ServerRoot/System/Library/PrivateFrameworks/DeviceManagerModels.framework/Versions/Current/XPCServices/dmDeviceService.xpc/Contents/MacOS/dmDeviceService
1 455 0.0 root /Applications/Server.app/Contents/ServerRoot/System/Library/CoreServices/ServerManagerDaemon.bundle/Contents/MacOS/servermgr-notify
1 456 0.0 _devicemgr /Applications/Server.app/Contents/ServerRoot/System/Library/PrivateFrameworks/DeviceManagerModels.framework/Versions/Current/XPCServices/dmSCEPService.xpc/Contents/MacOS/dmSCEPService
393 462 0.0 _devicemgr postgres: devicemgrd devicemgr_v2m0 [local] idle
1 473 3.3 root com.google.santa.daemon
393 483 0.0 _devicemgr postgres: _devicemgr devicemgr_v2m0 [local] idle
1 497 0.0 root /usr/libexec/searchpartyd
1 502 0.0 root /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/XPCServices/ViewBridgeAuxiliary.xpc/Contents/MacOS/ViewBridgeAuxiliary
1 516 0.0 root /usr/sbin/PasswordService -n
400 520 0.0 _www /usr/sbin/httpd -D FOREGROUND -f /Library/Server/Web/Config/Proxy/apache_serviceproxy.conf -E /private/var/log/apache2/service_proxy_error.log
1 550 0.0 root /System/Library/CoreServices/ReportCrash daemon
1 564 0.0 _driverkit /System/Library/DriverExtensions/AppleUserHIDDrivers.dext/AppleUserHIDDrivers com.apple.driverkit.AppleUserUSBHostHIDDevice0 0x1000008a2
1 569 0.0 root /usr/libexec/sysmond
122 574 0.0 root /usr/sbin/systemstats --logger-helper /private/var/db/systemstats
1 575 0.0 root /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/XPCServices/com.apple.cmio.registerassistantservice.xpc/Contents/MacOS/com.apple.cmio.registerassistantservice
1 580 0.0 _driverkit /System/Library/DriverExtensions/AppleUserHIDDrivers.dext/AppleUserHIDDrivers com.apple.driverkit.AppleUserUSBHostHIDDevice0 0x1000008a4
1 581 0.0 _driverkit /System/Library/DriverExtensions/AppleUserHIDDrivers.dext/AppleUserHIDDrivers com.apple.driverkit.AppleUserUSBHostHIDDevice0 0x1000008a6
1 582 0.0 _driverkit /System/Library/DriverExtensions/AppleUserHIDDrivers.dext/AppleUserHIDDrivers com.apple.driverkit.AppleUserUSBHostHIDDevice0 0x1000008a8
1 583 0.0 _driverkit /System/Library/DriverExtensions/AppleUserHIDDrivers.dext/AppleUserHIDDrivers com.apple.driverkit.AppleUserUSBHostHIDDevice0 0x1000008aa
1 584 0.0 _driverkit /System/Library/DriverExtensions/AppleUserHIDDrivers.dext/AppleUserHIDDrivers com.apple.driverkit.AppleUserUSBHostHIDDevice0 0x1000008ac
1 585 0.0 _driverkit /System/Library/DriverExtensions/AppleUserHIDDrivers.dext/AppleUserHIDDrivers com.apple.driverkit.AppleUserUSBHostHIDDevice0 0x1000008ae
1 586 0.0 _driverkit /System/Library/DriverExtensions/AppleUserHIDDrivers.dext/AppleUserHIDDrivers com.apple.driverkit.AppleUserUSBHostHIDDevice0 0x1000008b0
125 587 0.0 root /usr/libexec/ioupsd
1 588 0.0 root /System/Library/Frameworks/AudioToolbox.framework/AudioComponentRegistrar -daemon
1 589 0.0 _coreaudiod /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
1 590 0.0 _driverkit /System/Library/DriverExtensions/AppleUserHIDDrivers.dext/AppleUserHIDDrivers com.apple.driverkit.AppleUserHIDEventDriver 0x100000944
1 592 0.0 root /usr/libexec/thermald
1 598 0.8 root /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mds_stores
1 600 0.0 root /usr/libexec/secinitd
401 601 0.0 _devicemgr /Applications/Server.app/Contents/ServerRoot/usr/bin/ruby /Applications/Server.app/Contents/ServerRoot/usr/share/devicemgr/backend/thin --chdir /Applications/Server.app/Contents/ServerRoot/usr/share/devicemgr/backend --rackup config.ru --address localhost --port 3320 --log /Library/Logs/ProfileManager/thin-3320.log start
1 605 0.0 _atsserver /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support/fontd
1 606 0.0 root /usr/libexec/colorsync.displayservices
1 607 0.0 root /usr/libexec/colorsyncd
1 610 0.0 root /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
1 611 0.0 root /usr/sbin/distnoted agent
1 613 0.0 _appleevents /System/Library/CoreServices/appleeventsd --server
1 615 0.0 root /usr/libexec/bootinstalld
1 617 0.0 root /usr/bin/perl -T /usr/libexec/emlog.pl -l
1 622 0.0 root /System/Library/CoreServices/iconservicesagent runAsRoot
1 628 0.0 root /System/Library/CoreServices/sharedfilelistd
1 629 0.0 root /System/Library/CoreServices/CrashReporterSupportHelper server-init
401 630 0.0 _devicemgr /Applications/Server.app/Contents/ServerRoot/usr/bin/ruby /Applications/Server.app/Contents/ServerRoot/usr/share/devicemgr/backend/thin --chdir /Applications/Server.app/Contents/ServerRoot/usr/share/devicemgr/backend --rackup config.ru --address localhost --port 3321 --log /Library/Logs/ProfileManager/thin-3321.log start
617 633 0.0 root /usr/libexec/xssendevent
1 642 0.0 root /System/Library/PrivateFrameworks/AccountPolicy.framework/XPCServices/com.apple.AccountPolicyHelper.xpc/Contents/MacOS/com.apple.AccountPolicyHelper
401 648 0.0 _devicemgr /Applications/Server.app/Contents/ServerRoot/usr/bin/ruby /Applications/Server.app/Contents/ServerRoot/usr/share/devicemgr/backend/thin --chdir /Applications/Server.app/Contents/ServerRoot/usr/share/devicemgr/backend --rackup config.ru --address localhost --port 3322 --log /Library/Logs/ProfileManager/thin-3322.log start
1 649 0.0 root /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd
1 650 0.0 root /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp -d
1 653 0.0 _ctkd /System/Library/Frameworks/CryptoTokenKit.framework/ctkd -s
1 658 0.0 root /usr/sbin/systemsoundserverd
401 670 0.0 _devicemgr /Applications/Server.app/Contents/ServerRoot/usr/bin/ruby /Applications/Server.app/Contents/ServerRoot/usr/share/devicemgr/backend/thin --chdir /Applications/Server.app/Contents/ServerRoot/usr/share/devicemgr/backend --rackup config.ru --address localhost --port 3323 --log /Library/Logs/ProfileManager/thin-3323.log start
401 680 0.0 _devicemgr /Applications/Server.app/Contents/ServerRoot/usr/bin/ruby /Applications/Server.app/Contents/ServerRoot/usr/share/devicemgr/backend/thin --chdir /Applications/Server.app/Contents/ServerRoot/usr/share/devicemgr/backend --rackup config.ru --address localhost --port 3324 --log /Library/Logs/ProfileManager/thin-3324.log start
1 685 0.0 _netbios /usr/sbin/netbiosd
401 693 0.0 _devicemgr /Applications/Server.app/Contents/ServerRoot/usr/bin/ruby /Applications/Server.app/Contents/ServerRoot/usr/share/devicemgr/backend/thin --chdir /Applications/Server.app/Contents/ServerRoot/usr/share/devicemgr/backend --rackup config.ru --address localhost --port 3325 --log /Library/Logs/ProfileManager/thin-3325.log start
1 695 0.0 _captiveagent /usr/libexec/captiveagent
1 696 0.0 root /System/Library/PrivateFrameworks/AmbientDisplay.framework/Versions/A/XPCServices/com.apple.AmbientDisplayAgent.xpc/Contents/MacOS/com.apple.AmbientDisplayAgent
1 719 0.0 root /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/XPCServices/com.apple.PerformanceAnalysis.animationperfd.xpc/Contents/MacOS/com.apple.PerformanceAnalysis.animationperfd
401 720 0.0 _devicemgr /Applications/Server.app/Contents/ServerRoot/usr/bin/ruby /Applications/Server.app/Contents/ServerRoot/usr/share/devicemgr/backend/thin --chdir /Applications/Server.app/Contents/ServerRoot/usr/share/devicemgr/backend --rackup config.ru --address localhost --port 3326 --log /Library/Logs/ProfileManager/thin-3326.log start
1 727 0.0 _locationd /usr/sbin/distnoted agent
1 731 0.0 _nsurlstoraged /usr/libexec/nsurlstoraged --privileged
401 744 0.0 _devicemgr /Applications/Server.app/Contents/ServerRoot/usr/bin/ruby /Applications/Server.app/Contents/ServerRoot/usr/share/devicemgr/backend/thin --chdir /Applications/Server.app/Contents/ServerRoot/usr/share/devicemgr/backend --rackup config.ru --address localhost --port 3327 --log /Library/Logs/ProfileManager/thin-3327.log start
401 770 0.0 _devicemgr /Applications/Server.app/Contents/ServerRoot/usr/bin/ruby /Applications/Server.app/Contents/ServerRoot/usr/share/devicemgr/backend/thin --chdir /Applications/Server.app/Contents/ServerRoot/usr/share/devicemgr/backend --rackup config.ru --address localhost --port 3328 --log /Library/Logs/ProfileManager/thin-3328.log start
401 795 0.0 _devicemgr /Applications/Server.app/Contents/ServerRoot/usr/bin/ruby /Applications/Server.app/Contents/ServerRoot/usr/share/devicemgr/backend/thin --chdir /Applications/Server.app/Contents/ServerRoot/usr/share/devicemgr/backend --rackup config.ru --address localhost --port 3329 --log /Library/Logs/ProfileManager/thin-3329.log start
1 814 0.0 root /System/Library/PrivateFrameworks/AssetCacheServicesExtensions.framework/XPCServices/AssetCacheTetheratorService.xpc/Contents/MacOS/AssetCacheTetheratorService
1 820 0.0 root /System/Library/Frameworks/GSS.framework/Helpers/GSSCred
1 823 0.0 matteobonelli /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd
1 824 1.0 matteobonelli /usr/sbin/cfprefsd agent
1 825 0.0 root /usr/libexec/securityd_service
1 826 0.0 root /usr/libexec/PerfPowerServices
1 827 0.0 matteobonelli /usr/libexec/UserEventAgent (Aqua)
1 829 0.0 matteobonelli /usr/sbin/distnoted agent
1 830 0.0 matteobonelli /usr/sbin/universalaccessd launchd -s
1 831 0.0 matteobonelli /System/Library/PrivateFrameworks/CloudServices.framework/Helpers/com.apple.sbd
1 832 0.0 matteobonelli /usr/libexec/knowledge-agent
1 833 0.0 matteobonelli /usr/libexec/lsd
1 834 0.0 matteobonelli /usr/libexec/trustd --agent
1 835 0.0 matteobonelli /usr/libexec/secd
1 836 0.0 matteobonelli /usr/libexec/rapportd
1 837 3.1 matteobonelli /System/Library/PrivateFrameworks/UniversalAccess.framework/Versions/A/Resources/AXVisualSupportAgent.app/Contents/MacOS/AXVisualSupportAgent launchd -s
1 838 0.0 matteobonelli /System/Library/PrivateFrameworks/IDS.framework/identityservicesd.app/Contents/MacOS/identityservicesd
1 839 0.0 matteobonelli /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Support/cloudd
1 840 0.0 matteobonelli /System/Library/PrivateFrameworks/HomeKitDaemon.framework/Support/homed
1 841 0.0 matteobonelli /System/Library/CoreServices/backgroundtaskmanagementagent
1 842 0.0 matteobonelli /usr/libexec/pboard
1 843 0.0 matteobonelli /System/Library/PrivateFrameworks/TCC.framework/Resources/tccd
1 844 0.0 matteobonelli /usr/libexec/nsurlsessiond
1 845 0.0 matteobonelli /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
1 846 0.0 matteobonelli /System/Library/CoreServices/talagent
1 847 0.0 matteobonelli /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
1 848 0.8 matteobonelli /System/Library/CoreServices/SystemUIServer.app/Contents/MacOS/SystemUIServer
1 849 0.0 matteobonelli /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
1 850 0.0 matteobonelli /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/XPCServices/ViewBridgeAuxiliary.xpc/Contents/MacOS/ViewBridgeAuxiliary
1 853 0.0 matteobonelli /System/Library/CoreServices/sharedfilelistd
1 854 0.0 matteobonelli /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support/fontd
1 856 0.0 matteobonelli /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/Versions/A/Support/bird
1 857 0.0 matteobonelli /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/XPCServices/QuickLookUIService.xpc/Contents/MacOS/QuickLookUIService
1 858 0.6 matteobonelli /usr/libexec/pkd
1 859 0.0 matteobonelli /usr/libexec/secinitd
1 860 0.0 matteobonelli /System/Library/Frameworks/Security.framework/Versions/A/Resources/CloudKeychainProxy.bundle/Contents/MacOS/CloudKeychainProxy
1 862 0.0 matteobonelli /usr/libexec/dmd
1 863 0.0 matteobonelli /System/Library/Frameworks/CryptoTokenKit.framework/ctkd -tw
1 866 0.0 matteobonelli /System/Library/PrivateFrameworks/AMPDevices.framework/Versions/A/Support/AMPDeviceDiscoveryAgent --launchd
1 867 4.6 matteobonelli /usr/libexec/routined LAUNCHED_BY_LAUNCHD
1 868 0.0 matteobonelli /usr/sbin/usernoted
1 869 0.0 matteobonelli /System/Library/CoreServices/lockoutagent
1 870 0.0 matteobonelli /usr/libexec/networkserviceproxy
1 871 0.0 matteobonelli /System/Library/Frameworks/CoreTelephony.framework/Support/CommCenter -L
1 872 0.0 matteobonelli /System/Library/CoreServices/APFSUserAgent
1 873 0.0 matteobonelli /System/Library/PrivateFrameworks/ScreenTimeCore.framework/Versions/A/ScreenTimeAgent
1 875 0.0 matteobonelli /System/Library/PrivateFrameworks/CoreParsec.framework/parsecd
1 876 0.0 matteobonelli /System/Library/PrivateFrameworks/ExchangeSync.framework/Versions/Current/exchangesyncd
1 877 0.0 matteobonelli /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
1 878 0.0 matteobonelli /System/Library/CoreServices/NotificationCenter.app/Contents/MacOS/NotificationCenter
1 879 0.0 matteobonelli /System/Library/CoreServices/AirPort Base Station Agent.app/Contents/MacOS/AirPort Base Station Agent --launchd
1 880 0.0 matteobonelli /usr/libexec/nsurlstoraged
1 882 0.0 matteobonelli /System/Library/CoreServices/mapspushd
1 885 0.0 matteobonelli /System/Library/CoreServices/iconservicesagent
1 887 0.0 matteobonelli /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/TrustedPeersHelper.xpc/Contents/MacOS/TrustedPeersHelper
1 888 0.0 matteobonelli /System/Library/PrivateFrameworks/CoreDuetContext.framework/Resources/ContextStoreAgent
1 889 0.0 matteobonelli /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd
1 890 0.0 matteobonelli /System/Library/CoreServices/WiFiAgent.app/Contents/MacOS/WiFiAgent
1 891 0.0 matteobonelli /System/Library/CoreServices/RemoteManagement/ARDAgent.app/Contents/MacOS/ARDAgent
1 893 0.0 matteobonelli /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/Support/assistantd
1 894 0.0 matteobonelli /usr/libexec/adprivacyd
1 895 0.0 matteobonelli /System/Library/CoreServices/RemoteManagement/SSMenuAgent.app/Contents/MacOS/SSMenuAgent
1 896 0.0 root /usr/sbin/WirelessRadioManagerd
1 897 0.0 matteobonelli /System/Library/PrivateFrameworks/TelephonyUtilities.framework/callservicesd
1 898 0.0 matteobonelli /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent
1 899 0.0 matteobonelli /System/Library/CoreServices/CoreServicesUIAgent.app/Contents/MacOS/CoreServicesUIAgent
1 900 0.0 matteobonelli /System/Library/PrivateFrameworks/IMDPersistence.framework/XPCServices/IMDPersistenceAgent.xpc/Contents/MacOS/IMDPersistenceAgent
1 901 0.0 matteobonelli /System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd
1 906 0.0 matteobonelli /System/Library/CoreServices/SocialPushAgent.app/Contents/MacOS/SocialPushAgent
1 909 0.0 matteobonelli /Library/PreferencePanes/TechTool Protection.prefPane/Contents/PlugIns/TechToolProAgent.app/Contents/MacOS/TechToolProAgent
1 910 0.0 matteobonelli /System/Library/Frameworks/InputMethodKit.framework/Resources/imklaunchagent
1 911 0.0 matteobonelli /System/Library/Image Capture/Support/icdd
1 912 0.0 matteobonelli /Library/Objective-See/BlockBlock/BlockBlock.app/Contents/MacOS/BlockBlock agent
1 914 0.0 matteobonelli /Applications/Santa.app/Contents/MacOS/Santa --syslog
1 915 0.0 matteobonelli /System/Library/PrivateFrameworks/AskPermission.framework/Versions/A/Resources/askpermissiond
1 917 0.0 matteobonelli /usr/libexec/sharingd
1 918 0.0 matteobonelli /System/Library/CoreServices/AirPlayUIAgent.app/Contents/MacOS/AirPlayUIAgent --launchd
1 919 0.0 matteobonelli /System/Library/CoreServices/cloudpaird
1 920 0.0 matteobonelli /System/Library/CoreServices/diagnostics_agent
1 921 0.0 matteobonelli /System/Library/CoreServices/TextInputMenuAgent.app/Contents/MacOS/TextInputMenuAgent
1 922 0.0 matteobonelli /usr/libexec/remindd
1 923 0.0 matteobonelli /System/Library/PrivateFrameworks/AppleMediaServices.framework/Resources/amsaccountsd
1 925 0.0 matteobonelli /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp
1 926 0.0 matteobonelli /System/Library/CoreServices/Spotlight.app/Contents/MacOS/Spotlight
1 927 0.0 matteobonelli /Applications/HyperDock.app/Contents/MacOS/HyperDock
1 928 0.0 matteobonelli /Applications/Utilities/Adobe Sync/CoreSync/Core Sync.app/Contents/PlugIns/ACCFinderSync.appex/Contents/MacOS/ACCFinderSync
1 929 0.0 matteobonelli /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeaccountd
1 930 0.0 matteobonelli /Applications/Dropbox/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon
1 931 0.0 matteobonelli /Applications/OneDrive.app/Contents/PlugIns/FinderSync.appex/Contents/MacOS/FinderSync
1 932 0.0 matteobonelli /Applications/GraphicConverter 10.app/Contents/PlugIns/FinderSyncHelper.appex/Contents/MacOS/FinderSyncHelper
1 933 0.0 matteobonelli /System/Library/PrivateFrameworks/UserActivity.framework/Agents/useractivityd
1 934 0.0 matteobonelli /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Contents/MacOS/com.apple.dock.extra
1 935 0.0 matteobonelli /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.external.extra.xpc/Contents/MacOS/com.apple.dock.external.extra
1 937 0.0 matteobonelli /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/commerce
1 938 0.0 matteobonelli /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod
1 939 0.0 matteobonelli /System/Library/CoreServices/TextInputSwitcher.app/Contents/MacOS/TextInputSwitcher
1 940 0.0 matteobonelli /System/Library/Input Methods/PressAndHold.app/Contents/PlugIns/PAH_Extension.appex/Contents/MacOS/PAH_Extension
1 941 0.0 matteobonelli /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistoryPluginHelper
1 942 0.6 matteobonelli /Applications/HyperDock.app/Contents/Library/LoginItems/HyperDock Helper.app/Contents/MacOS/HyperDock Helper -psn_0_192559
1 943 0.0 matteobonelli /System/Library/CoreServices/pbs
1 945 0.0 matteobonelli /System/Library/CoreServices/NotificationCenter.app/Contents/XPCServices/com.apple.notificationcenterui.WeatherSummary.xpc/Contents/MacOS/com.apple.notificationcenterui.WeatherSummary
1 946 0.0 matteobonelli /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc/Contents/MacOS/com.apple.hiservices-xpcservice
1 947 0.0 root /usr/libexec/findmydeviced
1 948 0.0 matteobonelli /System/Library/Frameworks/AddressBook.framework/Executables/ContactsAccountsService
1 949 0.0 root /usr/sbin/spindump
1 950 0.0 matteobonelli /usr/libexec/WiFiVelocityAgent
1 951 0.0 matteobonelli /System/Library/PrivateFrameworks/WeatherKit.framework/Versions/A/XPCServices/com.apple.WeatherKitService.xpc/Contents/MacOS/com.apple.WeatherKitService
1 952 0.0 root /usr/libexec/wifivelocityd
1 953 0.0 matteobonelli /usr/libexec/spindump_agent
1 954 0.0 matteobonelli /System/Library/CoreServices/LocationMenu.app/Contents/MacOS/LocationMenu
1 962 0.0 matteobonelli /System/Library/PrivateFrameworks/AppSSO.framework/Support/AppSSOAgent.app/Contents/MacOS/AppSSOAgent
1 965 0.0 matteobonelli /System/Library/PrivateFrameworks/login.framework/Versions/A/XPCServices/LoginUserService.xpc/Contents/MacOS/LoginUserService
1 979 0.0 _fpsd /System/Library/PrivateFrameworks/CoreADI.framework/adid
1 981 0.0 matteobonelli SafeEjectGPUAgent
1 982 0.0 matteobonelli /System/Library/CoreServices/Menu Extras/SafeEjectGPUExtra.menu/Contents/XPCServices/SafeEjectGPUService.xpc/Contents/MacOS/SafeEjectGPUService
1 985 0.0 matteobonelli /Applications/Murus/Murus.app/Contents/MacOS/Murus -psn_0_237626
1 988 0.0 root /Library/PrivilegedHelperTools/it.murus.pf.helper
1 989 0.0 matteobonelli /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
1 990 0.0 matteobonelli /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
1 991 0.0 matteobonelli /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
1 992 0.0 matteobonelli /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/Resources/familycircled
1 993 0.0 matteobonelli /System/Library/PrivateFrameworks/MediaRemote.framework/Support/mediaremoteagent
1 994 0.0 matteobonelli /usr/libexec/neagent
1 996 0.0 matteobonelli /usr/libexec/loginitemregisterd
1 997 0.0 matteobonelli /System/Library/PrivateFrameworks/CoreFollowUp.framework/Versions/A/Support/followupd
1 998 0.0 matteobonelli /usr/libexec/swcd
1 999 0.0 matteobonelli /usr/libexec/fmfd
1 1000 0.0 matteobonelli /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
1 1004 13.6 matteobonelli /System/Applications/Utilities/Console.app/Contents/MacOS/Console
1 1005 0.0 _datadetectors /usr/libexec/DataDetectorsSourceAccess
1 1006 0.0 matteobonelli /System/Library/PrivateFrameworks/FileProvider.framework/Support/fileproviderd
1 1007 0.0 matteobonelli /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/XPCServices/ContainerMetadataExtractor.xpc/Contents/MacOS/ContainerMetadataExtractor
1 1008 0.0 matteobonelli /Library/Developer/PrivateFrameworks/CoreSimulator.framework/Versions/A/XPCServices/com.apple.CoreSimulator.CoreSimulatorService.xpc/Contents/MacOS/com.apple.CoreSimulator.CoreSimulatorService
1 1009 0.0 matteobonelli /Library/Developer/PrivateFrameworks/CoreSimulator.framework/Versions/A/XPCServices/SimulatorTrampoline.xpc/Contents/MacOS/SimulatorTrampoline
1 1011 0.0 matteobonelli /System/Library/CoreServices/CoreLocationAgent.app/Contents/MacOS/CoreLocationAgent
1 1012 0.0 matteobonelli /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/corespotlightd
1 1014 0.0 matteobonelli /System/Library/PrivateFrameworks/CoreSuggestions.framework/Versions/A/Support/suggestd
1 1016 0.0 matteobonelli /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/XPCServices/com.apple.iCloudHelper.xpc/Contents/MacOS/com.apple.iCloudHelper
1 1017 0.0 matteobonelli /usr/libexec/SidecarRelay
1 1019 13.7 root /usr/libexec/diagnosticd
1 1020 0.0 matteobonelli /System/Library/PrivateFrameworks/CoreCDP.framework/Versions/A/Resources/cdpd
1 1022 0.0 matteobonelli /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/XPCServices/AssetCacheLocatorService.xpc/Contents/MacOS/AssetCacheLocatorService -a
1 1023 30.4 matteobonelli /System/Library/PrivateFrameworks/CacheDelete.framework/deleted
1 1026 0.0 matteobonelli /System/Library/PrivateFrameworks/CommunicationsFilter.framework/CMFSyncAgent
1 1027 0.0 matteobonelli /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/XPCServices/com.apple.siri.ClientFlow.ClientScripter.xpc/Contents/MacOS/com.apple.siri.ClientFlow.ClientScripter
1 1028 0.0 matteobonelli /System/Library/PrivateFrameworks/DistributedEvaluation.framework/Versions/A/XPCServices/com.apple.siri-distributed-evaluation.xpc/Contents/MacOS/com.apple.siri-distributed-evaluation
1 1029 0.0 matteobonelli /System/Library/CoreServices/ReportCrash agent
1 1030 0.0 matteobonelli /System/Library/PrivateFrameworks/SoftwareUpdate.framework/Resources/SoftwareUpdateNotificationManager.app/Contents/MacOS/SoftwareUpdateNotificationManager
1 1031 0.0 _softwareupdate /System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdated
1 1032 0.0 root /System/Library/CoreServices/Software Update.app/Contents/Resources/suhelperd
1 1064 0.0 matteobonelli /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Support/fontworker
1 1069 0.0 matteobonelli /System/Library/PrivateFrameworks/AMPLibrary.framework/Versions/A/Support/AMPLibraryAgent --launchd
1 1074 0.0 matteobonelli /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
1 1092 0.0 _applepay /usr/libexec/nfcd
1 1093 0.0 matteobonelli /Library/Apple/System/Library/CoreServices/SafariSupport.bundle/Contents/MacOS/SafariBookmarksSyncAgent
1 1097 0.0 matteobonelli /Library/Apple/System/Library/CoreServices/SafariSupport.bundle/Contents/MacOS/SafariCloudHistoryPushAgent
1 1103 0.0 matteobonelli /usr/libexec/findmydevice-user-agent
1 1104 0.0 root /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd
1 1120 0.0 _fpsd /System/Library/PrivateFrameworks/CoreFP.framework/Versions/A/fpsd
1 1125 0.0 matteobonelli /System/Library/PrivateFrameworks/PassKitCore.framework/passd
1 1154 0.0 root /System/Library/PrivateFrameworks/StorageKit.framework/Resources/storagekitd
1 1155 0.0 root /System/Library/PrivateFrameworks/CacheDelete.framework/deleted_helper
1 1156 0.0 _spotlight /usr/libexec/trustd --agent
1 1159 0.0 matteobonelli /System/Library/Frameworks/QuickLookThumbnailing.framework/Support/com.apple.quicklook.ThumbnailsAgent
1 1160 0.0 matteobonelli /System/Library/Frameworks/QuickLook.framework/Versions/A/XPCServices/ExternalQuickLookSatellite.xpc/Contents/MacOS/ExternalQuickLookSatellite
1 1161 0.0 root /usr/libexec/rtcreportingd
1 1164 0.0 matteobonelli /usr/libexec/replayd
1 1166 0.0 matteobonelli /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storedownloadd
1 1167 0.0 root /System/Library/PrivateFrameworks/PackageKit.framework/Resources/installd
1 1168 0.0 root /System/Library/PrivateFrameworks/PackageKit.framework/Resources/system_installd
1 1177 0.0 matteobonelli /System/Library/Frameworks/AudioToolbox.framework/AudioComponentRegistrar
1 1180 0.0 matteobonelli /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
1 1181 0.0 matteobonelli /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/XPCServices/com.apple.siri.embeddedspeech.xpc/Contents/MacOS/com.apple.siri.embeddedspeech
1 1185 0.0 matteobonelli /usr/libexec/siriknowledged
1 1187 0.0 matteobonelli /System/Library/PrivateFrameworks/DeviceCheckInternal.framework/devicecheckd
1 1196 0.0 matteobonelli /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/Support/assistant_service
1 1200 0.0 matteobonelli /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdwrite
1 1234 0.0 matteobonelli /System/Library/PrivateFrameworks/FMClient.framework/Versions/A/XPCServices/FMIPClientXPCService.xpc/Contents/MacOS/FMIPClientXPCService
1 1248 0.0 matteobonelli /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/com.apple.appkit.xpc.openAndSavePanelService.xpc/Contents/MacOS/com.apple.appkit.xpc.openAndSavePanelService
1 1249 0.0 matteobonelli /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/XPCServices/QuickLookUIService.xpc/Contents/MacOS/QuickLookUIService
1 1260 0.0 root /usr/libexec/mobileactivationd
1 1264 0.0 root /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod
1 1265 0.0 root /usr/libexec/secinitd
1 1269 0.0 matteobonelli /System/Library/PrivateFrameworks/ContextKit.framework/Versions/A/XPCServices/ContextService.xpc/Contents/MacOS/ContextService
1 1337 0.0 root /usr/libexec/tailspind
400 1390 0.0 _www /usr/sbin/httpd -D FOREGROUND -f /Library/Server/Web/Config/Proxy/apache_serviceproxy.conf -E /private/var/log/apache2/service_proxy_error.log
1 1394 0.0 root /System/Library/PrivateFrameworks/InstallerDiagnostics.framework/Versions/A/Resources/installerdiagd
1 1401 0.0 root /usr/libexec/tzd
1 1402 0.0 _fpsd /System/Library/PrivateFrameworks/CoreLSKD.framework/Versions/A/lskdd
1 1404 0.0 _assetcache /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/XPCServices/AssetCacheLocatorService.xpc/Contents/MacOS/AssetCacheLocatorService -d
1 1410 0.0 root /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd
1 1518 0.0 matteobonelli /System/Library/PrivateFrameworks/KerberosHelper/Helpers/DiskUnmountWatcher
1 1649 0.0 matteobonelli /Applications/Google Chrome.app/Contents/MacOS/Google Chrome
1 1654 0.0 _gamecontrollerd /usr/libexec/gamecontrollerd
1 1656 0.0 matteobonelli /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/81.0.4044.129/Helpers/chrome_crashpad_handler --monitor-self-annotation=ptype=crashpad-handler --database=/Users/matteobonelli/Library/Application Support/Google/Chrome/Crashpad --metrics-dir=/Users/matteobonelli/Library/Application Support/Google/Chrome --url=
https://clients2.google.com/cr/report --annotation=channel= --annotation=plat=OS X --annotation=prod=Chrome_Mac --annotation=ver=81.0.4044.129 --handshake-fd=7
1649 1661 2.1 matteobonelli /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/81.0.4044.129/Helpers/Google Chrome Helper (GPU).app/Contents/MacOS/Google Chrome Helper (GPU) --type=gpu-process --field-trial-handle=1718379636,12981871602970630566,18337982942199887150,131072 --metrics-client-id=16d905c5-31ee-4a45-b576-9c5f3d7795fd --gpu-preferences=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 --shared-files
1649 1663 0.0 matteobonelli /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/81.0.4044.129/Helpers/Google Chrome Helper.app/Contents/MacOS/Google Chrome Helper --type=utility --field-trial-handle=1718379636,12981871602970630566,18337982942199887150,131072 --lang=it --service-sandbox-type=network --enable-audio-service-sandbox --metrics-client-id=16d905c5-31ee-4a45-b576-9c5f3d7795fd --shared-files --seatbelt-client=38
1 1665 0.0 matteobonelli /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/81.0.4044.129/XPCServices/AlertNotificationService.xpc/Contents/MacOS/AlertNotificationService
1 1668 0.0 matteobonelli /System/Library/Frameworks/VideoToolbox.framework/Versions/A/XPCServices/VTDecoderXPCService.xpc/Contents/MacOS/VTDecoderXPCService
1649 1670 0.0 matteobonelli /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/81.0.4044.129/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) --type=renderer --field-trial-handle=1718379636,12981871602970630566,18337982942199887150,131072 --lang=it --metrics-client-id=16d905c5-31ee-4a45-b576-9c5f3d7795fd --extension-process --enable-auto-reload --num-raster-threads=4 --enable-zero-copy --enable-gpu-memory-buffer-compositor-resources --enable-main-frame-before-activation --renderer-client-id=6 --no-v8-untrusted-code-mitigations --shared-files --seatbelt-client=94
1 1673 0.0 matteobonelli /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
1 1675 0.0 matteobonelli /usr/libexec/keyboardservicesd
1649 1676 0.0 matteobonelli /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/81.0.4044.129/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) --type=renderer --field-trial-handle=1718379636,12981871602970630566,18337982942199887150,131072 --lang=it --metrics-client-id=16d905c5-31ee-4a45-b576-9c5f3d7795fd --extension-process --enable-auto-reload --num-raster-threads=4 --enable-zero-copy --enable-gpu-memory-buffer-compositor-resources --enable-main-frame-before-activation --renderer-client-id=4 --no-v8-untrusted-code-mitigations --shared-files --seatbelt-client=120
1649 1678 0.0 matteobonelli /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/81.0.4044.129/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) --type=renderer --field-trial-handle=1718379636,12981871602970630566,18337982942199887150,131072 --lang=it --metrics-client-id=16d905c5-31ee-4a45-b576-9c5f3d7795fd --extension-process --enable-auto-reload --num-raster-threads=4 --enable-zero-copy --enable-gpu-memory-buffer-compositor-resources --enable-main-frame-before-activation --renderer-client-id=5 --no-v8-untrusted-code-mitigations --shared-files --seatbelt-client=135
1649 1679 0.0 matteobonelli /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/81.0.4044.129/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) --type=renderer --field-trial-handle=1718379636,12981871602970630566,18337982942199887150,131072 --lang=it --metrics-client-id=16d905c5-31ee-4a45-b576-9c5f3d7795fd --extension-process --enable-auto-reload --num-raster-threads=4 --enable-zero-copy --enable-gpu-memory-buffer-compositor-resources --enable-main-frame-before-activation --renderer-client-id=7 --no-v8-untrusted-code-mitigations --shared-files --seatbelt-client=130
1649 1681 0.0 matteobonelli /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/81.0.4044.129/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) --type=renderer --field-trial-handle=1718379636,12981871602970630566,18337982942199887150,131072 --lang=it --metrics-client-id=16d905c5-31ee-4a45-b576-9c5f3d7795fd --extension-process --enable-auto-reload --num-raster-threads=4 --enable-zero-copy --enable-gpu-memory-buffer-compositor-resources --enable-main-frame-before-activation --renderer-client-id=9 --no-v8-untrusted-code-mitigations --shared-files --seatbelt-client=132
1649 1682 0.0 matteobonelli /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/81.0.4044.129/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) --type=renderer --field-trial-handle=1718379636,12981871602970630566,18337982942199887150,131072 --lang=it --metrics-client-id=16d905c5-31ee-4a45-b576-9c5f3d7795fd --enable-auto-reload --num-raster-threads=4 --enable-zero-copy --enable-gpu-memory-buffer-compositor-resources --enable-main-frame-before-activation --renderer-client-id=11 --no-v8-untrusted-code-mitigations --shared-files --seatbelt-client=127
1649 1683 0.0 matteobonelli /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/81.0.4044.129/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) --type=renderer --field-trial-handle=1718379636,12981871602970630566,18337982942199887150,131072 --lang=it --metrics-client-id=16d905c5-31ee-4a45-b576-9c5f3d7795fd --enable-auto-reload --num-raster-threads=4 --enable-zero-copy --enable-gpu-memory-buffer-compositor-resources --enable-main-frame-before-activation --renderer-client-id=12 --no-v8-untrusted-code-mitigations --shared-files --seatbelt-client=177
1649 1685 0.0 matteobonelli /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/81.0.4044.129/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) --type=renderer --field-trial-handle=1718379636,12981871602970630566,18337982942199887150,131072 --lang=it --metrics-client-id=16d905c5-31ee-4a45-b576-9c5f3d7795fd --enable-auto-reload --num-raster-threads=4 --enable-zero-copy --enable-gpu-memory-buffer-compositor-resources --enable-main-frame-before-activation --renderer-client-id=13 --no-v8-untrusted-code-mitigations --shared-files --seatbelt-client=192
1649 1688 1.3 matteobonelli /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/81.0.4044.129/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) --type=renderer --field-trial-handle=1718379636,12981871602970630566,18337982942199887150,131072 --lang=it --metrics-client-id=16d905c5-31ee-4a45-b576-9c5f3d7795fd --enable-auto-reload --num-raster-threads=4 --enable-zero-copy --enable-gpu-memory-buffer-compositor-resources --enable-main-frame-before-activation --renderer-client-id=16 --no-v8-untrusted-code-mitigations --shared-files --seatbelt-client=231
1 1690 0.0 matteobonelli /System/Library/PrivateFrameworks/CoreRecents.framework/Versions/A/Support/recentsd
1649 1691 0.0 matteobonelli /Applications/Google Chrome.app/Contents/Frameworks/Google Chrome Framework.framework/Versions/81.0.4044.129/Helpers/Google Chrome Helper (Renderer).app/Contents/MacOS/Google Chrome Helper (Renderer) --type=renderer --field-trial-handle=1718379636,12981871602970630566,18337982942199887150,131072 --lang=it --metrics-client-id=16d905c5-31ee-4a45-b576-9c5f3d7795fd --enable-auto-reload --num-raster-threads=4 --enable-zero-copy --enable-gpu-memory-buffer-compositor-resources --enable-main-frame-before-activation --renderer-client-id=17 --no-v8-untrusted-code-mitigations --shared-files --seatbelt-client=135
1 1727 0.0 matteobonelli /System/Library/PrivateFrameworks/AppStoreDaemon.framework/Support/appstoreagent
1 1731 0.0 matteobonelli /System/Library/PrivateFrameworks/UsageTracking.framework/Versions/A/UsageTrackingAgent
1 1732 0.0 matteobonelli /System/Library/PrivateFrameworks/Categories.framework/Versions/A/XPCServices/CategoriesService.xpc/Contents/MacOS/CategoriesService
1 1734 0.0 matteobonelli /System/Library/PrivateFrameworks/PhotoAnalysis.framework/Versions/A/Support/photoanalysisd
1 1735 0.0 matteobonelli /System/Library/PrivateFrameworks/PhotoLibraryServices.framework/Versions/A/Support/photolibraryd
1 1736 0.0 matteobonelli /System/Library/CoreServices/ScopedBookmarkAgent
1 1739 0.0 matteobonelli cloudphotod
1 1782 0.0 root /usr/libexec/periodic-wrapper daily
1 1856 0.0 root /usr/libexec/dprivacyd
1 1864 0.0 matteobonelli /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 1898 0.0 matteobonelli /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 1899 0.0 matteobonelli /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 1901 0.0 matteobonelli /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 1903 0.0 matteobonelli /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 1904 0.0 matteobonelli /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 1905 0.0 matteobonelli /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 1906 0.0 matteobonelli /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 1907 0.0 matteobonelli /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 1908 0.0 matteobonelli /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 1910 0.0 matteobonelli /usr/libexec/silhouette
1 1912 0.0 root /usr/bin/sysdiagnose
1 1917 0.0 _spotlight /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 1918 0.0 matteobonelli /System/Library/PrivateFrameworks/SyncedDefaults.framework/Support/syncdefaultsd
1 1919 0.0 matteobonelli /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/XPCServices/media-indexer.xpc/Contents/MacOS/media-indexer
1 1920 0.0 matteobonelli /System/Library/PrivateFrameworks/PodcastServices.framework/XPCServices/PodcastContentService.xpc/Contents/MacOS/PodcastContentService
1 1921 0.0 matteobonelli /System/Library/PrivateFrameworks/BookKit.framework/Versions/A/XPCServices/com.apple.BKAgentService.xpc/Contents/MacOS/com.apple.BKAgentService
1 1922 0.0 matteobonelli /System/Library/PrivateFrameworks/AMPLibrary.framework/Versions/A/Support/AMPArtworkAgent --launchd
1 1923 0.0 matteobonelli /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 1924 0.0 matteobonelli /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 1926 0.0 matteobonelli /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 1927 0.0 matteobonelli /System/Library/CoreServices/EscrowSecurityAlert.app/Contents/MacOS/EscrowSecurityAlert
1 1929 0.0 matteobonelli /System/Library/PrivateFrameworks/IMDPersistence.framework/IMAutomaticHistoryDeletionAgent.app/Contents/MacOS/IMAutomaticHistoryDeletionAgent
1 1930 0.0 matteobonelli /usr/libexec/transparencyd
1 1932 0.0 matteobonelli /System/Library/Frameworks/ApplicationServices.framework/Frameworks/SpeechSynthesis.framework/Resources/com.apple.speech.speechsynthesisd
1 1936 0.0 root /usr/libexec/periodic-wrapper weekly
1 1954 0.0 matteobonelli /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker -s mdworker-sizing -c MDSSizingWorker -m com.apple.mdworker.sizing
1 1955 0.0 _reportmemoryexception /usr/libexec/ReportMemoryException
1 1956 0.0 matteobonelli /Applications/Xcode.app/Contents/PlugIns/IDECacheDeleteAppExtension.appex/Contents/MacOS/IDECacheDeleteAppExtension
1 1957 0.1 matteobonelli /System/Applications/Music.app/Contents/PlugIns/MusicCacheExtension.appex/Contents/MacOS/MusicCacheExtension
1 1958 0.0 matteobonelli /Applications/Safari Technology Preview.app/Contents/PlugIns/CacheDeleteExtension.appex/Contents/MacOS/CacheDeleteExtension
1 1959 0.0 matteobonelli /System/Applications/TV.app/Contents/PlugIns/TVCacheExtension.appex/Contents/MacOS/TVCacheExtension
1 1960 0.0 matteobonelli /Applications/Safari.app/Contents/PlugIns/CacheDeleteExtension.appex/Contents/MacOS/CacheDeleteExtension
1 1961 0.0 matteobonelli /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/Resources/helpd
1 1962 0.0 matteobonelli /System/Library/Frameworks/QuickLook.framework/Resources/quicklookd.app/Contents/MacOS/quicklookd
1 1963 0.0 matteobonelli /System/Library/Frameworks/QuickLook.framework/Versions/A/XPCServices/QuickLookSatellite.xpc/Contents/MacOS/QuickLookSatellite
1 1964 6.0 matteobonelli /Applications/DetectX Swift.app/Contents/MacOS/DetectX Swift
1 1996 0.0 matteobonelli /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMCompiler 2
1 2079 0.0 matteobonelli /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 2080 0.0 matteobonelli /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 2081 0.0 matteobonelli /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 2082 0.0 matteobonelli /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 2083 0.0 matteobonelli /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
Spero che tutte queste info che ho postato possano essere d'aiuto e soppratutto i log spero di averli postati giusti e di non aver fatto pasticci e di non averli più resi comprensibili.
Ancora grazie del supporto che mi state dando e buon proseguimento a tutti/e.
