high sierra 10.13.4 molto lento
auragraph
Salve a tutti ho un iMac "Late 2012" con processore da 2,7 Ghz i5 e 8 gb di ram lo uso tanto per via del lavoro, da quando ho aggiornato ad high sierra sono aumentati i rallentamenti in modo snervante.
Vi giro il reporto di EtreCheck. grazie per l'aiuto
EtreCheck version: 4.3.2 (4D034)
Report generated: 2018-06-14 19:36:12
Runtime: 5:14
Performance: Below Average
Problem: Computer is too slow
Major Issues:
Anything that appears on this list needs immediate attention.
No Time Machine backup - Time Machine backup not found.
Minor Issues:
These issues do not need immediate attention but they may indicate future problems.
Apps crashing - There have been numerous app crashes.
Apps with heavy CPU usage - There have been numerous cases of apps with heavy CPU usage.
Unsigned files - There is unsigned software installed. They appear to be legitimate but should be reviewed.
System modifications - There are a large number of system modifications running in the background.
Low performance - EtreCheck report took over 5 minutes to run. This is unusual.
Hardware Information:
iMac (21.5-inch, Late 2012)
iMac Model: iMac13,1
1 2,7 GHz Intel Core i5 (i5-3330S) CPU: 4-core
8 GB RAM - Upgradeable
BANK 0/DIMM0 - 4 GB DDR3 1600 ok
BANK 1/DIMM0 - 4 GB DDR3 1600 ok
Video Information:
NVIDIA GeForce GT 640M - VRAM: 512 MB
iMac 1920 x 1080
Drives:
disk0 - APPLE HDD ST1000LM024 1.00 TB (Mechanical)
Internal SATA 3 Gigabit Serial ATA
disk0s1 - EFI (MS-DOS FAT32) [EFI] 210 MB
disk0s2 - Macintosh HD (Journaled HFS+) 999.35 GB
disk0s3 - Recovery HD [Recovery] 650 MB
Mounted Volumes:
disk0s2 - Macintosh HD 999.35 GB (697.86 GB free)
Journaled HFS+
Mount point: /
Network:
Interface usbmodem1a122: BCM21553-Thunderbird
Interface en0: Ethernet
One IPv4 address
Proxy Auto Discovery
Interface en1: Wi-Fi
802.11 a/b/g/n
Interface en4: Bluetooth PAN
Interface bridge0: Thunderbolt Bridge
iCloud Quota: 1.79 GB available
System Software:
macOS High Sierra 10.13.4 (17E202)
Time since boot: About 11 hours
System Load: 1.57 (1 min ago) 1.22 (5 min ago) 1.17 (15 min ago)
Configuration Files:
File /etc/sysctl.conf exists but not expected
Security:
System Status
Gatekeeper Mac App Store and identified developers
System Integrity Protection Enabled
Unsigned Files:
Launchd: /Library/LaunchDaemons/com.efi.lmgr.plist
Executable: /Applications/EFI/EFILM/lmgrd_wrapper.sh /Applications/EFI/EFILM
Details: Exact match found in the whitelist - probably OK
Launchd: /Library/LaunchDaemons/fr.caldera.install_launcher.plist
Executable: /opt/caldera/bin/install_launcher /opt/caldera/lib/calserver.cfg
Launchd: /Library/LaunchAgents/com.efi.cws.analytics.plist
Executable: /Library/Application Support/efiLINQ/efiLINQ -n=CWSServer
Launchd: /Library/LaunchDaemons/com.efi.fieryd.plist
Executable: /usr/local/fieryd
Launchd: /Library/LaunchDaemons/com.oracle.java.Helper-Tool.plist
Executable: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Resources/Helper-Tool
Launchd: /Library/LaunchDaemons/com.adobe.SwitchBoard.plist
Executable: /Library/Application Support/Adobe/SwitchBoard/SwitchBoard.app/Contents/MacOS/launch.switchboard
Launchd: /Library/LaunchDaemons/com.microsoft.office.licensing.helper.plist
Executable: /Library/PrivilegedHelperTools/com.microsoft.office.licensing.helper
Launchd: /Library/LaunchAgents/com.efi.analytic.wxwidgets.plist
Executable: /Library/Application Support/efiLINQ/efiLINQ -n=wxWidgets
Launchd: /Library/LaunchDaemons/fr.caldera.verifications.plist
Executable: /opt/caldera/bin/osx_verifications
Launchd: /Library/LaunchDaemons/fr.caldera.bridge.plist
Executable: /opt/caldera/bin/calbridge
Launchd: /Library/LaunchDaemons/fr.caldera.calserver.plist
Executable: /opt/caldera/bin/calserver /opt/caldera/lib/calserver.cfg -nobackground
Launchd: /Library/LaunchDaemons/fr.caldera.keyserver.plist
Executable: /opt/caldera/bin/keyserver /opt/caldera/lib/Caldera.licenses -nobackground
Launchd: ~/Library/LaunchAgents/com.adobe.ARM.***.plist
Executable: /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/MacOS/Updater/Adobe Acrobat Updater Helper.app/Contents/MacOS/Adobe Acrobat Updater Helper
Launchd: /Library/LaunchAgents/com.oracle.java.Java-Updater.plist
Executable: /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Resources/Java Updater.app/Contents/MacOS/Java Updater -bgcheck
Kernel Extensions:
/Library/Application Support/HASP/kexts
[Not Loaded] aksfridge_signed.kext (SFNT Germany GmbH, 1.0.16332)
Startup Items:
FlowplusMounts Path: /Library/StartupItems/FlowplusMounts
MySQLCOM Path: /Library/StartupItems/MySQLCOM
System Launch Agents:
[Not Loaded] 9 Apple tasks
[Loaded] 160 Apple tasks
[Running] 121 Apple tasks
[Other] 3 Apple tasks
System Launch Daemons:
[Not Loaded] 33 Apple tasks
[Loaded] 177 Apple tasks
[Running] 123 Apple tasks
Launch Agents:
[Running] com.efi.fpdu.plist (? 8d653d1f - installed 2017-07-07)
[Loaded] com.xrite.device.softwareupdate.plist (? 2f2d6b43 - installed 2015-08-19)
[Loaded] com.efi.cws.analytics.plist (? 860f03c2 - installed 2018-06-14)
[Other] com.efi.analytic.wxwidgets.plist (? d2d90fee - installed 2018-06-14)
[Not Loaded] com.teamviewer.teamviewer_desktop.plist (? 5984e04 - installed 2016-09-19)
[Not Loaded] com.teamviewer.teamviewer.plist (? bb938493 - installed 2016-09-19)
[Not Loaded] com.adobe.AAM.Updater-1.0.plist (? ffb65062 - installed 2014-05-14)
[Loaded] org.macosforge.xquartz.startx.plist (Apple Inc. - XQuartz - installed 2016-05-05)
[Loaded] com.oracle.java.Java-Updater.plist (? 9e1f3bbe - installed 2016-12-13)
[Not Loaded] com.efi.FolderMapDockAgent.plist (EFI Inc - installed 2018-05-08)
[Loaded] com.efi.FSMAgent.plist (EFI Inc - installed 2018-04-23)
Launch Daemons:
[Running] com.efi.FRSMailboxSyncServiceDaemon.plist (EFI Inc - installed 2018-05-08)
[Not Loaded] com.teamviewer.teamviewer_service.plist (? e6c7921e - installed 2016-09-19)
[Not Loaded] fr.caldera.verifications.plist (? e8c97501 - installed 2017-09-22)
[Loaded] com.teamviewer.Helper.plist (? 7f4bf3e7 - installed 2016-09-19)
[Loaded] com.malwarebytes.HelperTool.plist (Malwarebytes Corporation - installed 2018-01-25)
[Other] com.efi.es1000service.plist (Electronics for Imaging - installed 2018-03-19)
[Loaded] com.adobe.SwitchBoard.plist (? 856489a3 - installed 2013-03-29)
[Loaded] com.adobe.fpsaud.plist (Adobe Systems, Inc. - installed 2018-06-02)
[Loaded] com.microsoft.office.licensing.helper.plist (? 6d8cb30e - installed 2010-08-25)
[Not Loaded] com.efi.packageversion.plist (? 0 - installed )
[Loaded] com.oracle.java.Helper-Tool.plist (? e3fefdd2 - installed 2016-12-13)
[Loaded] org.macosforge.xquartz.privileged_startx.plist (Apple Inc. - XQuartz - installed 2016-05-05)
[Running] com.efi.ofasq.plist (EFI Inc - installed 2018-06-14)
[Running] fr.caldera.install_launcher.plist (? 1e934720 - installed 2018-02-05)
[Running] fr.caldera.calserver.plist (? 94ddddf3 - installed 2018-06-05)
[Running] com.aladdin.aksusbd.plist (SFNT Germany GmbH - installed 2017-07-03)
[Running] com.xrite.device.xrdd.plist (? 28f4ae75 - installed 2015-08-19)
[Running] com.efi.fieryd.plist (? f793c348 - installed 2017-07-07)
[Running] fr.caldera.bridge.plist (? 4d25651a - installed 2018-06-05)
[Running] com.efi.lmgr.plist (? 8d2637a0 - installed 2018-06-14)
[Running] fr.caldera.keyserver.plist (? 3326efee - installed 2018-02-05)
User Launch Agents:
[Loaded] com.dropbox.DropboxMacUpdate.agent.plist (Dropbox, Inc. - installed 2018-04-13)
[Loaded] com.adobe.ARM.***.plist (? 0 - installed 2014-05-08)
[Loaded] com.adobe.AAM.Updater-1.0.plist (? 0 - installed 2013-03-29)
User Login Items:
iTunesHelper Applicazione (Apple - installed 2018-05-30)
(/Applications/iTunes.app/Contents/MacOS/iTunesHelper.app)
PopChar Applicazione (? - installed 2013-06-21)
(/Applications/PopChar.app)
imac Cartella (?)
(/Users/***)
Dropbox Applicazione (Dropbox, Inc. - installed 2018-06-07)
(/Applications/Dropbox.app)
Internet Plug-ins:
AdobeExManDetect: AdobeExManDetect 1.1.0.0 (installed 2013-04-03)
FlashPlayer-10.6: 30.0.0.113 (installed 2018-06-07)
QuickTime Plugin: 7.7.3 (installed 2018-04-10)
Flash Player: 30.0.0.113 (installed 2018-06-07)
AdobeAAMDetect: AdobeAAMDetect 1.0.0.0 (installed 2012-08-09)
SharePointBrowserPlugin: 14.1.0 (installed 2013-06-20)
JavaAppletPlugin: Java 8 Update 121 build 13 (installed 2017-02-22)
3rd Party Preference Panes:
Flash Player (installed 2018-06-02)
Java (installed 2017-02-22)
MySQL (installed 2018-02-20)
Time Machine:
Time Machine Not Configured!
Top Processes by CPU:
Process (count) Source % of CPU Location
sandboxd Apple 12
WindowServer Apple 7
Mail Apple 5
kernel_task Apple 3
mds_stores Apple 3
Top Processes by Memory:
Process (count) Source RAM usage Location
kernel_task Apple 879 MB
com.apple.WebKit.WebContent (3) Apple 466 MB
mdworker (10) Apple 194 MB
Finder Apple 191 MB
Safari Apple 115 MB
Top Processes by Network Use:
Process Source Input Output Location
Dropbox Dropbox, Inc. 965 KB 681 KB
mDNSResponder Apple 1 MB 239 KB
netbiosd Apple 174 KB 24 KB
com.apple.WebKit.Networking Apple 60 KB 1 KB
apsd Apple 29 KB 24 KB
Top Processes by Energy Use:
Process (count) Source Energy (0-100) Location
WindowServer Apple 4
com.apple.WebKit.WebContent (3) Apple 3
Safari Apple 1
sandboxd Apple 1
cloudd Apple 1
Virtual Memory Information:
Available RAM 3.11 GB
Free RAM 18 MB
Used RAM 4.89 GB
Cached files 3.09 GB
Swap Used 26 MB
Software Installs (past 30 days):
Name Version Install Date
The Unarchiver 3.11.6 2018-05-28
iTunes 12.7.5 2018-05-30
Gatekeeper Configuration Data 140 2018-06-01
Adobe Flash Player 30.0.0.113 2018-06-07
Fiery Remote Scan 6.6.0.04 2018-06-14
ES1000 installer 5.0.0.41 2018-06-14
FieryMeasure 5.0.00.47 2018-06-14
Fiery XF 7.0.0.33 2018-06-14
hasp_driver 7.60.703.1 2018-06-14
FieryConfigure 4.0.0.10 2018-06-14
Image Enhance Visual Editor 2.2.0.00a 2018-06-14
Fiery Hot Folders 3.11.0.12 2018-06-14
HF3_filters 3.11.0.09 2018-06-14
versioning_installer 1.2.0.018 2018-06-14
Calibrator3 3.0.0.41 2018-06-14
ClientAPI 1.0.0.45a 2018-06-14
CustomViewer 1.0.0.05a 2018-06-14
EFILM 11.14.1.1.0 2018-06-14
EFI License Activation 1.5.1.2 2018-06-14
CWS Wrapper 6.2.0.14 2018-06-14
DeviceManager 6.2.00.28 2018-06-14
Harmony installer 3.5.049a 2018-06-14
Diagnostics Information (past 7 days):
2018-06-14 19:30:00 Adobe Photoshop CS6.app Crash
/Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app
abort() called
2018-06-14 19:29:34 Dropbox.app Crash
2018-06-14 19:25:10 fierybidi Crash (14 times)
/Library/Printers/Xerox/PDEs/EF526740/fierybidi
2018-06-14 17:14:56 WindowServer CPU
/System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/Resources/WindowServer
2018-06-14 08:33:51 mkfontscale Crash (3 times)
/opt/X11/*/mkfontscale
2018-06-11 12:59:01 Adobe Illustrator.app CPU (6 times)
/Applications/Adobe Illustrator CS6/Adobe Illustrator.app
2018-06-11 10:05:59 Adobe Acrobat Pro.app Crash
Performing @selector(doClick:) from sender UIT_NSTableView 0x125c65f0
End of report
utente_autoeliminato
Oggetto del messaggio: Re: high sierra 10.13.4 molto lento
Il problema principale non è software ma hardware.
Hai un hard disk meccanico, non è adatto a High Sierra, il Mac sarebbe lento anche se avesse solo 1 programma installato.
In avvio hai un sacco di elementi, molti legati a Fiery di EFI
Qualche cosa si potrebbe cancellare per ottimizzare la macchina ma il beneficio è ben poco, non percettibile secondo me.
Devi installare un bel SSD al posto dell' hard disk ... questa è la soluzione per avere un mac veloce.
auragraph
Ti ringrazio molto, mi attiverò per seguire il tuo consiglio. Ma secondo te posso sostituirlo da me l'SSD oppure devo mandarlo in assistenza? Grazie
Visitano il forum: Google [Bot], SemrushBot [Bot] e 21 ospiti
