Yosemite il finder si congela ed i pixel impazziscono
savick
Oggetto del messaggio: Re: Yosemite il finder si congela ed i pixel impazziscono
Messaggio Inviato: ven, 11 dic 2015 14:59
A volte come oggi, non faccio in tempo a partire che va in crash di continuo....
ora 14:40:58
111/12/15 14:40:53,420 com.apple.xpc.launchd[1]: (com.apple.quicklook[491]) Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.quicklook
11/12/15 14:40:58,818 CoreServicesUIAgent[367]: unexpected message <OS_xpc_error: <error: 0x7fff77a5bc60> { count = 1, contents =
"XPCErrorDescription" => <string: 0x7fff77a5bf70> { length = 18, contents = "Connection invalid" }
11/12/15 14:40:58,826 ACCFinderSync[482]: host connection <NSXPCConnection: 0x6080001039f0> connection from pid 480 invalidated
11/12/15 14:42:19,000 bootlog[0]: BOOT_TIME 1449841339 0
savick
Messaggio Inviato: ven, 11 dic 2015 15:01
ecco un anteprima, mentre dalla consolle stavo copiando i dati per incollarli qui!
savick
Messaggio Inviato: ven, 11 dic 2015 15:57
ora 14:55:50
11/12/15 14:54:04,854 com.apple.SecurityServer[85]: Session 100000 created
11/12/15 14:54:04,902 com.apple.xpc.launchd[1]: (com.apple.secd) This key does not do anything: OnDemand
11/12/15 14:54:04,902 com.apple.xpc.launchd[1]: (com.apple.secd) The ServiceIPC key is no longer respected. Please remove it.
11/12/15 14:54:04,903 com.apple.xpc.launchd[1]: (com.apple.speech.speechsynthesisd) This key does not do anything: OnDemand
11/12/15 14:54:04,913 com.apple.xpc.launchd[1]: (com.apple.TrustEvaluationAgent) This key does not do anything: OnDemand
11/12/15 14:54:04,917 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.domain.user.0) Could not read path: path = /Library/LaunchAgents/com.oracle.java.Java-Updater.plist, error = 2: No such file or directory
11/12/15 14:54:04,919 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.domain.user.0) Failed to bootstrap path: path = /Library/LaunchAgents/com.oracle.java.Java-Updater.plist, error = 2: No such file or directory
11/12/15 14:54:04,925 watchdogd[61]: [watchdog_daemon] @( wd_watchdog_open) - IOIteratorNext failed (kr=0)
11/12/15 14:54:04,926 watchdogd[61]: [watchdog_daemon] @( wd_daemon_init) - could not initialize the hardware watchdog
11/12/15 14:54:04,926 watchdogd[61]: [watchdog_daemon] @( main) - cannot initialize the watchdog service
11/12/15 14:54:04,000 kernel[0]: IO80211Controller::dataLinkLayerAttachComplete(): adding AppleEFINVRAM notification
11/12/15 14:54:04,000 kernel[0]: IO80211Interface::efiNVRAMPublished():
11/12/15 14:54:04,000 kernel[0]: bpfAttach len 64 dlt 12
11/12/15 14:53:59,754 iconservicesagent[68]: iconservicesagent launched.
11/12/15 14:54:05,048 watchdogd[132]: [watchdog_daemon] @( wd_watchdog_open) - IOIteratorNext failed (kr=0)
11/12/15 14:54:05,049 watchdogd[132]: [watchdog_daemon] @( wd_daemon_init) - could not initialize the hardware watchdog
11/12/15 14:54:05,050 watchdogd[132]: [watchdog_daemon] @( main) - cannot initialize the watchdog service
11/12/15 14:54:05,051 com.apple.xpc.launchd[1]: (com.apple.watchdogd) Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
11/12/15 14:54:05,184 powerd[56]: Activity changes from 0xffff to 0x1. Assertions:1 HidState:0
11/12/15 14:54:05,273 com.apple.usbmuxd[84]: log filter changed from 4 to 6
11/12/15 14:54:05,287 com.apple.usbmuxd[84]: usbmuxd-364 on Aug 4 2015 at 14:36:18, running 64 bit
11/12/15 14:54:05,294 kdc[93]: krb5_kdc_set_dbinfo: failed to create root node: /Local/Default
11/12/15 14:54:05,296 com.apple.xpc.launchd[1]: (com.apple.Kerberos.kdc[93]) Service exited with abnormal code: 1
11/12/15 14:54:05,324 kdc[145]: label: default
11/12/15 14:54:05,324 kdc[145]: dbname: od:/Local/Default
11/12/15 14:54:05,324 kdc[145]: mkey_file: /var/db/krb5kdc/m-key
11/12/15 14:54:05,325 kdc[145]: acl_file: /var/db/krb5kdc/kadmind.acl
11/12/15 14:54:05,415 iconservicesd[67]: iconservicesd launched.
11/12/15 14:54:05,416 iconservicesd[67]: Cache path: /Library/Caches/com.apple.iconservices.store
11/12/15 14:54:05,422 opendirectoryd[78]: BUG in libdispatch: 14F1505 - 2004 - 0x5
11/12/15 14:54:05,670 com.apple.SecurityServer[85]: Entering service
11/12/15 14:54:06,000 kernel[0]: IOGraphics flags 0x43
11/12/15 14:54:06,000 kernel[0]: NVDAStartup: Official
11/12/15 14:54:06,000 kernel[0]: NVDANV50HAL loaded and registered
11/12/15 14:54:06,000 kernel[0]: IOBluetoothUSBDFU::probe
11/12/15 14:54:06,000 kernel[0]: IOBluetoothUSBDFU::probe ProductID - 0x8215 FirmwareVersion - 0x0208
11/12/15 14:54:06,000 kernel[0]: **** [IOBluetoothHostControllerUSBTransport][start] -- completed -- result = TRUE -- 0x8800 ****
11/12/15 14:54:06,000 kernel[0]: **** [BroadcomBluetoothHostControllerUSBTransport][start] -- Completed (matched on Device) -- 0x8800 ****
11/12/15 14:54:06,000 kernel[0]: [IOBluetoothHCIController][staticBluetoothTransportShowsUp] -- Received Bluetooth Controller register service notification -- 0x8800
11/12/15 14:54:06,000 kernel[0]: [IOBluetoothHCIController][start] -- completed
11/12/15 14:54:06,000 kernel[0]: No interval found for . Using 8000000
11/12/15 14:54:06,000 kernel[0]: [IOBluetoothHCIController::setConfigState] calling registerService
11/12/15 14:54:06,000 kernel[0]: **** [IOBluetoothHCIController][ProcessBluetoothTransportShowsUpActionWL] -- Connected to the transport successfully -- 0x6f80 -- 0xc800 -- 0x8800 ****
11/12/15 14:54:06,370 kdc[145]: WARNING Found KDC certificate (O=System Identity,CN=com.apple.kerberos.kdc)is missing the PK-INIT KDC EKU, this is bad for interoperability.
11/12/15 14:54:06,000 kernel[0]: Previous shutdown cause: 3
11/12/15 14:54:06,000 kernel[0]: DSMOS has arrived
11/12/15 14:54:06,528 thermald[52]: Waiting for OSTT support notification
11/12/15 14:54:06,615 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.domain.system) Service "com.apple.ManagedClient.startup" tried to hijack endpoint "com.apple.ManagedClient.agent" from owner: com.apple.ManagedClient
11/12/15 14:54:06,719 digest-service[137]: label: default
11/12/15 14:54:06,719 digest-service[137]: dbname: od:/Local/Default
11/12/15 14:54:06,719 digest-service[137]: mkey_file: /var/db/krb5kdc/m-key
11/12/15 14:54:06,719 digest-service[137]: acl_file: /var/db/krb5kdc/kadmind.acl
11/12/15 14:54:06,720 mDNSResponder[94]: mDNSResponder mDNSResponder-576.50.2 (Sep 30 2015 19:55:50) starting OSXVers 14
11/12/15 14:54:06,739 loginwindow[98]: Login Window Application Started
11/12/15 14:54:06,780 UserEventAgent[47]: Failed to copy info dictionary for bundle /System/Library/UserEventPlugins/alfUIplugin.plugin
11/12/15 14:54:06,791 UserEventAgent[47]: Captive: CNPluginHandler en1: Inactive
11/12/15 14:54:06,884 configd[55]: preference: no sharing preferences
11/12/15 14:54:06,949 systemkeychain[151]: done file: /var/run/systemkeychaincheck.done
11/12/15 14:54:07,000 kernel[0]: 00000000 00000020 NVEthernet::setLinkStatus - not Active
11/12/15 14:54:07,219 com.apple.xpc.launchd[1]: (com.apple.appkit.xpc.sandboxedServiceRunner) The JoinExistingSession key is only available to Application services.
11/12/15 14:54:07,219 com.apple.xpc.launchd[1]: (com.apple.lakitu) The JoinExistingSession key is only available to Application services.
11/12/15 14:54:07,219 com.apple.xpc.launchd[1]: (com.apple.accounts.dom) The _DirtyJetsamMemoryLimit key is not available on this platform.
11/12/15 14:54:07,219 com.apple.xpc.launchd[1]: (com.apple.imfoundation.IMRemoteURLConnectionAgent) The _DirtyJetsamMemoryLimit key is not available on this platform.
11/12/15 14:54:07,242 digest-service[137]: digest-request: uid=0
11/12/15 14:54:07,252 secinitd[167]: UID[0]: cache loaded: /System/Library/Caches/com.apple.app-sandbox-cache.plist
11/12/15 14:54:07,253 secinitd[167]: ctkd[166]: unable to get root path for bundle of main executable: /System/Library/Frameworks/CryptoTokenKit.framework/ctkd
11/12/15 14:54:07,314 configd[55]: network changed.
11/12/15 14:54:07,315 configd[55]: setting hostname to "iMac-di-Valerio.local"
11/12/15 14:54:07,320 digest-service[137]: digest-request: netr probe 0
11/12/15 14:54:07,321 digest-service[137]: digest-request: init request
11/12/15 14:54:07,334 digest-service[137]: digest-request: init return domain: BUILTIN server: IMAC-DI-VALERIO indomain was: <NULL>
11/12/15 14:54:07,625 iconservicesagent[68]: Starting service with cache path: /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/C/com.apple.iconservices
11/12/15 14:54:07,670 configd[55]: arp_client_transmit(en0) failed, Network is down (50)
11/12/15 14:54:07,671 configd[55]: MANUAL en0: arp probe failed, arp_client_transmit(en0) failed, Network is down (50)
11/12/15 14:54:07,742 locationd[87]: Logging binary sensor data to /var/folders/zz/zyxvpxvq6csfxvn_n00000sm00006d/C/locationdSensors.bin
11/12/15 14:54:07,749 locationd[87]: NBB-Could not get UDID for stable refill timing, falling back on random
11/12/15 14:54:07,768 locationd[87]: locationd was started after an unclean shutdown
11/12/15 14:54:07,807 configd[55]: network changed.
11/12/15 14:54:07,809 configd[55]: network changed: DNS*
11/12/15 14:54:07,811 mDNSResponder[94]: AwdlD2d AwdlD2dInitialize: Initialized
11/12/15 14:54:07,814 mDNSResponder[94]: D2D_IPC: Loaded
11/12/15 14:54:07,814 mDNSResponder[94]: D2DInitialize succeeded
11/12/15 14:54:07,819 mDNSResponder[94]: 4: Listening for incoming Unix Domain Socket client requests
11/12/15 14:54:07,876 networkd[180]: networkd-412.20.3 pid 180
11/12/15 14:54:07,946 locationd[87]: Location icon should now be in state 'Inactive'
11/12/15 14:54:07,971 kdc[145]: KDC started
11/12/15 14:54:08,585 mdmclient[71]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
11/12/15 14:54:09,676 mdmclient[71]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
11/12/15 14:54:10,000 kernel[0]: Ethernet [nvenet]: Link up on en0, 1-Gigabit, Full-duplex, Symmetric flow-control, Debug [796d,0000,0de1,000d,cde1,3c00]
11/12/15 14:54:10,000 kernel[0]: 3b9aca00 00500030 NVEthernet::setLinkStatus - Active
11/12/15 14:54:10,664 WindowServer[168]: Server is starting up
11/12/15 14:54:10,780 mdmclient[71]: ApplePushService: Timed out making blocking call, failed to perform call via XPC connection to 'com.apple.apsd'
11/12/15 14:54:10,939 UserEventAgent[47]: nsurlsessiond_events plugin: adding token 1 for client softwareupdate_download_service
11/12/15 14:54:10,960 mDNSResponder[94]: mDNS_Register_internal: ERROR!! Tried to register AuthRecord 00007FBEEA010D60 iMac-di-Valerio.local. (Addr) that's already in the list
11/12/15 14:54:10,961 mDNSResponder[94]: mDNS_Register_internal: ERROR!! Tried to register AuthRecord 00007FBEEA0111F0 1.0.0.127.in-addr.arpa. (PTR) that's already in the list
11/12/15 14:54:10,961 mDNSResponder[94]: mDNS_Register_internal: ERROR!! Tried to register AuthRecord 00007FBEEA01CD60 iMac-di-Valerio.local. (AAAA) that's already in the list
11/12/15 14:54:10,961 mDNSResponder[94]: mDNS_Register_internal: ERROR!! Tried to register AuthRecord 00007FBEEA01D1F0 1.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.8.E.F.ip6.arpa. (PTR) that's already in the list
11/12/15 14:54:11,176 apsd[81]: CGSLookupServerRootPort: Failed to look up the port for "com.apple.windowserver.active" (1102)
11/12/15 14:54:11,245 apsd[81]: Unable to bootstrap_look_up connection port 'com.apple.askpermission.aps' for user 0: Unknown service name
11/12/15 14:54:11,248 apsd[81]: Attempt to set push wake topics without dark wake enabled: ()
11/12/15 14:54:11,248 apsd[81]: Unable to bootstrap_look_up connection port 'com.apple.askpermission.aps' for user 0: Unknown service name
11/12/15 14:54:11,249 apsd[81]: <APSConnectionServer: 0x7fe05bc61e00> Invalid mach port - Cleaning up this named port's topics. com.apple.askpermission.aps
11/12/15 14:54:12,676 mds[63]: (FMW.Normal:1428) FMW 0 0
11/12/15 14:54:12,685 mds[63]: (Volume.Normal:2464) volume:0x7ff8f482b600 ********** Bootstrapped Creating a default store:0 SpotLoc:(null) SpotVerLoc:(null) occlude:0 /
11/12/15 14:54:14,000 kernel[0]: in func createVirtualInterface ifRole = 1
11/12/15 14:54:14,000 kernel[0]: AirPort_Brcm4331_P2PInterface::init name <p2p0> role 1
11/12/15 14:54:14,000 kernel[0]: AirPort_Brcm4331_P2PInterface::init <p2p> role 1
11/12/15 14:54:14,000 kernel[0]: Created virtif 0xffffff8027ffe800 p2p0
11/12/15 14:54:14,044 airportd[60]: airportdProcessDLILEvent: en1 attached (down)
11/12/15 14:54:14,437 configd[55]: network changed: v4(en0+:192.168.1.4) DNS+ Proxy+ SMB
11/12/15 14:54:14,448 mDNSResponder[94]: mDNS_RegisterInterface: Frequent transitions for interface en0 (FE80:0000:0000:0000:0223:DFFF:FE9A:B7AE)
11/12/15 14:54:15,863 sntp[194]: time set +0.878579 s
11/12/15 14:54:15,918 ntpd[185]: peer time.euro.apple.com @ 17.253.54.125
11/12/15 14:54:15,966 ntpd[185]: drift PPM:0.000 -> -48.068
11/12/15 14:54:15,989 stackshot[96]: Timed out waiting for IOKit to finish matching.
11/12/15 14:54:16,000 kernel[0]: AirPort: Link Down on en1. Reason 8 (Disassociated because station leaving).
11/12/15 14:54:16,000 kernel[0]: en1::IO80211Interface::postMessage bssid changed
11/12/15 14:54:16,800 airportd[60]: _handleLinkEvent: WiFi is not powered. Resetting state variables.
11/12/15 14:54:17,029 blued[90]: Logging disabled
11/12/15 14:54:22,125 apsd[81]: CGSLookupServerRootPort: Failed to look up the port for "com.apple.windowserver.active" (1102)
11/12/15 14:54:24,000 kernel[0]: [AGPM Controller] build GPUDict by Vendor10deDevice0655
11/12/15 14:54:24,091 WindowServer[168]: Session 257 retained (2 references)
11/12/15 14:54:24,091 WindowServer[168]: Session 257 released (1 references)
11/12/15 14:54:24,114 WindowServer[168]: Session 257 retained (2 references)
11/12/15 14:54:24,120 WindowServer[168]: init_page_flip: page flip mode is on
11/12/15 14:54:25,008 WindowServer[168]: Found 36 modes for display 0x00000000 [36, 0]
11/12/15 14:54:25,011 WindowServer[168]: Found 1 modes for display 0x00000000 [1, 0]
11/12/15 14:54:25,012 WindowServer[168]: mux_initialize: Couldn't find any matches
11/12/15 14:54:25,018 WindowServer[168]: Found 36 modes for display 0x00000000 [36, 0]
11/12/15 14:54:25,023 WindowServer[168]: Found 1 modes for display 0x00000000 [1, 0]
11/12/15 14:54:25,079 WindowServer[168]: WSMachineUsesNewStyleMirroring: false
11/12/15 14:54:25,079 WindowServer[168]: Display 0x04272580: GL mask 0x1; bounds (0, 0)[1920 x 1200], 36 modes available
Main, Active, on-line, enabled, built-in, boot, Vendor 610, Model 9c96, S/N 0, Unit 0, Rotation 0
UUID 0xe63f6b7955a5afe52eb2e8859200a251
11/12/15 14:54:25,079 WindowServer[168]: Display 0x003f003d: GL mask 0x2; bounds (0, 0)[0 x 0], 1 modes available
off-line, enabled, Vendor ffffffff, Model ffffffff, S/N ffffffff, Unit 1, Rotation 0
UUID 0xffffffffffffffffffffffffffffffff
11/12/15 14:54:25,080 WindowServer[168]: Set a breakpoint at CGSLogError to catch errors as they are logged.
11/12/15 14:54:25,080 WindowServer[168]: WSSetWindowTransform: Singular matrix
11/12/15 14:54:25,082 WindowServer[168]: Display 0x04272580: GL mask 0x1; bounds (0, 0)[1920 x 1200], 36 modes available
11/12/15 14:54:25,083 WindowServer[168]: Display 0x003f003d: GL mask 0x2; bounds (2944, 0)[1 x 1], 1 modes available
11/12/15 14:54:25,083 WindowServer[168]: CGXPerformInitialDisplayConfiguration
11/12/15 14:54:25,083 WindowServer[168]: Display 0x04272580: Unit 0; Vendor 0x610 Model 0x9c96 S/N 0 Dimensions 20.47 x 12.60; online enabled built-in, Bounds (0,0)[1920 x 1200], Rotation 0, Resolution 1
11/12/15 14:54:25,083 WindowServer[168]: Display 0x003f003d: Unit 1; Vendor 0xffffffff Model 0xffffffff S/N -1 Dimensions 0.00 x 0.00; offline enabled, Bounds (2944,0)[1 x 1], Rotation 0, Resolution 1
11/12/15 14:54:26,316 com.apple.xpc.launchd[1]: (com.apple.FileSyncAgent.PHD.isRunning) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:26,326 WindowServer[168]: GLCompositor: GL renderer id 0x0102260c, GL mask 0x00000003, accelerator 0x00003b9b, unit 0, caps QEX|MIPMAP, vram 256 MB
11/12/15 14:54:26,318 com.apple.xpc.launchd[1]: (com.apple.mbloginhelper.user) This key does not do anything: OnDemand
11/12/15 14:54:26,318 com.apple.xpc.launchd[1]: (com.apple.mbpluginhost.user) This key does not do anything: OnDemand
11/12/15 14:54:26,322 com.apple.xpc.launchd[1]: (com.apple.secd) This key does not do anything: OnDemand
11/12/15 14:54:26,322 com.apple.xpc.launchd[1]: (com.apple.secd) The ServiceIPC key is no longer respected. Please remove it.
11/12/15 14:54:26,323 com.apple.xpc.launchd[1]: (com.apple.speech.speechsynthesisd) This key does not do anything: OnDemand
11/12/15 14:54:26,326 com.apple.xpc.launchd[1]: (com.apple.TrustEvaluationAgent) This key does not do anything: OnDemand
11/12/15 14:54:26,327 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.domain.user.212) Could not read path: path = /Library/LaunchAgents/com.oracle.java.Java-Updater.plist, error = 2: No such file or directory
11/12/15 14:54:26,328 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.domain.user.212) Failed to bootstrap path: path = /Library/LaunchAgents/com.oracle.java.Java-Updater.plist, error = 2: No such file or directory
11/12/15 14:54:26,334 WindowServer[168]: GLCompositor: GL renderer id 0x0102260c, GL mask 0x00000003, texture max 8192, viewport max {8192, 8192}, extensions NPOT|GLSL|FLOAT
11/12/15 14:54:26,334 WindowServer[168]: GLCompositor enabled for tile size [256 x 256]
11/12/15 14:54:26,334 WindowServer[168]: CGXGLInitMipMap: mip map mode is on
11/12/15 14:54:27,080 WindowServer[168]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'. Run with arg = -discovery
11/12/15 14:54:29,339 WindowServer[168]: _CGXGLDisplayContextForDisplayDevice: acquired display context (0x7fea79c2ac30) - enabling OpenGL
11/12/15 14:54:30,661 com.apple.AmbientDisplayAgent[202]: AmbientDisplayAgent started
11/12/15 14:54:30,665 com.apple.AmbientDisplayAgent[202]: AMBD initializing devices
11/12/15 14:54:30,679 WindowServer[168]: CGXSetDisplayColorProfileAndTransfer: Display 0x04272580: Unit 0; ColorProfile { -31015789 }; TransferTable (256, 12)
11/12/15 14:54:30,680 com.apple.AmbientDisplayAgent[202]: AMBD Agent: xpc connection became invalid during event handler
11/12/15 14:54:30,684 com.apple.xpc.launchd[1]: (com.apple.AssistiveControl.running) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:30,685 com.apple.xpc.launchd[1]: (com.apple.btsa) This key does not do anything: OnDemand
11/12/15 14:54:30,686 com.apple.xpc.launchd[1]: (com.apple.coreservices.lsactivity) Unknown key for Boolean: DrainMessagesAfterFailedInit
11/12/15 14:54:30,687 com.apple.xpc.launchd[1]: (com.apple.helpd) This key does not do anything: OnDemand
11/12/15 14:54:30,691 com.apple.xpc.launchd[1]: (com.apple.noticeboard.agent) This key does not do anything: OnDemand
11/12/15 14:54:30,780 WindowServer[168]: CGXSetDisplayColorProfileAndTransfer: Display 0x04272580: Unit 0; ColorProfile { -31015789 }; TransferTable (256, 12)
11/12/15 14:54:30,694 com.apple.xpc.launchd[1]: (com.apple.speech.speechsynthesisd) This key does not do anything: OnDemand
11/12/15 14:54:30,695 com.apple.xpc.launchd[1]: (com.apple.inputswitcher.running) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:30,696 com.apple.xpc.launchd[1]: (com.apple.universalaccesscontrol.running) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:30,696 com.apple.xpc.launchd[1]: (com.apple.universalaccessd.running) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:30,805 com.apple.AmbientDisplayAgent[202]: AMBD Agent: xpc connection became invalid during event handler
11/12/15 14:54:30,697 com.apple.xpc.launchd[1]: (com.apple.UserEventAgent-LoginWindow) This service is defined to be constantly running and is inherently inefficient.
11/12/15 14:54:30,698 com.apple.xpc.launchd[1]: (com.apple.VoiceOver.running) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:30,699 com.apple.xpc.launchd[1]: (com.apple.ZoomWindow.running) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:30,806 DMProxy[200]: AMBD Services: connection interrupted: com.apple.AmbientDisplayAgent (Connection interrupted)
11/12/15 14:54:30,699 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.domain.user.loginwindow.98.4294967295) Could not read path: path = /Library/LaunchAgents/com.oracle.java.Java-Updater.plist, error = 2: No such file or directory
11/12/15 14:54:30,815 com.apple.AmbientDisplayAgent[202]: AmbientDisplayAgent started
11/12/15 14:54:30,728 PowerChime[207]: objc[207]: Class BUIPowerSource is implemented in both /System/Library/PrivateFrameworks/BatteryUIKit.framework/Versions/A/BatteryUIKit and /System/Library/CoreServices/PowerChime.app/Contents/MacOS/PowerChime. One of the two will be used. Which one is undefined.
11/12/15 14:54:30,819 com.apple.AmbientDisplayAgent[202]: AMBD initializing devices
11/12/15 14:54:30,822 mds[63]: (DiskStore.Normal:453) InstallResults.plist found
11/12/15 14:54:30,840 WindowServer[168]: CGXSetDisplayColorProfileAndTransfer: Display 0x04272580: Unit 0; ColorProfile { -31015789 }; TransferTable (256, 12)
11/12/15 14:54:30,842 com.apple.AmbientDisplayAgent[202]: AMBD Agent: xpc connection became invalid during event handler
11/12/15 14:54:31,014 loginwindow[98]: The current system was not found in the list of machines requiring a switch to a black background
11/12/15 14:54:31,028 com.apple.xpc.launchd[1]: (com.apple.DataDetectorsDynamicData) The JoinExistingSession key is only available to Application services.
11/12/15 14:54:31,030 com.apple.xpc.launchd[1]: (com.apple.appkit.xpc.sandboxedServiceRunner) The JoinExistingSession key is only available to Application services.
11/12/15 14:54:31,042 loginwindow[98]: Login Window Started Security Agent
11/12/15 14:54:31,075 askpermissiond[203]: objc[203]: Class FALogging is implemented in both /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/FamilyCircle and /System/Library/PrivateFrameworks/FamilyNotification.framework/Versions/A/FamilyNotification. One of the two will be used. Which one is undefined.
11/12/15 14:54:31,076 com.apple.SecurityServer[85]: Session 100005 created
11/12/15 14:54:31,138 lsregister[191]: LaunchServices: Begin database seeding
11/12/15 14:54:31,139 lsregister[191]: LaunchServices: Completed database seeding
11/12/15 14:54:31,150 SecurityAgent[213]: This is the first run
11/12/15 14:54:31,150 SecurityAgent[213]: MacBuddy was run = 0
11/12/15 14:54:31,168 SecurityAgent[213]: User info context values set for valeriosalsi
11/12/15 14:54:31,307 askpermissiond[203]: StoreTransport: Resetting APS Connection using environment name production
11/12/15 14:54:31,312 apsd[81]: Unable to bootstrap_look_up connection port 'com.apple.askpermission.aps' for user 0: Unknown service name
11/12/15 14:54:31,339 SecurityAgent[213]: Login Window login proceeding
11/12/15 14:54:31,451 loginwindow[98]: Login Window - Returned from Security Agent
11/12/15 14:54:31,464 loginwindow[98]: USER_PROCESS: 98 console
11/12/15 14:54:31,481 mds[63]: (Volume.Normal:2980) Spotlight is disabled on /Users/valeriosalsi 089422DA-0157-4D60-9BA0-9B438B71DC6E. This can impact search in Mail and other applications
11/12/15 14:54:31,482 com.apple.xpc.launchd[1]: (com.apple.FileSyncAgent.PHD.isRunning) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:31,483 com.apple.xpc.launchd[1]: (com.apple.mbloginhelper.user) This key does not do anything: OnDemand
11/12/15 14:54:31,483 com.apple.xpc.launchd[1]: (com.apple.mbpluginhost.user) This key does not do anything: OnDemand
11/12/15 14:54:31,487 com.apple.xpc.launchd[1]: (com.apple.secd) This key does not do anything: OnDemand
11/12/15 14:54:31,487 com.apple.xpc.launchd[1]: (com.apple.secd) The ServiceIPC key is no longer respected. Please remove it.
11/12/15 14:54:31,487 com.apple.xpc.launchd[1]: (com.apple.speech.speechsynthesisd) This key does not do anything: OnDemand
11/12/15 14:54:31,488 com.apple.xpc.launchd[1]: (com.apple.TrustEvaluationAgent) This key does not do anything: OnDemand
11/12/15 14:54:31,489 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.domain.user.501) Could not read path: path = /Library/LaunchAgents/com.oracle.java.Java-Updater.plist, error = 2: No such file or directory
11/12/15 14:54:31,490 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.domain.user.501) Failed to bootstrap path: path = /Library/LaunchAgents/com.oracle.java.Java-Updater.plist, error = 2: No such file or directory
11/12/15 14:54:31,504 UserEventAgent[209]: Failed to copy info dictionary for bundle /System/Library/UserEventPlugins/alfUIplugin.plugin
11/12/15 14:54:31,521 UserEventAgent[209]: user agent networkd: built May 12 2015 20:37:54
11/12/15 14:54:31,583 WiFiAgent[210]: securityd_message_with_reply_sync Failed to talk to secd after 4 attempts.
11/12/15 14:54:31,000 kernel[0]: AppleKeyStore:Sending lock change 0 for handle -501
11/12/15 14:54:31,636 com.apple.xpc.launchd[1]: (com.apple.AssistiveControl.running) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:31,636 com.apple.xpc.launchd[1]: (com.apple.btsa) This key does not do anything: OnDemand
11/12/15 14:54:31,637 com.apple.xpc.launchd[1]: (com.apple.coreservices.lsactivity) Unknown key for Boolean: DrainMessagesAfterFailedInit
11/12/15 14:54:31,637 com.apple.xpc.launchd[1]: (com.apple.coreservices.uiagent) This key does not do anything: OnDemand
11/12/15 14:54:31,638 com.apple.xpc.launchd[1]: (com.apple.diagnostics_agent) This service is defined to be constantly running and is inherently inefficient.
11/12/15 14:54:31,638 com.apple.xpc.launchd[1]: (com.apple.dock.fullscreen) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:31,638 com.apple.xpc.launchd[1]: (com.apple.dock.server) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:31,638 com.apple.xpc.launchd[1]: (com.apple.dock.notificationcenter) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:31,638 com.apple.xpc.launchd[1]: (com.apple.dock.appstore) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:31,638 com.apple.xpc.launchd[1]: (com.apple.dock.remotedesktoppicture) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:31,638 com.apple.xpc.launchd[1]: (com.apple.dock.launchpad) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:31,639 com.apple.xpc.launchd[1]: (com.apple.dock.downloads) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:31,639 com.apple.xpc.launchd[1]: (com.apple.EscrowSecurityAlert) Unknown key for string: seatbelt-profiles
11/12/15 14:54:31,640 com.apple.xpc.launchd[1]: (com.apple.FontRegistryUIAgent) This key does not do anything: OnDemand
11/12/15 14:54:31,640 com.apple.xpc.launchd[1]: (com.apple.ATS.FontValidator) This key does not do anything: OnDemand
11/12/15 14:54:31,640 com.apple.xpc.launchd[1]: (com.apple.Finder) ThrottleInterval set to zero. You're not that important. Ignoring.
11/12/15 14:54:31,640 com.apple.xpc.launchd[1]: (com.apple.ATS.FontValidatorConduit) This key does not do anything: OnDemand
11/12/15 14:54:31,640 com.apple.xpc.launchd[1]: (com.apple.gamed) The JetsamProperties key is not available on this platform.
11/12/15 14:54:31,640 com.apple.xpc.launchd[1]: (com.apple.gamed) This key does not do anything: OnDemand
11/12/15 14:54:31,640 com.apple.xpc.launchd[1]: (com.apple.gamed) The ServiceIPC key is no longer respected. Please remove it.
11/12/15 14:54:31,641 com.apple.xpc.launchd[1]: (com.apple.helpd) This key does not do anything: OnDemand
11/12/15 14:54:31,642 com.apple.xpc.launchd[1]: (com.apple.installd.user) This key does not do anything: OnDemand
11/12/15 14:54:31,643 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.user.501.100005.Aqua) Caller tried to hijack service: path = /System/Library/LaunchAgents/com.apple.mbpluginhost.user.plist, caller = loginwindow.98
11/12/15 14:54:31,645 com.apple.xpc.launchd[1]: (com.apple.midiserver.io) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:31,645 com.apple.xpc.launchd[1]: (com.apple.noticeboard.agent) This key does not do anything: OnDemand
11/12/15 14:54:31,645 com.apple.xpc.launchd[1]: (com.apple.notificationcenterui.alerts) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:31,645 com.apple.xpc.launchd[1]: (com.apple.notificationcenterui.tcc) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:31,645 com.apple.xpc.launchd[1]: (com.apple.notificationcenterui.agent) This service is defined to be constantly running and is inherently inefficient.
11/12/15 14:54:31,646 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.user.501.100005.Aqua) Caller tried to hijack service: path = /System/Library/LaunchAgents/com.apple.pluginkit.pkd.plist, caller = loginwindow.98
11/12/15 14:54:31,647 com.apple.xpc.launchd[1]: (com.apple.PubSub.Agent) The ServiceIPC key is no longer respected. Please remove it.
11/12/15 14:54:31,648 com.apple.xpc.launchd[1]: (com.apple.quicklook.ui.helper.active) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:31,649 com.apple.xpc.launchd[1]: (com.apple.ReportCrash) The DrainMessagesOnCrash key is not yet implemented. If you rely on this key, please file a bug.
11/12/15 14:54:31,649 com.apple.xpc.launchd[1]: (com.apple.ReportCrash.Self) The DrainMessagesOnCrash key is not yet implemented. If you rely on this key, please file a bug.
11/12/15 14:54:31,649 com.apple.xpc.launchd[1]: (com.apple.rtcreportingd) The UserName key is not supported for non-System services.
11/12/15 14:54:31,649 com.apple.xpc.launchd[1]: (com.apple.SafariCloudHistoryPushAgent) The UserName key is not supported for non-System services.
11/12/15 14:54:31,650 com.apple.xpc.launchd[1]: (com.apple.sharingd) This service is defined to be constantly running and is inherently inefficient.
11/12/15 14:54:31,650 com.apple.xpc.launchd[1]: (com.apple.soagent) Invalid type for event (event/type): events/array
11/12/15 14:54:31,650 com.apple.xpc.launchd[1]: (com.apple.soagent) Invalid type for event (event/type): bundleid/string
11/12/15 14:54:31,651 com.apple.xpc.launchd[1]: (com.apple.speech.speechdatainstallerd) This key does not do anything: OnDemand
11/12/15 14:54:31,651 com.apple.xpc.launchd[1]: (com.apple.ssinvitationagent) This key does not do anything: OnDemand
11/12/15 14:54:31,652 com.apple.xpc.launchd[1]: (com.apple.systemuiserver.ServiceProvider) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:31,652 com.apple.xpc.launchd[1]: (com.apple.dockextra.server) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:31,652 com.apple.xpc.launchd[1]: (com.apple.SUISMessaging) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:31,652 com.apple.xpc.launchd[1]: (com.apple.ipodserver) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:31,652 com.apple.xpc.launchd[1]: (com.apple.systemuiserver.screencapture) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:31,652 com.apple.xpc.launchd[1]: (com.apple.tsm.uiserver) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:31,652 com.apple.xpc.launchd[1]: (com.apple.dockling.server) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:31,652 com.apple.xpc.launchd[1]: (com.apple.window_proxies.startup) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:31,652 com.apple.xpc.launchd[1]: (com.apple.window_proxies) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:31,653 com.apple.xpc.launchd[1]: (com.apple.inputswitcher.running) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:31,653 com.apple.xpc.launchd[1]: (com.apple.universalaccesscontrol.running) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:31,653 com.apple.xpc.launchd[1]: (com.apple.universalaccessd.running) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:31,653 com.apple.xpc.launchd[1]: (com.apple.UserEventAgent-Aqua) This service is defined to be constantly running and is inherently inefficient.
11/12/15 14:54:31,654 com.apple.xpc.launchd[1]: (com.apple.usernoted) This service is defined to be constantly running and is inherently inefficient.
11/12/15 14:54:31,654 com.apple.xpc.launchd[1]: (com.apple.VoiceOver.running) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:31,655 com.apple.xpc.launchd[1]: (com.apple.ZoomWindow.running) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:31,655 com.apple.xpc.launchd[1]: (org.openbsd.ssh-agent) The ServiceIPC key is no longer respected. Please remove it.
11/12/15 14:54:31,655 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.user.501.100005.Aqua) Could not read path: path = /Library/LaunchAgents/com.oracle.java.Java-Updater.plist, error = 2: No such file or directory
11/12/15 14:54:31,656 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.user.501.100005.Aqua) Failed to bootstrap path: path = /System/Library/LaunchAgents/com.apple.pluginkit.pkd.plist, error = 17: File exists
11/12/15 14:54:31,656 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.user.501.100005.Aqua) Failed to bootstrap path: path = /Library/LaunchAgents/com.oracle.java.Java-Updater.plist, error = 2: No such file or directory
11/12/15 14:54:31,656 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.user.501.100005.Aqua) Failed to bootstrap path: path = /System/Library/LaunchAgents/com.apple.mbpluginhost.user.plist, error = 17: File exists
11/12/15 14:54:31,681 distnoted[220]: # distnote server agent absolute time: 57.845314662 civil time: Fri Dec 11 14:54:31 2015 pid: 220 uid: 501 root: no
11/12/15 14:54:31,908 com.apple.xpc.launchd[1]: (com.apple.DataDetectorsDynamicData) The JoinExistingSession key is only available to Application services.
11/12/15 14:54:31,910 com.apple.xpc.launchd[1]: (com.apple.appkit.xpc.sandboxedServiceRunner) The JoinExistingSession key is only available to Application services.
11/12/15 14:54:31,935 WindowServer[168]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'. Run with arg = -login
11/12/15 14:54:31,947 UserEventAgent[218]: Failed to copy info dictionary for bundle /System/Library/UserEventPlugins/alfUIplugin.plugin
11/12/15 14:54:31,964 UserEventAgent[218]: com.apple.TMHelperAgent.SetupOffer enabled
11/12/15 14:54:32,065 UserEventAgent[218]: user agent networkd: built May 12 2015 20:37:54
11/12/15 14:54:32,115 lsregister[223]: LaunchServices: Begin database seeding
11/12/15 14:54:32,115 lsregister[223]: LaunchServices: Completed database seeding
11/12/15 14:54:32,131 otherbsd[219]: Could not copy LoginItems URL.
11/12/15 14:54:32,250 UserEventAgent[218]: received an unknown event from daemon
11/12/15 14:54:32,285 locationd[228]: Logging binary sensor data to /var/folders/zz/zyxvpxvq6csfxvn_n00000sm00006d/C/locationdSensors.bin
11/12/15 14:54:32,291 locationd[228]: NBB-Could not get UDID for stable refill timing, falling back on random
11/12/15 14:54:32,305 locationd[228]: Location icon should now be in state 'Inactive'
11/12/15 14:54:32,382 com.apple.xpc.launchd[1]: (com.apple.imfoundation.IMRemoteURLConnectionAgent) The _DirtyJetsamMemoryLimit key is not available on this platform.
11/12/15 14:54:32,385 DMProxy[224]: AMBD Services: connection interrupted: com.apple.AmbientDisplayAgent (Connection interrupted)
11/12/15 14:54:32,390 com.apple.AmbientDisplayAgent[202]: AmbientDisplayAgent started
11/12/15 14:54:32,394 com.apple.AmbientDisplayAgent[202]: AMBD initializing devices
11/12/15 14:54:32,399 secinitd[230]: UID[501]: cache loaded: /System/Library/Caches/com.apple.app-sandbox-cache.plist
11/12/15 14:54:32,405 com.apple.SecurityServer[85]: Session 100007 created
11/12/15 14:54:32,416 WindowServer[168]: CGXSetDisplayColorProfileAndTransfer: Display 0x04272580: Unit 0; ColorProfile { -31015789 }; TransferTable (256, 12)
11/12/15 14:54:32,441 iconservicesagent[231]: iconservicesagent launched.
11/12/15 14:54:32,445 iconservicesagent[231]: Starting service with cache path: /var/folders/nc/n9zf_cr94pn8dwkrth890b0h0000gn/C/com.apple.iconservices
11/12/15 14:54:32,513 com.apple.AmbientDisplayAgent[202]: AMBD Agent: xpc connection became invalid during event handler
11/12/15 14:54:32,738 com.apple.xpc.launchd[1]: (com.apple.imfoundation.IMRemoteURLConnectionAgent) The _DirtyJetsamMemoryLimit key is not available on this platform.
11/12/15 14:54:32,753 pboard[238]: Attempt to unlink previous shared memory during startup returned an error. Continuing...
11/12/15 14:54:32,858 CalendarAgent[229]: Exception fetching ABCDContact in context <ABManagedObjectContext: 0x7f97e8da7d30>: keypath birthdayComponents not found in entity <NSSQLEntity ABCDContact id=21>
11/12/15 14:54:32,858 CalendarAgent[229]: Error fetching ABCDContact in context <ABManagedObjectContext: 0x7f97e8da7d30>: (null) (null)
11/12/15 14:54:33,169 com.apple.xpc.launchd[1]: (com.apple.imfoundation.IMRemoteURLConnectionAgent) The _DirtyJetsamMemoryLimit key is not available on this platform.
11/12/15 14:54:36,086 BezelServices 250.15[98]: ASSERTION FAILED: dvcAddrRef != ((void *)0) -[DriverServices getDeviceAddress:] line: 2727
11/12/15 14:54:36,087 BezelServices 250.15[98]: ASSERTION FAILED: dvcAddrRef != ((void *)0) -[DriverServices getDeviceAddress:] line: 2727
11/12/15 14:54:36,208 com.apple.xpc.launchd[1]: (com.apple.FileSyncAgent.PHD.isRunning) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:36,283 com.apple.audio.DriverHelper[254]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class AMDRadeonX4000_AMDAccelDevice.
11/12/15 14:54:36,283 com.apple.audio.DriverHelper[254]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class AMDRadeonX4000_AMDAccelSharedUserClient.
11/12/15 14:54:36,283 com.apple.audio.DriverHelper[254]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class AMDSIVideoContext.
11/12/15 14:54:36,283 com.apple.audio.DriverHelper[254]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class Gen6DVDContext.
11/12/15 14:54:36,284 com.apple.audio.DriverHelper[254]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IGAccelDevice.
11/12/15 14:54:36,284 com.apple.audio.DriverHelper[254]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IGAccelSharedUserClient.
11/12/15 14:54:36,211 com.apple.xpc.launchd[1]: (com.apple.mbloginhelper.user) This key does not do anything: OnDemand
11/12/15 14:54:36,211 com.apple.xpc.launchd[1]: (com.apple.mbpluginhost.user) This key does not do anything: OnDemand
11/12/15 14:54:36,218 com.apple.xpc.launchd[1]: (com.apple.secd) This key does not do anything: OnDemand
11/12/15 14:54:36,218 com.apple.xpc.launchd[1]: (com.apple.secd) The ServiceIPC key is no longer respected. Please remove it.
11/12/15 14:54:36,219 com.apple.xpc.launchd[1]: (com.apple.speech.speechsynthesisd) This key does not do anything: OnDemand
11/12/15 14:54:36,222 com.apple.xpc.launchd[1]: (com.apple.TrustEvaluationAgent) This key does not do anything: OnDemand
11/12/15 14:54:36,225 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.domain.user.202) Could not read path: path = /Library/LaunchAgents/com.oracle.java.Java-Updater.plist, error = 2: No such file or directory
11/12/15 14:54:36,225 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.domain.user.202) Failed to bootstrap path: path = /Library/LaunchAgents/com.oracle.java.Java-Updater.plist, error = 2: No such file or directory
11/12/15 14:54:36,226 com.apple.xpc.launchd[1]: (com.apple.DataDetectorsDynamicData) The JoinExistingSession key is only available to Application services.
11/12/15 14:54:36,284 com.apple.audio.DriverHelper[254]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IGAccelVideoContextMain.
11/12/15 14:54:36,286 com.apple.audio.DriverHelper[254]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IGAccelVideoContextMedia.
11/12/15 14:54:36,286 com.apple.audio.DriverHelper[254]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IGAccelVideoContextVEBox.
11/12/15 14:54:36,286 com.apple.audio.DriverHelper[254]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IOBluetoothDeviceUserClient.
11/12/15 14:54:36,286 com.apple.audio.DriverHelper[254]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IOHIDParamUserClient.
11/12/15 14:54:36,286 com.apple.audio.DriverHelper[254]: The plug-in named AirPlay.driver requires extending the sandbox for the IOKit user-client class IOSurfaceRootUserClient.
11/12/15 14:54:36,287 com.apple.audio.DriverHelper[254]: The plug-in named AirPlay.driver requires extending the sandbox for the mach service named com.apple.AirPlayXPCHelper.
11/12/15 14:54:36,287 com.apple.audio.DriverHelper[254]: The plug-in named AirPlay.driver requires extending the sandbox for the mach service named com.apple.wirelessproxd.
11/12/15 14:54:36,293 com.apple.xpc.launchd[1]: (com.apple.appkit.xpc.sandboxedServiceRunner) The JoinExistingSession key is only available to Application services.
11/12/15 14:54:36,436 mds[63]: (Server.Warning:445) No stores registered for metascope "kMDQueryScopeComputer"
11/12/15 14:54:36,504 sharingd[257]: 14:54:36.502 : Starting Up...
11/12/15 14:54:36,508 sharingd[257]: 14:54:36.507 : Device Capabilities (Handoff:NO, Instant Hotspot:NO, AirDrop:NO, Legacy AirDrop:YES, Remote Disc:NO)
11/12/15 14:54:36,754 coreaudiod[251]: 2015-12-11 02:54:36.746217 PM [AirPlay] BTLE discovery removing all devices
11/12/15 14:54:36,756 coreaudiod[251]: 2015-12-11 02:54:36.756187 PM [AirPlay] Resetting AWDL traffic registration.
11/12/15 14:54:36,757 coreaudiod[251]: 2015-12-11 02:54:36.756513 PM [AirPlay] Deregister AirPlay traffic for AWDL at MAC 00:00:00:00:00:00 with target infra non critical PeerIndication=0 err=-3900
11/12/15 14:54:36,781 com.apple.audio.DriverHelper[254]: The plug-in named BluetoothAudioPlugIn.driver requires extending the sandbox for the IOKit user-client class IOBluetoothDeviceUserClient.
11/12/15 14:54:36,781 com.apple.audio.DriverHelper[254]: The plug-in named BluetoothAudioPlugIn.driver requires extending the sandbox for the mach service named com.apple.blued.
11/12/15 14:54:36,781 com.apple.audio.DriverHelper[254]: The plug-in named BluetoothAudioPlugIn.driver requires extending the sandbox for the mach service named com.apple.bluetoothaudiod.
11/12/15 14:54:36,817 coreaudiod[251]: Logging disabled
11/12/15 14:54:36,867 coreaudiod[251]: 2015-12-11 02:54:36.866540 PM [AirPlay] AirPlay: Performing audio format change for 4 (AP Out) to PCM/44100/16/2 for output and for input
11/12/15 14:54:36,935 Finder[250]: assertion failed: 14F1505: libxpc.dylib + 62447 [5C829202-962E-3744-8B50-00D38CC88E84]: 0x89
11/12/15 14:54:36,901 bluetoothaudiod[261]: Logging disabled
11/12/15 14:54:37,186 SystemUIServer[249]: Error loading /System/Library/CoreServices/Search.bundle/Contents/MacOS/Search: dlopen(/System/Library/CoreServices/Search.bundle/Contents/MacOS/Search, 265): no suitable image found. Did find:
/System/Library/CoreServices/Search.bundle/Contents/MacOS/Search: open() failed with errno=13
11/12/15 14:54:37,214 pkd[258]: enabling pid=250 for plug-in com.adobe.accmac.ACCFinderSync(2.0.0.734) 98BE3CF8-BACA-4DF6-868E-70A7E0CD0C04 /Applications/Utilities/Adobe Creative Cloud/CoreSync/Core Sync.app/Contents/PlugIns/ACCFinderSync.appex
11/12/15 14:54:37,375 SystemUIServer[249]: Cannot find executable for CFBundle 0x7ff11ac17030 </System/Library/CoreServices/Menu Extras/Clock.menu> (not loaded)
11/12/15 14:54:37,451 SystemUIServer[249]: Cannot find executable for CFBundle 0x7ff11ac1b070 </System/Library/CoreServices/Menu Extras/Volume.menu> (not loaded)
11/12/15 14:54:37,526 taskgated[106]: no application identifier provided, can't use provisioning profiles [pid=264]
11/12/15 14:54:37,864 ACCFinderSync[264]: Failed to connect (colorGridView) outlet from (NSApplication) to (NSColorPickerGridView): missing setter or instance variable
11/12/15 14:54:37,864 ACCFinderSync[264]: Failed to connect (view) outlet from (NSApplication) to (NSColorPickerGridView): missing setter or instance variable
11/12/15 14:54:37,878 com.apple.xpc.launchd[1]: (com.apple.FileSyncAgent.PHD.isRunning) The HideUntilCheckIn property is an architectural performance issue. Please transition away from it.
11/12/15 14:54:37,880 com.apple.xpc.launchd[1]: (com.apple.mbloginhelper.user) This key does not do anything: OnDemand
11/12/15 14:54:37,880 com.apple.xpc.launchd[1]: (com.apple.mbpluginhost.user) This key does not do anything: OnDemand
11/12/15 14:54:37,883 com.apple.xpc.launchd[1]: (com.apple.appkit.xpc.sandboxedServiceRunner) The JoinExistingSession key is only available to Application services.
11/12/15 14:54:37,888 com.apple.xpc.launchd[1]: (com.apple.secd) This key does not do anything: OnDemand
11/12/15 14:54:37,888 com.apple.xpc.launchd[1]: (com.apple.secd) The ServiceIPC key is no longer respected. Please remove it.
11/12/15 14:54:37,889 com.apple.xpc.launchd[1]: (com.apple.speech.speechsynthesisd) This key does not do anything: OnDemand
11/12/15 14:54:37,890 com.apple.xpc.launchd[1]: (com.apple.TrustEvaluationAgent) This key does not do anything: OnDemand
11/12/15 14:54:37,891 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.domain.user.55) Could not read path: path = /Library/LaunchAgents/com.oracle.java.Java-Updater.plist, error = 2: No such file or directory
11/12/15 14:54:37,891 com.apple.xpc.launchd[1]: (com.apple.xpc.launchd.domain.user.55) Failed to bootstrap path: path = /Library/LaunchAgents/com.oracle.java.Java-Updater.plist, error = 2: No such file or directory
11/12/15 14:54:37,891 com.apple.xpc.launchd[1]: (com.apple.DataDetectorsDynamicData) The JoinExistingSession key is only available to Application services.
11/12/15 14:54:38,000 kernel[0]: Sandbox: appleeventsd(54) deny file-read-metadata /Library
11/12/15 14:54:38,000 kernel[0]: Sandbox: appleeventsd(54) deny mach-lookup com.apple.ocspd
11/12/15 14:54:38,326 WindowServer[168]: **DMPROXY** (2) Found `/System/Library/CoreServices/DMProxy'. Run with arg = -login
11/12/15 14:54:38,347 DMProxy[270]: AMBD Services: connection interrupted: com.apple.AmbientDisplayAgent (Connection interrupted)
11/12/15 14:54:38,354 com.apple.AmbientDisplayAgent[202]: AmbientDisplayAgent started
11/12/15 14:54:38,358 com.apple.AmbientDisplayAgent[202]: AMBD initializing devices
11/12/15 14:54:38,373 WindowServer[168]: CGXSetDisplayColorProfileAndTransfer: Display 0x04272580: Unit 0; ColorProfile { -31015789 }; TransferTable (256, 12)
11/12/15 14:54:38,375 com.apple.AmbientDisplayAgent[202]: AMBD Agent: xpc connection became invalid during event handler
11/12/15 14:54:38,564 coresymbolicationd[269]: /System/Library/Caches/com.apple.coresymbolicationd/data did not validate, resetting cache
11/12/15 14:54:38,760 mds[63]: (Server.Warning:445) No stores registered for metascope "kMDQueryScopeComputer"
11/12/15 14:54:39,431 SystemUIServer[249]: Could not find image named 'greenmarker'.
11/12/15 14:54:39,000 kernel[0]: firefox (map: 0xffffff802a5062d0) triggered DYLD shared region unnest for map: 0xffffff802a5062d0, region 0x7fff93c00000->0x7fff93e00000. While not abnormal for debuggers, this increases system memory footprint until the target exits.
11/12/15 14:54:40,048 sharingd[257]: 14:54:40.047 : No delegate parameters from account, account exists = NO
11/12/15 14:54:40,049 sharingd[257]: 14:54:40.048 : Tethering: Identifier needs fixing
11/12/15 14:54:40,052 sharingd[257]: 14:54:40.051 : No delegate parameters from account, account exists = NO
11/12/15 14:54:40,056 sharingd[257]: 14:54:40.055 : No delegate parameters from account, account exists = NO
11/12/15 14:54:40,192 Console[246]: Failed to connect (_consoleX) outlet from (NSApplication) to (ConsoleX): missing setter or instance variable
11/12/15 14:54:40,319 Finder[250]: CoreDockSetTrashFull returned error -4956
11/12/15 14:54:40,918 ACCFinderSync[264]: building singleton CFMessage dispatcher
11/12/15 14:54:40,919 ACCFinderSync[264]: Dispatcher: no remote port found for com.adobe.accmac.explinder.coresync
11/12/15 14:54:40,920 ACCFinderSync[264]: Dispatcher: no remote port found for com.adobe.accmac.explinder.coresync
11/12/15 14:54:41,604 identityservicesd[272]: [Warning] DeviceHeartbeat - Failed loading device heartbeat data from keychain -25300
11/12/15 14:54:41,783 WindowServer[168]: disable_update_timeout: UI updates were forcibly disabled by application "Finder" for over 1.00 seconds. Server has re-enabled them.
11/12/15 14:54:41,899 sandboxd[268]: ([54]) appleeventsd(54) deny file-read-metadata /Library
11/12/15 14:54:42,198 identityservicesd[272]: <IMMacNotificationCenterManager: 0x7f840ac87650>: Configuring notification center for identifier: com.apple.iChat topics: (
11/12/15 14:54:42,245 sandboxd[268]: ([54]) appleeventsd(54) deny file-read-metadata /Library
11/12/15 14:54:42,268 WindowServer[168]: common_reenable_update: UI updates were finally reenabled by application "Finder" after 1.49 seconds (server forcibly re-enabled them after 1.00 seconds)
11/12/15 14:54:43,735 identityservicesd[272]: <IMMacNotificationCenterManager: 0x7f840ac87650>: NC Disabled: NO
11/12/15 14:54:44,033 identityservicesd[272]: <IMMacNotificationCenterManager: 0x7f840ac87650>: DND Enabled: NO
11/12/15 14:54:44,033 identityservicesd[272]: <IMMacNotificationCenterManager: 0x7f840ac87650>: Updating enabled: YES (Topics: (
11/12/15 14:54:44,044 sharingd[257]: [Warning] Services all disappeared, removing all dependent devices
11/12/15 14:54:44,430 com.apple.xpc.launchd[1]: (com.apple.imdmessageservices.IMDMessageServicesAgent) The _DirtyJetsamMemoryLimit key is not available on this platform.
11/12/15 14:54:44,432 com.apple.xpc.launchd[1]: (com.apple.imfoundation.IMRemoteURLConnectionAgent) The _DirtyJetsamMemoryLimit key is not available on this platform.
11/12/15 14:54:44,458 logind[99]: -[SessionManager getClient:withRole:inAuditSession:]:241: ERROR: No session dictionary for audit session 100007
11/12/15 14:54:44,459 logind[99]: _SMGetSessionAgent:73: ERROR: __SMGetClientForAuditSessionAgent failed 2
11/12/15 14:54:44,459 IMDPersistenceAgent[281]: SACShieldWindowShowing:925: ERROR: NULL response
11/12/15 14:54:44,566 com.apple.xpc.launchd[1]: (com.apple.imfoundation.IMRemoteURLConnectionAgent) The _DirtyJetsamMemoryLimit key is not available on this platform.
11/12/15 14:54:44,996 sandboxd[268]: ([54]) appleeventsd(54) deny file-read-metadata /Library
11/12/15 14:54:45,000 kernel[0]: Sandbox: Finder(250) System Policy: deny file-write-unlink /Users/valeriosalsi/Library/Saved Application State/com.apple.finder.savedState/restorecount.plist
11/12/15 14:54:45,686 com.apple.xpc.launchd[1]: (com.apple.imtranscoding.IMTranscoderAgent) The _DirtyJetsamPriority key is not available on this platform.
11/12/15 14:54:45,686 com.apple.xpc.launchd[1]: (com.apple.imtranscoding.IMTranscoderAgent) The _DirtyJetsamMemoryLimit key is not available on this platform.
11/12/15 14:54:46,201 sandboxd[268]: ([54]) appleeventsd(54) deny file-read-metadata /Library/Keychains/System.keychain
11/12/15 14:54:46,227 imagent[279]: [Warning] SMSServiceSession: Error no IDS Service available for SMS Relay
11/12/15 14:54:46,810 sandboxd[268]: ([54]) appleeventsd(54) deny file-read-metadata /Library
11/12/15 14:54:47,328 sandboxd[268]: ([54]) appleeventsd(54) deny file-read-metadata /Library
11/12/15 14:54:47,555 fmfd[286]: Initialized sandbox
11/12/15 14:54:47,578 com.apple.xpc.launchd[1]: (com.apple.lakitu) The JoinExistingSession key is only available to Application services.
11/12/15 14:54:47,579 com.apple.xpc.launchd[1]: (com.apple.accounts.dom) The _DirtyJetsamMemoryLimit key is not available on this platform.
11/12/15 14:54:47,579 com.apple.xpc.launchd[1]: (com.apple.imfoundation.IMRemoteURLConnectionAgent) The _DirtyJetsamMemoryLimit key is not available on this platform.
11/12/15 14:54:47,772 callservicesd[276]: Failed to get the bundle id
11/12/15 14:54:48,372 com.apple.iCloudHelper[289]: objc[289]: Class FALogging is implemented in both /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/FamilyCircle and /System/Library/PrivateFrameworks/FamilyNotification.framework/Versions/A/FamilyNotification. One of the two will be used. Which one is undefined.
11/12/15 14:54:48,381 com.apple.xpc.launchd[1]: (com.apple.imfoundation.IMRemoteURLConnectionAgent) The _DirtyJetsamMemoryLimit key is not available on this platform.
11/12/15 14:54:49,039 WindowServer[168]: disable_update_timeout: UI updates were forcibly disabled by application "TextEdit" for over 1.00 seconds. Server has re-enabled them.
11/12/15 14:55:50,000 bootlog[0]: BOOT_TIME 1449842150 0
savick
Messaggio Inviato: sab, 12 dic 2015 12:55
Ho reinstallato Yosemite, però non facevo in tempo ad accenderlo che crashava il desktop e poi pixelava tutto.
Ho portato i valori alti "smcFanControl"
ma problemi comunque
Perchè su un forum dell'apple ci sono dedicate quasi 30 pagine a questo problema che è presente dal lontano 2006,
dicono che nvidia ha i driver non corretti, mentri altri dicono che è il surriscaldamento dell'iMac.
Infatti stamattina doo un riposo di 24 ore e la finestra aperta nella camera, nonostante la temperatura indicata del iMac sia identica a ieri: 32°, non da alcun problema.
Ho fatto girare "EtreCheck" risulta nessun problema software ne hardware.
Con tutta calma trasferisco tutti i dati su di un altra macchina poi formatto completamente inizializzando l'hardisk e poi vedremo...
savick
Messaggio Inviato: sab, 12 dic 2015 22:40
Finito ora di inizializzare l'iMac e installare Yosemite, per tutto il periodo dell'installazione durato circa 2 orette, nessun problema
poi appena partito dopo nemmeno 20 minuti, ha iniziato a flashare per poi piantarsi!!!
mauripucci
Messaggio Inviato: sab, 12 dic 2015 22:58
Hd o Ssd?
Verificato se l'iMac è pieno di povere all'interno?
Verificato lo stato della pasta termica?
savick
Messaggio Inviato: dom, 13 dic 2015 10:17
non saprei se dentro all'imac c'è della polvere, ragni o topi
non sono in grado di aprirlo, lo porterò in assistenza qui a Reggio Emilia e speriamo di non spendere un capitale.
Durante l'inizializzazione ed installazione del sistema operativo, nessun crash nessun errore, e nessun pixel impazzito.
Quindi presumo che la scheda video non sia rovinata.
Mi piacerebbe sapere esattamente la traduzione pezzo per pezzo di questo:
kernel: NVDA(OpenGL): Channel exception! exception type = 0xd = graphics Engine error (GR Error 5)
savick
Messaggio Inviato: dom, 13 dic 2015 10:26
se faccio una ricerca su internet di questo errore è pieno di pagine, per darti un idea di ciò che mi accade, guardati i primi secondi di questo video: https://www.youtube.com/watch?v=4kjWH950opM" onclick="window.open(this.href);return false;
mauripucci
Messaggio Inviato: dom, 13 dic 2015 17:25
Non vorrei fare il... pessimista
ma è possibile (anche se l'iMac di cui si parla è "fine" e non "inizio" 2009):
viewtopic.php?f=8&t=34608" onclick="window.open(this.href);return false;
savick
Messaggio Inviato: dom, 13 dic 2015 21:22
oggi ho fatto di tutto:
- installato YOSEMITE
- messo DVD per hardware test e diceva nessun danneggiamento a parte un banco ram nello slot 1
- tolto il banco stesso errore
- installato inizializzando il disco SnowLeopard
- girava bene, poi ho fatto gli aggiornamenti
- non è più partito!
e pensare che dal 2010 ad oggi non ho mai avuto un problema!
cicciopasticcio
Messaggio Inviato: dom, 13 dic 2015 21:45
Vabbe', si puo' concludere che hai un problema hardware, right? Affidalo ai mEccanici!
L'altro ieri, Macintosh. Oggi, MacBook Air 13" i7 8/500. Domani, chissà!
savick
Messaggio Inviato: lun, 14 dic 2015 11:36
Diciamo che riescono a leggere tra le righe dei log...e sono generosi ascoltando i nostri problemi.
Ringrazio i "imaccanici". :wink:
savick
Messaggio Inviato: gio, 17 dic 2015 10:24
Fine della storia:
ho portato l'iMac in riparazione, siccome dopo 5 anni l'Apple non ha più i pezzi di ricambio, negli USA c'è una ditta che ne approfitta di questo, la risposta è:
Preventivo riparazione iMac, sostituzione exchange scheda madre €512,00+iva!
