spegahsheen ha scritto:Seguendo il link di KP si può arrivare
QUI
Premesso che [quasi] non ci capisco una cippa di linguaggio informatico e che ho solo letto qualche paragrafo al volo, mi pare di percepire che tutte queste spiegazioni così dettagliate rese pubbliche, potrebbero essere utili a chiunque voglia provare ad approfittarne di queste falle, ho sbaglio?
Mi riferisco a paragrafi come questo:
"To be able to actually use this behavior for an attack, an attacker needs to be able to cause the execution of such a vulnerable code pattern in the targeted context with an out-of-bounds index. For this, the vulnerable code pattern must either be present in existing code, or there must be an interpreter or JIT engine that can be used to generate the vulnerable code pattern. So far, we have not actually identified any existing, exploitable instances of the vulnerable code pattern; the PoC for leaking kernel memory using variant 1 uses the eBPF interpreter or the eBPF JIT engine, which are built into the kernel and accessible to normal users.
A minor variant of this could be to instead use an out-of-bounds read to a function pointer to gain control of execution in the mis-speculated path. We did not investigate this variant further."
Oppure:
"Attacking the kernel
This section describes in more detail how variant 1 can be used to leak Linux kernel memory using the eBPF bytecode interpreter and JIT engine. While there are many interesting potential targets for variant 1 attacks, we chose to attack the Linux in-kernel eBPF JIT/interpreter because it provides more control to the attacker than most other JITs.
The Linux kernel supports eBPF since version 3.18. Unprivileged userspace code can supply bytecode to the kernel that is verified by the kernel and then:
either interpreted by an in-kernel bytecode interpreter
or translated to native machine code that also runs in kernel context using a JIT engine (which translates individual bytecode instructions without performing any further optimizations)
Execution of the bytecode can be triggered by attaching the eBPF bytecode to a socket as a filter and then sending data through the other end of the socket.
Whether the JIT engine is enabled depends on a run-time configuration setting - but at least on the tested Intel processor, the attack works independent of that setting."
