Gravit Designer 3.5.8
Aggiornamento 137MB
dmg 185MB
305.4MB su disco
OS X 10.9.0 Mavericks+
Anche per iPad e online
https://itunes.apple.com/it/app/gravit- ... 4923?mt=12
https://designer.io - app online -
https://gravit.io
Un'applicazione per il disegno vettoriale.
Multipiattaforma, anche online, con cloud proprio.
In miglioramento (resta ancora una beta)
Di proprietà Corel andrà, secondo loro, a coprire il mercato Mac in cui manca Corel Draw.
Ancora gratuita.
Massiccio aggiornamento di versione.
Novità in 3.5.8:
With this release we are focusing on internationalization and some long overdue additions and optimizations in this regard. The first being the support of right-to-left (and top-to-bottom) languages, which finally enables to use scripts such as Arabic, Hebrew and Persian in Gravit Designer. In addition, we also included many other non-Latin characters sets, including Japanese, Chinese, Bengali or Georgian, to name a few.
But we didn’t stop there: The Cloud dialog received a massive overhaul with some new functionality and we have some new controls for text layers in the Inspector, including some advanced options like subscript, fractions, and paragraph spacing.
There’s not enough space here for all the improvements and bugfixes in this release, so please have a look at the related article on our blog at medium.com/gravitdesigner.
More improvements (selection):
- New "script” selection in the Inspector to choose between the different character sets contained in a font. Try _Noto Sans_ for example.
- Pressing Shift + Enter now creates a soft break, that’s not affected by paragraph spacing.
- Ability to set the zoom stop with a double-click on the zoom icon in the toolbar.
- Updated Web Fonts to include all the shiny new Google Fonts.
- Continued improving SVG support and the performance of Gravit Designer.
And a bunch of bugfixes. All changes can be found at designer.io/changelog
Telegram Swift 4.9.5
https://rink.hockeyapp.net/apps/6ed2ac3 ... ffcb74e81f
Versione nativa di Telegram Messenger per MacOS.
In questa versione si alternano alfa, beta e stabili, senza problemi funzionali.
È la versione più aggiornata basata sul linguaggio Swift 3.
OS X 10.11 El Capitan+
28.5MB aggiornamento da app
dmg 27.13MB (!?)
72.6MB su disco
Esistono separate edizioni per 10.6 e 10.7 nelle versioni classiche.
Le altre versioni per Mac:
Telegram Desktop
https://desktop.telegram.org
Telegram Messenger LLP su App Store
https://itunes.apple.com/us/app/telegra ... d946399090
Sorgenti
https://github.com/overtake/TelegramSwift
Estrema sicurezza e inviolabilità dei contenuti condivisi fra gli utenti.
Le chat cifrate appaiono essere blindate.
Per questo Telegram è stato proibito in qualche paese.
In Russia, suo paese d'origine, in Turchia.
Perché non rilascia le chiavi d'accesso anche a richiesta di polizia e magistratura.
Attualmente è il canale di diffusione di organizzazioni terroristiche e criminali.
Ma anche di streaming, coupon, occasioni, mercatini settoriali e di varie merci, download illegali ecc.
E una famosa chat di iMattacchioni.
Novità in 4.9.5:
Patterns and colors in wallpapers
Pingus
Vista la notifica... per un attimo ho temuto il peggio...
Seashore - 2.3.4
Seashore è un editor di immagini free e open source, basato su GIMP e sin dagli inizi nativo per OS X, dispone di tutte le funzioni basilari e anche di più ed è in grado di soddisfare le esigenze di utenti che non hanno necessità di usare programmi professionali.
What's New in Seashore:
Fix major bug where layers were not displayed when selection in use - all users running 2.3.0+ should upgrade !. Sorry !!! Also, I added a 'crop layer' to crop tool, so at least you get something new too...
Seashore is now available on the App Store !!! >>> https://itunes.apple.com/it/app/id1448648921
The current source-code can be found on github
>>> https://sourceforge.net/projects/seashore/
Pingù ha scritto:
sab, 02 feb 2019 13:27
Che ci vuoi fare, è la vita ....
Kernel Panic ha scritto:
dom, 03 feb 2019 07:22
Hex Fiend 2.11
OS X 10.8 Mountain Lion +
zip 2.1MB
5.6MB su disco
Su GitHub
https://github.com/ridiculousfish/HexFiend
Download e versioni precedenti
https://github.com/ridiculousfish/HexFiend/releases
Editor esadecimale open source veloce e intelligente per Mac OS X.
Caratteristiche
Inserisce, cancella e riorganizza le stringhe, non limitandosi a sovrascriverle.
Lavora con file di grandi dimensioni. Hex Fiend è stato testato su file fino a 118GB.
Non mantiene i file nella memoria, lavora anche con Mac molto vecchi e ram scarsa.
Molto veloce, aprire un file enorme, lo scorre, copia e incolla in un istante.
ha una ricerca rapida integrata.
Può mostrare le differenze tra i file binari, tenendo conto delle inserzioni o delezioni.
Non sovrascrive i dati non interessati e non occupa memoria di swap.
Interpreta i dati come numero intero o in virgola mobile, firmato o non firmato endian, grande o piccola.
È davvero facile da integrare come interprete di dati esadecimali in altre applicazioni in altre app.
La licenza è libera BSD.
È integrata in FileSpy come framework.
Su brew per installare:
brew cask install hex-fiend
Novità in 2.11:
Hex Fiend is notarized for added security on 10.14+
Binary template improvements:
Add section selection
Add entry command for arbitrary key/value fields
Add eof as a special length parameter to go to the end of the file
Add optional -hex argument for unsigned integers to display as hexadecimal
Add str command that takes an encoding identifier
Add sectionvalue command that sets the value of the current section
Sections now auto-expand
Add preference for controlling behavior on single and double click of template entries
Set working directory to templates folder so "source" command can use relative paths
Performing a copy with a selected entry copies its value to the clipboard
Fix incorrect anchor usage in some commands
Fix incorrect error handling with zlib_uncompress
Fix window width adjustment when showing/hiding templates
Prefix hexadecimal values with 0x to match Data Inspector
Improve error messages for read failures
Improve documentation
Add anchored scrolling. When scrolling horizontally, the document will be anchored by the selection offset (if visible) or first visible byte
Add column view (off by default)
Add custom byte grouping
Fix data inspector text alignment (thanks rpendleton)
Fix plain/ascii text alignment with line numbers
Fix crash when Color Bytes is enabled with a multi-byte text encoding
Fix incorrect parsing of large ULEB128/SLEB128 values
Move fonts in Font menu to bottom to improve handling for a large number of fonts
lun, 11 feb 2019 20:47
Monolingual
Hahaha...
Spiritoso!
Monolingual in effetti ha ancora un senso. ;-)
mar, 12 feb 2019 07:48
Forse...
Ma non mi viene in mente.
Aspè... ce l'ho qui... Sulla punta della lingua...
Tor Browser Bundle 8.0.6
Dmg 66MB dmg - localizzato in lingua italiana
Aggiornamento 66MB
151.5MB su disco
È un Tor Bundle, già pronto su una versione di Firefox preparata per l’uso.
Il popolare software Tor assicura l’anonimato delle comunicazioni attraverso una rete distribuita di relay, gestiti da volontari in tutto il mondo.
Impedisce a chiunque di monitorare la connessione Internet e di conoscere quali siti vengono visitati,.
Impedisce ai siti visitati da rilevare la locazione e qualsiasi altro dato del visitatore.
Consente di accedere a siti che sono bloccati.
Tor Browser Bundle è multipiattaforma, non necessita di altro software ed è pronto per essere utilizzato.
Può essere installato ed usato anche su una chiavetta usb, quindi portatile.
https://www.torproject.org/projects/torbrowser.html.en
https://blog.torproject.org/new-release-tor-browser-806
Aggiornamenti in sottofondo tramite il canale Aurora, come in Firefox Quantum Developer
Cliccando il pulsante di identità del sito (posto a sinistra dell'URL) si vedrà il circuito.
Novità in 8.0.6:
* Update Firefox to 60.5.1esr
* Update HTTPS Everywhere to 2019.1.31
Risoluzione di vari bug
Shazam 2.2
Su App Store
OS X El Capita 10.11+
(attenzione, chi ha Yosemite non deve aggiornare)
Aggiornamento 7MB
9.2MB dmg
26.3MB su disco
Scoprire, acquistare e condividere le canzoni e i programmi TV con playlist personalizzata.
Opera in sottofondo riconoscendo il brano musicale attivo e ascoltato sul sistema (quasi sempre)
https://www.shazam.com/it/apps
https://itunes.apple.com/us/app/shazam/ ... l=fr&mt=12
Novità in 2.2:
Thanks for Shazaming! We’re always working hard to make the app faster and better than ever.
Update to the most recent version to enjoy the latest and greatest Shazam
DetectX Swift 1.084
dmg 9.9MB
Aggiornamento dall'applicazione 10.3MB
20.9MB su disco
https://sqwarq.com/detectx/
Versioni precedenti sul sito:
DetectX OS X 10.7
DetectXSL OS X 10.6.8
DetectX Swift è uno scanner di adware (potenzialmente anche malware).
Ma è anche uno strumento di risoluzione dei problemi Mac e altro.
Esamina il contenuto di ogni cartella critica, poco note agli utenti ordinari.
E quindi anche alle applicazioni in avvio, demoni e agenti, plugin ecc.
Compresi i crontab dell'utente, /etc, /$Root, supporti applicazioni, ~/Shared e le preferenze gestite.
Gli HelpersTools privilegiati, gli script aggiunti e gli aggiornamenti iscritti nella libreria del disco.
DetectX Swift utilizza un sistema di classificazione progressivo.
Quando un problema rientra in più di una categoria, la ricerca lo etichetta in base alla categoria più alta.
La scala è crescente:
1. Software potenzialmente destabilizzante (PDS)
2. Software potenzialmente indesiderato (PUS)
3. Adware (ADW)
4. Malware (MAL)
Lo sviluppatore è certificato e questo software è riconosciuto dal Gatekeeper Apple.
Non è, ovviamente, in App Store perché non è sanboxato.
Altrimenti, non frugando nelle cartelle "vietate" da Apple, non potrebbe funzionare.
A mio parere non presenta il minimo rischio d'uso.
È shareware di tipo classico.
Cioè non è gratuito, ma può essere usato con funzioni complete senza limiti da utenti saltuari.
È commerciale per chi lo utilizza correntemente o per uso professionale.
Sul sito si può registrare per l'uso corrente o pro
https://sites.fastspring.com/sqwarq/pro ... xswifthome
Novità in Swift 1.084:
adware search heuristics updated
Torna a “Aggiornamenti”
