IL MAC NON SI SPEGNE NE SI RIAVVIA
rikievo
Buona sera a tutti!!
ragazzi ho un problema che hanno avuto in molti su questo forum ma io non sono riuscito a risolverlo. Non riesco a spegnere in alcun modo il mac, ne riavviarlo e soprattutto ho notato che si scalda subito e la batteria dura meno del solito. Ho scaricato malware byte ma non è emerso niente... Chiedo il vostro aiuto :) grazie :(
Posto i risultati di etrecheck
EtreCheck version: 3.2.4 (365)
Report generated 2017-05-29 21:20:46
Runtime: 1:56
Performance: Excellent
Click the [Remove/Report] links to remove adware or update the whitelist of legitimate software.
Problem: Other problem
Hardware Information: ⓘ
MacBook Air (13-inch, Mid 2013)
MacBook Air - model: MacBookAir6,2
1 1,3 GHz Intel Core i5 (i5-4250U) CPU: 2-core
4 GB RAM Not upgradeable
BANK 0/DIMM0
2 GB DDR3 1600 MHz ok
BANK 1/DIMM0
Wireless: en0: 802.11 a/b/g/n/ac
Battery: Health = Normal - Cycle count = 356
Video Information: ⓘ
Intel HD Graphics 5000
Color LCD 1440 x 900
System Software: ⓘ
macOS Sierra 10.12.3 (16D32) - Time since boot: about 20 days
Disk Information: ⓘ
APPLE SSD SD0128F disk0 : (121,33 GB) (Solid State - TRIM: Yes)
[Show SMART report]
Macintosh HD (disk1) / [Startup]: 120.10 GB (48.91 GB free)
Core Storage: disk0s2 120.47 GB Online
USB Information: ⓘ
Apple Inc. BRCM20702 Hub
Thunderbolt Information: ⓘ
Apple Inc. thunderbolt_bus
Configuration files: ⓘ
/etc/sudoers, File size 2330 but expected 1563
Gatekeeper: ⓘ
Possible adware: ⓘ
Unknown file: ~/Library/LaunchAgents/com.ELRmiVaK.plist
~/Library/SDUBxzUe/jtdtaqrW/YkixrdMc/ELRmiVaK
Adware: ~/Library/LaunchAgents/com.bittorrent.uTorrent.plist
Unknown file: ~/Library/LaunchAgents/com.fbrrrvcsnyyh.plist
~/Library/fbrrrvcsnyyh/fbrrrvcsnyyh
Unknown file: ~/Library/LaunchAgents/com.plicater.plist
~/Library/spotted_atropinize/gsKBptDJ/MSPNitWq/RVOkgZRJ/ADAyjqtp/plicater
4 possible adware files found. [Remove/Report]
Kernel Extensions: ⓘ
/System/Library/Extensions
[not loaded] com.devguru.driver.SamsungComposite (1.4.16 - SDK 10.6 - 2017-05-16) [Lookup]
/System/Library/Extensions/ssuddrv.kext/Contents/PlugIns
[not loaded] com.devguru.driver.SamsungACMControl (1.4.16 - SDK 10.6 - 2013-11-19) [Lookup]
[not loaded] com.devguru.driver.SamsungACMData (1.4.16 - SDK 10.6 - 2013-11-19) [Lookup]
[not loaded] com.devguru.driver.SamsungMTP (1.4.16 - SDK 10.5 - 2013-11-19) [Lookup]
[not loaded] com.devguru.driver.SamsungSerial (1.4.16 - SDK 10.6 - 2013-11-19) [Lookup]
System Launch Agents: ⓘ
[not loaded] 7 Apple tasks
[loaded] 161 Apple tasks
[running] 112 Apple tasks
System Launch Daemons: ⓘ
[not loaded] 42 Apple tasks
[loaded] 164 Apple tasks
[running] 106 Apple tasks
Launch Daemons: ⓘ
[loaded] com.adobe.fpsaud.plist (2017-04-27) [Lookup]
[running] com.malwarebytes.HelperTool.plist ✔︎ (2017-03-08) [Lookup]
[loaded] com.microsoft.office.licensing.helper.plist (2010-09-23) [Lookup]
User Launch Agents: ⓘ
[running] com.ELRmiVaK.plist (2017-03-16) [Lookup]
[loaded] com.adobe.ARM.[...].plist (2017-04-08) [Lookup]
[loaded] com.bittorrent.uTorrent.plist ✔︎ (2016-12-10) Adware! [Remove/Report]
/usr/bin/open
[loaded] com.fbrrrvcsnyyh.plist (2017-03-04) [Lookup]
[loaded] com.google.keystone.agent.plist ✔︎ (2017-03-29) [Lookup]
[running] com.plicater.plist (2017-03-22) [Lookup]
[running] com.spotify.webhelper.plist ✔︎ (2016-07-01) [Lookup]
User Login Items: ⓘ
iTunesHelper Applicazione (2017-05-16)
(/Applications/iTunes.app/Contents/MacOS/iTunesHelper.app)
Google Drive Applicazione
(/Applications/Google Drive.app)
Cartella pubblica di [redacted] Cartella
(~/Public)
AdobeResourceSynchronizer Applicazione - Hidden
(/Applications/Adobe Reader.app/Contents/Support/AdobeResourceSynchronizer.app)
Internet Plug-ins: ⓘ
FlashPlayer-10.6: 25.0.0.171 - SDK 10.9 (2017-05-09) [Lookup]
QuickTime Plugin: 7.7.3 (2017-01-19)
AdobePDFViewerNPAPI: 11.0.19 - SDK 10.6 (2017-04-08) [Lookup]
AdobePDFViewer: 11.0.19 - SDK 10.6 (2017-04-08) [Lookup]
Flash Player: 25.0.0.171 - SDK 10.9 (2017-05-09) [Lookup]
SharePointBrowserPlugin: 14.0.0 (2010-09-23) [Lookup]
Silverlight: 5.1.41212.0 - SDK 10.6 (2016-02-08) [Lookup]
3rd Party Preference Panes: ⓘ
Flash Player (2017-04-27) [Lookup]
Time Machine: ⓘ
Time Machine not configured!
Top Processes by CPU: ⓘ
58% launchservicesd
14% loginwindow
12% osascript(4)
7% WindowServer
3% notifyd
Top Processes by Memory: ⓘ
608 MB kernel_task
213 MB com.apple.WebKit.WebContent(2)
123 MB Google Drive
115 MB mdworker(19)
74 MB Safari
Virtual Memory Information: ⓘ
1.20 GB Available RAM
58 MB Free RAM
2.80 GB Used RAM
1.14 GB Cached files
437 MB Swap Used
Prova a reimpostare meticolosamente il controller di gestione del sistema (SMC):
http://support.apple.com/kb/HT3964?viewlocale=it_IT" onclick="window.open(this.href);return false;
Benvenuto intanto rikievo, e se vuoi presentarti a tutti puoi farlo qui creando un nuovo topic:
Kundalini
Benvenuto rikievo.
Dopo aver fatto quanto suggerito da fragrua, vedi un po' come si comporta, se rimangono gli stessi problemi di accensione e spegnimento.
Poi prova a fare un'ulteriore operazione; stai usando una versione di EtreCheck vecchia, scarica l'ultima da qui https://etrecheck.com" onclick="window.open(this.href);return false;
Quindi ripeti il test. Se ti risulterà dell'adware, come questo che copio dal tuo report EtreCheck
Possible adware: ⓘ
clicca sulla scritta [Remove] dello stesso report per eliminarlo.
Hai solo 4 GB di RAM sul tuo Air, e purtroppo non puoi aumentarla; Sierra girerà sempre lento, se messo sotto sforzo.
Poi ci sono un paio di altre cose che non mi piacciono; questo
e questi altri file, già citati prima
Per favore quindi, apri Terminale, lo trovi in Applicazioni > Utility e copia ed incolla (non scrivere tu) questo comando:
dscl /Local/Default -list /Users UniqueID | awk '$2 >= 100 && $2 < 500 { print $1; }'
quindi premi ⏎
dopo fai lo stesso con questo altro comando
dscl . -list /Users UniqueID | grep 401
di nuovo ⏎ .
Copia la risposta di Terminale integralmente, ed incollala tra i TAG code, così
incolla qui
Ci sarebbero pure un paio di altre cose da mettere a posto, ma prima esegui quanto indicato.
Se funziona, non aggiustarlo.
