Aggiornamento Find Any File
Find Any File è stato aggiornato alla versione 1.8.5.
New Features:
By adding an item named "FindAnyFile" to your keychain, containing an admin user's name and password, FAF won't ask for your login any more when doing Find All.
Find All can now be made the default by issuing this command in Terminal: defaults write org.tempel.findanyfile AlwaysFindAll -bool YES
Can now search for the size of resource forks (available only in expert mode)
Adds Norwegian, Swedish and Czech localization.
Improvements:
Now excludes the files saved as Recent Searches from the results.
The collection of Recent searches can now be cleared and also entirely disabled in the preferences.
Copying results to the clipboard now includes all columns (separated by Tab characters), unless Shift or Option is held down when Copying.
Using Select All in the hierarchical view does not select the interim folders any more but only the actually searched items.
Improves sorting by paths by not taking the file name into account any more.
Bug fixes:
Fixes an issue with resizing columns directly after adding a column to the results list.
No more crash when opening a saved search (.faf) using the File/Open menu command.
No more crash when righting clicking on the path at the bottom of the Results window and then not choosing any of the options.
http://apps.tempel.org/FindAnyFile/" onclick="window.open(this.href);return false;
Oh graziA!
:D
Find Any File - 1.8.6b2
Improvements:
When using Quicklook, cmd+O now opens the viewed item.
Speeds up searching on network volumes, especially in "(slow)" mode (SMB, NAS).
Hidden files and folders now appear with a dimmed icon.
Bug fixes:
No more crash ("Runtime Error") when the "Recent Searches" folder or another searched folder is not readable.
Corrects filtering of hidden items when using the "Invisibles" show/hide/only options.
Find Any File - 1.8.7b7
Improvements:
Retina support.
"Special Folders" button in Preferences window allows permanent exclusion of volumes and folders from search, as well as suppressing "fast search" on problematic network volumes (certain NAS systems apply).
Bug fixes:
Adding additional search targets by dropping them with the Shift key held down now also works when a single volume is chosen so far.
Prevents accidentally deleting network files in FAF that had just been moved by the Finder (formerly, FAF did not refresh its lists for network volumes, and so would keep showing files in their old places, suggesting that the files were still there).
No more crash in "UITools.NewPictureFromPicWithMask".
Find Any File - 1.8.7b10
The shortcuts for the "Delete" commands in the Results menu work again with the Backspace key instead of the Forward Delete key.
Link alla beta:
http://files.tempel.org/FindAnyFile/betas/" onclick="window.open(this.href);return false;
Geniale
Geniale
Bella questa nuova icona!
Improvements:
Retina display support.
Search box in Results window now also works in hierarchical (tree) view.
New Special Folders button in Preferences window for excluding volumes and folders from search permanently.
The Reveal command works with Path Finder if it's set to be the default browser in its preferences.
New choices to limit or exclude Path and Folder Names.
Bug fixes:
No more crash when control-clicking into the list header to choose the shown columns.
mauropasha ha scritto:Bella questa nuova icona!
Sì, decisamente migliore della precedente (e in controtendenza, visto che mi sembra in 3D).
Find Any File - 1.8.8b1
Fixes a harmless crash under OS X 10.9 Mavericks when using "Find All", i.e. when searching with the Option key .
Pronta la versione definitiva di Find Any File 1.8.8!
Find Any File - 1.8.9b9
Localization updates (if you like to help, please use the Help menu to Context Support by E-Mail)
Fixes issues (lockups) with unavailable NFS network volumes.
File Icons are fully opaque again.
Makes sure windows appear on-screen when an external monitor gets detached.
Fixes an issue where refreshing the Results takes an unusually long time.
Solves an issue with OSX 10.10.2 where opening more than six items failed.
When searching a "slow" volume, its name is displayed in the Find window again.
Fixes issues with deleting items on a network volume.
If the command "Delete Immediately" or "Move to Trash" fails, an error message is displayed.
Deleting symlinks doesn't instead delete their destination any more.
Switching between flat and tree views now preserves the selection even if more than one item is selected.
The shortcuts Cmd-Shift-C and Cmd-Opt-C work again.
Fix for OSX 10.9 and later: Changing an item's Label removes all other Tags previously set on that item.
Fixes a few rare crash cases.
Uscito Find Any File 1.8.9b10. ;)
Find Any File - 1.8.9b11
Fixes a crash introduced in recent beta versions that could occur with temporary (disappearing) files.
tighine
Scusa, KP, a me quel link fa scaricare solo la versione 1.8.8: http://files.tempel.org.s3.amazonaws.co ... _1.8.8.zip" onclick="window.open(this.href);return false;
La 1.8.9b11 la vedo (e non si capisce se sia solo la storia delle versioni oppure c'é possibilità di download) solo sui siti macupdaters (http://www.macupdate.com/app/mac/30079/ ... on-history#" onclick="window.open(this.href);return false;).
(A me viene fuori solo così, e per trovarla ho dovuto espressamente cercare con il testo: Find Any File 1.8.9b11)
Torna a “Aggiornamenti”
