Vi incollo il Log
Mar 22 12:08:57 localhost opendirectoryd[186]: [default] Failed to open file <private> [2: No such file or directory]
Mar 22 12:09:01 localhost opendirectoryd[186]: [default] Failed to open file <private> [2: No such file or directory]
Mar 22 12:09:03 localhost opendirectoryd[186]: [default] Failed to open file <private> [2: No such file or directory]
Mar 22 12:09:04 localhost opendirectoryd[186]: [default] Failed to open file <private> [2: No such file or directory]
Mar 22 12:09:10 localhost opendirectoryd[186]: [default] Failed to open file <private> [2: No such file or directory]
Mar 22 12:09:11 localhost opendirectoryd[186]: [session] failed to open local node for internal record copy
Mar 22 12:09:17 localhost Installer Progress[181]: Progress UI App Starting
Mar 22 12:09:30 localhost opendirectoryd[186]: [session] time: 17.753 - excessive time in seconds
Mar 22 12:09:41 MacBook-Pro launchprogresswindow[546]: ISAP: Show progress UI called
Mar 22 12:10:39 MacBook-Pro Installer Progress[181]: IASGetCurrentInstallPhaseList: phases = (
ConclusionDelay = 0;
InstallPhase = "IOKit Boot";
InstallPhasePercentageKey = 80;
ConclusionDelay = "-1";
InstallPhase = "loginwindow Boot";
InstallPhasePercentageKey = 20;
Mar 22 12:10:39 MacBook-Pro Installer Progress[181]: IASGetCurrentInstallPhase: Current phase name is "loginwindow Boot"
Mar 22 12:10:39 MacBook-Pro Installer Progress[181]: phaseName = loginwindow Boot
Mar 22 12:10:39 MacBook-Pro Installer Progress[181]: _currentPhase = "<IASPPhase: 0x7f9ef5c15e70: 'loginwindow Boot', percentage 20.0, delay -1>", _phases = (
"<IASPPhase: 0x7f9ef5c15bf0: 'IOKit Boot', percentage 80.0, delay 0>",
Mar 22 12:10:39 MacBook-Pro Installer Progress[181]: _currentPhase = "<IASPPhase: 0x7f9ef5c15bf0: 'loginwindow Boot', percentage 20.0, delay -1>", _phases = (
"<IASPPhase: 0x7f9ef5c15bd0: 'IOKit Boot', percentage 80.0, delay 0>",
Mar 22 12:10:40 MacBook-Pro Installer Progress[181]: Progress app is loading…
Mar 22 12:10:40 MacBook-Pro Installer Progress[181]: Progress app is running…
Mar 22 12:10:40 MacBook-Pro Installer Progress[181]: Showing Progress UI
Mar 22 12:10:41 MacBook-Pro Installer Progress[181]: There are 0 window(s) and 1 display(s), 1 window(s) will be added
Mar 22 12:10:42 MacBook-Pro Installer Progress[181]: IOProgressColorTheme is set to 1
Mar 22 12:10:42 MacBook-Pro Installer Progress[181]: Created a window at {{0, 0}, {1440, 900}}
Mar 22 12:10:46 MacBook-Pro Installer Progress[181]: Status is ""
Mar 22 12:10:46 MacBook-Pro Installer Progress[181]: Alternate status is ""
Mar 22 12:10:48 MacBook-Pro Installer Progress[181]: Setting window alpha values to 0.0
Mar 22 12:10:48 MacBook-Pro Installer Progress[181]: Ordering windows front
Mar 22 12:10:48 MacBook-Pro Installer Progress[181]: Setting window alpha values to 1.0
Mar 22 12:10:53 MacBook-Pro Unknown[550]: 2019-03-22 12:10:53.539 Language Chooser[549:6359] NSDisabledCharacterPaletteMenuItem=YES
Mar 22 12:10:53 MacBook-Pro Unknown[550]: 2019-03-22 12:10:53.554 Language Chooser[549:6359] TISFileInterrogator updateSystemInputSources false but old data invalid: currentCacheHeaderPtr nonNULL? 0, ->cacheFormatVersion 0, ->magicCookie 00000000, inputSourceTableCountSys 0
Mar 22 12:10:53 MacBook-Pro Unknown[550]: Keyboard Layouts: duplicate keyboard layout identifier -14934.
Mar 22 12:10:53 MacBook-Pro Unknown[550]: Keyboard Layouts: keyboard layout identifier -14934 has been replaced with -28673.
Mar 22 12:10:53 MacBook-Pro Language Chooser[549]: Setup: Factory cable attached: 0
Mar 22 12:10:53 MacBook-Pro Unknown[550]: Setting boot completed.
Mar 22 12:10:53 MacBook-Pro Unknown[550]: 2019-03-22 12:10:53.807 Language Chooser[549:6359] unable to obtain configuration from file:///Library/Preferences/com.apple.ViewBridge.plist due to Error Domain=NSCocoaErrorDomain Code=260 "The file “com.apple.ViewBridge.plist” couldn’t be opened because there is no such file." UserInfo={NSFilePath=/Library/Preferences/com.apple.ViewBridge.plist, NSUnderlyingError=0x7f88b1f01430 {Error Domain=NSPOSIXErrorDomain Code=2 "No such file or directory"}}
Mar 22 12:11:03 MacBook-Pro Language Chooser[549]: Could not read prev-lang:kbd to set keyboard.
Mar 22 12:11:04 MacBook-Pro Language Chooser[549]: ISAP: hide progress UI called
Mar 22 12:11:04 MacBook-Pro Installer Progress[181]: Hiding Progress UI
Mar 22 12:11:04 MacBook-Pro Installer Progress[181]: Setting window alpha values to 0.0
Mar 22 12:11:04 MacBook-Pro Installer Progress[181]: Ordering windows out
Mar 22 12:11:13 MacBook-Pro OSIESpringboard[570]: ISAP: hide progress UI called
Mar 22 12:11:13 MacBook-Pro OSIESpringboard[570]: Can not connect to /var/run/systemkeychaincheck.socket: No such file or directory
Mar 22 12:11:13 MacBook-Pro OSIESpringboard[570]: Failed to unlock login keychain.
Mar 22 12:11:17 MacBook-Pro Unknown[550]: 2019-03-22 12:11:17.263 macOS Utilities[570:37038] NSDisabledCharacterPaletteMenuItem=YES
Mar 22 12:11:17 MacBook-Pro Unknown[550]: 2019-03-22 12:11:17.337 macOS Utilities[570:37038] isPrefsCreateCacheFromEnabledAndDefaultInputSources - can't find anything from GetInputSourceEnabledPrefs, use defaultASCIIKeyLayoutDict = <CFBasicHash 0x7f88784037b0 [0x1136368f0]>{type = immutable dict, count = 3,
Mar 22 12:11:17 MacBook-Pro Unknown[550]: entries =>
Mar 22 12:11:17 MacBook-Pro Unknown[550]: 0 : <CFString 0x11d903b68 [0x1136368f0]>{contents = "InputSourceKind"} = <CFString 0x11d904528 [0x1136368f0]>{contents = "Keyboard Layout"}
Mar 22 12:11:17 MacBook-Pro Unknown[550]: 1 : <CFString 0x11d904568 [0x1136368f0]>{contents = "KeyboardLayout Name"} = <CFString 0x1136efeb8 [0x1136368f0]>{contents = "Italian - Pro"}
Mar 22 12:11:17 MacBook-Pro Unknown[550]: 2 : <CFString 0x11d904548 [0x1136368f0]>{contents = "KeyboardLayout ID"} = <CFNumber 0xdaa2f728f2fb0d93 [0x1136368f0]>{value = +223, type = kCFNumberSInt32Type}
Mar 22 12:11:17 MacBook-Pro Unknown[550]: }
Mar 22 12:11:19 MacBook-Pro Unknown[550]: 2019-03-22 12:11:19.093 macOS Utilities[570:37038] unable to obtain configuration from file:///Library/Preferences/com.apple.ViewBridge.plist due to Error Domain=NSCocoaErrorDomain Code=260 "Impossibile aprire il file “com.apple.ViewBridge.plist” perché non esiste." UserInfo={NSFilePath=/Library/Preferences/com.apple.ViewBridge.plist, NSUnderlyingError=0x7f8878543b40 {Error Domain=NSPOSIXErrorDomain Code=2 "No such file or directory"}}
Mar 22 12:11:19 MacBook-Pro Unknown[550]: 2019-03-22 12:11:19.559 macOS Utilities[570:37038] TISFileInterrogator updateSystemInputSources false but old data invalid: currentCacheHeaderPtr nonNULL? 0, ->cacheFormatVersion 0, ->magicCookie 00000000, inputSourceTableCountSys 0
Mar 22 12:11:19 MacBook-Pro Unknown[550]: Keyboard Layouts: duplicate keyboard layout identifier -14934.
Mar 22 12:11:19 MacBook-Pro Unknown[550]: Keyboard Layouts: keyboard layout identifier -14934 has been replaced with -28673.
Mar 22 12:11:25 MacBook-Pro Unknown[550]: 2019-03-22 12:11:25.191 Disk Utility[576:37506] NSDisabledCharacterPaletteMenuItem=YES
Mar 22 12:11:25 MacBook-Pro Unknown[550]: 2019-03-22 12:11:25.199 Disk Utility[576:37506] isPrefsCreateCacheFromEnabledAndDefaultInputSources - can't find anything from GetInputSourceEnabledPrefs, use defaultASCIIKeyLayoutDict = <CFBasicHash 0x7fc923f4c3c0 [0x10d7c48f0]>{type = immutable dict, count = 3,
Mar 22 12:11:25 MacBook-Pro Unknown[550]: entries =>
Mar 22 12:11:25 MacBook-Pro Unknown[550]: 0 : <CFString 0x1165b7b68 [0x10d7c48f0]>{contents = "InputSourceKind"} = <CFString 0x1165b8528 [0x10d7c48f0]>{contents = "Keyboard Layout"}
Mar 22 12:11:25 MacBook-Pro Unknown[550]: 1 : <CFString 0x1165b8568 [0x10d7c48f0]>{contents = "KeyboardLayout Name"} = <CFString 0x10d87deb8 [0x10d7c48f0]>{contents = "Italian - Pro"}
Mar 22 12:11:25 MacBook-Pro Unknown[550]: 2 : <CFString 0x1165b8548 [0x10d7c48f0]>{contents = "KeyboardLayout ID"} = <CFNumber 0x48e511b8827a7d41 [0x10d7c48f0]>{value = +223, type = kCFNumberSInt32Type}
Mar 22 12:11:25 MacBook-Pro Unknown[550]: }
Mar 22 12:11:25 MacBook-Pro Unknown[550]: 2019-03-22 12:11:25.684 Disk Utility[576:37506] unable to obtain configuration from file:///Library/Preferences/com.apple.ViewBridge.plist due to Error Domain=NSCocoaErrorDomain Code=260 "Impossibile aprire il file “com.apple.ViewBridge.plist” perché non esiste." UserInfo={NSFilePath=/Library/Preferences/com.apple.ViewBridge.plist, NSUnderlyingError=0x7fc923c66080 {Error Domain=NSPOSIXErrorDomain Code=2 "No such file or directory"}}
Mar 22 12:15:27 MacBook-Pro Unknown[550]: 2019-03-22 12:15:27.420 Disk Utility[576:38844] Connected to daemon. Language set to: Italian
Mar 22 12:15:27 MacBook-Pro Unknown[550]: 2019-03-22 12:15:27.581 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc92803f5a0: { Volume Name: "untitled" BSD Name: disk14 Mount point: /private/var/root/Library/Containers Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 560582C4-403B-3AFD-8304-DA431EAFE8D7}>
Mar 22 12:15:27 MacBook-Pro Unknown[550]: 2019-03-22 12:15:27.581 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc92803eac0: { Volume Name: "untitled" BSD Name: disk20 Mount point: /private/var/tmp/InstallerCookies Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 5B3DDA87-B63F-31E1-AB39-E5CBDE4FE268}>
Mar 22 12:15:27 MacBook-Pro Unknown[550]: 2019-03-22 12:15:27.581 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc928039120: { Volume Name: "untitled" BSD Name: disk8 Mount point: /private/tmp Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 4BBCC77D-0578-391E-BBDF-DDA46C726C11}>
Mar 22 12:15:27 MacBook-Pro Unknown[550]: 2019-03-22 12:15:27.581 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc928038f70: { Volume Name: "untitled" BSD Name: disk16 Mount point: /Library/Preferences/SystemConfiguration Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 1F70167B-BB6A-379D-8F08-2DB8B01AC9C1}>
Mar 22 12:15:27 MacBook-Pro Unknown[550]: 2019-03-22 12:15:27.581 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc928038600: { Volume Name: "untitled" BSD Name: disk11 Mount point: /private/var/folders Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 79CD98D5-CE85-37DC-A107-F394F99BFD04}>
Mar 22 12:15:27 MacBook-Pro Unknown[550]: 2019-03-22 12:15:27.582 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc923f1fc70: { Volume Name: "untitled" BSD Name: disk18 Mount point: /private/var/tmp/RecoveryTemp Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: A19FC28C-06C4-3EF7-BBFC-06C0B5CEF618}>
Mar 22 12:15:27 MacBook-Pro Unknown[550]: 2019-03-22 12:15:27.582 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc923f238b0: { Volume Name: "untitled" BSD Name: disk7 Mount point: /private/var/run Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: A4DB9F23-8569-3BC3-AC12-05ACD199A13C}>
Mar 22 12:15:27 MacBook-Pro Unknown[550]: 2019-03-22 12:15:27.582 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc923f069e0: { Volume Name: "untitled" BSD Name: disk13 Mount point: Not Mounted Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 89D1CD8B-6FAE-36E4-B8A7-F8095296E94E}>
Mar 22 12:15:27 MacBook-Pro Unknown[550]: 2019-03-22 12:15:27.583 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc923f3f9b0: { Volume Name: "untitled" BSD Name: disk6 Mount point: /private/var/tmp Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: E683FAD5-DF2A-3544-AE7C-4F21D89A3EA6}>
Mar 22 12:15:27 MacBook-Pro Unknown[550]: 2019-03-22 12:15:27.583 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc923f30b40: { Volume Name: "untitled" BSD Name: disk15 Mount point: /Library/Preferences Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 7FE0548D-1F39-3C7C-AE27-6E911D219C21}>
Mar 22 12:15:27 MacBook-Pro Unknown[550]: 2019-03-22 12:15:27.583 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc923f49470: { Volume Name: "untitled" BSD Name: disk10 Mount point: /private/var/db Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: AD69F7FF-E64E-3B84-8BD5-72BC608BCE6E}>
Mar 22 12:15:27 MacBook-Pro Unknown[550]: 2019-03-22 12:15:27.583 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc9283dad10: { Volume Name: "untitled" BSD Name: disk21 Mount point: /Library/Logs/DiagnosticReports Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: CE9B3DC8-D71A-36C0-AE7D-6F9FF7A9ADD4}>
Mar 22 12:15:27 MacBook-Pro Unknown[550]: 2019-03-22 12:15:27.584 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc9287097c0: { Volume Name: "untitled" BSD Name: disk5 Mount point: /Volumes Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: FF09294B-139E-3307-92AA-40A7D5B81859}>
Mar 22 12:15:27 MacBook-Pro Unknown[550]: 2019-03-22 12:15:27.584 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc9283d1090: { Volume Name: "untitled" BSD Name: disk17 Mount point: /Library/Keychains Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 7D08905B-D387-3C34-9C57-F95DD307ABFF}>
Mar 22 12:15:27 MacBook-Pro Unknown[550]: 2019-03-22 12:15:27.584 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc923d70480: { Volume Name: "untitled" BSD Name: disk12 Mount point: /private/var/root/Library Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: CC97A050-60F3-3E9F-886F-CD074E5BD980}>
Mar 22 12:15:27 MacBook-Pro Unknown[550]: 2019-03-22 12:15:27.584 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc923ee07b0: { Volume Name: "untitled" BSD Name: disk4 Mount point: /private/var/log Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: F97563F2-6A7F-39AB-8E04-E370A210513C}>
Mar 22 12:15:27 MacBook-Pro Unknown[550]: 2019-03-22 12:15:27.585 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc92803efc0: { Volume Name: "untitled" BSD Name: disk19 Mount point: /private/var/tmp/OSISPredicateUpdateProductTemp Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 31D9E99F-F829-3D25-9BD4-64DAB81C137F}>
Mar 22 12:15:27 MacBook-Pro Unknown[550]: 2019-03-22 12:15:27.585 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc92803fb60: { Volume Name: "untitled" BSD Name: disk9 Mount point: /System/Installation Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 1E9020DC-550C-3038-93C9-DE992DF6466C}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.383 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc92803f5a0: { Volume Name: "untitled" BSD Name: disk14 Mount point: /private/var/root/Library/Containers Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 560582C4-403B-3AFD-8304-DA431EAFE8D7}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.383 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc92803eac0: { Volume Name: "untitled" BSD Name: disk20 Mount point: /private/var/tmp/InstallerCookies Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 5B3DDA87-B63F-31E1-AB39-E5CBDE4FE268}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.383 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc928039120: { Volume Name: "untitled" BSD Name: disk8 Mount point: /private/tmp Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 4BBCC77D-0578-391E-BBDF-DDA46C726C11}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.384 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc928038f70: { Volume Name: "untitled" BSD Name: disk16 Mount point: /Library/Preferences/SystemConfiguration Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 1F70167B-BB6A-379D-8F08-2DB8B01AC9C1}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.384 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc928038600: { Volume Name: "untitled" BSD Name: disk11 Mount point: /private/var/folders Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 79CD98D5-CE85-37DC-A107-F394F99BFD04}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.384 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc923f1fc70: { Volume Name: "untitled" BSD Name: disk18 Mount point: /private/var/tmp/RecoveryTemp Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: A19FC28C-06C4-3EF7-BBFC-06C0B5CEF618}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.384 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc923f238b0: { Volume Name: "untitled" BSD Name: disk7 Mount point: /private/var/run Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: A4DB9F23-8569-3BC3-AC12-05ACD199A13C}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.385 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc923f069e0: { Volume Name: "untitled" BSD Name: disk13 Mount point: Not Mounted Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 89D1CD8B-6FAE-36E4-B8A7-F8095296E94E}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.385 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc923f3f9b0: { Volume Name: "untitled" BSD Name: disk6 Mount point: /private/var/tmp Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: E683FAD5-DF2A-3544-AE7C-4F21D89A3EA6}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.385 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc923f30b40: { Volume Name: "untitled" BSD Name: disk15 Mount point: /Library/Preferences Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 7FE0548D-1F39-3C7C-AE27-6E911D219C21}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.385 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc923f49470: { Volume Name: "untitled" BSD Name: disk10 Mount point: /private/var/db Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: AD69F7FF-E64E-3B84-8BD5-72BC608BCE6E}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.385 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc9283dad10: { Volume Name: "untitled" BSD Name: disk21 Mount point: /Library/Logs/DiagnosticReports Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: CE9B3DC8-D71A-36C0-AE7D-6F9FF7A9ADD4}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.386 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc9287097c0: { Volume Name: "untitled" BSD Name: disk5 Mount point: /Volumes Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: FF09294B-139E-3307-92AA-40A7D5B81859}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.386 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc9283d1090: { Volume Name: "untitled" BSD Name: disk17 Mount point: /Library/Keychains Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 7D08905B-D387-3C34-9C57-F95DD307ABFF}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.386 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc923d70480: { Volume Name: "untitled" BSD Name: disk12 Mount point: /private/var/root/Library Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: CC97A050-60F3-3E9F-886F-CD074E5BD980}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.386 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc923ee07b0: { Volume Name: "untitled" BSD Name: disk4 Mount point: /private/var/log Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: F97563F2-6A7F-39AB-8E04-E370A210513C}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.386 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc92803efc0: { Volume Name: "untitled" BSD Name: disk19 Mount point: /private/var/tmp/OSISPredicateUpdateProductTemp Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 31D9E99F-F829-3D25-9BD4-64DAB81C137F}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.387 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc92803fb60: { Volume Name: "untitled" BSD Name: disk9 Mount point: /System/Installation Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 1E9020DC-550C-3038-93C9-DE992DF6466C}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.414 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc92803f5a0: { Volume Name: "untitled" BSD Name: disk14 Mount point: /private/var/root/Library/Containers Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 560582C4-403B-3AFD-8304-DA431EAFE8D7}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.414 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc92803eac0: { Volume Name: "untitled" BSD Name: disk20 Mount point: /private/var/tmp/InstallerCookies Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 5B3DDA87-B63F-31E1-AB39-E5CBDE4FE268}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.414 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc928039120: { Volume Name: "untitled" BSD Name: disk8 Mount point: /private/tmp Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 4BBCC77D-0578-391E-BBDF-DDA46C726C11}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.415 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc928038f70: { Volume Name: "untitled" BSD Name: disk16 Mount point: /Library/Preferences/SystemConfiguration Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 1F70167B-BB6A-379D-8F08-2DB8B01AC9C1}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.415 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc928038600: { Volume Name: "untitled" BSD Name: disk11 Mount point: /private/var/folders Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 79CD98D5-CE85-37DC-A107-F394F99BFD04}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.415 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc923f1fc70: { Volume Name: "untitled" BSD Name: disk18 Mount point: /private/var/tmp/RecoveryTemp Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: A19FC28C-06C4-3EF7-BBFC-06C0B5CEF618}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.416 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc923f238b0: { Volume Name: "untitled" BSD Name: disk7 Mount point: /private/var/run Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: A4DB9F23-8569-3BC3-AC12-05ACD199A13C}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.416 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc923f069e0: { Volume Name: "untitled" BSD Name: disk13 Mount point: Not Mounted Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 89D1CD8B-6FAE-36E4-B8A7-F8095296E94E}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.416 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc923f3f9b0: { Volume Name: "untitled" BSD Name: disk6 Mount point: /private/var/tmp Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: E683FAD5-DF2A-3544-AE7C-4F21D89A3EA6}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.416 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc923f30b40: { Volume Name: "untitled" BSD Name: disk15 Mount point: /Library/Preferences Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 7FE0548D-1F39-3C7C-AE27-6E911D219C21}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.417 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc923f49470: { Volume Name: "untitled" BSD Name: disk10 Mount point: /private/var/db Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: AD69F7FF-E64E-3B84-8BD5-72BC608BCE6E}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.417 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc9283dad10: { Volume Name: "untitled" BSD Name: disk21 Mount point: /Library/Logs/DiagnosticReports Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: CE9B3DC8-D71A-36C0-AE7D-6F9FF7A9ADD4}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.417 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc9287097c0: { Volume Name: "untitled" BSD Name: disk5 Mount point: /Volumes Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: FF09294B-139E-3307-92AA-40A7D5B81859}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.417 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc9283d1090: { Volume Name: "untitled" BSD Name: disk17 Mount point: /Library/Keychains Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 7D08905B-D387-3C34-9C57-F95DD307ABFF}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.418 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc923d70480: { Volume Name: "untitled" BSD Name: disk12 Mount point: /private/var/root/Library Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: CC97A050-60F3-3E9F-886F-CD074E5BD980}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.418 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc923ee07b0: { Volume Name: "untitled" BSD Name: disk4 Mount point: /private/var/log Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: F97563F2-6A7F-39AB-8E04-E370A210513C}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.418 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc92803efc0: { Volume Name: "untitled" BSD Name: disk19 Mount point: /private/var/tmp/OSISPredicateUpdateProductTemp Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 31D9E99F-F829-3D25-9BD4-64DAB81C137F}>
Mar 22 12:15:28 MacBook-Pro Unknown[550]: 2019-03-22 12:15:28.418 Disk Utility[576:37506] Sidebar failed to get physical whole disk: <SKDisk 0x7fc92803fb60: { Volume Name: "untitled" BSD Name: disk9 Mount point: /System/Installation Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 1E9020DC-550C-3038-93C9-DE992DF6466C}>
Mar 22 12:37:13 MacBook-Pro Unknown[550]: Connected to daemon. Language set to: Italian
Mar 22 12:37:22 MacBook-Pro InstallAssistant_springboard[579]: Springboarding to: /Volumes/Image Volume/Install macOS Mojave.app/Contents/MacOS/InstallAssistant
Mar 22 12:37:22 MacBook-Pro InstallAssistant_springboard[579]: argv[0]: InstallAssistant
Mar 22 12:37:22 MacBook-Pro InstallAssistant_springboard[579]: argv[1]: -NSDisabledCharacterPaletteMenuItem
Mar 22 12:37:22 MacBook-Pro InstallAssistant_springboard[579]: argv[2]: YES
Mar 22 12:37:22 MacBook-Pro InstallAssistant_springboard[579]: argv[3]: -AppleKeyboardUIMode
Mar 22 12:37:22 MacBook-Pro InstallAssistant_springboard[579]: argv[4]: 2
Mar 22 12:37:22 MacBook-Pro InstallAssistant_springboard[579]: argv[5]: -AppleLanguages
Mar 22 12:37:22 MacBook-Pro InstallAssistant_springboard[579]: argv[6]: (it)
Mar 22 12:37:22 MacBook-Pro InstallAssistant_springboard[579]: argv[7]: -RunInOSIEnv
Mar 22 12:37:23 MacBook-Pro InstallAssistant[579]: No compatibility bundle on this version of macOS. Will assume compatible.
Mar 22 12:37:23 MacBook-Pro Unknown[550]: objc[579]: Class OSISSystemInfo is implemented in both /Volumes/Image Volume/Install macOS Mojave.app/Contents/MacOS/InstallAssistant (0x100cb4530) and /Volumes/Image Volume/Install macOS Mojave.app/Contents/Frameworks/OSInstallerSetup.framework/Versions/A/OSInstallerSetup (0x1110f2080). One of the two will be used. Which one is undefined.
Mar 22 12:37:23 MacBook-Pro Unknown[550]: objc[579]: Class OSISAppCompatibilityBundle is implemented in both /Volumes/Image Volume/Install macOS Mojave.app/Contents/MacOS/InstallAssistant (0x100cb44b8) and /Volumes/Image Volume/Install macOS Mojave.app/Contents/Frameworks/OSInstallerSetup.framework/Versions/A/OSInstallerSetup (0x1110f20f8). One of the two will be used. Which one is undefined.
Mar 22 12:37:23 MacBook-Pro Unknown[550]: objc[579]: Class OSISLegacyMacProSupport is implemented in both /Volumes/Image Volume/Install macOS Mojave.app/Contents/MacOS/InstallAssistant (0x100cb4558) and /Volumes/Image Volume/Install macOS Mojave.app/Contents/PlugIns/IA.bundle/Contents/MacOS/IA (0x1110b2b30). One of the two will be used. Which one is undefined.
Mar 22 12:50:01 MacBook-Pro Unknown[550]: 2019-03-22 12:50:01.421 Disk Utility[599:42843] NSDisabledCharacterPaletteMenuItem=YES
Mar 22 12:50:01 MacBook-Pro Unknown[550]: 2019-03-22 12:50:01.428 Disk Utility[599:42843] isPrefsCreateCacheFromEnabledAndDefaultInputSources - can't find anything from GetInputSourceEnabledPrefs, use defaultASCIIKeyLayoutDict = <CFBasicHash 0x7fc435640410 [0x11117a8f0]>{type = immutable dict, count = 3,
Mar 22 12:50:01 MacBook-Pro Unknown[550]: entries =>
Mar 22 12:50:01 MacBook-Pro Unknown[550]: 0 : <CFString 0x119f6ab68 [0x11117a8f0]>{contents = "InputSourceKind"} = <CFString 0x119f6b528 [0x11117a8f0]>{contents = "Keyboard Layout"}
Mar 22 12:50:01 MacBook-Pro Unknown[550]: 1 : <CFString 0x119f6b568 [0x11117a8f0]>{contents = "KeyboardLayout Name"} = <CFString 0x111233eb8 [0x11117a8f0]>{contents = "Italian - Pro"}
Mar 22 12:50:01 MacBook-Pro Unknown[550]: 2 : <CFString 0x119f6b548 [0x11117a8f0]>{contents = "KeyboardLayout ID"} = <CFNumber 0x5a6d26829308060d [0x11117a8f0]>{value = +223, type = kCFNumberSInt32Type}
Mar 22 12:50:01 MacBook-Pro Unknown[550]: }
Mar 22 12:50:01 MacBook-Pro Unknown[550]: 2019-03-22 12:50:01.582 Disk Utility[599:42843] unable to obtain configuration from file:///Library/Preferences/com.apple.ViewBridge.plist due to Error Domain=NSCocoaErrorDomain Code=260 "Impossibile aprire il file “com.apple.ViewBridge.plist” perché non esiste." UserInfo={NSFilePath=/Library/Preferences/com.apple.ViewBridge.plist, NSUnderlyingError=0x7fc435441f70 {Error Domain=NSPOSIXErrorDomain Code=2 "No such file or directory"}}
Mar 22 12:50:02 MacBook-Pro Unknown[550]: 2019-03-22 12:50:02.213 Disk Utility[599:42844] Connected to daemon. Language set to: Italian
Mar 22 12:50:02 MacBook-Pro Unknown[550]: 2019-03-22 12:50:02.221 Disk Utility[599:42843] Sidebar failed to get physical whole disk: <SKDisk 0x7fc43567ba40: { Volume Name: "untitled" BSD Name: disk19 Mount point: /private/var/tmp/OSISPredicateUpdateProductTemp Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 31D9E99F-F829-3D25-9BD4-64DAB81C137F}>
Mar 22 12:50:02 MacBook-Pro Unknown[550]: 2019-03-22 12:50:02.221 Disk Utility[599:42843] Sidebar failed to get physical whole disk: <SKDisk 0x7fc4356850a0: { Volume Name: "untitled" BSD Name: disk14 Mount point: /private/var/root/Library/Containers Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 560582C4-403B-3AFD-8304-DA431EAFE8D7}>
Mar 22 12:50:02 MacBook-Pro Unknown[550]: 2019-03-22 12:50:02.221 Disk Utility[599:42843] Sidebar failed to get physical whole disk: <SKDisk 0x7fc4356ab570: { Volume Name: "untitled" BSD Name: disk20 Mount point: /private/var/tmp/InstallerCookies Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 5B3DDA87-B63F-31E1-AB39-E5CBDE4FE268}>
Mar 22 12:50:02 MacBook-Pro Unknown[550]: 2019-03-22 12:50:02.222 Disk Utility[599:42843] Sidebar failed to get physical whole disk: <SKDisk 0x7fc43566c8a0: { Volume Name: "untitled" BSD Name: disk8 Mount point: /private/tmp Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 4BBCC77D-0578-391E-BBDF-DDA46C726C11}>
Mar 22 12:50:02 MacBook-Pro Unknown[550]: 2019-03-22 12:50:02.222 Disk Utility[599:42843] Sidebar failed to get physical whole disk: <SKDisk 0x7fc43566f060: { Volume Name: "untitled" BSD Name: disk16 Mount point: /Library/Preferences/SystemConfiguration Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 1F70167B-BB6A-379D-8F08-2DB8B01AC9C1}>
Mar 22 12:50:02 MacBook-Pro Unknown[550]: 2019-03-22 12:50:02.222 Disk Utility[599:42843] Sidebar failed to get physical whole disk: <SKDisk 0x7fc4356b10a0: { Volume Name: "untitled" BSD Name: disk11 Mount point: /private/var/folders Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 79CD98D5-CE85-37DC-A107-F394F99BFD04}>
Mar 22 12:50:02 MacBook-Pro Unknown[550]: 2019-03-22 12:50:02.222 Disk Utility[599:42843] Sidebar failed to get physical whole disk: <SKDisk 0x7fc435756b90: { Volume Name: "untitled" BSD Name: disk18 Mount point: /private/var/tmp/RecoveryTemp Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: A19FC28C-06C4-3EF7-BBFC-06C0B5CEF618}>
Mar 22 12:50:02 MacBook-Pro Unknown[550]: 2019-03-22 12:50:02.223 Disk Utility[599:42843] Sidebar failed to get physical whole disk: <SKDisk 0x7fc4357570e0: { Volume Name: "untitled" BSD Name: disk7 Mount point: /private/var/run Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: A4DB9F23-8569-3BC3-AC12-05ACD199A13C}>
Mar 22 12:50:02 MacBook-Pro Unknown[550]: 2019-03-22 12:50:02.223 Disk Utility[599:42843] Sidebar failed to get physical whole disk: <SKDisk 0x7fc43573d1b0: { Volume Name: "untitled" BSD Name: disk13 Mount point: Not Mounted Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 89D1CD8B-6FAE-36E4-B8A7-F8095296E94E}>
Mar 22 12:50:02 MacBook-Pro Unknown[550]: 2019-03-22 12:50:02.223 Disk Utility[599:42843] Sidebar failed to get physical whole disk: <SKDisk 0x7fc435754270: { Volume Name: "untitled" BSD Name: disk6 Mount point: /private/var/tmp Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: E683FAD5-DF2A-3544-AE7C-4F21D89A3EA6}>
Mar 22 12:50:02 MacBook-Pro Unknown[550]: 2019-03-22 12:50:02.223 Disk Utility[599:42843] Sidebar failed to get physical whole disk: <SKDisk 0x7fc435752880: { Volume Name: "untitled" BSD Name: disk15 Mount point: /Library/Preferences Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 7FE0548D-1F39-3C7C-AE27-6E911D219C21}>
Mar 22 12:50:02 MacBook-Pro Unknown[550]: 2019-03-22 12:50:02.224 Disk Utility[599:42843] Sidebar failed to get physical whole disk: <SKDisk 0x7fc43574a3f0: { Volume Name: "untitled" BSD Name: disk10 Mount point: /private/var/db Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: AD69F7FF-E64E-3B84-8BD5-72BC608BCE6E}>
Mar 22 12:50:02 MacBook-Pro Unknown[550]: 2019-03-22 12:50:02.224 Disk Utility[599:42843] Sidebar failed to get physical whole disk: <SKDisk 0x7fc43573ebd0: { Volume Name: "untitled" BSD Name: disk21 Mount point: /Library/Logs/DiagnosticReports Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: CE9B3DC8-D71A-36C0-AE7D-6F9FF7A9ADD4}>
Mar 22 12:50:02 MacBook-Pro Unknown[550]: 2019-03-22 12:50:02.224 Disk Utility[599:42843] Sidebar failed to get physical whole disk: <SKDisk 0x7fc43ac31830: { Volume Name: "untitled" BSD Name: disk5 Mount point: /Volumes Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: FF09294B-139E-3307-92AA-40A7D5B81859}>
Mar 22 12:50:02 MacBook-Pro Unknown[550]: 2019-03-22 12:50:02.224 Disk Utility[599:42843] Sidebar failed to get physical whole disk: <SKDisk 0x7fc43ac31320: { Volume Name: "untitled" BSD Name: disk17 Mount point: /Library/Keychains Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 7D08905B-D387-3C34-9C57-F95DD307ABFF}>
Mar 22 12:50:02 MacBook-Pro Unknown[550]: 2019-03-22 12:50:02.224 Disk Utility[599:42843] Sidebar failed to get physical whole disk: <SKDisk 0x7fc43ac2fa60: { Volume Name: "untitled" BSD Name: disk12 Mount point: /private/var/root/Library Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: CC97A050-60F3-3E9F-886F-CD074E5BD980}>
Mar 22 12:50:02 MacBook-Pro Unknown[550]: 2019-03-22 12:50:02.225 Disk Utility[599:42843] Sidebar failed to get physical whole disk: <SKDisk 0x7fc43540a1d0: { Volume Name: "untitled" BSD Name: disk4 Mount point: /private/var/log Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: F97563F2-6A7F-39AB-8E04-E370A210513C}>
Mar 22 12:50:02 MacBook-Pro Unknown[550]: 2019-03-22 12:50:02.225 Disk Utility[599:42843] Sidebar failed to get physical whole disk: <SKDisk 0x7fc43573f610: { Volume Name: "untitled" BSD Name: disk9 Mount point: /System/Installation Role: kSKDiskRoleLegacyMacData Type: kSKDiskTypeHFS isValid: YES volumeUUID: 1E9020DC-550C-3038-93C9-DE992DF6466C}>
Mar 22 12:50:41 MacBook-Pro Unknown[550]: Connected to daemon. Language set to: Italian
Mar 22 12:50:46 MacBook-Pro Unknown[550]: 2019-03-22 12:50:46.596 macOS Utilities[570:37038] *** WARNING: Method userSpaceScaleFactor in class NSWindow is deprecated on 10.7 and later. It should not be used in new applications. Use convertRectToBacking: instead.
Mar 22 12:50:46 MacBook-Pro Unknown[550]: 2019-03-22 12:50:46.600 macOS Utilities[570:37038] NSSoftLinking - The Quartz framework's library couldn't be loaded from /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz.
Mar 22 12:51:08 MacBook-Pro Unknown[550]: 2019-03-22 12:51 macOS Utilities[570] (FSEvents.framework) FSEventStreamStart: ERROR: FSEvents_connect() => Unknown service name (1102)
Mar 22 12:51:09 MacBook-Pro Unknown[550]: 2019-03-22 12:51:09.003 macOS Utilities[570:37038] NSSoftLinking - The Quartz framework's library couldn't be loaded from /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz.
Mar 22 12:51:09 MacBook-Pro Unknown[550]: 2019-03-22 12:51 macOS Utilities[570] (FSEvents.framework) FSEventStreamStart: ERROR: FSEvents_connect() => Unknown service name (1102)
Mar 22 12:52:01 MacBook-Pro Unknown[550]: 2019-03-22 12:52 macOS Utilities[570] (FSEvents.framework) FSEventStreamStart: ERROR: FSEvents_connect() => Unknown service name (1102)
Mar 22 12:52:15 MacBook-Pro Unknown[550]: 2019-03-22 12:52 macOS Utilities[570] (FSEvents.framework) FSEventStreamStart: ERROR: FSEvents_connect() => Unknown service name (1102)
