Hammarby
- Unix Expert
...e spesso peggio.
Cervantes
MrZyc
- Pietra Miliare Maccanica
speriamo che risolvano il problema.
Zen
- Unix Expert
Per il momento:
In some cases, you can undo the damage yourself. If you have a Mac, and the message was sent by another Apple user via the iMessage service, simply open the offending conversation in the Messages app and send another reply — even "hi" will do. If your only Apple product is an iPhone, you can either send the person who sent the string a message using the share sheet — the box that appears after pressing the "share" button in other apps — or open Siri and ask it to "send [whoever sent it] a message."
404
- Maccanico attivo
MrZyc ha scritto:speriamo che risolvano il problema.
Speriamo non subito, ho un paio di scherzetti da inviare!
MrZyc
buon divertimento
mauripucci
per ora non esistono soluzioni se non:
Update: Crashing Messages App Fix
If you are experiencing issues while trying to open the messages app, you are not alone. Here’s how to fix it. There are several methods to choose from because the issue can be solved by by clearing the power message from the last line of the message.
Method 1: Open Notes, and create a new note with any text you like. Tap the Share button in the top-right, and send it to the message that contains the power message. After it is sent, relaunch Messages, and it will work.
Method 2: Use Siri to send anything you like to the message that contains the power message to clear it from the last line of the message.
Other Methods: Any other method will work so solve this problem as long as it involves sending a message. Sending a photo from the Photos app or a contact from the Contacts app will also work.
Not working? If you don’t remember who sent the power message, just make a backup of your device and use an application such as iExplorer for Mac and Windows to identify the message from your computer. Then reply to it using one of the previous methods. If you have a Mac, you can simply use the Messages app to find the message and reply to it. The power message has no effect on Mac.
Still not working? Contact us after you have tried all of these methods, and we will find a solution for you.
According to an Apple Senior Advisor, Apple has been inundated with calls about the issue and their engineering team is working on a solution.
http://www.theapplebyte.info/2015/05/26 ... o-restart/" onclick="window.open(this.href);return false;
INCREDIBILE, funziona!
- Pestifero
È dall'una di stanotte che è diventato il mio gioco preferito!
https://instagram.com/p/3Nvb0bO-2p/" onclick="window.open(this.href);return false;
- Pestifero
Forza, inviamolo tutti a tutti ed iniziamo una piccola rivoluzione.
Chissà mai che ci prendiamo gusto e che sia l'inizio.
Zen
- Unix Expert
Comunque è un bug di iMessage e si verifica quindi solo tramite questo. Non funziona tramite sms.
Sicuro? Anche Instagram si chiude se incolli il codice. Quindi anche tramite SMS.
Zen
- Unix Expert
Sicuro no, è quello che ho letto ieri sera
- Pestifero
Sono tentatissimo!!!
Non lo mando solo perché poi mi toccherebbe andare a casa di tutti a sistemargli il problema
Il futuro (Apple)? Nammerda!
Visitano il forum: Nessuno e 17 ospiti
