GrazieHammarby ha scritto:Un log di sistema no, eh?
May 17 17:22:33 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
May 17 17:22:35 --- last message repeated 1 time ---
May 17 17:22:35 Marcos-Mac-mini nsurlstoraged[433]: DEPRECATED USE in libdispatch client: Setting timer interval to 0 requests a 1ns timer, did you mean FOREVER (a one-shot timer)?
May 17 17:22:37 Marcos-Mac-mini spindump_agent[408]: BUG in libdispatch client: dispatch_mig_server: mach_msg() failed (ipc/send) msg too small - 0x10000008
May 17 17:22:40 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
May 17 17:22:42 Marcos-Mac-mini gamed[421]: BUG in libdispatch client: kevent[mach_recv] monitored resource vanished before the source cancel handler was invoked
May 17 17:22:43 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
May 17 17:22:49 --- last message repeated 2 times ---
May 17 17:22:49 Marcos-Mac-mini Paragon Updater[473]: [Paragon NTFS for Mac] no installed version found
May 17 17:22:49 Marcos-Mac-mini Paragon Updater[473]: [Paragon ExtFS for Mac] no installed version found
May 17 17:22:49 Marcos-Mac-mini Paragon Updater[473]: update available? NO
May 17 17:22:54 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
May 17 17:23:24 --- last message repeated 2 times ---
May 17 17:23:24 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.quicklook[620]): Endpoint has been activated through legacy launch(3) APIs. Please switch to XPC or bootstrap_check_in(): com.apple.quicklook
May 17 17:23:38 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
May 17 17:24:18 --- last message repeated 1 time ---
May 17 17:25:48 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
May 17 17:26:17 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
May 17 17:26:49 Marcos-Mac-mini systemstats[78]: assertion failed: 17E202: systemstats + 914800 [D1E75C38-62CE-3D77-9ED3-5F6D38EF0676]: 0x40
May 17 17:27:44 Marcos-Mac-mini syslogd[65]: ASL Sender Statistics
May 17 17:29:50 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
May 17 17:30:25 --- last message repeated 1 time ---
May 17 17:30:48 Marcos-Mac-mini WhatsApp Helper[641]: objc[641]: Class NotificationCenterDelegate is implemented in both /Applications/WhatsApp.app/Contents/Frameworks/Electron Framework.framework/Versions/A/Electron Framework (0x110498ed8) and /Applications/WhatsApp.app/Contents/Resources/app.asar.unpacked/node_modules/node-mac-notifier/build/Release/Notification.node (0x115be09f8). One of the two will be used. Which one is undefined.
May 17 17:31:17 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
May 17 17:31:17 --- last message repeated 1 time ---
May 17 17:31:17 Marcos-Mac-mini parsecd[429]: libcoreservices: _dirhelper: 666: mkdir: path=/var/folders/p9/c4tx3sdn3698tfrs3htf54bw0000gn/0/com.apple.parsecd/ modes[0]=0755: Operation not permitted
May 17 17:31:18 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
May 17 17:31:28 --- last message repeated 4 times ---
May 17 17:31:28 Marcos-Mac-mini parsecd[429]: BUG in libdispatch client: dispatch_mig_server: mach_msg() failed (ipc/send) msg too small - 0x10000008
May 17 17:31:44 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.WebKit.Storage.9B6E3B81-7915-4278-980E-67B4FABDF3A8[648]): Service exited with abnormal code: 1
May 17 17:31:44 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.WebKit.Networking.EB16AB18-B4FB-4DB0-9E85-BAB340C0E30F[646]): Service exited with abnormal code: 1
May 17 17:31:52 Marcos-Mac-mini systemstats[78]: assertion failed: 17E202: systemstats + 914800 [D1E75C38-62CE-3D77-9ED3-5F6D38EF0676]: 0x40
May 17 17:31:53 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.imfoundation.IMRemoteURLConnectionAgent): Unknown key for integer: _DirtyJetsamMemoryLimit
May 17 18:42:15 Marcos-Mac-mini syslogd[65]: ASL Sender Statistics
May 17 18:42:16 Marcos-Mac-mini Dropbox[444]: [0517/184216:WARNING:dns_config_service_posix.cc(306)] Failed to read DnsConfig.
May 17 18:42:22 Marcos-Mac-mini netbiosd[657]: DEPRECATED USE in libdispatch client: Setting timer interval to 0 requests a 1ns timer, did you mean FOREVER (a one-shot timer)?
May 17 19:27:05 Marcos-Mac-mini syslogd[65]: ASL Sender Statistics
May 17 19:27:06 Marcos-Mac-mini Dropbox[444]: [0517/192706:WARNING:dns_config_service_posix.cc(306)] Failed to read DnsConfig.
May 17 19:27:06 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.preference.displays.MirrorDisplays): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
May 17 19:27:08 Marcos-Mac-mini timed[107]: settimeofday({0x5afdbb6c,0x996bc}) == 0
May 17 19:27:10 Marcos-Mac-mini timed[107]: settimeofday({0x5afdbb6e,0xdffaa}) == 0
May 17 19:27:12 Marcos-Mac-mini netbiosd[675]: DEPRECATED USE in libdispatch client: Setting timer interval to 0 requests a 1ns timer, did you mean FOREVER (a one-shot timer)?
May 17 19:27:16 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.preference.displays.MirrorDisplays): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
May 17 19:27:46 --- last message repeated 2 times ---
May 17 19:27:46 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.preference.displays.MirrorDisplays): Service only ran for 0 seconds. Pushing respawn out by 10 seconds.
May 17 19:27:50 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.WebKit.Storage.0F098542-1452-4D09-8025-BBED5829FB9C[584]): Service exited with abnormal code: 1
May 17 19:27:50 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.WebKit.Networking.686DADB0-F972-4356-8F17-1C1B07A1F3DD[496]): Service exited with abnormal code: 1
May 17 19:27:50 Marcos-Mac-mini systemstats[78]: assertion failed: 17E202: systemstats + 914800 [D1E75C38-62CE-3D77-9ED3-5F6D38EF0676]: 0x40
May 17 19:27:52 --- last message repeated 1 time ---
May 17 19:27:52 Marcos-Mac-mini garcon[436]: Garcon destroyed (0 alive).
May 17 19:27:52 Marcos-Mac-mini Finder[366]: BUG in libdispatch client: kevent[mach_recv] monitored resource vanished before the source cancel handler was invoked
May 17 19:27:52 Marcos-Mac-mini systemstats[78]: assertion failed: 17E202: systemstats + 914800 [D1E75C38-62CE-3D77-9ED3-5F6D38EF0676]: 0x40
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.xpc.launchd.user.domain.501.100007.Aqua): Caller not allowed to perform action: loginwindow.120, action = service removal, code = 150: Operation not permitted while System Integrity Protection is engaged, uid = 0, euid = 501, gid = 20, egid = 20, asid = 100007
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.talagent[363]): Service exited due to signal: Killed: 9 sent by loginwindow[120]
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.dropbox.activityprovider[529]): Service exited due to signal: Killed: 9 sent by loginwindow[120]
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.CoreLocationAgent[492]): Service exited due to signal: Killed: 9 sent by loginwindow[120]
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.wifi.WiFiAgent[502]): Service exited due to signal: Killed: 9 sent by loginwindow[120]
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.wacom.WacomTouchDriver.4332[485]): Service exited with abnormal code: 1
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.noticeboard.agent[479]): Service exited due to signal: Killed: 9 sent by loginwindow[120]
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.cloudphotosd[389]): Service exited due to signal: Killed: 9 sent by loginwindow[120]
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.storeuid[535]): Service exited due to signal: Killed: 9 sent by loginwindow[120]
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.AirPlayUIAgent[476]): Service exited due to signal: Killed: 9 sent by loginwindow[120]
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (2BUA8C4S2C.com.agilebits.onepassword-osx-helper[468]): Service exited due to signal: Killed: 9 sent by loginwindow[120]
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.SystemUIServer.agent[364]): Service exited due to signal: Killed: 9 sent by loginwindow[120]
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.Siri.agent[470]): Service exited with abnormal code: 1
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.imklaunchagent[438]): Service exited due to signal: Terminated: 15 sent by loginwindow[120]
May 17 19:27:52 Marcos-Mac-mini filecoordinationd[407]: BUG in libdispatch client: kevent[mach_recv] monitored resource vanished before the source cancel handler was invoked
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.universalaccessd[360]): Service exited due to signal: Killed: 9 sent by loginwindow[120]
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.apple.coreservices.uiagent[490]): Service exited due to signal: Killed: 9 sent by loginwindow[120]
May 17 19:27:52 Marcos-Mac-mini com.apple.xpc.launchd[1] (com.wacom.wacomtablet[465]): Service exited with abnormal code: 1
May 17 19:27:53 Marcos-Mac-mini systemstats[78]: assertion failed: 17E202: systemstats + 914800 [D1E75C38-62CE-3D77-9ED3-5F6D38EF0676]: 0x40
May 17 19:27:53 --- last message repeated 5 times ---
May 17 19:27:53 Marcos-Mac-mini sessionlogoutd[695]: DEAD_PROCESS: 120 console
May 17 19:27:53 Marcos-Mac-mini shutdown[696]: SHUTDOWN_TIME: 1526578073 361882
Per controllare se ho applicato bene la pasta termica, metto sotto stress la CPU per più di dodici ore (se sono buono) o più di 24 ore quando ho seri dubbi... Non sulla pasta termica, ma sulla CPU..PeT ha scritto:si può essere. credevo che per mettere sotto test un mac non ci volesse l’eternità. nella mail che ho ricevuto giovedì scorso indicavano “Turnaround time stimato: Ti chiameremo entro 48 ore” e il “Genius” che mi ha ritirato il computer ha detto ci vorranno 2/3 gg max. okok
Visitano il forum: Brandwatch [Crawler], ZoomBot [Bot] e 14 ospiti
