Suspicious Package - per chi disabilita il gatekeeper
Suspicious Package 3.5.2
4.3MB
http://www.mothersruin.com/software/SuspiciousPackage/
macOS 10.13+
Sistemi precedenti sul sito, da Leopard+.
Novità in 3.5.2:
Ongoing attempts to improve behavior on macOS 10.15 (Catalina).
Fixed a crash that might occur when the installer scripts contain empty property list or strings files (such as inside an app bundled along with the scripts).
Improved the handling of XML-format property lists and text-format strings files inside the installer scripts: these are more reliably displayed directly by Suspicious Package, instead of requiring that you open them in another app
Suspicious Package 3.5.3
dmg 4.3MB
7.8MB su disco
macOS 10.13+
Novità in 3.5.3:
The Receipts tab (added in version 3.5) is now visible automatically.
Previously, it would be added only when you clicked on the Previously Installed line in the Package Info tab.
Or used Window > Receipts, but this proved difficult to discover.
If you find this annoying and want to go back to the previous behavior, turn off Preferences > General > Show Receipts tab.
Added File > Show Package in Finder (Cmd-Option-R)
Added Edit > Copy Path for Package (Cmd-Option-C)
When exporting a file or folder, you can now prevent Suspicious Package from stripping off any access control lists that were defined by the package.
Normally, we strip these by default, because the ACLs might prevent the exported item from being removed again, which can be confusing. But if you know what you're doing, you might want to inhibit this. You can either:
Use File > Export Item, and uncheck Remove any access controls from exported items before clicking Save.
Use the AppleScript export command, adding without access controls removed
Added AppleScript support for specifying the target macOS version, i.e. for proper interpretation of packages that use a writable startup volume folder.
You can use something like open file "X.pkg" for installing to macOS 10.15
quadret
scusate per la domanda ingenua
io uso pacifist e riesco a vedere cosa c'è dentro il pkg e non solo in quello, questo sospicious package è uguale oppure segnala che il pkg ha un malware?
quadret
ok
allora lo installo
che tu sappia ve bene anche per i dmg?
grazie
Torna a “Aggiornamenti”
