Running Processes:
PPID PID %CPU USER COMMAND
0 1 0.0 root /sbin/launchd
1 165 0.0 root /usr/sbin/syslogd
1 166 0.0 root /usr/libexec/UserEventAgent (System)
1 169 0.0 root /System/Library/PrivateFrameworks/Uninstall.framework/Resources/uninstalld
1 170 0.0 root /usr/libexec/kextd
1 171 0.0 root /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/Support/fseventsd
1 172 0.0 root /System/Library/PrivateFrameworks/MediaRemote.framework/Support/mediaremoted
1 175 0.0 root /usr/sbin/systemstats --daemon
1 176 0.0 root /usr/libexec/configd
1 177 0.0 root /Library/Application Support/DAEMONTools/DAEMONToolsService.app/Contents/MacOS/DAEMONToolsService
1 178 0.0 root endpointsecurityd
1 179 0.0 root /System/Library/CoreServices/powerd.bundle/powerd
1 183 0.0 root /usr/libexec/logd
1 184 0.0 root /usr/libexec/keybagd -t 15
1 185 0.0 root /Library/Application Support/MICE/360Daemon.app/Contents/MacOS/360Daemon
1 188 0.0 root /usr/libexec/watchdogd
1 191 0.0 root /usr/libexec/warmd
1 192 0.0 root /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Support/mds
1 193 0.0 _iconservices /System/Library/CoreServices/iconservicesd
1 194 0.7 root /usr/libexec/diskarbitrationd
1 197 0.0 root /usr/libexec/coreduetd
1 200 0.0 root /usr/libexec/opendirectoryd
1 202 0.0 root /System/Library/CoreServices/launchservicesd
1 203 0.0 _timed /usr/libexec/timed
1 205 0.0 _usbmuxd /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/A/Resources/usbmuxd -launchd
1 206 0.0 root /usr/sbin/securityd -i
1 207 0.0 root auditd -l
1 212 0.0 root autofsd
1 213 0.0 _displaypolicyd /usr/libexec/displaypolicyd -k 1
1 214 0.0 root /usr/libexec/dasd
1 218 0.0 root /usr/libexec/PerfPowerServices
1 220 0.0 root /System/Library/CoreServices/logind
1 221 0.0 root /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/Support/revisiond
1 222 0.0 root /usr/sbin/KernelEventAgent
1 224 0.0 root /usr/sbin/bluetoothd
1 225 1.3 _hidd /usr/libexec/hidd
1 226 0.6 root /usr/libexec/sandboxd
1 227 0.0 root /usr/libexec/corebrightnessd --launchd
1 228 0.0 root /usr/libexec/AirPlayXPCHelper
1 229 0.0 root /usr/sbin/notifyd
1 230 0.0 root /usr/libexec/amfid
1 231 0.0 root /System/Library/CoreServices/coreservicesd
1 232 0.0 root /usr/sbin/cfprefsd daemon
1 233 0.0 _distnote /usr/sbin/distnoted daemon
1 237 0.0 root /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/authd.xpc/Contents/MacOS/authd
1 239 0.0 _analyticsd /System/Library/PrivateFrameworks/CoreAnalytics.framework/Support/analyticsd
1 240 0.0 root /System/Library/PrivateFrameworks/TCC.framework/Resources/tccd system
1 242 0.0 Fabio /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow console
1 243 0.0 root aslmanager
1 285 0.0 _coreaudiod /usr/sbin/coreaudiod
1 295 0.0 _coreaudiod /System/Library/Frameworks/CoreAudio.framework/Versions/A/XPCServices/com.apple.audio.DriverHelper.xpc/Contents/MacOS/com.apple.audio.DriverHelper
1 296 0.0 root /usr/libexec/trustd
1 297 0.0 root /usr/libexec/airportd
1 298 0.0 root /System/Library/PrivateFrameworks/CoreDuetContext.framework/Resources/contextstored
1 299 0.0 root /usr/libexec/nehelper
1 314 0.0 root /usr/libexec/mobileassetd
1 328 0.0 root /usr/libexec/sysmond
1 329 0.0 _nsurlsessiond /usr/libexec/nsurlsessiond --privileged
1 330 0.0 _mdnsresponder /usr/sbin/mDNSResponder
1 331 0.0 root /usr/sbin/mDNSResponderHelper
175 332 0.0 root /usr/sbin/systemstats --logger-helper /private/var/db/systemstats
1 333 0.0 root /usr/libexec/lsd runAsRoot
1 335 0.0 root /usr/libexec/syspolicyd
1 337 0.0 root /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/XPCServices/com.apple.cmio.registerassistantservice.xpc/Contents/MacOS/com.apple.cmio.registerassistantservice
1 339 10.0 _windowserver /System/Library/PrivateFrameworks/SkyLight.framework/Resources/WindowServer -daemon
1 341 0.0 root /usr/libexec/smd
1 343 0.0 root /System/Library/PrivateFrameworks/SystemAdministration.framework/XPCServices/writeconfig.xpc/Contents/MacOS/writeconfig
1 344 0.0 root /System/Library/PrivateFrameworks/WirelessDiagnostics.framework/Support/awdd
1 345 0.0 root /usr/libexec/diskmanagementd
1 346 0.0 root /usr/libexec/searchpartyd
1 347 0.0 _cmiodalassistants /System/Library/Frameworks/CoreMediaIO.framework/Resources/VDC.plugin/Contents/Resources/VDCAssistant
1 350 0.0 _networkd /usr/libexec/symptomsd
1 352 0.0 _locationd /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod
1 353 0.0 _locationd /usr/libexec/secinitd
1 355 0.0 root /System/Library/CryptoTokenKit/com.apple.ifdreader.slotd/Contents/MacOS/com.apple.ifdreader
1 356 0.0 root /usr/libexec/apfsd
1 358 0.0 root /usr/libexec/usbd
1 359 0.0 root /System/Library/PrivateFrameworks/InstallerDiagnostics.framework/Versions/A/Resources/installerdiagwatcher
1 360 0.0 _locationd /usr/sbin/cfprefsd agent
1 361 0.0 _locationd /usr/libexec/trustd --agent
1 362 0.0 root /usr/libexec/tzd
1 366 0.0 _softwareupdate /System/Library/CoreServices/Software Update.app/Contents/Resources/softwareupdated
1 367 0.0 _locationd /usr/libexec/locationd
1 368 0.0 root /System/Library/CoreServices/Software Update.app/Contents/Resources/suhelperd
1 374 0.0 _atsserver /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support/fontd
1 388 0.0 root /System/Library/PrivateFrameworks/Heimdal.framework/Helpers/kdc
1 439 0.0 root /usr/libexec/secinitd
1 440 0.0 root /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd-helper -launchd
1 441 0.0 root /usr/libexec/dprivacyd
1 444 0.0 root /System/Library/PrivateFrameworks/XprotectFramework.framework/Versions/A/XPCServices/XprotectService.xpc/Contents/MacOS/XprotectService
1 445 0.0 root /System/Library/CoreServices/iconservicesagent runAsRoot
1 449 0.0 _nsurlstoraged /usr/libexec/nsurlstoraged --privileged
1 450 0.0 root /System/Library/Frameworks/PreferencePanes.framework/Versions/A/XPCServices/cacheAssistant.xpc/Contents/MacOS/cacheAssistant
1 451 0.0 root /usr/libexec/findmydeviced
1 453 0.0 root /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
1 454 0.0 root /usr/libexec/rtcreportingd
1 465 0.0 root /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/com.apple.CodeSigningHelper.xpc/Contents/MacOS/com.apple.CodeSigningHelper
1 466 0.0 root /usr/libexec/runningboardd
1 468 0.0 root /System/Library/PrivateFrameworks/InstallerDiagnostics.framework/Versions/A/Resources/installerdiagd
1 470 0.0 root /usr/libexec/firmwarecheckers/ethcheck/ethcheck --integrity-check-daemon
1 475 0.0 _captiveagent /usr/libexec/captiveagent
1 476 0.0 root /usr/libexec/thermald
1 477 0.0 _netbios /usr/sbin/netbiosd
1 478 0.0 root /System/Library/Frameworks/AudioToolbox.framework/AudioComponentRegistrar -daemon
1 479 0.0 _coreaudiod /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
1 485 0.0 root /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 486 0.0 _locationd /usr/sbin/distnoted agent
1 488 0.0 root /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mds_stores
1 490 0.0 root /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
1 491 0.0 root /usr/libexec/colorsync.displayservices
1 492 0.0 root /System/Library/PrivateFrameworks/AmbientDisplay.framework/Versions/A/XPCServices/com.apple.AmbientDisplayAgent.xpc/Contents/MacOS/com.apple.AmbientDisplayAgent
1 493 0.0 root /usr/libexec/colorsyncd
179 495 0.0 root /usr/libexec/ioupsd
1 498 0.0 root /usr/sbin/systemsoundserverd
1 501 0.0 root /usr/libexec/nesessionmanager
1 502 0.0 _appleevents /System/Library/CoreServices/appleeventsd --server
1 503 0.0 Fabio /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker -s mdworker-sizing -c MDSSizingWorker -m com.apple.mdworker.sizing
1 504 0.0 _spotlight /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker -s mdworker-sizing -c MDSSizingWorker -m com.apple.mdworker.sizing
1 509 0.0 Fabio /usr/sbin/cfprefsd agent
1 510 0.0 root /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/XPCServices/ViewBridgeAuxiliary.xpc/Contents/MacOS/ViewBridgeAuxiliary
1 511 0.0 root /usr/sbin/distnoted agent
1 512 0.0 Fabio /usr/libexec/lsd
1 513 0.0 root /usr/libexec/bootinstalld
1 516 0.0 root /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 517 0.0 root /System/Library/PrivateFrameworks/AccountPolicy.framework/XPCServices/com.apple.AccountPolicyHelper.xpc/Contents/MacOS/com.apple.AccountPolicyHelper
1 519 0.0 _spotlight /usr/libexec/trustd --agent
1 521 0.0 root /System/Library/CoreServices/ReportCrash daemon
1 523 0.0 root /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd
1 524 0.0 Fabio /System/Library/Frameworks/LocalAuthentication.framework/Support/coreauthd
1 525 0.0 root /usr/libexec/securityd_service
1 527 0.0 root /System/Library/Frameworks/SystemExtensions.framework/Versions/A/Helpers/sysextd
1 528 0.0 Fabio /usr/libexec/UserEventAgent (Aqua)
1 530 0.0 Fabio /usr/sbin/distnoted agent
1 531 0.0 Fabio /usr/sbin/universalaccessd launchd -s
1 532 0.0 Fabio /System/Library/PrivateFrameworks/CloudServices.framework/Helpers/com.apple.sbd
1 533 0.0 Fabio /usr/libexec/knowledge-agent
1 534 0.0 Fabio /usr/libexec/trustd --agent
1 536 0.0 Fabio /usr/libexec/secd
1 537 0.0 Fabio /usr/libexec/rapportd
1 538 0.0 Fabio /System/Library/PrivateFrameworks/HomeKitDaemon.framework/Support/homed
1 539 0.0 Fabio /System/Library/PrivateFrameworks/IDS.framework/identityservicesd.app/Contents/MacOS/identityservicesd
1 540 0.0 _assetcache /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/XPCServices/AssetCacheLocatorService.xpc/Contents/MacOS/AssetCacheLocatorService -d
1 541 0.0 Fabio /System/Library/PrivateFrameworks/CloudKitDaemon.framework/Support/cloudd
1 542 0.0 Fabio /System/Library/PrivateFrameworks/TCC.framework/Resources/tccd
1 543 0.0 Fabio /usr/libexec/nsurlsessiond
1 544 0.0 Fabio /usr/libexec/routined LAUNCHED_BY_LAUNCHD
1 545 0.0 Fabio /usr/sbin/usernoted
1 546 0.0 Fabio /System/Library/Frameworks/CoreTelephony.framework/Support/CommCenter -L
1 547 0.0 Fabio /System/Library/CoreServices/APFSUserAgent
1 548 0.0 Fabio /usr/libexec/networkserviceproxy
1 549 0.0 Fabio /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
1 550 0.0 Fabio /System/Library/PrivateFrameworks/CoreDuetContext.framework/Resources/ContextStoreAgent
1 551 0.0 Fabio /System/Library/PrivateFrameworks/CoreSuggestions.framework/Versions/A/Support/suggestd
1 552 0.0 Fabio /System/Library/PrivateFrameworks/UsageTracking.framework/Versions/A/UsageTrackingAgent
1 553 0.0 Fabio /System/Library/PrivateFrameworks/PhotoLibraryServices.framework/Versions/A/Support/photolibraryd
1 554 0.0 Fabio /usr/libexec/secinitd
1 555 0.0 Fabio /System/Library/CoreServices/lockoutagent
1 556 0.0 Fabio /System/Library/CoreServices/WiFiAgent.app/Contents/MacOS/WiFiAgent
1 557 0.0 Fabio /usr/libexec/dmd
1 558 0.0 Fabio /System/Library/PrivateFrameworks/ScreenTimeCore.framework/Versions/A/ScreenTimeAgent
1 559 0.0 root /usr/sbin/spindump
1 560 0.0 Fabio /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
1 561 0.0 Fabio /usr/libexec/spindump_agent
1 563 0.0 Fabio /System/Library/PrivateFrameworks/CoreCDP.framework/Versions/A/Resources/cdpd
1 564 0.0 Fabio /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Helpers/ProtectedCloudKeySyncing
1 565 0.0 Fabio /System/Library/CoreServices/Keychain Circle Notification.app/Contents/MacOS/Keychain Circle Notification
1 566 0.0 root /System/Library/CoreServices/SubmitDiagInfo server-init
1 567 0.0 Fabio /System/Library/Frameworks/Security.framework/Versions/A/Resources/CloudKeychainProxy.bundle/Contents/MacOS/CloudKeychainProxy
1 568 0.0 _nsurlsessiond /System/Library/PrivateFrameworks/StreamingZip.framework/Versions/A/XPCServices/com.apple.StreamingUnzipService.xpc/Contents/MacOS/com.apple.StreamingUnzipService
1 569 0.0 _assetcache /usr/libexec/AssetCache/AssetCache
1 571 0.0 Fabio /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/Support/assistantd
1 574 0.0 Fabio /usr/libexec/pboard
1 575 0.0 Fabio /usr/libexec/nsurlstoraged
1 578 0.0 root /usr/sbin/WirelessRadioManagerd
1 579 0.0 Fabio /System/Library/PrivateFrameworks/TelephonyUtilities.framework/callservicesd
1 581 0.0 Fabio /System/Library/PrivateFrameworks/CalendarNotification.framework/Versions/A/XPCServices/CalNCService.xpc/Contents/MacOS/CalNCService
1 582 0.0 Fabio /System/Library/CoreServices/ScopedBookmarkAgent
1 583 0.0 Fabio /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/XPCServices/com.apple.DictionaryServiceHelper.xpc/Contents/MacOS/com.apple.DictionaryServiceHelper
1 584 0.0 Fabio /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent
1 585 0.0 Fabio /System/Library/PrivateFrameworks/IMDPersistence.framework/XPCServices/IMDPersistenceAgent.xpc/Contents/MacOS/IMDPersistenceAgent
1 586 0.0 root /usr/sbin/filecoordinationd
1 588 0.0 Fabio /System/Library/Frameworks/CryptoTokenKit.framework/ctkd -tw
1 589 0.0 Fabio /usr/libexec/pkd
1 590 0.0 Fabio /System/Library/Frameworks/AddressBook.framework/Executables/ContactsAccountsService
1 591 0.0 Fabio /System/Library/PrivateFrameworks/AuthKit.framework/Versions/A/Support/akd
1 592 0.0 Fabio /System/Library/CoreServices/mapspushd
1 593 0.0 Fabio /System/Library/CoreServices/LocationMenu.app/Contents/MacOS/LocationMenu
1 594 0.0 _fpsd /System/Library/PrivateFrameworks/CoreADI.framework/adid
1 595 0.0 Fabio /System/Library/PrivateFrameworks/CoreFollowUp.framework/Versions/A/Support/followupd
1 596 0.0 root /System/Library/PrivateFrameworks/AssetCacheServicesExtensions.framework/XPCServices/AssetCacheTetheratorService.xpc/Contents/MacOS/AssetCacheTetheratorService
1 597 0.0 Fabio /System/Library/PrivateFrameworks/FamilyCircle.framework/Versions/A/Resources/familycircled
1 599 0.0 Fabio /System/Library/CoreServices/NotificationCenter.app/Contents/MacOS/NotificationCenter
1 605 0.0 Fabio /usr/libexec/sharingd
1 608 0.0 Fabio /System/Library/CoreServices/sharedfilelistd
1 609 0.0 Fabio /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/XPCServices/com.apple.siri.ClientFlow.ClientScripter.xpc/Contents/MacOS/com.apple.siri.ClientFlow.ClientScripter
1 610 0.0 Fabio /System/Library/Frameworks/Security.framework/Versions/A/XPCServices/TrustedPeersHelper.xpc/Contents/MacOS/TrustedPeersHelper
1 611 0.0 Fabio /System/Library/PrivateFrameworks/AppSSO.framework/Support/AppSSOAgent.app/Contents/MacOS/AppSSOAgent
1 612 0.0 Fabio /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/XPCServices/com.apple.geod.xpc/Contents/MacOS/com.apple.geod
1 613 0.0 Fabio /System/Library/PrivateFrameworks/AMPLibrary.framework/Versions/A/Support/AMPLibraryAgent --launchd
1 614 0.0 Fabio /usr/libexec/neagent
1 616 0.0 Fabio /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/XPCServices/AssetCacheLocatorService.xpc/Contents/MacOS/AssetCacheLocatorService -a
1 620 0.0 Fabio /System/Library/CoreServices/pbs
1 621 0.0 Fabio /System/Library/CoreServices/backgroundtaskmanagementagent
1 622 0.0 Fabio /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/XPCServices/ViewBridgeAuxiliary.xpc/Contents/MacOS/ViewBridgeAuxiliary
1 624 0.0 Fabio /System/Library/CoreServices/talagent
1 626 0.0 _ctkd /System/Library/Frameworks/CryptoTokenKit.framework/ctkd -s
1 627 0.0 Fabio /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support/fontd
1 632 0.0 Fabio /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
1 634 0.0 Fabio /System/Library/PrivateFrameworks/MediaRemote.framework/Support/mediaremoteagent
1 635 0.0 Fabio /System/Library/PrivateFrameworks/UserActivity.framework/Agents/useractivityd
1 636 0.0 Fabio /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
1 637 0.0 Fabio /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/Versions/A/Support/bird
1 638 0.0 Fabio /usr/libexec/swcd
1 639 0.0 Fabio /System/Library/CoreServices/iconservicesagent
1 640 0.0 Fabio /Library/Apple/System/Library/CoreServices/SafariSupport.bundle/Contents/MacOS/SafariBookmarksSyncAgent
1 641 0.0 Fabio /System/Library/PrivateFrameworks/PassKitCore.framework/passd
1 642 0.0 Fabio /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storeaccountd
1 645 0.0 Fabio /System/Library/CoreServices/NotificationCenter.app/Contents/XPCServices/com.apple.notificationcenterui.WeatherSummary.xpc/Contents/MacOS/com.apple.notificationcenterui.WeatherSummary
1 646 0.0 Fabio /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 647 0.0 Fabio /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/commerce
1 648 0.0 Fabio /System/Library/PrivateFrameworks/WeatherKit.framework/Versions/A/XPCServices/com.apple.WeatherKitService.xpc/Contents/MacOS/com.apple.WeatherKitService
1 649 0.0 Fabio /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/corespotlightd
1 650 0.0 Fabio /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
1 651 0.0 Fabio /System/Library/CoreServices/CoreLocationAgent.app/Contents/MacOS/CoreLocationAgent
1 652 0.0 Fabio /usr/libexec/fmfd
1 654 0.0 Fabio /System/Library/PrivateFrameworks/CommunicationsFilter.framework/CMFSyncAgent
1 655 0.0 _applepay /usr/libexec/nfcd
1 656 0.0 Fabio /System/Library/PrivateFrameworks/ClassKit.framework/Versions/A/progressd
1 668 0.0 root /System/Library/PrivateFrameworks/PackageKit.framework/Resources/system_installd
1 670 0.0 Fabio /System/Library/PrivateFrameworks/SoftwareUpdate.framework/Resources/SoftwareUpdateNotificationManager.app/Contents/MacOS/SoftwareUpdateNotificationManager
1 671 10.5 Fabio /System/Library/PrivateFrameworks/CacheDelete.framework/deleted
1 672 0.0 root /System/Library/CoreServices/CrashReporterSupportHelper server-init
1 673 0.0 Fabio /System/Library/PrivateFrameworks/CloudPhotoServices.framework/Versions/A/XPCServices/com.apple.CloudPhotosConfiguration.xpc/Contents/MacOS/com.apple.CloudPhotosConfiguration
1 679 0.0 root /System/Library/PrivateFrameworks/CacheDelete.framework/deleted_helper
1 680 0.0 Fabio /System/Library/PrivateFrameworks/DistributedEvaluation.framework/Versions/A/XPCServices/com.apple.siri-distributed-evaluation.xpc/Contents/MacOS/com.apple.siri-distributed-evaluation
1 682 0.0 Fabio /System/Library/CoreServices/diagnostics_agent
1 683 0.0 Fabio /usr/libexec/replayd
1 684 0.0 root /System/Library/PrivateFrameworks/PackageKit.framework/Resources/installd
1 685 0.0 Fabio /System/Library/PrivateFrameworks/FileProvider.framework/Support/fileproviderd
1 686 0.0 Fabio /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Resources/storedownloadd
1 687 0.0 Fabio /System/Library/Frameworks/QuickLookThumbnailing.framework/Support/com.apple.quicklook.ThumbnailsAgent
1 688 0.0 root /System/Library/PrivateFrameworks/CoreSymbolication.framework/coresymbolicationd
1 702 0.0 Fabio /System/Library/Frameworks/InputMethodKit.framework/Resources/imklaunchagent
1 703 0.0 root /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 704 0.0 root /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 721 0.0 Fabio /System/Library/Input Methods/PressAndHold.app/Contents/PlugIns/PAH_Extension.appex/Contents/MacOS/PAH_Extension
1 734 0.0 Fabio cloudphotod
1 741 0.0 _fpsd /System/Library/PrivateFrameworks/CoreFP.framework/Versions/A/fpsd
1 744 0.0 Fabio /System/Library/Frameworks/AudioToolbox.framework/AudioComponentRegistrar
1 746 0.0 Fabio /System/Library/PrivateFrameworks/CloudDocsDaemon.framework/XPCServices/ContainerMetadataExtractor.xpc/Contents/MacOS/ContainerMetadataExtractor
1 747 0.0 Fabio /System/Library/PrivateFrameworks/AppStoreDaemon.framework/Support/appstoreagent
1 748 0.0 Fabio /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
1 755 0.0 Fabio /System/Library/PrivateFrameworks/ContextKit.framework/Versions/A/XPCServices/ContextService.xpc/Contents/MacOS/ContextService
1 758 0.0 Fabio /System/Library/PrivateFrameworks/Categories.framework/Versions/A/XPCServices/CategoriesService.xpc/Contents/MacOS/CategoriesService
1 778 0.0 Fabio /System/Library/CoreServices/CoreServicesUIAgent.app/Contents/MacOS/CoreServicesUIAgent
1 809 0.0 Fabio /usr/libexec/adprivacyd
1 812 0.0 root /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 813 0.0 root /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp -d
1 814 0.0 root /System/Library/Frameworks/VideoToolbox.framework/Versions/A/XPCServices/VTDecoderXPCService.xpc/Contents/MacOS/VTDecoderXPCService
1 815 0.0 Fabio /System/Library/Frameworks/CryptoTokenKit.framework/ctkahp.bundle/Contents/MacOS/ctkahp
1 819 0.0 root /usr/libexec/periodic-wrapper daily
1 905 0.0 Fabio /System/Library/CoreServices/ReportCrash agent
1 912 0.0 Fabio /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/XPCServices/com.apple.siri.embeddedspeech.xpc/Contents/MacOS/com.apple.siri.embeddedspeech
1 913 0.0 Fabio /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/Support/assistant_service
1 935 0.0 root /usr/libexec/tailspind
1 939 0.0 _spotlight /usr/sbin/distnoted agent
1 946 0.0 Fabio /usr/libexec/siriknowledged
1 1034 0.0 Fabio /System/Library/PrivateFrameworks/FMClient.framework/Versions/A/XPCServices/FMIPClientXPCService.xpc/Contents/MacOS/FMIPClientXPCService
1 1035 0.0 Fabio /System/Library/PrivateFrameworks/DeviceCheckInternal.framework/devicecheckd
1 1036 0.0 root /usr/libexec/mobileactivationd
1 1038 0.0 Fabio /usr/libexec/searchpartyuseragent
1 1042 0.0 root /usr/bin/sysdiagnose
1 1045 0.0 Fabio /System/Library/PrivateFrameworks/AssistantServices.framework/Versions/A/XPCServices/media-indexer.xpc/Contents/MacOS/media-indexer
1 1046 0.0 Fabio /System/Library/PrivateFrameworks/PodcastServices.framework/XPCServices/PodcastContentService.xpc/Contents/MacOS/PodcastContentService
1 1047 0.0 Fabio /System/Library/PrivateFrameworks/BookKit.framework/Versions/A/XPCServices/com.apple.BKAgentService.xpc/Contents/MacOS/com.apple.BKAgentService
1 1048 0.0 Fabio /System/Library/PrivateFrameworks/AMPLibrary.framework/Versions/A/Support/AMPArtworkAgent --launchd
1 1049 0.0 Fabio /usr/libexec/silhouette
1 1051 0.0 Fabio /System/Library/PrivateFrameworks/CoreParsec.framework/parsecd
1 1057 0.0 Fabio /usr/libexec/USBAgent
1 1086 0.0 Fabio /usr/libexec/transparencyd
1 1150 0.0 Fabio /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdwrite
1 1151 0.0 Fabio /System/Library/CoreServices/Spotlight.app/Contents/MacOS/Spotlight
1 1340 0.0 lavoro /usr/sbin/cfprefsd agent
1 1353 0.0 lavoro /usr/sbin/distnoted agent
1 1354 0.0 lavoro /usr/libexec/lsd
1 1367 0.0 lavoro /usr/libexec/trustd --agent
1 1385 0.0 lavoro /usr/libexec/secd
1 1704 0.0 Fabio /System/Library/CoreServices/OSDUIHelper.app/Contents/MacOS/OSDUIHelper
1 1759 0.0 Fabio /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
1 1760 0.0 Fabio /System/Library/CoreServices/SystemUIServer.app/Contents/MacOS/SystemUIServer
1 1761 0.0 Fabio /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
1 1768 0.0 Fabio /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/XPCServices/QuickLookUIService.xpc/Contents/MacOS/QuickLookUIService
1 1769 0.0 Fabio /usr/libexec/WiFiVelocityAgent
1 1771 0.0 root /usr/libexec/wifivelocityd
1 1772 0.0 Fabio /System/Library/PrivateFrameworks/login.framework/Versions/A/XPCServices/LoginUserService.xpc/Contents/MacOS/LoginUserService
1 1776 0.0 Fabio SafeEjectGPUAgent
1 1777 0.0 Fabio /System/Library/CoreServices/Menu Extras/SafeEjectGPUExtra.menu/Contents/XPCServices/SafeEjectGPUService.xpc/Contents/MacOS/SafeEjectGPUService
1 1793 0.0 Fabio /System/Library/PrivateFrameworks/AMPDevices.framework/Versions/A/Support/AMPDeviceDiscoveryAgent --launchd
1 1802 0.0 Fabio /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 1803 0.0 Fabio /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 1806 0.0 Fabio /Applications/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon
1 1807 0.0 Fabio /Applications/DAEMON Tools.app/Contents/PlugIns/ContextMenu.appex/Contents/MacOS/ContextMenu
1 1808 0.0 Fabio /Applications/OneDrive.app/Contents/PlugIns/FinderSync.appex/Contents/MacOS/FinderSync
1 1825 0.0 Fabio /usr/libexec/studentd
1 1826 0.0 Fabio /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Contents/MacOS/com.apple.dock.extra
1 1828 0.0 Fabio /System/Library/PrivateFrameworks/CoreSpeech.framework/corespeechd
1 1832 0.0 Fabio /System/Library/CoreServices/SocialPushAgent.app/Contents/MacOS/SocialPushAgent
1 1834 0.0 Fabio /System/Library/CoreServices/Siri.app/Contents/MacOS/Siri launchd
1 1836 0.0 Fabio /System/Library/Image Capture/Support/icdd
1 1838 0.0 Fabio /System/Library/PrivateFrameworks/AskPermission.framework/Versions/A/Resources/askpermissiond
1 1840 0.0 Fabio /System/Library/CoreServices/AirPlayUIAgent.app/Contents/MacOS/AirPlayUIAgent --launchd
1 1841 0.0 Fabio /Users/Fabio/Library/Application Support/Setapp/LaunchAgents/Setapp.app/Contents/MacOS/SetappAgent -xpcServer
1 1842 0.0 Fabio /System/Library/CoreServices/cloudpaird
1 1843 0.0 Fabio /System/Library/CoreServices/TextInputMenuAgent.app/Contents/MacOS/TextInputMenuAgent
1 1844 0.0 Fabio /System/Library/PrivateFrameworks/AppleMediaServices.framework/Resources/amsaccountsd
1 1846 0.1 Fabio /Applications/Dropbox.app/Contents/MacOS/Dropbox
1 1851 0.0 Fabio /Applications/AppKiller.app/Contents/MacOS/AppKiller
1 1853 0.0 Fabio /Applications/Dropbox.app/Contents/MacOS/Dropbox -type:crashpad-handler --no-upload-gzip --no-rate-limit --capture-python --no-identify-client-via-url --database=/Users/Fabio/.dropbox/Crashpad --metrics-dir=0 --url=https://d.dropbox.com/report_crashpad_minidump --https-pin=0x23,0xf2,0xed,0xff,0x3e,0xde,0x90,0x25,0x9a,0x9e,0x30,0xf4,0xa,0xf8,0xf9,0x12,0xa5,0xe5,0xb3,0x69,0x4e,0x69,0x38,0x44,0x3,0x41,0xf6,0x6,0xe,0x1,0x4f,0xfa --https-pin=0xaf,0xf9,0x88,0x90,0x6d,0xde,0x12,0x95,0x5d,0x9b,0xeb,0xbf,0x92,0x8f,0xdc,0xc3,0x1c,0xce,0x32,0x8d,0x5b,0x93,0x84,0xf2,0x1c,0x89,0x41,0xca,0x26,0xe2,0x3,0x91 --https-pin=0x5a,0x88,0x96,0x47,0x22,0xe,0x54,0xd6,0xbd,0x8a,0x16,0x81,0x72,0x24,0x52,0xb,0xb5,0xc7,0x8e,0x58,0x98,0x4b,0xd5,0x70,0x50,0x63,0x88,0xb9,0xde,0xf,0x7,0x5f --https-pin=0xfe,0xa2,0xb7,0xd6,0x45,0xfb,0xa7,0x3d,0x75,0x3c,0x1e,0xc9,0xa7,0x87,0xc,0x40,0xe1,0xf7,0xb0,0xc5,0x61,0xe9,0x27,0xb9,0x85,0xbf,0x71,0x18,0x66,0xe3,0x6f,0x22 --https-pin=0x76,0xee,0x85,0x90,0x37,0x4c,0x71,0x54,0x37,0xbb,0xca,0x6b,0xba,0x60,0x28,0xea,0xdd,0xe2,0xdc,0x6d,0xbb,0xb8,0xc3,0xf6,0x10,0xe8,0x51,0xf1,0x1d,0x1a,0xb7,0xf5 --https-pin=0x6d,0xbf,0xae,0x0,0xd3,0x7b,0x9c,0xd7,0x3f,0x8f,0xb4,0x7d,0xe6,0x59,0x17,0xaf,0x0,0xe0,0xdd,0xdf,0x42,0xdb,0xce,0xac,0x20,0xc1,0x7c,0x2,0x75,0xee,0x20,0x95 --https-pin=0x1e,0xa3,0xc5,0xe4,0x3e,0xd6,0x6c,0x2d,0xa2,0x98,0x3a,0x42,0xa4,0xa7,0x9b,0x1e,0x90,0x67,0x86,0xce,0x9f,0x1b,0x58,0x62,0x14,0x19,0xa0,0x4,0x63,0xa8,0x7d,0x38 --https-pin=0x87,0xaf,0x34,0xd6,0x6f,0xb3,0xf2,0xfd,0xf3,0x6e,0x9,0x11,0x1e,0x9a,0xba,0x2f,0x6f,0x44,0xb2,0x7,0xf3,0x86,0x3f,0x3d,0xb,0x54,0xb2,0x50,0x23,0x90,0x9a,0xa5 --https-pin=0xbc,0xfb,0x44,0xaa,0xb9,0xad,0x2,0x10,0x15,0x70,0x6b,0x41,0x21,0xea,0x76,0x1c,0x81,0xc9,0xe8,0x89,0x67,0x59,0xf,0x6f,0x94,0xae,0x74,0x4d,0xc8,0x8b,0x78,0xfb --https-pin=0xab,0x98,0x49,0x52,0x76,0xad,0xf1,0xec,0xaf,0xf2,0x8f,0x35,0xc5,0x30,0x48,0x78,0x1e,0x5c,0x17,0x18,0xda,0xb9,0xc8,0xe6,0x7a,0x50,0x4f,0x4f,0x6a,0x51,0x32,0x8f --https-pin=0x49,0x5,0x46,0x66,0x23,0xab,0x41,0x78,0xbe,0x92,0xac,0x5c,0xbd,0x65,0x84,0xf7,0xa1,0xe1,0x7f,0x27,0x65,0x2d,0x5a,0x85,0xaf,0x89,0x50,0x4e,0xa2,0x39,0xaa,0xaa --https-pin=0x56,0x32,0xd9,0x7b,0xfa,0x77,0x5b,0xf3,0xc9,0x9d,0xde,0xa5,0x2f,0xc2,0x55,0x34,0x10,0x86,0x40,0x16,0x72,0x9c,0x52,0xdd,0x65,0x24,0xc8,0xa9,0xc3,0xb4,0x48,0x9f --https-pin=0x2a,0x8f,0x2d,0x8a,0xf0,0xeb,0x12,0x38,0x98,0xf7,0x4c,0x86,0x6a,0xc3,0xfa,0x66,0x90,0x54,0xe2,0x3c,0x17,0xbc,0x7a,0x95,0xbd,0x2,0x34,0x19,0x2d,0xc6,0x35,0xd0 --https-pin=0x32,0xb6,0x4b,0x66,0x72,0x7a,0x20,0x63,0xe4,0x6,0x6f,0x3b,0x95,0x8c,0xb0,0xaa,0xee,0x57,0x6a,0x5e,0xce,0xfd,0x95,0x33,0x99,0xbb,0x88,0x74,0x73,0x1d,0x95,0x87 --https-pin=0xf5,0x3c,0x22,0x5,0x98,0x17,0xdd,0x96,0xf4,0x0,0x65,0x16,0x39,0xd2,0xf8,0x57,0xe2,0x10,0x70,0xa5,0x9a,0xbe,0xd9,0x7,0x94,0x0,0xd9,0xf6,0x95,0x50,0x69,0x0 --https-pin=0x67,0xdc,0x4f,0x32,0xfa,0x10,0xe7,0xd0,0x1a,0x79,0xa0,0x73,0xaa,0xc,0x9e,0x2,0x12,0xec,0x2f,0xfc,0x3d,0x77,0x9e,0xa,0xa7,0xf9,0xc0,0xf0,0xe1,0xc2,0xc8,0x93 --https-pin=0x19,0x6,0xc6,0x12,0x4d,0xbb,0x43,0x85,0x78,0xd0,0xe,0x6,0x6d,0x50,0x54,0xc6,0xc3,0x7f,0xf,0xa6,0x2,0x8c,0x5,0x54,0x5e,0x9,0x94,0xed,0xda,0xec,0x86,0x29 --https-pin=0x1d,0x75,0xd0,0x83,0x1b,0x9e,0x8,0x85,0x39,0x4d,0x32,0xc7,0xa1,0xbf,0xdb,0x3d,0xbc,0x1c,0x28,0xe2,0xb0,0xe8,0x39,0x1f,0xb1,0x35,0x98,0x1d,0xbc,0x5b,0xa9,0x36 --annotation=host_int_account1_boot=5354845143 --annotation=machine_id=300937b9-1662-56fb-9605-72f629f104ad --annotation=platform=mac --annotation=platform_version=10.15.6 --handshake-fd=4
1846 1854 0.0 Fabio /Applications/Dropbox.app/Contents/MacOS/Dropbox -type:exit-monitor -method:collectupload -python-version:3.7.5 -session-token:85dd45a2-b05c-412a-b9c8-e93c28e02943 -target-handle:1846 -target-shutdown-event:4 -target-restart-event:6 -target-command-line:/Applications/Dropbox.app/Contents/MacOS/Dropbox
1 1861 0.0 Fabio /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 1874 0.0 Fabio /System/Library/Frameworks/QuickLook.framework/Versions/A/XPCServices/QuickLookSatellite.xpc/Contents/MacOS/QuickLookSatellite
1 1882 0.0 Fabio /System/Library/CoreServices/Siri.app/Contents/XPCServices/SiriNCService.xpc/Contents/MacOS/SiriNCService
1 1889 0.0 Fabio /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.external.extra.xpc/Contents/MacOS/com.apple.dock.external.extra
1 1890 0.0 Fabio /System/Library/PrivateFrameworks/CallHistory.framework/Support/CallHistoryPluginHelper
1 1894 0.0 _gamecontrollerd /usr/libexec/gamecontrollerd
1846 1895 0.0 Fabio /Applications/Dropbox.app/Contents/Frameworks/Tungsten.framework/Versions/A/Frameworks/Dropbox Web Helper.app/Contents/MacOS/Dropbox Web Helper --type=gpu-process --field-trial-handle=0,18004334198828983329,7208004638977674188,131072 --disable-breakpad --framework-dir-path=/Applications/Dropbox.app/Contents/Frameworks/Tungsten.framework/Versions/A/Frameworks/Chromium Embedded Framework.framework --log-file=/Users/Fabio/Library/Logs/Dropbox_debug.log --log-severity=warning --product-version=Tungsten/73.3683.95 --suffix-user-agent=ShangriLa/101.4.434 --lang=en-US --tungsten-schemes=dbx-local --tungsten-crashpad=/Applications/Dropbox.app/Contents/Frameworks/DropboxCrashpad.framework/Versions/A/DropboxCrashpad --gpu-preferences=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 --log-file=/Users/Fabio/Library/Logs/Dropbox_debug.log --service-request-channel-token=9254696458352538625
1 1899 0.0 Fabio /System/Library/Frameworks/VideoToolbox.framework/Versions/A/XPCServices/VTDecoderXPCService.xpc/Contents/MacOS/VTDecoderXPCService
1846 1902 0.0 Fabio /Applications/Dropbox.app/Contents/Frameworks/Tungsten.framework/Versions/A/Frameworks/Dropbox Web Helper.app/Contents/MacOS/Dropbox Web Helper --type=renderer --disable-breakpad --file-url-path-alias=/gen=/Applications/gen --log-file=/Users/Fabio/Library/Logs/Dropbox_debug.log --field-trial-handle=0,18004334198828983329,7208004638977674188,131072 --service-pipe-token=14926331329178508630 --lang=en-US --framework-dir-path=/Applications/Dropbox.app/Contents/Frameworks/Tungsten.framework/Versions/A/Frameworks/Chromium Embedded Framework.framework --log-file=/Users/Fabio/Library/Logs/Dropbox_debug.log --log-severity=warning --product-version=Tungsten/73.3683.95 --suffix-user-agent=ShangriLa/101.4.434 --disable-extensions --uncaught-exception-stack-size=16 --tungsten-schemes=dbx-local --tungsten-crashpad=/Applications/Dropbox.app/Contents/Frameworks/DropboxCrashpad.framework/Versions/A/DropboxCrashpad --num-raster-threads=2 --enable-zero-copy --enable-gpu-memory-buffer-compositor-resources --enable-main-frame-before-activation --service-request-channel-token=14926331329178508630 --renderer-client-id=3 --seatbelt-client=90
1846 1903 0.0 Fabio /Applications/Dropbox.app/Contents/Frameworks/Tungsten.framework/Versions/A/Frameworks/Dropbox Web Helper.app/Contents/MacOS/Dropbox Web Helper --type=renderer --disable-breakpad --file-url-path-alias=/gen=/Applications/gen --log-file=/Users/Fabio/Library/Logs/Dropbox_debug.log --field-trial-handle=0,18004334198828983329,7208004638977674188,131072 --service-pipe-token=16656584289041131280 --lang=en-US --framework-dir-path=/Applications/Dropbox.app/Contents/Frameworks/Tungsten.framework/Versions/A/Frameworks/Chromium Embedded Framework.framework --log-file=/Users/Fabio/Library/Logs/Dropbox_debug.log --log-severity=warning --product-version=Tungsten/73.3683.95 --suffix-user-agent=ShangriLa/101.4.434 --disable-extensions --uncaught-exception-stack-size=16 --tungsten-schemes=dbx-local --tungsten-crashpad=/Applications/Dropbox.app/Contents/Frameworks/DropboxCrashpad.framework/Versions/A/DropboxCrashpad --num-raster-threads=2 --enable-zero-copy --enable-gpu-memory-buffer-compositor-resources --enable-main-frame-before-activation --service-request-channel-token=16656584289041131280 --renderer-client-id=4 --seatbelt-client=91
1 1905 0.0 Fabio /Applications/Dropbox.app/Contents/XPCServices/DropboxActivityProvider.xpc/Contents/MacOS/DropboxActivityProvider
1 1911 0.0 Fabio /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 1912 0.0 Fabio /Applications/Dropbox.app/Contents/PlugIns/garcon.appex/Contents/MacOS/garcon
1 1917 0.0 Fabio /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 1918 0.0 Fabio /Applications/DAEMON Tools.app/Contents/PlugIns/ContextMenu.appex/Contents/MacOS/ContextMenu
1 1926 0.0 Fabio /System/Library/Frameworks/VideoToolbox.framework/Versions/A/XPCServices/VTDecoderXPCService.xpc/Contents/MacOS/VTDecoderXPCService
1 1936 0.0 Fabio /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelper.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
1 1950 0.0 Fabio /Library/Apple/System/Library/Frameworks/SafariServices.framework/Versions/A/XPCServices/com.apple.SafariServices.xpc/Contents/MacOS/com.apple.SafariServices
1 1951 0.0 Fabio /System/Library/PrivateFrameworks/SafariSafeBrowsing.framework/com.apple.Safari.SafeBrowsing.Service
1 1954 0.0 Fabio /System/Library/Frameworks/CoreSpotlight.framework/CoreSpotlightService
1 2013 0.0 Fabio /System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
1 2029 0.0 Fabio /usr/libexec/SidecarRelay
1 2042 0.0 Fabio /Applications/WhatsApp.app/Contents/MacOS/WhatsApp
1 2044 0.0 Fabio /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 2046 0.0 Fabio /Applications/WhatsApp.app/Contents/Frameworks/Electron Framework.framework/Resources/crashpad_handler --no-rate-limit --no-upload-gzip --database=/var/folders/l0/lv7x1q8j6t96lscr8gm40d5c0000gn/T/WhatsApp Crashes --metrics-dir=/var/folders/l0/lv7x1q8j6t96lscr8gm40d5c0000gn/T/WhatsApp Crashes --url=https://crashlogs.whatsapp.net/wa_clb_data?access_token=1063127757113399%7C745146ffa34413f9dbb5469f5370b7af --handshake-fd=33
2042 2047 0.0 Fabio /Applications/WhatsApp.app/Contents/Frameworks/WhatsApp Helper (GPU).app/Contents/MacOS/WhatsApp Helper (GPU) --type=gpu-process --field-trial-handle=1718379636,8085130158011324073,6110702770657037301,131072 --enable-features=WebComponentsV0Enabled --disable-features=SpareRendererForSitePerProcess --gpu-preferences=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 --shared-files
1 2052 0.0 Fabio /System/Library/Frameworks/VideoToolbox.framework/Versions/A/XPCServices/VTDecoderXPCService.xpc/Contents/MacOS/VTDecoderXPCService
2042 2053 0.0 Fabio /Applications/WhatsApp.app/Contents/Frameworks/WhatsApp Helper.app/Contents/MacOS/WhatsApp Helper --type=utility --field-trial-handle=1718379636,8085130158011324073,6110702770657037301,131072 --enable-features=WebComponentsV0Enabled --disable-features=SpareRendererForSitePerProcess --lang=it --service-sandbox-type=network --standard-schemes=whatsapp --secure-schemes=whatsapp --bypasscsp-schemes --cors-schemes --fetch-schemes --service-worker-schemes --shared-files
2042 2054 0.0 Fabio /Applications/WhatsApp.app/Contents/Frameworks/WhatsApp Helper (Renderer).app/Contents/MacOS/WhatsApp Helper (Renderer) --type=renderer --autoplay-policy=no-user-gesture-required --field-trial-handle=1718379636,8085130158011324073,6110702770657037301,131072 --enable-features=WebComponentsV0Enabled --disable-features=SpareRendererForSitePerProcess --lang=it --standard-schemes=whatsapp --secure-schemes=whatsapp --bypasscsp-schemes --cors-schemes --fetch-schemes --service-worker-schemes --app-path=/Applications/WhatsApp.app/Contents/Resources/app.asar --no-sandbox --no-zygote --preload=/Applications/WhatsApp.app/Contents/Resources/app.asar/preload.js --enable-remote-module --background-color=#fff --enable-websql --num-raster-threads=2 --enable-zero-copy --enable-gpu-memory-buffer-compositor-resources --enable-main-frame-before-activation --renderer-client-id=5 --no-v8-untrusted-code-mitigations --shared-files
1 2057 0.0 Fabio /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 2073 0.0 Fabio /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 2074 6.1 Fabio /Applications/Safari.app/Contents/MacOS/Safari
1 2075 0.0 Fabio /System/Library/PrivateFrameworks/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.History.xpc/Contents/MacOS/com.apple.Safari.History
1 2078 0.0 Fabio /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.Networking.xpc/Contents/MacOS/com.apple.WebKit.Networking
1 2079 0.0 Fabio /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 2081 0.0 root /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/XPCServices/com.apple.PerformanceAnalysis.animationperfd.xpc/Contents/MacOS/com.apple.PerformanceAnalysis.animationperfd
1 2082 0.0 Fabio /Library/Apple/System/Library/CoreServices/SafariSupport.bundle/Contents/MacOS/SafariLaunchAgent
1 2083 0.0 Fabio /Applications/Safari.app/Contents/XPCServices/com.apple.Safari.SandboxBroker.xpc/Contents/MacOS/com.apple.Safari.SandboxBroker
1 2084 0.0 Fabio /System/Library/Frameworks/ImageIO.framework/Versions/A/XPCServices/ImageIOXPCService.xpc/Contents/MacOS/ImageIOXPCService
1 2085 0.0 Fabio /Library/Apple/System/Library/CoreServices/SafariSupport.bundle/Contents/MacOS/webinspectord
1 2086 0.0 Fabio /Library/Apple/System/Library/CoreServices/SafariSupport.bundle/Contents/MacOS/SafariCloudHistoryPushAgent
1 2090 0.0 Fabio /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/XPCServices/com.apple.hiservices-xpcservice.xpc/Contents/MacOS/com.apple.hiservices-xpcservice
1 2091 0.0 Fabio /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 2097 0.0 Fabio /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
1 2098 0.0 Fabio /System/Library/PrivateFrameworks/PhotoAnalysis.framework/Versions/A/Support/photoanalysisd
1 2103 0.0 Fabio /usr/libexec/keyboardservicesd
1 2104 0.0 _fpsd /System/Library/PrivateFrameworks/CoreLSKD.framework/Versions/A/lskdd
1 2108 0.0 Fabio /System/Library/PrivateFrameworks/CoreRecents.framework/Versions/A/Support/recentsd
1 2131 0.0 Fabio /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
1 2133 0.0 Fabio /System/Library/PrivateFrameworks/SafariShared.framework/Versions/A/XPCServices/com.apple.Safari.SearchHelper.xpc/Contents/MacOS/com.apple.Safari.SearchHelper
1 2134 0.0 Fabio /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 2135 0.0 Fabio /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 2139 0.0 Fabio /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
1 2151 0.0 Fabio /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 2152 0.0 Fabio /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 2153 0.0 Fabio /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
1 2156 0.0 Fabio /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 2157 0.0 Fabio /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 2170 1.2 Fabio /System/Applications/Utilities/System Information.app/Contents/MacOS/System Information
1 2172 0.0 Fabio /System/Library/PrivateFrameworks/XprotectFramework.framework/Versions/A/XPCServices/XprotectService.xpc/Contents/MacOS/XprotectService
1 2176 0.0 Fabio /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 2179 0.0 Fabio /System/Library/PrivateFrameworks/DiskImages.framework/Resources/diskimages-helper -uuid A7E14C6F-456B-4557-B6CA-2E235C8C9892 -post-exec 4
1 2192 0.0 root /System/Library/PrivateFrameworks/DiskImages.framework/Resources/hdiejectd
1 2554 0.0 root /usr/sbin/ocspd
1 2612 0.0 Fabio /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
1 2613 18.8 Fabio /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
1 2614 0.0 Fabio /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 2615 0.0 Fabio /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
1 2636 0.0 Fabio /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 2643 3.3 Fabio /Applications/DetectX Swift.app/Contents/MacOS/DetectX Swift
1 2861 0.0 Fabio /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 2862 0.0 Fabio /System/Library/Frameworks/Metal.framework/Versions/A/XPCServices/MTLCompilerService.xpc/Contents/MacOS/MTLCompilerService
1 2912 0.0 _reportmemoryexception /usr/libexec/ReportMemoryException
1 2984 0.0 Fabio /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 2985 0.0 Fabio /System/Applications/Music.app/Contents/PlugIns/MusicCacheExtension.appex/Contents/MacOS/MusicCacheExtension
1 2986 0.0 Fabio /Applications/Safari.app/Contents/PlugIns/CacheDeleteExtension.appex/Contents/MacOS/CacheDeleteExtension
1 2987 0.0 Fabio /System/Applications/TV.app/Contents/PlugIns/TVCacheExtension.appex/Contents/MacOS/TVCacheExtension
1 2988 0.0 Fabio /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/A/Support/mdworker_shared -s mdworker -c MDSImporterWorker -m com.apple.mdworker.shared
1 3010 0.0 Fabio /System/Library/PrivateFrameworks/IMDMessageServices.framework/XPCServices/IMDMessageServicesAgent.xpc/Contents/MacOS/IMDMessageServicesAgent
«»EOF»«
