Software o Hardware?
Hammarby
Oggetto del messaggio: Re: Software o Hardware?
Messaggio Inviato: gio, 17 mag 2018 19:36
Un log di sistema no, eh?
...e spesso peggio.
Cervantes
Marpar
Messaggio Inviato: gio, 17 mag 2018 19:52
Hammarby ha scritto:Un log di sistema no, eh?
May 17 17:22:33 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
May 17 17:22:35 --- last message repeated 1 time ---
May 17 17:22:35 Marcos-Mac-mini nsurlstoraged[433]: DEPRECATED USE in libdispatch client: Setting timer interval to 0 requests a 1ns timer, did you mean FOREVER (a one-shot timer)?
May 17 17:22:37 Marcos-Mac-mini spindump_agent[408]: BUG in libdispatch client: dispatch_mig_server: mach_msg() failed (ipc/send) msg too small - 0x10000008
May 17 17:22:40 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
May 17 17:22:42 Marcos-Mac-mini gamed[421]: BUG in libdispatch client: kevent[mach_recv] monitored resource vanished before the source cancel handler was invoked
May 17 17:22:43 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
May 17 17:22:49 --- last message repeated 2 times ---
May 17 17:22:49 Marcos-Mac-mini Paragon Updater[473]: [Paragon NTFS for Mac] no installed version found
May 17 17:22:49 Marcos-Mac-mini Paragon Updater[473]: [Paragon ExtFS for Mac] no installed version found
May 17 17:22:49 Marcos-Mac-mini Paragon Updater[473]: update available? NO
May 17 17:22:54 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
May 17 17:23:24 --- last message repeated 2 times ---
May 17 17:23:24 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.quicklook[620]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.quicklook
May 17 17:23:38 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
May 17 17:24:18 --- last message repeated 1 time ---
May 17 17:25:48 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
May 17 17:26:17 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
May 17 17:26:49 Marcos-Mac-mini systemstats[78]: assertion failed: 17E202: systemstats + 914800 [D1E75C38-62CE-3D77-9ED3-5F6D38EF0676]: 0x40
May 17 17:27:44 Marcos-Mac-mini syslogd[65]: ASL Sender Statistics
May 17 17:29:50 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
May 17 17:30:25 --- last message repeated 1 time ---
May 17 17:30:48 Marcos-Mac-mini WhatsApp Helper[641]: objc[641]: Class NotificationCenterDelegate is implemented in both /Applications/WhatsApp.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework (0x110498ed8) and /Applications/WhatsApp.app/Contents/Resources/app.asar.unpacked/node_modules/node-mac-notifier/build/Release/Notification.node (0x115be09f8). One of the two will be used. Which one is undefined.
May 17 17:31:17 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
May 17 17:31:17 --- last message repeated 1 time ---
May 17 17:31:17 Marcos-Mac-mini parsecd[429]: libcoreservices: _dirhelper: 666: mkdir: path=/var/folders/p9/c4tx3sdn3698tfrs3htf54bw0000gn/0/com.apple.parsecd/ modes[0]=0755: Operation not permitted
May 17 17:31:18 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
May 17 17:31:28 --- last message repeated 4 times ---
May 17 17:31:28 Marcos-Mac-mini parsecd[429]: BUG in libdispatch client: dispatch_mig_server: mach_msg() failed (ipc/send) msg too small - 0x10000008
May 17 17:31:44 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.WebKit.Storage.9B6E3B81-7915-4278-980E-67B4FABDF3A8[648]): Service exited with abnormal code: 1
May 17 17:31:44 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.WebKit.Networking.EB16AB18-B4FB-4DB0-9E85-BAB340C0E30F[646]): Service exited with abnormal code: 1
May 17 17:31:52 Marcos-Mac-mini systemstats[78]: assertion failed: 17E202: systemstats + 914800 [D1E75C38-62CE-3D77-9ED3-5F6D38EF0676]: 0x40
May 17 17:31:53 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
May 17 18:42:15 Marcos-Mac-mini syslogd[65]: ASL Sender Statistics
May 17 18:42:16 Marcos-Mac-mini Dropbox[444]: [0517/184216:WARNING:dns_config_service_posix.cc(306)] Failed to read DnsConfig.
May 17 18:42:22 Marcos-Mac-mini netbiosd[657]: DEPRECATED USE in libdispatch client: Setting timer interval to 0 requests a 1ns timer, did you mean FOREVER (a one-shot timer)?
May 17 19:27:05 Marcos-Mac-mini syslogd[65]: ASL Sender Statistics
May 17 19:27:06 Marcos-Mac-mini Dropbox[444]: [0517/192706:WARNING:dns_config_service_posix.cc(306)] Failed to read DnsConfig.
May 17 19:27:06 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.preference.displays.MirrorDisplays): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
May 17 19:27:08 Marcos-Mac-mini timed[107]: settimeofday({0x5afdbb6c,0x996bc}) == 0
May 17 19:27:10 Marcos-Mac-mini timed[107]: settimeofday({0x5afdbb6e,0xdffaa}) == 0
May 17 19:27:12 Marcos-Mac-mini netbiosd[675]: DEPRECATED USE in libdispatch client: Setting timer interval to 0 requests a 1ns timer, did you mean FOREVER (a one-shot timer)?
May 17 19:27:16 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.preference.displays.MirrorDisplays): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
May 17 19:27:46 --- last message repeated 2 times ---
May 17 19:27:46 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.preference.displays.MirrorDisplays): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
May 17 19:27:50 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.WebKit.Storage.0F098542-1452-4D09-8025-BBED5829FB9C[584]): Service exited with abnormal code: 1
May 17 19:27:50 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.WebKit.Networking.686DADB0-F972-4356-8F17-1C1B07A1F3DD[496]): Service exited with abnormal code: 1
May 17 19:27:50 Marcos-Mac-mini systemstats[78]: assertion failed: 17E202: systemstats + 914800 [D1E75C38-62CE-3D77-9ED3-5F6D38EF0676]: 0x40
May 17 19:27:52 --- last message repeated 1 time ---
May 17 19:27:52 Marcos-Mac-mini garcon[436]: Garcon destroyed (0 alive).
May 17 19:27:52 Marcos-Mac-mini Finder[366]: BUG in libdispatch client: kevent[mach_recv] monitored resource vanished before the source cancel handler was invoked
May 17 19:27:52 Marcos-Mac-mini systemstats[78]: assertion failed: 17E202: systemstats + 914800 [D1E75C38-62CE-3D77-9ED3-5F6D38EF0676]: 0x40
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.domain.501.100007.Aqua): Caller not allowed to perform action: loginwindow.120, action = service removal, code = 150: Operation not permitted while System Integrity Protection is engaged, uid = 0, euid = 501, gid = 20, egid = 20, asid = 100007
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.talagent[363]): Service exited due to signal: Killed: 9 sent by loginwindow[120]
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.dropbox.activityprovider[529]): Service exited due to signal: Killed: 9 sent by loginwindow[120]
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.CoreLocationAgent[492]): Service exited due to signal: Killed: 9 sent by loginwindow[120]
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.wifi.WiFiAgent[502]): Service exited due to signal: Killed: 9 sent by loginwindow[120]
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.wacom.WacomTouchDriver.4332[485]): Service exited with abnormal code: 1
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.noticeboard.agent[479]): Service exited due to signal: Killed: 9 sent by loginwindow[120]
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.cloudphotosd[389]): Service exited due to signal: Killed: 9 sent by loginwindow[120]
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.storeuid[535]): Service exited due to signal: Killed: 9 sent by loginwindow[120]
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.AirPlayUIAgent[476]): Service exited due to signal: Killed: 9 sent by loginwindow[120]
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (2BUA8C4S2C.com.agilebits.onepassword-osx-helper[468]): Service exited due to signal: Killed: 9 sent by loginwindow[120]
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.SystemUIServer.agent[364]): Service exited due to signal: Killed: 9 sent by loginwindow[120]
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.Siri.agent[470]): Service exited with abnormal code: 1
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.imklaunchagent[438]): Service exited due to signal: Terminated: 15 sent by loginwindow[120]
May 17 19:27:52 Marcos-Mac-mini filecoordinationd[407]: BUG in libdispatch client: kevent[mach_recv] monitored resource vanished before the source cancel handler was invoked
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.universalaccessd[360]): Service exited due to signal: Killed: 9 sent by loginwindow[120]
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.coreservices.uiagent[490]): Service exited due to signal: Killed: 9 sent by loginwindow[120]
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.wacom.wacomtablet[465]): Service exited with abnormal code: 1
May 17 19:27:53 Marcos-Mac-mini systemstats[78]: assertion failed: 17E202: systemstats + 914800 [D1E75C38-62CE-3D77-9ED3-5F6D38EF0676]: 0x40
May 17 19:27:53 --- last message repeated 5 times ---
May 17 19:27:53 Marcos-Mac-mini sessionlogoutd[695]: DEAD_PROCESS: 120 console
May 17 19:27:53 Marcos-Mac-mini shutdown[696]: SHUTDOWN_TIME: 1526578073 361882
Mac mini 6,1 - Intel Core i5 2,5 GHz (2cores)/8 GB DDR3 1600MHz/2x525GB SSD Crucial MX300 (RAID 0) - HD Graphics 4000 - Mac OS X 10.14.1
Hammarby
Messaggio Inviato: gio, 17 mag 2018 21:53
Somiglia a questo
https://www.tonymacx86.com/threads/comp ... te.240690/" onclick="window.open(this.href);return false;
e pare che sia stato introdotto con l'ultimo aggiornamento di sistema.
Questo è il bug
Mi sa che devi aspettare che lo corregga Apple, ad ogni modo vedo che hai le librerie di Whatsapp duplicate
e che ci sono molti messaggi di worning e taluni di errore come per esempio
Posso consigliarti di reinstallare il sistema operativo da capo, o almeno con un full update?
...e spesso peggio.
Cervantes
Marpar
Messaggio Inviato: ven, 18 mag 2018 10:42
Grazie Hammarby.
Come dovrei procedere per eliminare una delle due librerie di Whatsapp?
Hammarby
Messaggio Inviato: ven, 18 mag 2018 12:39
Oer Whatsapp io farei in questo modo:
1. Disinstalla Whatsapp
2. Cancella a mano la directory (se ancora esiste dopo la disinstallazione)
3. Reinstalla Whatsapp
...e spesso peggio.
Cervantes
PeT
Oggetto del messaggio: Software o Hardware?
Messaggio Inviato: sab, 19 mag 2018 10:42
ho il Mac al genius bar e sono venuto a sapere che c’è un programma di sostituzione gratuita delle schede video fino al 30 di questo mese.
Penso cercherò di vendere il Mac Pro una volta aggiustato (a prescindere che si tratti di un guasto alla GPU o altro) Se qualcuno è interessato mi contatti in PM.
Mac Pro 6,1 macOS 10.14.1
iPhone 7 Plus iOS 12.1
PeT
Messaggio Inviato: gio, 24 mag 2018 12:51
Qualcuno ha idea di quanto ci può mettere un laboratorio di assistenza Apple Store a capire che problemi ha il mio Mac ? non so.. è da una settimana che ce l’hanno e continuano a dirmi che devo portare pazienza.. che i tecnici lo stanno mettendo sotto stress per testarlo e capire dov’è il difetto..
albertocchio
Messaggio Inviato: gio, 24 mag 2018 13:06
è come chiedere: ma il 12 luglio del 2032 pioverà o posso andare tranquillamente al mare?
type expert stocasso
PeT
Messaggio Inviato: gio, 24 mag 2018 13:24
si può essere. credevo che per mettere sotto test un mac non ci volesse l’eternità. nella mail che ho ricevuto giovedì scorso indicavano “Turnaround time stimato: Ti chiameremo entro 48 ore” e il “Genius” che mi ha ritirato il computer ha detto ci vorranno 2/3 gg max. okok
PeT
Messaggio Inviato: gio, 24 mag 2018 13:34
so che non gliene può fregare una mazza a nessuno del forum (alla Apple ancora meno, forse) ma a mio avviso stanno perdendo punti a iosa oltre ad un cliente che da 14 anni spende soldi nei loro negozi. W
albertocchio
Messaggio Inviato: gio, 24 mag 2018 13:39
ecco: non gli frega niente a nessuno ormai… in US: take the money and run.
se questo 3D si intitolava Fig*a o Tett*e? sai che pullulare?
PeT
Messaggio Inviato: gio, 24 mag 2018 13:53
bravo albertocchio.. si vede che tira di più anche su un forum che tratta quasi esclusivamente argomenti relativi al Mac una stupidata del genere
Messaggio Inviato: gio, 24 mag 2018 14:00
Che sfiga, Alb! :shock:
Hai subito beccato l'unico al mondo a cui frega di più il Mac. :roll:
PeT, se mi procuri un po' di quella roba li, ti presto il mio (Mac).
Se ti serve, posso anche aggiornarlo ad High Sierra... :twisted: :twisted:
PeT
Messaggio Inviato: gio, 24 mag 2018 14:09
No grazie mi arrangio.. Ciao
kext
Messaggio Inviato: gio, 24 mag 2018 14:11
PeT ha scritto:si può essere. credevo che per mettere sotto test un mac non ci volesse l’eternità. nella mail che ho ricevuto giovedì scorso indicavano “Turnaround time stimato: Ti chiameremo entro 48 ore” e il “Genius” che mi ha ritirato il computer ha detto ci vorranno 2/3 gg max. okok
Per controllare se ho applicato bene la pasta termica, metto sotto stress la CPU per più di dodici ore (se sono buono) o più di 24 ore quando ho seri dubbi... Non sulla pasta termica, ma sulla CPU..
:!: Ultimo articolo: Sito web in Alpha test :!:
ImmagineImmagine
