Ogni tanto il mio MacBook Pro sviene!!!
tblu13
Ciao a tutti ho un MacBook Pro (Retina, 13-inch, Mid 2014) a cui ho sostituito batteria e ssd ,ogni tanto in avvio va in crash e poi mettendolo in carica rinviene, qualcuno potrebbe aiutarmi a risolvere questo problema?
Posto il resoconto :
panic(cpu 0 caller 0xffffff80108cf860): nvme: "Fatal error occurred. CSTS=0x1 US[1]=0x0 US[0]=0x12 VID=0xc0a9 DID=0x540a
. FW Revision=P2CR033\n"@/System/Volumes/Data/SWE/macOS/BuildRoots/a0c6c82cc8/Library/Caches/com.apple.xbs/Sources/IONVMeFamily/IONVMeFamily-557.120.1/Common/IONVMeController.cpp:5499
Backtrace (CPU 0), Frame : Return Address
0xffffffa087833960 : 0xffffff800e08b26d
0xffffffa0878339b0 : 0xffffff800e1d2993
0xffffffa0878339f0 : 0xffffff800e1c2f8a
0xffffffa087833a40 : 0xffffff800e02fa2f
0xffffffa087833a60 : 0xffffff800e08aa8d
0xffffffa087833b80 : 0xffffff800e08ad83
0xffffffa087833bf0 : 0xffffff800e89c5aa
0xffffffa087833c60 : 0xffffff80108cf860
0xffffffa087833c80 : 0xffffff80108b445b
0xffffffa087833de0 : 0xffffff800e7f3185
0xffffffa087833e50 : 0xffffff800e7f3086
0xffffffa087833e80 : 0xffffff800e0d1985
0xffffffa087833ef0 : 0xffffff800e0d28f4
0xffffffa087833fa0 : 0xffffff800e02f13e
Kernel Extensions in backtrace:
com.apple.iokit.IONVMeFamily(2.1)[A69B93A6-5818-37A7-AB02-34C88B9BADA5]@0xffffff80108ad000->0xffffff80108d6fff
dependency: com.apple.driver.AppleEFINVRAM(2.1)[A506788E-BC7C-3C87-BD70-376984C225D3]@0xffffff800f4fe000->0xffffff800f507fff
dependency: com.apple.driver.AppleMobileFileIntegrity(1.0.5)[31810E2C-FD94-31EC-8723-BA1B19DDF0A1]@0xffffff800f6c0000->0xffffff800f6d5fff
dependency: com.apple.iokit.IOPCIFamily(2.9)[F9CEE803-CCD0-37F1-A06C-60062C48DEF2]@0xffffff8010b6b000->0xffffff8010b93fff
dependency: com.apple.iokit.IOReportFamily(47)[8C08A9E9-A5DA-340B-BFCB-3F5E82BDAF01]@0xffffff8010ba2000->0xffffff8010ba4fff
dependency: com.apple.iokit.IOStorageFamily(2.1)[FFF27081-0E9D-3E7F-8807-C018C8E46A09]@0xffffff8010c6e000->0xffffff8010c7ffff
Process name corresponding to current thread: kernel_task
Mac OS version:
20G527
Kernel version:
Darwin Kernel Version 20.6.0: Tue Feb 22 21:10:41 PST 2022; root:xnu-7195.141.26~1/RELEASE_X86_64
Kernel UUID: 40A47F9A-078F-3F9B-B353-53A194CC6F1D
KernelCache slide: 0x000000000de00000
KernelCache base: 0xffffff800e000000
Kernel slide: 0x000000000de10000
Kernel text base: 0xffffff800e010000
__HIB text base: 0xffffff800df00000
System model name: MacBookPro11,1 (Mac-189A3D4F975D5FFC)
System shutdown begun: NO
Panic diags file available: NO (0xe00002d8)
Hibernation exit count: 0
System uptime in nanoseconds: 74838332422
Last Sleep: absolute base_tsc base_nano
Uptime : 0x000000116cb66f27
Sleep : 0x0000000000000000 0x0000000000000000 0x0000000000000000
Wake : 0x0000000000000000 0x0000000268f3d9d9 0x0000000000000000
last started kext at 2032188271: |IO!BUSBDFU 8.0.5d7 (addr 0xffffff80107a6000, size 4096)
loaded kexts:
|IO!BUSBDFU 8.0.5d7
>!UTCKeyEventDriver 256
>!UTCButtons 256
>!UTCKeyboard 256
|SCSITaskUserClient 436.140.1
>!UCardReader 511.141.1
>!AFileSystemDriver 3.0.1
@filesystems.tmpfs 1
@filesystems.hfs.kext 556.100.12
@BootCache 40
@!AFSCompression.!AFSCompressionTypeZlib 1.0.0
@!AFSCompression.!AFSCompressionTypeDataless 1.0.0d1
@filesystems.apfs 1677.141.3
>AirPort.BrcmNIC 1400.1.1
@private.KextAudit 1.0
>!ASmartBatteryManager 161.0.0
>!ARTC 2.0
>!AACPIButtons 6.1
>!AHPET 1.8
>!ASMBIOS 2.1
>!AACPIEC 6.1
>!AAPIC 1.7
@!ASystemPolicy 2.0.0
@nke.applicationfirewall 311
|IOKitRegistryCompatibility 1
|EndpointSecurity 1
|Broadcom!BHost!CUSBTransport 8.0.5d7
|IO!BHost!CUSBTransport 8.0.5d7
|IO!BHost!CTransport 8.0.5d7
>usb.!UHub 1.2
>!UMultitouch 264
>usb.IOUSBHostHIDDevice 1.2
>usb.cdc 5.0.0
>usb.networking 5.0.0
>usb.!UHostCompositeDevice 1.2
>!AThunderboltDPInAdapter 8.1.4
>!AThunderboltDPAdapter!F 8.1.4
>!AThunderboltPCIDownAdapter 4.1.1
>!ABSDKextStarter 3
|IOSurface 290.8.1
@filesystems.hfs.encodings.kext 1
>!AXsanScheme 3
|IONVMe!F 2.1.0
>!AThunderboltNHI 7.2.8
|IOThunderbolt!F 9.3.2
|IO80211!F 1200.12.2b1
|IOSkywalk!F 1
>mDNSOffloadUserClient 1.0.1b8
>corecapture 1.0.4
>!A!ILpssGspi 3.0.60
>usb.!UHostPacketFilter 1.0
|IOUSB!F 900.4.2
>usb.!UXHCIPCI 1.2
>usb.!UXHCI 1.2
>!AEFINVRAM 2.1
>!AEFIRuntime 2.1
|IOSMBus!F 1.1
|IOHID!F 2.0.0
$!AImage4 3.0.0
|IOTimeSync!F 985.2
|IONetworking!F 3.4
>DiskImages 493.0.0
|IO!B!F 8.0.5d7
|IOReport!F 47
|IO!BPacketLogger 8.0.5d7
$quarantine 4
$sandbox 300.0
@kext.!AMatch 1.0.0d1
|CoreAnalytics!F 1
>!ASSE 1.0
>!AKeyStore 2
>!UTDM 511.141.1
|IOUSBMass!SDriver 184.140.2
|IOSCSIBlockCommandsDevice 436.140.1
|IO!S!F 2.1
|IOSCSIArchitectureModel!F 436.140.1
>!AMobileFileIntegrity 1.0.5
@kext.CoreTrust 1
>!AFDEKeyStore 28.30
>!AEffaceable!S 1.0
>!ACredentialManager 1.0
>KernelRelayHost 1
|IOUSBHost!F 1.2
>!UHostMergeProperties 1.2
>usb.!UCommon 1.0
>!ABusPower!C 1.0
>!ASEPManager 1.0.1
>IOSlaveProcessor 1
>!AACPIPlatform 6.1
>!ASMC 3.1.9
|IOPCI!F 2.9
|IOACPI!F 1.4
>watchdog 1
@kec.pthread 1
@kec.corecrypto 11.1
@kec.Libm 1
Alberto.G
tblu13 ha scritto:
mar, 24 mag 2022 09:49
Vedo che hai sostituito batteria ed ssd ed infatti il kernel panic che hai ha come riferimento la parola “nvme”.
Ti consiglio di fare questo test per un controllo hardware del Mac
https://support.apple.com/it-it/HT202731
Poi, ti consiglio anche di fare una verifica della macchina con DetectX Swift.
Segui queste indicazioni.
Scarica l’app da qui (è gratis)
https://sqwarq.com/detectx/
Per primo verifica il risultato della finestra di DetectX Swift (quella dove c’è scritto STATUS:); se appare la scritta: “Search complete. No threats or problems found.” sei a posto, tutto è OK.
Se invece sono indicate stringhe di file vuol dire che DetectX ha trovato la presenza di adware o malware.
Posta quindi il risultato della finestra SEARCH, facendo semplicemente uno screenshot della pagina, o eventualmente di più pagine se ce ne fossero tante, e poi inviarcelo o inviarceli come [ Allegati ] che trovi nella pagina che stai utilizzando per il tuo messaggio.
Invece, per postare correttamente il report PROFILE, come Codice [</>], devi
- cliccare su finestra PROFILE
- cliccare su simbolo (quadratino con la freccetta verso alto)
Schermata tasto Condividi.png (3.3 KiB) Visto 955 volte
- cliccare su opzione Sanitized (per non far vedere sul report i propri dati sensibili)
- cliccare su Copy report to clipboard
- chiudere quindi DetectX cliccando su cerchietto rosso oppure cliccando prima su DetectX Swift (in alto barra menu) e poi su Quit /Esci
- cliccare su simbolo [<>] che trovi nella barra menu appena sopra il riquadro del messaggio da scrivere
- poi cliccare su Modifica (barra del menu in alto) e poi su Incolla
- il report viene caricato
- poi scorri il report che è stato appena inserito e vai in fondo fino a trovare il Paragrafo "Running Processes”
- poi cancelli tutte le righe che vengono dopo il suddetto Paragrafo e fino alla fine del report, perché non servono.
Ti invio la parte iniziale del mio report PROFILE come esempio.
Timestamp (98): Wed May 25 23:44:39 2022
DetectX Swift v1.0982
macOS: Version 12.4 (Build 21F79)
File System: apfs
Boot time: Tue May 17 00:36:10 2022
Uptime: 8 days, 23:08
Spotlight status for /:
	Indexing enabled.
FileVault is Off.
Internet:	Reachable
    Hardware Overview:
      Model Name: iMac
      Model Identifier: iMac16,2
      Processor Name: Quad-Core Intel Core i5
      Processor Speed: 3,1 GHz
      Number of Processors: 1
      Total Number of Cores: 4
      L2 Cache (per Core): 256 KB
      L3 Cache: 4 MB
      Memory: 8 GB
      System Firmware Version: 430.120.6.0.0
      OS Loader Version: 540.120.3~6
      SMC Version (system): 2.32f21
      Provisioning UDID: 6D932C3D-14D8-5B78-B3F8-C56386BEE1E3
  Sharing Preferences:
	File Sharing:  On
	Screen Sharing:  Off
	Remote Management:  Off
	Back To My Mac:  Off
	Remote Login:  Off
	Remote Apple Events:  Off
3rd Party Kexts (loaded):
 $PATH:
/etc/paths:
	/usr/local/bin
	/usr/bin
	/bin
	/usr/sbin
	/sbin
/etc/paths.d/:
~/.bash_profile:
~/.bashrc:
~/.bash_login:
~/.profile:
~/.bash_logout:
PID	Status	Label
-	1	com.maintain.PurgeInactiveMemory
965	0	com.bjango.istatmenus.agent
-	0	com.maintain.Restart
«»EOF»«
joseterra
..ma sei realmente in avvio o riprendi ad usarlo dall'ibernazione?
Il nuovo Nvme SSD è un normale 2280 con adattatore oppure uno tipo OWC (senza adattatore)?
MacBook Air 11 pollici 2011, 4 GB RAM, 1 TB SSD (OCLP per Catalina)
MacBook Air 13 pollici 2014, 4 GB RAM, 256 GB SSD,
MacBook Air 13 pollici 2017, 8 GB RAM, 1 TB NVMe
MacBook Pro 13 pollici 2015, i7 16 GB Ram, 2 TB NVMe
Qualche Hackintosh
Qualche Apple Silicon per lavoro
Qualche PC Windows
tblu13
Parto da un normale avvio ma il Mac quando la batteria non è completamente carica non si avvia, poi collego l'alimentatore e dopo un paio di minuti si riavvia dandomi il resoconto che ho postato.
E' un ssd con adattatore...
cosa cambia riguardo il problema che riscontro?Potrebbe essere l'adattatore?
tblu13
Timestamp (8): Wed Jul 06 09:48:47 2022
DetectX Swift v1.0983
macOS: Version 11.6.7 (Build 20G630)
File System: apfs
Boot time: Wed Jul 6 09:36:16 2022
Uptime: up 13 mins, 1 user
	Indexing enabled.
FileVault is Off.
Internet:	Reachable
    Hardware Overview:
      Model Name: MacBook Pro
      Model Identifier: MacBookPro11,1
      Processor Name: Dual-Core Intel Core i5
      Processor Speed: 2,6 GHz
      Total Number of Cores: 2
      L3 Cache: 3 MB
      Hyper-Threading Technology: Enabled
      Memory: 8 GB
      System Firmware Version: 433.120.6.0.0
      SMC Version (system): 2.16f68
      Provisioning UDID: 9108A363-6BDC-5DCB-A95A-781E5646F9DD
	File Sharing:  On
	Screen Sharing:  On
	Remote Management:  On
	Back To My Mac:  Off
	Remote Login:  Off
 $PATH:
/etc/paths:
	/usr/local/bin
	/usr/bin
	/bin
	/usr/sbin
	/sbin
/etc/paths.d/:
	/opt/X11/bin
	/Library/Frameworks/Mono.framework/Versions/Current/Commands
~/.bash_profile:
~/.bashrc:
~/.bash_login:
~/.profile:
~/.bash_logout:
PID	Status	Label
-	0	com.macpaw.CleanMyMac4.HealthMonitor
-	0	com.google.keystone.user.xpcservice
-	0	net.protected.AVLaunchHelper
458	0	com.brother.LOGINserver
1285	0	application.com.sqwarq.DetectX-Swift.4054293.4054305
463	0	com.adobe.GC.AGM
465	0	com.piriform.CCleaner
481	0	application.com.getdropbox.dropbox.147653.3769874
-	78	com.adobe.AdobeCreativeCloud
-	0	com.openssh.ssh-agent
-	78	/Library/lhvZzJJk/rFKlgBzC/ZOaHFXqy/dUItLbhL/tzJXZUbS/SoLRaBal
-	0	CorelUpdateHelperTask
-	0	com.piriform.ccleaner.update
491	0	application.com.google.android.mtpagent.506925.506997
-	78	UtilityParze
871	0	application.com.brother.utility.USBAppControlServer.454153.454159
523	0	application.com.brother.utility.USBserver.454190.454196
-	78	/Library/naphthol-sneap/IlIUIAEb/KjuSiRUJ/isopodan
-	111	com.adobe.ARMDCHelper.cc24aef4a1b90ed56a725c38014c95072f92651fb65e1bf9c8e43c37a23d420d
870	0	application.com.brother.utility.WorkflowAppControlServer.454200.454206
-	78	com.OperaHelper
470	0	com.GoPro.goproapp-devicedetection
-	2	rrwfP
-	-15	com.macpaw.CleanMyMac4.Updater
-	1	com.adobe.ccxprocess
-	1	com.google.keystone.user.agent
869	0	application.com.brother.utility.NETserver.454144.454150
-	0	com.dropbox.DropboxMacUpdate.agent
 System Launchd processes:
301      - 	47M7HL5AG8.net.protected.macos.TotalAV.ESAVExtension
0      0 	Vgvdq
0      - 	com.adobe.acc.installer.v2
274      - 	com.vix.cron
0      - 	com.piriform.ccleaner.engine.xpc
0      - 	com.piriform.ccleaner.update.xpc
0      - 	us.zoom.ZoomDaemon
0      - 	com.piriform.ccleaner.services.submit
540      - 	com.piriform.ccleaner.services.xpc
0      - 	com.teamviewer.Helper
103      - 	Adobe_Genuine_Software_Integrity_Service
0      - 	com.macpaw.CleanMyMac4.Agent
0      0 	org.cups.cupsd
0      - 	com.adobe.ARMDC.Communicator
527      - 	net.protected.macos.AVHelper
0      - 	com.adobe.ARMDC.SMJobBlessHelper
0      - 	com.transcend.RxRecoveryHelper
0      - 	com.piriform.ccleaner.uninstall
 User Login Items:
	/Applications/TotalAV.app
	/Applications/TotalAV.app/Contents/Library/LoginItems/AVLaunchHelper.app
	/Applications/Dropbox.app
	/Applications/Android File Transfer.app
	/Users/[U503]/Library/Application Support/Google/Android File Transfer/Android File Transfer Agent.app
	/Applications/GoPro Quik.app
	/Applications/GoPro Quik.app/Contents/Library/LoginItems/goproapp.devicedetection.app
 /Library/LaunchDaemons:
	com.piriform.ccleaner.services.xpc.plist
		-> Program: /Applications/CCleaner.app/Contents/PlugIns/Services.framework/XPCServices/com.piriform.ccleaner.services.xpc
	com.adobe.agsservice.plist
		--> Program Arguments: /Library/Application Support/Adobe/AdobeGCClient/AGSService
	com.adobe.ARMDC.SMJobBlessHelper.plist
		--> Program Arguments: /Library/PrivilegedHelperTools/com.adobe.ARMDC.SMJobBlessHelper
	com.piriform.ccleaner.engine.xpc.plist
		-> Program: /Applications/CCleaner.app/Contents/Frameworks/CleaningEngine.framework/XPCServices/com.piriform.ccleaner.engine.xpc
	com.macpaw.CleanMyMac4.Agent.plist
		-> Program: /Library/PrivilegedHelperTools/com.macpaw.CleanMyMac4.Agent
		--> Program Arguments: /Library/PrivilegedHelperTools/com.macpaw.CleanMyMac4.Agent
	com.adobe.ARMDC.Communicator.plist
		--> Program Arguments: /Library/PrivilegedHelperTools/com.adobe.ARMDC.Communicator
	com.piriform.ccleaner.services.submit.plist
		-> Program: /Applications/CCleaner.app/Contents/PlugIns/Services.framework/Versions/Current/com.piriform.ccleaner.services.crashReporter
	com.transcend.RxRecoveryHelper.plist
		-> Program: /Library/PrivilegedHelperTools/com.transcend.RxRecoveryHelper
		--> Program Arguments: /Library/PrivilegedHelperTools/com.transcend.RxRecoveryHelper
	com.Vgvdq.plist
		-> Program: /Library/4JHPd/ZNr1E
	com.teamviewer.Helper.plist
		-> Program: /Library/PrivilegedHelperTools/com.teamviewer.Helper
		--> Program Arguments: /Library/PrivilegedHelperTools/com.teamviewer.Helper
	com.adobe.acc.installer.v2.plist
		-> Program: /Library/PrivilegedHelperTools/com.adobe.acc.installer.v2
		--> Program Arguments: /Library/PrivilegedHelperTools/com.adobe.acc.installer.v2
	com.teamviewer.teamviewer_service.plist
		--> Program Arguments: /Applications/TeamViewer.app/Contents/MacOS/TeamViewer_Service
		--> Program Arguments: -Module
		--> Program Arguments: Full
	com.piriform.ccleaner.update.xpc.plist
		--> Program Arguments: /Applications/CCleaner.app/Contents/Frameworks/com.piriform.ccleaner.update.bundle/Contents/XPCServices/com.piriform.ccleaner.update.xpc/Contents/MacOS/com.piriform.ccleaner.update.xpc
	us.zoom.ZoomDaemon.plist
		-> Program: /Library/PrivilegedHelperTools/us.zoom.ZoomDaemon
		--> Program Arguments: /Library/PrivilegedHelperTools/us.zoom.ZoomDaemon
	net.protected.macos.AVHelper.plist
		-> Program: /Library/PrivilegedHelperTools/net.protected.macos.AVHelper
		--> Program Arguments: /Library/PrivilegedHelperTools/net.protected.macos.AVHelper
	com.piriform.ccleaner.uninstall.plist
		-> Program: /Applications/CCleaner.app/Contents/Uninstaller.app/Contents/XPCServices/com.piriform.ccleaner.uninstall.helper
 /Library/LaunchAgents:
	com.piriform.ccleaner.plist
		--> Program Arguments: /Applications/CCleaner.app/Contents/MacOS/CCleaner
		--> Program Arguments: -standaloneInstanceAllowed
		--> Program Arguments: YES
	com.adobe.AdobeCreativeCloud.plist
		-> Program: /Applications/Utilities/Adobe Creative Cloud/ACC/Creative Cloud.app/Contents/MacOS/Creative Cloud
		--> Program Arguments: /Applications/Utilities/Adobe Creative Cloud/ACC/Creative Cloud.app/Contents/MacOS/Creative Cloud
		--> Program Arguments: --showwindow=false
		--> Program Arguments: --onOSstartup=true
	com.teamviewer.teamviewer_desktop.plist
		--> Program Arguments: /Applications/TeamViewer.app/Contents/MacOS/TeamViewer_Desktop
		--> Program Arguments: -RunAsAgent
	com.adobe.ccxprocess.plist
		--> Program Arguments: /usr/bin/open
		--> Program Arguments: -a
		--> Program Arguments: /Applications/Utilities/Adobe Creative Cloud Experience/CCXProcess/CCXProcess.app
	com.corel.CorelUpdateHelperTask.agent.plist
		--> Program Arguments: /Library/Preferences/com.corel.CUH/CUH.app/Contents/MacOS/CUH
		--> Program Arguments: -macSched
	com.adobe.GC.AGM.plist
		-> Program: /Library/Application Support/Adobe/AdobeGCClient/AGMService
		--> Program Arguments: /Library/Application Support/Adobe/AdobeGCClient/AGMService
		--> Program Arguments: -mode=logon
	com.teamviewer.teamviewer.plist
	com.SoLRaBal.plist
		-> Program: /Library/lhvZzJJk/rFKlgBzC/ZOaHFXqy/dUItLbhL/tzJXZUbS/SoLRaBal
	com.adobe.AAM.Updater-1.0.plist
		-> Program: /Library/Application Support/Adobe/OOBE/PDApp/UWA/UpdaterStartupUtility
		--> Program Arguments: /Library/Application Support/Adobe/OOBE/PDApp/UWA/UpdaterStartupUtility
	com.adobe.GC.Invoker-1.0.plist
		-> Program: /Library/Application Support/Adobe/AdobeGCClient/agcinvokerutility
		--> Program Arguments: /Library/Application Support/Adobe/AdobeGCClient/agcinvokerutility
	com.adobe.ARMDCHelper.cc24aef4a1b90ed56a725c38014c95072f92651fb65e1bf9c8e43c37a23d420d.plist
		--> Program Arguments: /Library/Application Support/Adobe/ARMDC/Application/Acrobat Update Helper.app/Contents/MacOS/Acrobat Update Helper
	com.brother.LOGINserver.plist
		--> Program Arguments: /Library/Printers/Brother/Utilities/Server/LOGINserver.app/Contents/MacOS/LOGINserver
	com.piriform.ccleaner.update.plist
		--> Program Arguments: /Applications/CCleaner.app/Contents/Frameworks/com.piriform.ccleaner.update.bundle/Contents/MacOS/com.piriform.ccleaner.update
	update.log
	com.isopodan.plist
		-> Program: /Library/naphthol-sneap/IlIUIAEb/KjuSiRUJ/isopodan
 ~/Library/LaunchAgents:
		--> Program Arguments: /Users/[U503]/Library/Google/GoogleSoftwareUpdate/GoogleSoftwareUpdate.bundle/Contents/Resources/GoogleSoftwareUpdateAgent.app/Contents/MacOS/GoogleSoftwareUpdateAgent
	com.macpaw.CleanMyMac4.HealthMonitor.plist
		--> Program Arguments: /Users/[U503]/Library/Application Support/CleanMyMac X/CleanMyMac X HealthMonitor.app/Contents/MacOS/CleanMyMac X HealthMonitor
	com.UtilityParze.plist
		-> Program: /Users/[U503]/Library/UpdatesMac/UtilityParze/UtilityParze
	com.macpaw.CleanMyMac4.Updater.plist
		--> Program Arguments: /Users/[U503]/Library/Application Support/CleanMyMac X/CleanMyMac X Updater.app/Contents/MacOS/CleanMyMac X Updater
	com.Opera_Helper.plist
		-> Program: /var/tmp/.opera_helper.sh
	com.rrwfP.plist
		-> Program: /Users/[U503]/Library/lVAwh/zfPgX
		--> Program Arguments: -mode=scheduled
	com.dropbox.DropboxMacUpdate.agent.plist
		--> Program Arguments: /Users/[U503]/Library/Dropbox/DropboxMacUpdate.app/Contents/MacOS/DropboxMacUpdate
		--> Program Arguments: -check
		--> Program Arguments: periodic
 User Crontab:
	41 * * * *  cr
 /etc:
	rc.common
	bashrc_Apple_Terminal
	zshrc_Apple_Terminal
	php-NOTICE-PLANNED-REMOVAL.txt
	bashrc
	zshrc
	rc.netboot
	efax.rc~previous
	php.ini.default-previous~orig
	php.ini.default-5.2-previous
	aliases
	uucp / .. children: 3
	zprofile
 / $Root:
	.file
	.VolumeIcon.icns
	AppleInternal
	opt / .. children: 1
 ~/ $Home:
	.invoicex / .. children: 15
	.config / .. children: 3
	Music / .. children: 4
	objc.scan
	Creative Cloud Files tblu13@libero.it b8e9c54e286b87e9d99049ba3026afdb233f17f2ab527788342cafe28b96c78a / .. children: 3
	Dropbox (Precedente) / .. children: 8
	iCloud Drive (Archivio) - 1 / .. children: 7
	.CFUserTextEncoding
	iCloud Drive (Archivio) / .. children: 4
	.adobe / .. children: 1
	.local / .. children: 1
	Creative Cloud Files / .. children: 1
	Pictures / .. children: 27
	cache.ga
	Desktop / .. children: 39
	Library / .. children: 99
	.dat
	.oracle_jre_usage / .. children: 10
	.cups / .. children: 1
	.bash_sessions / .. children: 7
	.hsvc_0503 / .. children: 1
	Public / .. children: 4
	.dropbox / .. children: 13
	Creative Cloud Files (archived) (1) / .. children: 1
	.ssh / .. children: 1
	Movies / .. children: 8
	Applications / .. children: 0
	Dropbox / .. children: 29
	.Trash / .. children: 4
	Documents / .. children: 48
	.mono / .. children: 1
	Downloads / .. children: 321
	.cache / .. children: 1
	.bash_history
	tblu13@libero.it Creative Cloud Files / .. children: 1
	.DVDVideoSoft / .. children: 7
 ~/Library:
	Receipts / .. children: 8
	Address Book Plug-Ins / .. children: 4
	.clappy
	studentd / .. children: 3
	Staging / .. children: 0
	HomeKit / .. children: 11
	ApplicationSupport / .. children: 1
	Translation / .. children: 1
	cashbook / .. children: 2
	NGL / .. children: 0
	Trial / .. children: 4
	.Dc3r
	UIKitSystem / .. children: 1
	Google / .. children: 2
	ldbnRnsB / .. children: 1
	Family / .. children: 1
	com.apple.icloud.searchpartyd / .. children: 5
	SafariSandboxBroker / .. children: 0
	CELSYS / .. children: 7
	Personas / .. children: 3
	HTTPStorages / .. children: 10
	DataDeliveryServices / .. children: 1
	PhotoshopCrashes / .. children: 0
	FrontBoard / .. children: 3
	UpdatesMac / .. children: 10
	instance
	Dropbox / .. children: 1
	utilityData / .. children: 0
	diplasiasmus.pn / .. children: 0
	ContainerManager / .. children: 4
	PersonalizationPortrait / .. children: 5
	Accessibility / .. children: 4
	UpdateMac / .. children: 3
	.U63yc
	deflator / .. children: 1
	VoiceTrigger / .. children: 1
	Reminders / .. children: 2
	lVAwh / .. children: 1
	Apple / .. children: 1
	Firefox / .. children: 5
	com.apple.replayd / .. children: 0
	DropboxElectron / .. children: 12
	com.GoPro.goproapp.GoProDeviceService / .. children: 2
	SyncServices / .. children: 1
	obs-studio / .. children: 5
	com.apple.kvs / .. children: 1
	.AdobeUpdater_Lock
	Mozilla / .. children: 1
	com.piriform.ccleaner / .. children: 15
	com.apple.transparencyd / .. children: 5
	com.movavi.photoeditor5 / .. children: 1
	com.apple.touristd / .. children: 25
	DiskImages / .. children: 1
	Steam / .. children: 0
	com.gopro.GoPro-Studio / .. children: 3
	.CCH_NGLW_Lock
	CoreParsec / .. children: 0
	com.wondershare.PDFelement6.Professional / .. children: 6
	com.GoPro.goproapp.GoProMediaFolderService / .. children: 2
	com.apple.exchangesync / .. children: 0
	Animoji / .. children: 3
	com.apple.akd / .. children: 1
	Skype Helper / .. children: 0
	zoom.us / .. children: 2
	MobileSync / .. children: 1
	OpenVR / .. children: 0
	eMuleTorrentgeoip / .. children: 1
	uTorrent / .. children: 17
	com.GoPro.goproapp.GoProPushNotificationService / .. children: 2
	Google / .. children: 5
	Microsoft / .. children: 1
	McNeel / .. children: 1
	Oracle / .. children: 1
	.CCH_UPI_Lock
	dmd / .. children: 0
	iMovie / .. children: 1
	Java / .. children: 0
	com.adobe.dunamis / .. children: 1
	Wine / .. children: 0
	com.apple.NewDeviceOutreach / .. children: 1
	Corel / .. children: 7
	CEF / .. children: 1
	kulerdata.json
	CELSYS / .. children: 4
	com.GoPro.goproapp.GoProMediaService / .. children: 3
	CleanMyMac X Menu / .. children: 2
	com.GoPro.goproapp.GoProExporterService / .. children: 1
	com.GoPro.goproapp.GoProUpdateService / .. children: 1
	TrustedPeersHelper / .. children: 0
	com.GoPro.goproapp.GoProMsgBus / .. children: 1
	Adobe / .. children: 56
	Gtk2 / .. children: 3
	.ACCC_Lock
	com.operasoftware.Opera / .. children: 59
	Garmin / .. children: 6
	TeamViewer / .. children: 1
	com.brother.utility.USBAppControlServer / .. children: 0
	com.GoPro.goproapp.GoProAlertService / .. children: 2
	System Preferences / .. children: 0
	Aperture / .. children: 0
	com.apple.ContextStoreAgent / .. children: 1
	balena-etcher / .. children: 8
	com.incrediblebee.Archiver3 / .. children: 0
	FileProvider / .. children: 4
	com.GoPro.goproapp.GoProShareService / .. children: 2
	Dropbox / .. children: 4
	com.apple.AMPLibraryAgent / .. children: 2
	CleanMyMac X / .. children: 13
	CELSYS_EN / .. children: 1
	Preview / .. children: 0
	com.GoPro.goproapp.GoProMusicService / .. children: 4
	µTorrent / .. children: 1
	com.GoPro.goproapp.GoProIDService / .. children: 2
	com.brother.utility.NETserver / .. children: 1
	Skype / .. children: 10
	com.brother.utility.USBserver / .. children: 1
	net.protected.macos.TotalAV / .. children: 4
	com.GoPro.goproapp.GoProAnalyticsService / .. children: 2
	com.apple.siri.inference / .. children: 0
	transparencyd / .. children: 0
	eMuleTorrent / .. children: 4
	com.bombich.ccc / .. children: 4
	syncdefaultsd / .. children: 0
	Movavi / .. children: 1
	GoPro / .. children: 1
	GIMP / .. children: 2
	aMule / .. children: 29
	com.GoPro.goproapp / .. children: 1
	Movavi Photo Editor 5 / .. children: 1
	JREInstaller / .. children: 1
	com.brother.utility.WorkflowAppControlServer / .. children: 1
	.ADCS_Lock
 ~/Library/Safari/Extensions:
	Trend Micro Antivirus.safariextz
	Extensions.plist
 ~/Library/Internet Plug-Ins:
 /Users/Shared:
	Previously Relocated Items 8 / .. children: 3
	Previously Relocated Items 1 / .. children: 3
	Previously Relocated Items 6 / .. children: 3
	adi / .. children: 0
	Previously Relocated Items 7 / .. children: 3
	SC Info / .. children: 0
	Previously Relocated Items 9 / .. children: 3
	Previously Relocated Items 15 / .. children: 3
	Previously Relocated Items 12 / .. children: 3
	Previously Relocated Items 24 / .. children: 3
	Previously Relocated Items 23 / .. children: 3
	Previously Relocated Items 22 / .. children: 3
	Previously Relocated Items 25 / .. children: 3
	Previously Relocated Items 13 / .. children: 3
	Previously Relocated Items 14 / .. children: 3
	Relocated Items / .. children: 3
	Canon / .. children: 1
	Previously Relocated Items 5 / .. children: 3
	Previously Relocated Items 2 / .. children: 3
	Adobe / .. children: 4
	Previously Relocated Items 3 / .. children: 3
	Previously Relocated Items 4 / .. children: 3
	Previously Relocated Items 11 / .. children: 3
	Previously Relocated Items 16 / .. children: 3
	Previously Relocated Items 20 / .. children: 3
	Previously Relocated Items 18 / .. children: 3
	Previously Relocated Items 19 / .. children: 3
	Previously Relocated Items 21 / .. children: 3
	Previously Relocated Items 17 / .. children: 3
	Previously Relocated Items 10 / .. children: 3
	CleanMyMac X / .. children: 9
	Previously Relocated Items / .. children: 4
	Canon_Inc_IC / .. children: 3
	AdobeGCData / .. children: 2
 /Applications:
	CLIP STUDIO 1.5 / .. children: 4
	Brother / .. children: 3
	presentazione.key
	VLC.app
	.svn / .. children: 7
	PDF to Pages Free.app
	StockControl2.app
	GIMP-2.10.app
	Brother iPrint&Scan.app
	Google Chrome.app
	Dropbox.app
	Toolbox for Pages.app
	Apnealizer.app
	aMule.app
	P-touch Editor 5.1 / .. children: 4
	DetectX Swift.app
	Invoicex.app
	Garmin BaseCamp.app
	unrarpro2.app
	Garmin MapManager.app
	GoPro Quik.app
	Adobe Acrobat Reader DC.app
	zoom.us.app
	P-touch Update Software / .. children: 1
	SuuntoDM5.app
	CCleaner.app
	Total Video Converter Lite.app
	Applications
	WeTransfer.app
	The Unarchiver.app
	Movavi Photo Editor 5.app
	Skype.app
	Firefox.app
	Air Printer Lite - Print to Any Printer.app
	Garmin MapInstall.app
	TotalAV.app
	Battery Health 2.app
	Garmin Express.app
 /Library:
	Apple / .. children: 3
	DropboxHelperTools / .. children: 3
	OSAnalytics / .. children: 1
	DataSave / .. children: 2
	StagedDriverExtensions / .. children: 0
	naphthol-sneap / .. children: 1
	CoreAuditDaemon / .. children: 0
	InstallerSandboxes / .. children: 2
	KernelCollections / .. children: 2
	User Template / .. children: 41
	societism.ep / .. children: 0
	instance
	4JHPd / .. children: 2
	lhvZzJJk / .. children: 1
	.U63yc
	SystemExtensions / .. children: 4
	com.piriform.ccleaner / .. children: 3
	CineForm / .. children: 3
	Macromedia / .. children: 3
	Corel / .. children: 2
	P-touch Editor / .. children: 2
	CELSYS / .. children: 1
	Adobe / .. children: 49
	Canon_Inc_IC / .. children: 2
	regid.1986-12.com.adobe / .. children: 4
 /Library/Extensions:
	FTDIUSBSerialDriver.kext
	AppleMobileDevice.kext
	NikeSportWatch.kext
	AdobeAAMDetect.plugin
	AdobePDFViewer.plugin
	AdobePDFViewerNPAPI.plugin
	JavaAppletPlugin.plugin
	PepperFlashPlayer / .. children: 0
 /Library/Managed Preferences:
	us.zoom.ZoomDaemon
 /Library/ScriptingAdditions:
	Adobe Unit Types.osax
 /Library/StartupItems:
 /Library/Updates:
	ProductMetadata.plist
	index.plist
Top Processes:
%CPU	PID	COMMAND
12.7 	141		WindowServer
3.5		0		kernel_task
2.9		1285		DetectX Swift
1.9		565		gamecontrollerd
0.2		527		net.protected.ma
0.1		481		Dropbox
tblu13
Allego screen shot dei problemi rilevati.
Schermata 2022-07-06 alle 10.08.04.jpg (241.32 KiB) Visto 805 volte
Alberto.G
La mia segnalazione di maggio vedo che ha dato dei risultati!
Consiglio subito di eliminare quei 5 elementi o file che DetectX ha evidenziato; li puoi eliminare con la stessa app come ben segnalato.
Sono elementi considerati comunque dannosi per il buon funzionamento del Mac per cui è bene non averli in macchina.
Altra cosa che vedo sono altre app antivirus che hai installato; vedi
- macpaw.CleanMyMac4
- CCleaner
per cui ti consiglio di eliminarle subito: cestino e poi utilizzo dell’app EasyFind per cercare eventuali residui di file rimasti ancora in macchina.
Vedo che non hai EasyFind per cui la prendi da questo link
https://www.devontechnologies.com/apps/freeware
Fatte le suddette eliminazioni, devi prima RIAVVIARE il Mac e poi eseguire ancora DetectX per verificare che non ci siano più le presenze sia di elementi dannosi che di antivirus.
Tieni sempre presente che le app antivirus, le app di pulizia e i software di sicurezza di terze parti, tutti tanto “decantati”, non sono necessari su un Mac e di solito causano più problemi di quanti ne risolvano ed influiscono poi, negativamente, sulle prestazioni.
tblu13
panic(cpu 0 caller 0xffffff80172d0860): nvme: "Fatal error occurred. CSTS=0x1 US[1]=0x0 US[0]=0x1a VID=0xc0a9 DID=0x540a
. FW Revision=P2CR033\n"@/System/Volumes/Data/SWE/macOS/BuildRoots/880a0f6e74/Library/Caches/com.apple.xbs/Sources/IONVMeFamily/IONVMeFamily-557.120.1/Common/IONVMeController.cpp:5499
0xffffffa0816eb960 : 0xffffff8014a8b26d
0xffffffa0816eb9b0 : 0xffffff8014bd2993
0xffffffa0816eb9f0 : 0xffffff8014bc2f8a
0xffffffa0816eba40 : 0xffffff8014a2fa2f
0xffffffa0816eba60 : 0xffffff8014a8aa8d
0xffffffa0816ebb80 : 0xffffff8014a8ad83
0xffffffa0816ebbf0 : 0xffffff801529c5fa
0xffffffa0816ebc60 : 0xffffff80172d0860
0xffffffa0816ebc80 : 0xffffff80172b545b
0xffffffa0816ebde0 : 0xffffff80151f31d5
0xffffffa0816ebe50 : 0xffffff80151f30d6
0xffffffa0816ebe80 : 0xffffff8014ad1985
0xffffffa0816ebef0 : 0xffffff8014ad28f4
0xffffffa0816ebfa0 : 0xffffff8014a2f13e
         com.apple.iokit.IONVMeFamily(2.1)[A1753019-2266-3C90-B5B2-7F8E2370CDA0]@0xffffff80172ae000->0xffffff80172d7fff
            dependency: com.apple.driver.AppleEFINVRAM(2.1)[B20DB0B8-D6EC-3C32-91FD-69F48F11D71B]@0xffffff8015efe000->0xffffff8015f07fff
            dependency: com.apple.driver.AppleMobileFileIntegrity(1.0.5)[30D95038-46A0-3115-8909-B80F1D9E5F40]@0xffffff80160c0000->0xffffff80160d5fff
            dependency: com.apple.iokit.IOPCIFamily(2.9)[4169693C-CDDE-3CA7-800A-F665762B5B4C]@0xffffff801756c000->0xffffff8017594fff
            dependency: com.apple.iokit.IOReportFamily(47)[4E7E4EDD-1B85-3EC1-93BF-C3A713EB6DDF]@0xffffff80175a3000->0xffffff80175a5fff
            dependency: com.apple.iokit.IOStorageFamily(2.1)[12E52DC2-DD26-3C9A-94CD-07C7732363A7]@0xffffff801766f000->0xffffff8017680fff
Mac OS version:
20G630
Kernel version:
Darwin Kernel Version 20.6.0: Tue Apr 19 21:04:45 PDT 2022; root:xnu-7195.141.29~1/RELEASE_X86_64
Kernel UUID: 76569598-07D6-3661-974C-6C024B198E5B
KernelCache slide: 0x0000000014800000
KernelCache base:  0xffffff8014a00000
Kernel slide:      0x0000000014810000
Kernel text base:  0xffffff8014a10000
__HIB  text base: 0xffffff8014900000
System uptime in nanoseconds: 74852395479
  Uptime  : 0x000000116d8d054d
  Wake    : 0x0000000000000000 0x000000026517c20f 0x0000000000000000
last started kext at 2217710683: |IO!BUSBDFU	8.0.5d7 (addr 0xffffff80171a7000, size 4096)
loaded kexts:
|IO!BUSBDFU	8.0.5d7
>!UTCButtons	256
>!UTCKeyboard	256
@BootCache	40
>!ARTC	2.0
>!AACPIButtons	6.1
>!AHPET	1.8
>!ASMBIOS	2.1
>!AACPIEC	6.1
>!AAPIC	1.7
|EndpointSecurity	1
>usb.!UHub	1.2
>!UMultitouch	264
>usb.cdc	5.0.0
>!ABSDKextStarter	3
|IOSurface	290.8.1
>!AXsanScheme	3
|IONVMe!F	2.1.0
|IOUSB!F	900.4.2
|IOSkywalk!F	1
>corecapture	1.0.4
>!A!ILpssGspi	3.0.60
>usb.!UXHCIPCI	1.2
>usb.!UXHCI	1.2
>!AEFINVRAM	2.1
>!AEFIRuntime	2.1
|IOSMBus!F	1.1
|IOHID!F	2.0.0
$!AImage4	3.0.0
|IOTimeSync!F	985.2
|IONetworking!F	3.4
>DiskImages	493.0.0
|IO!B!F	8.0.5d7
|IOReport!F	47
$quarantine	4
$sandbox	300.0
|CoreAnalytics!F	1
>!ASSE	1.0
>!AKeyStore	2
>!UTDM	511.141.1
|IO!S!F	2.1
@kext.CoreTrust	1
>!AFDEKeyStore	28.30
>!AEffaceable!S	1.0
>KernelRelayHost	1
|IOUSBHost!F	1.2
>usb.!UCommon	1.0
>!ABusPower!C	1.0
>!ASEPManager	1.0.1
>IOSlaveProcessor	1
>!AACPIPlatform	6.1
>!ASMC	3.1.9
|IOPCI!F	2.9
|IOACPI!F	1.4
>watchdog	1
@kec.pthread	1
@kec.Libm	1
tblu13
dopo aver eliminato TotalAV e CCleaner il problema del crush in avvio si ripropone....DetectX non rileva problemi.
avete altri consigli per individuare e risolvere il problema?
Ultima modifica di tblu13 il mar, 12 lug 2022 16:13, modificato 1 volta in totale.
joseterra
tblu13 ha scritto:
mer, 06 lug 2022 09:25
in genere, con SSD+adattatore, si hanno problemi di risveglio dall'ibernazione, ma anche incostanza di velocità di scrittura (anche lettura, ma meno) sul disco.
Se dopo aver tutto ciò che ti ha suggerito, correttamente, Alberto.G, il problema persistesse, proverei a rimettere la configurazione col disco originale per capire se avvenga comunque..in quel caso, il problema è verosimile che dipenda dalla combinazione SSD+Adattarore (nel senso che può esser il disco, come l'adattatore).
Però, fai prima ciò che ti ha suggerito Alberto.G
Qualche Hackintosh
Qualche PC Windows
