snow leopard e safari
dentosan
Salve a tutti .Ho installato Sl sul mio Mac Book Pro e quando ora lancio Safari questo si apre e si chiude immediatamente :Ecco il report che appare :Process: Safari [152]
Path: /Applications/Safari.app/Contents/MacOS/Safari
Identifier: com.apple.Safari
Version: 4.0.3 (6531.9)
Build Info: WebBrowser-65310900~1
Code Type: X86 (Native)
Parent Process: launchd [86]
Date/Time: 2009-09-15 17:00:45.030 +0200
OS Version: Mac OS X 10.6.1 (10B504)
Report Version: 6
Interval Since Last Report: 16641 sec
Crashes Since Last Report: 22
Per-App Interval Since Last Report: 285 sec
Per-App Crashes Since Last Report: 12
Anonymous UUID: C8E9F3EA-15E9-4F47-A1D7-B212D648403A
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Dyld Error Message:
Symbol not found: _GetSortedJVMVersions
Referenced from: /Library/Internet Plug-Ins/JavaPluginCocoa.bundle 1/Contents/MacOS/JavaPluginCocoa
Expected in: /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
Model: MacBookPro1,1, BootROM MBP11.0055.B08, 2 processors, Intel Core Duo, 2.16 GHz, 1 GB, SMC 1.2f10
Graphics: ATI Radeon X1600, ATY,RadeonX1600, PCIe, 256 MB
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x86), Atheros 5424: 2.0.19.4
Bluetooth: Version 2.2.1f7, 2 service, 1 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: FUJITSU MHV2100BH, 93,16 GB
Parallel ATA Device: HL-DT-ST DVDRW GWA4080M
USB Device: Built-in iSight, 0x05ac (Apple Inc.), 0x8501, 0xfd400000
USB Device: Apple Internal Keyboard / Trackpad, 0x05ac (Apple Inc.), 0x0218, 0x1d200000
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8205, 0x7d100000
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8240, 0x5d200000.
Lo stesso capita con alcuni messaggi di Mail .Qualcuno sa dirmi cosa devo fare .
akenzo
Photo Expert
Photo Expert
qui occorre un intervento di Fragrua :)
 iMac Retina 5k 27 3.5 24 gb  iMac 21 8 gb early 2020  MacBook Air 11 I5 1.4 256 gb  iPod Nano 4 gb grigio (con batteria fusa)  iPhone 13 pro nero 256 gb  iPad 1 32 gb 3G  iPad Pro M1 64 gb 4G  Apple Watch serie 7  Apple Airpods Pro
Purtroppo non sono la persona più indicata in queste situazioni.
Mi chiedevo, tu hai aggiornato a Snow Leopard, e OK.
Ma hai fatto anche gli aggiornamenti software dal pannello Aggiornamento Software?
Sembra un problema legato a Java.
dentosan
Ho provato con aggiornamento software ma mi dice che è aggiornato
RickS
Guarda in /Library/Internet Plug-Ins/
Mi sa` che probabilmente hai un plug in chiamato "JavaPluginCocoa.bundle 1" invece che JavaPluginCocoa.bundle o forse li hai tutti e due.
Questo e` MALE perche` per far funzionare le cose correttamente ce ne vuole uno solo chiamato javaPluginCocoa.bundle.
E` altresi` probabile che uno o tutti e due i file puntino ad un percorso errato.
Questo perche` quei due file sono due alias, in realta` non sono proprio alias ma link simbolici comunque chiamiamoli alias per semplicita`.
Cliccaci con il tasto destro e seleziona la voce "show original" per vedere dove puntano, dovrebbero puntare a:
/System/Library/Frameworks/JavaVM.framework/Versions/A/Resources/JavaPluginCocoa.bundle
Almeno uno dei due.
se almeno uno dei due punta a questo percorso, allora cancella l'altro e prova a vedere se il problema e` risolto.
se e` quello chiamato "JavaPluginCocoa.bundle 1" che ha il link giusto cancella l'altro e rinominalo come "JavaPluginCocoa.bundle"-
se invece e` "JavaPluginCocoa.bundle" ad avere il link giusto cancella l'altro e basta
Una volta fatto questo riavvia safari e prova a vedere se ora funziona.
Se ancora non va` allora devi ricostruire il link.
Leggiti anche questa discussione:
<http://www.macitynet.it/forum/showthrea ... luginCocoa>
Qui viene proposta un'altra soluzione
Oppure meglio prova questa soluzione per ricostruire il link simbolico.
Questa e` la soluzione postata da matbard sul forum di macity:
1) Apri la cartella /Library/Internet Plug-Ins.
2) Tasto destro su JavaPluginCocoa.bundle e "mostra originale". Mantieni aperta questa finestra!
3) Annotati l'elemento puntato come originale al punto 2.
4) cancella il collegamento simbolico dentro /Library/Internet Plug-Ins.
5) In una nuova finestra, apri il Terminale.
6) scrivi "sudo su" e metti la password.
7) nel Terminale, naviga fino a /Library/Internet Plug-Ins.
8) scrivi "ln -s" e successivamente trascina l'elemento indicato come originale al punto 2. Dai invio
9) Chiudi il Terminale.
dentosan
Ho provato tutte le vostre soluzioni ,anche quelle suggerite da Matbard ,che peraltro si è pure arrabbiato perchè non sono tanto smanicato con i computer ,ma a parte gli isterismi di qualcuno le soluzioni proposte non risultano essere efficaci .Ora il problema si pone anche con mail ,Itunes ,skype . Ricorro ad un centro di assistenza o qualcuno ha altre idee? Attendo fiducioso
Grazie :cry:
Se hai anche provato a riparare i permessi e no ha funzionato, forse è il caso di fare il backup dei dati (che è una regola fondamentale a prescindere dallo stato di salute del Mac) e procedere ad una reinstallazione di Snow Leopard.
dentosan
Ho già fatto il back up ,consilgieresti di re inizializzare HD da capo ho soltanto di re installare SL -Grazie
shun0321
prima di fare tutto cio, prova a scaricarti l'aggiornamento dal sito apple 10.6.1 e reinstallarlo, io avevo fino a ieri sera un problema simile ma l'ho risolto in questo modo.
Ha ragione shun0321, comunque intendevo reinstallare non inizializzare.
RickS
dentosan ha scritto:Ho già fatto il back up ,consilgieresti di re inizializzare HD da capo ho soltanto di re installare SL -Grazie
Ma hai eliminato il file "JavaPluginCocoa.bundle 1"
Perche nel tuo caso l'erroe e proprio li.
Riporto il log che hai postato:
Dyld Error Message:
guarda la riga: Referenced from: /Library/Internet Plug-Ins/JavaPluginCocoa.bundle 1/Contents/MacOS/JavaPluginCocoa
ti dice che il problem e nel plugin /Library/Internet Plug-Ins/JavaPluginCocoa.bundle 1
che si trova in /Library/Internet Plug-Ins/
Vediamo se riesco a guidarti passo passo:
apri il terminale e dai il seguente comando:
ls -lat /Library/"Internet Plug-Ins"/
e posta il risultato.
Matbard si e` scordato di dirti che le cartelle che contengono spazi nel nome devono essere messe tra " " quando si opera sul terminale. o in alternativa lo spazio deve essere sostituito da \ seguito da lo spazio, io personalmente preferisco le "" perche con l'altro sistema mi sono sbagliato ogni tanto.
E` per questo che non riuscivi ad eseguire i comandi che lui ti dava.
dentosan
questo è quello che compare sul terminale dopo il comando :
Last login: Wed Sep 16 22:38:24 on console
Macintosh:~ pieropieri$ Is-lat/Library/"Internet Plug-Ins"/
-bash: Is-lat/Library/Internet Plug-Ins/: No such file or directory
dentosan
EUREKA EUREKA .Come suggerito ho spostato nel cestino (prima lo avevo fatto solo sulla scrivania) JavacocoaBundle e JavaCocoa Bundle 1 (che è una cartella) e tutto ha ripreso a funzionare con vigore .La domanda che mi pongo e che vi ]pongo è la seguente : Cancello definitivamente i due file o no ?[/u]
RickS
dentosan ha scritto:EUREKA EUREKA .Come suggerito ho spostato nel cestino (prima lo avevo fatto solo sulla scrivania) JavacocoaBundle e JavaCocoa Bundle 1 (che è una cartella) e tutto ha ripreso a funzionare con vigore .La domanda che mi pongo e che vi ]pongo è la seguente : Cancello definitivamente i due file o no ?[/u]
A quanto ne so io uno dei due serve, per sapere quale e` quello giusto devi seguire la procedura:
Il comando che hai dato l'hai dato sbagliato ci vogliono gli spazi.
Il comando che devi dare e`
Mentre quello che hai dato tu e`:
Cioe` senza gli spazi, tra l'altro il comando comincia con ls (elle minuscolo esse minuscolo) e non Is (i maiuscolo s minuscolo) come hai scritto tu.
dentosan
Grazie ecco quello che compare con il comando suggeritomi :
Last login: Thu Sep 17 22:24:41 on console
Macintosh:~ pieropieri$ ls -lat /Library/"Internet Plug-Ins"/
total 64
-rw-rw-r--@ 1 pieropieri admin 12292 17 Set 00:16 .DS_Store
drwxrwxr-x 15 root admin 510 17 Set 00:11 .
drwxrwxr-x 3 root admin 102 11 Set 22:30 QuickTime Plugin.plugin
drwxrwxr-t+ 59 root admin 2006 11 Set 09:37 ..
-rw-rw-r-- 1 root admin 2394 23 Lug 05:23 nsIQTScriptablePlugin.xpt
drwxrwxr-x 3 root admin 102 19 Mag 08:02 Quartz Composer.webplugin
drwxrwxr-x 3 root admin 102 5 Mag 00:02 Flash Player.plugin
-rw-rw-r-- 1 root admin 856 6 Feb 2009 flashplayer.xpt
drwxrwxr-x 3 root admin 102 15 Gen 2009 Silverlight.plugin
drwxrwxr-x 3 pieropieri admin 102 21 Mag 2008 AdobePDFViewer.plugin
drwxrwxr-x 3 root admin 102 26 Mar 2008 DivXBrowserPlugin.plugin
-rwxrwxr-x 1 root admin 1607 26 Mar 2008 npdivx.xpt
drwxr-xr-x@ 3 pieropieri admin 102 16 Ott 2007 JoostPlugin.plugin
drwxrwxr-x 3 root admin 102 11 Feb 2006 iPhotoPhotocast.plugin
-rwxrwxr-x@ 1 root admin 4752 8 Feb 2006 NP-PPC-Dir-Shockwave
Che fare ?
