Aggiornamenti Terze Parti vari
Etcher 1.4.5
OS X 10.9 Mavericks+
Dmg 93.5MB
257.8MB su disco
https://etcher.io
https://github.com/resin-io/etcher
Etcher è una semplice applicazione multipiattaforma per creare una chiavetta usb o scheda SD con un'installazione avviabile di Linux.
Sarà possibile così usare una ISO di una distribuzione Linux senza installarla sul disco o virtualizzarla.
Pur essendo multipiattaforma, qui presento la versione per OS X/macOS.
Il funzionamento è elementare, come si vede nella gif:
C'è anche una versione sperimentale CLI dell'utilità
https://etcher.io/cli/
Istallazione macOS o GNU/Linux:
Extract the .tar.gz package by running:
tar fvx path/to/cli.tar.gz
Move the resulting directory to /opt/etcher-cli.
Add /opt/etcher-cli to the PATH. For example, add the following to .bashrc or .zshrc:
export PATH="$PATH:/opt/etcher-cli"
Novità nella 1.4.5:
Center content independent to window resolution.
Add electron-native file-picker component.
Hide unsafe mode option toggle with an env var.
Use new design background color and drive step size ordering.
Add a convenience Storage class on top of localStorage.
Introduce env var to toggle autoselection of all drives.
Add font-awesome.
Add support for configuration files
Use GTK-3 darkTheme mode.
Add environment variable to toggle fullscreen.
Allow blacklisting of drives through and environment variable ETCHER_BLACKLISTED_DRIVES.
Show selected drives below drive selection step.
Add a button to cancel the flash process.
Download usbboot drivers installer when clicking a driverless usbboot device on Windows.
Allow disabling links and hiding help link with an env var.
Fixes
Add "make webpack" to travis-ci build script
Makefile: Don't use tilde in rpm versions
Change Spectron port so not to overlap with other builds
Fix multi-writes analytics by reusing existing logic in multi-write events.
Load usbboot adapter on start on GNU/Linux if running as root.
Misc
Update drivelist to v6.4.2
Add instructions for installing and uninstalling on Solus
Sync Folders 3.4.6
OS X 10.7 Lion+
2.8MB da App Store
Aggiornamento 896KB
4.6MB su disco
https://itunes.apple.com/it/app/sync-fo ... 3877?mt=12
È un sincronizzatore di cartelle facile da usare per i principianti.
Sincronizzare un paio di cartelle in modo manuale o automatico, istantaneamente.
Ci sono anche strumenti per filtrare i documenti in modo da sincronizzare esattamente quello si vuole.
Anche montagne di dati.
Le cartelle di sincronizzazione possono essere usate per i backup in tutte le destinazioni.
USB, schede DS, in remoto anche VPN (con app a parte), sui servizi Cloud (Dropbox ecc.)
La sincronizzazione è bidirezionale programmabile.
C'è anche la versione Pro, attenzione a non cliccarla se non la si vuole!
Novità in 3.4.6:
- Aggiunto il supporto Mojave Dark Mode
- Migliore compatibilità Mojave
utente_autoeliminato
Oggetto del messaggio: Re: Aggiornamenti Terze Parti vari
LightsOff 1.0.6
https://www.lightsoff-app.com/
Piccola applicazione gratuita che permette di scegliere quali programmi avere in Dark Mode se si usa l'aspetto chiaro.
Se si utilizza l'aspetto Dark Mode - fa il contrario - permette di scegliere quali programmi avere in Light Mode
Di semplice utilizzo, adatta a chi non vuole avere tutto chiaro o tutto nero.
Tor Browser Bundle 8.0.3
Dmg 64.2MB dmg - localizzato in lingua italiana
Aggiornamento 50.5MB
154.2MB su disco
È un Tor Bundle, già pronto su una versione di Firefox preparata per l’uso.
Il popolare software Tor assicura l’anonimato delle comunicazioni attraverso una rete distribuita di relay, gestiti da volontari in tutto il mondo.
Impedisce a chiunque di monitorare la connessione Internet e di conoscere quali siti vengono visitati,.
Impedisce ai siti visitati da rilevare la locazione e qualsiasi altro dato del visitatore.
Consente di accedere a siti che sono bloccati.
Tor Browser Bundle è multipiattaforma, non necessita di altro software ed è pronto per essere utilizzato.
Può essere installato ed usato anche su una chiavetta usb, quindi portatile.
https://www.torproject.org/projects/torbrowser.html.en
https://blog.torproject.org/new-release-tor-browser-803
Ora gli aggiornamenti vengono fatti senza avviso, in sottofondo tramite il canale Aurora, come in Firefox Quantum Developer
La visualizzazione del circuito Tor è stata spostata e migliorata.
Cliccando il pulsante di identità del sito (posto a sinistra dell'URL) si vedrà il nuovo circuito.
Cos'è la visione circuito:
Immagine. Immagine
Novità in 8.0.3:
Update Firefox to 60.3.0esr
Update Torbutton to 2.0.8
Blackmagic Disk Speed 3.2
Disk Speed Test è uno strumento facilissimo da usare per misurare e certificare le prestazioni del disco.
Utile per lavorare con video di alta qualità in modo rapido
Su App Store
dmg 16.8MB
32.2MB su disco
OS X Yosemite 10+ (era OS X 10.6 Snow Leopard+)
https://itunes.apple.com/us/app/id425264550?mt=12
Novità nella versione 3.2:
Improve UI to support faster disks
Telegram Swift 4.5.1
https://rink.hockeyapp.net/apps/6ed2ac3 ... ffcb74e81f
Versione nativa di Telegram Messenger per MacOS.
In questa versione si alternano alfa, beta e stabili, senza problemi funzionali.
È la versione più aggiornata basata sul linguaggio Swift 3.
OS X 10.11 El Capitan+
25.6MB aggiornamento da app e dmg
65.7MB su disco
Esistono separate edizioni per 10.6 e 10.7 nelle versioni classiche.
Le altre versioni per Mac (capito Matt?):
Telegram Desktop
https://desktop.telegram.org
Telegram Messenger LLP su App Store
https://itunes.apple.com/us/app/telegra ... d946399090
Sorgenti
https://github.com/overtake/TelegramSwift
Estrema sicurezza e inviolabilità dei contenuti condivisi fra gli utenti.
Le chat cifrate appaiono essere blindate.
Per questo Telegram è stato proibito in qualche paese.
In Russia, suo paese d'origine, in Turchia.
Perché non rilascia le chiavi d'accesso anche a richiesta di polizia e magistratura.
Attualmente è il canale di diffusione di Daesh - al-Baghdādī
Novità in 4.5.1:
Now you can send whole folders (or packages) as archive! (Is automatically archiving before sending)
faxus ha scritto:
mer, 24 ott 2018 23:30
:-D
Pingus
Synchronize Files and Folders
sito ufficiale FreeFileSync: https://freefilesync.org/
download FreeFileSync: https://freefilesync.org/download.php
link diretto download FreeFileSync: https://freefilesync.org/download/FreeF ... _macOS.zip
faq FreeFileSync: https://freefilesync.org/faq.php
video tutorial FreeFileSync: https://freefilesync.org/tutorials.php
screenshots FreeFileSync: https://freefilesync.org/screenshots.php
FreeFileSync: Folder Comparison and Synchronization
by FreeFileSync
https://youtu.be/811ujCTbUAQ
canale FreeFileSync: https://www.youtube.com/channel/UC5_ehf ... OcvcGJnYVA
Zacksit
Expert Translator
Expert Translator
65.7MB su disco
Telegram Desktop
Ovviamente non sono Matt :D , ma non ho capito bene la differenza fra la versione Swift e la Desktop. L'altro giorno ho ricevuto l'avviso di aggiornamento di Telegram Desktop (ho OS X 10.11 El Capitan) che ho eseguito. Dovrei disinstallarla e installare Telegram Swift?
Pingus
Zacksit ha scritto:
gio, 25 ott 2018 11:32
devi farti aggiungere al gruppo iMaccanici su Telegram :D
Una è identica alla versione Windows e funziona così così. Serve per chi salta da un SO all'altro.
L'altra è stata scritta rispettando le regole di programmazione della Apple e funziona bene.
Non mi ricordo (*) quale è una e quale è l'altra, ma sul sito di Telegram c'è scritto.
Opinione personale: trovo che mettere a disposizione due applicazioni che generano solo confusione invece di una sola, sia una cosa molto stupida.
(*) Non uso Telegram, semplicemente perché, per ora, non ho nessuno con cui comunicare tramite Telegram.
Zacksit
Expert Translator
Expert Translator
Pingù ha scritto:
gio, 25 ott 2018 12:26
Ho difficoltà a seguire il forum, non credo che avrei tempo per seguire imaccanici anche su Telegram.
Paolofast ha scritto:
gio, 25 ott 2018 15:32
Sono d'accordo, c'è abbastanza confusione per i non addetti. Er.. veramente anch'io non ho nessuno con cui comunicare con Telegram. L'unica altra persona con cui comunicavo l'ha abbandonato perché ero l'unica persona fra i suoi contatti che ce l'aveva. L'ho tenuta perché seguo i messaggi delle agenzie ONU per lavoro.
GraziA
Telegram Swift è solo per macOS.
Lo dice la parola stessa.
lo uso su High Sierra, è perfetto.
Uso Telegram Messenger su Android 7.
Oggi li usati entrambi in modo intenso, come molti sanno, senza sbavature
Ovviamente non sono Matt :D , ma non ho capito bene la differenza fra la versione Swift e la Desktop ....
Io - che non li uso, come non uso Whatsapp - penso che siano la stessa cosa, poi va' a capire .....
Zacksit
Expert Translator
Expert Translator
faxus ha scritto:
gio, 25 ott 2018 17:49
Veramente per me non era così ovvio dal nome perché non sapevo che Swift fosse un linguaggio di programmazione di mamma Apple.
GraziA anche te per la spiegazione.
Torna a “Aggiornamenti”
