Aggiornamento Cocktail
Oggetto del messaggio: Re: Aggiornamento Cocktail
Messaggio Inviato: mar, 29 nov 2016 18:20
Cocktail - 10.1.2
Added ability to customize the layout - change the number of rows and columns of icons - of Launchpad (Interface - Misc)
Addresses an issue in which Cocktail may fail to display Time Machine log (System - Time Machine)
Addresses an issue in which Cocktail may fail to delete items from encrypted disk images (System - Trash)
Resolves a number of other issues discovered in the previous release
Updated Help files.
http://www.maintain.se/cocktail/" onclick="window.open(this.href);return false;
Messaggio Inviato: mer, 14 dic 2016 21:14
Cocktail - 10.1.3
Added ability to clear Siri caches
Added ability to prevent Photos from launching automatically when a device is connected (Interface - Misc)
Added macOS Sierra 10.12.2 compatibility
Updated Automator actions
Updated Help files.
Messaggio Inviato: mar, 03 gen 2017 17:03
Cocktail - 10.1.4
Cocktail 10.1.4 (Sierra Edition) for users running macOS Sierra has been released. Here are the release notes for this version:
Improvements on the "Delete localization files" procedure
Fixed compatibility issues with Logic Pro X audio units plug-ins
Fixed a bug in which network optimization for Fiber connection type could not be applied
Fixed a bug in which some items in /private/tmp folder were not deleted during clearing of the temporary files
Addresses an issue in which Cocktail may unexpectedly quit while rebuilding XPC helper agent caches
Addresses an issue in which Cocktail may report problems with srm utility
Addresses an issue in which Cocktail don't work properly if the System Events process is not running
Addresses an issue in which Cocktail could not force empty the Trash, error -362 (The Trash contains more than 2000 items)
Addresses an issue in which Pilot scheduler could not be enabled, error -114 (Home directory not found in the /Users folder)
Overall performance improvements.
Messaggio Inviato: mar, 24 gen 2017 20:26
Cocktail - 10.2
Cocktail 10.2 (Sierra Edition) for users running macOS Sierra has been released. Here are the release notes for this version:
Added ability to clear sandbox caches
Improvements on the "Clear system caches" procedure
Improvements on the "Clear applications caches" procedure
Fixed iCloud Drive synchronization bug
Added macOS Sierra 10.12.3 compatibility
Updated Help files.
Messaggio Inviato: gio, 09 feb 2017 16:46
Cocktail - 10.2.1
Cocktail 10.2.1 (Sierra Edition) for users running macOS Sierra has been released. Here are the release notes for this version:
Added support for unified logging
Improvements on the "Clear log files" procedure
Fixed compatibility issues with Adobe Flash Player
Updated Help files.
Messaggio Inviato: mer, 15 feb 2017 17:47
Cocktail - 10.2.2
Cocktail 10.2.2 (Sierra Edition) for users running macOS Sierra has been released. Here are the release notes for this version:
Added ability to clear WebKit caches
Added support for additional (en5-en8) network interfaces
Improvements on the "Optimize network" procedure
Updated Help files.
Messaggio Inviato: mer, 01 mar 2017 19:20
Cocktail - 10.3
Cocktail 10.3 (Sierra Edition) for users running macOS Sierra has been released. Here are the release notes for this version:
Added ability to quit Finder by adding "Quit" item to Finder menu (Interface - Finder)
Added ability to disable animation when hiding or showing Dock (Interface - Dock)
Added ability to change default page zoom for Safari (Interface - Safari)
Added ability to auto-activate Terminal windows by mouse cursor (Interface - Misc)
Addresses an issue in which Cocktail may fail to restart dynamic pager daemon when run on a beta version of macOS Sierra 10.12.4
Added macOS Sierra 10.12.4 compatibility
Minor user interface improvements
Updated Help files.
Messaggio Inviato: ven, 24 mar 2017 04:31
Cocktail - 10.3.1
Cocktail 10.3.1 (Sierra Edition) for users running macOS Sierra has been released. Here are the release notes for this version:
New feature: "Show this computer when browsing the network" (Network - File Sharing)
New feature: "Hide Quick Look panel when put in the background" (Interface - Finder)
New feature: "Scroll while hovering over an icon to reveal app windows" (Interface - Dock). While hovering over an app icon in the Dock, use the scroll wheel on the mouse, or use the scroll gesture on the trackpad to reveal all the windows in the app. When enabled, this setting will also let you use the same method to activate any stack in the Dock.
Addresses an issue in which Cocktail may fail to create a Keychain key
Added support for more localizations (.lproj language codes)
Updated Help files.
Messaggio Inviato: gio, 13 apr 2017 18:18
Cocktail - 10.3.2
Cocktail 10.3.2 (Sierra Edition) for users running macOS Sierra has been released. Here are the release notes for this version:
Added ability to disable caching in Safari (Interface - Safari)
Added ability to show "Other…" (users) button in the login window (Interface - Login)
Added ability to enable dark mode in Spotlight (System - Spotlight)
Fixed an issue where few settings were non-persistent
Further improved compatibility with macOS Sierra
Other stability improvements and bug fixes
Updated Help files.
Messaggio Inviato: gio, 11 mag 2017 16:57
Cocktail - 10.3.3
Cocktail 10.3.3 (Sierra Edition) for users running macOS Sierra has been released. Here are the release notes for this version:
Fixed some compatibility issues with System Integrity Protection and EtreCheck
Reduced CPU load
Fixed a bug which caused a kernel panic in some rare cases
Added macOS Sierra 10.12.5 compatibility
Other bug fixes and improvements
Updated Help files.
Messaggio Inviato: gio, 01 giu 2017 19:01
Cocktail - 10.3.4
Cocktail 10.3.4 (Sierra Edition) for users running macOS Sierra has been released. Here are the release notes for this version:
Added ability to show heat map in "Year" view in Calendar (Interface - Misc). Shows an increasingly red heat map for busier days when in "Year" view.
Added ability to disable checking for updates for connected devices in iTunes (Interface - Misc). Prevents iTunes from automatically checking for upgrades for connected devices (iPhones, iPads, etc).
Added ability to easily access Common Unix Printing System (Utilities menu)
Updated Help files.
Messaggio Inviato: gio, 15 giu 2017 15:56
Cocktail - 10.3.5
Cocktail 10.3.5 (Sierra Edition) for users running macOS Sierra has been released. Here are the release notes for this version:
Added ability to clear autosave information (Caches - Applications)
Added macOS Sierra 10.12.6 compatibility
Updated Help files.
Messaggio Inviato: mer, 05 lug 2017 18:17
Cocktail - 10.4
Cocktail 10.4 (Sierra Edition) for users running macOS Sierra has been released. Here are the release notes for this version:
Added ability to perform essential system maintenance with a click of a button, without any need to configure even a single option
Added Safari 11 compatibility
Other bug fixes and interface improvements.
Messaggio Inviato: gio, 20 lug 2017 18:26
Cocktail - 10.4.1
Cocktail 10.4.1 (Sierra Edition) for users running macOS Sierra has been released. Here are the release notes for this version:
Added clearing of the WebKit caches to the "Perform essential system maintenance" procedure
Improvements on the "Clear Internet caches" procedure
Added compatibility with the latest versions of supported web browsers
Other minor bug fixes
Updated Automator actions.
Messaggio Inviato: mer, 09 ago 2017 17:44
Cocktail - 10.4.2
Cocktail 10.4.2 (Sierra Edition) for users running macOS Sierra has been released. Here are the release notes for this version:
Addresses an issue in which Cocktail may fail to restart or shut down computer after performing essential system maintenance
Fixed compatibility issues with upcoming Cocktail (High Sierra Edition)
Addresses an issue in which Cocktail may disable Switch Control
Improvements on the "Search for corrupted preference files" procedure
Corrected a problem where Cocktail could show an error message regarding the Keychain key when launching for the first time
