Homebrew su OS X - Diamo la birra al Mac
Oggetto del messaggio: Re: Homebrew su OS X - Diamo la birra al Mac
Messaggio da faxus »
Allora eseguo update
Eh... Ha ancora da ridire.
C'è ancora da sistemare qualcosa...
Quindi eseguo anche
cd /usr/local/Homebrew/Library/Taps/caskroom/homebrew-cask && git stash pop
Dovrebbe essere finito, no?
No...
Quando ricomincio, prima il comando non va più bene.
Cerco su GitHub e trovo in una discussione che stavo leggendo il comando giusto
Vado quindi di
brew cask install Caskroom/cask/xquartz
Fore un bug, mi dice di segnalarlo a Cask
Spero in istruzioni preliminari.
Infatti ci sono:
https://github.com/caskroom/homebrew-ca ... _report.md" onclick="window.open(this.href);return false;
Before reporting a bug, lets make sure everything is right with your setup.
When reporting bugs, remember that Homebrew-Cask is an independent project from Homebrew. Do your best to direct bug reports to the appropriate project. If your command started with brew cask, bring the bug to us first.
Start by searching for your issue before posting a new one. If you find an open issue and have any new information not reported in the original, please add your insights. If you find a closed issue, try the solutions there. If the issue is still not solved, open a new one with your new information and a link back to the old related issue.
If you did not find your particular bug, before reporting it make sure you have the latest versions of Homebrew, Homebrew-Cask, and all Taps by running the following commands. These will also fix some other issues:
$ cd $(brew --repo); git fetch; git reset --hard origin/master
$ brew untap phinze/cask; brew untap caskroom/cask; brew uninstall --force brew-cask
$ brew cleanup; brew cask cleanup; brew update
Retry your failing command. If the issue persists, go back and pick the appropriate instructions for your problem.
... Continua
[Edit ho sostituito un'immagine che non corrispondeva]
Ultima modifica di faxus il ven, 11 nov 2016 16:34, modificato 1 volta in totale.
Quindi eseguo
MacBook-Pro-di-Fabio:~ faxus$ cd $(brew --repo); git fetch; git reset --hard origin/master
HEAD is now at 2ce17a1 Merge pull request #1082 from alyssais/uninstall_dependancy_error
MacBook-Pro-di-Fabio:Homebrew faxus$ brew untap phinze/cask; brew untap caskroom/cask; brew uninstall --force brew-cask
Error: No available tap phinze/cask.
Untapping caskroom/cask... (3,708 files, 77M)
Untapped 0 formulae
Error: No such file or directory - /usr/local/Cellar/brew-cask
MacBook-Pro-di-Fabio:Homebrew faxus$ brew cleanup; brew cask cleanup; brew update
Removing: /usr/local/Cellar/binutils/2.25.1... (107 files, 136.2M)
Removing: /usr/local/Cellar/binutils/2.26... (109 files, 140.3M)
Removing: /usr/local/Cellar/binutils/2.26.1... (109 files, 140.3M)
Removing: /usr/local/Cellar/cask/0.7.4... (13 files, 162.8K)
Removing: /usr/local/Cellar/cask/0.8.0... (13 files, 165.4K)
Removing: /usr/local/Cellar/emacs/24.5... (3,916 files, 99.6M)
Removing: /usr/local/Cellar/glib/2.50.0... (426 files, 22.3M)
Removing: /usr/local/Cellar/glib/2.50.1... (427 files, 22.3M)
Removing: /usr/local/Cellar/harfbuzz/1.3.2... (122 files, 4.2M)
Removing: /usr/local/Cellar/harfbuzz/1.3.3... (132 files, 4.5M)
Removing: /usr/local/Cellar/htop/2.0.1... (10 files, 182.4K)
Removing: /usr/local/Cellar/icu4c/57.1... (265 files, 65.0M)
Removing: /usr/local/Cellar/libpng/1.6.25... (25 files, 1.2M)
Removing: /usr/local/Cellar/libtiff/4.0.6_2... (261 files, 3.4M)
Removing: /usr/local/Cellar/nmap/7.12... (727 files, 23M)
Removing: /usr/local/Cellar/nmap/7.30... (748 files, 23.9M)
Removing: /usr/local/Cellar/openssl/1.0.2e... (1,646 files, 11.9M)
Removing: /usr/local/Cellar/openssl/1.0.2f... (1,651 files, 11.9M)
Removing: /usr/local/Cellar/openssl/1.0.2g... (1,678 files, 12.0M)
Removing: /usr/local/Cellar/openssl/1.0.2h_1... (1,691 files, 12M)
Removing: /usr/local/Cellar/smartmontools/6.4... (31 files, 1.6M)
Removing: /usr/local/Cellar/wget/1.17.1... (9 files, 1.5M)
Removing: /Users/faxus/Library/Caches/Homebrew/cask-0.8.0.tar.gz... (303.3K)
Removing: /Users/faxus/Library/Caches/Homebrew/emacs-25.1.sierra.bottle.tar.gz... (43.6M)
Removing: /Users/faxus/Library/Caches/Homebrew/glib-2.50.0.sierra.bottle.tar.gz... (6.6M)
Removing: /Users/faxus/Library/Caches/Homebrew/glib-2.50.1.sierra.bottle.tar.gz... (6.6M)
Removing: /Users/faxus/Library/Caches/Homebrew/harfbuzz-1.3.2.sierra.bottle.tar.gz... (980.6K)
Removing: /Users/faxus/Library/Caches/Homebrew/harfbuzz-1.3.3.sierra.bottle.tar.gz... (1022.1K)
Removing: /Users/faxus/Library/Caches/Homebrew/icu4c-57.1.sierra.bottle.tar.gz... (24.2M)
Removing: /Users/faxus/Library/Caches/Homebrew/libpng-1.6.25.sierra.bottle.tar.gz... (436.4K)
Removing: /Users/faxus/Library/Caches/Homebrew/libtiff-4.0.6_2.sierra.bottle.tar.gz... (1M)
Removing: /Users/faxus/Library/Caches/Homebrew/nmap-7.12.sierra.bottle.tar.gz... (6M)
Removing: /Users/faxus/Library/Caches/Homebrew/nmap-7.30.sierra.bottle.tar.gz... (6.3M)
Removing: /Users/faxus/Library/Caches/Homebrew/openssl-1.0.2h_1.sierra.bottle.tar.gz... (3.6M)
Removing: /Users/faxus/Library/Logs/Homebrew/binutils... (6 files, 1.3M)
Removing: /Users/faxus/Library/Logs/Homebrew/fontconfig... (808B)
Removing: /Users/faxus/Library/Logs/Homebrew/gdk-pixbuf... (212B)
Removing: /Users/faxus/Library/Logs/Homebrew/glib... (68B)
Removing: /Users/faxus/Library/Logs/Homebrew/htop... (5 files, 178.9K)
Removing: /Users/faxus/Library/Logs/Homebrew/librsvg... (200B)
Removing: /Users/faxus/Library/Logs/Homebrew/openssl... (68B)
Removing: /Users/faxus/Library/Logs/Homebrew/pkg-config... (5 files, 355K)
Removing: /Users/faxus/Library/Logs/Homebrew/shared-mime-info... (218B)
Removing: /Users/faxus/Library/Logs/Homebrew/smartmontools... (5 files, 149.6K)
Removing: /Users/faxus/Library/Logs/Homebrew/tree... (2 files, 5.5K)
Removing: /Users/faxus/Library/Logs/Homebrew/xz... (5 files, 289.4K)
==> This operation has freed approximately 840.8M of disk space.
==> Tapping caskroom/cask
Cloning into '/usr/local/Homebrew/Library/Taps/caskroom/homebrew-cask'...
remote: Counting objects: 3519, done.
remote: Compressing objects: 100% (3504/3504), done.
remote: Total 3519 (delta 31), reused 152 (delta 11), pack-reused 0
Receiving objects: 100% (3519/3519), 1.14 MiB | 126.00 KiB/s, done.
Resolving deltas: 100% (31/31), done.
Checking connectivity... done.
Tapped 0 formulae (3,527 files, 3.5M)
==> Removing cached downloads
/Users/faxus/Library/Caches/Homebrew/Cask/cakebrew--1.2.1.zip
/Users/faxus/Library/Caches/Homebrew/Cask/gimp--2.8.18-x86_64.dmg
/Users/faxus/Library/Caches/Homebrew/Cask/wesnoth--1.12.4.dmg.incomplete
==> This operation has freed approximately 68M of disk space.
Already up-to-date.
Bene ho fatto un bel po' di pulizia, vediamo...
Ah... Finalmente è tornata la pace...
Ho installato Hex Fiend, per aggiornare una vecchia edizione:
brew cask install hex-fiend
==> Downloading https://github.com/ridiculousfish/HexFiend/releases/download/v2.
######################################################################## 100,0%
==> Verifying checksum for Cask hex-fiend
==> It seems there is already an App at '/Applications/Hex Fiend.app'; not movin
hex-fiend was successfully installed!
MacBook-Pro-di-Fabio:~ faxus$ brew cask info hex-fiend
hex-fiend: 2.3.0
http://ridiculousfish.com/hexfiend/
/usr/local/Caskroom/hex-fiend/2.3.0 (154 files, 2.4M)
From: https://github.com/caskroom/homebrew-cask/blob/master/Casks/hex-fiend.rb
==> Name
Hex Fiend
==> Artifacts
Hex Fiend.app (app)
Non avevo rimosso la vecchia 2.1.2, poi l'ho fatto e quindi dopo l'ho dovuta reintallare sopra.
Per averla disponibile in /Applicazioni.
Quindi
Warning: A Cask for hex-fiend is already installed.
To re-install hex-fiend, run:
  brew cask reinstall hex-fiend
MacBook-Pro-di-Fabio:~ faxus$ brew cask reinstall hex-fiend
==> Moving App 'Hex Fiend.app' to '/Applications/Hex Fiend.app'
Password:
Già che ci sono...
Removing: /Users/faxus/Library/Logs/Homebrew/cask... (68B)
==> This operation has freed approximately 68B of disk space.
/Users/faxus/Library/Caches/Homebrew/Cask/hex-fiend--2.3.0.zip
/Users/faxus/Library/Caches/Homebrew/Cask/xquartz--2.7.11.dmg
==> This operation has freed approximately 76.8M of disk space.
Updated 2 taps (caskroom/cask, homebrew/core).
==> New Formulae
closure-stylesheets        kops                       node@5
dnsviz                     libgosu                    node@6
elasticsearch@1.7          lumo                       packetbeat
elasticsearch@2.4          mysql@5.5                  qjson
github-keygen              mysql@5.6                  qwtpolar
glfw                       nanomsgxx                  swiftformat
google-java-format         node@0.10                  tomcat@6
ib                         node@0.12                  tomcat@7
juju@2.0                   node@4
==> Updated Formulae
advancecomp                              libwpd
afflib                                   links
agda                                     llnode
algernon                                 loc
ansifilter                               logstash
antigen                                  logtalk
arangodb                                 luaradio
archi-steam-farm                         m-cli
argyll-cms                               mackup
artifactory                              macvim
aws-elasticbeanstalk                     mandoc
aws-sdk-cpp                              mawk
awscli                                   mdv
babl                                     media-info
baresip                                  mediaconch
bazel                                    mercurial
buku                                     mg3a
caf                                      micro
camlp4                                   mikutter
camlp5                                   minio
certigo                                  minio-mc
cheat                                    mkvtoolnix
checkstyle                               moc
chruby-fish                              modd
citus                                    mongodb
cli53                                    monkeysphere
clipper                                  mono
clojurescript                            mpv
closure-compiler                         mu
clutter-gst                              mutt
cmake                                    mytop
cmus                                     neo4j
coffeescript                             neofetch
collectd                                 netpbm
conan                                    nghttp2
convox                                   nifi
coq                                      node
coreutils                                node-build
cromwell                                 noti
crystal-lang                             notmuch
datetime-fortran                         nss
davmail                                  ocaml
dbhash                                   ocamlbuild
dbus                                     ocamlsdl
dcraw                                    offlineimap
digdag                                   openvdb
dmd                                      orientdb
docker-machine-driver-xhyve              osquery
dub                                      osrm-backend
efl                                      paket
eject                                    pandoc
elasticsearch                            pandoc-citeproc
etcd                                     pandoc-crossref
exploitdb                                parallel
fabio                                    parquet-tools
feedgnuplot                              percona-server
ffmpeg                                   percona-toolkit
filebeat                                 percona-xtrabackup
flow                                     pgcli
fltk                                     pgroonga
fluent-bit                               pngquant
folly                                    pre-commit
fonttools                                prometheus
freetds                                  pugixml
fstar                                    pyenv
fzf                                      pypy3
gflags                                   rakudo-star
ghc                                      rancher-cli
gibo                                     rancher-compose
git                                      rancid
git-cola                                 rbenv
git-ftp                                  readline
git-lfs                                  redis
git-series                               riemann
gitbucket                                ripgrep
gitlab-ci-multi-runner                   rocksdb
gjstest                                  roswell
glbinding                                rtags
glog                                     s-search
gnome-builder                            saltstack
go                                       sbcl
goaccess                                 scala
gofabric8                                scale2x
gradle                                   sdl_image
grafana                                  sdl_mixer
grib-api                                 sfk
groonga                                  sfml
gst-editing-services                     shairport-sync
gst-libav                                shared-mime-info ✔
gst-plugins-bad                          sjk
gst-plugins-base                         skinny
gst-plugins-good                         slimerjs
gst-plugins-ugly                         snap-telemetry
gst-python                               snappystream
gst-validate                             snapraid
gstreamer                                snzip
gtkdatabox                               softhsm
gtksourceview3                           sourcekitten
gwyddion                                 sqldiff
haproxy                                  sqlite
harfbuzz ✔                               sqlite-analyzer
headphones                               sqlmap
highlight                                srclib
hunspell                                 ssreflect
hyper                                    stunnel
imagejs                                  stuntman
imagemagick                              subversion
imapfilter                               supersonic
infer                                    svgcleaner
influxdb                                 swiftgen
innotop                                  swiftlint
ios-sim                                  sync_gateway
ipmitool                                 syncthing
jadx                                     synfig
jasper                                   tag
javarepl                                 taylor
jboss-forge                              tccutil
jemalloc                                 td
jenkins                                  terraform
jmeter                                   terragrunt
jpeg-turbo                               testssl
jruby                                    texmath
jsonschema2pojo                          tgui
kapacitor                                the_silver_searcher
kibana                                   tippecanoe
lablgtk                                  tomcat-native
lean-cli                                 tor
ledit                                    treefrog
lesspipe                                 ttfautohint
lfe                                      ttyd
libarchive                               twarc
libcouchbase                             typescript
libcue                                   u-boot-tools
libgsf                                   ufraw
libical                                  vala
libical-glib                             vault
libicns                                  vim
libmicrohttpd                            vmtouch
libosmium                                vultr
libphonenumber                           yarn
libpst                                   yle-dl
libraw                                   youtube-dl
libre                                    zero-install
librem                                   zplug
libtiff ✔                                zstd
libunistring
==> Renamed Formulae
juju -> juju@1.25                        mongo-c -> mongo-c-driver
libmongoclient -> mongo-cxx-driver
==> Deleted Formulae
libbson             polygen             ttylog              yelp-xsl
Messaggio da iStefano »
Installato per vedere com'è ...
Ma è più fico il terminale ...
Una rinfrescata, visto che c'è il tempo...
MacBook-Pro-di-Fabio:~ faxus$ brew update
xcrun: error: invalid active developer path (/Library/Developer/CommandLineTools), missing xcrun at: /Library/Developer/CommandLineTools/usr/bin/xcrun
==> New Formulae
bnd                 gcc@4.9             jid                 ppl@0.11
cloog@0.15          gmp@4               kubernetes-helm     qt@5.5
cloog@0.18          gst-rtsp-server     libhttpseverywhere  rpcgen
curaengine          handbrake           libmpc@0.8          termius
excel-compare       isl@0.11            mmark
gcc@4.8             isl@0.14            mpfr@2
abcl                       gspell                     p11-kit
abcm2ps                    gtk+3                      packer
activemq                   gtkglext                   pandoc
agda                       gwyddion                   parallel
alot                       h2o                        passenger
amazon-ecs-cli             hadolint                   pazpar2
ammonite-repl              haproxy                    pcsc-lite
ansible                    haskell-stack              pdal
ansible-cmdb               heroku                     pdf2htmlex
antigen                    homebank                   pdftoedn
apache-flink               html-xml-utils             peco
app-engine-java            httpie                     pgloader
arangodb                   hugo                       pick
aria2                      hunspell                   pigz
artifactory                ibex                       pkcs11-helper
asciinema                  ice                        platformio
autotrace                  idris                      pngquant
aws-sdk-cpp                imagemagick                ponyc
awscli                     imapfilter                 poppler
azure-cli                  ioping                     proxychains-ng
bazel                      ios-sim                    pstoedit
bitrise                    ipsumdump                  pulseaudio
blockhash                  ircd-hybrid                purescript
bmon                       isl                        pwntools
buku                       iso-codes                  py3cairo
cabal-install              jasper                     pyenv
caddy                      jenkins                    pygtkglext
cairo ✔                    jetty                      pyqt5
cairomm                    jfrog-cli-go               python
calabash                   jlog                       python3
ccextractor                jmxtrans                   qbs
chkrootkit                 jsoncpp                    qscintilla2
chromedriver               jsonschema2pojo            ranger
clipper                    keepassc                   ringojs
collectd                   khal                       rmlint
conan                      khard                      rocksdb
consul                     kibana                     roswell
cookiecutter               knot                       rtv
coq                        kobalt                     ruby
creduce                    kops                       ruby-build
crystal-lang               kubernetes-cli             ruby-install
csvtomd                    lbdb                       sagittarius-scheme
curl                       lcov                       saltstack
dateutils                  lensfun                    sassc
devd                       libbpg                     scamper
diff-pdf                   libcouchbase               serf
diffoscope                 libgcrypt                  shyaml
digdag                     libgit2                    skinny
direnv                     libgosu                    snakemake
dmtx-utils                 libgpg-error               sngrep
dnscrypt-proxy             libgraphqlparser           solr
docker                     libgweather                sourcekitten
dockviz                    libltc                     speedtest_cli
docutils                   libphonenumber             spim
dovecot                    libsass                    sqliteodbc
dpkg                       libstfl                    squid
efl                        libtermkey                 ssh-copy-id
eigen                      libvirt                    sslyze
ejabberd                   libvoikko                  stern
elasticsearch              libwebsockets              suomi-malaga-voikko
elasticsearch@2.4          lighttpd                   swi-prolog
emscripten                 llnode                     swiftformat
epeg                       llvm                       swiftlint
ephemeralpg                logstash                   syncthing
epubcheck                  luvit                      synfig
erlang                     macvim                     sysdig
exiftool                   mailutils                  tbb
exploitdb                  makensis                   tcsh
fabric                     mariadb                    telegraf
fades                      mdv                        terraform
fantom                     meson                      terragrunt
fdroidserver               metabase                   the_platinum_searcher
filebeat                   mikutter                   tile38
flake8                     minio                      tippecanoe
flow                       minio-mc                   tomcat
fobis                      minizinc                   tor
folly                      mkdocs                     ttyd
fonttools                  monetdb                    twtxt
format-udf                 mongo-c-driver             typescript
fwup                       mongo-cxx-driver           unbound
gabedit                    mongo-orchestration        upx
game-music-emu             mosquitto                  urbit
gammu                      mpd                        vapoursynth
gauge                      mpv                        vault
gcc                        mupdf-tools                vdirsyncer
gdk-pixbuf ✔               mvtools                    vim
geos                       mypy                       vnstat
geoserver                  mysql-sandbox              voltdb
ghc                        netpbm                     vowpal-wabbit
gimme                      nmap ✔                     vultr
git-annex                  node                       wakatime-cli
git-cola                   node-build                 wavpack
gitbucket                  node@4                     webp
github-keygen              nomad                      wireguard-tools
gitlab-ci-multi-runner     notmuch                    wireshark
global                     nsd                        x264
gmime                      nss                        xonsh
gmp                        nuxeo                      yarn
gnatsd                     ola                        yaz
gnome-builder              oniguruma                  you-get
gnutls                     open-scene-graph           youtube-dl
go                         openconnect                zbar
godep                      openrtsp                   zinc
goenv                      openshift-cli              znc
gofabric8                  openvpn                    zplug
googler                    orientdb                   zsh
grails                     osm2pgsql                  zstd
graphviz                   osquery
gsl                        owfs
pangox-compat              pdksh                      unfs3
Aggiorniamo anche
Ed eseguiamo quanto richiesto.
Sistemato Python, ci saranno un bel po' di scorie da eliminare:
MacBook-Pro-di-Fabio:~ faxus$ brew cleanup
Removing: /usr/local/Cellar/cairo/1.14.6_1... (118 files, 5.9M)
Removing: /usr/local/Cellar/gdk-pixbuf/2.36.0_2... (223 files, 4.4M)
Removing: /usr/local/Cellar/harfbuzz/1.3.3_1... (132 files, 4.5M)
Removing: /usr/local/Cellar/libtiff/4.0.6_3... (262 files, 3.4M)
Removing: /usr/local/Cellar/nmap/7.31... (748 files, 23.9M)
Removing: /usr/local/Cellar/shared-mime-info/1.7_1... (838 files, 6.7M)
Removing: /Users/faxus/Library/Caches/Homebrew/cairo-1.14.6_1.sierra.bottle.tar.gz... (1.6M)
Removing: /Users/faxus/Library/Caches/Homebrew/gdk-pixbuf-2.36.0_2.sierra.bottle.tar.gz... (1M)
Removing: /Users/faxus/Library/Caches/Homebrew/harfbuzz-1.3.3_1.sierra.bottle.1.tar.gz... (1022.2K)
Removing: /Users/faxus/Library/Caches/Homebrew/libtiff-4.0.6_3.sierra.bottle.tar.gz... (1M)
Removing: /Users/faxus/Library/Caches/Homebrew/nmap-7.31.sierra.bottle.tar.gz... (6.3M)
Removing: /Users/faxus/Library/Caches/Homebrew/shared-mime-info-1.7_1.sierra.bottle.tar.gz... (1M)
==> This operation has freed approximately 60.8M of disk space.
Indi
Vabbè, sempre la solita storia...
Ma i CLT ci stanno, è solo un fastidio.
Un'altra volta, eh...
Devo decidermi a risolvere il fatto che non mi rileva i CLT.
Ma che funzionano benissimo...
==> New Formulae
MacBook-Pro-di-Fabio:~ faxus$ brew upgrade
Updating Homebrew...
==> Upgrading 6 outdated packages, with result:
freetype 2.7.1, harfbuzz 1.4.2, icu4c 58.2, libpng 1.6.28, libtiff 4.0.7_2, openssl 1.0.2k
==> Upgrading freetype
==> Installing dependencies for freetype: libpng
==> Installing freetype dependency: libpng
==> Downloading https://homebrew.bintray.com/bottles/libpng-1.6.28.sierra.bottle
==> Pouring libpng-1.6.28.sierra.bottle.tar.gz
/usr/local/Cellar/libpng/1.6.28: 26 files, 1.2M
==> Downloading https://homebrew.bintray.com/bottles/freetype-2.7.1.sierra.bottl
==> Pouring freetype-2.7.1.sierra.bottle.tar.gz
/usr/local/Cellar/freetype/2.7.1: 62 files, 2.5M
==> Upgrading harfbuzz
==> Installing dependencies for harfbuzz: icu4c
==> Installing harfbuzz dependency: icu4c
==> Downloading https://homebrew.bintray.com/bottles/icu4c-58.2.sierra.bottle.ta
==> Pouring icu4c-58.2.sierra.bottle.tar.gz
==> Caveats
This formula is keg-only, which means it was not symlinked into /usr/local.
macOS provides libicucore.dylib (but nothing else).
Generally there are no consequences of this for you. If you build your
own software and it requires this formula, you'll need to add to your
build variables:
    LDFLAGS:  -L/usr/local/opt/icu4c/lib
    CPPFLAGS: -I/usr/local/opt/icu4c/include
    PKG_CONFIG_PATH: /usr/local/opt/icu4c/lib/pkgconfig
==> Summary
/usr/local/Cellar/icu4c/58.2: 242 files, 65M
==> Downloading https://homebrew.bintray.com/bottles/harfbuzz-1.4.2.sierra.bottl
==> Pouring harfbuzz-1.4.2.sierra.bottle.tar.gz
/usr/local/Cellar/harfbuzz/1.4.2: 133 files, 4.9M
==> Upgrading libtiff
==> Downloading https://homebrew.bintray.com/bottles/libtiff-4.0.7_2.sierra.bott
==> Pouring libtiff-4.0.7_2.sierra.bottle.tar.gz
/usr/local/Cellar/libtiff/4.0.7_2: 248 files, 3.4M
==> Upgrading openssl
==> Downloading https://homebrew.bintray.com/bottles/openssl-1.0.2k.sierra.bottl
==> Pouring openssl-1.0.2k.sierra.bottle.tar.gz
==> Using the sandbox
==> Caveats
A CA file has been bootstrapped using certificates from the SystemRoots
keychain. To add additional certificates (e.g. the certificates added in
the System keychain), place .pem files in
  /usr/local/etc/openssl/certs
and run
  /usr/local/opt/openssl/bin/c_rehash
Apple has deprecated use of OpenSSL in favor of its own TLS and crypto libraries
build variables:
    LDFLAGS:  -L/usr/local/opt/openssl/lib
    CPPFLAGS: -I/usr/local/opt/openssl/include
    PKG_CONFIG_PATH: /usr/local/opt/openssl/lib/pkgconfig
==> Summary
/usr/local/Cellar/openssl/1.0.2k: 1,696 files, 12M
Removing: /usr/local/Cellar/freetype/2.7... (61 files, 2.4M)
Removing: /usr/local/Cellar/harfbuzz/1.3.4... (132 files, 4.5M)
Removing: /usr/local/Cellar/icu4c/58.1... (242 files, 65M)
Removing: /usr/local/Cellar/libpng/1.6.26... (26 files, 1.2M)
Removing: /usr/local/Cellar/libtiff/4.0.7... (248 files, 3.3M)
Removing: /usr/local/Cellar/openssl/1.0.2j... (1,695 files, 12M)
Removing: /Users/faxus/Library/Caches/Homebrew/freetype-2.7.sierra.bottle.tar.gz... (806.5K)
Removing: /Users/faxus/Library/Caches/Homebrew/harfbuzz-1.3.4.sierra.bottle.tar.gz... (1M)
Removing: /Users/faxus/Library/Caches/Homebrew/icu4c-58.1.sierra.bottle.tar.gz... (24.6M)
Removing: /Users/faxus/Library/Caches/Homebrew/libpng-1.6.26.sierra.bottle.tar.gz... (438.6K)
Removing: /Users/faxus/Library/Caches/Homebrew/libtiff-4.0.7.sierra.bottle.tar.gz... (1M)
Removing: /Users/faxus/Library/Caches/Homebrew/openssl-1.0.2j.sierra.bottle.tar.gz... (3.6M)
Removing: /Users/faxus/Library/Logs/Homebrew/gdk-pixbuf... (210B)
Removing: /Users/faxus/Library/Logs/Homebrew/shared-mime-info... (216B)
==> This operation has freed approximately 119.9M of disk space.
MacBook-Pro-di-Fabio:~ faxus$ brew doctor
Please note that these warnings are just used to help the Homebrew maintainers
with debugging if you file an issue. If everything you use Homebrew for is
working fine: please don't worry and just ignore them. Thanks!
Warning: No developer tools installed.
Install the Command Line Tools:
  xcode-select --install
faxus ha scritto:Devo decidermi a risolvere il fatto che non mi rileva i CLT.
... xcrun: error: invalid active developer path (/Library/Developer/CommandLineTools), missing xcrun at: /Library/Developer/CommandLineTools/usr/bin/xcrun...
Si risolve reinstallando
Il perché:
Succede perché ad ogni aggiornamento, anche se i CLT risultano validi ed aggiornati, non si sottoscrive il contratto di licenza.
Mentre riscaricandoli, sì...
Riporto qui il link a una discussione interessante sul Forum sull'uso di strings contenuto nei CLT.
Ma che pare sia sempre stato presente in Terminale in nSnow Leopard e precedenti
viewtopic.php?f=8&t=40310" onclick="window.open(this.href);return false;
Già che ci siamo...
MacBook-Pro-di-Fabio:~ faxus$ brew update && brew upgrade && brew cleanup
==> New Formulae
abuse... zeromq...
... ==> Renamed Formulae
berkeley-db4 -> berkeley-db@4            juju2 -> juju
boost155 -> boost@1.55                   juju@2.0 -> juju
boost157 -> boost@1.57                   lua51 -> lua@5.1
boost159 -> boost@1.59                   lua53 -> lua@5.3
boost160 -> boost@1.60
apg                 edelta              lcab                probatron4j
bip                 esound              malaga              rtpbreak
cups-pdf            keybase             mingw-w64-binutils
E finalmente:
Your system is ready to brew.
Occhebello!
L'aggiornamento a macOS Sierra 10.12.4 è stato molto oneroso...
==> New Formulae
alexjs…
...terraform-docs
abcde…
...zstd
bazel02 -> bazel@0.2
ruby23 -> ruby@2.3
android-ndk…
…scsh
==> Upgrading 12 outdated packages, with result:
atk 2.24.0, binutils 2.28, gdk-pixbuf 2.36.6, glib 2.52.0, gobject-introspection 1.52.0, harfbuzz 1.4.5, libffi 3.2.1, libpng 1.6.29, pcre 8.40, pkg-config 0.29.2, poppler 0.53.0, shared-mime-info 1.8_1
==> Upgrading atk
==> Installing dependencies for atk: libffi, pcre, glib, pkg-config, libpng, readline, sqlite, gdbm, python, gobject-introspection
==> Installing atk dependency: libffi
==> Downloading https://homebrew.bintray.com/bottles/libffi-3.2.1.sierra.bottle.
==> Pouring libffi-3.2.1.sierra.bottle.tar.gz
==> Caveats
Some formulae require a newer version of libffi.
For compilers to find this software you may need to set:
    LDFLAGS:  -L/usr/local/opt/libffi/lib
For pkg-config to find this software you may need to set:
    PKG_CONFIG_PATH: /usr/local/opt/libffi/lib/pkgconfig
==> Summary
brew  /usr/local/Cellar/libffi/3.2.1: 16 files, 297.0KB
==> Installing atk dependency: pcre
==> Downloading https://homebrew.bintray.com/bottles/pcre-8.40.sierra.bottle.tar
==> Pouring pcre-8.40.sierra.bottle.tar.gz
brew  /usr/local/Cellar/pcre/8.40: 204 files, 5.4MB
==> Installing atk dependency: glib
==> Downloading https://homebrew.bintray.com/bottles/glib-2.52.0.sierra.bottle.t
==> Pouring glib-2.52.0.sierra.bottle.tar.gz
brew  /usr/local/Cellar/glib/2.52.0: 430 files, 22.5MB
==> Installing atk dependency: pkg-config
==> Downloading https://homebrew.bintray.com/bottles/pkg-config-0.29.2.sierra.bo
==> Pouring pkg-config-0.29.2.sierra.bottle.tar.gz
brew  /usr/local/Cellar/pkg-config/0.29.2: 11 files, 627KB
==> Installing atk dependency: libpng
==> Downloading https://homebrew.bintray.com/bottles/libpng-1.6.29.sierra.bottle
==> Pouring libpng-1.6.29.sierra.bottle.tar.gz
brew  /usr/local/Cellar/libpng/1.6.29: 26 files, 1.2MB
==> Installing atk dependency: readline
==> Downloading https://homebrew.bintray.com/bottles/readline-7.0.3_1.sierra.bot
==> Pouring readline-7.0.3_1.sierra.bottle.tar.gz
==> Caveats
macOS provides the BSD libedit library, which shadows libreadline.
In order to prevent conflicts when programs look for libreadline we are
defaulting this GNU Readline installation to keg-only.
    LDFLAGS:  -L/usr/local/opt/readline/lib
    CPPFLAGS: -I/usr/local/opt/readline/include
==> Summary
brew  /usr/local/Cellar/readline/7.0.3_1: 46 files, 1.5MB
==> Installing atk dependency: sqlite
==> Downloading https://homebrew.bintray.com/bottles/sqlite-3.17.0.sierra.bottle
==> Pouring sqlite-3.17.0.sierra.bottle.tar.gz
==> Caveats
macOS provides an older sqlite3.
If you need to have this software first in your PATH run:
  echo 'export PATH="/usr/local/opt/sqlite/bin:$PATH"' >> ~/.bash_profile
    LDFLAGS:  -L/usr/local/opt/sqlite/lib
    CPPFLAGS: -I/usr/local/opt/sqlite/include
    PKG_CONFIG_PATH: /usr/local/opt/sqlite/lib/pkgconfig
==> Summary
brew  /usr/local/Cellar/sqlite/3.17.0: 11 files, 2.9MB
==> Installing atk dependency: gdbm
==> Downloading https://homebrew.bintray.com/bottles/gdbm-1.13.sierra.bottle.tar
==> Pouring gdbm-1.13.sierra.bottle.tar.gz
brew  /usr/local/Cellar/gdbm/1.13: 19 files, 554.4KB
==> Installing atk dependency: python
==> Downloading https://homebrew.bintray.com/bottles/python-2.7.13.sierra.bottle
==> Pouring python-2.7.13.sierra.bottle.tar.gz
==> /usr/local/Cellar/python/2.7.13/bin/python -s setup.py --no-user-cfg install
==> Caveats
Pip and setuptools have been installed. To update them
  pip install --upgrade pip setuptools
You can install Python packages with
  pip install <package>
They will install into the site-package directory
  /usr/local/lib/python2.7/site-packages
See: http://docs.brew.sh/Homebrew-and-Python.html
==> Summary
brew  /usr/local/Cellar/python/2.7.13: 3,526 files, 48MB
==> Installing atk dependency: gobject-introspection
==> Downloading https://homebrew.bintray.com/bottles/gobject-introspection-1.52.
==> Pouring gobject-introspection-1.52.0.sierra.bottle.tar.gz
brew  /usr/local/Cellar/gobject-introspection/1.52.0: 172 files, 9.6MB
==> Installing atk
==> Downloading https://homebrew.bintray.com/bottles/atk-2.24.0.sierra.bottle.ta
==> Pouring atk-2.24.0.sierra.bottle.tar.gz
brew  /usr/local/Cellar/atk/2.24.0: 209 files, 3.3MB
==> Upgrading binutils
==> Downloading https://homebrew.bintray.com/bottles/binutils-2.28.sierra.bottle
==> Pouring binutils-2.28.sierra.bottle.tar.gz
brew  /usr/local/Cellar/binutils/2.28: 111 files, 143.2MB
==> Upgrading gdk-pixbuf
==> Installing dependencies for gdk-pixbuf: shared-mime-info
==> Installing gdk-pixbuf dependency: shared-mime-info
==> Downloading https://homebrew.bintray.com/bottles/shared-mime-info-1.8_1.sier
==> Pouring shared-mime-info-1.8_1.sierra.bottle.tar.gz
==> /usr/local/Cellar/shared-mime-info/1.8_1/bin/update-mime-database /usr/local
brew  /usr/local/Cellar/shared-mime-info/1.8_1: 83 files, 4.4MB
==> Downloading https://homebrew.bintray.com/bottles/gdk-pixbuf-2.36.6.sierra.bo
==> Pouring gdk-pixbuf-2.36.6.sierra.bottle.tar.gz
==> /usr/local/Cellar/gdk-pixbuf/2.36.6/bin/gdk-pixbuf-query-loaders --update-ca
brew  /usr/local/Cellar/gdk-pixbuf/2.36.6: 214 files, 4.4MB
==> Downloading https://homebrew.bintray.com/bottles/harfbuzz-1.4.5.sierra.bottl
==> Pouring harfbuzz-1.4.5.sierra.bottle.tar.gz
brew  /usr/local/Cellar/harfbuzz/1.4.5: 133 files, 5.0MB
==> Upgrading poppler
==> Downloading https://homebrew.bintray.com/bottles/poppler-0.53.0.sierra.bottl
==> Pouring poppler-0.53.0.sierra.bottle.tar.gz
brew  /usr/local/Cellar/poppler/0.53.0: 478 files, 22.6MB
Warning: Some installed formula are missing dependencies.
You should `brew install` the missing dependencies:
  brew install doxygen
Run `brew missing` for more details.
hex-fiend: 2.5.0
/usr/local/Caskroom/hex-fiend/2.4.0 (2 files, 3.2KB)
==> Name
Hex Fiend
==> Artifacts
Hex Fiend.app (app)
MacBook-Pro-di-Fabio:~ faxus$ brew cask cleanup
Nothing to do
Removing: /usr/local/Cellar/atk/2.22.0... (206 files, 3.2MB)
Removing: /usr/local/Cellar/binutils/2.27... (110 files, 141.5MB)
Removing: /usr/local/Cellar/gdk-pixbuf/2.36.2... (226 files, 4.4MB)
Removing: /usr/local/Cellar/glib/2.50.3... (427 files, 22.4MB)
Removing: /usr/local/Cellar/gobject-introspection/1.50.0... (172 files, 9.6MB)
Removing: /usr/local/Cellar/harfbuzz/1.4.2... (133 files, 4.9MB)
Removing: /usr/local/Cellar/harfbuzz/1.4.4... (133 files, 5.0MB)
Removing: /usr/local/Cellar/libffi/3.0.13... (15 files, 361.8KB)
Removing: /usr/local/Cellar/libpng/1.6.28... (26 files, 1.2MB)
Removing: /usr/local/Cellar/pango/1.40.3... (125 files, 5.1MB)
Removing: /usr/local/Cellar/pcre/8.39... (203 files, 5.4MB)
Removing: /usr/local/Cellar/pkg-config/0.29.1_2... (10 files, 627.4KB)
Removing: /usr/local/Cellar/poppler/0.52.0... (478 files, 22.6MB)
Removing: /usr/local/Cellar/shared-mime-info/1.8... (844 files, 6.8MB)
Removing: /Users/faxus/Library/Caches/Homebrew/atk-2.22.0.sierra.bottle.tar.gz... (548.4KB)
Removing: /Users/faxus/Library/Caches/Homebrew/gdk-pixbuf-2.36.2.sierra.bottle.tar.gz... (1MB)
Removing: /Users/faxus/Library/Caches/Homebrew/glib-2.50.3.sierra.bottle.tar.gz... (6.6MB)
Removing: /Users/faxus/Library/Caches/Homebrew/gobject-introspection-1.50.0.sierra.bottle.tar.gz... (1.5MB)
Removing: /Users/faxus/Library/Caches/Homebrew/harfbuzz-1.4.2.sierra.bottle.tar.gz... (1.1MB)
Removing: /Users/faxus/Library/Caches/Homebrew/harfbuzz-1.4.4.sierra.bottle.tar.gz... (1.1MB)
Removing: /Users/faxus/Library/Caches/Homebrew/libffi-3.0.13.sierra.bottle.tar.gz... (107.0KB)
Removing: /Users/faxus/Library/Caches/Homebrew/libpng-1.6.28.sierra.bottle.tar.gz... (439.2KB)
Removing: /Users/faxus/Library/Caches/Homebrew/pango-1.40.3.sierra.bottle.tar.gz... (999.8KB)
Removing: /Users/faxus/Library/Caches/Homebrew/pcre-8.39.sierra.bottle.tar.gz... (1.8MB)
Removing: /Users/faxus/Library/Caches/Homebrew/pkg-config-0.29.1_2.sierra.bottle.tar.gz... (235.3KB)
Removing: /Users/faxus/Library/Caches/Homebrew/poppler-0.52.0.sierra.bottle.tar.gz... (6.9MB)
Removing: /Users/faxus/Library/Caches/Homebrew/shared-mime-info-1.8.sierra.bottle.tar.gz... (1MB)
Removing: /Users/faxus/Library/Logs/Homebrew/inkscape... (8 files, 10.6MB)
==> This operation has freed approximately 267.1MB of disk space.
Poche rifiniture, solo un'implementazione per Inkscape.
I CLT non hanno creato problemi di percorso, stavolta
Aggiornate sempre, ad ogni occasione.
Oggi l'occasione è l'aggiornamento di Xcode.
Verifichiamo se cambia qualcosa
To restore the stashed changes to /usr/local/Homebrew/Library/Taps/caskroom/homebrew-cask run:
  'cd /usr/local/Homebrew/Library/Taps/caskroom/homebrew-cask && git stash pop'
==> New Formulae
sqlite ✔...
glibmm ✔ ...
gobject-introspection ✔...
Non ci sono quindi da aggiornare i CLT
MacBook-Pro-di-Fabio:~ faxus$ brew cleanup; brew cask cleanup
Removing: /usr/local/Cellar/glibmm/2.50.0... (1,666 files, 44.5MB)
Removing: /usr/local/Cellar/gobject-introspection/1.52.0... (172 files, 9.6MB)
Removing: /usr/local/Cellar/sqlite/3.17.0... (11 files, 2.9MB)
Removing: /Users/faxus/Library/Caches/Homebrew/doxygen-1.8.13_1.sierra.bottle.tar.gz... (4.1MB)
Removing: /Users/faxus/Library/Caches/Homebrew/glibmm-2.50.0.sierra.bottle.tar.gz... (9.0MB)
Removing: /Users/faxus/Library/Caches/Homebrew/gobject-introspection-1.52.0.sierra.bottle.tar.gz... (1.5MB)
Removing: /Users/faxus/Library/Caches/Homebrew/poppler-0.53.0.sierra.bottle.tar.gz... (6.9MB)
Removing: /Users/faxus/Library/Caches/Homebrew/python-2.7.13.sierra.bottle.tar.gz... (11.8MB)
Removing: /Users/faxus/Library/Caches/Homebrew/sqlite-3.17.0.sierra.bottle.tar.gz... (1.4MB)
==> This operation has freed approximately 91.7MB of disk space.
Nothing to do
Nuova aggiunta:
Oops... non avevo disinstallato la 0.0.6...
Già che ci siamo
/Users/faxus/Library/Caches/Homebrew/Cask/iina--0.0.7.dmg
==> This operation has freed approximately 28.5MB of disk space.
==> New Formulae
maven@3.3
... pango ✔... libcroco ✔ ... librsvg ✔  ... nano
eris -> monax
Ero indietro...
Non l'avevo postata giorni fa
e infatti
$ brew upgrade
==> Auto-updated Homebrew!
==> New Formulae
immortal
aws-sdk-cpp... ... youtube-dl
Already up-to-date.
$ brew doctor
Messaggio da Scialla »
Vedo te e mi ricordo di farlo anche io....
a me da i soliti errori di python, dylibs, header, .la, .pc e static library...
...insomma, tutto a posto :D
