Un'immagine disco criptata o una password a protezione di una cartella, sono più che sufficienti.
No.
### SYSTEM INFORMATION ###
Report Timestamp : 26 novembre 2019 19:36:12 CET
Report Timestamp (ISO 8601 format) : 2019-11-26T19:36:12
Application Name : DriveDx
Application Version : 1.8.3.615
Application SubBuild : 0
Application Edition : Standalone
Application Website : https://binaryfruit.com/drivedx
DriveDx Knowledge Base Revision : 9/9
Computer Name : iMac di Marco
Host Name : iMac-di-Marco
Computer Model : iMac10,1
OS Boot Time : 2019-11-26T16:46:06
Time Since Boot : 02h 50m 06s
OS Name : macOS
OS Version : 10.11.6
OS Build : 15G22010
OS Kernel Version : Darwin 15.6.0
SAT SMART Driver Version : N/A
ATA Command Support Tolerance : verypermissive
N of drives with S.M.A.R.T support : 1
### DRIVE 1 OF 1 ###
Last Checked : 26 novembre 2019 19:35:00 CET
Last Checked (ISO 8601 format) : 2019-11-26T19:35:00
Advanced SMART Status : OK
Overall Health Rating : AVERAGE 44.4%
Overall Performance Rating : AVERAGE 44.4%
Issues found : 0
Serial Number : STR608MQ0219ES
WWN Id : 5 000cca 366c0eda3
Volumes : Macintosh HD, Macintosh HD 2
Device Path : /dev/disk0
Total Capacity : 1.0 TB (1.000.204.886.016 Bytes)
Model Family : Hitachi Deskstar E7K1000
Model : Hitachi HDE721010SLA330
Firmware Version : ST0KA36E
Drive Type : HDD 7200 rpm
Power On Time : 19.434 hours (26 months 29 days 18 hours)
Power Cycles Count : 9.043
Current Power Cycle Time : 2.8 hours
=== DEVICE CAPABILITIES ===
S.M.A.R.T. support enabled : yes
DriveDx Active Diagnostic Config : Base config [hdd.default]
Sector Logical Size : 512
Sector Physical Size : 512
Physical Interconnect : SATA
Logical Protocol : SATA
Removable : no
Ejectable : no
ATA Version : ATA8-ACS T13/1699-D revision 4
SATA Version : SATA 2.6, 3.0 Gb/s
Bay # : 1
I/O Path : IOService:/AppleACPIPlatformExpert/PCI0@0/AppleACPIPCI/SATA@B/AppleMCP79AHCI/PRT0@0/IOAHCIDevice@0/AppleAHCIDiskDriver/IOAHCIBlockStorageDevice
Attributes Data Structure Revision : 16
SMART Command Transport (SCT) flags : 0x3d
SCT Status supported : yes
SCT Feature Control supported : yes
SCT Data Table supported : yes
Error logging capabilities : 0x1
Self-tests supported : yes
Offline Data Collection capabilities : 0x5b
Offline Data Collection status : 0x84
Auto Offline Data Collection flags : 0x1
[Known device ]: yes
[Drive State Flags ]: 0x20
[Last State Change Timestamp ]: 2019-11-26T19:35:00
[Last State Change Flags ]: 0x20
[Last State Change Diff Flags ]: 0x1
Last Email Report Timestamp : 2019-11-26T19:35:00
Last Email Report Reason Flags : 0x20
Last Email Report State Change Flags : 0x1
=== CURRENT POWER CYCLE STATISTICS ===
Data Read : 11.5 GB
Data Written : 3.9 GB
Data Read/Write Ratio : 2.94
Average Throughput (Read) : 4.2 MB/s
Average Throughput (Write) : 1.7 MB/s
Operations (Read) : 717.017
Operations (Write) : 109.727
Operations Read/Write Ratio : 7
Throughput per operation (Read) : 16.7 KB/Op
Throughput per operation (Write) : 37.2 KB/Op
Latency Time (Read) : 0 ns
Latency Time (Write) : 0 ns
Retries (Read) : 0
Retries (Write) : 0
Errors (Read) : 0
Errors (Write) : 0
=== PROBLEMS SUMMARY ===
Failed Indicators (life-span / pre-fail) : 0 (0 / 0)
Failing Indicators (life-span / pre-fail) : 0 (0 / 0)
Warnings (life-span / pre-fail) : 0 (0 / 0)
Recently failed Self-tests (Short / Full) : 0 (0 / 0)
I/O Error Count : 0 (0 / 0)
Time in Under temperature : 0 minutes
Time in Over temperature : 0 minutes
=== IMPORTANT HEALTH INDICATORS ===
ID NAME RAW VALUE STATUS
5 Reallocated Sector Count 0 100% OK
197 Current Pending Sector Count 0 100% OK
198 Offline Uncorrectable Sector Count 0 100% OK
199 UDMA CRC Error Count 0 100% OK
=== TEMPERATURE INFORMATION (CELSIUS) ===
Current Temperature : 52
Power Cycle Min Temperature : 31
Power Cycle Max Temperature : 52
Lifetime Min Temperature : 18
Lifetime Max Temperature : 61
Recommended Min Temperature : 0
Recommended Max Temperature : 60
Temperature Min Limit : -40
Temperature Max Limit : 70
=== DRIVE HEALTH INDICATORS ===
ID | NAME | TYPE | UPDATE | RAW VALUE | VALUE | THRESHOLD | WORST | LAST MODIFIED | STATUS
1 Raw Read Error Rate Pre-fail online 0x0 100 16 100 - 100% OK
2 Throughput Performance Pre-fail offline 119 131 54 131 - 52.7% OK
3 Spin Up Time Pre-fail online 482 119 24 119 26/11/19 19:35 54.0% OK
4 Start Stop Count Life-span online 13.549 97 0 97 26/11/19 19:35 97.0% OK
5 Reallocated Sector Count Pre-fail online 0 100 5 100 - 100% OK
7 Seek Error Rate Pre-fail online 0x0 100 67 100 - 100% OK
8 Seek Time Performance Pre-fail offline 56 100 20 100 26/11/19 19:35 44.4% OK
9 Power On Hours Life-span online 19.434 98 0 98 26/11/19 19:35 98.0% OK
10 Spin Retry Count Pre-fail online 0 100 60 100 - 100% OK
12 Power Cycle Count Life-span online 9.043 98 0 98 26/11/19 19:35 98.0% OK
192 Power-Off Retract Count Life-span online 13.592 89 0 89 26/11/19 19:35 89.0% OK
193 Load Cycle Count Life-span online 13.592 89 0 89 26/11/19 19:35 89.0% OK
194 Temperature (Celsius) Life-span online 52 115 0 115 26/11/19 19:35 57.5% OK
196 Reallocated Event Count Life-span online 0 100 0 100 - 100% OK
197 Current Pending Sector Count Life-span online 0 100 0 100 - 100% OK
198 Offline Uncorrectable Sector Count Life-span offline 0 100 0 100 - 100% OK
199 UDMA CRC Error Count Life-span online 0 200 0 200 - 100% OK
=== DRIVE ERROR LOG ===
error log is empty
=== DRIVE SELF-TEST LOG ===
self-test log is empty
Aggiungo anche singoli file protetti da password (documenti PDF, Word, Pages ecc. possono essere protetti).
Sta tutto qui:
Questo riassume tutto:marmaro ha scritto: ↑mer, 27 nov 2019 09:03Codice: Seleziona tutto
... Advanced SMART Status : OK Overall Health Rating : AVERAGE 44.4% Overall Performance Rating : AVERAGE 44.4% Issues found : 0 ... Power On Time : 19.434 hours (26 months 29 days 18 hours) ...
È la stessa identica cosa.
